    4. [ Geklärt ] Problem bei Influx Installation
      Altersrentner @crunchip last edited by
      @crunchip
      pi@raspberrypi:~ $ sudo systemctl stop influxdb
      pi@raspberrypi:~ $ sudo systemctl unmask influxdb.service
      pi@raspberrypi:~ $ sudo systemctl enable influxdb
      pi@raspberrypi:~ $ sudo systemctl start influxdb
      pi@raspberrypi:~ $ sudo systemctl status influxdb
      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Sun 2020-12-20 19:07:54 CET; 26s ago
           Docs: https://docs.influxdata.com/influxdb/
        Process: 7963 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
       Main PID: 7963 (code=exited, status=1/FAILURE)
      Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
      Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
      Dec 20 19:07:54 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
      Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
      Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
      Dec 20 19:07:54 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
      pi@raspberrypi:~ $ netstat -tulpen
      (Not all processes could be identified, non-owned process info
       will not be shown, you would have to be root to see it all.)
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       882108     -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       881190     -
      tcp        0      0 192.168.178.41:2000     0.0.0.0:*               LISTEN      1001       887022     -
      tcp        0      0 192.168.178.41:2001     0.0.0.0:*               LISTEN      1001       884408     -
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15904      -
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       1015445    -
      tcp        0      0 192.168.178.41:8701     0.0.0.0:*               LISTEN      1001       886967     -
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       883885     -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       883049     -
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       885009     -
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       882261     -
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15906      -
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       1015444    -
      tcp6       0      0 :::8090                 :::*                    LISTEN      1001       884598     -
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14271      -
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       883886     -
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       884062     -
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15151      -
      udp        0      0 0.0.0.0:43619           0.0.0.0:*                           108        14273      -
      udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       881469     -
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       882347     -
      udp6       0      0 :::5353                 :::*                                108        14272      -
      udp6       0      0 :::546                  :::*                                0          18566      -
      udp6       0      0 :::51291                :::*                                108        14274      -
      pi@raspberrypi:~ $
        crunchip Forum Testing Most Active @Altersrentner last edited by crunchip
        @Altersrentner so kommen wir nicht weiter, da is der Wurm drin und kann dir ehrlich gesagt, nicht sagen, wo der Fehler liegt.
        Ne Möglichkeit dann doch nochmal influx zu entfernen und frisch installieren.
        sudo apt-get autoremove influxdb
        danach nochmal eine installation anstoßen, bezieht sich auf ubuntu
        wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
        source /etc/lsb-release
        echo "deb https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
        sudo apt-get update && sudo apt-get install influxdb
        für debian
        source /etc/os-release
        echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
        wenn fertig, prüfen ob der Dienst läuft
        A Duffy 4 Replies Last reply Reply Quote 0
          Altersrentner @crunchip last edited by Altersrentner
          @crunchip
          OK,
          Nach welcher Vorlage?
          pi@raspberrypi:~ $ sudo apt-get autoremove influxdb
          Reading package lists... Done
          Building dependency tree
          The following packages will be REMOVED:
            influxdb rpi-eeprom-images
          0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
          After this operation, 153 MB disk space will be freed.
          Do you want to continue? [Y/n] y
          y
          (Reading database ... 61344 files and directories currently installed.)
          Removing influxdb (1.8.3-1) ...
          Removing rpi-eeprom-images (11.0-1) ...
          Processing triggers for man-db (2.8.5-2) ...
          pi@raspberrypi:~ $
          War es das schon?
            @Altersrentner scheint so,
            hab oben weiter ergänzt, zwecks Installation
              @crunchip
              Wo ist oben?
              Das sind die Angaben zu meinem System
              pi@raspberrypi:~ $ cat /proc/version
              Linux version 5.4.79-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1373 SMP Mon Nov 23 13:27:40                  GMT 2020
              pi@raspberrypi:~ $ uname -a
              Linux raspberrypi 5.4.79-v7l+ #1373 SMP Mon Nov 23 13:27:40 GMT 2020 armv7l GNU/Linux
              pi@raspberrypi:~ $ cat /etc/debian_version
              10.7
              pi@raspberrypi:~ $
                @Altersrentner sagte in Problem bei Influx Installation:
                Wo ist oben?
                https://forum.iobroker.net/post/541116
                ah moment stop, Ubuntu
                @Altersrentner sorry, war grad abgelenkt, hatte kleinen zwischenfall,
                also debian läuft?, dann war ich doch richtig, mit der Anleitung
                  @crunchip
                  Zeile 2 ?
                  pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                  OK
                  pi@raspberrypi:~ $ source /etc/lsb-release
                  -bash: /etc/lsb-release: No such file or directory
                  pi@raspberrypi:~ $ sudo source /etc/lsb-release
                  sudo: source: command not found
                  pi@raspberrypi:~ $
                    @Altersrentner das sind doch ganze Befehle, guck mal selbst, auf der ganz normalen offiziellen Seite
                      @crunchip
                         Active: active (running) since Sun 2020-12-20 20:05:48 CET; 20s ago
                       Main PID: 4285 (influxd)
                          Tasks: 14 (limit: 4915)
                         CGroup: /system.slice/influxdb.service
                                 └─4285 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                      Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999473Z lvl=info msg="Starting continuous query service" log_id=0RCOY820000 service
                      Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999496Z lvl=info msg="Starting HTTP service" log_id=0RCOY820000 service=httpd authe
                      Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999517Z lvl=info msg="opened HTTP access log" log_id=0RCOY820000 service=httpd path
                      Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999520Z lvl=info msg="Storing statistics" log_id=0RCOY820000 service=monitor db_ins
                      Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999745Z lvl=info msg="Listening on HTTP" log_id=0RCOY820000 service=httpd addr=[::]
                      Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999809Z lvl=info msg="Starting retention policy enforcement service" log_id=0RCOY82
                      Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:50.000038Z lvl=info msg="Listening for signals" log_id=0RCOY820000
                      Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:50.004535Z lvl=info msg="Sending usage statistics to usage.influxdata.com" log_id=0RCO
                      Dec 20 20:05:59 raspberrypi influxd[4285]: ts=2020-12-20T19:05:59.234954Z lvl=info msg="Executing query" log_id=0RCOY820000 service=query query="SHOW
                      Dec 20 20:05:59 raspberrypi influxd[4285]: [httpd] 192.168.178.41 - MEB [20/Dec/2020:20:05:59 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precisi
                      lines 1-19/19 (END)
                      Sieht das gut aus?
                        @Altersrentner 👍
                        A 2 Replies Last reply Reply Quote 1
                          @crunchip
                          Ich bedanke 👍 👍 👍 mich für Deine unendlichen Bemühungen
                          mir zu helfen.
                          Für heute ist Schluss.
                          Morgen ist auch noch ein Tag
                          Einen schönen Abend
                          wünscht Michael
                            @crunchip Hallo,
                            Der Ärger geht weiter.
                            Heute Morgen war noch alles im grünen Bereich.
                            Influydb lief, und der influxdb.0 Adapter war auch grün.
                            Dann hatte ich grafana installiert.
                            Konnte über Port 3000 zugreifen.
                            Bei der Dateneingabe verlief alles gut nur bei Host war
                            localhost vorgegeben. konnte auch nicht in IP geändert werden.
                            Nach Sicherung kam die Meldung keine Verbindung möglich.
                            Darauf habe ich in der influxdb.0 die iP in localhost geändert,
                            in derHoffnung eine Verbindung zu bekommen.
                            Leider klappte das nicht.
                            Nach zurücksetzen localhost in IP bleibt die Ampel jetzt auf gelb.
                            Habe dann grafana und den influxdb.0 Adapter deinstalliert.
                            Adapter neu installiert, daten eingegeben, gestartet und die Ampel bleibt gelb.
                            Im Terminal influxdb überprüft. alles ok, läuft.
                            Das ist die Fehlermeldung aus dem log.
                            influxdb.0	2020-12-21 11:05:35.664	error	(1453) Error: authorization failed
                            influxdb.0	2020-12-21 11:05:35.659	info	(1453) Connecting http://192.168.178.41:8086 ...
                            Juser und Paswort im Adapter sind die, In influxdb eingegebenen.
                            Hast Du noch eine Idee?
                            Gruß Michael
                              @Altersrentner auf die schnelle nicht, da ich unterwegs bin. Möglich, das sich ein Leerzeichen oder so mit eingeschlichen hat?
                                @crunchip Hallo,
                                Ich muss mich doch noch mal um Hilfe bitten.
                                Nicht das jemand denkt ich bin zu düsig! aber es geling mir nicht
                                Influxdb zu konfigurieren.
                                Mehrmaliges löschen und wieder installieren hat nichts gebracht.
                                Ich komme immer bis zu diesem Punkt:
                                OK
                                pi@raspberrypi:~ $ source /etc/os-release
                                pi@raspberrypi:~ $ echo "deb https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                deb https://repos.influxdata.com/  stable
                                pi@raspberrypi:~ $ sudo apt update
                                E: Malformed entry 1 in list file /etc/apt/sources.list.d/influxdb.list (Component)
                                E: The list of sources could not be read.
                                pi@raspberrypi:~ $ echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                deb https://repos.influxdata.com/debian buster stable
                                Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                                Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
                                Hit:4 https://repos.influxdata.com/debian buster InRelease
                                Fetched 15.0 kB in 2s (9,888 B/s)
                                All packages are up to date.
                                pi@raspberrypi:~ $ sudo apt install influxdb
                                The following NEW packages will be installed:
                                  influxdb
                                0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                Need to get 0 B/60.0 MB of archives.
                                After this operation, 153 MB of additional disk space will be used.
                                Selecting previously unselected package influxdb.
                                (Reading database ... 63673 files and directories currently installed.)
                                Preparing to unpack .../influxdb_1.8.3-1_armhf.deb ...
                                Unpacking influxdb (1.8.3-1) ...
                                Setting up influxdb (1.8.3-1) ...
                                pi@raspberrypi:~ $ sudo systemctl status influxdb.service
                                   Active: active (running) since Tue 2020-12-22 11:44:21 CET; 3h 12min ago
                                 Main PID: 5478 (influxd)
                                           └─5478 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                                Dec 22 14:55:30 raspberrypi influxd[5478]: ts=2020-12-22T13:55:30.303321Z lvl=info msg="failed to store statistic
                                Dec 22 14:55:40 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:55:40 +0100] "GET /query?db=
                                Dec 22 14:55:40 raspberrypi influxd[5478]: ts=2020-12-22T13:55:40.504680Z lvl=info msg="failed to store statistic
                                Dec 22 14:55:50 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:55:50 +0100] "GET /query?db=
                                Dec 22 14:56:00 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:00 +0100] "GET /query?db=
                                Dec 22 14:56:10 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:10 +0100] "GET /query?db=
                                Dec 22 14:56:21 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:20 +0100] "GET /query?db=
                                Dec 22 14:56:31 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:31 +0100] "GET /query?db=
                                Dec 22 14:56:41 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:41 +0100] "GET /query?db=
                                Dec 22 14:56:51 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:51 +0100] "GET /query?db=
                                pi@raspberrypi:~ $ sudo systemctl enable influxdb.service
                                pi@raspberrypi:~ $
                                pi@raspberrypi:~ $
                                pi@raspberrypi:~ $ sudo influx
                                Connected to http://localhost:8086 version 1.8.3
                                InfluxDB shell version: 1.8.3
                                > CREATE DATABASE "iobroker"
                                ERR: unable to parse authentication credentials
                                Warning: It is possible this error is due to not setting a database.
                                Please set a database with the command "use <database>".
                                Alles was danach versucht wird einzugeben wird mit der
                                letzten Fehlermeldung beantwortet
                                Die influxdb.0 Ampel ist gelb.
                                Dortige Eingaben sind wie gehabt
                                Auch USE "iobroker" bringt das selbe Ergebnis.
                                > auth
                                username: admin
                                password:
                                > show database
                                ERR: authorization failed
                                > show databases
                                Gestern habe ich eine andere Speicherkarte neu aufgesetzt.
                                Rasphian buster und iobroker installiert und
                                dort hat die Installation von influxdb und Grafana auf Anhieb geklappt.
                                Ich vermute, das es in einer Konfigurationsdatei Einträge gibt,
                                die diese Fehlermeldungen herforrufen.
                                Freundliche Grüße
                                Michael
                                crunchip 2 Replies Last reply Reply Quote 0
                                  @Altersrentner du kannst influx löschen incl aller Abhängigkeiten und Konfigurationseinstellungen, mittels
                                  sudo apt-get autoremove --purge influxdb
                                  Anschliessend kannst du sauber neu installieren
                                  Und wenn du schon beim installieren bist, warum nicht gleich die neuste Version?
                                  https://portal.influxdata.com/downloads/
                                  Influxdb v 2.0.3
                                    Thomas Braun Most Active @crunchip last edited by
                                    @crunchip sagte in Problem bei Influx Installation:
                                    Weil's da keinen passenden build für 32bit Raspian OS gibt. Alles arm64.
                                    A crunchip 2 Replies Last reply Reply Quote 1
                                      Altersrentner @Thomas Braun last edited by
                                      @Thomas-Braun Hallo,
                                      So habe ich das auch gesehen!??
                                      Gruß Michael
                                        crunchip Forum Testing Most Active @Thomas Braun last edited by
                                        @Thomas-Braun stimmt, hatte ich nicht dran gedacht🤦 geht ja um nen raspberry
                                          @Altersrentner wenn ich mich nicht Irre, kannst du das create database.... Weglassen auf der Konsole.
                                          Die wird nämlich automatisch angelegt, wenn du in deiner Influx Instanz, die Werte/Einstellungen gemacht hast und anschliessend startest. Das denke ich, behebt auch deinen Fehler
                                            @crunchip Hallo,
                                            😊 😊 😊 Es hat geklappt.
                                            Folgende Situation war gegeben,
                                            trotz mehrmaligem löschen der influxdb war aber noch die
                                            alte config vorhanden und damit die vormals kommentierten Zeilen.
                                            Ich war immer davon ausgegangen, das die config auch entfernt wurde.
                                            Habe dann alle Zeilen bis auf bind.... auskommentiert und damit hatten
                                            sich login und database selbst unter influxdb eingetragen.
                                            Das brachte dann SHOW..... ans Licht. ist zwar etwas komisch,
                                            denn in den Anleitungen wird ja immer geschrieben CREATE......
                                            Na ja - alles gut!! für heute reicht`s
                                            Ich bedanke mich nochmals für Eure Unterstützung!
                                            Freundliche Grüße und besinnliche Feiertage
                                            wünscht Michael
                                            crunchip 1 Reply Last reply Reply Quote 1
                                            influxdb
                                            12
                                            178
                                            33062
