    4. Probleme mit CUL 868
    • a200
      a200 last edited by
      Hallo mein CUL startet nicht.
      host-minime	2016-10-31 19:50:34.986	info	Restart adapter system.adapter.cul.0 because enabled
      host-minime	2016-10-31 19:50:34.985	error	instance system.adapter.cul.0 terminated with code 0 (OK)
      cul-0	2016-10-31 19:50:34.958	info	terminating
      TypeError:	2016-10-31 19:50:34.916	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      TypeError:	2016-10-31 19:50:34.916	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      TypeError:	2016-10-31 19:50:34.916	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:394:29)
      TypeError:	2016-10-31 19:50:34.916	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3004:14)
      TypeError:	2016-10-31 19:50:34.916	error	at Adapter.emit (events.js:166:7)
      TypeError:	2016-10-31 19:50:34.916	error	at emitNone (events.js:67:13)
      TypeError:	2016-10-31 19:50:34.916	error	at Adapter. (/opt/iobroker/node_modules/iobroker.cul/cul.js:32:5)
      TypeError:	2016-10-31 19:50:34.916	error	at main (/opt/iobroker/node_modules/iobroker.cul/cul.js:42:11)
      TypeError:	2016-10-31 19:50:34.916	error	at new Cul (/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/cul.js:89:22)
      TypeError:	2016-10-31 19:50:34.916	error	at new SerialPort (/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/node_modules/serialport/lib/serialport.js:101:11)
      TypeError:	2016-10-31 19:50:34.916	error	Invalid "baudRate" must be a number got: 9600
      uncaught	2016-10-31 19:50:34.907	error	exception: Invalid "baudRate" must be a number got: 9600
      cul-0	2016-10-31 19:50:34.874	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.cul
      host-minime	2016-10-31 19:50:33.437	info	instance system.adapter.cul.0 started with pid 13772
      host-minime	2016-10-31 19:50:33.422	info	object change system.adapter.cul.0
      Meine Einstellungen:
      "serialport": "/dev/ttyACM0", "baudrate": 9600, "mode": "SlowRF", "parse": true, "init": true, "coc": false, "rssi": true
      unter FHEM geht das Ding:
      CMDS             BbCFiAZNkGMKUYRTVWXefmLltux
      CUL_0_MSGCNT        78
      CUL_0_TIME             2016-10-31 19:08:32
      Clients                     :FS20:FHT.*:KS300:USF1000:BS:HMS: :CUL_EM:CUL_WS:CUL_FHTTK:CUL_HOERMANN:
                                    :ESA2000:CUL_IR:CUL_TX:Revolt:IT:UNIRoll:SOMFY:
                                    :STACKABLE_CC:CUL_RFR::CUL_TCM97001:CUL_REDIRECT:
      DEF	                      /dev/ttyACM0@9600 1034
      DeviceName              /dev/ttyACM0@9600
      FD                          11
      FHTID                     1034
      NAME                      CUL_0
      NR                          20
      PARTIAL
      RAWMSG                  HCF0420862151F4
      RSSI                        -80
      STATE                      Initialized
      TYPE                        CUL
      VERSION                   V 1.66 CUL868
      initString                   X21
      Wer kennt sich mit CUL aus?
      Danke im Voraus,
      a200.
      • Bluefox
        Bluefox last edited by
        Kannst du vom git ausprobieren?
        • a200
          a200 last edited by
          @Bluefox:
          Kannst du vom git ausprobieren? `
          Heute Abend. Hier in Hessen haben wir heute keinen Feiertag! ;(
          • a200
            a200 last edited by
            @Bluefox:
            yup! jetzt gehts. Danke.
              Super, dass der Adapter jetzt auch läuft.
              Habe zwar noch keine Ahnung was und vor allem wie damit arbeiten, aber er läuft!
              Ich musste auch als Port eingeben:
              ttyACM0
              Dann kam die Fehlermeldung:
              cul.0	2016-11-01 19:38:05.583	info	List of port: [{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS3"}]
              cul.0	2016-11-01 19:37:30.772	error	Cannot open port: Error: Error: No such file or directory, cannot open /dev/ttyACM0
              Nach einem restart der Instanz lief er aber.
              Rainer
              • a200
                a200 last edited by
                ich sehe zwar die zustände der CUL, aber unter Objekte kann ich sie nicht sehen.
                was läuft da falsch?
                • a200
                  a200 last edited by
                  entwarnung. im experten-modus sind die werte des CULs sichtbar.
                  • eric2905
                    eric2905 last edited by
                    @a200:
                    entwarnung. im experten-modus sind die werte des CULs sichtbar. `
                    Vorsicht, das sind die Werte des Adapters selber - keine "Empfangsdaten".
                    Gruß,
                    Eric
                    • a200
                      a200 last edited by
                      Ja, das sehe ich auch so. Denn bis jetzt wurden keine Geräte gefunden.
                      • Dutchman
                        @a200:
                        Ja, das sehe ich auch so. Denn bis jetzt wurden keine Geräte gefunden. `
                        mal zur neuier und fehler suche, was fuer geraete moechtest du den mit dem CUL 868 betreiben ?
                        • a200
                          a200 last edited by
                          @Dutchman:
                          mal zur neuier und fehler suche, was fuer geraete moechtest du den mit dem CUL 868 betreiben ? `
                          Thermometer. der wird in fhem problemlos gefunden. ich wollte mir den umweg und die ressourcen über fhem sparen.
                          • Bluefox
                            Kannst du paar Logs besorgen? MIT debug Level.
                            • a200
                              a200 last edited by
                              Kann ich gerne machen. Allerdings erst morgen.
                              Danke und LG
                              • a200
                                a200 last edited by
                                Das ist alles, was bei mir im Log zu CUL steht:
                                cul.0	2016-11-02 18:59:35.608	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-02 18:59:35.479	debug	statesDB connected
                                cul.0	2016-11-02 18:59:35.453	debug	objectDB connected
                                cul.0	2016-11-02 18:58:51.451	info	terminating
                                cul.0	2016-11-02 18:58:43.608	error	Cannot open port: Port is not selected
                                cul.0	2016-11-02 18:58:43.592	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-02 18:47:52.299	info	terminating
                                cul.0	2016-11-02 15:34:53.954	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-02 15:19:14.938	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-02 14:16:38.777	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-02 14:00:59.691	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-02 13:50:33.703	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-02 13:40:07.647	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-02 13:29:41.649	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-02 12:53:10.482	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-02 12:32:18.414	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-02 12:16:39.539	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                Irgendwelche Vorschläge Bluefox?
                                • a200
                                  a200 last edited by
                                  schon wieder gabs im Log eine Überraschung:
                                  cul.0	2016-11-03 18:58:12.679	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                  cul.0	2016-11-03 18:58:12.580	debug	statesDB connected
                                  cul.0	2016-11-03 18:58:12.548	debug	objectDB connected
                                  host.minime	2016-11-03 18:58:11.262	info	instance system.adapter.cul.0 started with pid 17467
                                  host.minime	2016-11-03 18:57:41.231	info	Restart adapter system.adapter.cul.0 because enabled
                                  host.minime	2016-11-03 18:57:41.226	error	instance system.adapter.cul.0 terminated with code 0 (OK)
                                  ReferenceError:	2016-11-03 18:57:41.186	error	at FSReqWrap.wrapper [as oncomplete] (fs.js:576:17)
                                  ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort. (/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/lib/serialport.js:306:7)
                                  ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort. (/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/lib/serialport.js:293:14)
                                  ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort._emitData (/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/lib/serialport.js:313:18)
                                  ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort.module.exports.raw (/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/lib/parsers.js:7:13)
                                  ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort.emit (events.js:169:7)
                                  ReferenceError:	2016-11-03 18:57:41.186	error	at emitOne (events.js:77:13)
                                  ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort. (/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/cul.js:128:70)
                                  ReferenceError:	2016-11-03 18:57:41.186	error	at parse (/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/cul.js:183:43)
                                  ReferenceError:	2016-11-03 18:57:41.186	error	at Object.module.exports.parse (/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/lib/hms.js:47:26)
                                  ReferenceError:	2016-11-03 18:57:41.186	error	data is not defined
                                  uncaught	2016-11-03 18:57:41.180	error	exception: data is not defined
                                  • Bluefox
                                    @a200:
                                    Da ist jetzt hobbyquaker dran.
                                    Du kannst aber auch ausprobieren wenn du die Datei__/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/lib/hms.js__ bei sich wie folgt änderst:
                                    https://github.com/hobbyquaker/cul/pull/4/files
                                    GermanBluefox created this issue in hobbyquaker/cul
                                    closed Small fix #4
                                    • a200
                                      a200 last edited by
                                      nach der installation:
                                      ` > root@minime:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.cul/tarball/master –production
                                      serialport@4.0.4 install /opt/iobroker/node_modules/iobroker.cul/node_modules/serialport
                                      node-pre-gyp install --fallback-to-build
                                      node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz
                                      node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.4 and node@4.6.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                                      make: Entering directory '/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/build'
                                      CXX(target) Release/obj.target/serialport/src/serialport.o
                                      CXX(target) Release/obj.target/serialport/src/serialport_unix.o
                                      CXX(target) Release/obj.target/serialport/src/serialport_poller.o
                                      SOLINK_MODULE(target) Release/obj.target/serialport.node
                                      COPY Release/serialport.node
                                      make: Leaving directory '/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/build'
                                      iobroker.cul@0.1.0 node_modules/iobroker.cul
                                      ├── cul@0.2.1
                                      └── serialport@4.0.4 (bindings@1.2.1, commander@2.9.0, debug@2.2.0, lie@3.1.0, nan@2.4.0, object.assign@4.0.4) `
                                      ist mein lib verzeichnis fast leer:
                                      root@minime:/opt/iobroker/node_modules/iobroker.cul/lib# ls -la
                                      total 12
                                      drwxr-xr-x 2 root root 4096 Nov  3 20:20 .
                                      drwxr-xr-x 6 root root 4096 Nov  3 20:20 ..
                                      -rw-r--r-- 1 root root 2577 Nov  1 09:22 utils.js
                                      was mache ich falsch, bei der installation? muss ich vorher das cul paket https://github.com/hobbyquaker/cul installieren?
                                      • Bluefox
                                        @a200:
                                        ├── cul@0.2.1
                                        total 12
                                        was mache ich falsch, bei der installation? muss ich vorher das cul paket https://github.com/hobbyquaker/cul installieren? `
                                        Lasse es. Hobbyquaker hat schon erledigt. KannSt du noch mal vom gut einfach updaten?
                                        2752
