    4. "vis-google-fonts" benötigt?
    UNSOLVED "vis-google-fonts" benötigt?
      Supermicha last edited by Supermicha
      micha@ioBroker:/opt/iobroker$ iobroker del vis-google-fonts
      Delete adapter "vis-google-fonts"
      host.ioBroker Counted 1 meta of vis-google-fonts
      host.ioBroker Counted 1 adapter for vis-google-fonts
      host.ioBroker Counted 2 states (system.adapter.vis-google-fonts.*) from states
      host.ioBroker file vis-google-fonts.admin deleted
      host.ioBroker object vis-google-fonts.admin deleted
      host.ioBroker Deleting 2 object(s).
      host.ioBroker Deleting 2 state(s).
      npm uninstall iobroker.vis-google-fonts --error --prefix "/opt/iobroker" (System call)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN babel-eslint@10.1.0 requires a peer of eslint@>= 4.12.1 but none is installed. You must install peer dependencies yourself.
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      Adapter "system.adapter.vis.0" restarted.
      ich starte jetz neu
        Thomas Braun Most Active @Supermicha last edited by
        @Supermicha
        Da scheint mir aber ich noch anderes schief zu sein. Die peer dependencies sollten mMn auch installiert sein/werden.
          @Thomas-Braun kein Plan...
          hier jetzt der neuinstall
          micha@ioBroker:~$ iobroker install vis-google-fonts
          NPM version: 6.14.8
          npm install iobroker.vis-google-fonts@0.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
          host.ioBroker install adapter vis-google-fonts
          upload [1] vis-google-fonts.admin /opt/iobroker/node_modules/iobroker.vis-google-fonts/admin/vis-google-fonts.png vis-google-fonts.png image/png
          upload [0] vis-google-fonts.admin /opt/iobroker/node_modules/iobroker.vis-google-fonts/admin/index.html index.html text/html
          host.ioBroker object system.adapter.vis-google-fonts created/updated
            Homoran Global Moderator Administrators @Supermicha last edited by
            @Supermicha sagte in "vis-google-fonts" benötigt?:
            ich starte jetz neu
            da stimmt bei deiner gogglefonts Installation (oder gar noch tiefer) etwas gar nicht.
            Da können dependencies nicht aufgelöst werden, dann konnten die auch nicht installiert werden
              Installfixer mal drüberlaufen lassen?
                Homoran Global Moderator Administrators @Supermicha last edited by Homoran
                schadet nie, repariert aber dein deps nicht.
                aber klappt es denn immer noch nicht?
                  nein, es kommt noch die gleiche Fehlermeldung
                    Nachtrag:
                    Installfixer laufen lassen, wie du erwartet hast, keine Änderung.
                      @Supermicha
                      Ich hab zwar keinen Plan von vis, aber muss man die entsprechenden Fonts nicht separat erstmal auf das System holen?
                      Ich kann mir nicht vorstellen, dass der Adapter das tut.
                        @Thomas-Braun sagte in "vis-google-fonts" benötigt?:
                        doch! Das soll er
                          hatte es auch schon mal mit
                          npm install vis-google-fonts
                          versucht, brachte aber auch nix
                            hoffentlich vorher in /opt/iobroker gewechselt
                              @Homoran
                              ja selbstverständlich
                              Leute, ich bin mal off und muss zu nem Geburtstag.
                              Hätte nicht gedacht, das hier Montag Mittag so viele Experten online sind.... 🙂
                              Ich bin späterer Nachmittag wieder da...
                              Schon mal danke bis hierher.
                              • Gargano
                                Gargano @Supermicha last edited by Gargano
                                @Supermicha hätte ich auch gedacht, aber scheinbar bin ich der einzige mit dem Problem?
                                Bist Du nicht, bei mir kann ich Material Design Widgets nicht über die Website updaten.
                                Beim Update Icon kommt 'Keine Versionsinfo für vis-google-fonts'. Nach Installieren von vis-google-fonts ging es dann über die Website upzudaten.
                                  Homoran Global Moderator Administrators @Gargano last edited by
                                  @Gargano sagte in "vis-google-fonts" benötigt?:
                                  leider hat @Supermicha die googlefonts installiert
                                    Speedy012 @Homoran last edited by
                                    Ich hatte die Fehlermeldung auch, nach installation von "vis-google-fonts" scheint diese weg zu sein.
                                    • Scrounger
                                      Scrounger Developer @Supermicha last edited by
                                      @Supermicha @Gargano
                                      Bin dran den Fehler zu finden. Bitte postet im folgendem Ticket
                                      https://github.com/Scrounger/ioBroker.vis-materialdesign/issues/135
                                      welche Admin Version ihr installiert habt.
                                      fu-zhou created this issue in Scrounger/ioBroker.vis-materialdesign
                                      open Lässt sich nicht auf 0.4.1 aktualisieren - "keine versions info für vis google fonts" #135
                                        Erledigt.
                                        (Admin Version ist 4.1.12)
                                          liv-in-sky last edited by liv-in-sky
                                          na super - habe mir gedacht ich mach mal auch das update des adapters - auch bei mir nun der selbe fehler
                                          dann wartn wir mal auf das update
                                            fastfoot @liv-in-sky last edited by
                                            @liv-in-sky sagte in "vis-google-fonts" benötigt?:
                                            du kannst die vis-google-fonts auch aus dem Adapter-Tab installieren, dann klappts
                                            vis-google-fonts
                                            2594
