    5. [gelöst] Temparatur Umzug Fhem
      paul53 @nolimitek last edited by paul53
      @nolimitek sagte:
      Hat jemand eine Idee
      Bau mal eine Log-Ausgabe ein:
      Lässt sich der Aktor im Tab "Objekte" schalten ?
      • N
        nolimitek @paul53 last edited by
        @paul53 ja kann ich schalten
        Das kommt dabei rauß
        22.12.2020, 17:53:52.013	[info ]: javascript.0 (4229) Stop script script.js.debug
        22.12.2020, 17:53:52.024	[info ]: javascript.0 (4229) Start javascript script.js.debug
        22.12.2020, 17:53:52.031	[info ]: javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.temperature, timerId=undefined) => {"val":"21.1","ack":true,"ts":1608655982096,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1608655982096}
        22.12.2020, 17:53:52.032	[info ]: javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.desiredTemperature, timerId=undefined) => {"val":"13.5","ack":true,"ts":1608655945660,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1608655944150}
        22.12.2020, 17:53:52.032	[info ]: javascript.0 (4229) script.js.debug: Temparatur:21.1Grad13.5
        22.12.2020, 17:53:52.032	[info ]: javascript.0 (4229) script.js.debug: registered 0 subscriptions and 0 schedules
        22.12.2020, 17:54:45.610	[info ]: javascript.0 (4229) Stop script script.js.debug
        22.12.2020, 17:54:45.622	[info ]: javascript.0 (4229) Start javascript script.js.debug
        22.12.2020, 17:54:45.634	[info ]: javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.temperature, timerId=undefined) => {"val":"21.1","ack":true,"ts":1608655982096,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1608655982096}
        22.12.2020, 17:54:45.634	[info ]: javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.desiredTemperature, timerId=undefined) => {"val":"5.0","ack":false,"ts":1608656079906,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1608656079906}
        22.12.2020, 17:54:45.635	[info ]: javascript.0 (4229) script.js.debug: Temparatur:21.1Grad5.0
        22.12.2020, 17:54:45.635	[info ]: javascript.0 (4229) script.js.debug: registered 0 subscriptions and 0 schedules
        N paul53 2 Replies Last reply Reply Quote 0
        • N
          nolimitek @nolimitek last edited by
          gerade nochmals mit dem blockly probiert
          egal ob ich das Terhmostat rauf oder runter schalte es wird immer eingeschaltet
            @nolimitek sagte:
            Wenn der Sollwert so niedrig ist (13,5 / 5,0 °C) muss der Aktor auf wahr schalten, denn Deine Aktion ist falsch herum. Richtig:
            Ist > Soll --> falsch
            EDIT: Liefert FHEM Zahlen? Bitte mittels Modifikation der Log-Ausgabe prüfen:
            N 2 Replies Last reply Reply Quote 0
            • N
              @paul53 wenn ich
              Richtig: Ist > Soll --> falsch mache un dich den wert von zb 5 Grad auf 24 Grad erhöhe als mehr als die Ist Temparatur schaltet er auf off.
              • N
                @paul53 said in Temparatur Umzug Fhem:
                @nolimitek sagte:
                18:19:38.861	info	javascript.0 (4229) Start javascript script.js.debug
                18:19:38.868	info	javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.temperature, timerId=undefined) => {"val":"21.1","ack":true,"ts":1608655982096,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1608655982096}
                18:19:38.868	info	javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.desiredTemperature, timerId=undefined) => {"val":"6.0","ack":true,"ts":1608657576366,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1608657576366}
                18:19:38.868	info	javascript.0 (4229) script.js.debug: Temparatur:stringGradstring
                18:19:38.869	info	javascript.0 (4229) script.js.debug: registered 0 subscriptions and 0 schedules
                  @nolimitek
                  Mit Strings kann es nicht funktionieren. Man muss in Zahlen wandeln:
                  • N
                    @paul53 Wennst mir jetzt noch kurz schreiben könntest wo ich den Block "setze .... auf" finde.
                    Seh langsam nichts mehr 🙂
                      @nolimitek sagte:
                      Unter "Variablen" müssen erst die 3 Variablen ist, soll, ein erstellt werden. Dann wird dort auch "setze auf" angeboten.
                      • N
                        @paul53 Besten Dank für deine Hilfe. Ich hatte das mal schon testweise gemacht da braucht ich aber die umrechnung auf zahlen nicht. Daher brachte mich das gerade fast zu wahnsinn 🙂
                        Jetzt gehts auf alle Fälle
                        lg
                        Christian
                          @nolimitek sagte:
                          Jetzt gehts
                          Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [gelöst].
                          1191
