    4. JavaScript
    5. HTMLTabelle UnifiClients-newAdapter
      MyMeyer last edited by
      Hatte paar Tage Pause 🙂 ...das schaue ich mir doch mal an. 😊
        @liv-in-sky Hi, bekomme ein paar Fehler im Log angezeigt. Habe die aktuelle Version am laufen.
        script.js.Allgemein.Unifi_Tabelle_1
        12.7.2020, 22:49:44.065 [warn ]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:191:20
        12.7.2020, 22:49:44.065 [warn ]: javascript.0 (27555) at writeHTML (script.js.Allgemein.Unifi_Tabelle_1:175:36)
        12.7.2020, 22:49:44.066 [warn ]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:342:1
        12.7.2020, 22:49:44.070 [error]: javascript.0 (27555) script.js.Allgemein.Unifi_Tabelle_1: script.js.Allgemein.Unifi_Tabelle_1:230
        12.7.2020, 22:49:44.070 [error]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:230:148
        12.7.2020, 22:49:44.071 [error]: javascript.0 (27555) at writeHTML (script.js.Allgemein.Unifi_Tabelle_1:229:18)
        12.7.2020, 22:49:44.071 [error]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:342:1
        12.7.2020, 22:49:58.214 [info ]: javascript.0 (27555) Stop script script.js.Allgemein.Unifi_Tabelle_1
        12.7.2020, 22:49:58.271 [info ]: javascript.0 (27555) Start javascript script.js.Allgemein.Unifi_Tabelle_1
        12.7.2020, 22:49:58.284 [warn ]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:191:20
        12.7.2020, 22:49:58.284 [warn ]: javascript.0 (27555) at writeHTML (script.js.Allgemein.Unifi_Tabelle_1:175:36)
        12.7.2020, 22:49:58.284 [warn ]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:342:1
        12.7.2020, 22:49:58.288 [error]: javascript.0 (27555) script.js.Allgemein.Unifi_Tabelle_1: script.js.Allgemein.Unifi_Tabelle_1:230
        12.7.2020, 22:49:58.289 [error]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:230:148
        12.7.2020, 22:49:58.289 [error]: javascript.0 (27555) at writeHTML (script.js.Allgemein.Unifi_Tabelle_1:229:18)
        12.7.2020, 22:49:58.289 [error]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:342:1
        12.7.2020, 22:50:00.010 [warn ]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:191:20
        12.7.2020, 22:50:00.010 [warn ]: javascript.0 (27555) at writeHTML (script.js.Allgemein.Unifi_Tabelle_1:175:36)
        12.7.2020, 22:50:00.010 [warn ]: javascript.0 (27555) at Object.<anonymous> (script.js.Allgemein.Unifi_Tabelle_1:339:2)
        12.7.2020, 22:50:00.015 [error]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:230:148
        12.7.2020, 22:50:00.015 [error]: javascript.0 (27555) at writeHTML (script.js.Allgemein.Unifi_Tabelle_1:229:18)
        12.7.2020, 22:50:00.015 [error]: javascript.0 (27555) at Object.<anonymous> (script.js.Allgemein.Unifi_Tabelle_1:339:2)
        12.7.2020, 22:50:11.404 [info ]: javascript.0 (27555) Stop script script.js.Allgemein.Unifi_Tabelle_1
        12.7.2020, 22:50:32.535 [info ]: javascript.0 (27555) Start javascript script.js.Allgemein.Unifi_Tabelle_1
        12.7.2020, 22:50:32.544 [warn ]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:191:20
        12.7.2020, 22:50:32.545 [warn ]: javascript.0 (27555) at writeHTML (script.js.Allgemein.Unifi_Tabelle_1:175:36)
        12.7.2020, 22:50:32.545 [warn ]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:342:1
        12.7.2020, 22:50:32.550 [error]: javascript.0 (27555) script.js.Allgemein.Unifi_Tabelle_1: script.js.Allgemein.Unifi_Tabelle_1:230
        12.7.2020, 22:50:32.551 [error]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:230:148
        12.7.2020, 22:50:32.551 [error]: javascript.0 (27555) at writeHTML (script.js.Allgemein.Unifi_Tabelle_1:229:18)
        12.7.2020, 22:50:32.551 [error]: javascript.0 (27555) at script.js.Allgemein.Unifi_Tabelle_1:342:1
          liv-in-sky @MyMeyer last edited by
          @MyMeyer
          hallo - es scheint du hast dieses problem : https://forum.iobroker.net/post/459129
          du hast auch die doppelte anzahl an zeilen - bitte wie dort beschrieben den chrome browser mal probieren, um das script zu kopieren
          ansonsten wichtig:
          • datenpunkte müssen von hand angelegt sein und im script eingetragen werden
          • alle benötigten datenpunkte müssen im adaptersetiing angegeben sein (erster post)
          • wenn dann noch probleme, kann es nicht schaden, das script stoppen, die unifi instanz zu stoppen - alle datenpunkte unter unifi.0 (also den ganzen ordner) zu löschen , instanz wieder starten - etwas warten - script wieder starten (nur wichtig, falls objecte da aber states sind leer)
            bauerpower last edited by
            kann ich um etwas Geburtshilfe bitten?
            Ich habe die Datenpunkte angelegt .... und hoffentlich alle Anpassungen gemacht...
            Leider bekomme ich folgenden Fehler:
            Und im Log is Chaos 🙂
            //@liv-in-sky 2020  8.7.2020 17 19:30
            //HIER WIRD PFAD UND FILENAME DEFINIERT
            const path = "/unifi.html";                   //FIlenamen definieren
            const home = 'vis.0'                               //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
            let braucheEinFile = false;                          // bei true wird ein file geschrieben
            let braucheEinVISWidget = true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
            let dpVIS = "0_userdata.0.Tabellen.Unifi-Clients"         //WICHTIG wenn "braucheEinVISWidget" auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget type Zeichenkette
            let dpSort = "0_userdata.0.Tabellen.Unifi-Clients-Sort"   //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget  type logic
            let dpSortIPMAC = "0_userdata.0.Tabellen.Unifi-MAC-IP"   //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget  type logic
            let dpSortDevice = "0_userdata.0.Tabellen.Unifi-Clients-Device"   //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget  type logic
            let dpDelete = "0_userdata.0.Tabellen.Unifi-Clients-DeleteDP"     //WICHTIG wenn "braucheEinVISWidget" auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget type Zeichenkette
            let mySchedule = " */30 * * * * * ";                      //jede minute
            let kuerzungNamen = 15                      // länge der namen kürzen
            let offlineColor = true;                     // wenn true dann wird farbe von apName nicht beachtet
            let offlineFarbe = "#66b3ff";
            let abwesendZeit = 187200000                  // in millisekunden für länger abwesende clients
            let htmlColorDeviceLangAbwesend = "white";     // frbe überschrift für länger abwesende
            const apName = {
                "74:83:c2:b3:85:b4": { aname: "APAC-WZ", afarbe: "#737373" },      // standard #BDBDBD   afarbe ist die farbe
                "74:83:c2:b3:86:9e": { aname: "APAC-KG", afarbe: "#b3b300" },    // standard #BDBDBD
                "78:8a:20:8c:dc:75": { aname: "APAC-EL", afarbe: "#D8D8D8" }
            }    // standard #BDBDBD
            let sortiereClient = false; // false ist nach IP; true nach Name
            let symbolSort = "↔️"                //"👁️‍🗨️";
            let symbolSortMAC = "👁️‍🗨️";
            let symbolSortDevice = "👁️‍🗨️";
            let symbolTrue = "⚫";                       //  oder : ="❌"  ⚪  ⚫ ⭕  🔴 🔵 ⏱ 💀 👍 👎 📑 💲 👀 🔹
            let symbolFalse = "🔹";
            let symbolDelete = "☢️";
            //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 4
            var htmlFeld1 = 'Name'; var Feld1lAlign = "left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
            var htmlFeld2 = 'IP/MAC'; var Feld2lAlign = "left";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
            var htmlFeld3 = 'Device'; var Feld3lAlign = "left";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
            var htmlFeld4 = 'Online'; var Feld4lAlign = "center";                    // überschrift Tabellen Spalte4 und  Ausrichtung left,right or center
            //ÜBERSCHRIFT ÜBER TABELLE
            let htmlUberschrift = true;                           // mit Überschrift über der tabelle
            let htmlSignature = false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
            const htmlFeldUeber = 'Unifi Clients';              // Überschrift und Signature
            const htmlFarbUber = "white";                         // Farbe der Überschrift
            const htmlSchriftWeite = "normal";                       // bold, normal - Fettschrift für Überschrift
            const htmlÜberFontGroesse = "18px";                       // schriftgröße überschrift
            //MEHRERE TABELLEN NEBENEINANDER
            let mehrfachTabelle = 2;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
            const trennungsLinie = "2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
            const farbetrennungsLinie = "white";
            const htmlFarbZweiteTabelle = "white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
            const htmlFarbTableColorUber = "#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
            //ÜBERSCHRIFT SPALTEN
            const UeberSchriftHöhe = "35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
            const LinieUnterUeberschrift = "3";                   // Linie nur unter Spaltenüberschrift -
            const farbeLinieUnterUeberschrift = "white";
            const groesseUeberschrift = 16;
            const UeberschriftStyle = "normal"                     // möglich "bold"
            //GANZE TABELLE
            let abstandZelle = "1";
            let farbeUngeradeZeilen = "#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
            let farbeGeradeZeilen = "#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
            let weite = "auto";                                     //Weite der Tabelle
            let zentriert = true;                                   //ganze tabelle zentriert
            const backgroundAll = "#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
            const htmlSchriftart = "Helvetica";
            const htmlSchriftgroesse = "14px";
            //FELDER UND RAHMEN
            let UeberschriftSpalten = true;                // ein- oder ausblenden der spatlen-überschriften
            const htmlFarbFelderschrift = "#BDBDBD";                  // SchriftFarbe der Felder
            const htmlFarbFelderschrift2 = "#BDBDBD";                 // SchriftFarbe der Felder für jede 2te Tabelle   D8D8D8
            const htmlFarbTableColorGradient1 = "#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
            const htmlFarbTableColorGradient2 = "#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
            const htmlFarbTableBorderColor = "grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
            let htmlRahmenLinien = "none";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
            const htmlSpalte1Weite = "auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
            // HIER NICHTS  ÄNDERN
            let borderHelpBottum;
            let borderHelpRight;
            let htmlcenterHelp;
            let htmlcenterHelp2;
            if (htmlRahmenLinien == "rows") { borderHelpBottum = 1; borderHelpRight = 0; }
            if (htmlRahmenLinien == "cols") { borderHelpBottum = 0; borderHelpRight = 1; }
            if (htmlRahmenLinien == "none") { borderHelpBottum = 0; borderHelpRight = 0; }
            if (htmlRahmenLinien == "all") { borderHelpBottum = 1; borderHelpRight = 1; }
            zentriert ? htmlcenterHelp = "auto" : htmlcenterHelp = "left";
            zentriert ? htmlcenterHelp2 = "center" : htmlcenterHelp2 = "left";
            const htmlZentriert = '<center>'
            const htmlStart = "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">" +
                "<style> * {  margin: 0;} body {background-color: " + backgroundAll + "; margin: 0 auto;  }" +
                " p {padding-top: 10px; padding-bottom: 10px; text-align: " + htmlcenterHelp2 + "}" +
                // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                " td { padding:" + abstandZelle + "px; border:0px solid " + htmlFarbTableBorderColor + ";  border-right:" + borderHelpRight + "px solid " + htmlFarbTableBorderColor + ";border-bottom:" + borderHelpBottum + "px solid " + htmlFarbTableBorderColor + ";}" +
                " table { width: " + weite + ";  margin: 0 " + htmlcenterHelp + "; border:1px solid " + htmlFarbTableBorderColor + "; border-spacing=\"" + abstandZelle + "0px\" ; }" +   // margin macht center
                "td:nth-child(1) {width: " + htmlSpalte1Weite + "}" + "td:nth-child(2) {width:" + htmlSpalte1Weite + "}" +
                " </style></head><body> <div>";
            //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
            const htmlTabStyle = "<table bordercolor=\"" + htmlFarbTableBorderColor + "\" border=\"2px\" cellspacing=\"" + abstandZelle + "\" cellpadding=\"" + abstandZelle + "\" width=\"" + weite + "\" rules=\"" + htmlRahmenLinien + "\" style=\"color:" + htmlFarbFelderschrift + ";  font-size:" + htmlSchriftgroesse +
                "; font-family:" + htmlSchriftart + ";background-image: linear-gradient(42deg," + htmlFarbTableColorGradient2 + "," + htmlFarbTableColorGradient1 + ");\">";
            const htmlTabUeber1 = "<tr height=\"" + UeberSchriftHöhe + "\" style=\"color:" + htmlFarbTableColorUber + "; font-size: " + groesseUeberschrift + "px; font-weight: " + UeberschriftStyle + " ;  border-bottom: " + LinieUnterUeberschrift + "px solid " + farbeLinieUnterUeberschrift + " \">";
            const htmlTabUeber3 = "</tr>";
            //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 4
            var buttonScript = '<script> function setOnSort1() {	var Self = this; var objID =\'' + dpSort + '\';	Self.servConn.getStates(\'' + dpSort + '\', (error, states) => {  console.log(states); self.servConn.setState(\'' + dpSort + '\', !states[\'' + dpSort + '\'].val);}  )}' +
                'function setOnSort() {	var Self = this; var objID =\'' + dpSortIPMAC + '\';	Self.servConn.getStates(\'' + dpSortIPMAC + '\', (error, states) => {  console.log(states); self.servConn.setState(\'' + dpSortIPMAC + '\', !states[\'' + dpSortIPMAC + '\'].val);}  )}' +
                'function setOnSort2() {	var Self = this; var objID =\'' + dpSortDevice + '\';	Self.servConn.getStates(\'' + dpSortDevice + '\', (error, states) => {  console.log(states); self.servConn.setState(\'' + dpSortDevice + '\', !states[\'' + dpSortDevice + '\'].val);}  )}' +
                'function setOnDelete( myvalue ) {	 var Self = this; var objID = myvalue; console.log(myvalue); self.servConn.setState(\'' + dpDelete + '\',myvalue)   }' +
                '</script>'
            var htmlTabUeber2 = "<td width=" + htmlSpalte1Weite + " align=" + Feld1lAlign + ">&ensp;" + htmlFeld1 +
                "&ensp;<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnSort1\()\">" + symbolSort + "</button></td><td width=" + htmlSpalte1Weite + " align=" + Feld2lAlign + ">&ensp;" + htmlFeld2 +
                "&ensp;<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnSort\()\">" + symbolSortMAC + "</button>" + "&ensp;</td><td  align=" + Feld3lAlign + ">&ensp;" + htmlFeld3 +
                "&ensp;<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnSort2\()\">" + symbolSortDevice + "</button>" + "&ensp;</td><td align=" + Feld4lAlign + ">&ensp;" + htmlFeld4 + "&ensp;</td>";
            var htmlTabUeber2_1 = "<td width=" + htmlSpalte1Weite + " align==" + Feld1lAlign + " style=\"color:" + htmlFarbZweiteTabelle + "\">&ensp;" + htmlFeld1 + "&ensp;</td><td width=" + htmlSpalte1Weite + "  align=" + Feld2lAlign + " style=\"color:" + htmlFarbZweiteTabelle + "\">&ensp;" + htmlFeld2 +
                "&ensp;</td><td  align==" + Feld3lAlign + " style=\"color:" + htmlFarbZweiteTabelle + "\">&ensp;" + htmlFeld3 + "&ensp;</td><td  align=" + Feld4lAlign + " style=\"color:" + htmlFarbZweiteTabelle + "\">&ensp;" + htmlFeld4 +
                "&ensp;</td>";
            //'function setOnDelete( myvalue ) {	var Self = this; var objID = myvalue;	Self.servConn.getStates(objID, (error, states) => {  console.log(states);  Self.servConn.setState(objID, !states[objID].val); }); }'+
            var htmlOut = "";
            var mix;
            var counter;
            var val1; var val2; var val0; var val3;
            var htmlTabUeber = "";
            var myReactionArr = []
            function writeHTML() {
                let myObj = [];
                let myObjOlder = [];
                myReactionArr = []
                let varhelp0; let varhelp1; let varhelp2; let varhelp3
                htmlOut = "";
                counter = -1;
                htmlTabUeber = "";
                switch (mehrfachTabelle) {
                    case 1: htmlTabUeber = htmlTabUeber1 + htmlTabUeber2 + htmlTabUeber3; break;
                    case 2: htmlTabUeber = htmlTabUeber1 + htmlTabUeber2 + htmlTabUeber2_1 + htmlTabUeber3; break;
                    case 3: htmlTabUeber = htmlTabUeber1 + htmlTabUeber2 + htmlTabUeber2 + htmlTabUeber2 + htmlTabUeber3; break;
                    case 4: htmlTabUeber = htmlTabUeber1 + htmlTabUeber2 + htmlTabUeber2_1 + htmlTabUeber2 + htmlTabUeber2_1 + htmlTabUeber3; break;
                if (!UeberschriftSpalten) { htmlTabUeber = "" }
                //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2,val3 !!!---------------------------------------------------------------------
                sortiereClient = getState(dpSort).val
                let zeigeMAC = getState(dpSortIPMAC).val
                let sortDevice = getState(dpSortDevice).val
                let jetzt = new Date().getTime();
                let help = [];
                //log("jetzt: "+jetzt.toString()+"  test : " + Date.parse('2020-07-04 17:27:42')) //ew Date('July 20, 69 00:20:18 GMT+00:00')
                $('unifi.0.default.clients.*.mac').each(function (id, i) {           // hier eigene schleife definieren
                    var ida = id.split('.');
                    if (existsState(id.replace("mac", "ap_mac")) || existsState(id.replace("mac", "sw_mac"))) {
                        //counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                        //log(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]+"."+ida[4])
                        varhelp0 = getObject(ida[0] + "." + ida[1] + "." + ida[2] + "." + ida[3] + "." + ida[4]).common.name;
                        varhelp1 = getState(id.replace("mac", "ip")).val;
                        zeigeMAC ? varhelp1 = getState(id.replace("mac", "ip")).val : varhelp1 = getState(id).val;
                        if (existsState(id.replace("mac", "sw_mac"))) { varhelp2 = getState(id.replace("mac", "sw_mac")).val }
                        if (existsState(id.replace("mac", "ap_mac"))) { varhelp2 = getState(id.replace("mac", "ap_mac")).val }
                        let farbehelp;
                        for (let device_name in apName) {                            //Abfrage welcher AP
                            //   dlog(versuch[i].ap_mac +" - " + device_name +" - " + apName[device_name].aname);
                            if (varhelp2 == device_name) { varhelp2 = apName[device_name].aname; farbehelp = apName[device_name].afarbe }
                        varhelp3 = getState(id.replace("mac", "is_online")).val;
                        myReactionArr.push(id.replace("mac", "is_online"));
                        //  log(varhelp3)
                        if (existsState(id.replace("mac", "last_seen_by_uap"))) {
                            if (jetzt - Date.parse(getState(id.replace("mac", "last_seen_by_uap")).val) > abwesendZeit) {     //
                                // log(" "+ getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]+"."+ida[4]).common.name);
                                let varhelp2_2 = jetzt - Date.parse(getState(id.replace("mac", "last_seen_by_uap")).val)
                                varhelp2 = Math.floor(((varhelp2_2 / 1000) / 60 / 60 / 24)) + "d " + Math.floor(((varhelp2_2 / 1000) / 60 / 60) % 24) + "h " + Math.floor(((varhelp2_2 / 1000) / 60) % 60) + "m ";
                                let valButton = ida[0] + "." + ida[1] + "." + ida[2] + "." + ida[3] + "." + ida[4] //'unifi.0.default.clients.bc:54:51:eb:74:44'
                                varhelp3 = "<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDelete\(\'" + valButton + "\')\">" + symbolDelete + "</button>";
                                help = [varhelp0, varhelp1, varhelp2, varhelp3, farbehelp];
                                myObjOlder.push(help)
                            } else {
                                myObj.push(help)
                            //  if (i==4) {log(getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]+"."+ida[4]).common.name+" "+(jetzt-(getState(id.replace("mac","is_online")).lc)).toString()+"  ts : "+getState(id.replace("mac","is_online")).lc)}
                        }  //exists uap
                        else {
                            myObj.push(help)
                    }   //  abfrage ap_mac
                }); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                if (sortiereClient) {
                    myObj.sort(function (alpha, beta) {
                        if (alpha[0].toUpperCase().trim() > beta[0].toUpperCase().trim())
                            return 1;
                        if (beta[0].toUpperCase().trim() > alpha[0].toUpperCase().trim())
                            return -1;
                        return 0;
                } else {
                        if ((parseFloat(beta[1].replace(/.+\.(.+)$/, "$1"))) + (parseFloat(beta[1].replace(/.+\.(.+)\..+$/, "$1")) * 1000) > (parseFloat(alpha[1].replace(/.+\.(.+)$/, "$1"))) + (parseFloat(alpha[1].replace(/.+\.(.+)\..+$/, "$1")) * 1000))
                            return -1;
                        if ((parseFloat(alpha[1].replace(/.+\.(.+)$/, "$1"))) + (parseFloat(alpha[1].replace(/.+\.(.+)\..+$/, "$1")) * 1000) > (parseFloat(beta[1].replace(/.+\.(.+)$/, "$1"))) + (parseFloat(beta[1].replace(/.+\.(.+)\..+$/, "$1")) * 1000))
                            return 1;
                        return 0;
                if (sortDevice) {
                        if (alpha[2].toUpperCase().trim() > beta[2].toUpperCase().trim())
                            return 1;
                        if (beta[2].toUpperCase().trim() > alpha[2].toUpperCase().trim())
                            return -1;
                        return 0;
                    setStateDelayed(dpSortDevice, false, 2500);
                for (var i = 0; i < myObj.length; i++) {
                    counter++
                    if (!offlineColor) {
                        val0 = myObj[i][0]; if (val0.length >= (kuerzungNamen) + 2) val0 = val0.substring(0, kuerzungNamen) + " ..."; val0 = "<font color=\"" + myObj[i][4] + "\">" + val0
                        val1 = myObj[i][1]; val1 = "<font color=\"" + myObj[i][4] + "\">" + val1
                        val2 = myObj[i][2]; val2 = "<font color=\"" + myObj[i][4] + "\">" + val2
                        val3 = myObj[i][3]; if (!val3) { val3 = symbolFalse } else { val3 = symbolTrue }   //val3="<font color=\""+myObj[i][4]+"\">"+val3
                    } else {
                        // log(val3)
                        val3 = myObj[i][3]
                        val0 = myObj[i][0]; if (val0.length >= (kuerzungNamen) + 2) val0 = val0.substring(0, kuerzungNamen) + " ..."; if (val3 == false) val0 = "<font color=\"" + offlineFarbe + "\">" + val0
                        val1 = myObj[i][1]; if (val3 == false) val1 = "<font color=\"" + offlineFarbe + "\">" + val1
                        val2 = myObj[i][2]; if (val3 == false) val2 = "<font color=\"" + offlineFarbe + "\">" + val2
                        // val3=myObj[i][3] ;
                    tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                } // log(counter.toString())
                tabelleMachSchoen()
                counter = -1;
                for (var i = 0; i < mehrfachTabelle; i++) {
                    if (i == 0) {
                        val0 = "<font color=\"" + htmlColorDeviceLangAbwesend + "\"><b><i>Abwesend</i></b>";
                        val1 = "<font color=\"" + htmlColorDeviceLangAbwesend + "\"><i>über: " + Math.floor(((abwesendZeit / 1000) / 60 / 60 / 24)) + "d " + Math.floor(((abwesendZeit / 1000) / 60 / 60) % 24) + "h " + Math.floor(((abwesendZeit / 1000) / 60) % 60) + "m " + "</i></b>";
                        //  val1=Math.floor( ((abwesendZeit/1000)/60/60/24) )+"d "+ Math.floor(((abwesendZeit/1000)/60/60) % 24) +"h "+ Math.floor( ((abwesendZeit/1000)/60) % 60 )+" m"
                        //  val2="<font color=\""+htmlColorDeviceLangAbwesend+"\"><i>um "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"</i>";
                    } else { val0 = ""; val1 = ""; }
                    val2 = ""; val3 = ""; counter++; tabelleBind();
                // val0="Lange Abwesend";
                // val1="";val2="";val3="";
                myObjOlder.sort(function (alpha, beta) {
                        return 1;
                        return -1;
                    return 0;
                counter = -1;
                for (var i = 0; i < myObjOlder.length; i++) {
                    counter++
                        val0 = myObjOlder[i][0]; if (val0.length >= (kuerzungNamen) + 2) val0 = val0.substring(0, kuerzungNamen) + " ..."; val0 = "<font color=\"" + myObjOlder[i][4] + "\">" + val0
                        val1 = myObjOlder[i][1]; val1 = "<font color=\"" + myObjOlder[i][4] + "\">" + val1
                        val2 = myObjOlder[i][2]; val2 = "<font color=\"" + myObjOlder[i][4] + "\">" + val2
                        val3 = myObjOlder[i][3];  //if (!val3) {val3=symbolFalse} else{val3=symbolTrue}   //val3="<font color=\""+myObj[i][4]+"\">"+val3
                    } else {
                        // log(val3)
                        val0 = myObjOlder[i][0]; if (val0.length >= (kuerzungNamen) + 2) val0 = val0.substring(0, kuerzungNamen) + " ..."; if (val3 == false) val0 = "<font color=\"" + offlineFarbe + "\">" + val0
                        val1 = myObjOlder[i][1]; if (val3 == false) val1 = "<font color=\"" + offlineFarbe + "\">" + val1
                        val2 = myObjOlder[i][2]; if (val3 == false) val2 = "<font color=\"" + offlineFarbe + "\">" + val2
                        // if (!val3) {val3=symbolFalse} else{val3=symbolTrue}
                counter++
                val0 = "<font color=\"" + htmlColorDeviceLangAbwesend + "\"><b><i>Last Update</i></b>";
                val1 = "<font color=\"" + htmlColorDeviceLangAbwesend + "\"><i>um " + formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss") + "</i>";
                tabelleBind()
                //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
            } // function ende
            //MAIN:
            schedule(mySchedule, function () {
                writeHTML();
                if (braucheEinFile) { writeFile(home, path, htmlOut, function (error) { /* log('file written');*/ }); }
            writeHTML();
            function tabelleBind() {
                //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 4 Felder definiert, braucht man hier 4 Werte
                    case 1: if (counter % 2 == 0) { htmlOut = htmlOut + "<tr bgcolor=\"" + farbeGeradeZeilen + "\"><td align=" + Feld1lAlign + ">&ensp;" + val0 + "&ensp;</td><td align=" + Feld2lAlign + ">&ensp;" + val1 + "&ensp;</td><td align=" + Feld3lAlign + ">&ensp;" + val2 + "&ensp;</td><td align=" + Feld4lAlign + ">&ensp;" + val3 + "&ensp;</td></tr>"; break; } else { htmlOut = htmlOut + "<tr bgcolor=\"" + farbeUngeradeZeilen + "\"><td align=" + Feld1lAlign + ">&ensp;" + val0 + "&ensp;</td><td align=" + Feld2lAlign + ">&ensp;" + val1 + "&ensp;</td><td align=" + Feld3lAlign + ">&ensp;" + val2 + "&ensp;</td><td align=" + Feld4lAlign + ">&ensp;" + val3 + "&ensp;</td></tr>"; break; }
                    case 2: if (counter % 4 == 0) {
                            htmlOut = htmlOut + "<tr bgcolor=\"" + farbeGeradeZeilen + "\"><td align=" + Feld1lAlign + ">&ensp;" + val0 + "&ensp;</td><td align=" + Feld2lAlign + ">&ensp;" + val1 + "&ensp;</td><td align=" + Feld3lAlign + ">&ensp;" + val2 + "&ensp;</td><td style=\" border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie +
                            ";\"align=" + Feld4lAlign + ">&ensp;" + val3 + "&ensp;</td>";
                        else { htmlOut = htmlOut + "<td align=" + Feld1lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val0 + "&ensp;</td><td  align=" + Feld2lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val1 + "&ensp;</td><td  align=" + Feld3lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val2 + "&ensp;</td><td  align=" + Feld4lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val3 + "&ensp;</td></tr>"; } break;
                    } else {
                            htmlOut = htmlOut + "<tr bgcolor=\"" + farbeUngeradeZeilen + "\"><td align=" + Feld1lAlign + ">&ensp;" + val0 + "&ensp;</td><td align=" + Feld2lAlign + ">&ensp;" + val1 + "&ensp;</td><td align=" + Feld3lAlign + ">&ensp;" + val2 + "&ensp;</td><td style=\" border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie +
                            ";\" align=" + Feld4lAlign + ">&ensp;" + val3 + "&ensp;</td>";
                    case 3: if (counter % 2 == 0) {
                        if (counter % 3 == 0) {
                        else {
                            if (counter % 3 == 1) {
                                htmlOut = htmlOut + "<td align=" + Feld1lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val0 + "&ensp;</td><td  align=" + Feld2lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val1 + "&ensp;</td><td  align=" + Feld3lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val2 + "&ensp;</td><td  align=" + Feld4lAlign + " style=\"border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie +
                                ";color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val3 + "&ensp;</td>";
                            else { htmlOut = htmlOut + "<td align=" + Feld1lAlign + ">&ensp;" + val0 + "&ensp;</td><td align=" + Feld2lAlign + ">&ensp;&ensp;" + val1 + "&ensp;</td><td align=" + Feld3lAlign + ">&ensp;" + val2 + "&ensp;</td><td align=" + Feld4lAlign + ">&ensp;" + val3 + "&ensp;</td></tr>"; }
                        } break;
                    } else {
                        else {
                        } break;
                    case 4: if (counter % 8 == 0) {
                        if (counter % 4 == 0) { htmlOut = htmlOut + "<tr bgcolor=\"" + farbeGeradeZeilen + "\"><td align=" + Feld1lAlign + ">&ensp;" + val0 + "&ensp;</td><td align=" + Feld2lAlign + ">&ensp;" + val1 + "&ensp;</td><td align=" + Feld3lAlign + ">&ensp;" + val2 + "&ensp;</td><td style=\" border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie + ";\" align=" + Feld4lAlign + ">&ensp;" + val3 + "&ensp;</td>"; }
                        else {
                            if (counter % 4 == 1) { htmlOut = htmlOut + "<td align=" + Feld1lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val0 + "&ensp;</td><td  align=" + Feld2lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val1 + "&ensp;</td><td  align=" + Feld3lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val2 + "&ensp;</td><td  align=" + Feld4lAlign + " style=\" border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie + "; color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val3 + "&ensp;</td>"; }
                            else {
                                if (counter % 4 == 3) { htmlOut = htmlOut + "<td align=" + Feld1lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\"&ensp;>" + val0 + "&ensp;</td><td  align=" + Feld2lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val1 + "&ensp;</td><td align=" + Feld3lAlign + " style=\"border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie + ";color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val2 + "&ensp;</td><td  align=" + Feld4lAlign + " style=\"border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie + "color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val3 + "&ensp;</td></tr>"; }
                                else { htmlOut = htmlOut + "<td align=" + Feld1lAlign + ">&ensp;" + val0 + "&ensp;</td><td align=" + Feld2lAlign + ">&ensp;" + val1 + "&ensp;</td><td align=" + Feld3lAlign + ">&ensp;" + val2 + "&ensp;</td><td  style=\" border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie + ";\"align=" + Feld4lAlign + ">&ensp;" + val3 + "&ensp;</td>"; }
                        } break;
                    } else {
                        if (counter % 4 == 0) { htmlOut = htmlOut + "<tr bgcolor=\"" + farbeUngeradeZeilen + "\"><td align=" + Feld1lAlign + ">&ensp;" + val0 + "&ensp;</td><td align=" + Feld2lAlign + ">&ensp;" + val1 + "&ensp;</td><td align=" + Feld3lAlign + ">&ensp;" + val2 + "&ensp;</td><td style=\" border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie + ";\" align=" + Feld4lAlign + ">&ensp;" + val3 + "&ensp;</td>"; }
                        else {
                            if (counter % 4 == 1) { htmlOut = htmlOut + "<td align=" + Feld1lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val0 + "&ensp;</td><td  align=" + Feld2lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val1 + "&ensp;</td><td  align=" + Feld3lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val2 + "&ensp;</td><td  align=" + Feld4lAlign + " style=\"border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie + ";color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val3 + "&ensp;</td>"; }
                            else {
                                if (counter % 4 == 3) { htmlOut = htmlOut + "<td align=" + Feld1lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\"&ensp;>" + val0 + "&ensp;</td><td  align=" + Feld2lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val1 + "&ensp;</td><td align=" + Feld3lAlign + " style=\"color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val2 + "&ensp;</td><td  align=" + Feld4lAlign + "  color:" + htmlFarbFelderschrift2 + "\">&ensp;" + val3 + "&ensp;</td></tr>"; }
                        } break;
                } //switch ende
            function tabelleMachSchoen() {
                // tabelle fertigstellen
                    case 1: break;
                    case 2:
                        if (counter % 2 == 0) htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                        break;
                    case 3: if (counter % 3 == 2) htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                        if (counter % 3 == 1) htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                        if (counter % 3 == 0) htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie + "\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                        break;
                    case 4: if (counter % 4 == 3) { log(htmlOut); htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>"); log(htmlOut) }
                        if (counter % 4 == 2) htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                        if (counter % 4 == 1) htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie + "\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                        if (counter % 4 == 0) htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie + "\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: " + trennungsLinie + "px solid " + farbetrennungsLinie + "\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                        break;
            function tabelleFinish() {
                    case 1: break;
                    case 2:
                        break;
                        break;
                        break;
                var htmlUeber = "<p style=\"color:" + htmlFarbUber + "; font-family:" + htmlSchriftart + "; font-size: " + htmlÜberFontGroesse + "; font-weight:" + htmlSchriftWeite + "\">" + htmlFeldUeber + "&ensp;&ensp;Last Update: " + formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss"); +"</p>";
                var htmlUnter = "<div  style=\"color:" + htmlFarbUber + "; font-family:" + htmlSchriftart + "; font-size: 70%; text-align: right;\" >" + htmlFeldUeber + "&ensp;&ensp;Last Update: " + formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss"); +"</div>";
                if (!htmlSignature) htmlUnter = "";
                //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                var htmlOutVIS = "";
                //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                if (htmlUberschrift) {
                    zentriert ? htmlOutVIS = htmlZentriert + htmlUeber + htmlTabStyle + htmlTabUeber + htmlOut + "</table>" + htmlUnter + buttonScript : htmlOutVIS = htmlUeber + htmlTabStyle + htmlTabUeber + htmlOut + "</table>" + htmlUnter + buttonScript;
                } else {
                    zentriert ? htmlOutVIS = htmlZentriert + htmlTabStyle + htmlTabUeber + htmlOut + "</table>" + htmlUnter + buttonScript : htmlOutVIS = htmlTabStyle + htmlTabUeber + htmlOut + "</table>" + htmlUnter + buttonScript;
                // log("bin raus aus tabelleBind");
                if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS);
                var htmlUnter = "<div  style=\"color:" + htmlFarbUber + "; font-family:" + htmlSchriftart + "; font-size: 80%;  text-align: center; \" >" + htmlFeldUeber + "&ensp;&ensp;Last Update: " + formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss"); +"</div>"
                var htmlEnd = "</table>" + htmlUnter + "</div></body>";
                //mit oder ohne überschrift - zentriert oder links
                htmlUberschrift ? htmlOut = htmlStart + htmlUeber + htmlTabStyle + htmlTabUeber + htmlOut + htmlEnd : htmlOut = htmlStart + htmlTabStyle + htmlTabUeber + htmlOut + htmlEnd;
                //log(htmlOut);
            on({ id: dpSort, change: "any" }, function (obj) {
                var timeout2 = setTimeout(function () {
                    writeHTML();
                }, 1500);
            on({ id: dpSortIPMAC, change: "any" }, function (obj) {
                    writeHTML();
                }, 1500);
            on({ id: dpSortDevice, val: true }, function (obj) {
                    writeHTML();
                }, 1500);
            on({ id: myReactionArr, change: "any" }, function (obj) {
                //log("bin da","error")
                writeHTML();
            //  LÖSCHE alte Datenpunkte
            on({ id: dpDelete, change: "any" }, function (obj) {
                deleteMydp(getState(dpDelete).val)
                    writeHTML();
                }, 3000);
            function deleteMydp(myID) {
                var obj = getObject("system.adapter.unifi.0");
                obj.common.enabled = false;  // Adapter ausschalten
                setObject("system.adapter.unifi.0", obj);
                deleteObject(myID, true);
                obj.common.enabled = true;  // Adapter ausschalten
            Freue mich sehr über Hilfe 🙂
            Liebe Grüsse
            Jörg
              liv-in-sky @bauerpower last edited by
              @bauerpower
              benenne mal die constante path in path2 um und auch unten im script ung. zeile 338 - auch dort path2 ändern
                bauerpower @liv-in-sky last edited by
                @liv-in-sky
                Herzlich Dank für Deine schnelle Antwort. Bedingt durch "Gänsebraten" eine etwas verspätete Rückmeldung.
                Mein Script lief nicht in Global... da ich schon ein ähnliches "HTML Script" in Global laufen hatte (Tanken) haben
                sich die Variablen wohl in die Haare bekommen....
                Jetzt läuft alles 🙂
                Lieben Dank
                Wünsche Dir schöne und vor allem gesunde Weihnachten 🙂
                Jörg
                  @bauerpower
                  das ist mir im moment auch nicht klar - ich habe einige solche scripte laufen und hatte auch mal so einen fehler, obwohl ich keine globalen files nutze - irgendwann bei den javascript adapter updates kam dieser fehler auf
                  du solltest eigentlich keine solchen scripte unter global am laufen haben - braucht man ja nur, wenn eine bestimmte function in allen anderen scripten verfügbar sein soll. jedes globale script wird an jedes andere script angehängt, damit die function dort verfügbar ist. das bohrt die scripte extrem auf !
                  auch dir schöne x-ams
                    @liv-in-sky
                    mir ist aufgefallen das der Adapter gelegentlich neu startet. Leider bin ich noch nicht dahinter gekommen
                    was der Grund ist.
                    Hast Du eine Ahnung wie man die "system.adapter.x" überwachen kann ... ?
                    Es gibt ja einen Datenpunkt "alive" nur wenn der Javascript Adapter weg ist bringt mir das auch nichts mehr 🙂
                    Danke für die info bezüglich "Globale Scripte" ... ich werde meine Scripte mal aus Global nehmen.... und schauen was passiert...
                    Liebe Grüsse
                    Jörg
                      @bauerpower welcher adapter startet immer neu ?
                        @liv-in-sky
                        Sorry, der Javascript (Javascript Script Engine) Adapter.
                        Liebe Grüsse
                          liv-in-sky @bauerpower last edited by liv-in-sky
                          @bauerpower schwierige fehlersuche
                          ist wohl ein script
                          ich würde eine zweite javascript instanz installieren und die komplexeren scripte dort hin gekopieren - evtl findest du so das script, welches ärger macht
                          memory ist genug in der hardware?
                          ansonsten muss eigentlich das logfile von iobroker gecheckt werden - manchmal findet sich da was
                          • I
                            Idefix01 @liv-in-sky last edited by Idefix01
                            Guten Abend,
                            lässt sich die Clients Tabelle auch noch mit der Signalstärke erweitern?
                            Die farbliche Darstellung funktioniert bei mir nicht, kann mir jemand sagen warum?
                             const apName = {  "f4:92:bf:69:c9:67": { aname: "AP AC-Wohnzimmer" , afarbe: "#99FF33"},      // standard #BDBDBD   afarbe ist die farbe
                                "f4:92:bf:69:d0:e0": { aname: "AP AC-Stübchen" , afarbe: "#80BFFF"},    // standard #BDBDBD
                                "f4:92:bf:69:ce:13": { aname: "AP AC-Keller" , afarbe: "#D8D8D8"},
                                "f4:92:bf:99:72:2a": { aname: "24 Port Switch" , afarbe: "#BDBDBD"},
                                "74:ac:b9:d4:10:ae": { aname: "8 Port Switch" , afarbe: "#b3b430"}
                              liv-in-sky @Idefix01 last edited by
                              @idefix01
                              @idefix01 sagte in HTMLTabelle UnifiClients-newAdapter:
                              let offlineColor=false;
                              probiere mal dieses script und setting: let satisfactionInsteadOnline=true;
                              es muss satisfaction als dp unter den clients geben !
                              https://github.com/liv-in-sky/unifi-clients-table-vis
                              • I
                                @liv-in-sky
                                danke hat geklappt
                                • I
                                  Idefix01 @Idefix01 last edited by
                                  @liv-in-sky
                                  habe glaube gerade Mist gemacht, wollte die Liste neu schreiben lassen und habe den deleteDP Punkt kurz auf true gesetzt.
                                  Nun habe ich alles nochmal neu gestartet aber bekomme nun von dem Script diese Fehler
                                  javascript.0	2021-04-19 18:15:41.264	error	(6687) at Script.runInContext (vm.js:143:18)
                                  javascript.0	2021-04-19 18:15:41.264	error	(6687) at script.js.Haussteuerung2.Flur.Unifi_Clients:547:3
                                  javascript.0	2021-04-19 18:15:41.264	error	(6687) at script.js.Haussteuerung2.Flur.Unifi_Clients:344:2
                                  javascript.0	2021-04-19 18:15:41.263	error	(6687) at writeHTML (script.js.Haussteuerung2.Flur.Unifi_Clients:176:36)
                                  javascript.0	2021-04-19 18:15:41.263	error	(6687) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:800:29)
                                  javascript.0	2021-04-19 18:15:41.263	error	(6687) at script.js.Haussteuerung2.Flur.Unifi_Clients:181:82
                                  javascript.0	2021-04-19 18:15:41.263	error	(6687) script.js.Haussteuerung2.Flur.Unifi_Clients: TypeError: Cannot read property 'common' of null
                                  javascript.0	2021-04-19 18:15:41.261	info	(6687) script.js.Haussteuerung2.Flur.Unifi_Clients: registered 0 subscriptions and 1 schedule
                                  javascript.0	2021-04-19 18:15:41.260	warn	(6687) Object "unifi.0.default.clients.70:1c:e7:b1:a6:b1" does not exist
                                  javascript.0	2021-04-19 18:15:41.249	info	(6687) Start javascript script.js.Haussteuerung2.Flur.Unifi_Clients
                                    liv-in-sky @Idefix01 last edited by liv-in-sky
                                    @idefix01
                                    stoppe unifi- und js-instanz und auch das script
                                    lösche alles bzw ganzen ordner von (falls vorhanden)
                                    dann js-instanz start
                                    dann unifi-instanz start
                                    etwas warten
                                    dann script start
                                      @idefix01
                                      arbeite eh gerade an neuer version des scriptes - dauert noch ein wenig
                                      • I
                                        @liv-in-sky
                                        puh danke, habe es wieder hin bekommen
                                          falls jmd die neue version testen möchte
                                          https://github.com/liv-in-sky/iobroker-unificlients-table-vis
                                          es wäre auch interessant, wenn jmd einen switch (LAN-geräte) hat - kann ich nicht testen und ich weiß nicht, ob die clients richtig angezeigt werden
                                          P U D 3 Replies Last reply Reply Quote 0
                                            ps1304 @liv-in-sky last edited by
                                            @liv-in-sky wollte testen - Log hab ich folgenden Fehler:
                                            16:20:37.610 error javascript.0 (754) script.js.Unifi-Sky: Error: The id is empty! Please provide a valid id.
                                            16:20:37.611 error javascript.0 (754) at Object.<anonymous> (script.js.Unifi-Sky:1161:5)
                                            Muß ich irgendwo die Unifi ID hinterlegen, oder was ist damit gemeint? Gruß Peter
                                            81.1k
                                            javascript
                                            9175
