    4. Bitte um Test js-controller 0.13.0
    • rantanplan
      rantanplan last edited by
      Hallo Bluefox
      Hier den, aus dem anderen Thread, gewünschte Protokollauszug.
      ! 2016-10-25 08:48:01.783 - [32minfo[39m: iobroker url "https://github.com/ioBroker/ioBroker.js … all/master" js-controller
      ! 2016-10-25 08:48:02.892 - [32minfo[39m: iobroker install https://github.com/ioBroker/ioBroker.js ... all/master
      ! 2016-10-25 08:48:03.111 - [32minfo[39m: iobroker npm install https://github.com/ioBroker/ioBroker.js ... all/master --production --prefix "C:/ioBroker" (System call)
      ! 2016-10-25 08:48:37.908 - [32minfo[39m: iobroker npm
      ! 2016-10-25 08:48:37.908 - [32minfo[39m: iobroker WARN
      ! 2016-10-25 08:48:37.908 - [32minfo[39m: iobroker peerDependencies
      ! 2016-10-25 08:48:37.923 - [32minfo[39m: iobroker The peer dependency request@^2.75.0 included from iobroker.js-controller will no
      ! 2016-10-25 08:48:37.923 - [32minfo[39m: iobroker npm
      ! 2016-10-25 08:48:37.923 - [32minfo[39m: iobroker WARN
      ! 2016-10-25 08:48:37.923 - [32minfo[39m: iobroker peerDependencies
      ! 2016-10-25 08:48:37.923 - [32minfo[39m: iobroker longer be automatically installed to fulfill the peerDependency
      ! 2016-10-25 08:48:37.939 - [32minfo[39m: iobroker npm
      ! 2016-10-25 08:48:37.939 - [32minfo[39m: iobroker WARN
      ! 2016-10-25 08:48:37.939 - [32minfo[39m: iobroker peerDependencies
      ! 2016-10-25 08:48:37.939 - [32minfo[39m: iobroker in npm 3+. Your application will need to depend on it explicitly.
      ! 2016-10-25 08:48:37.955 - [32minfo[39m: iobroker
      ! 2016-10-25 08:48:37.955 - [32minfo[39m: iobroker WARN
      ! 2016-10-25 08:48:37.955 - [32minfo[39m: iobroker peerDependencies
      ! 2016-10-25 08:48:37.955 - [32minfo[39m: iobroker The peer dependency socket.io@^1.5.0 included from iobroker.js-controller will no
      ! 2016-10-25 08:48:37.955 - [32minfo[39m: iobroker npm
      ! 2016-10-25 08:48:37.970 - [32minfo[39m: iobroker longer be automatically installed to fulfill the peerDependency
      ! 2016-10-25 08:48:37.970 - [32minfo[39m: iobroker npm
      ! 2016-10-25 08:48:37.970 - [32minfo[39m: iobroker WARN
      ! 2016-10-25 08:48:37.970 - [32minfo[39m: iobroker peerDependencies
      ! 2016-10-25 08:48:37.970 - [32minfo[39m: iobroker in npm 3+. Your application will need to depend on it explicitly.
      ! 2016-10-25 08:49:44.548 - [32minfo[39m: iobroker gyp
      ! 2016-10-25 08:49:44.564 - [32minfo[39m: iobroker
      ! 2016-10-25 08:49:44.564 - [32minfo[39m: iobroker ERR!
      ! 2016-10-25 08:49:44.564 - [32minfo[39m: iobroker configure error
      ! 2016-10-25 08:49:44.564 - [32minfo[39m: iobroker gyp
      ! 2016-10-25 08:49:44.580 - [32minfo[39m: iobroker ERR!
      ! 2016-10-25 08:49:44.580 - [32minfo[39m: iobroker stack
      ! 2016-10-25 08:49:44.580 - [32minfo[39m: iobroker Error: Can't find Python executable "python", you can set the PYTHON env variable.
      ! 2016-10-25 08:49:44.580 - [32minfo[39m: iobroker gyp
      ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker stack
      ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:116:14)
      ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker gyp
      ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker ERR!
      ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:71:11
      ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker at FSReqWrap.oncomplete (fs.js:82:15)
      ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker System
      ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker Windows_NT 10.0.14393
      ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker gyp
      ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker ERR!
      ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker command
      ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
      ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker cwd
      ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker C:\ioBroker\node_modules\iobroker.js-controller\node_modules\letsencrypt\node_modules\rsa-compat\node_modules\ursa
      ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker node -v
      ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker v4.3.1
      ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker node-gyp -v
      ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker v3.0.3
      ! 2016-10-25 08:49:44.642 - [32minfo[39m: iobroker
      ! 2016-10-25 08:49:44.642 - [32minfo[39m: iobroker ERR!
      ! 2016-10-25 08:49:44.642 - [32minfo[39m: iobroker not ok
      ! 2016-10-25 08:49:44.798 - [32minfo[39m: iobroker npm
      ! 2016-10-25 08:49:44.814 - [32minfo[39m: iobroker
      ! 2016-10-25 08:49:44.814 - [32minfo[39m: iobroker WARN
      ! 2016-10-25 08:49:44.814 - [32minfo[39m: iobroker optional dep failed, continuing
      ! 2016-10-25 08:49:44.814 - [32minfo[39m: iobroker ursa@0.9.4
      ! 2016-10-25 08:51:43.128 - [32minfo[39m: iobroker exit 0
      ! 2016-10-25 08:51:43.393 - [32minfo[39m: host.host-pc-xyz Update repository "online" under "https://raw.githubusercontent.com/ioBro ... -dist.json"
      ! 2016-10-25 08:58:52.921 - [31merror[39m: host.host-pc-xyz instance system.adapter.admin.0 terminated with code 4294967295 ()
      ! 2016-10-25 08:58:52.921 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.admin.0 because enabled
      ! 2016-10-25 08:58:53.077 - [31merror[39m: host.host-pc-xyz instance system.adapter.hm-rpc.0 terminated with code 4294967295 ()
      ! 2016-10-25 08:58:53.077 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.hm-rpc.0 because enabled
      ! 2016-10-25 08:58:53.249 - [31merror[39m: host.host-pc-xyz instance system.adapter.hm-rega.0 terminated with code 4294967295 ()
      ! 2016-10-25 08:58:53.249 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.hm-rega.0 because enabled
      ! 2016-10-25 08:58:53.405 - [31merror[39m: host.host-pc-xyz instance system.adapter.web.0 terminated with code 4294967295 ()
      ! 2016-10-25 08:58:53.405 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.web.0 because enabled
      ! 2016-10-25 08:58:53.561 - [31merror[39m: host.host-pc-xyz instance system.adapter.javascript.0 terminated with code 4294967295 ()
      ! 2016-10-25 08:58:53.561 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.javascript.0 because enabled
      ! 2016-10-25 08:58:53.702 - [31merror[39m: host.host-pc-xyz instance system.adapter.pushover.0 terminated with code 4294967295 ()
      ! 2016-10-25 08:58:53.702 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.pushover.0 because enabled
      ! 2016-10-25 08:58:53.874 - [31merror[39m: host.host-pc-xyz instance system.adapter.javascript.1 terminated with code 4294967295 ()
      ! 2016-10-25 08:58:53.874 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.javascript.1 because enabled
      ! 2016-10-25 08:58:54.014 - [31merror[39m: host.host-pc-xyz instance system.adapter.scenes.0 terminated with code 4294967295 ()
      ! 2016-10-25 08:58:54.014 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.scenes.0 because enabled
      ! 2016-10-25 08:58:57.983 - [32minfo[39m: host.host-pc-xyz iobroker.js-controller version 0.13.0 js-controller starting
      ! 2016-10-25 08:58:57.983 - [32minfo[39m: host.host-pc-xyz Copyright (c) 2014-2016 bluefox, hobbyquaker
      ! 2016-10-25 08:58:57.983 - [32minfo[39m: host.host-pc-xyz hostname: host-pc-xyz, node: v4.3.1
      ! 2016-10-25 08:58:57.983 - [32minfo[39m: host.host-pc-xyz ip addresses: xxx.xxx.xxx.xxx
      ! 2016-10-25 08:58:58.123 - [32minfo[39m: inMem-states listening on port 9000
      ! 2016-10-25 08:58:58.264 - [32minfo[39m: inMem-objects listening on port 9001
      ! 2016-10-25 08:58:58.264 - [32minfo[39m: host.host-pc-xyz InMemoryDB connected
      ! 2016-10-25 08:58:58.279 - [32minfo[39m: host.host-pc-xyz 32 instances found
      ! 2016-10-25 08:58:58.295 - [32minfo[39m: host.host-pc-xyz starting 21 instances
      ! 2016-10-25 08:58:58.326 - [32minfo[39m: host.host-pc-xyz instance system.adapter.admin.0 started with pid 7892
      ! 2016-10-25 08:59:02.295 - [32minfo[39m: host.host-pc-xyz instance system.adapter.hm-rpc.0 started with pid 8232
      ! 2016-10-25 08:59:02.279 - [32minfo[39m: admin.0 starting. Version 1.6.4 in C:/ioBroker/node_modules/iobroker.admin, node: v4.3.1
      ! 2016-10-25 08:59:02.310 - [32minfo[39m: admin.0 requesting all states
      ! 2016-10-25 08:59:02.310 - [32minfo[39m: admin.0 requesting all objects
      ! 2016-10-25 08:59:02.310 - [32minfo[39m: admin.0 Request actual repository...
      ! 2016-10-25 08:59:02.310 - [32minfo[39m: admin.0 http server listening on port 8081
      ! 2016-10-25 08:59:02.310 - [32minfo[39m: admin.0 Use link "http://localhost:8081" to configure.
      ! 2016-10-25 08:59:04.060 - [32minfo[39m: admin.0 received all states
      ! 2016-10-25 08:59:04.638 - [32minfo[39m: admin.0 received all objects
      ! 2016-10-25 08:59:04.826 - [32minfo[39m: host.host-pc-xyz Update repository "online" under "https://raw.githubusercontent.com/ioBro ... -dist.json"
      ! 2016-10-25 08:59:05.482 - [32minfo[39m: hm-rpc.0 starting. Version 1.3.3 in C:/ioBroker/node_modules/iobroker.hm-rpc, node: v4.3.1
      ! 2016-10-25 08:59:05.889 - [32minfo[39m: hm-rpc.0 binrpc server is trying to listen on xxx.xxx.xxx.xxx:2001
      ! 2016-10-25 08:59:05.904 - [32minfo[39m: hm-rpc.0 binrpc client is trying to connect to xxx.xxx.xxx.xxx:2001 with ["xmlrpc_bin://xxx.xxx.xxx.xxx:2001","hm-rpc.0"]
      ! 2016-10-25 08:59:06.686 - [32minfo[39m: host.host-pc-xyz instance system.adapter.hm-rega.0 started with pid 5212
      ! 2016-10-25 08:59:09.170 - [32minfo[39m: hm-rpc.0 binrpc <- system.listMethods ["hm-rpc.0"]
      ! 2016-10-25 08:59:09.186 - [32minfo[39m: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
      ! 2016-10-25 08:59:09.264 - [32minfo[39m: hm-rpc.0 binrpc -> 348 devices
      ! 2016-10-25 08:59:10.248 - [32minfo[39m: hm-rpc.0 Connected
      ! 2016-10-25 08:59:10.295 - [32minfo[39m: host.host-pc-xyz instance system.adapter.web.0 started with pid 1656
      ! 2016-10-25 08:59:09.014 - [32minfo[39m: hm-rega.0 starting. Version 1.3.0 in C:/ioBroker/node_modules/iobroker.hm-rega, node: v4.3.1
      ! 2016-10-25 08:59:09.014 - [32minfo[39m: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
      ! 2016-10-25 08:59:12.654 - [32minfo[39m: hm-rega.0 ReGaHSS xxx.xxx.xxx.xxx up
      ! 2016-10-25 08:59:12.685 - [32minfo[39m: hm-rega.0 time difference local-ccu -39s
      ! 2016-10-25 08:59:12.779 - [32minfo[39m: hm-rega.0 added/updated 2 favorites to enum.favorites
      ! 2016-10-25 08:59:13.045 - [32minfo[39m: hm-rega.0 added/updated functions to enum.functions
      ! 2016-10-25 08:59:13.951 - [32minfo[39m: hm-rega.0 added/updated rooms to enum.rooms
      ! 2016-10-25 08:59:14.670 - [32minfo[39m: hm-rega.0 got 26 programs
      ! 2016-10-25 08:59:14.764 - [32minfo[39m: hm-rega.0 added/updated 26 programs
      ! 2016-10-25 08:59:14.764 - [32minfo[39m: hm-rega.0 deleted 0 programs
      ! 2016-10-25 08:59:15.295 - [32minfo[39m: hm-rega.0 got 113 variables
      ! 2016-10-25 08:59:15.935 - [32minfo[39m: hm-rega.0 added/updated 113 variables
      ! 2016-10-25 08:59:15.935 - [32minfo[39m: hm-rega.0 deleted 0 variables
      ! 2016-10-25 08:59:15.935 - [32minfo[39m: hm-rega.0 request state values
      ! 2016-10-25 08:59:13.732 - [32minfo[39m: web.0 starting. Version 1.7.2 in C:/ioBroker/node_modules/iobroker.web, node: v4.3.1
      ! 2016-10-25 08:59:16.747 - [32minfo[39m: web.0 socket.io server listening on port 8082
      ! 2016-10-25 08:59:16.747 - [32minfo[39m: web.0 http server listening on port 8082
      ! 2016-10-25 08:59:22.310 - [32minfo[39m: hm-rega.0 got state values
      ! 2016-10-25 08:59:17.513 - [32minfo[39m: vis.0 starting. Version 0.10.14 in C:/ioBroker/node_modules/iobroker.vis, node: v4.3.1
      ! 2016-10-25 08:59:28.545 - [32minfo[39m: host.host-pc-xyz instance system.adapter.vis.0 terminated while should be started once
      ! 2016-10-25 08:59:42.311 - [32minfo[39m: host.host-pc-xyz instance system.adapter.javascript.0 started with pid 3680
      ! 2016-10-25 08:59:46.420 - [32minfo[39m: javascript.0 starting. Version 3.1.0 in C:/ioBroker/node_modules/iobroker.javascript, node: v4.3.1
      ! 2016-10-25 08:59:46.436 - [32minfo[39m: javascript.0 requesting all states
      ! 2016-10-25 08:59:46.514 - [32minfo[39m: javascript.0 requesting all objects
      ! 2016-10-25 08:59:47.170 - [32minfo[39m: javascript.0 received all states
      ! 2016-10-25 08:59:47.873 - [32minfo[39m: javascript.0 received all objects[/spoiler]
      • Bluefox
        Bluefox last edited by
        @RS_Tobi:
        es war "on the run" installiert.
        also über git-Button aus dem Admin im laufenden system heraus installiert.
        war das falsch?
        soll ich was anderes nochmal testen?
        tobi `
        Leider geht js-controller on the run nicht.
        Man muss immer js-controller erst stoppen.
        Aber gute Punkt. Werde ich aus admin rausnehmen.
          @Bluefox:
          Aber gute Punkt. Werde ich aus admin rausnehmen. `
          Hinweis:
          Js-Controller ist auch bei github update in Admin mit drin!
            RS_Tobi last edited by
            Back….
            so habe es nochmal "manuell" installiert.
            hier der log
            ! root@raspberrypi:/opt/iobroker# cd /opt/iobroker
            ! root@raspberrypi:/opt/iobroker# iobroker stop
            ! Stopping iobroker controller daemon…
            ! iobroker controller daemon stopped.
            ! Exit code for "killall.sh": 0
            ! root@raspberrypi:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker .js-controller/tarball/master --production
            ! npm WARN peerDependencies The peer dependency request@^2.75.0 included from iobr oker.js-controller will no
            ! npm WARN peerDependencies longer be automatically installed to fulfill the peerD ependency
            ! npm WARN peerDependencies in npm 3+. Your application will need to depend on it explicitly.
            ! npm WARN peerDependencies The peer dependency socket.io@^1.5.0 included from iob roker.js-controller will no
            ! > ursa@0.9.4 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
            ! > node-gyp rebuild
            ! make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
            ! CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
            ! SOLINK_MODULE(target) Release/obj.target/ursaNative.node
            ! COPY Release/ursaNative.node
            ! make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
            ! > iobroker.js-controller@0.13.0 install /opt/iobroker/node_modules/iobroker.js-controller
            ! > node lib/setup.js setup first
            ! socket.io@1.5.1 node_modules/socket.io
            ! ├── has-binary@0.1.7 (isarray@0.0.1)
            ! ├── socket.io-parser@2.3.1 (isarray@0.0.1, json3@3.3.2, component-emitter@1.1.2)
            ! ├── debug@2.2.0 (ms@0.7.1)
            ! ├── socket.io-adapter@0.4.0 (socket.io-parser@2.2.2)
            ! ├── engine.io@1.7.2 (base64id@0.1.0, ws@1.1.1, engine.io-parser@1.3.1, accepts@1.3.3)
            ! └── socket.io-client@1.5.1 (to-array@0.1.4, component-emitter@1.2.0, indexof@0.0.1, component-bind@1.0.0, backo2@1.0.2, object-component@0.0.3, parseuri@0.0.4, engine.io-client@1.7.2)
            ! request@2.76.0 node_modules/request
            ! ├── aws-sign2@0.6.0
            ! ├── tunnel-agent@0.4.3
            ! ├── forever-agent@0.6.1
            ! ├── oauth-sign@0.8.2
            ! ├── is-typedarray@1.0.0
            ! ├── caseless@0.11.0
            ! ├── stringstream@0.0.5
            ! ├── aws4@1.5.0
            ! ├── isstream@0.1.2
            ! ├── json-stringify-safe@5.0.1
            ! ├── extend@3.0.0
            ! ├── tough-cookie@2.3.1
            ! ├── node-uuid@1.4.7
            ! ├── qs@6.3.0
            ! ├── combined-stream@1.0.5 (delayed-stream@1.0.0)
            ! ├── mime-types@2.1.12 (mime-db@1.24.0)
            ! ├── form-data@2.1.1 (asynckit@0.4.0)
            ! ├── hawk@3.1.3 (cryptiles@2.0.5, hoek@2.16.3, sntp@1.0.9, boom@2.10.1)
            ! ├── http-signature@1.1.1 (assert-plus@0.2.0, jsprim@1.3.1, sshpk@1.10.1)
            ! └── har-validator@2.0.6 (pinkie-promise@2.0.1, commander@2.9.0, chalk@1.1.3, is-my-json-valid@2.15.0)
            ! iobroker.js-controller@0.13.0 node_modules/iobroker.js-controller
            ! ├── safe-replace@1.0.2
            ! ├── le-sni-auto@2.1.0
            ! ├── le-challenge-fs@2.0.8
            ! ├── pyconf@1.1.2
            ! ├── winston-daily-rotate-file@1.3.1
            ! ├── mime@1.3.4
            ! ├── semver@5.3.0
            ! ├── daemonize2@0.4.2
            ! ├── ncp@2.0.0
            ! ├── node.extend@1.1.6 (is@3.2.0)
            ! ├── redis@2.6.2 (double-ended-queue@2.1.0-0, redis-parser@2.0.4, redis-commands@1.3.0)
            ! ├── mkdirp@0.5.1 (minimist@0.0.8)
            ! ├── bluebird@3.4.6
            ! ├── node-schedule@1.1.1 (long-timeout@0.0.2, cron-parser@1.1.0)
            ! ├── winston@2.2.0 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, async@1.0.0, pkginfo@0.3.1, colors@1.0.3)
            ! ├── socket.io-client@1.5.1 (to-array@0.1.4, component-emitter@1.2.0, indexof@0.0.1, component-bind@1.0.0, backo2@1.0.2, object-component@0.0.3, has-binary@0.1.7, socket.io-parser@2.3.1, debug@2.2.0, parseuri@0.0.4, engine.io-client@1.7.2)
            ! ├── prompt@1.0.0 (revalidator@0.1.8, pkginfo@0.4.0, colors@1.1.2, read@1.0.7, winston@2.1.1, utile@0.3.0)
            ! ├── yargs@6.3.0 (get-caller-file@1.0.2, decamelize@1.2.0, y18n@3.2.1, camelcase@3.0.0, which-module@1.0.0, set-blocking@2.0.0, window-size@0.2.0, yargs-parser@4.0.2, require-main-filename@1.0.1, require-directory@2.1.1, os-locale@1.4.0, cliui@3.2.0, string-width@1.0.2, read-pkg-up@1.0.1)
            ! ├── letsencrypt@2.1.8 (le-store-certbot@2.0.3, homedir@0.6.0, asn1js@1.2.12, localhost.daplie.com-certificates@1.2.3, certpem@1.0.1, pkijs@1.3.27, le-acme-core@2.0.7, le-challenge-sni@2.0.1, rsa-compat@1.2.7)
            ! ├── tar.gz@1.0.5 (commander@2.9.0, tar@2.2.1, bluebird@2.11.0, fstream@1.0.10, mout@0.11.1)
            ! ├── jszip@3.1.3 (es6-promise@3.0.2, lie@3.1.0, pako@1.0.3, readable-stream@2.0.6, core-js@2.3.0)
            ! └── npm@2.15.11
            ! root@raspberrypi:/opt/iobroker# iobroker start
            ! Starting iobroker controller daemon...
            ! iobroker controller daemon started. PID: 9386
            hat bis jetzt auf den ersten Blick recht gut funktioniert.
            grüße
            • Bluefox
              Bitte 0.13.1 testen. Ich will die Version releasen.
              • Jey Cee
                ich hab das jetzt mehrfach versucht auf meinem test host. Aber ich bekomme beim versuch den js-controller zu installieren immer eine Fehlermeldung.
                root@iobroker-test:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
                node-gyp rebuild
                ! gyp ERR! configure error
                gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
                gyp ERR! stack at failNoPython (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:449:14)
                gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:353:11
                gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:16)
                gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
                gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
                gyp ERR! System Linux 4.4.0-45-generic
                gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
                gyp ERR! node -v v4.6.1
                gyp ERR! node-gyp -v v3.4.0
                gyp ERR! not ok
                npm WARN optional dep failed, continuing ursa@0.9.4
                ! > iobroker.js-controller@0.13.1 install /opt/iobroker/node_modules/iobroker.js-controller
                ! fs.js:549
                return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
                ! Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
                at Error (native)
                at Object.fs.openSync (fs.js:549:18)
                at Object.fs.writeFileSync (fs.js:1156:15)
                at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:88:24)
                at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:552:23
                at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:573:11)
                at Module._compile (module.js:409:26)
                at Object.Module._extensions..js (module.js:416:10)
                at Module.load (module.js:343:32)
                at Function.Module._load (module.js:300:12)
                npm ERR! Linux 4.4.0-45-generic
                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.js-controller/tarball/master" "--production"
                npm ERR! node v4.6.1
                npm ERR! npm v2.15.9
                npm ERR! code ELIFECYCLE
                ! npm ERR! iobroker.js-controller@0.13.1 install: node lib/setup.js setup first
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the iobroker.js-controller@0.13.1 install script 'node lib/setup.js setup first'.
                npm ERR! This is most likely a problem with the iobroker.js-controller package,
                npm ERR! not with npm itself.
                npm ERR! Tell the author that this fails on your system:
                npm ERR! node lib/setup.js setup first
                npm ERR! You can get information on how to open an issue for this project with:
                npm ERR! npm bugs iobroker.js-controller
                npm ERR! Or if that isn't available, you can get their info via:
                npm ERR!
                npm ERR! npm owner ls iobroker.js-controller
                npm ERR! There is likely additional logging output above.
                ! npm ERR! Please include the following file with any support request:
                npm ERR! /opt/iobroker/npm-debug.log</anonymous>
                Versuche ich die version 0.12.2 zu installieren bekomme ich die gleich Fehlermeldung. Es scheint also ein Problem mit dem test host zu geben. Ich versteh nur nicht warum die Installation direkt davor Reibunglos läuft.
                • Bluefox
                  Kannst du bitte folgendes machen.
                  cd /opt/iobroker
                  sudo iobroker stop
                  sudo chmod 777 * -R
                  sudo apt-get install build-essential
                  sudo npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
                  sudo chmod 777 * -R
                  sudo iobroker start
                  • Jey Cee
                    Danke jetzt hat es funktioniert.
                    Nur eins es muss "sudo apt-get install build-essentials" heissen, nicht "sudo npm install build-essentials".
                    Auf den ersten Blick sieht mal alles gut aus.
                    Ich hab gesehen du hast meinen Adapter in die Hauptliste aufgenommen. Da er aber noch nicht in npm gelistet ist kann er nicht installiert werden.
                    Erledigt: Gibt es irgendwo einen crash-kurs wie man den in npm Veröffentlicht?
                    Edit: Ich hab den Adapter jetzt auf npm veröffentlicht und er lässt sich auch installieren. Aber es wird ein Fehler im Reiter Admin angezeigt. Siehe Bild.
                      Stmiko last edited by
                      Bekomme die version leider nicht installiert:
                      ! ` > root@Raspi31:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.js … all/master --production
                      npm WARN peerDependencies The peer dependency iobroker.admin@>=1.6.4 included from iobroker.js-controller will no
                      npm WARN peerDependencies longer be automatically installed to fulfill the peerDependency
                      node-gyp rebuild
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-babel/node_modules/gulp-util requires object-assign@'^3.0.0' but will load
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-babel/node_modules/object-assign,
                      npm WARN unmet dependency which is version 4.1.0
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-concat/node_modules/gulp-util requires through2@'^2.0.0' but will load
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-concat/node_modules/through2,
                      npm WARN unmet dependency which is version 0.6.5
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-less/node_modules/accord requires lodash@'4.11.2' but will load
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/lodash,
                      npm WARN unmet dependency which is version 4.16.5
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-less/node_modules/gulp-util requires object-assign@'^3.0.0' but will load
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-less/node_modules/object-assign,
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-minify-html/node_modules/gulp-util requires through2@'^2.0.0' but will load
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-minify-html/node_modules/through2,
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/chokidar requires glob-parent@'^2.0.0' but will load
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/glob-parent,
                      npm WARN unmet dependency which is version 3.0.1
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/gulp-util requires object-assign@'^3.0.0' but will load
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/object-assign,
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/gulp-util requires vinyl@'^0.5.0' but will load
                      npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/vinyl,
                      npm WARN unmet dependency which is version 1.2.0
                      npm ERR! Linux 4.4.27-v7+
                      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.js ... all/master" "--production"
                      npm ERR! code EPEERINVALID
                      npm ERR! peerinvalid The package iobroker.admin@0.8.3 does not satisfy its siblings' peerDependencies requirements!
                      npm ERR! peerinvalid Peer iobroker.js-controller@0.13.1 wants iobroker.admin@>=1.6.4
                      npm ERR! /opt/iobroker/npm-debug.log `
                      Admin ist aber version 1.6.5:
                      ! ` > update done
                      Adapter "zwave" : 0.2.5
                      Adapter "yr" : 1.0.5
                      Adapter "yamaha" : 0.2.1
                      Adapter "wolf" : 0.1.0
                      Adapter "web" : 1.7.2 , installed 1.7.2
                      Adapter "weatherunderground": 1.0.2
                      Adapter "vis-timeandweather": 1.1.4 , installed 1.1.4
                      Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
                      Adapter "vis-plumb" : 0.1.6 , installed 0.1.6
                      Adapter "vis-metro" : 1.0.4 , installed 1.0.4
                      Adapter "vis-map" : 0.1.3 , installed 0.1.3
                      Adapter "vis-lcars" : 1.0.1 , installed 1.0.1
                      Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2
                      Adapter "vis-justgage" : 0.6.0 , installed 0.6.0
                      Adapter "vis-jqui-mfd" : 1.0.5 , installed 1.0.5
                      Adapter "vis-hqwidgets" : 1.0.6 , installed 1.0.6
                      Adapter "vis-history" : 0.2.4 , installed 0.2.4
                      Adapter "vis-google-fonts": 0.1.0 , installed 0.1.0
                      Adapter "vis-fancyswitch": 1.0.0 , installed 1.0.0
                      Adapter "vis-colorpicker": 1.1.0 , installed 1.1.0
                      Adapter "vis-canvas-gauges": 0.1.3
                      Adapter "vis-bars" : 0.1.2 , installed 0.1.2
                      Adapter "vis" : 0.10.14 , installed 0.10.14
                      Adapter "vcard" : 0.0.8
                      Adapter "upnp" : npm error
                      Adapter "tvspielfilm" : 0.2.2
                      Adapter "text2command" : 1.1.3 , installed 1.1.3
                      Adapter "terminal" : 0.1.2 , installed 0.1.2
                      Adapter "telegram" : 0.4.4 , installed 0.4.4
                      Adapter "tankerkoenig" : 1.0.0
                      Adapter "starline" : 0.1.7
                      Adapter "sonos" : 0.2.2
                      Adapter "solarwetter" : 0.1.2
                      Adapter "socketio" : 1.7.1
                      Adapter "squeezebox" : 0.1.0
                      Adapter "sql" : 1.2.1
                      Adapter "simple-api" : 1.3.0
                      Adapter "scenes" : 0.2.6 , installed 0.2.6
                      Adapter "sayit" : 1.1.2
                      Adapter "samsung" : 0.0.11
                      Adapter "s7" : 0.2.4
                      Adapter "rwe-smarthome" : 0.1.9
                      Adapter "rpi2" : 0.2.1
                      Adapter "rickshaw" : 0.4.4
                      Adapter "rflink" : 1.0.2
                      Adapter "pushover" : 1.0.2
                      Adapter "pushsafer" : 0.1.7
                      Adapter "pushbullet" : 0.0.11
                      Adapter "ping" : 1.1.1 , installed 1.1.1
                      Adapter "piface" : 0.0.50
                      Adapter "phantomjs" : 0.1.2
                      Adapter "owntracks" : 0.1.1
                      Adapter "owfs" : 0.3.4
                      Adapter "onkyo" : 0.2.0
                      Adapter "occ" : 0.2.4
                      Adapter "nut" : 0.3.1
                      Adapter "noolite" : 0.0.1
                      Adapter "node-red" : 1.1.2
                      Adapter "netatmo" : 0.4.0
                      Adapter "mysensors" : 1.0.4
                      Adapter "mqtt-client" : 0.3.0
                      Adapter "mqtt" : 1.1.2
                      Adapter "modbus" : 0.3.11
                      Adapter "mobile" : 0.4.9
                      Adapter "miele" : 0.0.16
                      Adapter "megad" : 1.2.1
                      Adapter "lgtv" : 1.0.0
                      Adapter "kodi" : 0.1.4
                      Adapter "knx" : 0.7.0
                      Controller "js-controller" : 0.12.2 , installed 0.12.2
                      Adapter "javascript" : 3.0.10 , installed 3.0.10
                      Adapter "influxdb" : 1.1.0 , installed 1.1.0
                      Adapter "icons-ultimate-png": 0.1.0
                      Adapter "icons-open-icon-library-png": 0.1.3
                      Adapter "icons-mfd-svg" : 1.0.0
                      Adapter "icons-mfd-png" : 1.0.0 , installed 1.0.0
                      Adapter "icons-material-svg": 0.1.0
                      Adapter "icons-material-png": 0.1.0
                      Adapter "icons-icons8" : 0.0.1
                      Adapter "icons-addictive-flavour-png": 0.1.0
                      Adapter "ical" : 1.2.0 , installed 1.2.0
                      Adapter "hmm" : 1.0.1
                      Adapter "homepilot" : 0.0.7
                      Adapter "homekit2" : 0.1.6
                      Adapter "hue" : 0.5.9 , installed 0.5.9
                      Adapter "hm-rpc" : 1.3.3 , installed 1.3.3
                      Adapter "hm-rega" : 1.3.0 , installed 1.3.0
                      Adapter "history" : 1.3.1 , installed 1.3.1
                      Adapter "harmony" : 0.5.6
                      Adapter "geofency" : 0.1.5 , installed 0.1.5
                      Adapter "fritzbox" : 0.2.1
                      Adapter "foobar2000" : 0.1.2
                      Adapter "feiertage" : 0.3.2
                      Adapter "flot" : 1.5.5 , installed 1.5.5
                      Adapter "fhem" : 0.2.2
                      Adapter "epson_stylus_px830": 0.0.2
                      Adapter "email" : 1.0.0
                      Adapter "dwd" : 2.1.1
                      Adapter "cul" : 0.0.4
                      Adapter "cloud" : 0.1.1 , installed 0.1.1
                      Adapter "chromecast" : 1.1.0
                      Adapter "botvac" : 0.5.0
                      Adapter "b-control-em" : 0.1.1
                      Adapter "artnet" : 0.1.4
                      Adapter "amazon-dash" : 0.1.0
                      Adapter "admin" : 1.6.4 , installed 1.6.5 Was bedeuted eigentlich das hier: > npm ERR! peerinvalid The package iobroker.admin@0.8.3 does not satisfy its siblings' peerDependencies requirements! `
                      build-essential ist installiert.
                      Was kann ich tun?
                      Lg
                      • Bluefox
                        npm findet irgendwo: iobroker.admin@0.8.3
                        Kannst du mal in
                        /opt/iobroker/node_modules/iobroker.admin/package.json
                        und
                        /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/package.json
                        checken?
                        Welche Versionen sind dadrin?
                          ` > Kannst du mal in
                          und
                          checken?
                          Welche Versionen sind dadrin? `
                          Im ersten package.json stand in der Tat bei admin noch eine 0.8.3 drin. Warum auch immer?
                          Das zweite package.json gibts bei mir nicht.
                          Ich habe das jetzt im ersten file händisch auf 1.6.5 geändert und jetzt läuft die Installation durch.:
                          node-gyp rebuild
                          iobroker.js-controller@0.13.1 node_modules/iobroker.js-controller
                          ├── pyconf@1.1.2
                          ├── semver@5.3.0
                          ├── mime@1.3.4
                          ├── ncp@2.0.0
                          ├── redis@2.6.3 (double-ended-queue@2.1.0-0, redis-parser@2.1.1, redis-commands@1.3.0)
                          ├── bluebird@3.4.6
                          ├── socket.io-client@1.5.1 (to-array@0.1.4, indexof@0.0.1, component-bind@1.0.0, component-emitter@1.2.0, backo2@1.0.2, object-component@0.0.3, has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.3.1, parseuri@0.0.4, engine.io-client@1.7.2)
                          ├── yargs@6.3.0 (get-caller-file@1.0.2, decamelize@1.2.0, camelcase@3.0.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, window-size@0.2.0, yargs-parser@4.0.2, require-main-filename@1.0.1, require-directory@2.1.1, os-locale@1.4.0, string-width@1.0.2, cliui@3.2.0, read-pkg-up@1.0.1)
                          ├── letsencrypt@2.1.8 (le-store-certbot@2.0.3, homedir@0.6.0, asn1js@1.2.12, le-acme-core@2.0.7, localhost.daplie.com-certificates@1.2.3, certpem@1.0.1, pkijs@1.3.27, le-challenge-sni@2.0.1, rsa-compat@1.2.7)
                          └── npm@2.15.11 Allerdings scheint das Update nicht geklappt zu haben, er zeigt mir im web interface immer noch die 0.12.2 an (auch nach einem reboot)? > host.Raspi31 2016-11-01 00:46:27.478 info Copyright © 2014-2016 bluefox, hobbyquaker
                          host.Raspi31 2016-11-01 00:46:27.464 info iobroker.js-controller version 0.12.2 js-controller starting `
                            Ok, jetzt hat es nach mehreren Versuchen endlich geklappt: js-controller 0.13.1 installiert .
                            Läuft bisher ohne Probleme.
                            Lg,
                            • rantanplan
                              Hallo
                              Kann mir bitte jemand die Befehle für das Update für Win10 angeben.
                                akamia last edited by
                                Installation in c:\iobroker
                                • CMD aufrufen
                                • Ins Verzeichnis gehen
                                • iobroker stop
                                • npm install https://github.com/ioBroker/ioBroker.js … all/master
                                • iobroker start
                                  Bisher keine Auffälligkeiten
                                  +Admin 1.6.5
                                  +js-controller 0.13.1
                                  Keine Fehlermeldungen im Log.
                                  • eric2905
                                    eric2905 last edited by
                                    @akamia:
                                    +Admin 1.6.5
                                    Keine Fehlermeldungen im Log. `
                                    Bei mir, mit gleicher Konstellation, auch bisher keine Fehler.
                                    Gruß,
                                    Eric
                                    • rantanplan
                                      @akamia Herzlichen Dank. Hat ohne Probleme geklappt.
                                      @Bluefox Meine "SendTo-Bausteine" sind immer noch weg 😞
                                        Ritter last edited by
                                        Habs unter Windows 10 64bit installiert und funktioniert bis jetzt alles.
                                        • Bluefox
                                          @rantanplan:
                                          Grüße `
                                          Ich befürchte, du bist der einzigste.
                                          • rantanplan
                                            @Bluefox:
                                            @rantanplan:
                                            Grüße Ich befürchte, du bist der einzigste.
                                            Das befürchte ich mittlerweile auch 😉
                                            Irgend eine Idee wie ich mich wieder der Allgemeinheit anschließen kann?
                                            56
                                            6660
