    4. Kein Zugriff mehr auf IO-Broker nach Update Admin-Adapter
    UNSOLVED Kein Zugriff mehr auf IO-Broker nach Update Admin-Adapter
      sigi234 Forum Testing Most Active @datenkrake156 last edited by
      @datenkrake156
      Was kommt bei:
      iobroker list instances
      node -v
      nodejs -v
      npm -v
        datenkrake156 @Jan1 last edited by Negalein
        @Jan1
        Hallo Jan1, danke für die schnelle Antwort,
        Habe diese Angabe mit Fragezeichen gemacht, da ich in einer Datei
        "iobroker_20201210.out.log" diese Einträge gefunden habe:
        ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
        ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
        ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
        Send diag info: {"uuid":"b4898d28-b1b9-46a3-1fae-5a2565dd1417","language":"de","hosts":[{"**version":"3.1.4**","platform":"Javascript/Node.js","type":"win32"}],"node":"v12.17.0","arch":"x64","adapters":{"admin":{"version":"4.1.11","platform":"Javascript/Node.js"},"discovery":{"version":"2.3.11","platform":"Javascript/Node.js"},"info":{"version":"1.7.10","platform":"Javascript/Node.js"},"alexa2":{"version":"3.3.5","platform":"Javascript/Node.js"},"coronavirus-statistics":{"version":"0.6.3","platform":"Javascript/Node.js"},"dwd":{"version":"2.5.1","platform":"javascript/Node.js"},"tr-064":{"version":"4.2.1","platform":"Javascript/Node.js"},"fritzdect":{"version":"0.2.4","platform":"Javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"},"loxone":{"version":"2.0.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.4.8","platform":"Javascript/Node.js"},"openweathermap":{"version":"0.1.0","platform":"Javascript/Node.js"},"odl":{"version":"1.0.7","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.0.5","platform":"javascript/Node.js"},"ical":{"version":"1.7.4","platform":"Javascript/Node.js"},"trashschedule":{"version":"1.0.3","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.2.1","platform":"Javascript/Node.js"},"hue":{"version":"3.3.8","platform":"Javascript/Node.js"},"feiertage":{"version":"1.0.17","platform":"javascript/Node.js"},"ping":{"version":"1.4.12","platform":"Javascript/Node.js"},"squeezebox":{"version":"1.0.0","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.14.24","platform":"Javascript/Node.js"},"hue-extended":{"version":"1.2.3","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.4","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"sayit":{"version":"1.12.2","platform":"Javascript/Node.js"},"email":{"version":"1.0.7","platform":"Javascript/Node.js"},"influxdb":{"version":"1.9.3","platform":"Javascript/Node.js"},"luftdaten":{"version":"1.0.1","platform":"Javascript/Node.js"},"nina":
        ```{"version":"0.0.23","platform":"Javascript/Node.js"},"backitup"
          @datenkrake156
          Bitte benutzt die Code Tags Funktion -> </>
          Hier gehts zur Hilfe.
            datenkrake156 @sigi234 last edited by
            @sigi234 sagte in Kein Zugriff mehr auf IO-Broker nach Update Admin-Adapter:
            Hallo Sigi,
            vielen Dank. Von Dir habe ich mir einige Ideen für den wetter-View gemaust. Ich hoffe, ich habe die Eingabe an der Richtigen Stelle gemacht, leider ohne Ergebnis:
              @datenkrake156
              wenn du mit den Installer installiert hast dann hier:
                @sigi234
                Hallo Sigi,
                die Installation vor ca. 6 Monaten war eine Katastrophe. Das Tool aus dem Downloadbereich setzte auf Node 10 auf, einige Adapter verlangten aber Node 12.
                In den Untiefen des Forums hatte ich dann eine Anleitung gefunden, nach der ich manuell das Node-update durchgeführt habe. Seit dem funktionierte IO. Er hängt sich zwar immer mal auf, aber das ist jetzt ein anderes Thema.
                Node und npm
                Nodejs
                Für list instances gab es nur Fehlermeldungen.
                Homoran sigi234 2 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @datenkrake156 last edited by
                  @datenkrake156 sagte in Kein Zugriff mehr auf IO-Broker nach Update Admin-Adapter:
                  Da könnten aber auch falsche (?) oder veraltete Informationen drin stehen.
                  Es können nicht alle Threads umgeschrieben werden wenn sich nach Jahren etwas ändert.
                  von wann war denn jener Thread?
                  Bitte keine Screenshots mit logs, sondern als Text in code-tags posten!
                    sigi234 Forum Testing Most Active @datenkrake156 last edited by sigi234
                    @datenkrake156
                    Das kennst du?
                    https://forum.iobroker.net/topic/33421/iobroker-unter-windows-installieren-ohne-installer/125
                      @sigi234
                      @Homoran
                      Ja genau, das war der Thread, an dem ich mich Anfang Juni orientiert hatte, damals also praktisch tagesaktuell (Paladin, Aktualisierung Node Mitte Mai). Danach liefen ja dann auch alle Adapter.
                      Im Registrierungseditor habe ich jetzt noch gefunden:
                      Sehr Ihr jetzt noch eine Möglichkeit, den Admin-Adapter irgendwie manuell anzuschubsen, oder ratet Ihr mir wirklich zu einer Neuinstallation? Für die nächste Woche habe ich mir eigentlich andere Sachen geplant. 😕
                        datenkrake156 @datenkrake156 last edited by
                        Für andere Windows-Nutzer eventuell als Hilfestellung:
                        Nach viel Suchen habe ich auf einer Windows-Seite die Syntax-Lösung gefunden.
                        In der Eingabeaufforderung auf das IO-Broker-Verzeichnis (und ggf. wie bei mir die entsprechende Instanz) gehen, dort dann
                        node node_modules/iobroker.js-controller/iobroker.js list instances eingeben.
                        Wie erwartet stand der admin-Adapter auf disabled.
                        Mit der Eingabe "node node_modules/iobroker.js-controller/iobroker.js start admin" konnte ich ihn wieder anstupsen. Im Browser war dann sofort alles wieder erreichbar. Das Update des Admin-Adapters auf die Version 4.1.11 hatte sogar auch funktioniert.
                        Bin heilfroh, daß mir die Neuinstallation erspart geblieben ist!
                        Allen trotz der miserablen Rahmenbedingungen einen schönen Restadvent.
                        Bleibt Negativ!
                        adapter admin windows
                        882
