    4. [ Geklärt ] Problem bei Influx Installation
      crunchip Forum Testing Most Active @Altersrentner last edited by crunchip
      @Altersrentner sagte in Problem bei Influx Installation:
      Wo ist oben?
      https://forum.iobroker.net/post/541116
      ah moment stop, Ubuntu
      @Altersrentner sorry, war grad abgelenkt, hatte kleinen zwischenfall,
      also debian läuft?, dann war ich doch richtig, mit der Anleitung
        Altersrentner @crunchip last edited by
        @crunchip
        Zeile 2 ?
        pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
        OK
        pi@raspberrypi:~ $ source /etc/lsb-release
        -bash: /etc/lsb-release: No such file or directory
        pi@raspberrypi:~ $ sudo source /etc/lsb-release
        sudo: source: command not found
        pi@raspberrypi:~ $
          @Altersrentner das sind doch ganze Befehle, guck mal selbst, auf der ganz normalen offiziellen Seite
            @crunchip
            ● influxdb.service - InfluxDB is an open-source, distributed, time series database
               Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
               Active: active (running) since Sun 2020-12-20 20:05:48 CET; 20s ago
                 Docs: https://docs.influxdata.com/influxdb/
             Main PID: 4285 (influxd)
                Tasks: 14 (limit: 4915)
               CGroup: /system.slice/influxdb.service
                       └─4285 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
            Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999473Z lvl=info msg="Starting continuous query service" log_id=0RCOY820000 service
            Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999496Z lvl=info msg="Starting HTTP service" log_id=0RCOY820000 service=httpd authe
            Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999517Z lvl=info msg="opened HTTP access log" log_id=0RCOY820000 service=httpd path
            Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999520Z lvl=info msg="Storing statistics" log_id=0RCOY820000 service=monitor db_ins
            Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999745Z lvl=info msg="Listening on HTTP" log_id=0RCOY820000 service=httpd addr=[::]
            Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999809Z lvl=info msg="Starting retention policy enforcement service" log_id=0RCOY82
            Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:50.000038Z lvl=info msg="Listening for signals" log_id=0RCOY820000
            Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:50.004535Z lvl=info msg="Sending usage statistics to usage.influxdata.com" log_id=0RCO
            Dec 20 20:05:59 raspberrypi influxd[4285]: ts=2020-12-20T19:05:59.234954Z lvl=info msg="Executing query" log_id=0RCOY820000 service=query query="SHOW
            Dec 20 20:05:59 raspberrypi influxd[4285]: [httpd] 192.168.178.41 - MEB [20/Dec/2020:20:05:59 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precisi
            lines 1-19/19 (END)
            Sieht das gut aus?
              @Altersrentner 👍
              A 2 Replies Last reply Reply Quote 1
                @crunchip
                Ich bedanke 👍 👍 👍 mich für Deine unendlichen Bemühungen
                mir zu helfen.
                Für heute ist Schluss.
                Morgen ist auch noch ein Tag
                Einen schönen Abend
                wünscht Michael
                  @crunchip Hallo,
                  Der Ärger geht weiter.
                  Heute Morgen war noch alles im grünen Bereich.
                  Influydb lief, und der influxdb.0 Adapter war auch grün.
                  Dann hatte ich grafana installiert.
                  Konnte über Port 3000 zugreifen.
                  Bei der Dateneingabe verlief alles gut nur bei Host war
                  localhost vorgegeben. konnte auch nicht in IP geändert werden.
                  Nach Sicherung kam die Meldung keine Verbindung möglich.
                  Darauf habe ich in der influxdb.0 die iP in localhost geändert,
                  in derHoffnung eine Verbindung zu bekommen.
                  Leider klappte das nicht.
                  Nach zurücksetzen localhost in IP bleibt die Ampel jetzt auf gelb.
                  Habe dann grafana und den influxdb.0 Adapter deinstalliert.
                  Adapter neu installiert, daten eingegeben, gestartet und die Ampel bleibt gelb.
                  Im Terminal influxdb überprüft. alles ok, läuft.
                  Das ist die Fehlermeldung aus dem log.
                  influxdb.0	2020-12-21 11:05:35.664	error	(1453) Error: authorization failed
                  influxdb.0	2020-12-21 11:05:35.659	info	(1453) Connecting http://192.168.178.41:8086 ...
                  Juser und Paswort im Adapter sind die, In influxdb eingegebenen.
                  Hast Du noch eine Idee?
                  Gruß Michael
                    @Altersrentner auf die schnelle nicht, da ich unterwegs bin. Möglich, das sich ein Leerzeichen oder so mit eingeschlichen hat?
                      Altersrentner @crunchip last edited by Altersrentner
                      @crunchip Hallo,
                      Ich muss mich doch noch mal um Hilfe bitten.
                      Nicht das jemand denkt ich bin zu düsig! aber es geling mir nicht
                      Influxdb zu konfigurieren.
                      Mehrmaliges löschen und wieder installieren hat nichts gebracht.
                      Ich komme immer bis zu diesem Punkt:
                      OK
                      pi@raspberrypi:~ $ source /etc/os-release
                      pi@raspberrypi:~ $ echo "deb https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                      deb https://repos.influxdata.com/  stable
                      pi@raspberrypi:~ $ sudo apt update
                      E: Malformed entry 1 in list file /etc/apt/sources.list.d/influxdb.list (Component)
                      E: The list of sources could not be read.
                      pi@raspberrypi:~ $ echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                      deb https://repos.influxdata.com/debian buster stable
                      Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
                      Hit:4 https://repos.influxdata.com/debian buster InRelease
                      Fetched 15.0 kB in 2s (9,888 B/s)
                      Reading package lists... Done
                      Building dependency tree
                      All packages are up to date.
                      pi@raspberrypi:~ $ sudo apt install influxdb
                      The following NEW packages will be installed:
                        influxdb
                      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 0 B/60.0 MB of archives.
                      After this operation, 153 MB of additional disk space will be used.
                      Selecting previously unselected package influxdb.
                      (Reading database ... 63673 files and directories currently installed.)
                      Preparing to unpack .../influxdb_1.8.3-1_armhf.deb ...
                      Unpacking influxdb (1.8.3-1) ...
                      Setting up influxdb (1.8.3-1) ...
                      Processing triggers for man-db (2.8.5-2) ...
                      pi@raspberrypi:~ $ sudo systemctl status influxdb.service
                         Active: active (running) since Tue 2020-12-22 11:44:21 CET; 3h 12min ago
                       Main PID: 5478 (influxd)
                                 └─5478 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                      Dec 22 14:55:30 raspberrypi influxd[5478]: ts=2020-12-22T13:55:30.303321Z lvl=info msg="failed to store statistic
                      Dec 22 14:55:40 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:55:40 +0100] "GET /query?db=
                      Dec 22 14:55:40 raspberrypi influxd[5478]: ts=2020-12-22T13:55:40.504680Z lvl=info msg="failed to store statistic
                      Dec 22 14:55:50 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:55:50 +0100] "GET /query?db=
                      Dec 22 14:56:00 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:00 +0100] "GET /query?db=
                      Dec 22 14:56:10 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:10 +0100] "GET /query?db=
                      Dec 22 14:56:21 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:20 +0100] "GET /query?db=
                      Dec 22 14:56:31 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:31 +0100] "GET /query?db=
                      Dec 22 14:56:41 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:41 +0100] "GET /query?db=
                      Dec 22 14:56:51 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:51 +0100] "GET /query?db=
                      pi@raspberrypi:~ $ sudo systemctl unmask influxdb.service
                      pi@raspberrypi:~ $ sudo systemctl start influxdb
                      pi@raspberrypi:~ $ sudo systemctl enable influxdb.service
                      pi@raspberrypi:~ $
                      pi@raspberrypi:~ $
                      pi@raspberrypi:~ $ sudo influx
                      Connected to http://localhost:8086 version 1.8.3
                      InfluxDB shell version: 1.8.3
                      > CREATE DATABASE "iobroker"
                      ERR: unable to parse authentication credentials
                      Warning: It is possible this error is due to not setting a database.
                      Please set a database with the command "use <database>".
                      Alles was danach versucht wird einzugeben wird mit der
                      letzten Fehlermeldung beantwortet
                      Die influxdb.0 Ampel ist gelb.
                      Dortige Eingaben sind wie gehabt
                      Auch USE "iobroker" bringt das selbe Ergebnis.
                      > auth
                      username: admin
                      password:
                      > show database
                      ERR: authorization failed
                      > show databases
                      Gestern habe ich eine andere Speicherkarte neu aufgesetzt.
                      Rasphian buster und iobroker installiert und
                      dort hat die Installation von influxdb und Grafana auf Anhieb geklappt.
                      Ich vermute, das es in einer Konfigurationsdatei Einträge gibt,
                      die diese Fehlermeldungen herforrufen.
                      Freundliche Grüße
                      Michael
                      crunchip 2 Replies Last reply Reply Quote 0
                        @Altersrentner du kannst influx löschen incl aller Abhängigkeiten und Konfigurationseinstellungen, mittels
                        sudo apt-get autoremove --purge influxdb
                        Anschliessend kannst du sauber neu installieren
                        Und wenn du schon beim installieren bist, warum nicht gleich die neuste Version?
                        https://portal.influxdata.com/downloads/
                        Influxdb v 2.0.3
                          Thomas Braun Most Active @crunchip last edited by
                          @crunchip sagte in Problem bei Influx Installation:
                          Weil's da keinen passenden build für 32bit Raspian OS gibt. Alles arm64.
                          A crunchip 2 Replies Last reply Reply Quote 1
                            Altersrentner @Thomas Braun last edited by
                            @Thomas-Braun Hallo,
                            So habe ich das auch gesehen!??
                            Gruß Michael
                              crunchip Forum Testing Most Active @Thomas Braun last edited by
                              @Thomas-Braun stimmt, hatte ich nicht dran gedacht🤦 geht ja um nen raspberry
                                @Altersrentner wenn ich mich nicht Irre, kannst du das create database.... Weglassen auf der Konsole.
                                Die wird nämlich automatisch angelegt, wenn du in deiner Influx Instanz, die Werte/Einstellungen gemacht hast und anschliessend startest. Das denke ich, behebt auch deinen Fehler
                                  @crunchip Hallo,
                                  😊 😊 😊 Es hat geklappt.
                                  Folgende Situation war gegeben,
                                  trotz mehrmaligem löschen der influxdb war aber noch die
                                  alte config vorhanden und damit die vormals kommentierten Zeilen.
                                  Ich war immer davon ausgegangen, das die config auch entfernt wurde.
                                  Habe dann alle Zeilen bis auf bind.... auskommentiert und damit hatten
                                  sich login und database selbst unter influxdb eingetragen.
                                  Das brachte dann SHOW..... ans Licht. ist zwar etwas komisch,
                                  denn in den Anleitungen wird ja immer geschrieben CREATE......
                                  Na ja - alles gut!! für heute reicht`s
                                  Ich bedanke mich nochmals für Eure Unterstützung!
                                  Freundliche Grüße und besinnliche Feiertage
                                  wünscht Michael
                                  crunchip 1 Reply Last reply Reply Quote 1
                                    @Altersrentner sagte in [ Geklärt ] Problem bei Influx Installation:
                                    Ja, man geht bei der offiziellen Anleitung auch nicht davon aus, das iobroker genutzt wird😉
                                    Nein, die config bleibt erhalten, daher hatte ich den Befehl oben genannt, damit alles "Restlos" gelöscht wird und du von Grundauf neu installeren kannst.
                                      Altersrentner @Altersrentner last edited by Altersrentner
                                      @Altersrentner
                                      crunchip 👍 👍 👍
                                        @Altersrentner ein Tipp vorne weg, beim loggen eines Datenpunktes.
                                        Beim Auswahlmenü "Speichern unter" nicht Automatic auswählen, da es je nach Datenpunkt zu Problemen führen kann, wenn der zu loggende Datentyp z.b. vom Typ "boolean" oder "String" ist. Ein nachträgliches Ändern führt dazu, das keine Werte mehr in Grafana angezeigt werden und dieser dann erst aus der Datenbank gelöscht werden muss. Dementsprechend also gleich beim aktivieren den "richtigen Typ auswählen.
                                          @crunchip Hallo,
                                          Danke für Deinen Hinweis!!!!
                                          Ich kämpfe immer noch😧
                                          Möchte mit mi Temperaturen und Türmagneten anfangen.
                                          Natürlich steht alles auf Autom.
                                          Temperaturen sind ja Zahlen und Schalter Logikwerte.
                                          Ich habe aber nur die von Dir gezeigten Parameter zur Auswahl.
                                          Was benutze ich wo?
                                            @Altersrentner ist richtig, siehst du im RAW des jeweiligen Datenpunktes, Stichwort Typ
                                            Beispiel dein xiaomi Klima Sensor. Öffnest den Objektbaum.
                                            Bei Temperatur und Humitidy jeweils, rechts auf den Schraubenschlüssel und config influx aufrufen, da erscheint dann das Fenster, wie in meinem Screen.
                                            Da der Typ in dem Fall "Number" ist ,wählst du dies entsprechend aus. Wenn du unten links "alias" frei lässt, erscheint dein geloggter Datenpunkt auch so wie er in iobroker benannt ist.
                                            Wenn du dann unten mit ok bestätigst, füllt sich die Datenbank, sobald eine Änderung des Wertes stattgefunden hat.
                                            Bei deinem Tür/Fensterkontakt gehst du genauso vor, jedoch ist da der Typ "boolean" auszuwählen.
                                            influxdb
                                            12
                                            178
                                            33083
