    4. Test Adapter MyQ v0.1.x GitHub
      chhe last edited by
      Habe hier seit kurzem das gleiche Problem. Hier mein log:
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.834	info	Restart adapter system.adapter.myq.0 because enabled
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.834	info	instance system.adapter.myq.0 terminated with code 0 (NO_ERROR)
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.834	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.834	error	Caught by controller[0]: at endReadableNT (_stream_readable.js:1143:12)
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.834	error	Caught by controller[0]: at IncomingMessage.emit (events.js:203:15)
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.834	error	Caught by controller[0]: at Object.onceWrapper (events.js:286:20)
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.834	error	Caught by controller[0]: at IncomingMessage.<anonymous> (E:\ioBroker\SmartHome\node_modules\request\request.js:1083:12)
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.834	error	Caught by controller[0]: at Request.emit (events.js:198:13)
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.834	error	Caught by controller[0]: at Request.<anonymous> (E:\ioBroker\SmartHome\node_modules\request\request.js:1161:10)
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.833	error	Caught by controller[0]: at Request.self.callback (E:\ioBroker\SmartHome\node_modules\request\request.js:185:22)
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.833	error	Caught by controller[0]: at Request._callback (E:\ioBroker\SmartHome\node_modules\iobroker.myq\lib\myq.js:102:32)
      host.HomeServer(SmartHome)	2020-07-06 16:58:51.833	error	Caught by controller[0]: TypeError: controller.context.stop is not a function
      myq.0	2020-07-06 16:58:51.297	info	(1220) Terminated (NO_ERROR): Without reason
      myq.0	2020-07-06 16:58:51.297	info	(1220) terminating
      myq.0	2020-07-06 16:58:51.290	error	(1220) TypeError: controller.context.stop is not a function at Request._callback (E:\ioBroker\SmartHome\node_modules\iobroker.myq\lib\myq.js:102:32) at Request.self.callback (E:\ioBroker\Smart
      myq.0	2020-07-06 16:58:51.289	error	(1220) uncaught exception: controller.context.stop is not a function
      myq.0	2020-07-06 16:58:51.284	warn	(1220) Login failed.
      myq.0	2020-07-06 16:58:50.712	info	(1220) [INFO] Configured polling interval: 10000
      myq.0	2020-07-06 16:58:50.705	info	(1220) [START] Starting MyQ adapter
      myq.0	2020-07-06 16:58:50.693	info	(1220) starting. Version 0.1.2 in E:/ioBroker/SmartHome/node_modules/iobroker.myq, node: v10.17.0
      • andrix.iobroker
        andrix.iobroker last edited by
        Hallo Marius!
        Seit einer Woche funktioniert der Adapter MyQ bei mir nicht mehr (ab Juli 2020 war alles in Ordnung). Die Log-Daten zum Fehler sind wie folgt:
        host.iobroker 2020-10-04 10:27:30.424 info Do not restart adapter system.adapter.myq.0 because disabled or deleted
        host.iobroker 2020-10-04 10:27:30.423 error instance system.adapter.myq.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        myq.0 2020-10-04 10:27:29.902 warn (6530) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        myq.0 2020-10-04 10:27:29.896 error (6530) adapter disabled
        host.iobroker 2020-10-04 10:27:16.197 info "system.adapter.myq.0" disabled
        host.iobroker 2020-10-04 10:26:59.008 info Restart adapter system.adapter.myq.0 because enabled
        host.iobroker 2020-10-04 10:26:59.008 info instance system.adapter.myq.0 terminated with code 0 (NO_ERROR)
        myq.0 2020-10-04 10:26:58.491 info (6515) Terminated (NO_ERROR): Without reason
        myq.0 2020-10-04 10:26:58.491 info (6515) terminating
        myq.0 2020-10-04 10:26:58.484 warn (6515) Login failed.
        myq.0 2020-10-04 10:26:57.983 info (6515) [INFO] Configured polling interval: 10000
        myq.0 2020-10-04 10:26:57.981 info (6515) [START] Starting MyQ adapter
        myq.0 2020-10-04 10:26:57.967 info (6515) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.myq, node: v12.18.0, js-controller: 3.1.6
        host.iobroker 2020-10-04 10:26:57.182 info instance system.adapter.myq.0 started with pid 6515
        host.iobroker 2020-10-04 10:26:27.170 info Restart adapter system.adapter.myq.0 because enabled
        host.iobroker 2020-10-04 10:26:27.169 info instance system.adapter.myq.0 terminated with code 0 (NO_ERROR)
        myq.0 2020-10-04 10:26:26.650 info (6500) Terminated (NO_ERROR): Without reason
        myq.0 2020-10-04 10:26:26.649 info (6500) terminating
        myq.0 2020-10-04 10:26:26.643 warn (6500) Login failed.
        myq.0 2020-10-04 10:26:23.606 info (6500) [INFO] Configured polling interval: 10000
        myq.0 2020-10-04 10:26:23.602 info (6500) [START] Starting MyQ adapter
        myq.0 2020-10-04 10:26:23.589 info (6500) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.myq, node: v12.18.0, js-controller: 3.1.6
        host.iobroker 2020-10-04 10:26:22.764 info instance system.adapter.myq.0 started with pid 6500
        host.iobroker 2020-10-04 10:26:22.737 info "system.adapter.myq.0" enabled
        Die Login-Daten sind dabei vollkommen korrekt: die MyQ-Apps auf iPhone, Android und Plugin auf Homebridge-Server laufen ordnungsgemäß.
        Nur der MyQ-Adapter in iobroker geht nicht mehr und die Instanz bleibt immer rot.
        Gibt es irgendwelche Ratschläge, was ist zu tun?
        Danke.
        MyQ Adapter 0.1.2
        Ubuntu Server 18.04.5 LTS
        Node 12.18.0
        NPM 6.14.8
        JS controller 3.1.6
        StrathCole 1 Reply Last reply Reply Quote 0
        • StrathCole
          StrathCole @andrix.iobroker last edited by
          @andrix-iobroker Oha. Ich habe gerade gemerkt, dass ich auch Login-Fehler bekomme. Vielleicht muss ich auf eine neue API-Version umstellen 😩
          andrix.iobroker 1 Reply Last reply Reply Quote 0
          • andrix.iobroker
            andrix.iobroker @StrathCole last edited by
            Hallo Marius,
            vielen Dank für diese schnelle Reaktion!
            Ja, es wäre sehr hilfreich für alle MyQ-Adapter-Freunde, eine entsprechende Umstellung vorzunehmen.
            Danke.
              chhe @andrix.iobroker last edited by
              auch ich bekomme einige Fehlermeldungen im Log. Der Adapter kann sich entsprechend auch nicht mehr verbinden.
              Wäre super, wenn du ihn updaten könntest... Vielen Dank!
                chhe @chhe last edited by
                @StrathCole
                konnte das Problem bereits behoben werden?
                • N
                  NormanBates last edited by
                  ich bin neu hier, und versuche mir gerade einen Überblick über ioBroker und die verfügbaren Adapter und die, die ich benötige zu machen - darunter auch den MyQ-Adapter.
                  MyQ scheint eine neue API v5 zu besitzen. Eine fertige JS-Komponente, die die v5 unterstützt, existiert bereits: https://github.com/thomasmunduchira/myq-api
                  Im Prinzip sollte es kein Hexenwerk sein, die Implementierung im Projekt dagegen auszutauschen - riesig sind die Unterschiede nicht.
                  • StrathCole
                    StrathCole @NormanBates last edited by
                    @NormanBates Danke für die Info.
                    https://github.com/StrathCole/ioBroker.myq/issues/2#issuecomment-724624190
                    chhe-01 created this issue in StrathCole/ioBroker.myq
                    closed myq adapter can't connect #2
                    • N
                      NormanBates @StrathCole last edited by
                      @StrathCole said in Test Adapter MyQ v0.1.x GitHub:
                      Sehr cool, vielen Dank für die schnelle Reaktion. Funktioniert einwandfrei!
                        chhe @NormanBates last edited by
                        @StrathCole
                        es bestehen wieder Verbindungsprobleme mit dem MyQ Adapter...
                        Verbindung zu MyQ schlägt fehl.
                        • StrathCole
                          StrathCole @chhe last edited by
                          @chhe github Version? Geht denn die normale MyQ App?
                            chhe @StrathCole last edited by chhe
                            @StrathCole
                            Ja, github Version. Installiert wie hier beschrieben. link
                            Seitdem lief es auch. Aber seit gestern oder heute besteht das Problem beschriebene Problem. Die normale MyQ App funktioniert problemlos.
                              @StrathCole
                              Nachdem es über die Feiertage zwischenzeitlich wieder funktionierte, geht es nun wieder nicht.
                              Der Adapter ist zwar verbunden und die "Ampel" auf grün. Es werden jedoch keine Aktionen (Öffnen/Schließen) angenommen. Über die myQ App funktioniert es problemlos.
                              Ich kann nur allen von diesem Adapter abraten. Ständig treten Probleme auf... Wer das Teil halbwegs professionell einsetzen möchte, sollte sich dringend nach einer anderen Lösung umsehen!
                              • StrathCole
                                StrathCole @chhe last edited by StrathCole
                                @chhe Es gibt leider keine offizielle API von myq. Der Adapter verwendet inzwischen die Bibliothek myq-api von hier: https://github.com/thomasmunduchira/myq-api doch auch die kann sich derzeit nicht verbinden, da myq auf eine neue API-Version umgestellt hat. Wie gesagt, sind die Spezifikationen der API nicht öffentlich und es müssen sich immer erst Leute finden, die das "entschlüsseln".
                                Siehe auch hier: https://github.com/thomasmunduchira/myq-api/issues/34 und https://github.com/thomasmunduchira/myq-api/issues/35
                                nsnyder created this issue in thomasmunduchira/myq-api
                                open V6 Support #34
                                johndc7 created this issue in thomasmunduchira/myq-api
                                closed Cannot run getDevices(): Unidentified error returned from service. #35
                                • StrathCole
                                  StrathCole @StrathCole last edited by StrathCole
                                  Aktuell ist es zumindest temporär wieder möglich, den Adapter zu starten und zu nutzen:
                                  Folgende Datei öffnen:
                                  /opt/iobroker/node_modules/myq-api/src/constants.js
                                  Zeile 46:
                                  ApiVersion: '5.1' ändern in ApiVersion: '5.2'
                                  Adapterinstanz neu starten.
                                    Matdos @StrathCole last edited by Matdos
                                    ist der Adapter noch aktuell?
                                    Finde ihn in Iobroker nicht, oder muss ich den über Putty installieren?
                                    Habe jetzt ein Liftmaster Antrib mit MyQ Gateway
                                    Grüsse Martin
                                      mikiline last edited by mikiline
                                      Hi Alle und @StrathCole , kann jemand bestätigen ob der Adapter funktioniert?
                                      Leider ist der Thread schon ziemlich alt und es wurde nicht auf die Frage von @Matdos genatwortet
                                      Danke!
                                        mikiline @mikiline last edited by
                                        Evtl hilft es hier weiter.....wird zumindest aktualisiert
                                        Link Text
                                          Ich kann hiermit bestätigen das der Adapter funktioniert, ohne Eingriffe in ein Skript.
                                          Wichtig ist bei dem Gateway 830REV das die Lichtschranken angeschlossen sind!
                                            deltaac @StrathCole last edited by deltaac
                                            Guten Morgen,
                                            nachdem ich am Wochenende den Adapter installiert habe, ist leider das Fehlerprotokoll immer wieder mit Error gefüllt:
                                            2023-09-11 06:55:31.900	debug	Result of refresh devices is false
                                            2023-09-11 06:55:31.900	info	Retrying refresh devices (30 seconds past)
                                            2023-09-11 06:55:01.904	debug	stateChange myq.0.info.connection
                                            2023-09-11 06:54:58.915	error	It seems that login failed. Either the server was unreachable or you used wrong credential. Please activate debug log to check.
                                            2023-09-11 06:54:58.915	error	Could not get device info.
                                            2023-09-11 06:54:58.913	error	myQ API: Unable to access the OAuth authorization endpoint.
                                            2023-09-11 06:54:58.912	error	myQ API: %s Error: %s %s
                                            {"val":false,"ack":true,"ts":16XXXXXXX1902,"q":0,"from":"system.adapter.myq.0","user":"system.user.admin","lc":1YYYYYYY11774}
                                            Prinzipiell funktioniert der Adapter jedoch, ich bin eingeloggt und bekomme auch den aktuellen Status von meinem Torantrieb angezeigt. Hat jemand hier einen Tip für mich?
                                            31.7k
                                            79.8k
                                            adapter chamberlain garagentor myq
                                            10
                                            24
                                            2309
