    4. Test Adapter enigma2 v1.2.x
    • hg6806
      hg6806 Most Active last edited by hg6806
      Seit 1 Woche habe ich nun eine Dreambox One, jedoch bleibt der Adapter immer rot.
      Weiß jemand ob und was da anders ist? Port 80?
      Hier ein Log:
      enigma2.0	2020-12-16 13:16:53.305	error	(30964) TypeError: Cannot read property 'e2currentserviceinformation' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:436:10) at /opt/iobroker/n
      enigma2.0	2020-12-16 13:16:53.305	error	(30964) uncaught exception: Cannot read property 'e2currentserviceinformation' of undefined
      enigma2.0	2020-12-16 13:16:53.301	error	(30964) TypeError: Cannot read property 'e2volume' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:416:13) at /opt/iobroker/node_modules/iobroke
      enigma2.0	2020-12-16 13:16:53.300	error	(30964) uncaught exception: Cannot read property 'e2volume' of undefined
      enigma2.0	2020-12-16 13:16:53.296	error	(30964) TypeError: Cannot read property 'e2abouts' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:547:51) at /opt/iobroker/node_modules/iobroke
      enigma2.0	2020-12-16 13:16:53.295	error	(30964) uncaught exception: Cannot read property 'e2abouts' of undefined
      enigma2.0	2020-12-16 13:16:53.291	error	(30964) TypeError: Cannot read property 'e2simplexmlresult' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:382:46) at /opt/iobroker/node_module
      enigma2.0	2020-12-16 13:16:53.291	error	(30964) uncaught exception: Cannot read property 'e2simplexmlresult' of undefined
      enigma2.0	2020-12-16 13:16:53.281	error	(30964) TypeError: Cannot read property 'e2powerstate' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:403:63) at /opt/iobroker/node_modules/iob
      enigma2.0	2020-12-16 13:16:53.280	error	(30964) uncaught exception: Cannot read property 'e2powerstate' of undefined
      Irgendwie scheint die Box keine Verbindung zu bekommen. IP, Benutzer und PW stimmen aber.
      Thomas Braun Meister Mopper E 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @hg6806 last edited by
        @hg6806
        Die Meldungen sind abgeschnitten. Bitte aus dem log file die vollständen Meldungen posten.
        • Meister Mopper
          Meister Mopper @hg6806 last edited by
          @hg6806 Wie ist das webinterface eingestellt: http oder https?
            el_malto @hg6806 last edited by
            @hg6806 wenn du das originale DreamOS drauf hast, benutzt dieses nicht das OpenWebIF sonder das Webinterface. Du musst in den Adaptereinstellungen unter "Webinterface Version" das "Dream Webinterface" auswählen.
            Ansonsten kann du auch das OpenWebTF nachinstallieren. Müsstest halt höchstens die Ports anpassen und dann kann der Adapter über das OpenWebIF laufen.
            • hg6806
              hg6806 Most Active @el_malto last edited by
              @el_malto
              Wo finde ich denn die Adaptereinstellungen?
              In der Adapterkonfiguration ist nichts.
              • dslraser
                dslraser Forum Testing Most Active @hg6806 last edited by
                @hg6806 sagte in Test Adapter enigma2 v1.2.x:
                @el_malto
                hg6806 1 Reply Last reply Reply Quote 1
                • hg6806
                  hg6806 Most Active @dslraser last edited by
                  @dslraser
                  Ähhh, und genau das fehlt mir
                  J haselchen 2 Replies Last reply Reply Quote 0
                    Jan1 @hg6806 last edited by
                    @hg6806
                    welche Adapter Version läuft denn bei Dir?
                    • haselchen
                      haselchen Most Active @hg6806 last edited by
                      @hg6806
                      Von den Screenshots her habt ihr beide verschiedene Adapter Versionen.
                      • hg6806
                        hg6806 Most Active @haselchen last edited by
                        V1.2.3, was neueres wird mir nicht angeboten
                        dslraser J 2 Replies Last reply Reply Quote 0
                        • dslraser
                            @hg6806
                            normal endet hier die Hilfe, wenn einer nicht in der Lage ist den ersten und meist wichtigsten Post eines Adapter Thread zu lesen.
                            • hg6806
                              Sorry, hatte übersehen dass es auf Git neuere Versionen gibt.
                              Habe Dream Webinterface eingestellt, geht aber leider immer noch nicht.
                              Muss ich auf der Box noch was einstellen?
                                @hg6806
                                Schalt mal in den Einstellungen der Box das ganze Firewall Zeug aus.
                                • hg6806
                                  hg6806 Most Active @Jan1 last edited by
                                  @Jan1
                                  Klappt. Tausend Dank!
                                    @hg6806
                                    Dann kannst das mal wieder eins nach dem anderen anschalten uns schauen welche Einstellung den Adapter blockiert.
                                    • hg6806
                                      @Jan1 ok
                                        Sekretär last edited by
                                        Hallo, ich hatte heute mal wieder etwas Zeit zum spielen. Habe im Enigma2 Adapter den vorhandenen Punkt enigma2.0./command REMOTE-CONTROL "enigma2 send remote control command as number" über Alexa eingebunden. Das funktioniert aber die Zahl stimmt nicht. Ich sage "schalte Fernseher 3" und es wird auf Kanal 2 geschalten. Ich weiß nicht wo die Zahlen im Adapter hinterlegt sind und an meiner Dreambox kann ich keinen Kanal "0" anlegen. Sonst würde es ja vielleicht funktionieren.
                                        Kann da jemand helfen?
                                        • Negalein
                                          Negalein Global Moderator @Sekretär last edited by
                                          @Sekretär sagte in Test Adapter enigma2 v1.2.x:
                                          3=2
                                          4=3
                                          usw.
                                          116 Key "Power"
                                          2   Key "1"
                                          3   Key "2"
                                          4   Key "3"
                                          5   Key "4"
                                          6   Key "5"
                                          7   Key "6"
                                          8   Key "7"
                                          9   Key "8"
                                          10  Key "1"
                                          11  Key "0"
                                          412 Key "previous"
                                          407 Key "next
                                          115 Key "volume up"
                                          113 Key "mute"
                                          402 Key "bouquet up"
                                          114 Key "volume down"
                                          174 Key "lame"
                                          403 Key "bouquet down"
                                          358 Key "info"
                                          103 Key "up"
                                          139 Key "menu"
                                          105 Key "left"
                                          352 Key "OK"
                                          106 Key "right"
                                          392 Key "audio"
                                          108 Key "down"
                                          393 Key "video"
                                          398 Key "red"
                                          399 Key "green"
                                          400 Key "yellow"
                                          401 Key "blue"
                                          377 Key "tv"
                                          385 Key "radio"
                                          388 Key "text"
                                          138 Key "help"
                                            Das ist gut aber ich habe noch gar keine Zahlen vergeben. Irgendwo muss die Zahl ja herkommen? Ich habe einfach im iot.0
                                            den Punkt:
                                            Fernseher
                                            angelegt, der wird von Alexa erkannt und es wird umgeschaltet. Wo kommt dann die Zahl her?
                                            adapter enigma2
                                            71
                                            640
                                            141546
