    5. Fenster und andere Geräte zählen opt. Alexa Ansagen
      sigi234 Forum Testing Most Active @dslraser last edited by
      @dslraser
      Türen werden nicht angezeigt in IQ?
      Version 1.6.2
        DocGame @dslraser last edited by
        @dslraser in meinen bisherigen Scripten habe ich 30 % eingestellt. Ich denke da bin ich auf der sicheren Seite. Ich wechsle lieber rechtzeitig bevor was nicht geht. Könnte mir vorstellen, das auch noch 20 ausreichen. Hier mal einige Raws (Ich habe zwar alle in LinkedDevice drin, hönge aber mal auch welche von anderen Adaptern an:
        LinkedDevice
          "type": "state",
          "common": {
            "name": "Bad Bewegung",
            "type": "number",
            "unit": "%",
            "read": true,
            "write": false,
            "role": "battery.percent",
            "min": 0,
            "max": 100,
            "icon": "linkeddevices_small.png",
            "custom": {
              "linkeddevices.0": {
                "enabled": true,
                "parentId": "zigbee.0.00158d0002b49103.battery",
                "parentType": "number",
                "isLinked": true,
                "mergeSettingsOnRestart": true
            "desc": "Created by linkeddevices"
          "native": {},
          "from": "system.adapter.linkeddevices.0",
          "user": "system.user.admin",
          "ts": 1608023510596,
          "_id": "linkeddevices.0.Bad.Bewegung.battery",
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.admin",
        Hue
          "_id": "hue.0.Hue_outdoor_ambient_light_sensor.battery",
          "type": "state",
          "common": {
            "name": "Hue outdoor ambient light sensor.battery",
            "read": true,
            "write": true,
            "type": "number",
            "role": "value.battery",
            "unit": "%",
            "def": 100
          "native": {
            "id": "3"
          "from": "system.adapter.hue.0",
          "ts": 1602015052397,
          "acl": {
            "object": 1636,
            "state": 1636,
        Mihome
          "_id": "mihome.0.devices.weather_v1_158d0003214163.percent",
          "common": {
            "name": "Battery percent",
            "write": false,
            "read": true,
            "type": "number",
            "unit": "%",
            "icon": "/icons/battery_p.png",
            "desc": "Battery level in percent",
            "min": 0,
            "max": 100,
            "custom": {
                "enabled": true,
                "number_unit": "",
                "linkedId": "Keller.Flaschenkeller.Temperatur.percent",
                "name": "Flaschenkeller Temperatur",
                "role": "",
                "mergeSettingsOnRestart": true,
                "expertSettings": false,
                "number_convertTo": "",
                "number_maxDecimal": "",
                "number_min": "",
                "number_max": "",
                "number_calculation": "",
                "number_calculation_readOnly": "",
                "number_to_boolean_condition": "",
                "number_to_boolean_value_true": "",
                "number_to_boolean_value_false": "",
                "number_to_string_condition": "",
                "number_to_duration_convert_seconds": "",
                "number_to_duration_format": "",
                "number_to_datetime_convert_seconds": "",
                "number_to_datetime_format": "",
                "number_to_multi_condition": "",
                "boolean_convertTo": "",
                "boolean_to_string_value_true": "",
                "boolean_to_string_value_false": "",
                "string_convertTo": "",
                "string_prefix": "",
                "string_suffix": "",
                "string_to_boolean_value_true": "",
                "string_to_boolean_value_false": "",
                "string_to_number_unit": "",
                "string_to_number_maxDecimal": "",
                "string_to_number_calculation": "",
                "string_to_number_calculation_readOnly": "",
                "string_to_duration_format": "",
                "string_to_datetime_parser": "",
                "string_to_datetime_format": ""
          "type": "state",
          "native": {},
          "from": "system.adapter.mihome.0",
          "ts": 1597959250641,
          "acl": {
            "object": 1636,
            "state": 1636,
        Zigbee
          "type": "state",
          "common": {
            "type": "number",
            "unit": "%",
            "read": true,
            "write": false,
            "min": 0,
            "max": 100,
            "icon": "img/battery_p.png",
            "custom": {
                "enabled": true,
                "number_unit": "",
                "linkedId": "Gästezimmer.Schalter.Licht-Rollo.battery",
                "name": "Gästezimmer Schalter Licht-Rollo battery",
                "role": "",
                "number_min": "",
                "number_max": "",
          "native": {},
          "from": "system.adapter.zigbee.0",
          "ts": 1604773037924,
          "_id": "zigbee.0.04cf8cdf3c75b44a.battery",
          "acl": {
            "object": 1636,
            "state": 1636,
        Wenn du noch was brauchst...kein Problem.
        Ps: Das Fensteblockly klappt 1A... Danke
        • dslraser
          dslraser Forum Testing Most Active @sigi234 last edited by
          @sigi234
          hm....bei mir zeigt es richtig an.
          Ich schaue morgen mal...
          • dslraser
            dslraser Forum Testing Most Active @DocGame last edited by
            @DocGame
            ich könnte die Warnschwelle ja einstellbar machen.
            • dslraser
              dslraser Forum Testing Most Active @sigi234 last edited by dslraser
              @sigi234
              bei Dir ist auch die gesamte Türenliste (07) leer...., seltsam
              Edit: sieht bei mir so aus
                @dslraser sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
                @sigi234
                Jupp, alle anderen Blockly funktionieren.
                Stephan Schleich 1 Reply Last reply Reply Quote 0
                • Stephan Schleich
                  Stephan Schleich @sigi234 last edited by Stephan Schleich
                  @dslraser Batterie Prozent:
                    "fritzdect.0.Comet_133560281368": {
                      "type": "channel",
                      "common": {
                        "name": "Wohnzimmer Comet DECT",
                        "role": "thermo.heat"
                      "native": {
                        "aid": "133560281368"
                      "from": "system.adapter.fritzdect.0",
                      "ts": 1601731472046,
                      "_id": "fritzdect.0.Comet_133560281368",
                      "acl": {
                        "object": 1636,
                    "fritzdect.0.Comet_133560281368.actualtemp": {
                      "type": "state",
                      "common": {
                        "name": "Actual Temp",
                        "type": "number",
                        "unit": "°C",
                        "role": "value.temperature",
                        "desc": "Actual Temp",
                        "read": true,
                        "write": false
                      "native": {},
                      "ts": 1601731472052,
                      "_id": "fritzdect.0.Comet_133560281368.actualtemp",
                      "acl": {
                        "object": 1636,
                        "state": 1636
                    "fritzdect.0.Comet_133560281368.battery": {
                      "type": "state",
                      "common": {
                        "name": "Comet Dect Wohnzimmer - Battery",
                        "type": "number",
                        "unit": "%",
                        "read": true,
                        "write": false,
                        "desc": "Battery",
                        "enums": [
                            "_id": "enum.functions.batterie_prozent",
                            "common": {
                              "name": "Batterie_Prozent",
                              "icon": "data:image/png;base64,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",
                              "color": false
                      "native": {},
                      "ts": 1601731472053,
                      "_id": "fritzdect.0.Comet_133560281368.battery",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.batterylow": {
                      "type": "state",
                      "common": {
                        "name": "low Battery",
                        "type": "boolean",
                        "read": true,
                        "write": false,
                        "role": "indicator"
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.batterylow",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.comfytemp": {
                      "type": "state",
                      "common": {
                        "name": "Comfort Temp",
                        "type": "number",
                        "unit": "°C",
                        "read": true,
                        "write": false,
                        "desc": "Comfort Temp"
                      "native": {},
                      "ts": 1601737946327,
                      "_id": "fritzdect.0.Comet_133560281368.comfytemp",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.devicelock": {
                      "type": "state",
                      "common": {
                        "name": "Thermostat Button lock",
                        "type": "boolean",
                        "read": true,
                        "write": false,
                        "role": "indicator"
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.devicelock",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.errorcode": {
                      "type": "state",
                      "common": {
                        "name": "errorcode",
                        "type": "number",
                        "read": true,
                        "write": false,
                        "role": "indicator"
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.errorcode",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.fwversion": {
                      "type": "state",
                      "common": {
                        "name": "FW version",
                        "type": "string",
                        "read": true,
                        "write": false,
                        "role": "text",
                        "desc": "firmware version"
                      "native": {},
                      "ts": 1601731472049,
                      "_id": "fritzdect.0.Comet_133560281368.fwversion",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.holidayactive": {
                      "type": "state",
                      "common": {
                        "name": "Product Name",
                        "type": "boolean",
                        "read": true,
                        "write": false,
                        "role": "indicator",
                        "desc": "Product Name"
                      "native": {},
                      "ts": 1601731472054,
                      "_id": "fritzdect.0.Comet_133560281368.holidayactive",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.id": {
                      "type": "state",
                      "common": {
                        "name": "ID",
                        "type": "string",
                        "read": true,
                        "write": false,
                        "role": "text",
                        "desc": "ID"
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.id",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.lasttarget": {
                      "type": "state",
                      "common": {
                        "name": "last setting of target temp",
                        "type": "number",
                        "unit": "°C",
                        "read": true,
                        "write": false,
                        "desc": "last setting of target temp"
                      "native": {},
                      "ts": 1601731472051,
                      "_id": "fritzdect.0.Comet_133560281368.lasttarget",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.lock": {
                      "type": "state",
                      "common": {
                        "name": "Thermostat UI/API lock",
                        "type": "boolean",
                        "read": true,
                        "write": false,
                        "role": "indicator"
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.lock",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.manufacturer": {
                      "type": "state",
                      "common": {
                        "name": "Manufacturer",
                        "type": "string",
                        "read": true,
                        "write": false,
                        "role": "text",
                        "desc": "Manufacturer"
                      "native": {},
                      "ts": 1601731472050,
                      "_id": "fritzdect.0.Comet_133560281368.manufacturer",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.mode": {
                      "type": "state",
                      "common": {
                        "name": "Thermostat operation mode (0=auto, 1=closed, 2=open)",
                        "type": "number",
                        "read": true,
                        "write": true,
                        "role": "value",
                        "min": 0,
                        "max": 2,
                        "desc": "Thermostat operation mode (0=auto, 1=closed, 2=open)"
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.mode",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.name": {
                      "type": "state",
                      "common": {
                        "name": "Name",
                        "type": "string",
                        "read": true,
                        "write": false,
                        "role": "text",
                        "desc": "Name"
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.name",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.nighttemp": {
                      "type": "state",
                      "common": {
                        "name": "Night Temp",
                        "type": "number",
                        "unit": "°C",
                        "read": true,
                        "write": false,
                        "desc": "Night Temp"
                      "native": {},
                      "ts": 1601737946329,
                      "_id": "fritzdect.0.Comet_133560281368.nighttemp",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.operationList": {
                      "type": "state",
                      "common": {
                        "name": "List of operation modes",
                        "type": "string",
                        "read": true,
                        "write": false,
                        "desc": "List of operation modes"
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.operationList",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.operationMode": {
                      "type": "state",
                      "common": {
                        "name": "Current operation mode",
                        "type": "string",
                        "read": true,
                        "write": false,
                        "desc": "Current operation mode"
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.operationMode",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.present": {
                      "type": "state",
                      "common": {
                        "name": "Device present",
                        "type": "boolean",
                        "read": true,
                        "write": false,
                        "role": "indicator.connected",
                        "desc": "Device present"
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.present",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.prodname": {
                      "type": "state",
                      "common": {
                        "type": "string",
                        "read": true,
                        "write": false,
                        "role": "text",
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.prodname",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.summeractive": {
                      "type": "state",
                      "common": {
                        "type": "boolean",
                        "read": true,
                        "write": false,
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.summeractive",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.targettemp": {
                      "type": "state",
                      "common": {
                        "name": "Target Temp",
                        "type": "number",
                        "unit": "°C",
                        "read": true,
                        "write": true,
                        "desc": "Target Temp"
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.targettemp",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Comet_133560281368.temp": {
                      "type": "state",
                      "common": {
                        "name": "actual Temp",
                        "type": "number",
                        "unit": "°C",
                        "desc": "actual Temp",
                        "read": true,
                        "write": false
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.temp",
                      "acl": {
                        "object": 1636,
                        "state": 1636
                    "fritzdect.0.Comet_133560281368.temp_offset": {
                      "type": "state",
                      "common": {
                        "name": "Temp Offset",
                        "type": "number",
                        "unit": "°C",
                        "desc": "Temp Offset",
                        "read": true,
                        "write": false
                      "native": {},
                      "_id": "fritzdect.0.Comet_133560281368.temp_offset",
                      "acl": {
                        "object": 1636,
                        "state": 1636
                    "fritzdect.0.Comet_133560281368.windowopenactiv": {
                      "type": "state",
                      "common": {
                        "name": "Window open",
                        "type": "boolean",
                        "read": true,
                        "write": false,
                        "desc": "Window open"
                      "native": {},
                      "ts": 1601731472058,
                      "_id": "fritzdect.0.Comet_133560281368.windowopenactiv",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.GuestWLAN": {
                      "_id": "fritzdect.0.GuestWLAN",
                      "type": "channel",
                      "common": {
                        "name": "GuestWLAN",
                        "role": "switch"
                      "native": {},
                      "acl": {
                        "object": 1636,
                    "fritzdect.0.GuestWLAN.state": {
                      "_id": "fritzdect.0.GuestWLAN.state",
                      "type": "state",
                      "common": {
                        "name": "GuestWLAN  on/off",
                        "type": "boolean",
                        "role": "switch",
                        "read": true,
                        "write": true,
                        "desc": "GuestWLAN  on/off"
                      "native": {},
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5": {
                      "type": "channel",
                      "common": {
                        "name": "Wohnzimmer",
                      "native": {
                        "aid": "grpDAF0E0-3BA5A8CF5"
                      "ts": 1601731472626,
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5",
                      "acl": {
                        "object": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.actualtemp": {
                      "type": "state",
                      "common": {
                        "type": "number",
                        "unit": "°C",
                        "read": true,
                        "write": false,
                      "native": {},
                      "ts": 1601731472630,
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.actualtemp",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.batterylow": {
                      "type": "state",
                      "common": {
                        "type": "boolean",
                        "read": true,
                        "write": false,
                        "role": "indicator"
                      "native": {},
                      "ts": 1601731472631,
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.batterylow",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.comfytemp": {
                      "type": "state",
                      "common": {
                        "type": "number",
                        "unit": "°C",
                        "read": true,
                        "write": false,
                      "native": {},
                      "ts": 1601731472629,
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.comfytemp",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.devicelock": {
                      "type": "state",
                      "common": {
                        "type": "boolean",
                        "read": true,
                        "write": false,
                        "role": "indicator"
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.devicelock",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.errorcode": {
                      "type": "state",
                      "common": {
                        "type": "number",
                        "read": true,
                        "write": false,
                        "role": "indicator"
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.errorcode",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.fwversion": {
                      "type": "state",
                      "common": {
                        "type": "string",
                        "read": true,
                        "write": false,
                        "role": "text",
                      "native": {},
                      "ts": 1601731472627,
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.fwversion",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.holidayactive": {
                      "type": "state",
                      "common": {
                        "type": "boolean",
                        "read": true,
                        "write": false,
                      "native": {},
                      "ts": 1601731472632,
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.holidayactive",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.id": {
                      "type": "state",
                      "common": {
                        "name": "ID",
                        "type": "string",
                        "read": true,
                        "write": false,
                        "role": "text",
                        "desc": "ID"
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.id",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.lasttarget": {
                      "type": "state",
                      "common": {
                        "type": "number",
                        "unit": "°C",
                        "read": true,
                        "write": false,
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.lasttarget",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.lock": {
                      "type": "state",
                      "common": {
                        "type": "boolean",
                        "read": true,
                        "write": false,
                        "role": "indicator"
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.lock",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.manufacturer": {
                      "type": "state",
                      "common": {
                        "type": "string",
                        "read": true,
                        "write": false,
                        "role": "text",
                      "native": {},
                      "ts": 1601731472628,
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.manufacturer",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.masterdeviceid": {
                      "type": "state",
                      "common": {
                        "name": "masterdeviceid",
                        "type": "string",
                        "read": true,
                        "write": false,
                        "role": "text",
                        "desc": "masterdeviceid"
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.masterdeviceid",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.members": {
                      "type": "state",
                      "common": {
                        "name": "members",
                        "type": "string",
                        "read": true,
                        "write": false,
                        "role": "text",
                        "desc": "members"
                      "native": {},
                      "ts": 1601731472636,
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.members",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.mode": {
                      "type": "state",
                      "common": {
                        "type": "number",
                        "read": true,
                        "write": true,
                        "role": "value",
                        "min": 0,
                        "max": 2,
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.mode",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.name": {
                      "type": "state",
                      "common": {
                        "name": "Name",
                        "type": "string",
                        "read": true,
                        "write": false,
                        "role": "text",
                        "desc": "Name"
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.name",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.nighttemp": {
                      "type": "state",
                      "common": {
                        "type": "number",
                        "unit": "°C",
                        "read": true,
                        "write": false,
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.nighttemp",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.operationList": {
                      "type": "state",
                      "common": {
                        "type": "string",
                        "read": true,
                        "write": false,
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.operationList",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.operationMode": {
                      "type": "state",
                      "common": {
                        "type": "string",
                        "read": true,
                        "write": false,
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.operationMode",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.present": {
                      "type": "state",
                      "common": {
                        "type": "boolean",
                        "read": true,
                        "write": false,
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.present",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.summeractive": {
                      "type": "state",
                      "common": {
                        "type": "boolean",
                        "read": true,
                        "write": false,
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.summeractive",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.targettemp": {
                      "type": "state",
                      "common": {
                        "type": "number",
                        "unit": "°C",
                        "read": true,
                        "write": true,
                      "native": {},
                      "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.targettemp",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    sigi234 Forum Testing Most Active @Stephan Schleich last edited by
                    @Stephan-Schleich
                    Bitte benutzt die Code Tags Funktion -> </>
                    Hier gehts zur Hilfe.
                      Sequal @dslraser last edited by
                      @dslraser said in Fenster und andere Geräte zählen opt. Alexa Ansagen:
                      Wenn das von einigen getestet wurde und alles laufen sollte mache ich dann das Türen Blockly.
                      Das Fensterblockly läuft 1A. Ich beschäftige mich gerade damit wie ich die "Hausansage" entfernen kann 🙂
                      Sequal
                      • dslraser
                        dslraser Forum Testing Most Active @Sequal last edited by
                        @Sequal sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
                        Sequal
                        In diesen beiden Funktionen....
                        in den beiden Funktionen jeweils
                        und in der Funktion main
                          @dslraser
                          super, danke.....alles hatte ich noch nicht gefunden. Aber das sollte ich hinkriegen.
                          Eine Frage hab ich gleich noch: Im Alias-Script hast Du die Dreh-Kipp-Sensoren für Türen (0,1,und 2 im Zustand) in die Fenster_alias gelegt.
                          //2 x Fensterdrehgriffe HMIP
                          //HMIP Fensterdrehgriffe über rpc-Adapter in function fenster_alias
                          //{0: 'geschlossen', 1: 'gekippt', 2: 'geöffnet'}
                          Können die auch in tueren_alias oder kommt dann das Türen-Blockly durcheinander, wenn es fertig ist? Im Fensterscript läuft es prima. An einer Tür hab ich diesen Sensor, zwar kein IP sondern normal RF, aber es wäre "hübscher" wenn die Terrassentür auch in die Türenliste kann.
                          Sequal
                          • dslraser
                            ist eigentlich da auch drinn. Geht denn was nicht ?
                            • dslraser
                              dslraser Forum Testing Most Active @Sequal last edited by dslraser
                              @Sequal
                              ach Du meinst im alias ? Da kannst Du es auch einfügen. (meine Vorlage für alias sollte nur als Beispiel dienen.)
                              • dslraser
                                Versionen 1.6.4 in den ersten Beitrag geladen.
                                https://forum.iobroker.net/post/273896
                                Ich habe bei allen Listen für die Sprachausgabe auf Semikolon als Trennung umgestellt. (Um das 250 Zeichen Limit in speak zu umgehen)
                                  @Sequal
                                  Ich versuche halt noch alle Zusammenhänge zu verstehen 😉 Es funktioniert jetzt alles bestens!
                                    Link Falsch?
                                    • dslraser
                                      @sigi234 sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
                                      Link Falsch?
                                      wieso ? (ist der erste Beitrag)
                                      Edit:
                                      • dslraser
                                        ich habe im ersten Beitrag Batterien_Prozent Version 1.6.4 im Spoiler Blockly Exporte eingefügt.
                                          Link Falsch?
                                          Edit:
                                          Jupp geht.
                                            Die Batterie in Prozentanzeige funktioniert soweit (Muss noch etwas die Namen der States anpassen). Was mir aufgefallen ist:
                                            Könnte man die Spalte der Werte etwas Breiter machen? Bei einer Nachkommastelle gibt es sonst einen Zeilenumbruch
                                            blockly javascript
                                            41
                                            1186
                                            361458
