    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Разные ошибки
    Разные ошибки
      Haus last edited by
      @spectrekr:
      Драйвер Rickshaw Charts не обновляется ни в какую. Статус обновления 0, а в админке так и весит что надо обновить. Через консоль тоже самое.
      ! iobroker 2016-09-07 10:07:43.218 info exit 0
      ! iobroker 2016-09-07 10:07:43.209 info Adapter "rickshaw" updated
      ! iobroker 2016-09-07 10:07:43.117 info upload [0] rickshaw /opt/iobroker/node_modules/iobroker.rickshaw/www/edit.html edit.html text/html
      ! iobroker 2016-09-07 10:07:43.052 info upload [1] rickshaw /opt/iobroker/node_modules/iobroker.rickshaw/www/index.html index.html text/html
      ! iobroker 2016-09-07 10:07:42.993 info upload [2] rickshaw /opt/iobroker/node_modules/iobroker.rickshaw/www/lib/css/rickshaw.min.css lib/css/rickshaw.min.css text/css
      ! iobroker 2016-09-07 10:07:42.913 info upload [3] rickshaw /opt/iobroker/node_modules/iobroker.rickshaw/www/lib/js/d3.v3.js lib/js/d3.v3.js application/javascript
      ! iobroker 2016-09-07 10:07:42.904 info upload [0] rickshaw.admin /opt/iobroker/node_modules/iobroker.rickshaw/admin/index.html index.html text/html
      ! iobroker 2016-09-07 10:07:42.820 info upload [4] rickshaw /opt/iobroker/node_modules/iobroker.rickshaw/www/lib/js/rickshaw.min.js lib/js/rickshaw.min.js application/javascript
      ! iobroker 2016-09-07 10:07:42.813 info upload [1] rickshaw.admin /opt/iobroker/node_modules/iobroker.rickshaw/admin/rickshaw.png rickshaw.png image/png
      ! iobroker 2016-09-07 10:07:42.787 info got /opt/iobroker/node_modules/iobroker.rickshaw/www
      ! iobroker 2016-09-07 10:07:42.783 info got /opt/iobroker/node_modules/iobroker.rickshaw/admin
      ! iobroker 2016-09-07 10:07:41.892 info npm install –production --prefix "/opt/iobroker/node_modules/iobroker.rickshaw" (System call)
      ! iobroker 2016-09-07 10:07:23.312 info npm install iobroker.rickshaw --production --prefix "/opt/iobroker" (System call)
      ! iobroker 2016-09-07 10:07:22.761 info upgrade rickshaw `
      Bluefox исправь io-package.json
      "common": {
              "name":         "rickshaw",
              "version":      "0.4.2",
        dimon last edited by
        После последних обновлений перестал работать админский интерфейс - белый экран. Причем vis работает.
        Что можно сделать?
          Haus last edited by
          @dimon:
          Что можно сделать? `
          http://forum.iobroker.net/viewtopic.php … 120#p34162
            ford7 last edited by
            Откатился, вроде задышал брокер, но в логе сыпется каждые 2-3 минуты
            host-zvmubn	2016-09-07 21:10:42.120	info	Restart adapter system.adapter.admin.0 because enabled
            host-zvmubn	2016-09-07 21:10:42.119	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
            host-zvmubn	2016-09-07 21:10:42.075	info	Restart adapter system.adapter.web.0 because enabled
            host-zvmubn	2016-09-07 21:10:42.075	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
            host-zvmubn	2016-09-07 21:10:41.438	info	instance system.adapter.web.0 started with pid 10658
            host-zvmubn	2016-09-07 21:10:40.896	info	instance system.adapter.admin.0 started with pid 10656
            host-zvmubn	2016-09-07 21:10:38.908	info	Restart adapter system.adapter.sayit.0 because enabled
            host-zvmubn	2016-09-07 21:10:38.908	error	instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
            host-zvmubn	2016-09-07 21:10:38.597	info	instance system.adapter.sayit.0 started with pid 10650
            host-zvmubn	2016-09-07 21:10:33.284	info	Update repository "fast-online" under "http://download.iobroker.net/sources-dist.json"
            host-zvmubn	2016-09-07 21:10:26.785	info	Restart adapter system.adapter.socketio.0 because enabled
            host-zvmubn	2016-09-07 21:10:26.784	error	instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
            host-zvmubn	2016-09-07 21:10:26.602	info	Restart adapter system.adapter.s7.0 because enabled
            host-zvmubn	2016-09-07 21:10:26.602	error	instance system.adapter.s7.0 terminated with code 7 (Adapter already running)
            host-zvmubn	2016-09-07 21:10:26.038	info	Restart adapter system.adapter.sql.0 because enabled
            host-zvmubn	2016-09-07 21:10:26.037	error	instance system.adapter.sql.0 terminated with code 7 (Adapter already running)
            host-zvmubn	2016-09-07 21:10:25.874	info	instance system.adapter.s7.0 started with pid 10635
            host-zvmubn	2016-09-07 21:10:25.848	info	instance system.adapter.socketio.0 started with pid 10633
            host-zvmubn	2016-09-07 21:10:25.219	info	instance system.adapter.sql.0 started with pid 10631
            • Bluefox
              Bluefox last edited by
              @ford7:
              Перезапустить надо комп.
                andrey99986 last edited by
                после попытки обновить admin через админку, он пропал.
                В консоли:
                root@debian:/home/iobroker# iobroker stop
                Stopping iobroker controller daemon...
                iobroker controller daemon stopped.
                Exit code for "killall.sh": 0
                root@debian:/home/iobroker# npm install iobroker.admin --production
                iobroker.core@ /home/iobroker
                └── (empty)
                npm ERR! code 1
                Дело в том что по умолчанию указал репозитарий с гита. Может в этом проблема ? Как лечить?
                Драйвер не запускается, на порт 8081 ничего нет.
                  kID last edited by
                  @andrey99986:
                  после попытки обновить admin через админку, он пропал. `
                  вначале обновить js-controller
                  iobroker upgrade self
                  затем
                  iobroker del admin
                  iobroker add admin –enabled
                  Мне помогло
                    @kID:
                    @andrey99986:
                    затем
                    iobroker del admin
                    Мне помогло `
                    Дело было в канале связи - ограничение скорости до 64 кбит.
                    Пополнил баланс, команда на обновление после этого отработала нормально.
                    Возьмите на заметку.
                      spectrekr last edited by
                      Обнаружил ошибку в мультихост.
                      Ситуация: на основном сервере стоит драйвер, вторую версию драйвера устанавливаю на дочерний сервер. Ошибка заключается в том, что если с дочернего сервера удаляешь драйвер, то с основного сервера он тоже удаляется.
                        Настройка let's encrypt.
                        2016-11-01 12:13:37.224 - error: uncaught exception: listen EACCES 0.0.0.0:80
                        2016-11-01 12:13:37.238 - error: Error: listen EACCES 0.0.0.0:80
                        at Object.exports._errnoException (util.js:874:11)
                        at exports._exceptionWithHostPort (util.js:897:20)
                        at Server._listen2 (net.js:1221:19)
                        at listen (net.js:1270:10)
                        at Server.listen (net.js:1366:5)
                        at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:69:21)
                        at initWebServer (/opt/iobroker/node_modules/iobroker.admin/admin.js:523:28)
                        at /opt/iobroker/node_modules/iobroker.admin/admin.js:255:25
                        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:360:21)
                        at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                        at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                        at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                        at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                        at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                        at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                        at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                        at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
                        at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
                        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                        at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
                        at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:444:14)
                        at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:261:10)
                        at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
                        at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8)
                        at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8)
                        at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:135:10)
                        at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
                        at emitTwo (events.js:87:13)
                        2016-11-01 12:13:37.245 - info: admin.0 terminating https server on port 8081
                        2016-11-01 12:13:37.269 - info: admin.0 https server listening on port 8081
                        2016-11-01 12:13:37.271 - info: admin.0 Use link "https://localhost:8081" to configure.
                        2016-11-01 12:13:38.259 - info: admin.0 terminating https server on port 8081
                        2016-11-01 12:13:39.783 - error: host.Cubian instance system.adapter.admin.0 terminated with code 6 (uncaught exception)
                        2016-11-01 12:13:39.786 - info: host.Cubian Restart adapter system.adapter.admin.0 because enabled</anonymous></anonymous></anonymous></anonymous></anonymous>
                          Попробовал сделать экспорт всех скриптов, получил ошибку.
                          ! TypeError: 2017-02-15 12:23:57.693 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                          ! TypeError: 2017-02-15 12:23:57.693 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                          ! TypeError: 2017-02-15 12:23:57.693 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                          ! TypeError: 2017-02-15 12:23:57.693 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:228:12)
                          ! TypeError: 2017-02-15 12:23:57.693 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:270:10)
                          ! TypeError: 2017-02-15 12:23:57.693 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                          ! TypeError: 2017-02-15 12:23:57.693 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
                          ! TypeError: 2017-02-15 12:23:57.693 error at Object.States.change (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:228:25)
                          ! TypeError: 2017-02-15 12:23:57.693 error at processMessage (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:1282:26)
                          ! TypeError: 2017-02-15 12:23:57.693 error at Object.readObjectsAsZip (/opt/iobroker/node_modules/iobroker.js-controller/lib/zipFiles.js:249:13)
                          ! TypeError: 2017-02-15 12:23:57.693 error objects.getConfigKeys is not a function
                          ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function
                          • Bluefox
                            @spectrekr:
                            ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function `
                            Multihost?
                              @Bluefox:
                              @spectrekr:
                              ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function Multihost?
                              Да.
                              • Bluefox
                                @spectrekr:
                                @Bluefox:
                                @spectrekr:
                                Да. `
                                Ошибка.. Поправлю в следующей версии.
                                Спасибо.
                                • Bluefox
                                  @spectrekr:
                                  ! 2016-11-01 12:13:37.224 - error: uncaught exception: listen EACCES 0.0.0.0:80 2016-11-01 12:13:37.238 - error: Error: listen EACCES 0.0.0.0:80 at Object.exports._errnoException (util.js:874:11) at exports._exceptionWithHostPort (util.js:897:20) at Server._listen2 (net.js:1221:19) at listen (net.js:1270:10) at Server.listen (net.js:1366:5) at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:69:21) at initWebServer (/opt/iobroker/node_modules/iobroker.admin/admin.js:523:28) at /opt/iobroker/node_modules/iobroker.admin/admin.js:255:25 at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:360:21) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12) at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8) at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12) at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16) at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:444:14) at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:261:10) at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8) at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8) at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:135:10) at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14) at emitTwo (events.js:87:13) 2016-11-01 12:13:37.245 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:37.269 - info: admin.0 https server listening on port 8081 2016-11-01 12:13:37.271 - info: admin.0 Use link "https://localhost:8081" to configure. 2016-11-01 12:13:38.259 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:39.783 - error: host.Cubian instance system.adapter.admin.0 terminated with code 6 (uncaught exception) 2016-11-01 12:13:39.786 - info: host.Cubian Restart adapter system.adapter.admin.0 because enabled</anonymous></anonymous></anonymous></anonymous></anonymous> `
                                  Кто то висит на порту 80 и не даёт запустить web.
                                  Lets Encrypt работает только с 80. Хотя если на рутере перенаправить 80 на что либо другое, то тоже будет работать.
                                    @Bluefox:
                                    @spectrekr:
                                    Lets Encrypt работает только с 80. Хотя если на рутере перенаправить 80 на что либо другое, то тоже будет работать. `
                                    Странно, висеть больше не чему. Ну в любом случае обновился.
                                      Подскажите, node-red ругается на node.js- как поправить?
                                      node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB
                                      node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB
                                      node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------
                                      node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode.
                                      node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
                                      node-red.0 2017-03-09 10:48:09.753 warn ^^^^^
                                      node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1
                                      node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100
                                      web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin
                                      web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin
                                      web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin
                                      node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] *****************************************************************
                                      node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 *
                                      node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] *****************************************************************
                                        Haus last edited by
                                        @ford7:
                                        ! node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode. node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:09.753 warn ^^^^^ node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1 node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100 node-red.0 2017-03-09 10:48:09.753 warn web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] ***************************************************************** node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 * node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] ***************************************************************** `
                                        Сменить nodejs нужна версия v4.x и выше.
                                        • I
                                          Izzm last edited by
                                          Обновился до крайней версии. MQTT сервер стал заваливать сообщениями в лог.
                                          Перезапускал отдельно драйвер, перезагружал сервер целиком. Эффекта нет.
                                          js-controller 0.16.2
                                          Admin 1.7.0
                                          JS 3.2.6
                                          • Bluefox
                                            @Izzm:
                                            Admin 1.7.0
                                            JS 3.2.6 `
                                            А на самом деле эти переменные существуют?
                                            192
                                            52385
