    4. [ Geklärt ] Problem bei Influx Installation
      Altersrentner @Thomas Braun last edited by
      @Thomas-Braun said in Problem bei Influx Installation:
      pi@raspberrypi:~ $ sudo service influxdb start
      pi@raspberrypi:~ $ sudo influx
      Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial tcp [::1]:8086: connect: connection refused
      Please check your connection settings and ensure 'influxd' is running.
      pi@raspberrypi:~ $ sudo apt policy influxdb
      influxdb:
        Installed: 1.8.3-1
        Candidate: 1.8.3-1
        Version table:
       *** 1.8.3-1 500
              500 https://repos.influxdata.com/debian buster/stable armhf Packages
              100 /var/lib/dpkg/status
           1.6.4-1 500
      pi@raspberrypi:~ $
        ok, hast zwar noch die "alte" Version aber sollte passen.
        ist dein Port vllt belegt?
        netstat -tulpen
          Altersrentner @crunchip last edited by
          @crunchip said in Problem bei Influx Installation:
          netstat -tulpen
          Leider das selbe Ergebnis😧
          pi@raspberrypi:~ $ sudo netstat -tulpen
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17609      637/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17608      637/iobroker.js-con
          tcp        0      0 192.168.178.41:2000     0.0.0.0:*               LISTEN      1001       20269      1195/io.hm-rpc.2
          tcp        0      0 192.168.178.41:2001     0.0.0.0:*               LISTEN      1001       20769      1156/io.hm-rpc.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15904      644/sshd
          tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       285748     16680/sshd: pi@pts/
          tcp        0      0 192.168.178.41:8701     0.0.0.0:*               LISTEN      1001       20759      1175/io.hm-rpc.1
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       19711      903/io.harmony.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17670      662/io.admin.0
          tcp6       0      0 :::8083                 :::*                    LISTEN      1001       17292      1127/io.web.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       16792      731/io.socketio.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15906      644/sshd
          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       20792      1237/io.terminal.0
          tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       285747     16680/sshd: pi@pts/
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14271      402/avahi-daemon: r
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       19712      903/io.harmony.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17212      1093/io.shelly.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15151      636/dhcpcd
          udp        0      0 0.0.0.0:43619           0.0.0.0:*                           108        14273      402/avahi-daemon: r
          udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       18957      869/io.mihome.0
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       18929      858/io.mihome-vacuu
          udp6       0      0 :::5353                 :::*                                108        14272      402/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          18566      636/dhcpcd
          udp6       0      0 :::51291                :::*                                108        14274      402/avahi-daemon: r
          pi@raspberrypi:~ $
            crunchip Forum Testing Most Active @Altersrentner last edited by crunchip
            @Altersrentner
            Standardmäßig verwendet InfluxDB die folgenden Netzwerkports:
            Der TCP-Port 8086 ist für die Client-Server-Kommunikation über die InfluxDB-API verfügbar.
            Der TCP-Port 8088 steht dem RPC-Dienst zur Verfügung, um Sicherungs- und Wiederherstellungsvorgänge durchzuführen.
            bei dir ist, siehe Zeile 16 dein iobroker terminal auf port 8088, bin mir da nicht sicher ob das Probleme bereitet
            @Altersrentner änder mal deinen terminal port in iobroker und probier es dann nochmal den Service enable, start....
            siehe auch hier
            https://forum.iobroker.net/post/378412
              Altersrentner @crunchip last edited by Altersrentner
              @crunchip
              ich verzweifle bald
              Zustand wie gehabt
              Habe jetzt mal
              influxd eingegeben
              pi@raspberrypi:~ $ sudo influxd
               8888888           .d888 888                   8888888b.  888888b.
                 888            d88P"  888                   888  "Y88b 888  "88b
                 888            888    888                   888    888 888  .88P
                 888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
                 888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
                 888   888  888 888    888 888  888   X88K   888    888 888    888
                 888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
               8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
              2020-12-20T13:31:40.279443Z     info    InfluxDB starting       {"log_id": "0RC5QVTG000", "version": "1.8.3", "branch": "1.8", "commit": "563e6                            c3d1a7a2790763c6289501095dbec19244e"}
              2020-12-20T13:31:40.280532Z     info    Go runtime      {"log_id": "0RC5QVTG000", "version": "go1.13.8", "maxprocs": 4}
              2020-12-20T13:31:41.290904Z     info    Using data dir  {"log_id": "0RC5QVTG000", "service": "store", "path": "/var/lib/influxdb/data"}
              2020-12-20T13:31:41.293624Z     info    Compaction settings     {"log_id": "0RC5QVTG000", "service": "store", "max_concurrent_compactions": 2,                             "throughput_bytes_per_second": 50331648, "throughput_bytes_per_second_burst": 50331648}
              2020-12-20T13:31:41.296007Z     info    Open store (start)      {"log_id": "0RC5QVTG000", "service": "store", "trace_id": "0RC5QZRl000", "op_na                            me": "tsdb_open", "op_event": "start"}
              2020-12-20T13:31:41.298469Z     info    Open store (end)        {"log_id": "0RC5QVTG000", "service": "store", "trace_id": "0RC5QZRl000", "op_na                            me": "tsdb_open", "op_event": "end", "op_elapsed": "2.477ms"}
              2020-12-20T13:31:41.300868Z     info    Opened service  {"log_id": "0RC5QVTG000", "service": "subscriber"}
              2020-12-20T13:31:41.310202Z     info    Starting monitor service        {"log_id": "0RC5QVTG000", "service": "monitor"}
              2020-12-20T13:31:41.312167Z     info    Registered diagnostics client   {"log_id": "0RC5QVTG000", "service": "monitor", "name": "build"}
              2020-12-20T13:31:41.312781Z     info    Registered diagnostics client   {"log_id": "0RC5QVTG000", "service": "monitor", "name": "runtime"}
              2020-12-20T13:31:41.313403Z     info    Registered diagnostics client   {"log_id": "0RC5QVTG000", "service": "monitor", "name": "network"}
              2020-12-20T13:31:41.313732Z     info    Registered diagnostics client   {"log_id": "0RC5QVTG000", "service": "monitor", "name": "system"}
              2020-12-20T13:31:41.314463Z     info    Starting precreation service    {"log_id": "0RC5QVTG000", "service": "shard-precreation", "check_interv                            al": "10m", "advance_period": "30m"}
              2020-12-20T13:31:41.315897Z     info    Starting snapshot service       {"log_id": "0RC5QVTG000", "service": "snapshot"}
              2020-12-20T13:31:41.316280Z     info    Storing statistics      {"log_id": "0RC5QVTG000", "service": "monitor", "db_instance": "_internal", "db                            _rp": "monitor", "interval": "10s"}
              2020-12-20T13:31:41.317118Z     info    Starting continuous query service       {"log_id": "0RC5QVTG000", "service": "continuous_querier"}
              2020-12-20T13:31:41.319668Z     info    Starting HTTP service   {"log_id": "0RC5QVTG000", "service": "httpd", "authentication": false}
              2020-12-20T13:31:41.321326Z     info    opened HTTP access log  {"log_id": "0RC5QVTG000", "service": "httpd", "path": "stderr"}
              2020-12-20T13:31:41.322670Z     info    Listening on HTTP       {"log_id": "0RC5QVTG000", "service": "httpd", "addr": "[::]:8086", "https": fal                            se}
              2020-12-20T13:31:41.326261Z     info    Starting retention policy enforcement service   {"log_id": "0RC5QVTG000", "service": "retention", "chec                            k_interval": "30m"}
              2020-12-20T13:31:41.327863Z     info    Sending usage statistics to usage.influxdata.com        {"log_id": "0RC5QVTG000"}
              2020-12-20T13:31:41.331840Z     info    Listening for signals   {"log_id": "0RC5QVTG000"}
              2020-12-20T13:31:44.084613Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "SHOW DATABASES"}
              [httpd] 192.168.178.41 - admin [20/Dec/2020:14:31:44 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=admin HTTP                            /1.1" 200 84 "-" "-" b3681eb6-42c7-11eb-8001-dca6321bbd83 9249
              2020-12-20T13:31:54.107193Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "SHOW DATABASES"}
              [httpd] 192.168.178.41 - admin [20/Dec/2020:14:31:54 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=admin HTTP                            /1.1" 200 84 "-" "-" b9620632-42c7-11eb-8002-dca6321bbd83 1031
              2020-12-20T13:32:04.115541Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "SHOW DATABASES"}
              [httpd] 192.168.178.41 - admin [20/Dec/2020:14:32:04 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=admin HTTP                            /1.1" 200 109 "-" "-" bf592910-42c7-11eb-8003-dca6321bbd83 2055833
              2020-12-20T13:32:06.177505Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "CREATE DATABASE iobroker"}
              [httpd] 192.168.178.41 - admin [20/Dec/2020:14:32:06 +0100] "POST /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=create+database+%22iobroke                            r%22&u=admin HTTP/1.1" 200 33 "-" "-" c093ce61-42c7-11eb-8004-dca6321bbd83 468972
              2020-12-20T13:32:06.651822Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "CREATE RETENTION POLICY global                             ON iobroker DURATION 365d REPLICATION 1 DEFAULT"}
              [httpd] 192.168.178.41 - admin [20/Dec/2020:14:32:06 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=CREATE+RETENTION+POLICY+%22                            global%22+ON+iobroker+DURATION+31536000s+REPLICATION+1+DEFAULT&u=admin HTTP/1.1" 200 232 "-" "-" c0dc2b88-42c7-11eb-8005-dca6321bbd83 2247119
              2020-12-20T13:32:08.905601Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "SHOW DATABASES"}
              [httpd] 192.168.178.41 - admin [20/Dec/2020:14:32:08 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=admin HTTP                            /1.1" 200 122 "-" "-" c234151c-42c7-11eb-8006-dca6321bbd83 2841
              Kannst Du hier etwas lokalisierne?
                @Altersrentner es läuft immer noch auf port 8088, gegebenenfalls system neustarten.
                danach nochmal prüfen, wenn dieser port dann auf 8090 läuft
                nochmal
                sudo systemctl daemon-reload
                sudo systemctl enable influxdb
                sudo systemctl start influxdb
                anschliessend prüfen, ob influx läuft mit
                sudo systemctl status influx
                @Altersrentner sagte in Problem bei Influx Installation:
                dein influx läuft noch nicht
                  @crunchip
                  jetzt wird influx nicht mehr gefunden
                  pi@raspberrypi:~ $ sudo iobroker stop
                  pi@raspberrypi:~ $ sudo iobroker restart
                  pi@raspberrypi:~ $ sudo systemctl daemon-reload
                  pi@raspberrypi:~ $ sudo systemctl enable influxdb
                  pi@raspberrypi:~ $ sudo systemctl start influxdb
                  pi@raspberrypi:~ $ sudo systemctl status influx
                  Unit influx.service could not be found.
                  pi@raspberrypi:~ $
                    @Altersrentner mein Fehler
                    sudo systemctl status influxdb
                      @crunchip
                      pi@raspberrypi:~ $ sudo systemctl status influxdb
                      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
                         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
                         Active: failed (Result: exit-code) since Sun 2020-12-20 14:47:04 CET; 12min ago
                           Docs: https://docs.influxdata.com/influxdb/
                        Process: 22523 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
                       Main PID: 22523 (code=exited, status=1/FAILURE)
                      Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                      Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                      Dec 20 14:47:04 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                      Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                      Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                      Dec 20 14:47:04 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                      pi@raspberrypi:~ $
                      konnte nicht gestartet werden
                        @Altersrentner weil ich gerade systemd.... lese
                        geb mal folgendes ein
                        sudo systemctl unmask influxdb.service
                        und prüfe danach ob der service läuft
                          @crunchip
                          pi@raspberrypi:~ $ sudo systemctl unmask influxdb.service
                          2020-12-20T14:15:35.152027Z     info    InfluxDB starting       {"log_id": "0RC7wJwl000", "version": "1.8.3", "branch": "1.8", "commit": "563e6c3d1a7a2790763c6289501095dbec19244e"}
                          2020-12-20T14:15:35.152128Z     info    Go runtime      {"log_id": "0RC7wJwl000", "version": "go1.13.8", "maxprocs": 4}
                          2020-12-20T14:15:35.253479Z     info    Using data dir  {"log_id": "0RC7wJwl000", "service": "store", "path": "/var/lib/influxdb/data"}
                          2020-12-20T14:15:35.253597Z     info    Compaction settings     {"log_id": "0RC7wJwl000", "service": "store", "max_concurrent_compactions": 2, "throughput_bytes_per_second": 50331648, "throughput_bytes_per_second_burst": 50331648}
                          2020-12-20T14:15:35.253674Z     info    Open store (start)      {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "op_event": "start"}
                          2020-12-20T14:15:35.257327Z     info    Reading file    {"log_id": "0RC7wJwl000", "engine": "tsm1", "service": "cacheloader", "path": "/var/lib/influxdb/wal/_internal/monitor/1/_00001.wal", "size": 132881}
                          2020-12-20T14:15:37.573216Z     info    Opened shard    {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "index_version": "inmem", "path": "/var/lib/influxdb/data/_internal/monitor/1", "duration": "2317.079ms"}
                          2020-12-20T14:15:37.573402Z     info    Open store (end)        {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "op_event": "end", "op_elapsed": "2319.731ms"}
                          2020-12-20T14:15:37.573525Z     info    Opened service  {"log_id": "0RC7wJwl000", "service": "subscriber"}
                          2020-12-20T14:15:37.573570Z     info    Starting monitor service        {"log_id": "0RC7wJwl000", "service": "monitor"}
                          2020-12-20T14:15:37.573611Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "build"}
                          2020-12-20T14:15:37.573649Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "runtime"}
                          2020-12-20T14:15:37.573688Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "network"}
                          2020-12-20T14:15:37.573737Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "system"}
                          2020-12-20T14:15:37.573810Z     info    Starting precreation service    {"log_id": "0RC7wJwl000", "service": "shard-precreation", "check_interval": "10m", "advance_period": "30m"}
                          2020-12-20T14:15:37.573888Z     info    Starting snapshot service       {"log_id": "0RC7wJwl000", "service": "snapshot"}
                          2020-12-20T14:15:37.573929Z     info    Starting continuous query service       {"log_id": "0RC7wJwl000", "service": "continuous_querier"}
                          2020-12-20T14:15:37.573983Z     info    Starting HTTP service   {"log_id": "0RC7wJwl000", "service": "httpd", "authentication": false}
                          2020-12-20T14:15:37.574022Z     info    opened HTTP access log  {"log_id": "0RC7wJwl000", "service": "httpd", "path": "stderr"}
                          2020-12-20T14:15:37.574321Z     info    Storing statistics      {"log_id": "0RC7wJwl000", "service": "monitor", "db_instance": "_internal", "db_rp": "monitor", "interval": "10s"}
                          2020-12-20T14:15:37.574445Z     info    Listening on HTTP       {"log_id": "0RC7wJwl000", "service": "httpd", "addr": "[::]:8086", "https": false}
                          2020-12-20T14:15:37.574529Z     info    Starting retention policy enforcement service   {"log_id": "0RC7wJwl000", "service": "retention", "check_interval": "30m"}
                          2020-12-20T14:15:37.574895Z     info    Sending usage statistics to usage.influxdata.com        {"log_id": "0RC7wJwl000"}
                          2020-12-20T14:15:37.575398Z     info    Listening for signals   {"log_id": "0RC7wJwl000"}
                          2020-12-20T14:15:43.954822Z     info    Executing query {"log_id": "0RC7wJwl000", "service": "query", "query": "SHOW DATABASES"}
                          [httpd] 192.168.178.41 - MEB [20/Dec/2020:15:15:43 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=MEB HTTP/1.1" 200 122 "-" "-" d8e47f87-42cd-11eb-8001-dca6321bbd83 5504
                            @Altersrentner sudo systemctl status influxdb
                              @crunchip
                              Jetzt hat der influxdb.0 Adapter auf grün gewechselt.😊
                              Wenn ich aber auf "Verbindung testen" gehe,
                              gibt es keine Reaktion.
                              Ist das normal?
                                im Iobroker? ja
                                  @crunchip
                                  ja im ioBroker.
                                  Aber im Terminal wird immer noch "keine Verbindung" angezeigt.
                                  Womit soll er sich dann auch verbinden?
                                  Kann ich influxdb deinstallieren und neu aufsetzen?
                                  Könnte das zu einer Lösung beitragen?
                                    @Altersrentner verstehe ich gerade nicht ganz was du meinst?
                                    welche Verbindung funktioniert nicht?
                                      @crunchip
                                      pi@raspberrypi:~ $
                                      und die Ampel vom influxdb ist wieder auf gelb
                                        @Altersrentner dann jetzt nochmal von vorne
                                        • hast du irgend etwas anderes noch gemacht?
                                        • was zeigt der status an, läuft influx?
                                          @crunchip
                                          Nein, ich habe nichts weiter gemacht,
                                          Ampel ist jetzt wieder grün.
                                          pi@raspberrypi:~ $
                                          HAL crunchip 2 Replies Last reply Reply Quote 0
                                          • HAL
                                            HAL @Altersrentner last edited by
                                            @Altersrentner hiernach hat bei mir die Installation von influxb problemlos geklappt
                                            lnfluxdb Raspberry
                                            Segway A 2 Replies Last reply Reply Quote 0
                                            influxdb
                                            12
                                            178
                                            33083
