    4. Test Adapter nibeuplink v0.4.0 Latest
      seb Developer last edited by seb
      Aktuelle Test Version 0.4.0
      Veröffentlichungsdatum 24.12.2020 - Christmas edition 😉
      Github Link https://github.com/sebilm/ioBroker.nibeuplink
      Hinweis:
      Direkt nach dem Update kommt es vermutlich zu einem "Bad Request"-Fehler (in den Logs und im Error-Datenpunkt vom nibeuplink-Adapter). Das passiert, weil leider das Token zur Authendifizierung beim Update verloren geht. Deshalb muss man in den nibeuplink-Einstellungen den AuthCode über den Link neu holen und eintragen. Dann funktioniert es wieder. Das Problem habe ich in dieser Version behoben. Es muss aber beim Update zu dieser Version noch einmal durchgeführt werden. Bei späteren Versionen nicht mehr.
      Changelog
      • Set required js-controller to >=2.0.0
      • Test for Node 8 removed
      • Support for compact mode enabled
      • Support for more than one unit added
        • There is a new object structure - one level more for the unit.
        • The old objects will be updated if they are found - so don't panic.
        • If you don't need the old objects, you can remove them. They will not be created again.
      • Devide by 10 added to external flow temperature
      • Hundreds of missing parameters were added
        • The old fallback objects are no longer supported and updated. So check your objects update time.
        • You can remove the old objects. They will not be created again.
      • Fallback names for unknown parameters changed (id added at the beginning)
        • If you have objects with numbers at the beginning, then these are fallback names. Please email me and I can add them.
      • Store session in iobroker data directory
        • After the adapter update you always had to get a new AuthCode and set it in the adapter settings.
        • This is no longer necessary from the next version.
        • But after the update to this version (0.4.0) it is necessary once again.
      • Translate object keys of serial number, version and product in english for all languages (section SYSTEM_INFO)
        • The old objects are no longer supported and updated. So check your objects update time.
      • Norwegian added
      • Code refactoring
      Die Version ist im latest verfügbar. Wurde über GitHub durch mich und 2 andere User schon getestet. Ich freue mich über weitere Rückmeldungen.
        Matzeit @seb last edited by
        @seb Super! Habs heute im Admin aktualisiert. Jetzt sind fast alle Werte abrufbar!
        Was mir lediglich noch fehlt ist die "Ventilatorstufe" der Außeneinheit.
        1.2k
        81.1k
        nibe nibeuplink test
