    4. [ Geklärt ] Problem bei Influx Installation
      crunchip Forum Testing Most Active @Altersrentner last edited by crunchip
      @Altersrentner weil ich gerade systemd.... lese
      geb mal folgendes ein
      sudo systemctl unmask influxdb.service
      sudo systemctl start influxdb
      und prüfe danach ob der service läuft
        Altersrentner @crunchip last edited by
        @crunchip
        pi@raspberrypi:~ $ sudo systemctl unmask influxdb.service
        pi@raspberrypi:~ $ sudo systemctl start influxdb
        pi@raspberrypi:~ $ sudo influxd
         8888888           .d888 888                   8888888b.  888888b.
           888            d88P"  888                   888  "Y88b 888  "88b
           888            888    888                   888    888 888  .88P
           888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
           888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
           888   888  888 888    888 888  888   X88K   888    888 888    888
           888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
         8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
        2020-12-20T14:15:35.152027Z     info    InfluxDB starting       {"log_id": "0RC7wJwl000", "version": "1.8.3", "branch": "1.8", "commit": "563e6c3d1a7a2790763c6289501095dbec19244e"}
        2020-12-20T14:15:35.152128Z     info    Go runtime      {"log_id": "0RC7wJwl000", "version": "go1.13.8", "maxprocs": 4}
        2020-12-20T14:15:35.253479Z     info    Using data dir  {"log_id": "0RC7wJwl000", "service": "store", "path": "/var/lib/influxdb/data"}
        2020-12-20T14:15:35.253597Z     info    Compaction settings     {"log_id": "0RC7wJwl000", "service": "store", "max_concurrent_compactions": 2, "throughput_bytes_per_second": 50331648, "throughput_bytes_per_second_burst": 50331648}
        2020-12-20T14:15:35.253674Z     info    Open store (start)      {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "op_event": "start"}
        2020-12-20T14:15:35.257327Z     info    Reading file    {"log_id": "0RC7wJwl000", "engine": "tsm1", "service": "cacheloader", "path": "/var/lib/influxdb/wal/_internal/monitor/1/_00001.wal", "size": 132881}
        2020-12-20T14:15:37.573216Z     info    Opened shard    {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "index_version": "inmem", "path": "/var/lib/influxdb/data/_internal/monitor/1", "duration": "2317.079ms"}
        2020-12-20T14:15:37.573402Z     info    Open store (end)        {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "op_event": "end", "op_elapsed": "2319.731ms"}
        2020-12-20T14:15:37.573525Z     info    Opened service  {"log_id": "0RC7wJwl000", "service": "subscriber"}
        2020-12-20T14:15:37.573570Z     info    Starting monitor service        {"log_id": "0RC7wJwl000", "service": "monitor"}
        2020-12-20T14:15:37.573611Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "build"}
        2020-12-20T14:15:37.573649Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "runtime"}
        2020-12-20T14:15:37.573688Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "network"}
        2020-12-20T14:15:37.573737Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "system"}
        2020-12-20T14:15:37.573810Z     info    Starting precreation service    {"log_id": "0RC7wJwl000", "service": "shard-precreation", "check_interval": "10m", "advance_period": "30m"}
        2020-12-20T14:15:37.573888Z     info    Starting snapshot service       {"log_id": "0RC7wJwl000", "service": "snapshot"}
        2020-12-20T14:15:37.573929Z     info    Starting continuous query service       {"log_id": "0RC7wJwl000", "service": "continuous_querier"}
        2020-12-20T14:15:37.573983Z     info    Starting HTTP service   {"log_id": "0RC7wJwl000", "service": "httpd", "authentication": false}
        2020-12-20T14:15:37.574022Z     info    opened HTTP access log  {"log_id": "0RC7wJwl000", "service": "httpd", "path": "stderr"}
        2020-12-20T14:15:37.574321Z     info    Storing statistics      {"log_id": "0RC7wJwl000", "service": "monitor", "db_instance": "_internal", "db_rp": "monitor", "interval": "10s"}
        2020-12-20T14:15:37.574445Z     info    Listening on HTTP       {"log_id": "0RC7wJwl000", "service": "httpd", "addr": "[::]:8086", "https": false}
        2020-12-20T14:15:37.574529Z     info    Starting retention policy enforcement service   {"log_id": "0RC7wJwl000", "service": "retention", "check_interval": "30m"}
        2020-12-20T14:15:37.574895Z     info    Sending usage statistics to usage.influxdata.com        {"log_id": "0RC7wJwl000"}
        2020-12-20T14:15:37.575398Z     info    Listening for signals   {"log_id": "0RC7wJwl000"}
        2020-12-20T14:15:43.954822Z     info    Executing query {"log_id": "0RC7wJwl000", "service": "query", "query": "SHOW DATABASES"}
        [httpd] 192.168.178.41 - MEB [20/Dec/2020:15:15:43 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=MEB HTTP/1.1" 200 122 "-" "-" d8e47f87-42cd-11eb-8001-dca6321bbd83 5504
          @Altersrentner sudo systemctl status influxdb
            @crunchip
            Jetzt hat der influxdb.0 Adapter auf grün gewechselt.😊
            Wenn ich aber auf "Verbindung testen" gehe,
            gibt es keine Reaktion.
            Ist das normal?
              @Altersrentner sagte in Problem bei Influx Installation:
              im Iobroker? ja
                @crunchip
                ja im ioBroker.
                Aber im Terminal wird immer noch "keine Verbindung" angezeigt.
                Womit soll er sich dann auch verbinden?
                Kann ich influxdb deinstallieren und neu aufsetzen?
                Könnte das zu einer Lösung beitragen?
                  @Altersrentner verstehe ich gerade nicht ganz was du meinst?
                  welche Verbindung funktioniert nicht?
                    Altersrentner @crunchip last edited by Altersrentner
                    @crunchip
                    Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial tcp [::1]:8086: connect: connection refused
                    Please check your connection settings and ensure 'influxd' is running.
                    pi@raspberrypi:~ $
                    und die Ampel vom influxdb ist wieder auf gelb
                      @Altersrentner dann jetzt nochmal von vorne
                      • hast du irgend etwas anderes noch gemacht?
                      • was zeigt der status an, läuft influx?
                        @crunchip
                        Nein, ich habe nichts weiter gemacht,
                        Ampel ist jetzt wieder grün.
                        pi@raspberrypi:~ $
                        HAL crunchip 2 Replies Last reply Reply Quote 0
                        • HAL
                          HAL @Altersrentner last edited by
                          @Altersrentner hiernach hat bei mir die Installation von influxb problemlos geklappt
                          lnfluxdb Raspberry
                          Segway A 2 Replies Last reply Reply Quote 0
                          • Segway
                            Segway @HAL last edited by
                            Ich nehme immer die offizielle Herstellerseite --> H I E R
                            Da bin ich sicher immer alles aktuell zu haben und das das Setup auch klappt. Alles andere kann und meistens ist es auch so dann veraltet sein ! Das gibt nur Probleme
                              @Altersrentner ich wollte wissen, ob der status grün ist/bzw aktiv
                                Altersrentner @HAL last edited by
                                @HAL
                                kann ich das so drüber installieren oder meine Installation löschen?
                                Aber wie!!
                                  @crunchip
                                  Hatte ich leider übersehen, Entschuldigung
                                  Nein
                                  pi@raspberrypi:~ $ sudo systemctl status influxdb
                                  ● influxdb.service - InfluxDB is an open-source, distributed, time series database
                                     Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
                                     Active: failed (Result: exit-code) since Sun 2020-12-20 18:04:01 CET; 13min ago
                                       Docs: https://docs.influxdata.com/influxdb/
                                   Main PID: 30313 (code=exited, status=1/FAILURE)
                                  Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling r
                                  Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5
                                  Dec 20 18:04:01 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series dat
                                  Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                                  Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                                  Dec 20 18:04:01 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time se
                                  lines 1-12/12 (END)
                                  Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                                  Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                                  Dec 20 18:04:01 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                                  Dec 20 18:04:01 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                                  lines 1-12/12 (END)
                                  lines 1-12/12 (END)
                                    @Altersrentner na irgend etwas ist da bei dir faul
                                    probier bitte nochmal in der Reihenfolge
                                    sudo systemctl stop influxdb
                                      @crunchip
                                      pi@raspberrypi:~ $ sudo systemctl stop influxdb
                                         Active: failed (Result: exit-code) since Sun 2020-12-20 18:39:16 CET; 17s ago
                                        Process: 3797 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
                                       Main PID: 3797 (code=exited, status=1/FAILURE)
                                      Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                                      Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                                      Dec 20 18:39:16 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                                      Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                                      Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                                      Dec 20 18:39:16 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                                      pi@raspberrypi:~ $
                                      Ampel ist grün
                                        @Altersrentner die Ampel interessiert momentan nicht, da dein influx-service nicht läuft, Zeile 7
                                        hast du in der
                                        irgendwas geändert/angepasst?
                                          @crunchip NEIN!!
                                            @Altersrentner dann nochmal, mit enable...
                                            sudo systemctl enable influxdb
                                            netstat -tulpen
                                            influxdb
                                            12
                                            178
                                            33083
