    4. Test Adapter Material Design Widgets v0.4.x
    • O
      Oli @Scrounger last edited by
      @Scrounger said in Test Adapter Material Design Widgets v0.4.0-beta:
      Welcher Button beim Dialog Widget?
      Sorry, wahrscheinlich etwas doof ausgedrückt
      Betroffenes Widget:
      Soll aussehen wie
      Hier der Consoleneintrag:
      :8082/vis/adapter/rssfeed/words.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_5.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_5.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_5.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_5.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_8.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_8.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_8.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_8.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_8.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_8.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_8.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_8.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_8.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_11.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_11.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_11.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_11.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_11.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_11.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_11.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_11.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_11.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_14.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_14.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_14.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_14.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_14.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_14.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_14.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_14.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_14.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_17.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_17.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_17.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_17.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_17.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_17.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_17.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_17.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_17.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_20.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_20.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_20.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_20.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_20.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_20.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_20.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_20.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_20.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_23.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_23.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_23.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_23.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_23.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_23.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_23.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_23.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.Hour_23.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_2.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_2.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_2.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_2.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_2.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_2.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_2.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_2.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_2.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_5.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_5.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_5.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_5.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_5.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_5.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_5.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_5.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_5.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_8.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_8.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_8.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_8.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_8.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_8.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_8.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_8.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_8.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_11.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_11.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_11.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_11.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_11.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_11.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_11.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_11.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_11.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_14.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_14.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_14.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_14.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_14.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_14.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_14.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_14.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_14.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_17.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_17.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_17.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_17.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_17.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_17.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_17.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_17.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_17.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_20.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_20.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_20.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_20.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_20.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_20.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_20.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_20.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_20.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_23.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_23.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_23.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_23.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_23.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_23.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_23.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_23.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.Hour_23.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_1.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_1.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_1.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_1.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_1.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_1.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_1.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_1.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_2.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_2.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_2.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_2.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_2.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_2.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_2.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_2.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_2.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_3.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_3.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_3.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_3.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_3.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_3.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_3.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_3.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_3.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_4.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_4.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_4.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_4.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_4.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_4.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_4.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_4.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_4.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_5.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_5.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_5.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_5.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_5.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_5.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_5.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_5.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_5.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_6.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_6.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_6.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_6.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_6.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_6.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_6.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_6.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_6.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_7.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_7.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_7.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_7.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_7.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_7.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_7.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_7.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_7.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_8.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_8.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_8.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_8.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_8.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_8.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_8.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_8.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.Hour_8.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_1.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_1.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_1.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_1.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_1.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_1.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_1.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_1.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_1.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_2.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_2.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_2.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_2.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_2.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_2.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_2.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_2.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_2.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_3.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_3.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_3.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_3.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_3.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_3.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_3.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_3.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_3.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_4.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_4.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_4.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_4.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_4.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_4.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_4.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_4.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_4.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_5.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_5.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_5.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_5.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_5.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_5.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_5.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_5.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_5.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_6.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_6.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_6.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_6.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_6.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_6.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_6.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_6.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_6.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_7.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_7.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_7.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_7.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_7.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_7.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_7.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_7.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_7.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_8.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_8.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_8.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_8.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_8.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_8.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_8.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_8.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.Hour_8.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_1.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_1.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_1.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_1.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_1.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_1.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_1.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_1.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_1.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_2.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_2.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_2.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_2.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_2.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_2.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_2.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_2.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_2.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_3.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_3.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_3.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_3.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_3.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_3.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_3.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_3.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_3.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_4.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_4.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_4.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_4.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_4.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_4.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_4.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_4.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_4.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_5.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_5.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_5.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_5.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_5.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_5.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_5.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_5.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_5.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_6.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_6.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_6.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_6.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_6.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_6.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_6.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_6.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_6.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_7.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_7.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_7.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_7.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_7.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_7.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_7.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_7.temp_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_7.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_8.symbol_desc
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_8.symbol_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_8.hour_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_8.snowline_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_8.humidity_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_8.pressure_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_8.rain_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_8.wind_value
      promisebuffer.ts:24 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.Hour_8.temp_value
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Ambrosia.index_tomorrow
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Beifuss.index_today
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Beifuss.index_tomorrow
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Birke.index_today
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Birke.index_tomorrow
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Erle.index_today
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Erle.index_tomorrow
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Esche.index_today
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Esche.index_tomorrow
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#24.Esche.index_today
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Graeser.index_today
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Graeser.index_tomorrow
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Hasel.index_today
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Hasel.index_tomorrow
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Roggen.index_today
      promisebuffer.ts:24 Create inner vis object pollenflug.0.region#124.Roggen.index_tomorrow
      promisebuffer.ts:24 Create inner vis object javascript.0.Wetter.Diagramme.Chart.Day_1
      promisebuffer.ts:24 Create inner vis object javascript.0.Biowetter.nürnberg.Kombi
      promisebuffer.ts:24 Create inner vis object system.adapter.openuv.0.alive
      promisebuffer.ts:24 Create inner vis object openuv.0.UV_Max
      promisebuffer.ts:24 Create inner vis object openuv.0.UV_Bewertung
      promisebuffer.ts:24 Create inner vis object javascript.0.Wetter.Diagramme.UvIndex.UvIndex
      promisebuffer.ts:24 Create inner vis object javascript.0.Qnap.Diagramm.Control.timeInterval
      promisebuffer.ts:24 Create inner vis object weatherunderground.0.forecast.0d.precipitationDay
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.0.status
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.0.e5.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.0.e5.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.cheapest.e5.station_id
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.0.e10.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.0.e10.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.cheapest.e10.station_id
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.0.diesel.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.0.diesel.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.cheapest.diesel.station_id
      promisebuffer.ts:24 Create inner vis object javascript.0.Tankstellen.stations.0.Adresse
      promisebuffer.ts:24 Create inner vis object javascript.0.Tankstellen.stations.1.Adresse
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.1.status
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.1.e5.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.1.e5.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.1.e10.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.1.e10.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.1.diesel.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.1.diesel.3rd
      promisebuffer.ts:24 Create inner vis object javascript.0.Tankstellen.stations.2.Adresse
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.2.status
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.2.e5.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.2.e5.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.2.e10.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.2.e10.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.2.diesel.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.2.diesel.3rd
      promisebuffer.ts:24 Create inner vis object javascript.0.Tankstellen.stations.3.Adresse
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.3.status
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.3.e5.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.3.e5.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.3.e10.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.3.e10.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.3.diesel.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.3.diesel.3rd
      promisebuffer.ts:24 Create inner vis object javascript.0.Tankstellen.stations.4.Adresse
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.4.status
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.4.e5.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.4.e5.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.4.e10.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.4.e10.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.4.diesel.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.4.diesel.3rd
      promisebuffer.ts:24 Create inner vis object javascript.0.Tankstellen.stations.5.Adresse
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.5.status
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.5.e5.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.5.e5.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.5.e10.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.5.e10.3rd
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.5.diesel.combined
      promisebuffer.ts:24 Create inner vis object tankerkoenig.0.stations.5.diesel.3rd
      promisebuffer.ts:24 Create inner vis object javascript.0.Tankstellen.Diagramm.Benzinpreise
      promisebuffer.ts:24 Create inner vis object javascript.0.Tankstellen.Diagramm.Control.timeInterval
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Bestelldaten.Zahlungsart ID
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Bestelldaten.Heizölsorte ID
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Bestelldaten.Entladestellen
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Bestelldaten.Lieferort
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Bestelldaten.Liefermenge
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Bruttopreis 100l
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.MwSt 100l
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Nettozuschlag 100l
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Nettopreis 100l
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Skriptstart
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Bruttopreis Gesamt
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.MwSt Gesamt
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Nettozuschlag Gesamt
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Nettopreis Gesamt
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Lieferant.Mail
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Lieferant.Fax
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Lieferant.Telefon
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Lieferant.Adresse
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Lieferant.Name
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Heizölpreis.Allgemein.Preis
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Heizölpreis.Allgemein.Änderung zum Vortag
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Heizölpreis.Allgemein.Trend zum Vortag
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Diagramme.Heizoelpreis.Heizölpreis
      promisebuffer.ts:24 Create inner vis object javascript.0.Heizoel.Diagramme.Heizoelpreis.Control.timeInterval
      promisebuffer.ts:24 Create inner vis object bring.0.1fd76184-df96-42b0-93ae-fca87b2e468e
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.calendar.ical2calendar
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fontSizes.calendar.header
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.calendar.header
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fontSizes.calendar.today
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.calendar.today
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fontSizes.calendar.weeks
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.calendar.weeks
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.light.calendar.button_background
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.dark.calendar.button_background
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fontSizes.calendar.button
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.calendar.button
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fontSizes.calendar.button_today
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.calendar.button_today
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.light.calendar.control_panel_background
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.dark.calendar.control_panel_background
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fontSizes.calendar.control
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.calendar.control
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fontSizes.calendar.time_axis
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.calendar.time_axis
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fontSizes.calendar.event
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.calendar.event
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Datum.tagmonattext
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Jahr.Schaltjahr_String
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Quartal.Nummer
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Woche.Jahr.Kalenderwoche.Nummer
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Woche.Jahr.Anzahl
      promisebuffer.ts:24 Create inner vis object javascript.0.scriptEnabled.common.System.Kalender.System_Datuminfo
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Tag.Monat.Zukunft.Anzahl
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Tag.Monat.Vergangenheit.Anteil
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Tag.Monat.Vergangenheit.Anzahl
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Tag.Monat.Anzahl
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Tag.Monat.Nummer
      promisebuffer.ts:24 Create inner vis object javascript.2.Paket.trackntrace.Tabelle
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Monat.Name.lang
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Tag.Jahr.Zukunft.Anzahl
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Tag.Jahr.Vergangenheit.Anteil
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Tag.Jahr.Vergangenheit.Anzahl
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Tag.Jahr.Anzahl
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Tag.Jahr.Nummer
      promisebuffer.ts:24 Create inner vis object javascript.0.Kalender.Datuminfo.de.Jahr.Zahl
      promisebuffer.ts:24 Create inner vis object javascript.0.Rezepte.Rezeptsuche.SpeisenID
      promisebuffer.ts:24 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Name
      promisebuffer.ts:24 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Blättern.AnzahlRezepte
      promisebuffer.ts:24 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Blättern.Stand
      promisebuffer.ts:24 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Link
      promisebuffer.ts:24 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Schwierigkeitsgrad
      promisebuffer.ts:24 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Portionen
      promisebuffer.ts:24 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Zubereitung
      ​ Create inner vis object javascript.0.Rezepte.Rezeptsuche.Gesamtzeit
      ​ Create inner vis object javascript.0.Rezepte.Rezeptsuche.Zutaten
      ​ Create inner vis object javascript.0.Rezepte.Rezeptsuche.vis.switch
      ​ Create inner vis object javascript.0.Rezepte.Rezeptsuche.Bild
      ​ Create inner vis object javascript.0.Essensplan.save_rezept
      ​ Create inner vis object javascript.0.Essensplan.Montag.Link
      ​ Create inner vis object javascript.0.Essensplan.vis_switch
      ​ Create inner vis object javascript.0.Netzwerk.jsonList
      ​ Create inner vis object javascript.0.Netzwerk.sortMode
      ​ Create inner vis object javascript.0.Netzwerk.filterMode
      ​ Create inner vis object ping.0.ioBroker.192_168_2_1
      ​ Create inner vis object ping.0.ioBroker.www_google_de
      ​ Create inner vis object ping.0.ioBroker.192_168_2_103
      ​ Create inner vis object ping.0.ioBroker.192_168_2_110
      ​ Create inner vis object ping.0.ioBroker.192_168_2_107
      ​ Create inner vis object ping.0.ioBroker.192_168_2_125
      ​ Create inner vis object ping.0.ioBroker.192_168_2_115
      ​ Create inner vis object ping.0.ioBroker.192_168_2_111
      ​ Create inner vis object ping.0.ioBroker.192_168_2_108
      ​ Create inner vis object ping.0.ioBroker.192_168_2_112
      ​ Create inner vis object ping.0.ioBroker.192_168_2_113
      ​ Create inner vis object ping.0.ioBroker.192_168_2_106
      ​ Create inner vis object ping.0.ioBroker.192_168_2_105
      ​ Create inner vis object ping.0.ioBroker.192_168_2_121
      ​ Create inner vis object ping.0.ioBroker.192_168_2_123
      ​ Create inner vis object ping.0.ioBroker.192_168_2_124
      ​ Create inner vis object ping.0.ioBroker.192_168_2_127
      ​ Create inner vis object ping.0.ioBroker.192_168_2_122
      ​ Create inner vis object ping.0.ioBroker.192_168_2_117
      ​ Create inner vis object homee.0.MeteringPlug-20.CurrentEnergyUse-190
      ​ Create inner vis object javascript.0.Adapter.filterMode
      ​ Create inner vis object javascript.0.Adapter.sortMode
      ​ Create inner vis object javascript.0.Adapter.jsonList
      ​ Create inner vis object javascript.0.SkriptStatus.jsonList
      ​ Create inner vis object javascript.0.SkriptStatus.filterMode
      ​ Create inner vis object javascript.0.SkriptStatus.sortMode
      ​ Create inner vis object web-speedy.0.Results.speeds.download_Mb
      ​ Create inner vis object web-speedy.0.Results.speeds.upload_Mb
      ​ Create inner vis object web-speedy.0.Results.speeds.upload_MB
      ​ Create inner vis object javascript.0.Web-Speedy-Test.Diagramm
      ​ Create inner vis object javascript.0.Web-Speedy-Test.Control.timeInterval
      ​ Create inner vis object vis-materialdesign.0.fontSizes.card.subTitle
      ​ Create inner vis object vis-materialdesign.0.fonts.card.subTitle
      ​ Create inner vis object vis-materialdesign.0.fontSizes.card.text
      ​ Create inner vis object vis-materialdesign.0.fonts.card.text
      ​ Create inner vis object vis-materialdesign.0.colors.light.card.subTitle
      ​ Create inner vis object vis-materialdesign.0.colors.dark.card.subTitle
      ​ Create inner vis object vis-materialdesign.0.colors.light.card.text
      ​ Create inner vis object vis-materialdesign.0.colors.dark.card.text
      promisebuffer.ts:24 Create inner vis object javascript.0.Web-Speedy-Test.VISAnzeige
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Results.client.country
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Results.client.isp
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Results.client.ip
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Results.Last_Run
      promisebuffer.ts:24 Create inner vis object web-speedy.0.running_upload
      promisebuffer.ts:24 Create inner vis object web-speedy.0.running_upload_speed
      promisebuffer.ts:24 Create inner vis object web-speedy.0.running_upload_progress
      promisebuffer.ts:24 Create inner vis object web-speedy.0.running_download
      promisebuffer.ts:24 Create inner vis object web-speedy.0.running_download_speed
      promisebuffer.ts:24 Create inner vis object web-speedy.0.running_download_progress
      promisebuffer.ts:24 Create inner vis object web-speedy.0.test_auto_intervall
      promisebuffer.ts:24 Create inner vis object web-speedy.0.test_best
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Results.client.isprating
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.3.bestPing
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.2.bestPing
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.1.bestPing
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.0.bestPing
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.3.name
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.2.name
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.1.name
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.0.name
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.3.country
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.2.country
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.1.country
      promisebuffer.ts:24 Create inner vis object web-speedy.0.Closest_servers.0.country
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive homee.Anzahl_ohne_Batterie
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive homee.Anzahl_Batterie
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive homee.Anzahl_Geräte
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive homee.Anzahl_deaktivierte_homeegramme
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive homee.Anzahl_Aktivierte_homeegramme
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive homee.Anzahl_homeegramme
      promisebuffer.ts:24 Create inner vis object homee.0.Homee-0.UsedStorage-211
      promisebuffer.ts:24 Create inner vis object homee.0.Homee-0.MemoryUsage-209
      promisebuffer.ts:24 Create inner vis object homee.0.Homee-0.ProcessorUtilization-210
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive homee.MaterialWidgetTable
      promisebuffer.ts:24 Create inner vis object info.0.sysinfo.os.processes.list
      promisebuffer.ts:24 Create inner vis object info.0.sysinfo.os.processes.all
      promisebuffer.ts:24 Create inner vis object javascript.0.Adapter.anzahl
      promisebuffer.ts:24 Create inner vis object info.0.sysinfo.os.versions.kernel
      promisebuffer.ts:24 Create inner vis object info.0.sysinfo.system.hardware.model
      promisebuffer.ts:24 Create inner vis object info.0.sysinfo.os.info.platform
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive ioBroker.Uptime
      promisebuffer.ts:24 Create inner vis object system.host.ioBroker.memAvailable
      promisebuffer.ts:24 Create inner vis object info.0.sysinfo.os.versions.node
      promisebuffer.ts:24 Create inner vis object info.0.sysinfo.os.versions.npm
      promisebuffer.ts:24 Create inner vis object info.0.sysinfo.os.versions.git
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive ioBroker.ioBroker_Updates
      promisebuffer.ts:24 Create inner vis object info.0.newsfeed_filtered
      promisebuffer.ts:24 Create inner vis object admin.0.info.updatesNumber
      promisebuffer.ts:24 Create inner vis object admin.0.info.lastUpdateCheck
      promisebuffer.ts:24 Create inner vis object info.0.sysinfo.cpu.currentLoad.currentload_user
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive ioBroker.ioBroker_ram_usage
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive ioBroker.Diagramm.ioBroker
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive ioBroker.Diagramm.Control.timeInterval
      promisebuffer.ts:24 Create inner vis object backitup.0.history.json
      promisebuffer.ts:24 Create inner vis object backitup.0.output.line
      promisebuffer.ts:24 Create inner vis object backitup.0.history.iobrokerLastTime
      promisebuffer.ts:24 Create inner vis object backitup.0.oneClick.iobroker
      promisebuffer.ts:24 Create inner vis object backitup.0.info.iobrokerNextTime
      promisebuffer.ts:24 Create inner vis object info.0.sysinfo.cpu.info.brand
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive QNAP TS-453 B mini.Name
      promisebuffer.ts:24 Create inner vis object snmp.0.192_168_2_115.Freier_Speicher RAM
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive QNAP TS-453 B mini.Uptime
      promisebuffer.ts:24 Create inner vis object snmp.0.192_168_2_115.Speicherplatz_Total
      promisebuffer.ts:24 Create inner vis object snmp.0.192_168_2_115.Speicherplatz_Frei
      promisebuffer.ts:24 Create inner vis object snmp.0.192_168_2_115.Gesamtspeicher_RAM
      promisebuffer.ts:24 Create inner vis object info.0.sysinfo.disks.fsSize.fs0.use
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive QNAP TS-453 B mini.Diagramm.Qnap
      promisebuffer.ts:24 Create inner vis object javascript.0.Netzwerk.Alive QNAP TS-453 B mini.Diagramm.Control.timeInterval
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.win10_ram_free
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.uptime
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.win10_totalsize
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.win10_freespace
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.win10_ram_total
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.win10_ram_usage
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.win10_cpu_usage
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.win10_c_usage
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.win10_d_usage
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.win10_f_usage
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.Diagramm.PC
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.pc.Diagramm.Control.timeInterval
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.laptop.win10_ram_free
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.laptop.uptime
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.laptop.win10_totalsize
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.laptop.win10_freespace
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.laptop.win10_ram_total
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.laptop.win10_ram_usage
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.laptop.win10_cpu_usage
      promisebuffer.ts:24 Create inner vis object javascript.0.Chart.history.timeInterval
      promisebuffer.ts:24 Create inner vis object javascript.0.Ressourcen.laptop.win10_c_usage
      promisebuffer.ts:24 Create inner vis object logparser.0.visualization.table0.json
      promisebuffer.ts:24 Create inner vis object logparser.0.visualization.table0.selection
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Info.jsonCount
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Warn.jsonCount
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Error.jsonCount
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Info.mostRecentLogTime
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Warn.mostRecentLogTime
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Error.mostRecentLogTime
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Info.emptyJson
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Warn.emptyJson
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Error.emptyJson
      promisebuffer.ts:24 Create inner vis object logparser.0.lastTimeUpdated
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Debug.jsonCount
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Debug.emptyJson
      promisebuffer.ts:24 Create inner vis object logparser.0.filters.Debug.mostRecentLogTime
      promisebuffer.ts:24 Create inner vis object logparser.0.visualization.table0.emptyJson
      promisebuffer.ts:24 Create inner vis object logparser.0.emptyAllJson
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.icon_list.text
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.icon_list.subText
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.light.icon_list.subText
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.dark.icon_list.subText
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.OrdnerCheck
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.RunScript
      promisebuffer.ts:24 Create inner vis object controll-own.0.mount.CPULuefter
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.RunSuccessful
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.MonsterSearch
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.CheckAliase
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.LatestChangeDP
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.LatestChangeDP_Factor
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.HistoryAnalyse
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.SmartHomeAnalyse
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.JavaInstanzCheck
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.ohneInstanzAnzeige
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.TypeAnalyse
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.WertAnalyse
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.ObjectAnzahlCheck
      promisebuffer.ts:24 Create inner vis object javascript.0.ProofingDatapoints.HTMLTable
      promisebuffer.ts:24 Create inner vis object javascript.0.Energieverbrauch.Strom.filterMode
      promisebuffer.ts:24 Create inner vis object javascript.0.Energieverbrauch.Strom.sortMode
      promisebuffer.ts:24 Create inner vis object javascript.0.Energieverbrauch.Strom.jsonList
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.GuestsPresent
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.switch.value
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fontSizes.switch.value
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.light.switch.on_hover
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.dark.switch.on_hover
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.light.switch.lock_icon
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.dark.switch.lock_icon
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.PartyNow
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.Present
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.PublicHolidyToday
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.HolidayPresent
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.VacationAbsent
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.TempDecreaseValues.VacationAbsentDecrease
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.TempValueListValue
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.TempDivValueListText
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.TempDecreaseValues.PartyDecrease
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.TempDecreaseValues.GuestIncrease
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.TempAddValueListText
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.TempDecreaseValues.AbsentDecrease
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.RoomValues.MinimumTemperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.TempDecreaseValues.WindowOpenDecrease
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.RoomValues.TemperaturOverride
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ChoosenRoom
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.CurrentProfile
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.info.TemperatureDecreaseMode
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.RoomValues.TemperaturOverrideTime
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.Rooms.Bad.WindowIsOpen
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.Rooms.Wohnzimmer.WindowIsOpen
      promisebuffer.ts:24 Create inner vis object javascript.0.HeatingControl.Thermostat.Vorhanden
      promisebuffer.ts:24 Create inner vis object javascript.0.HeatingControl.Thermostat.Modus
      promisebuffer.ts:24 Create inner vis object javascript.0.HeatingControl.Thermostat.Ventil
      promisebuffer.ts:24 Create inner vis object javascript.0.HeatingControl.Thermostat.Soll
      promisebuffer.ts:24 Create inner vis object javascript.0.HeatingControl.Raumthermostat.Ist
      promisebuffer.ts:24 Create inner vis object javascript.0.HeatingControl.Thermostat.Ist
      promisebuffer.ts:24 Create inner vis object javascript.0.HeatingControl.Thermostat.Auswahl
      promisebuffer.ts:24 Create inner vis object javascript.0.HeatingControl.Thermostat.Boost
      promisebuffer.ts:24 Create inner vis object homee.0.info.connection
      promisebuffer.ts:24 Create inner vis object hm-rpc.0.info.connection
      promisebuffer.ts:24 Create inner vis object javascript.0.HeatingControl.Thermostat.LastChange Text
      promisebuffer.ts:24 Create inner vis object javascript.0.HeatingControl.WindowStatesJsonTable
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.OpenWindowRoomCount
      promisebuffer.ts:24 Create inner vis object javascript.0.vis.HeatingControl.OpenWindowRoomCount
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.light.button.icon.icon_off
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.dark.button.icon.icon_off
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.light.button.icon.background_off
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.dark.button.icon.background_off
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.light.button.icon.lock_icon_background
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.dark.button.icon.lock_icon_background
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.info.UsedRooms
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileValueListValue
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.info.ProfileType
      promisebuffer.ts:24 Create inner vis object javascript.0.HeatingControl.CurrentTimePeriod
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.4.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.info.NumberOfPeriods
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.4.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.3.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.3.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.2.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.2.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.1.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.1.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.0.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.0.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.4.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.4.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.3.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.3.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.2.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.2.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.1.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.1.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.0.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.0.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.4.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.4.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.3.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.3.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.2.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.2.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.1.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.1.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.0.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.0.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.4.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.4.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.3.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.3.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.2.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.2.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.1.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.1.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.0.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.0.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.4.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.4.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.3.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.3.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.2.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.2.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.1.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.1.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.0.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.0.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.4.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.4.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.3.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.3.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.2.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.2.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.1.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.1.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.0.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.0.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.4.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.4.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.3.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.3.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.2.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.2.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.1.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.1.time
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.0.Temperature
      promisebuffer.ts:24 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.0.time
      promisebuffer.ts:24 Create inner vis object hm-rpc.0.MEQ0251193.4.SET_TEMPERATURE
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Büro.1.CurrentValvePosition
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Büro.1.Ist-Temperatur
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Büro.1.Solltemperatur
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Büro.1.HeatingMode
      promisebuffer.ts:24 Create inner vis object javascript.0.Gewerke.FensterEG.Büro.RoomOpenWindowCount
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Toilette.1.CurrentValvePosition
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Toilette.1.HeatingMode
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Toilette.1.Solltemperatur
      promisebuffer.ts:24 Create inner vis object javascript.0.Gewerke.FensterEG.Toilette.RoomOpenWindowCount
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Toilette.1.Ist-Temperatur
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.1.Ventilstellung
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.1.Solltemperatur
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.button.vertical.text
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fontSizes.button.vertical.text
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.1.HeatingMode
      promisebuffer.ts:24 Create inner vis object javascript.0.Gewerke.Fenster_EG.Wohnzimmer.RoomOpenWindowCount
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.1.Ist-Temperatur
      promisebuffer.ts:24 Create inner vis object netatmo.0.Home-(Netatmo-Wohnzimmer).Netatmo-Wohnzimmer.Humidity.Humidity
      promisebuffer.ts:24 Create inner vis object netatmo.0.Home-(Netatmo-Wohnzimmer).Netatmo-Wohnzimmer.CO2.CO2
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Wohnzimmer.2.Solltemperatur
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.2.HeatingMode
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.2.Ist-Temperatur
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.2.Ventilstellung
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.2.Solltemperatur
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.3.HeatingMode
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Wohnzimmer.3.Solltemperatur
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.3.Ist-Temperatur
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.3.Ventilstellung
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.EG.Wohnzimmer.3.Solltemperatur
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Bad.1.CurrentValvePosition
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Bad.1.Solltemperatur
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Bad.1.HeatingMode
      promisebuffer.ts:24 Create inner vis object linkeddevices.0.Heizung.Bad.1.Ist-Temperatur
      promisebuffer.ts:24 Create inner vis object javascript.0.Gewerke.FensterDG.Bad.RoomOpenWindowCount
      promisebuffer.ts:24 Create inner vis object javascript.0.Gewerke.FensterEG.Wohnzimmer.RoomOpenWindowCount
      promisebuffer.ts:24 Create inner vis object javascript.0.TV.Steuerung.Aktuelle Beschreibung
      promisebuffer.ts:24 Create inner vis object harmony.0.Harmony_Hub.activities.currentActivity
      promisebuffer.ts:24 Create inner vis object javascript.0.TV.Steuerung.Laufzeit
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.light.progress.track_background
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.dark.progress.track_background
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fontSizes.progress.text
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.fonts.progress.text
      promisebuffer.ts:24 Create inner vis object javascript.0.TV.Steuerung.Rest Min
      promisebuffer.ts:24 Create inner vis object javascript.0.TV.Steuerung.Aktueller Start
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.light.button.icon.pressed
      promisebuffer.ts:24 Create inner vis object vis-materialdesign.0.colors.dark.button.icon.pressed
      promisebuffer.ts:24 Create inner vis object javascript.0.TV.Steuerung.Aktuelles Ende
      promisebuffer.ts:24 Create inner vis object javascript.0.TV.Steuerung.Aktuelle Sendung
      promisebuffer.ts:24 Create inner vis object kodi.0.system.webserver
      promisebuffer.ts:24 Create inner vis object kodi.0.info.type
      promisebuffer.ts:24 Create inner vis object kodi.0.info.fanart
      promisebuffer.ts:24 Create inner vis object kodi.0.play
      promisebuffer.ts:24 Create inner vis object kodi.0.pause
      promisebuffer.ts:24 Create inner vis object kodi.0.next
      promisebuffer.ts:24 Create inner vis object kodi.0.previous
      promisebuffer.ts:24 Create inner vis object kodi.0.stop
      promisebuffer.ts:24 Create inner vis object kodi.0.mute
      promisebuffer.ts:24 Create inner vis object kodi.0.seek
      promisebuffer.ts:24 Create inner vis object kodi.0.repeat
      promisebuffer.ts:24 Create inner vis object kodi.0.shuffle
      promisebuffer.ts:24 Create inner vis object kodi.0.position
      promisebuffer.ts:24 Create inner vis object kodi.0.playlist
      promisebuffer.ts:24 Create inner vis object kodi.0.speed
      promisebuffer.ts:24 Create inner vis object kodi.0.info.currentplay
      promisebuffer.ts:24 Create inner vis object kodi.0.info.tagline
      promisebuffer.ts:24 Create inner vis object kodi.0.info.playing_time
      promisebuffer.ts:24 Create inner vis object kodi.0.info.plot
      promisebuffer.ts:24 Create inner vis object kodi.0.info.playing_time_total
      promisebuffer.ts:24 Create inner vis object kodi.0.info.rating
      promisebuffer.ts:24 Create inner vis object kodi.0.info.year
      promisebuffer.ts:24 Create inner vis object kodi.0.info.video_width
      promisebuffer.ts:24 Create inner vis object kodi.0.info.video_height
      promisebuffer.ts:24 Create inner vis object kodi.0.info.genre
      promisebuffer.ts:24 Create inner vis object kodi.0.info.originaltitle
      promisebuffer.ts:24 Create inner vis object kodi.0.info.thumbnail
      promisebuffer.ts:24 Create inner vis object kodi.0.state
      promisebuffer.ts:24 Create inner vis object denon.0.zoneMain.muteIndicator
      promisebuffer.ts:24 Create inner vis object denon.0.zoneMain.volumeDB
      promisebuffer.ts:24 Create inner vis object denon.0.zoneMain.volumeDown
      promisebuffer.ts:24 Create inner vis object denon.0.zoneMain.volumeUp
      promisebuffer.ts:24 Create inner vis object javascript.0.TV.Steuerung.Aktuelles Logo
      promisebuffer.ts:24 Create inner vis object harmony.0.Elite.activities.currentActivity
      promisebuffer.ts:24 Create inner vis object harmony.0.Harmony_Hub.activities.3D_Film_wiedergeben
      promisebuffer.ts:24 Create inner vis object harmony.0.Elite.activities.HTPC/_Kodi
      promisebuffer.ts:24 Create inner vis object harmony.0.Harmony_Hub.activities.Fire_TV_sehen
      promisebuffer.ts:24 Create inner vis object harmony.0.Harmony_Hub.activities.Fernsehen
      promisebuffer.ts:24 Create inner vis object harmony.0.Harmony_Hub.Panasonic_TV.ChannelUp
      promisebuffer.ts:24 Create inner vis object harmony.0.Harmony_Hub.Panasonic_TV.ChannelDown
      promisebuffer.ts:24 Create inner vis object javascript.0.TV.Steuerung.Aktuelles Programm
      promisebuffer.ts:24 Create inner vis object harmony.0.Harmony_Hub.activities.Wiedergabe_Xbox_360
      promisebuffer.ts:24 Create inner vis object harmony.0.Harmony_Hub.activities.Musik_hören
      promisebuffer.ts:24 Create inner vis object javascript.0.TV.Steuerung.jsonList
      promisebuffer.ts:24 Create inner vis object rssfeed.0.TVProgramm.HoerzuTVFilmTipp
      promisebuffer.ts:24 Create inner vis object rssfeed.0.TVProgramm.HoerzuTVSerienTipp
      promisebuffer.ts:24 Create inner vis object rssfeed.0.TVProgramm.HoerzuTVDokuTipp
      promisebuffer.ts:24 Create inner vis object rssfeed.0.TVProgramm.HoerzuTVUnterhaltungTipp
      promisebuffer.ts:24 Create inner vis object rssfeed.0.TVProgramm.HoerzuTVSportTipp
      promisebuffer.ts:24 Create inner vis object javascript.0.TV.ProgrammInfo.Tabelle
      promisebuffer.ts:24 Create inner vis object yamaha.0.input
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.TUN.PRESET
      promisebuffer.ts:24 Create inner vis object yamaha.0.power
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.MAIN.VOL
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.MAIN.INP
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.TUN.AVAIL
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.MAIN.PWR
      promisebuffer.ts:24 Create inner vis object hm-rega.0.22425.ProgramExecute
      promisebuffer.ts:24 Create inner vis object hm-rega.0.22436.ProgramExecute
      promisebuffer.ts:24 Create inner vis object musiccast.0.RX-V481_08125F03.netusb.presetrecallnumber
      promisebuffer.ts:24 Create inner vis object musiccast.0.RX-V481_08125F03.netusb.albumart_url
      promisebuffer.ts:24 Create inner vis object yamaha.0.Commands.skip
      promisebuffer.ts:24 Create inner vis object yamaha.0.Commands.stop
      promisebuffer.ts:24 Create inner vis object yamaha.0.Commands.toggleMute
      promisebuffer.ts:24 Create inner vis object yamaha.0.Commands.rewind
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.SERVER.ELAPSEDTIME
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.SERVER.PLAYBACKINFO
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.NETRADIO.ELAPSEDTIME
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.NETRADIO.AVAIL
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.TUN.FMFREQ
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.NETRADIO.PLAYBACKINFO
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.NETRADIO.MAXLINE
      promisebuffer.ts:24 Create inner vis object denon.0.info.friendlyName
      promisebuffer.ts:24 Create inner vis object yaTUN.AVAILmaha.0.Realtime.
      promisebuffer.ts:24 Create inner vis object yamaha.0.Realtime.TUN.RDSCLOCK
      promisebuffer.ts:24 Create inner vis object javascript.0.TV.HubSequence.input
      promisebuffer.ts:24 Version vis-hqwidgets: 1.1.7
      instrument.ts:353 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
      (anonymous) @ instrument.ts:353
      breadcrumbs.ts:164 Failed to load resource: the server responded with a status of 404 (Not Found)
      (anonymous) @ breadcrumbs.ts:164
      promisebuffer.ts:24 Error: can't render tplMusiccastAlbumArt w03368 on "900_Denon":
      promisebuffer.ts:24 Error: 0 - Error: can.view: No template or empty template:tplMusiccastAlbumArt.ejsError: can.view: No template or empty template:tplMusiccastAlbumArt.ejs
      promisebuffer.ts:24 Error: 1 -     at u (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:256)
      promisebuffer.ts:24 Error: 2 -     at Object.error (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:953)
      promisebuffer.ts:24 Error: 3 -     at j (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:2:27295)
      promisebuffer.ts:24 Error: 4 -     at Object.fireWith [as rejectWith] (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:2:28108)
      promisebuffer.ts:24 Error: 5 -     at x (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:22086)
      promisebuffer.ts:24 Error: 6 -     at b (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:25980)
      promisebuffer.ts:24 Error: 7 -     at Object.send (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:26084)
      promisebuffer.ts:24 Error: 8 -     at Object.ajax (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:21520)
      promisebuffer.ts:24 Error: 9 -     at o (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:899)
      promisebuffer.ts:24 Error: 10 -     at http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:46:3358
      promisebuffer.ts:24 Error: 11 -     at Function.renderAs (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:3466)
      promisebuffer.ts:24 Error: 12 -     at Object.e.view.e.template (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:1267)
      promisebuffer.ts:24 Error: 13 -     at Object.renderWidget (http://192.168.2.120:8082/vis/js/vis.js:1623:33)
      promisebuffer.ts:24 Error: 14 -     at http://192.168.2.120:8082/vis/js/vis.js:915:120
      promisebuffer.ts:24 Error: 15 -     at http://192.168.2.120:8082/vis/js/vis.js:2841:31
      promisebuffer.ts:24 Error: 16 -     at r.<anonymous> (http://192.168.2.120:8082/vis/js/conn.js:734:21)
      promisebuffer.ts:24 Error: 17 -     at r.onack (http://192.168.2.120:8082/lib/js/socket.io.js:8:10900)
      promisebuffer.ts:24 Error: 18 -     at r.onpacket (http://192.168.2.120:8082/lib/js/socket.io.js:8:10268)
      promisebuffer.ts:24 Error: 19 -     at r.<anonymous> (http://192.168.2.120:8082/lib/js/socket.io.js:8:12354)
      promisebuffer.ts:24 Error: 20 -     at r.emit (http://192.168.2.120:8082/lib/js/socket.io.js:6:19839)
      promisebuffer.ts:24 Error: 21 -     at r.ondecoded (http://192.168.2.120:8082/lib/js/socket.io.js:6:25583)
      promisebuffer.ts:24 Error: 22 -     at a.<anonymous> (http://192.168.2.120:8082/lib/js/socket.io.js:8:12354)
      promisebuffer.ts:24 Error: 23 -     at a.r.emit (http://192.168.2.120:8082/lib/js/socket.io.js:6:19839)
      promisebuffer.ts:24 Error: 24 -     at a.add (http://192.168.2.120:8082/lib/js/socket.io.js:6:12498)
      promisebuffer.ts:24 Error: 25 -     at r.ondata (http://192.168.2.120:8082/lib/js/socket.io.js:6:25536)
      promisebuffer.ts:24 Error: 26 -     at r.<anonymous> (http://192.168.2.120:8082/lib/js/socket.io.js:8:12354)
      promisebuffer.ts:24 Error: 27 -     at r.emit (http://192.168.2.120:8082/lib/js/socket.io.js:6:19839)
      promisebuffer.ts:24 Error: 28 -     at r.onPacket (http://192.168.2.120:8082/lib/js/socket.io.js:7:2948)
      promisebuffer.ts:24 Error: 29 -     at r.<anonymous> (http://192.168.2.120:8082/lib/js/socket.io.js:7:560)
      promisebuffer.ts:24 Error: 30 -     at r.emit (http://192.168.2.120:8082/lib/js/socket.io.js:6:19839)
      promisebuffer.ts:24 Error: 31 -     at r.onPacket (http://192.168.2.120:8082/lib/js/socket.io.js:7:15217)
      promisebuffer.ts:24 Error: 32 -     at r.onData (http://192.168.2.120:8082/lib/js/socket.io.js:7:15166)
      promisebuffer.ts:24 Error: 33 -     at WebSocket.ws.onmessage (http://192.168.2.120:8082/lib/js/socket.io.js:8:6594)
      promisebuffer.ts:24 Error: can't render tplBarNavigator w03370 on "900_Denon":
      promisebuffer.ts:24 Error: 0 - Error: can.view: No template or empty template:tplBarNavigator.ejsError: can.view: No template or empty template:tplBarNavigator.ejs
      promisebuffer.ts:24 Error: 13 -     at Object.renderWidget (http://192.168.2.120:8082/vis/js/vis.js:1638:33)
      transparens.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
      2:8082/icons-mfd-svg/status_light_low.svg:1 Failed to load resource: the server responded with a status of 404 (Not Found)
      promisebuffer.ts:24 [IconList - w00003] event bind for 'javascript.0.Adapter.restartTrigger.val'
      DevTools failed to load SourceMap: Could not load content for http://192.168.2.120:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      • Scrounger
        Scrounger Developer @Oli last edited by
        @Oli sagte in Test Adapter Material Design Widgets v0.4.0-beta:
        @Scrounger said in Test Adapter Material Design Widgets v0.4.0-beta:
        Welcher Button beim Dialog Widget?
        Sorry, wahrscheinlich etwas doof ausgedrückt
        Betroffenes Widget:
        Soll aussehen wie
        Der Dialog hat standardmäßig den default button und nicht den vertical button.
        Erstell dir einen datenpunkt (boolean) für den dialog und verwende ihn im vertical button, dann kannst das layout verwenden
          dos1973 @Scrounger last edited by
          @Scrounger
          ist ja noch beta, 🙂
          ich hoffe du steckst da noch etwas Arbeit rein.
          Ja, ich habe deinen Rat befolgt, habe 2 Tabs offen und einfach eine neue VIS gestartet und alle Buttons reingezogen und versucht diese zu definieren.
          ich Kriegs nicht hin - ich ändere etwas an einer Stelle und habe dann ein Effekt an einer anderen Stelle - wo ich es nicht will und leider auch nicht nachvollziehen kann. Dann muss ich wieder anfangen "hardcoded" einzutragen...
          ich habe leider nur ein Notebook, auf kleinen Bildschirmen ist das alles sehr gequetscht. Auch die Beschreibung (ganz recht) sind nicht immer ganz aussagekräftig.
          keine Ahnung, ob ich es mir einfach schwer machen, viel feedback gabs bisher leider noch nicht. Ich kann meine Fehler auch gar nicht richtig beschreiben, da ich irgendwie nicht fertig stellen kann, immer ändert sich irgendwo eine Farbe, wo ich nicht will
          Button Toggle und Button Toggle vertical verhalten sich nicht gleich.
          Trotzdem Dank für deine Mühe und dass du deine Tools hier bereitsstellst!
          • Scrounger
            Scrounger Developer @dos1973 last edited by
            @dos1973
            Das bekommen wir schon hin 🙂
            Anbei eine detaillierte Erläuterung wie das ganze funktioniert, hoffe es ist für Euch verständlicher.
            Standard Farben:
            Über die Standard Farben können die Farben für alle Widgets geändert werden, sofern die Widgets Standard Farben zugewiesen haben (über die Buttons 0-11 im Editor).
            Wie du siehst ändern sich bei allen Widgets die Farben.
            Standard Farben Widgets zuweisen:
            Über die Buttons 0-11 können gezielt einzelnen Widgets die oben definierten standard Farben zugewiesen werden.
            Wie du siehst ändert sich hier nur die Farben der Default Buttons, nicht die vom den vertical Buttons
            individuelle Farben Widgets zuweisen:
            Alternativ kann man den Widgets auch eigene Farben zuweisen, unabhängig von den oben definierten standard Farben
            Wie du siehst ändert sich nur die Farbe vom Progress Widget. Wenn du oben jetzt die Standard Farben änderst, wird das Progress Widget davon nicht beeinflusst.
              @Scrounger
              Prinzipiell, verstanden habe ich es und finde den Ansatz auch gut und richtig.
              Aber die Auswirkungen kann ich einfach nicht steuern.
              Du hast es gebaut, für dich wahrscheinlich simpel und logisch, aber dadurch dass der Effekt auf eine vielzahl Widgets durchschlägt ist es nicht nachvollziehbar .
              Im vis habe ich klare Abgrenzungen, Bei Dir hat ein Wert Auswirkung auf die verschiedenen Widgets.
              Ich würde immer noch dafür plädieren, pro Widget die möglichen Farben definieren, dann sind alle widgets/Typ gleich formatiert.
              Kann ja noch immer ein „Übernehme für alle vom Typ des Widgets“ Knopf geben...
              Kannst du nochmals erklären was Primär/ Sekundärfarben sind.
              Noch eine Frage:
              Wenn ich jetzt ein neues Vis, mit komplett neuem Farbdesign machen möchte, wie würde das gehen? Eine neue Instanz anlegen ging nucht
              • Scrounger
                Scrounger Developer @dos1973 last edited by Scrounger
                @dos1973 sagte in Test Adapter Material Design Widgets v0.4.0-beta:
                Primäre und Sekundäre Farbe gibt es nur bei den Button und Button Vertical. Hintergrund ist, dass man für die Buttons 4 verschiedene Styles auswählen kann (raised, unelevated, outlined und text).
                Damit ich nicht für jeden Sytle extra Farben erstellen musste, habe ich Primäre und Sekundäre Farbe eingebaut. Beim Style raised und unelevated ist die Primäfarbe Hintergrund, Sekundärfarbe ist Schrift und Click Farbe. Beim Style outlined und text ist Primärfarbe dann Text, Click und Rand, Sekundär wird nicht verwendet.
                Bsp: Primärfabre blau, Sekundärfarbe weiß
                Genau das gibt es doch:
                @Scrounger sagte in Test Adapter Material Design Widgets v0.4.0-beta:
                Ich schätze dich irritiert das z.B. Button State & Button Toggle das gleiche Theme verwenden?
                Das sind auch gleiche Widgets, nur mit unterschiedlichen Funktionen. Ein Theme ist dazu da das Layout von gleichen Elementen z.B. Buttons einheitlich zu steuern, ganz unabhängig von der Funktion.
                • tobasium
                  tobasium @Oli last edited by
                  @Oli hast du das Darstellungsproblem im Icon List Widget gelöst. Ich steh auf dem schlauch. Mir geht's genauso.
                  • tobasium
                    tobasium last edited by
                    @Scrounger , ich habe das gleiche Problem wie Oli weiter oben.
                    ich gebe unter CSS Allgemein die Höhe an normalerweise sollte dann der scrollbalken erscheinen aber Pustekuchen.
                    Folgende Ansichten sind davon betroffen:
                    Adapter Status
                    UniFi Netzwerk Status
                    Vor dem Update auf die 0.4 ging dies noch.
                    • O
                      Oli @tobasium last edited by
                      @tobasium
                      Ich konnte das Problem leider noch nicht lösen
                      • Scrounger
                        @tobasium
                        D.h bei dir ist auch das Problem das die scroll Bär nicht angezeigt wird? Höhe einstellen geht?
                        • O
                          Oli @Scrounger last edited by
                          @Scrounger
                          Ja genau, siehe Poste: https://forum.iobroker.net/topic/39522/test-adapter-material-design-widgets-v0-4-0-beta/63
                          Consoleneinträge: https://forum.iobroker.net/topic/39522/test-adapter-material-design-widgets-v0-4-0-beta/67
                          Scrounger 1 Reply Last reply Reply Quote 1
                          • Scrounger
                            @Oli, @tobasium
                            @tobasium sagte in Test Adapter Material Design Widgets v0.4.0-beta:
                            Sollte behoben sein, aktuelle version von github bitte testen.
                            tobasium 1 Reply Last reply Reply Quote 0
                            • tobasium
                              tobasium @Scrounger last edited by
                              @Scrounger Leider immer noch gleich, keine Veränderung.
                              Scrounger Nashra 2 Replies Last reply Reply Quote 0
                              • Scrounger
                                Scrounger Developer @tobasium last edited by Scrounger
                                @tobasium
                                Upload des vis Adapter durchgeführt? Bzw iob neu gestartet?
                                • tobasium
                                  @Scrounger ich hab es eben sicherheitshalber noch einmal getestet.
                                  Update via github
                                  Upload
                                  Iobroker neustart
                                  keine Veränderung.
                                  • Scrounger
                                    @tobasium
                                    Also ich kann den Fehler jetzt nicht mehr reproduzieren, d.h. fix müsste gehen.
                                    • Browser cache gelöscht?
                                    • upload vom vis Adapter gemacht? (nicht MDW Adapter!)
                                    • overflow-x / -y mal raus genommen und wieder gesetzt?
                                    • Widget löschen und neu erstellen?
                                    • tobasium
                                      @Scrounger also overflow-x / -y mal raus genommen und wieder gesetzt? --> war die Lösung.
                                      Vielen Dank.
                                      • Nashra
                                        Nashra Most Active Forum Testing @tobasium last edited by
                                        Moin, ist das ein Script von dir @tobasium und würdest Du dies zur verfügung stellen?
                                        • O
                                          Oli @Nashra last edited by
                                          @Nashra
                                          Schau mal hier:
                                          https://forum.iobroker.net/topic/30662/material-design-widgets-skript-status
                                          • Nashra
                                            Nashra Most Active Forum Testing @Oli last edited by
                                            @Nashra
                                            Schau mal hier:
                                            Boah das ist mir wohl durchgegangen, die Skripte für die Adapter und Unifi hatte ich ja
                                            Aber das Skript habe ich echt übersehen. 😞
                                            @Oli danke für den Link
                                            31.7k
                                            79.9k
                                            adapter material material design widgets vis visualisation widget
                                            20
                                            126
                                            14081
