    4. Test Adapter luxtronik2 v0.4.x
    • Philipp S.
      Philipp S. @UncleSam last edited by
      @UncleSam Hallo,
      hatte gestern leider keine Zeit mich darum zu kümmern.
      Das Update intervall steht auf 60 Sekunden.
      Hier der entsprechende Debug-Log:
      luxtronik2.0	2020-11-19 22:43:50.618	error	(27752) Luxtronik read error: Error: connect ECONNREFUSED 192.168.0.23:8888
      luxtronik2.0	2020-11-19 22:43:50.611	info	(27752) Connecting to 192.168.0.23:8888
      luxtronik2.0	2020-11-19 22:43:46.931	error	(27752) Couldn't handle message: Error: The "Informationen.Fehlerspeicher." is invalid. Ids are not allowed to end in "." Error: The "Informationen.Fehlerspeicher." is invalid. Ids are not allowed to
      luxtronik2.0	2020-11-19 22:43:45.129	debug	(27752) {"Content":{"item":[{"$":{"id":"0x54600c"},"name":["Temperaturen","Temperaturen"],"item":[{"$":{"id":"0x54285c"},"name":["Vorlauf"],"value":["40.1°C"]},{"$":{"id":"0x539d24"},"name":["Rücklauf
      luxtronik2.0	2020-11-19 22:43:45.059	debug	(27752) Getting 0x535308
      luxtronik2.0	2020-11-19 22:43:44.981	debug	(27752) {"Navigation":{"$":{"id":"0x55c540"},"item":[{"$":{"id":"0x535308"},"name":["Informationen"],"item":[{"$":{"id":"0x545e28"},"name":["Temperaturen"]},{"$":{"id":"0x53a0d8"},"name":["Eingänge"]}
      luxtronik2.0	2020-11-19 22:43:44.891	info	(27752) Connected to ws://192.168.0.23:8214
      luxtronik2.0	2020-11-19 22:43:44.842	info	(27752) Connecting to ws://192.168.0.23:8214
      luxtronik2.0	2020-11-19 22:43:44.786	info	(27752) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.luxtronik2, node: v12.18.4, js-controller: 3.1.6
      luxtronik2.0	2020-11-19 22:43:40.933	info	(27734) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      luxtronik2.0	2020-11-19 22:43:40.730	debug	(27734) {"Content":{"item":[{"$":{"id":"0x56cd04"},"name":["Temperaturen","Temperaturen"],"item":[{"$":{"id":"0x50fe8c"},"name":["Vorlauf"],"value":["40.1°C"]},{"$":{"id":"0x55280c"},"name":["Rücklau
      luxtronik2.0	2020-11-19 22:43:40.652	debug	(27734) Getting 0x535308
      luxtronik2.0	2020-11-19 22:43:40.626	debug	(27734) {"Navigation":{"$":{"id":"0x566bb8"},"item":[{"$":{"id":"0x535308"},"name":["Informationen"],"item":[{"$":{"id":"0x545e28"},"name":["Temperaturen"]},{"$":{"id":"0x55aa80"},"name":["Eingänge"]
      luxtronik2.0	2020-11-19 22:43:40.537	info	(27734) Connected to ws://192.168.0.23:8214
      luxtronik2.0	2020-11-19 22:43:40.506	info	(27734) Connecting to ws://192.168.0.23:8214
      luxtronik2.0	2020-11-19 22:43:40.444	info	(27734) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.luxtronik2, node: v12.18.4, js-controller: 3.1.6
      luxtronik2.0	2020-11-19 22:43:39.923	info	(27734) Got terminate signal TERMINATE_YOURSELF
      luxtronik2.0	2020-11-19 22:43:39.420	debug	(27734) statesDB connected
      luxtronik2.0	2020-11-19 22:43:39.418	debug	(27734) States connected to redis: 127.0.0.1:9000
      luxtronik2.0	2020-11-19 22:43:39.405	debug	(27734) States create System PubSub Client
      luxtronik2.0	2020-11-19 22:43:39.401	debug	(27734) States create User PubSub Client
      luxtronik2.0	2020-11-19 22:43:39.391	debug	(27734) Redis States: Use Redis connection: 127.0.0.1:9000
      luxtronik2.0	2020-11-19 22:43:39.389	debug	(27734) objectDB connected
      luxtronik2.0	2020-11-19 22:43:39.382	debug	(27734) Objects connected to redis: 127.0.0.1:9001
      luxtronik2.0	2020-11-19 22:43:39.366	debug	(27734) Objects client initialize lua scripts
      luxtronik2.0	2020-11-19 22:43:39.364	debug	(27734) Objects create User PubSub Client
      luxtronik2.0	2020-11-19 22:43:39.362	debug	(27734) Objects create System PubSub Client
      luxtronik2.0	2020-11-19 22:43:39.349	debug	(27734) Objects client ready ... initialize now
      luxtronik2.0	2020-11-19 22:43:39.297	debug	(27734) Redis Objects: Use Redis connection: 127.0.0.1:9001
      luxtronik2.0	2020-11-19 22:43:35.170	info	(3775) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      luxtronik2.0	2020-11-19 22:43:35.168	info	(3775) terminating
      luxtronik2.0	2020-11-19 22:43:35.163	info	(3775) Got terminate signal TERMINATE_YOURSELF
      UncleSam 1 Reply Last reply Reply Quote 0
      • UncleSam
        UncleSam Developer @Philipp S. last edited by UncleSam
        @Philipp-S Ach du glücklicher: dein Fehlerspeicher ist noch leer - und das kann der Adapter scheinbar noch nicht... werde ich baldmöglichst beheben.
        Und dann ist wohl Port 8888 falsch, dort hin kann er sich gar nicht verbinden. Schau mal, ob Port 8889 geht.
        Philipp S. 1 Reply Last reply Reply Quote 0
        • Philipp S.
          @UncleSam said in Test Adapter luxtronik2 v0.0.x:
          8889
          vielen Dank für dein Feedback. Ich hab mal den Port auf 8889 geändert.
          Ich glaube das hat mein Problem mit dem nicht aktualisieren schon behoben.
          Sollte ich die bezüglich des Leeren Fehlerspeichers dennoch irgendwie behilflich sein können sag einfach kurz bescheid.
          Gruß,
          Philipp
          • UncleSam
            @Philipp-S sagte in Test Adapter luxtronik2 v0.0.x:
            Du kannst sonst mal die aktuellste Version von Github installieren (Versionsnummer ist immer noch gleich!) und schauen, ob das Problem nicht mehr auftritt (du solltest keine Fehlermeldungen mehr sehen).
              pgBroker last edited by pgBroker
              Großes Kino @UncleSam . Nach zahlreichen erfolglosen Versuchen meine AIT Wärmepumpe mittels NodeRed auszulesen, habe ich jetzt deinen Adapter entdeckt und bin begeistert.
              Lief auf Anhieb. Einzige kleine Schwierigkeit war, dass meine WP nicht auf Port 8888 oder 8889 reagiert, wohl aber auf 8214. Ich habe in der Adapterkonfiguration einfach das Feld Luxtronik Port leer gelassen, bei Websocket-Port 8214 eingetragen und IP und Passwort gesetzt. Danach gab es keine Fehler mehr im Log.
              Bislang lese ich nur aus. Werte setzen kommt später.
              Einziges Problem, das ich bislang habe ist, dass nach mehrtägigem Betrieb die Aktualisierung der Werte manchmal stoppt. Neustart des Adapters behebt das Problem kurzzeitig.
              Könnte sein, dass dies auch an der Anbindung meiner WP liegt. Entgegen der Empfehlung von AIT habe ich sie derzeit provisorisch über eine WLAN Bridge angebunden. Direkter LAN-Anschluss wird aber in Kürze erfolgen. Mal schaun, ob die Hänger dann weg sind.
              Ich hoffe dein Adapter wird bald auch direkt über ioBroker installier- und updatebar sein.
              • UncleSam
                UncleSam Developer @pgBroker last edited by
                @pgBroker sagte in Test Adapter luxtronik2 v0.0.x:
                Einziges Problem, das ich bislang habe ist, dass nach mehrtägigem Betrieb die Aktualierung der Werte manchmal stoppt. Neustart des Adapters behebt das Problem kurzzeitig.
                Ja, das habe ich bei mir in den letzten Tagen auch entdeckt. Ich werde in der nächsten Version eine Überwachung einbauen, damit der Adapter das selber merkt.
                Das kommt, sobald ich die wichtigsten Bugs behoben und eine offizielle Version erstellt habe.
                  pgBroker @UncleSam last edited by
                  @UncleSam weißt du woran es liegt, wenn die Aktualisierung stoppt? Netzwerkprobleme, Autorisierungsfehler, Timeoutschleife?
                  Das direkt zu beseitgen wäre "sauberer" als immer den ganzen Adapter neuzustarten, wenn er hängt, so wie ich es mangels Alternativen derzeit händisch mache.
                  • UncleSam
                    Nein, ich müsste zuerst mal Logs vom Fehler haben und die habe ich bis jetzt noch nicht. Falls du etwas siehst in den Logs, bin ich froh um Feedback.
                      @UncleSam Mache ich. Derzeit habe ich aber nichts im Log. Die letzten Tage lief er recht stabil.
                      Habe die Logstufe für den Adapter jetzt mal auf Debug gestellt, um im Fall der Fälle mehr Infos zu bekommen.
                      • TbsJah
                        TbsJah @UncleSam last edited by
                        @UncleSam ich wollte freundlich anfragen ob eine Weiterentwicklung geplant ist?
                        Das Setzen des Fuss- und Endpunkt wäre sehr nützlich.
                        Ebenso das Ansteuern der Umwälzpumpe (Spannung 3.10V)
                        • UncleSam
                          UncleSam Developer @TbsJah last edited by UncleSam
                          @TbsJah Danke für die Nachfrage. Leider kann ich nur das umsetzen, was die darunterliegende Library kann. Wenn du also neue Sachen ansteuern willst, musst du das hier "beantragen": https://github.com/coolchip/luxtronik2/issues
                          (Wie ich sehe, hast du da schon einiges angefragt.)
                          Ich werde die neuste Version der Library baldmöglichst übernehmen.
                          Ist die Umwälzpumpe schon drin? Hast du das schon angefragt? Das wäre für mich auch sehr interessant.
                          TbsJah 1 Reply Last reply Reply Quote 0
                          • UncleSam
                            UncleSam Developer last edited by
                            Die Version 0.1.0 ist ab sofort auch per NPM verfügbar. Sie beinhaltet die neusten Versionen der Abhängigkeiten.
                            • Oreider
                              Oreider last edited by
                              vielen Dank für den Adapter... Läuft bei mir bisher ohne Probleme.
                              Eine Frage hätte ich noch. Wie kann ich die verschiedenen möglichen Werte der ID "luxtronik2.0.values.heatpump_extendet_state_string" herausfinden?
                              Also was die Anlage gerade macht... z.B. Heizbetrieb, Pumpenvorlauf usw.
                              Hintergrund... Ich möchte mich gerne bei einer Störung benachrichtigen lassen... Jetzt will ich wissen wie der Wert bei Störung benannt ist um einen Auslöser zu haben.
                              Schönen Gruß
                              Tom
                              • UncleSam
                                UncleSam Developer @Oreider last edited by
                                @Oreider Hier findest du alle Werte:
                                https://github.com/coolchip/luxtronik2/blob/3812bd92e90847b58430ff96d67ab16708e09675/types.js#L22
                                Oreider 1 Reply Last reply Reply Quote 1
                                • Oreider
                                  Oreider @UncleSam last edited by
                                  @UncleSam
                                  Super, genau das habe ich benötigt!
                                  chrid88 1 Reply Last reply Reply Quote 0
                                  • chrid88
                                    chrid88 @Oreider last edited by
                                    Hallo zusamme,
                                    Ich habe auch eine AIT WP mit einem Luxtronik 2.
                                    Meine WP ist aktuell gar nicht mit dem LAN verbunden. Kann ich (ggf. sogar selber) die WP ans LAN anschliessen und komme ich dann über den Adapter an die Werte? Oder muss man zwingend den Webserver Dienst bezahlt haben?
                                    Zum LAN Anschluss: wenn ich das in der Anleitung richtig verstehe, muss man da etwas auseinande bauen um an die LAN Schnittstelle zu kommen?
                                    • UncleSam
                                      UncleSam Developer @chrid88 last edited by
                                      @Christian-Drechsler Welches Modell hast du genau? Bei meiner WP (CTA) müsste noch nur die Frontabdeckung der Bedieneinheit entfernen. Aber es kann auch sein, dass deine EP das entsprechen Modul gar nicht eingebaut hat.
                                      • chrid88
                                        chrid88 @UncleSam last edited by
                                        @UncleSam https://www.alpha-innotec.ch/alpha-innotec/produkte/waermepumpen/solewasser/swc-82k3.html
                                        Diese haben wir!
                                        • UncleSam
                                          @Christian-Drechsler Sieht gut aus. Auf der Seite steht:
                                          Komfortabel online steuern – mit alpha app und alpha web
                                          Hast du das Inbetriebnahme Handbuch? Dort sollte stehen, wie man das LAN anschliesst.
                                          Bei mir konnte ich die Metall Abdeckung über dem Display und Drehknopf entfernen (nach vorne ziehen) und dann war der LAN Anschluss von unten sichtbar (unterhalb dem Drehknopf).
                                          • TbsJah
                                            TbsJah @UncleSam last edited by TbsJah
                                            @UncleSam said in Test Adapter luxtronik2 v0.1.x:
                                            @UncleSam Ist angefragt und auch umgesetzt 😊
                                            Sobald die Lib aktualisierst werde ich es testen 👍
                                            1.2k
                                            adapter luxtronik wp websocket
                                            52
                                            289
                                            68082
