    4. XBox-Adapter Fehler
    SOLVED XBox-Adapter Fehler
      TWART016 last edited by
      ich wollte eben den Adapter einrichten, bekomme jedoch den Fehler:
      xbox.0	2020-12-24 02:29:19.211	error	(20277) [START] Restarting adapter in 30 seconds
      xbox.0	2020-12-24 02:29:19.210	error	(20277) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found INFO: Started server process [20309] INFO: Wai
      xbox.0	2020-12-24 02:29:18.968	info	(20277) Terminated (NO_ERROR): Without reason
      xbox.0	2020-12-24 02:29:18.967	info	(20277) terminating
      xbox.0	2020-12-24 02:29:18.922	info	(20277) [END] cleaned everything up...
      xbox.0	2020-12-24 02:29:18.907	info	(20277) [END] REST server stopped
      xbox.0	2020-12-24 02:29:18.743	error	(20277) TypeError: Cannot read property 'includes' of undefined at Request.request.post [as _callback] (/opt/iobroker/node_modules/iobroker.xbox/main.js:685:45) at Request.self.callback (/opt/
      xbox.0	2020-12-24 02:29:18.743	error	(20277) unhandled promise rejection: Cannot read property 'includes' of undefined
      xbox.0	2020-12-24 02:29:18.742	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      xbox.0	2020-12-24 02:29:13.630	info	(20277) [START] Starting REST server
      xbox.0	2020-12-24 02:29:13.595	info	(20277) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
      Das habe ich mit dem Alias in meinem Homeverzeichnis gesetzt:
      python -V
      Python 3.8.5
      locale -a
      C
      C.UTF-8
      de_DE.utf8
      POSIX
      sudo cat /etc/default/locale
      LANG=de_DE.UTF-8
      Fehlt in dem Ordner noch was?
       ls -lah /opt/iobroker/node_modules/iobroker.xbox/node_modules
      total 12K
      drwxrwxr-x+ 3 iobroker iobroker 4,0K Dez 24 02:30 .
      drwxrwxr-x+ 7 iobroker iobroker 4,0K Dez 24 01:31 ..
      drwxrwxr-x+ 5 iobroker iobroker 4,0K Dez 24 01:31 ping
        Thomas Braun Most Active @TWART016 last edited by
        @TWART016 Das Log ist abgeschnitten, da fehlt das Ende.
        Und welche Distribution ist das? Python 3.8 scheint mir irgendwie nachinstalliert zu sein.
          TWART016 @Thomas Braun last edited by
          @Thomas-Braun
          So stand das im Log im ioBroker. Ich hab habe das nun heruntergeladen und gefiltert:
          2020-12-24 14:40:39.038  - info: xbox.0 (79678) [END] REST server stopped
          2020-12-24 14:40:39.049  - info: xbox.0 (79678) [END] cleaned everything up...
          2020-12-24 14:40:39.096  - info: xbox.0 (79678) terminating
          2020-12-24 14:40:39.096  - info: xbox.0 (79678) Terminated (NO_ERROR): Without reason
          2020-12-24 14:40:39.649  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:40:39.649  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:41:09.662  - info: host.iobroker instance system.adapter.xbox.0 started with pid 79728
          2020-12-24 14:41:11.792  - info: xbox.0 (79728) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:41:11.814  - info: xbox.0 (79728) [START] Starting REST server
          2020-12-24 14:41:16.882  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:41:16.882  - error: xbox.0 (79728) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:41:16.883  - error: xbox.0 (79728) TypeError: Cannot read property 'includes' of undefined
              at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
              at Request.emit (events.js:198:13)
              at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
              at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
              at Object.onceWrapper (events.js:286:20)
              at IncomingMessage.emit (events.js:203:15)
              at endReadableNT (_stream_readable.js:1145:12)
              at process._tickCallback (internal/process/next_tick.js:63:19)
          2020-12-24 14:41:17.030  - info: xbox.0 (79728) [END] REST server stopped
          2020-12-24 14:41:17.041  - info: xbox.0 (79728) [END] cleaned everything up...
          2020-12-24 14:41:17.084  - info: xbox.0 (79728) terminating
          2020-12-24 14:41:17.085  - info: xbox.0 (79728) Terminated (NO_ERROR): Without reason
          2020-12-24 14:41:17.322  - error: xbox.0 (79728) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [79757]
          INFO:     Waiting for application startup.
          INFO:     Application startup complete.
          INFO:     Uvicorn running on http://127.0.0.1:5557 (Press CTRL+C to quit)
          INFO:     Shutting down
          INFO:     Waiting for application shutdown.
          INFO:     Application shutdown complete.
          INFO:     Finished server process [79757]
          2020-12-24 14:41:17.322  - error: xbox.0 (79728) [START] Restarting adapter in 30 seconds
          2020-12-24 14:41:17.623  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:41:17.623  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:41:47.635  - info: host.iobroker instance system.adapter.xbox.0 started with pid 79775
          2020-12-24 14:41:49.940  - info: xbox.0 (79775) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:41:49.961  - info: xbox.0 (79775) [START] Starting REST server
          2020-12-24 14:41:55.033  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:41:55.033  - error: xbox.0 (79775) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:41:55.034  - error: xbox.0 (79775) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:41:55.222  - info: xbox.0 (79775) [END] REST server stopped
          2020-12-24 14:41:55.235  - info: xbox.0 (79775) [END] cleaned everything up...
          2020-12-24 14:41:55.240  - info: xbox.0 (79775) terminating
          2020-12-24 14:41:55.244  - info: xbox.0 (79775) Terminated (NO_ERROR): Without reason
          2020-12-24 14:41:55.520  - error: xbox.0 (79775) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [79806]
          INFO:     Shutting down
          INFO:     Finished server process [79806]
          2020-12-24 14:41:55.521  - error: xbox.0 (79775) [START] Restarting adapter in 30 seconds
          2020-12-24 14:41:55.779  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:41:55.780  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:42:25.790  - info: host.iobroker instance system.adapter.xbox.0 started with pid 79824
          2020-12-24 14:42:28.160  - info: xbox.0 (79824) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:42:28.194  - info: xbox.0 (79824) [START] Starting REST server
          2020-12-24 14:42:33.294  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:42:33.299  - error: xbox.0 (79824) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:42:33.300  - error: xbox.0 (79824) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:42:33.705  - info: xbox.0 (79824) [END] REST server stopped
          2020-12-24 14:42:33.717  - info: xbox.0 (79824) [END] cleaned everything up...
          2020-12-24 14:42:33.768  - info: xbox.0 (79824) terminating
          2020-12-24 14:42:33.769  - info: xbox.0 (79824) Terminated (NO_ERROR): Without reason
          2020-12-24 14:42:34.334  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:42:34.334  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:43:04.348  - info: host.iobroker instance system.adapter.xbox.0 started with pid 79873
          2020-12-24 14:43:06.789  - info: xbox.0 (79873) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:43:06.811  - info: xbox.0 (79873) [START] Starting REST server
          2020-12-24 14:43:11.865  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:43:11.866  - error: xbox.0 (79873) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:43:11.867  - error: xbox.0 (79873) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:43:12.038  - info: xbox.0 (79873) [END] REST server stopped
          2020-12-24 14:43:12.049  - info: xbox.0 (79873) [END] cleaned everything up...
          2020-12-24 14:43:12.052  - info: xbox.0 (79873) terminating
          2020-12-24 14:43:12.053  - info: xbox.0 (79873) Terminated (NO_ERROR): Without reason
          2020-12-24 14:43:12.375  - error: xbox.0 (79873) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [79902]
          INFO:     Shutting down
          INFO:     Finished server process [79902]
          2020-12-24 14:43:12.376  - error: xbox.0 (79873) [START] Restarting adapter in 30 seconds
          2020-12-24 14:43:12.586  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:43:12.587  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:43:42.601  - info: host.iobroker instance system.adapter.xbox.0 started with pid 79920
          2020-12-24 14:43:44.983  - info: xbox.0 (79920) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:43:45.006  - info: xbox.0 (79920) [START] Starting REST server
          2020-12-24 14:43:50.058  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:43:50.058  - error: xbox.0 (79920) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:43:50.059  - error: xbox.0 (79920) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:43:50.198  - info: xbox.0 (79920) [END] REST server stopped
          2020-12-24 14:43:50.222  - info: xbox.0 (79920) [END] cleaned everything up...
          2020-12-24 14:43:50.225  - info: xbox.0 (79920) terminating
          2020-12-24 14:43:50.226  - info: xbox.0 (79920) Terminated (NO_ERROR): Without reason
          2020-12-24 14:43:50.525  - error: xbox.0 (79920) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [79951]
          INFO:     Shutting down
          INFO:     Finished server process [79951]
          2020-12-24 14:43:50.525  - error: xbox.0 (79920) [START] Restarting adapter in 30 seconds
          2020-12-24 14:43:50.766  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:43:50.767  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:44:20.781  - info: host.iobroker instance system.adapter.xbox.0 started with pid 79969
          2020-12-24 14:44:22.909  - info: xbox.0 (79969) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:44:22.928  - info: xbox.0 (79969) [START] Starting REST server
          2020-12-24 14:44:27.998  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:44:27.999  - error: xbox.0 (79969) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:44:28.000  - error: xbox.0 (79969) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:44:28.160  - info: xbox.0 (79969) [END] REST server stopped
          2020-12-24 14:44:28.171  - info: xbox.0 (79969) [END] cleaned everything up...
          2020-12-24 14:44:28.216  - info: xbox.0 (79969) terminating
          2020-12-24 14:44:28.217  - info: xbox.0 (79969) Terminated (NO_ERROR): Without reason
          2020-12-24 14:44:28.477  - error: xbox.0 (79969) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80000]
          INFO:     Shutting down
          INFO:     Finished server process [80000]
          2020-12-24 14:44:28.477  - error: xbox.0 (79969) [START] Restarting adapter in 30 seconds
          2020-12-24 14:44:28.750  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:44:28.750  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:44:58.767  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80018
          2020-12-24 14:45:01.327  - info: xbox.0 (80018) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:45:01.363  - info: xbox.0 (80018) [START] Starting REST server
          2020-12-24 14:45:06.485  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:45:06.493  - error: xbox.0 (80018) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:45:06.493  - error: xbox.0 (80018) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:45:06.986  - info: xbox.0 (80018) [END] REST server stopped
          2020-12-24 14:45:06.998  - info: xbox.0 (80018) [END] cleaned everything up...
          2020-12-24 14:45:07.001  - info: xbox.0 (80018) terminating
          2020-12-24 14:45:07.002  - info: xbox.0 (80018) Terminated (NO_ERROR): Without reason
          2020-12-24 14:45:07.568  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:45:07.568  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:45:37.581  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80096
          2020-12-24 14:45:39.612  - info: xbox.0 (80096) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:45:39.636  - info: xbox.0 (80096) [START] Starting REST server
          2020-12-24 14:45:44.699  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:45:44.700  - error: xbox.0 (80096) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:45:44.701  - error: xbox.0 (80096) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:45:44.848  - info: xbox.0 (80096) [END] REST server stopped
          2020-12-24 14:45:44.859  - info: xbox.0 (80096) [END] cleaned everything up...
          2020-12-24 14:45:44.863  - info: xbox.0 (80096) terminating
          2020-12-24 14:45:44.864  - info: xbox.0 (80096) Terminated (NO_ERROR): Without reason
          2020-12-24 14:45:45.123  - error: xbox.0 (80096) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80127]
          INFO:     Shutting down
          INFO:     Finished server process [80127]
          2020-12-24 14:45:45.123  - error: xbox.0 (80096) [START] Restarting adapter in 30 seconds
          2020-12-24 14:45:45.396  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:45:45.396  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:46:15.406  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80146
          2020-12-24 14:46:17.595  - info: xbox.0 (80146) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:46:17.616  - info: xbox.0 (80146) [START] Starting REST server
          2020-12-24 14:46:22.743  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:46:22.743  - error: xbox.0 (80146) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:46:22.744  - error: xbox.0 (80146) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:46:22.894  - info: xbox.0 (80146) [END] REST server stopped
          2020-12-24 14:46:22.905  - info: xbox.0 (80146) [END] cleaned everything up...
          2020-12-24 14:46:22.948  - info: xbox.0 (80146) terminating
          2020-12-24 14:46:22.949  - info: xbox.0 (80146) Terminated (NO_ERROR): Without reason
          2020-12-24 14:46:23.265  - error: xbox.0 (80146) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80175]
          INFO:     Shutting down
          INFO:     Finished server process [80175]
          2020-12-24 14:46:23.265  - error: xbox.0 (80146) [START] Restarting adapter in 30 seconds
          2020-12-24 14:46:23.484  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:46:23.484  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:46:53.499  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80195
          2020-12-24 14:46:55.618  - info: xbox.0 (80195) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:46:55.637  - info: xbox.0 (80195) [START] Starting REST server
          2020-12-24 14:47:00.694  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:47:00.694  - error: xbox.0 (80195) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:47:00.695  - error: xbox.0 (80195) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:47:00.842  - info: xbox.0 (80195) [END] REST server stopped
          2020-12-24 14:47:00.856  - info: xbox.0 (80195) [END] cleaned everything up...
          2020-12-24 14:47:00.859  - info: xbox.0 (80195) terminating
          2020-12-24 14:47:00.860  - info: xbox.0 (80195) Terminated (NO_ERROR): Without reason
          2020-12-24 14:47:01.194  - error: xbox.0 (80195) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80224]
          INFO:     Shutting down
          INFO:     Finished server process [80224]
          2020-12-24 14:47:01.195  - error: xbox.0 (80195) [START] Restarting adapter in 30 seconds
          2020-12-24 14:47:01.395  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:47:01.395  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:47:31.407  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80241
          2020-12-24 14:47:34.982  - info: xbox.0 (80241) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:47:35.052  - info: xbox.0 (80241) [START] Starting REST server
          2020-12-24 14:47:40.131  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:47:40.131  - error: xbox.0 (80241) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:47:40.132  - error: xbox.0 (80241) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:47:40.288  - info: xbox.0 (80241) [END] REST server stopped
          2020-12-24 14:47:40.300  - info: xbox.0 (80241) [END] cleaned everything up...
          2020-12-24 14:47:40.303  - info: xbox.0 (80241) terminating
          2020-12-24 14:47:40.303  - info: xbox.0 (80241) Terminated (NO_ERROR): Without reason
          2020-12-24 14:47:40.555  - error: xbox.0 (80241) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80272]
          INFO:     Shutting down
          INFO:     Finished server process [80272]
          2020-12-24 14:47:40.555  - error: xbox.0 (80241) [START] Restarting adapter in 30 seconds
          2020-12-24 14:47:40.838  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:47:40.838  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:48:10.856  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80290
          2020-12-24 14:48:12.991  - info: xbox.0 (80290) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:48:13.009  - info: xbox.0 (80290) [START] Starting REST server
          2020-12-24 14:48:18.082  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:48:18.083  - error: xbox.0 (80290) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:48:18.084  - error: xbox.0 (80290) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:48:18.222  - info: xbox.0 (80290) [END] REST server stopped
          2020-12-24 14:48:18.232  - info: xbox.0 (80290) [END] cleaned everything up...
          2020-12-24 14:48:18.235  - info: xbox.0 (80290) terminating
          2020-12-24 14:48:18.236  - info: xbox.0 (80290) Terminated (NO_ERROR): Without reason
          2020-12-24 14:48:18.523  - error: xbox.0 (80290) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80321]
          INFO:     Shutting down
          INFO:     Finished server process [80321]
          2020-12-24 14:48:18.523  - error: xbox.0 (80290) [START] Restarting adapter in 30 seconds
          2020-12-24 14:48:18.767  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:48:18.768  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:48:48.781  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80339
          2020-12-24 14:48:51.045  - info: xbox.0 (80339) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:48:51.088  - info: xbox.0 (80339) [START] Starting REST server
          2020-12-24 14:48:56.138  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:48:56.139  - error: xbox.0 (80339) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:48:56.139  - error: xbox.0 (80339) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:48:56.285  - info: xbox.0 (80339) [END] REST server stopped
          2020-12-24 14:48:56.296  - info: xbox.0 (80339) [END] cleaned everything up...
          2020-12-24 14:48:56.340  - info: xbox.0 (80339) terminating
          2020-12-24 14:48:56.341  - info: xbox.0 (80339) Terminated (NO_ERROR): Without reason
          2020-12-24 14:48:56.567  - error: xbox.0 (80339) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80368]
          INFO:     Shutting down
          INFO:     Finished server process [80368]
          2020-12-24 14:48:56.567  - error: xbox.0 (80339) [START] Restarting adapter in 30 seconds
          2020-12-24 14:48:56.874  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:48:56.875  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:49:26.890  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80386
          2020-12-24 14:49:29.148  - info: xbox.0 (80386) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:49:29.168  - info: xbox.0 (80386) [START] Starting REST server
          2020-12-24 14:49:34.306  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:49:34.311  - error: xbox.0 (80386) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:49:34.312  - error: xbox.0 (80386) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:49:34.734  - info: xbox.0 (80386) [END] REST server stopped
          2020-12-24 14:49:34.745  - info: xbox.0 (80386) [END] cleaned everything up...
          2020-12-24 14:49:34.753  - info: xbox.0 (80386) terminating
          2020-12-24 14:49:34.755  - info: xbox.0 (80386) Terminated (NO_ERROR): Without reason
          2020-12-24 14:49:35.305  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:49:35.306  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:50:05.320  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80574
          2020-12-24 14:50:08.243  - info: xbox.0 (80574) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:50:08.269  - info: xbox.0 (80574) [START] Starting REST server
          2020-12-24 14:50:13.321  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:50:13.321  - error: xbox.0 (80574) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:50:13.322  - error: xbox.0 (80574) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:50:13.482  - info: xbox.0 (80574) [END] REST server stopped
          2020-12-24 14:50:13.500  - info: xbox.0 (80574) [END] cleaned everything up...
          2020-12-24 14:50:13.564  - info: xbox.0 (80574) terminating
          2020-12-24 14:50:13.565  - info: xbox.0 (80574) Terminated (NO_ERROR): Without reason
          2020-12-24 14:50:13.777  - error: xbox.0 (80574) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80605]
          INFO:     Shutting down
          INFO:     Finished server process [80605]
          2020-12-24 14:50:13.777  - error: xbox.0 (80574) [START] Restarting adapter in 30 seconds
          2020-12-24 14:50:14.100  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:50:14.100  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:50:44.112  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80634
          2020-12-24 14:50:46.194  - info: xbox.0 (80634) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:50:46.245  - info: xbox.0 (80634) [START] Starting REST server
          2020-12-24 14:50:51.312  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:50:51.312  - error: xbox.0 (80634) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:50:51.313  - error: xbox.0 (80634) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:50:51.462  - info: xbox.0 (80634) [END] REST server stopped
          2020-12-24 14:50:51.474  - info: xbox.0 (80634) [END] cleaned everything up...
          2020-12-24 14:50:51.477  - info: xbox.0 (80634) terminating
          2020-12-24 14:50:51.478  - info: xbox.0 (80634) Terminated (NO_ERROR): Without reason
          2020-12-24 14:50:51.714  - error: xbox.0 (80634) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80663]
          INFO:     Shutting down
          INFO:     Finished server process [80663]
          2020-12-24 14:50:51.714  - error: xbox.0 (80634) [START] Restarting adapter in 30 seconds
          2020-12-24 14:50:52.010  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:50:52.011  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:51:22.025  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80683
          2020-12-24 14:51:24.216  - info: xbox.0 (80683) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:51:24.237  - info: xbox.0 (80683) [START] Starting REST server
          2020-12-24 14:51:29.333  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:51:29.333  - error: xbox.0 (80683) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:51:29.334  - error: xbox.0 (80683) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:51:29.673  - info: xbox.0 (80683) [END] REST server stopped
          2020-12-24 14:51:30.116  - info: xbox.0 (80683) [END] cleaned everything up...
          2020-12-24 14:51:30.211  - info: xbox.0 (80683) terminating
          2020-12-24 14:51:30.212  - info: xbox.0 (80683) Terminated (NO_ERROR): Without reason
          2020-12-24 14:51:30.352  - error: xbox.0 (80683) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80714]
          INFO:     Shutting down
          INFO:     Finished server process [80714]
          2020-12-24 14:51:30.352  - error: xbox.0 (80683) [START] Restarting adapter in 30 seconds
          2020-12-24 14:51:31.037  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:51:31.037  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:52:01.054  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80733
          2020-12-24 14:52:03.549  - info: xbox.0 (80733) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:52:03.585  - info: xbox.0 (80733) [START] Starting REST server
          2020-12-24 14:52:08.641  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:52:08.642  - error: xbox.0 (80733) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:52:08.643  - error: xbox.0 (80733) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:52:08.807  - info: xbox.0 (80733) [END] REST server stopped
          2020-12-24 14:52:08.821  - info: xbox.0 (80733) [END] cleaned everything up...
          2020-12-24 14:52:08.867  - info: xbox.0 (80733) terminating
          2020-12-24 14:52:08.872  - info: xbox.0 (80733) Terminated (NO_ERROR): Without reason
          2020-12-24 14:52:09.127  - error: xbox.0 (80733) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80764]
          INFO:     Shutting down
          INFO:     Finished server process [80764]
          2020-12-24 14:52:09.128  - error: xbox.0 (80733) [START] Restarting adapter in 30 seconds
          2020-12-24 14:52:09.426  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:52:09.427  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:52:21.032  - info: host.iobroker "system.adapter.xbox.0" disabled
          2020-12-24 14:52:24.694  - info: host.iobroker "system.adapter.xbox.0" enabled
          2020-12-24 14:52:24.706  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80779
          2020-12-24 14:52:27.897  - info: xbox.0 (80779) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:52:27.919  - info: xbox.0 (80779) [START] Starting REST server
          2020-12-24 14:52:33.018  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:52:33.019  - error: xbox.0 (80779) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:52:33.020  - error: xbox.0 (80779) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:52:33.289  - info: xbox.0 (80779) [END] REST server stopped
          2020-12-24 14:52:33.302  - info: xbox.0 (80779) [END] cleaned everything up...
          2020-12-24 14:52:33.307  - info: xbox.0 (80779) terminating
          2020-12-24 14:52:33.308  - info: xbox.0 (80779) Terminated (NO_ERROR): Without reason
          2020-12-24 14:52:33.797  - error: xbox.0 (80779) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80810]
          INFO:     Shutting down
          INFO:     Finished server process [80810]
          2020-12-24 14:52:33.797  - error: xbox.0 (80779) [START] Restarting adapter in 30 seconds
          2020-12-24 14:52:33.873  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:52:33.874  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:53:03.892  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80828
          2020-12-24 14:53:06.465  - info: xbox.0 (80828) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:53:06.484  - info: xbox.0 (80828) [START] Starting REST server
          2020-12-24 14:53:11.584  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:53:11.585  - error: xbox.0 (80828) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:53:11.586  - error: xbox.0 (80828) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:53:11.745  - info: xbox.0 (80828) [END] REST server stopped
          2020-12-24 14:53:11.758  - info: xbox.0 (80828) [END] cleaned everything up...
          2020-12-24 14:53:11.803  - info: xbox.0 (80828) terminating
          2020-12-24 14:53:11.804  - info: xbox.0 (80828) Terminated (NO_ERROR): Without reason
          2020-12-24 14:53:12.055  - error: xbox.0 (80828) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80857]
          INFO:     Shutting down
          INFO:     Finished server process [80857]
          2020-12-24 14:53:12.055  - error: xbox.0 (80828) [START] Restarting adapter in 30 seconds
          2020-12-24 14:53:12.337  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:53:12.338  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:53:42.350  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80884
          2020-12-24 14:53:44.732  - info: xbox.0 (80884) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:53:44.769  - info: xbox.0 (80884) [START] Starting REST server
          2020-12-24 14:53:49.852  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:53:49.853  - error: xbox.0 (80884) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:53:49.854  - error: xbox.0 (80884) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:53:50.001  - info: xbox.0 (80884) [END] REST server stopped
          2020-12-24 14:53:50.015  - info: xbox.0 (80884) [END] cleaned everything up...
          2020-12-24 14:53:50.059  - info: xbox.0 (80884) terminating
          2020-12-24 14:53:50.060  - info: xbox.0 (80884) Terminated (NO_ERROR): Without reason
          2020-12-24 14:53:50.362  - error: xbox.0 (80884) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80915]
          INFO:     Shutting down
          INFO:     Finished server process [80915]
          2020-12-24 14:53:50.362  - error: xbox.0 (80884) [START] Restarting adapter in 30 seconds
          2020-12-24 14:53:50.593  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:53:50.593  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:54:20.650  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80933
          2020-12-24 14:54:22.900  - info: xbox.0 (80933) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:54:22.968  - info: xbox.0 (80933) [START] Starting REST server
          2020-12-24 14:54:28.037  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:54:28.038  - error: xbox.0 (80933) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:54:28.039  - error: xbox.0 (80933) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:54:28.232  - info: xbox.0 (80933) [END] REST server stopped
          2020-12-24 14:54:28.251  - info: xbox.0 (80933) [END] cleaned everything up...
          2020-12-24 14:54:28.295  - info: xbox.0 (80933) terminating
          2020-12-24 14:54:28.295  - info: xbox.0 (80933) Terminated (NO_ERROR): Without reason
          2020-12-24 14:54:28.576  - error: xbox.0 (80933) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [80964]
          INFO:     Shutting down
          INFO:     Finished server process [80964]
          2020-12-24 14:54:28.576  - error: xbox.0 (80933) [START] Restarting adapter in 30 seconds
          2020-12-24 14:54:28.832  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:54:28.833  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:54:58.843  - info: host.iobroker instance system.adapter.xbox.0 started with pid 80982
          2020-12-24 14:55:02.321  - info: xbox.0 (80982) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:55:02.356  - info: xbox.0 (80982) [START] Starting REST server
          2020-12-24 14:55:07.480  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:55:07.481  - error: xbox.0 (80982) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:55:07.482  - error: xbox.0 (80982) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:55:07.634  - info: xbox.0 (80982) [END] REST server stopped
          2020-12-24 14:55:07.654  - info: xbox.0 (80982) [END] cleaned everything up...
          2020-12-24 14:55:07.699  - info: xbox.0 (80982) terminating
          2020-12-24 14:55:07.700  - info: xbox.0 (80982) Terminated (NO_ERROR): Without reason
          2020-12-24 14:55:07.975  - error: xbox.0 (80982) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [81022]
          INFO:     Shutting down
          INFO:     Finished server process [81022]
          2020-12-24 14:55:07.975  - error: xbox.0 (80982) [START] Restarting adapter in 30 seconds
          2020-12-24 14:55:08.235  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:55:08.236  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:55:38.245  - info: host.iobroker instance system.adapter.xbox.0 started with pid 81044
          2020-12-24 14:55:40.488  - info: xbox.0 (81044) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:55:40.551  - info: xbox.0 (81044) [START] Starting REST server
          2020-12-24 14:55:45.602  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:55:45.603  - error: xbox.0 (81044) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:55:45.603  - error: xbox.0 (81044) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:55:45.751  - info: xbox.0 (81044) [END] REST server stopped
          2020-12-24 14:55:45.764  - info: xbox.0 (81044) [END] cleaned everything up...
          2020-12-24 14:55:45.768  - info: xbox.0 (81044) terminating
          2020-12-24 14:55:45.769  - info: xbox.0 (81044) Terminated (NO_ERROR): Without reason
          2020-12-24 14:55:46.089  - error: xbox.0 (81044) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [81075]
          INFO:     Shutting down
          INFO:     Finished server process [81075]
          2020-12-24 14:55:46.089  - error: xbox.0 (81044) [START] Restarting adapter in 30 seconds
          2020-12-24 14:55:46.304  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:55:46.304  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:56:16.322  - info: host.iobroker instance system.adapter.xbox.0 started with pid 81095
          2020-12-24 14:56:18.816  - info: xbox.0 (81095) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:56:18.842  - info: xbox.0 (81095) [START] Starting REST server
          2020-12-24 14:56:23.959  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:56:23.959  - error: xbox.0 (81095) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:56:23.960  - error: xbox.0 (81095) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:56:24.126  - info: xbox.0 (81095) [END] REST server stopped
          2020-12-24 14:56:24.139  - info: xbox.0 (81095) [END] cleaned everything up...
          2020-12-24 14:56:24.183  - info: xbox.0 (81095) terminating
          2020-12-24 14:56:24.185  - info: xbox.0 (81095) Terminated (NO_ERROR): Without reason
          2020-12-24 14:56:24.527  - error: xbox.0 (81095) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [81126]
          INFO:     Shutting down
          INFO:     Finished server process [81126]
          2020-12-24 14:56:24.527  - error: xbox.0 (81095) [START] Restarting adapter in 30 seconds
          2020-12-24 14:56:24.718  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:56:24.719  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:56:54.732  - info: host.iobroker instance system.adapter.xbox.0 started with pid 81144
          2020-12-24 14:56:56.878  - info: xbox.0 (81144) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:56:56.900  - info: xbox.0 (81144) [START] Starting REST server
          2020-12-24 14:57:01.955  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:57:01.955  - error: xbox.0 (81144) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:57:01.956  - error: xbox.0 (81144) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:57:02.105  - info: xbox.0 (81144) [END] REST server stopped
          2020-12-24 14:57:02.121  - info: xbox.0 (81144) [END] cleaned everything up...
          2020-12-24 14:57:02.167  - info: xbox.0 (81144) terminating
          2020-12-24 14:57:02.168  - info: xbox.0 (81144) Terminated (NO_ERROR): Without reason
          2020-12-24 14:57:02.484  - error: xbox.0 (81144) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [81173]
          INFO:     Shutting down
          INFO:     Finished server process [81173]
          2020-12-24 14:57:02.484  - error: xbox.0 (81144) [START] Restarting adapter in 30 seconds
          2020-12-24 14:57:02.707  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:57:02.707  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          2020-12-24 14:57:32.728  - info: host.iobroker instance system.adapter.xbox.0 started with pid 81192
          2020-12-24 14:57:36.420  - info: xbox.0 (81192) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.23.0, js-controller: 3.1.6
          2020-12-24 14:57:36.465  - info: xbox.0 (81192) [START] Starting REST server
          2020-12-24 14:57:41.540  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2020-12-24 14:57:41.541  - error: xbox.0 (81192) unhandled promise rejection: Cannot read property 'includes' of undefined
          2020-12-24 14:57:41.541  - error: xbox.0 (81192) TypeError: Cannot read property 'includes' of undefined
          2020-12-24 14:57:41.702  - info: xbox.0 (81192) [END] REST server stopped
          2020-12-24 14:57:41.715  - info: xbox.0 (81192) [END] cleaned everything up...
          2020-12-24 14:57:41.719  - info: xbox.0 (81192) terminating
          2020-12-24 14:57:41.720  - info: xbox.0 (81192) Terminated (NO_ERROR): Without reason
          2020-12-24 14:57:42.039  - error: xbox.0 (81192) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          INFO:     Started server process [81223]
          INFO:     Shutting down
          INFO:     Finished server process [81223]
          2020-12-24 14:57:42.040  - error: xbox.0 (81192) [START] Restarting adapter in 30 seconds
          2020-12-24 14:57:42.259  - info: host.iobroker instance system.adapter.xbox.0 terminated with code 0 (NO_ERROR)
          2020-12-24 14:57:42.259  - info: host.iobroker Restart adapter system.adapter.xbox.0 because enabled
          Ubuntu 20.04.1 LTS
          Davor war python 2.7 aktiv, das Modul braucht jedoch 3.7 oder höher. Was müsste ich hier ändern?
          Thomas Braun foxriver76 2 Replies Last reply Reply Quote 0
            @TWART016
            apt policy python3
              Schnutexxl @foxriver76 last edited by
              @foxriver76 sorry für das große delay. Frohe Weihnacht:
              # python -V
              Python 3.7.3
                @Thomas-Braun
                 apt policy python3
                python3:
                  Installiert:           3.8.2-0ubuntu2
                  Installationskandidat: 3.8.2-0ubuntu2
                  Versionstabelle:
                 *** 3.8.2-0ubuntu2 500
                        500 http://de.archive.ubuntu.com/ubuntu focal/main amd64 Packages
                        100 /var/lib/dpkg/status
                • foxriver76
                  foxriver76 Developer @TWART016 last edited by
                  @TWART016 habe eben die 0.7.2 als stable deklariert, da wine Neuinstallation einer 0.6.x vermutlich massig Probleme aufgrund der kaputten Dep bringt, bitte diese probieren.
                  S T 2 Replies Last reply Reply Quote 0
                    @foxriver76 habe nun 0.7.3 installiert, ging nur manuell und nicht über den iobroker admin, Rechtekonflikt.
                    Nach dem Starten der Instanz folgende Fehlermeldung:
                    xbox.0	2020-12-26 12:17:31.151	info	(9520) Terminated (NO_ERROR): Without reason
                    xbox.0	2020-12-26 12:17:31.149	info	(9520) terminating
                    xbox.0	2020-12-26 12:17:31.103	info	(9520) [END] cleaned everything up...
                    xbox.0	2020-12-26 12:17:31.069	info	(9520) [END] Could not stop REST server:
                    xbox.0	2020-12-26 12:17:31.018	warn	(9520) Restart initiated
                    xbox.0	2020-12-26 12:17:31.015	error	(9520) [START] Restarting adapter
                    xbox.0	2020-12-26 12:17:31.014	error	(9520) [START] Failed starting REST server: Process exited with code 1: Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server",
                    xbox.0	2020-12-26 12:17:29.012	info	(9520) [START] Starting REST server
                    xbox.0	2020-12-26 12:17:28.984	info	(9520) starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.20.0, js-controller: 3.1.6
                    xbox.0	2020-12-26 12:16:54.992	info	(8650) Terminated (NO_ERROR): Without reason
                    xbox.0	2020-12-26 12:16:54.990	info	(8650) terminating
                    xbox.0	2020-12-26 12:16:54.944	info	(8650) [END] cleaned everything up...
                    xbox.0	2020-12-26 12:16:54.919	info	(8650) [END] Could not stop REST server:
                    xbox.0	2020-12-26 12:16:54.875	warn	(8650) Restart initiated
                    xbox.0	2020-12-26 12:16:54.875	error	(8650) [START] Restarting adapter
                    xbox.0	2020-12-26 12:16:54.874	error	ModuleNotFoundError: No module named 'requests'
                    xbox.0	2020-12-26 12:16:54.874	error	import requests
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/stump/manager.py", line 6, in <module>
                    xbox.0	2020-12-26 12:16:54.874	error	from xbox.stump.manager import StumpManager
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/sg/console.py", line 49, in <module>
                    xbox.0	2020-12-26 12:16:54.874	error	from xbox.sg.console import Console
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/rest/consolewrap.py", line 5, in <module>
                    xbox.0	2020-12-26 12:16:54.874	error	from .consolewrap import ConsoleWrap
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/rest/singletons.py", line 6, in <module>
                    xbox.0	2020-12-26 12:16:54.874	error	from . import singletons
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/rest/app.py", line 5, in <module>
                    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
                    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap_external>", line 728, in exec_module
                    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
                    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
                    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap>", line 983, in _find_and_load
                    xbox.0	2020-12-26 12:16:54.874	error	File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
                    xbox.0	2020-12-26 12:16:54.874	error	return _bootstrap._gcd_import(name[level:], package, level)
                    xbox.0	2020-12-26 12:16:54.874	error	File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
                    xbox.0	2020-12-26 12:16:54.874	error	module = importlib.import_module(module_str)
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/importer.py", line 20, in import_from_string
                    xbox.0	2020-12-26 12:16:54.874	error	raise exc from None
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/importer.py", line 23, in import_from_string
                    xbox.0	2020-12-26 12:16:54.874	error	self.loaded_app = import_from_string(self.app)
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/config.py", line 328, in load
                    xbox.0	2020-12-26 12:16:54.874	error	config.load()
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/main.py", line 426, in serve
                    xbox.0	2020-12-26 12:16:54.874	error	return future.result()
                    xbox.0	2020-12-26 12:16:54.874	error	File "/usr/lib/python3.7/asyncio/base_events.py", line 584, in run_until_complete
                    xbox.0	2020-12-26 12:16:54.874	error	loop.run_until_complete(self.serve(sockets=sockets))
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/main.py", line 419, in run
                    xbox.0	2020-12-26 12:16:54.874	error	server.run()
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/uvicorn/main.py", line 391, in run
                    xbox.0	2020-12-26 12:16:54.874	error	uvicorn.run('xbox.rest.app:app', host=args.host, port=args.port, reload=args.reload)
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/scripts/rest_server.py", line 19, in main
                    xbox.0	2020-12-26 12:16:54.874	error	sys.exit(main())
                    xbox.0	2020-12-26 12:16:54.874	error	File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 8, in <module>
                    xbox.0	2020-12-26 12:16:54.874	error	(8650) [START] Failed starting REST server: Process exited with code 1: Traceback (most recent call last):
                    xbox.0	2020-12-26 12:16:52.777	info	(8650) [START] Starting REST server
                    xbox.0	2020-12-26 12:16:52.747	info	(8650) starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.20.0, js-controller: 3.1.6
                    xbox.0	2020-12-26 12:16:44.446	info	(8374) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    xbox.0	2020-12-26 12:16:44.445	info	(8374) terminating
                    xbox.0	2020-12-26 12:16:44.444	info	(8374) [END] cleaned everything up...
                    xbox.0	2020-12-26 12:16:44.427	info	(8374) [END] Could not stop REST server:
                    xbox.0	2020-12-26 12:16:44.401	info	(8374) Got terminate signal TERMINATE_YOURSELF
                    xbox.0	2020-12-26 12:16:39.364	warn	(8374) Please provide the ip address and the Live ID of your console
                    xbox.0	2020-12-26 12:16:39.316	info	(8374) starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.20.0, js-controller: 3.1.6
                    Wobei nun nur noch die kurzen Fehlermeldungen ausgegeben werden:
                    xbox.0	2020-12-26 12:18:08.220	info	(10273) Terminated (NO_ERROR): Without reason
                    xbox.0	2020-12-26 12:18:08.219	info	(10273) terminating
                    xbox.0	2020-12-26 12:18:08.173	info	(10273) [END] cleaned everything up...
                    xbox.0	2020-12-26 12:18:08.119	info	(10273) [END] Could not stop REST server:
                    xbox.0	2020-12-26 12:18:08.085	warn	(10273) Restart initiated
                    xbox.0	2020-12-26 12:18:08.084	error	(10273) [START] Restarting adapter
                    xbox.0	2020-12-26 12:18:08.083	error	(10273) [START] Failed starting REST server: Process exited with code 1: Traceback (most recent call last): File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server"
                    xbox.0	2020-12-26 12:18:05.381	info	(10273) [START] Starting REST server
                    xbox.0	2020-12-26 12:18:05.318	info	(10273) starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.20.0, js-controller: 3.1.6
                      Thomas Braun Most Active @Schnutexxl last edited by
                      @Schnutexxl @foxriver76
                      Muss das nicht request heißen?
                      • foxriver76
                        foxriver76 Developer @Schnutexxl last edited by foxriver76
                        @Schnutexxl vermutlich haben die dependency Entwickler eine Abhängigkeit vergessen:
                        python3.7 -m pip install requests
                        Oder je nachdem wie dein Interpreter heißt.
                        S R 2 Replies Last reply Reply Quote 0
                          TWART016 @foxriver76 last edited by
                          @foxriver76 ich konnte das Update ohne Probleme installieren.
                          Jetzt ist alles verbunden. Besten Dank.
                            @foxriver76 sagte in XBox-Adapter Fehler:
                            SUPER!!!! 😀 Läuft nun endlich. Besten Dank für den schnellen support.
                            Ich stand schon immer mit python3 auf dem Kriegsfuß.
                            Besten Dank 👍
                              RkcCorian @foxriver76 last edited by Negalein
                              @foxriver76 Hallo foxdriver76! Ich hoffe hier richtig zu sein, ich bin relativ neu in der ioBroker-Welt. Ich versuche den Xbox Adapter zu nutzen, hab jedoch leider Probleme. Meine Konfig ist wie folgt:
                              • Synology Docker buanet/iobroker:v5.1.0
                              • phyton 3.7.3-1
                              • Xbox Adapter 0.7.3
                              • Xbox Adapter Konfig: Xbox Live ID und IP korrekt ausgefüllt, Authentifizierung auf Xbox Live ist ausgeschaltet
                              Folgende Probleme:
                              1. Wenn ich die Authentifizierung einschalte (Haken setzen) kommt das Feld für Benutzername und Passwort nicht
                              2. Viel schlimmer/wichtiger: Ich sehe im Log lauter Fehler. Auch mit einem komplett frischen und leeren Container sind die gleichen Fehler vorhanden, daher vermute ich keine Querbeziehungen zu anderen Adaptern. Die ersten 3 Fehler im Log lauten:
                              xbox.0	2021-02-24 22:13:47.665	error	(2463) [START] Failed starting REST server: Process exited with code 1: Traceback (most recent call last):
                              xbox.0	2021-02-24 22:13:47.665	error	File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 8, in <module>
                              xbox.0	2021-02-24 22:13:47.665	error	sys.exit(main())
                              Kannst Du /Sie mir helfen? Ich würde mich sehr freuen. Falls ich hier falsch bin bitte um Rückmeldung, wohin ich mich "richtigerweise" wenden kann. Genauso, wenn ich weitere Informationen schicken soll. Bin halt wie gesagt recht neu bei ioBroker.
                              Vielen Dank im Voraus!!!
                              Markus
                              • foxriver76
                                foxriver76 Developer @RkcCorian last edited by
                                @markus-2 sagte in XBox-Adapter Fehler:
                                Auth mit Nutzername/Passwort ist leider aktuell nicht mehr möglich und muss manuell über Link im Log/Admin gemacht werden, taucht aber nur auf wenn der Adapter korrekt läuft. Ich schätze beim Install hat was nicht ganz geklappt. Sind die Pakete build-essential libssl-dev libffi-dev python3-dev installiert?
                                  RkcCorian @foxriver76 last edited by RkcCorian
                                  @foxriver76 "Sind die Pakete build-essential libssl-dev libffi-dev python3-dev installiert?" => Woran/Wie kann ich das sehen?
                                  • foxriver76
                                    @markus-2 apt policy build-essential libssl-dev libffi-dev python3-dev dann sagt er dir ob es installiert ist, falls unsicher gerne Ausgabe hier posten.
                                      Folgende steht in der Console (terminal adapter). Ich interpretiere mal, dass python nicht (richtig?) installiert ist?!
                                      /opt/iobroker$ apt policy build-essential libssl-dev libffi-dev python3-dev
                                      WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                                      build-essential:
                                        Installiert:           12.6
                                        Installationskandidat: 12.6
                                        Versionstabelle:
                                      *** 12.6 100
                                      libffi-dev:
                                        Installiert:           3.2.1-9
                                        Installationskandidat: 3.2.1-9
                                        Versionstabelle:
                                      *** 3.2.1-9 100
                                      python3-dev:
                                        Installiert:           (keine)
                                        Installationskandidat: (keine)
                                        Versionstabelle:
                                      /opt/iobroker$
                                        Thomas Braun Most Active @RkcCorian last edited by
                                        libssl-dev python3-dev
                                        Das fehlt vermutlich.
                                        sudo apt update
                                        sudo apt install libssl-dev python3-dev
                                          RkcCorian @Thomas Braun last edited by Negalein
                                          @thomas-braun sagte in XBox-Adapter Fehler:
                                          sudo apt update
                                          Folgende passiert wenn ich es in die Console eingebe...
                                          /opt/iobroker$ sudo apt update
                                          sudo: Hostname ioBroker_v5.1.0 kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
                                          sudo: Die Audit-Nachricht kann nicht gesendet werden: Die Operation ist nicht erlaubt
                                          OK:1 http://security.debian.org/debian-security buster/updates InRelease
                                          OK:2 http://deb.debian.org/debian buster InRelease
                                          OK:3 http://deb.debian.org/debian buster-updates InRelease
                                          OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                                          Paketlisten werden gelesen...
                                          Abhängigkeitsbaum wird aufgebaut....
                                          Statusinformationen werden eingelesen....
                                          Aktualisierung für 18 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                          /opt/iobroker$ sudo apt install libssl-dev phyton3-dev
                                          E: Paket phyton3-dev kann nicht gefunden werden.
                                          /opt/iobroker$
                                            Thomas Braun Most Active @RkcCorian last edited by Thomas Braun
                                            @markus-2
                                            Bitte Text in </> CodeTags packen. Danke.
                                            Und bitte vollständig posten, inkl. login prompt.
                                            xbox
                                            7246
