    4. [Vorstellung] Meine dritte VIS
      Kuddel @marhal last edited by
      @marhal das ist aktuell mein Skript
      // Liest die ioBroker Adapter aus und legt verschiedenen State's an.
      on({id:"system.adapter.admin.0.uptime",change:'any'}, function (obj) {
         createState('Adapter.Anzahl', 0, { name: 'Anzahl', desc: 'Anzahl der Adapter', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
         createState('Adapter.AdapterNummer', 0, { name: 'Adapter zum schalten', desc: 'Adapter zum schalten', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
         //var counterAlt = getState("javascript.0.Adapter.Anzahl").val;
         var counter =0;
         var on = 0
         var manuell=0
         var cacheSelector = $('[id=system.adapter.*.alive]');
         cacheSelector.each(function(id, i) {
             var devicename = getObject(id).common.name;
         	//Instanzen ausklammern
         	instanz0 = devicename.indexOf('daswetter');
         	instanz1 = devicename.indexOf('dwd');
             instanz2 = devicename.indexOf('ical');
         	instanz3 = devicename.indexOf('feiertage');
             instanz4 = devicename.indexOf('kodi.0');
         	instanz5 = devicename.indexOf('snmp.1');
             instanz6 = devicename.indexOf('vis.0');
             instanz7 = devicename.indexOf('yamaha.0');
         	if(instanz0 !=0 && instanz1 != 0 && instanz2 !=0 && instanz3 != 0 && instanz4 != 0 && instanz5 !=0 && instanz6 !=0 && instanz7 !=0){
         		var devicenameName=devicename;
         		var instanzname=getObject(id).common.name;
         		var test = devicenameName;
         		var devicename_array = devicenameName.split(' ');
         		devicenameName = devicename_array[0];
         		counter = counter+1;
         		var strStatePath = "system.adapter." + devicenameName + ".alive";
         		if (isState(strStatePath, true)) {
         			var uptime = getState("system.adapter." + devicenameName + ".uptime").val;
         			var tage = Math.floor(uptime / (24*3600));
         			var stunden = Math.floor((uptime % (24*3600))/3600);
         			var minuten = Math.floor((uptime % (3600))/60);
         			//var sekunden = Math.floor(uptime % 60);
         			if (stunden < 10) {stunden = "0"+stunden};
                     if (minuten < 10) {minuten = "0"+minuten};
         			if (tage == 1) {uptime = tage.toString()+" Tag, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";};
         			if (tage != 1) {uptime = tage.toString()+" Tage, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";}
         			//var total = getState("system.adapter." + devicenameName + ".memHeapTotal").val;
         			//var used = getState("system.adapter." + devicenameName + ".memHeapUsed").val;
         			//var rss = getState("system.adapter." + devicenameName + ".memRss").val;
         			var connect = getState("system.adapter." + devicenameName + ".alive").val;
         			if(connect == false){var con = 0;}
         			else {
         				var con = 1;
         				var strStatePath = devicenameName + ".info.connection";
         					var connectS = getState(devicenameName + ".info.connection").val;
         					if (connectS == false) {
         						con = 2;
         			if(con==1) {on = on + 1}
         		devicename="Adapter.Adapter"+counter.toString()+".KompletterNameAdapter";
         		createState(devicename, 'empty', { name: 'Kompletter Name des Adapters', desc: '', type: 'string', role: '',read: true, write: true });
         		setStateDelayed(devicename, devicenameName, 800);
         		var contentstring = devicenameName;
         		var suchstring = /(ical)/g;
         		var suchergebnis = suchstring.test( contentstring );
         		if (suchergebnis != true) {
         			var devicename_array = devicenameName.split('.');
         		if (devicenameName == "daswetter") {
         			var bild = "/" + devicenameName + ".admin/" + devicenameName + "com.png";
         		} else if (suchergebnis != false) {
         			var icalName = devicename_array[0];
         			var bild = "/" + icalName + ".admin/" + icalName + ".png";
         		} else {
         			var bild = "/" + devicenameName + ".admin/" + devicenameName + ".png";
         		//Alexa2
         		if (devicenameName == 'alexa2') {var bild = "/" + devicenameName + ".admin/" + "alexa.png";}
         		//FritzDECT
         		if (devicenameName == 'fritzdect') {var bild = "/" + devicenameName + ".admin/" + "fritzdect_logo.png";}
         		//FullyBrowser
         		if (devicenameName == 'fullybrowser') {var bild = "/" + devicenameName + ".admin/" + "fully.png";}
         		//HM-Rega
         		//if (devicenameName == 'hm-rega') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
         		if (devicenameName == 'hm-rega') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
         		//HomeMatic
         		//if (instanzname == 'hm-rpc.0 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
         		if (instanzname == 'hm-rpc.0 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
         		//HomeMatic-IP
         		//if (instanzname == 'hm-rpc.1 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
         		if (instanzname == 'hm-rpc.1 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic_ip.jpg";}
         		//UPNP
         		if (devicenameName == 'upnp') {var bild = "/" + devicenameName + ".admin/" + "upnp-discovery.png";}
                 //Pushover.1
         		if (instanzname == 'pushover.1 alive') {var bild = "/mihome-vacuum.admin/mihome-vacuum.png";}
                 //Pushover.2
         		if (instanzname == 'pushover.2 alive') {var bild = "/daswetter.admin/daswettercom.png";}
         		//AdapterName anpassen
                 //DasWetter
         		if (instanzname == 'daswetter.0 alive') {devicenameName='DasWetter'; manuell=1}
         		//DWD
         		if (instanzname == 'dwd.0 alive') {devicenameName='DWD'; manuell=1}
         		//HM-REGA
         		if (instanzname == 'hm-rega.0 alive') {devicenameName='HM-Rega'; manuell=1}
         		//HM-RPC.0
         		if (instanzname == 'hm-rpc.0 alive') {devicenameName='HomeMatic'; manuell=1}
         		//HM-RPC.1
         		if (instanzname == 'hm-rpc.1 alive') {devicenameName='HM-IP'; manuell=1}
         		//MiHome-Vacuum
         		if (instanzname == 'mihome-vacuum.0 alive') {devicenameName='Nono'; manuell=1}
         		//Pushover
         		if (instanzname == 'pushover.0 alive') {devicenameName='Pushover.0'; manuell=1}
         		if (instanzname == 'pushover.1 alive') {devicenameName='Pushover.1'; manuell=1}
         		if (instanzname == 'pushover.2 alive') {devicenameName='Pushover.2'; manuell=1}
         		//Simple-API
         		if (instanzname == 'simple-api.0 alive') {devicenameName='Simple-API'; manuell=1}
         		//SNMP.0
         		if (instanzname == 'snmp.0 alive') {devicenameName='SNMP.0'; manuell=1}
         		//SNMP.1
         		if (instanzname == 'snmp.1 alive') {devicenameName='SNMP.1'; manuell=1}
                 //Spotify
                 if (instanzname == 'spotify-premium.0 alive') {devicenameName='Spotify'; manuell=1}
                 //TR-064.0
         		if (instanzname == 'tr-064.0 alive') {devicenameName='TR-064.0'; manuell=1}
         		//TR-064.1
         		if (instanzname == 'tr-064.1 alive') {devicenameName='TR-064.1'; manuell=1}
                 //XPEnology
                 if (instanzname == 'synology.1 alive') {devicenameName='XPEnology'; manuell=1}
         		//Instanz-Namen setzen
         		if(manuell!=1) {devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();}
                 //devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();
         		devicename="Adapter.Adapter"+counter.toString()+".NameInstanz";
         		createState(devicename, 'empty', { name: 'Name des Geräts', desc: '', type: 'string', role: '',read: true, write: true });
         		//Bild Pfad setzen
         		devicename="Adapter.Adapter"+counter.toString()+".Bild";
         		createState(devicename, 'empty', { name: 'Speicherort Bild', desc: '', type: 'string', role: '',read: true, write: true });
         		setStateDelayed(devicename, bild, 800);
         		//Uptime setzen
         		devicename="Adapter.Adapter"+counter.toString()+".Uptime";
         		createState(devicename, 'empty', { name: 'Uptime', desc: '', type: 'string', role: '',read: true, write: true });
         		setStateDelayed(devicename, uptime, 800);
         		//MemUsed setzen
         		//devicename="Adapter.Adapter"+counter.toString()+".MemUsed";
         		//createState(devicename, 0, { name: 'Link MemUsed', desc: '', type: 'number', role: '',read: true, write: true });
         		//setStateDelayed(devicename, used, 800);
         		//MemToal setzen
         		//devicename="Adapter.Adapter"+counter.toString()+".MemTotal";
         		//createState(devicename, 0, { name: 'Link MemTotal', desc: '', type: 'number', role: '',read: true, write: true });
         		//setStateDelayed(devicename, total, 800);
         		//MemRSS setzen
         		//devicename="Adapter.Adapter"+counter.toString()+".MemRSS";
         		//createState(devicename, 0, { name: 'Link MemRSS', desc: '', type: 'number', role: '',read: true, write: true });
         		//setStateDelayed(devicename, rss, 800);
         		//Connected setzen
         		devicename="Adapter.Adapter"+counter.toString()+".Connected";
         		createState(devicename, 0, { name: 'Status Adapter', desc: '', type: 'number', role: '',read: true, write: true });
         		setStateDelayed(devicename, con, 800);
                 //Wert zurücksetzen
                 var manuell=0
         //Adaptet Icon Übersicht
         visstatus="javascript.0.VIS-Status.alle_adapter_gestartet";
         if(on == counter){setState(visstatus, true);}
         if(on == counter -1){setState(visstatus, true);}
         if(on < counter -1){setState(visstatus, false);}
         setStateDelayed('Adapter.Anzahl', counter, 800);
         function isState(strStatePath, strict) {
             let mSelector;
             if (strict) {
                 mSelector = $('state[id=' + strStatePath + '$]');
             } else {
                 mSelector = $('state[id=' + strStatePath + ']');
             if (mSelector.length > 0) {
                 return true;
             } else {
                 return false;
      on({id:"javascript.0.Adapter.AdapterNummer", change: 'any'}, function (dpobj) {
         if (getState("javascript.0.Adapter.AdapterNummer").val != 0) {
             const instanz = "javascript." + instance;
             var adapterNummer = getState(instanz + ".Adapter.AdapterNummer").val;
             var adapter = getState(instanz + ".Adapter.Adapter" + adapterNummer + ".KompletterNameAdapter").val; // Name und Instanz des Adapters
             var idAdapter = "system.adapter." + adapter;
             var obj = getObject(idAdapter);
             if (dpobj.state.val == false) {
                 obj.common.enabled = true;  // Adapter einschalten
             } else if (dpobj.state.val == true) {
                 obj.common.enabled = false;  // Adapter ausschalten
             setObject(idAdapter, obj);
             setStateDelayed('javascript.0.Adapter.AdapterNummer', 0, 800);
      Bevor wir jetzt groß rumprobieren, nimm einfach mal diese Version
      S K 2 Replies Last reply Reply Quote 0
      • V
        volx3eet @KHK last edited by
        Hat mir auch geholfen 😊
          Sequal @Kuddel last edited by
          @Kuddel
          Hut ab vor Deiner Arbeit! Deine Visualisierung ist echt gut gelungen!
          Ich hab allerdings ein kleines Verständnisproblem mit den Wetter-Views. Es wird alles bestens angezeigt, Objekte sind alle da, auch die Scripte laufen....eigentlich. Es wird jedoch nichts aktualisiert außer Datum und Uhrzeit. Temperaturen, Icons etc. bleiben immer bei den eingestellten Datenpunkten zb. von Day1. Auch die 5-Tagesübersicht bleibt wie eingerichtet, aber ändert sich nicht mit dem Fortschreiten der Woche. Was für ein Script hab ich da übersehen oder hab ich den Wetter.com-Adapter nicht richtig eingerichtet? Welcher Pfad im Adapter soll benutzt werden? Ich suche gerad den Wald zwischen all den Bäumen.....
          Sequal
            Kuddel @Sequal last edited by
            @Sequal die VIS stellt ja nur die Wetterdaten vom Adapter "DasWetter" dar.
            Ändern sich deine DPs unter "daswetter.0" denn korrekt ?
            Wenn der Adapter die Daten nicht korrekt aktualisiert, gibt es in der VIS natürlich auch keine Veränderungen.
              Sequal @Kuddel last edited by Sequal
              @Kuddel
              Ich war eigentlich der Meinung, die Datenpunkte sind alle korrekt, bis mir auffiel, dass sich die Temperaturen nicht verändern auf der Startseite. Kann es daran liegen, dass ich den falschen API Pfad im Adapter ausgewählt habe? Welcher passt hier?
                @Sequal poste mal bitte einen Screenshot von deinen Adapter Einstellungen, dann kann ich morgen früh mal vergleichen
                  @Kuddel said in [Vorstellung] Meine dritte VIS:
                  Ich hab die Instanz vorhin testweise gelöscht, neu hinzugefügt aber noch nicht wieder konfiguriert.
                  Erster Schritt wäre zu wissen, welchen Pfad Du gewählt hast, damit ich das schonmal ausschließen kann.
                  Gruß und Danke!
                  K V 2 Replies Last reply Reply Quote 0
                    • V
                      volx3eet @Sequal last edited by
                      @Sequal Ich hab dir hier auch nochmal eine Anleitung angehängt. Ich gehe davon aus, daß du dir bereits einen Account erstellt hast bei daswetter. Wenn du dich dort einloggst findest du eigentlich alle Links die du im Adapter eintragen musst.
                      Anleitung
                      VG
                      Volx
                        @Kuddel
                        Ok, Du hast 3 Pfade eingetragen......ich hatte mir einen ausgesucht. Vielleicht war das der Haken 🙂 Ich beobachte.....Danke!
                        Euch schöne Feiertage!
                          Sequal @volx3eet last edited by
                          @volx3eet
                          Jo, danke. War bereits alles eingerichtet, aber eben nur ein Pfad. Ich hatte die Erläuterung so verstanden.....
                            Sequal @Sequal last edited by
                            Nabend zusammen,
                            ich hab noch eine Kleinigkeit:
                            Kann mir jemand auf die Sprünge helfen wieso im Warnungsfeld anstatt dem Wert "warning begin" in korrekter Datums/Uhrzeitform lediglich eine 13stellige Zahl angezeigt wird? Ich finde den Fehler nicht.....
                            Sequal
                              @Sequal das kam glaube ich mit dem letzten Update vom DWD Adapter.
                              Habe mich bei in meiner aktuelle VIS gefixt.
                              Widgets:
                              [{"tpl":"tplFrame","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"","title_color":"#FFFFFF","title_top":"-10","title_left":"30","header_height":"0","header_color":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"title_back":"","title_font":"","name":"!_Hintergrund"},"style":{"left":"0px","top":"0px","width":"410px","height":"280px","color":"","z-index":"1","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","background":"#202020"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Wetterwarnungen","name":"!_Überschrift"},"style":{"left":"0px","top":"0px","height":"30px","width":"410px","z-index":"10","color":"white","text-align":"center","text-shadow":"","font-family":"Arial, Helvetica, sans-serif","font-style":"","font-variant":"","font-weight":"bolder","font-size":"20px","line-height":"30px","background":"grey"},"widgetSet":"basic"},{"tpl":"tplTimeValue","data":{"oid":"dwd.0.warning.begin","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"format_date":"DD.MM.YYYY - hh:mm","name":"Beginn","visibility-oid":"dwd.0.warning.severity","html_prepend":"Beginn: ","html_append":" Uhr"},"style":{"left":"20px","top":"90px","width":"250px","height":"20px","z-index":"20","font-weight":"bolder","line-height":"20px"},"widgetSet":"basic"},{"tpl":"tplValueListHtml8","data":{"oid":"dwd.0.warning.severity","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","count":"4","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Beschreibung","value2":"{dwd.0.warning.description}","value3":"{dwd.0.warning.description}","value5":"Hauptbrüste blockiert","value6":"Seitenbrüste blockiert","value7":"Festgefahren","value8":"Blockiert","visibility-oid":"dwd.0.warning.severity","html_prepend":"","style5":"color: red","style6":"color: red","test_list":"1","style2":"color: orange","value0":"dwd.0.warning.description}","value1":"{dwd.0.warning.description}","value4":"{dwd.0.warning.description}","value9":"Staubbehälter fehlt","value10":"Filter reinigen","value11":"Steckt in magn. Barriere","style0":"","style7":"color: red","style8":"color: red","style3":"color: red","style1":"color: yellow","style4":"color: red","style9":"color: red","style10":"color: red","style11":"color: red","value12":"Batterie leer","value13":"Ladefehler","value14":"Batterie  Fehler","value15":"Wand-Sensoren dreckig","value16":"Ebene Fläche benötigt","value17":"Seitenbürsten Problem","value18":"Sauggebläse Problem","value19":"Ladestation nicht angeschlossen","style12":"color: red","style13":"color: red","style14":"color: red","style15":"color: red","style16":"color: red","style18":"color: red","style17":"color: red","style19":"color: red"},"style":{"left":"20px","top":"145px","width":"370px","height":"120px","z-index":"10","text-align":"left","font-family":"Arial, Helvetica, sans-serif","font-weight":"bolder","font-size":"medium","line-height":"","background-color":"","border-radius":"","border-width":"","border-style":"","border-color":""},"widgetSet":"basic"},{"tpl":"tplTimeValue","data":{"oid":"dwd.0.warning.end","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"format_date":"DD.MM.YYYY - hh:mm","name":"Ende","visibility-oid":"dwd.0.warning.severity","html_prepend":"Ende: ","html_append":" Uhr"},"style":{"left":"20px","top":"110px","width":"250px","height":"20px","z-index":"20","font-weight":"bolder","line-height":"20px"},"widgetSet":"basic"},{"tpl":"tplValueListHtml8","data":{"oid":"dwd.0.warning.severity","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"count":"4","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Rahmen","value2":"","value3":"","value5":"Hauptbrüste blockiert","value6":"Seitenbrüste blockiert","value7":"Festgefahren","value8":"Blockiert","html_prepend":"","style5":"color: red","style6":"color: red","test_list":"1","style2":"color: red","value0":"Keine Meldung vorhanden","value1":"","value4":"","value9":"Staubbehälter fehlt","value10":"Filter reinigen","value11":"Steckt in magn. Barriere","style0":"boder-color: #41f316","style7":"color: red","style8":"color: red","style3":"color: red","style1":"color: orange","style4":"color: red","style9":"color: red","style10":"color: red","style11":"color: red","value12":"Batterie leer","value13":"Ladefehler","value14":"Batterie  Fehler","value15":"Wand-Sensoren dreckig","value16":"Ebene Fläche benötigt","value17":"Seitenbürsten Problem","value18":"Sauggebläse Problem","value19":"Ladestation nicht angeschlossen","style12":"color: red","style13":"color: red","style14":"color: red","style15":"color: red","style16":"color: red","style18":"color: red","style17":"color: red","style19":"color: red","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"5px","top":"40px","width":"400px","height":"235px","z-index":"10","text-align":"center","font-family":"Arial, Helvetica, sans-serif","font-weight":"bolder","font-size":"20px","line-height":"235px","background-color":"","border-radius":"10px","border-width":"1px","border-style":"solid","border-color":"{wert:dwd.0.warning.severity; wert==0? \"#41f316\": wert==1? \"yellow\": wert==2? \"orange\": wert==3? \"red\": wert==4? \"red\": \"#303030\"} "},"widgetSet":"basic"},{"tpl":"tplValueListHtml8","data":{"oid":"dwd.0.warning.severity","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"count":"4","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Severity","value2":"{dwd.0.warning.severity}","value3":"{dwd.0.warning.severity}","value5":"Hauptbrüste blockiert","value6":"Seitenbrüste blockiert","value7":"Festgefahren","value8":"Blockiert","html_prepend":"Crit: ","style5":"color: red","style6":"color: red","test_list":"1","style2":"color: orange","value0":"","value1":"{dwd.0.warning.severity}","value4":"{dwd.0.warning.severity}","value9":"Staubbehälter fehlt","value10":"Filter reinigen","value11":"Steckt in magn. Barriere","style0":"","style7":"color: red","style8":"color: red","style3":"color: red","style1":"color: yellow","style4":"color: red","style9":"color: red","style10":"color: red","style11":"color: red","value12":"Batterie leer","value13":"Ladefehler","value14":"Batterie  Fehler","value15":"Wand-Sensoren dreckig","value16":"Ebene Fläche benötigt","value17":"Seitenbürsten Problem","value18":"Sauggebläse Problem","value19":"Ladestation nicht angeschlossen","style12":"color: red","style13":"color: red","style14":"color: red","style15":"color: red","style16":"color: red","style18":"color: red","style17":"color: red","style19":"color: red","visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","visibility-oid":"dwd.0.warning.severity"},"style":{"left":"345px","top":"0px","width":"60px","height":"30px","z-index":"10","text-align":"right","font-family":"Arial, Helvetica, sans-serif","font-weight":"normal","font-size":"medium","line-height":"30px","background-color":"","border-radius":"","border-width":"","border-style":"","border-color":""},"widgetSet":"basic"},{"tpl":"tplValueListHtml8","data":{"oid":"dwd.0.warning.severity","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","count":"4","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Überschrift","value2":"{dwd.0.warning.text}","value3":"{dwd.0.warning.text}","value5":"Hauptbrüste blockiert","value6":"Seitenbrüste blockiert","value7":"Festgefahren","value8":"Blockiert","visibility-oid":"dwd.0.warning.severity","html_prepend":"","style5":"color: red","style6":"color: red","test_list":"1","style2":"color: orange","value0":"{dwd.0.warning.text}","value1":"{dwd.0.warning.text}","value4":"{dwd.0.warning.text}","value9":"Staubbehälter fehlt","value10":"Filter reinigen","value11":"Steckt in magn. Barriere","style0":"","style7":"color: red","style8":"color: red","style3":"color: red","style1":"color: yellow","style4":"color: red","style9":"color: red","style10":"color: red","style11":"color: red","value12":"Batterie leer","value13":"Ladefehler","value14":"Batterie  Fehler","value15":"Wand-Sensoren dreckig","value16":"Ebene Fläche benötigt","value17":"Seitenbürsten Problem","value18":"Sauggebläse Problem","value19":"Ladestation nicht angeschlossen","style12":"color: red","style13":"color: red","style14":"color: red","style15":"color: red","style16":"color: red","style18":"color: red","style17":"color: red","style19":"color: red"},"style":{"left":"20px","top":"45px","width":"370px","height":"35px","z-index":"10","text-align":"center","font-family":"Arial, Helvetica, sans-serif","font-weight":"normal","font-size":"25px","line-height":"30px","background-color":"","border-radius":"","border-width":"","border-style":"","border-color":""},"widgetSet":"basic"}]
                                KHK @Kuddel last edited by
                                @Kuddel
                                Habe dein eingestellte Script mal probiert, aber irgenwie werden nicht alle Daten gelesen...oder ist der Eintrag "object.object" richtig?
                                  Kuddel @KHK last edited by
                                  @KHK ne da läuft was nicht richtig. Uptime und Connected werde nicht korrekt ausgelesen.
                                  Sieht das bei allen Adaptenr so aus?
                                    @Kuddel
                                    ja, deswegen war ich mir nicht ganz sicher...
                                      @KHK wie sehen deine Einstellungen von der Javascript Instanz aus ?
                                        @Kuddel Der Haken unter "Erlaube das Kommando "sendtohost" war nicht gesetzt. Habe das angepasst, aber keine Änderung.
                                          @Kuddel
                                          Habe im Log dies entdeckt:
                                          Wo könnte ich dies finden?
                                            @KHK die Warnung sagt nur aus, dass der Wert, der in die DPs geschrieben werden soll, den falschen Typ hat. Bei Uptime wird ein String erwartet und bei Connected eine Nummer
                                            vis vis projekte
                                            83
                                            640
                                            172298
