    4. Test Adapter fb-checkpresence v1.1.x
      paul.honka @afuerhoff last edited by
      @afuerhoff
      Hallo, habe seit gestern auf meinem PI4 folgende Fehlermeldung:
      fb-checkpresence.0	2020-12-28 09:25:29.626	info	(28553) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      fb-checkpresence.0	2020-12-28 09:25:29.625	info	(28553) terminating
      fb-checkpresence.0	2020-12-28 09:25:29.624	info	(28553) cleaned everything up ...
      fb-checkpresence.0	2020-12-28 09:25:29.622	info	(28553) Got terminate signal TERMINATE_YOURSELF
      fb-checkpresence.0	2020-12-28 09:25:29.539	error	(28553) createFbDeviceObjects -> can't read devices from fritzbox! Adapter stops
      fb-checkpresence.0	2020-12-28 09:25:29.538	error	(28553) getDeviceList: "Can not read hostlist path"
      fb-checkpresence.0	2020-12-28 09:25:29.536	error	(28553) soapAction /upnp/control/hosts X_AVM-DE_GetHostListPath status=ECONNABORTED errNo=5 timeout of 10000ms exceeded
      fb-checkpresence.0	2020-12-28 09:25:09.454	info	(28553) createMemberObjects finished successfully
      fb-checkpresence.0	2020-12-28 09:25:08.995	info	(28553) createGlobalObjects finished successfully
      fb-checkpresence.0	2020-12-28 09:25:08.783	info	(28553) service DeviceConfig1-Reboot is supported
      fb-checkpresence.0	2020-12-28 09:25:08.766	warn	(28553) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
      fb-checkpresence.0	2020-12-28 09:25:08.765	warn	(28553) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
      fb-checkpresence.0	2020-12-28 09:25:08.764	info	(28553) service DeviceInfo1-GetInfo is supported
      fb-checkpresence.0	2020-12-28 09:25:08.744	info	(28553) service WLANConfiguration3-GetInfo is supported
      fb-checkpresence.0	2020-12-28 09:25:08.719	info	(28553) service WLANConfiguration3-SetEnable is supported
      fb-checkpresence.0	2020-12-28 09:25:08.693	info	(28553) service WANPPPConnection1-GetInfo is supported
      fb-checkpresence.0	2020-12-28 09:25:08.669	info	(28553) service DeviceInfo1-GetSecurityPort is supported
      fb-checkpresence.0	2020-12-28 09:25:08.650	info	(28553) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
      fb-checkpresence.0	2020-12-28 09:25:08.631	info	(28553) service Hosts1-GetSpecificHostEntry is supported
      fb-checkpresence.0	2020-12-28 09:25:08.612	info	(28553) service Hosts1-X_AVM-DE_GetMeshListPath is supported
      fb-checkpresence.0	2020-12-28 09:25:08.594	info	(28553) service Hosts1-X_AVM-DE_GetHostListPath is supported
      fb-checkpresence.0	2020-12-28 09:25:08.417	info	(28553) start fb-checkpresence: ip-address: "fritz.box" - interval devices: 2 Min. - interval members: 120 s
      fb-checkpresence.0	2020-12-28 09:25:08.387	info	(28553) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
      Das passiert nach dem Start des Adapters. Alle Adapter sind in latest auf dem neusten Stand. Node ist 12.20.0
      Habe den Benutzer in der Fritzbox6490 noch mal neu angelegt und auch ne zweite Instanz installiert, Fehler bleibt der gleiche. ???
      Beste Grüsse paul
      afuerhoff 1 Reply Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @paul.honka last edited by afuerhoff
        @paul-honka
        Hast du schon einen Neustart der Fritzbox durchgeführt? Am besten auch mal die IP-Adresse eingeben anstatt fritz.box.
          @afuerhoff
          Die IP Adresse stand schon immer drin. Neustart geht gerade nicht, Homeoffice.
          Mache ich später.
          Beste Grüsse Paul
          TG70 ? 2 Replies Last reply Reply Quote 0
          • TG70
            TG70 Forum Testing @paul.honka last edited by TG70
            Hallo ich habe das Problem, das wohl irgendwie meine Einstellungen nicht
            gespeichert werden. Auch die Zeit/Datum Formatierung wird immer wieder
            überschrieben. Neu installiert habe ich den Adapter bereits.
            ... oder der Adapter geht auch sofort wieder auf rot.
            Version 1.1.0
            ? afuerhoff 2 Replies Last reply Reply Quote 0
              A Former User @TG70 last edited by
              @TG70 trag mal die IP Adresse anstatt den evtl. Hostnamen ein..
              TG70 1 Reply Last reply Reply Quote 0
                A Former User @paul.honka last edited by
                @paul-honka "fritz.box" ist keine IP Adresse, versuch mal das richtig einzutragen, also 192.168.178.1 oder was du auch immer bei dir eingestellt hast.. 🙂
                • afuerhoff
                  afuerhoff Developer @TG70 last edited by
                  @TG70 sagte in Test Adapter fb-checkpresence v1.1.x:
                  gespeichert werden
                  Hallo, in der rot unterstrichenen Einstellung (Datumsformat) ist der senkrechte Strich nicht zulässig.
                    @afuerhoff
                    Jo, habe die Fritzbox neu gestartet. Der Adapter blieb rot.
                    Dann den IO Broker PI neugestartet, Adapter auf gelb.
                    Nach mehrmaligem starten ging der Adapter auf grün.
                    Die Mitglieder werden auch richtig angezeigt.
                    Weiss der T....
                    Beste Grüße paul
                      @paul-honka ... es weiss das Logfile.. 🙂
                      • Fenriswolf
                        Fenriswolf last edited by
                        Ich habe nochmal eine Frage:
                        Besteht die Möglichkeit eine Funktion für "manuelle" Anwesenheit einzubauen ?
                        Zur Erklärung:
                        Über die Mobiltelefone wird die Anwesenheit und dadurch auch die Alarmanlage gesteuert. Nun habe ich hin und wieder die Situation, das die Mobiltelefone ausgeschaltet sind oder nicht zuhause sind, ich aber nicht möchte, das eine Abwesenheit angenommen wird.
                        Daher würde mir eine Variable "true/false" gefallen, die den Status auf anwesend setzt, auch wenn kein Telefon da ist, oder aber ein Telefon ständig anwesend / abwesend ist. Ich kann zwar z.b. die Alarmanlage manuell auf "Aus" stellen, wenn dann aber ein Telefon kommt und geht aktiviert es sich wieder.
                        Momentan habe ich es für eine "externe" Variable gelöst, benötigt aber dadurch in anderen Bereichen einen erhöhten Programmieraufwand. Daher würde mir eine ein Schalter gefallen, der unabhändig von anwesenden oder eben nicht anwesenden Mobiltelefonen die Anwesenheit auf "wahr" setzt.
                        bis denne
                          A Former User @Fenriswolf last edited by
                          @Fenriswolf das würde den Adapter "verwurschteln".. er soll lieber das zeigen, was er von der Fritzbox bekommt, und sonst nix.. ( halt meine Meinung.. ) 🙂
                          Für die Anwesenheit benutze ich eine Variable, die durch das Handy, die Smartwatch, die Location und den Schlüsselanhänger auf true/false gesetzt wird, und darauf beziehen sich alle anderen Scripte, niemals direct nur auf das was der eine Adapter liefert...
                          ( Script ganz einfach, ist eins von den Geräten true, ist die Anwesenheit da, sind alle false, bin ich abwesend ).
                          So kann ich in Ruhe zuhause das Handy ausschalten, etc.. ohne dass gleich der Alarm scharf geschaltet wird und ich im dunkeln sitze.. 🙂 bzw. alles Rot blinkt und mir die Feuermelder ins Ohr brüllen.. etc..
                          • TG70
                            TG70 Forum Testing @Guest last edited by TG70
                            @ilovegym sagte in Test Adapter fb-checkpresence v1.1.x:
                            Ja hatte ich schon probiert. Leider gleiches Problem
                            Genau diesen Strich entferne ich und nach dem speichern und wieder öffnen ist er wieder
                            Sieht danach so aus wie es nicht gespeichert wurde
                              @TG70 nimm Mal n anderen Browser ...
                              TG70 1 Reply Last reply Reply Quote 1
                              • TG70
                                Hallo, danke euch für die Rückmeldungen. Browser habe ich schon einige probiert.
                                Es bleibt immer das gleiche, egal was ich rein schreibe, es werden immer wieder das falsche Datumsformat mit dem Strich und fritz.box anstatt der IP Adresse eingetragen.
                                Im Log scheint es auch so, als würde die Fritz!Box 6660 cable die Anfrage nicht akzeptieren??
                                fb-checkpresence.0	2020-12-29 11:02:54.739	error	(30572) createFbDeviceObjects -> can't read devices from fritzbox! Adapter stops
                                fb-checkpresence.0	2020-12-29 11:02:54.739	error	(30572) getDeviceList: "Can not read hostlist path"
                                fb-checkpresence.0	2020-12-29 11:02:54.738	error	(30572) soapAction xml2jsX_AVM-DE_GetHostListPath status=500 errNo=4 401 invalid action
                                fb-checkpresence.0	2020-12-29 11:02:54.718	warn	(30572) createMemberObjects: "no family members defined! Objects are not created!"
                                Was dazu kommt. ich habe nun auch noch eine neue Fritzbox, weil ich die Leihbox von Vodafone/KD zurück gegeben habe.
                                  @TG70 also wenn der Adapter die Konfig nicht speichert, kann es ja nicht gehen, sehe da eher ein Problem mit deiner iobroker installation als mit dem Adapter und der Fritzbox...
                                  Was benutzt du, File oder Redis?
                                  Welchen js-controller?
                                  Socketio ??
                                  • afuerhoff
                                    Hallo, nutzt du die Autofill Funktion im Browser?
                                    siehe auch hier: https://forum.iobroker.net/topic/36054/fb-checkpresence-timeout-fehler-und-falscher-username/16
                                      Flo1988 last edited by
                                      Erstmal ein großes Lob an den Adapter und @afuerhoff!
                                      Bin von TR-64 auf fb-checkpresence umgestiegen, da mit den Objekten "presenceAll" und "presence" ich mir einige Abfragen für meine Alarmanlage und andere Skripte spare.
                                      Super!!! Weiter so.
                                      Das ganze hat bis zum Update auf 1.10 gut funktioniert, seit dem Update wurden keine Anwesenheiten von Familienmitgliedern mehr aktualisiert.
                                      Für das einzelne Familienmitglied ist das Objekt/Ordner "member" dauerhaft false, während das Unterobjekt "presence" dauerhaft true ist.
                                      Bei Abwesenheit wird lediglich die Geschwindigkeit auf 0 gesetzt, mehr nicht.
                                      Ähnliche Probleme wurden hier ja auch schon diskutiert.
                                      Nach dem Downgrade auf 1.0.4 funktioniert wieder alles wie gehabt, leider lässt sich hier der Abfrageintervall für Familienmitglieder noch nicht einstellen.
                                      Selbes Problem konnte ich auch beim Setup meiner Eltern feststellen.
                                      Mein Aufbau sieht wie folgt aus:
                                      ioBroker auf einem Raspberry Pi 3, Fritzbox 7590 mit Mesch bestehend aus 2x FRITZ!WLAN Repeater 1750E und 1x FRITZ!Repeater 600 alle mit FW 7.21.
                                      Familienmitglieder sind zwei iPhones (1x 12pro und 1x Xs alle mit iOS 14.x).
                                      Gerne helfe ich mit Logdateien von 1.0.4 und 1.10 oder teste eine neue Version, müsste nur wissen was benötigt wird 😉
                                      Grüße Flo
                                      • afuerhoff
                                        afuerhoff Developer last edited by
                                        ich habe eine neue Version 1.1.1 auf Github hochgeladen. Sie ist noch nicht ganz fertig, aber die folgenden Änderungen habe ich schon vorgenommen.
                                        Änderungen:
                                        • Admin Konfiguration optimiert
                                        • Im Dateformat dürfen jetzt auch Bindestriche benutzt werden
                                        • https workaround implementiert (Konfiguration)-> es gab einen Fall, wo der Adapter nicht mit https die Fritzbox abfragen konnte.
                                        • Connection check wurde optimiert
                                        • Dokumentation geändert
                                        • Mesh Handling optimiert -> es werden jetzt die Channels im Klartext angelegt. Dies verhindert, dass sich die Id's ändern.
                                        Bitte Feedback, wenn euch etwas auffällt.
                                        Pedder007 1 Reply Last reply Reply Quote 0
                                        • afuerhoff
                                          afuerhoff Developer @Flo1988 last edited by
                                          @Flo1988 sagte in Test Adapter fb-checkpresence v1.1.x:
                                          Hallo, ist in den iPhones die Mac-Verschleierung aktiviert? Dann funktioniert die Anwesenheitserkennung nicht. Ist glaube ich mit iOS 14 eingeführt worden.
                                          • TG70
                                            TG70 Forum Testing @afuerhoff last edited by
                                            @afuerhoff Autofill hatte ich tatsächlich an ... habe es jetzt mal ausgeschaltet.
                                            Sieht so aus als würde er jetzt speichern. Danke dir
                                            An meinem Datums/Uhrzeitformat gefällt ihm irgendwie immer noch was nicht:
                                            Zuerst geht der Adapter auf gelb, danach auf rot, siehe Log:
                                            fb-checkpresence.0	2020-12-29 12:14:23.369	info	(15283) createGlobalObjects finished successfully
                                            fb-checkpresence.0	2020-12-29 12:14:23.273	info	(15283) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            fb-checkpresence.0	2020-12-29 12:14:23.272	info	(15283) terminating
                                            fb-checkpresence.0	2020-12-29 12:14:23.271	info	(15283) cleaned everything up ...
                                            fb-checkpresence.0	2020-12-29 12:14:23.271	info	(15283) Got terminate signal TERMINATE_YOURSELF
                                            fb-checkpresence.0	2020-12-29 12:14:23.137	warn	(15283) chkService: "can not get services!"
                                            fb-checkpresence.0	2020-12-29 12:14:23.136	warn	(15283) chkService: "can not get services!"
                                            fb-checkpresence.0	2020-12-29 12:14:23.135	warn	(15283) chkService: "can not get services!"
                                            fb-checkpresence.0	2020-12-29 12:14:23.134	warn	(15283) chkService: "can not get services!"
                                            fb-checkpresence.0	2020-12-29 12:14:23.133	warn	(15283) chkService: "can not get services!"
                                            fb-checkpresence.0	2020-12-29 12:14:23.132	warn	(15283) chkService: "can not get services!"
                                            fb-checkpresence.0	2020-12-29 12:14:23.130	error	(15283) Can not get services! Adapter stops
                                            fb-checkpresence.0	2020-12-29 12:14:23.129	error	(15283) getServices: {"message":"connect ETIMEDOUT 192.168.1.1:49000","name":"Error","stack":"Error: connect ETIMEDOUT 192.168.1.1:49000\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:114
                                            fb-checkpresence.0	2020-12-29 12:12:16.496	debug	(15283) system.adapter.admin.0: logging true
                                            fb-checkpresence.0	2020-12-29 12:12:15.475	debug	(15283) system.adapter.admin.0: logging false
                                            fb-checkpresence.0	2020-12-29 12:12:12.660	debug	(15283) configuratuion mesh info: true
                                            fb-checkpresence.0	2020-12-29 12:12:12.659	debug	(15283) configuration fb-devices true
                                            fb-checkpresence.0	2020-12-29 12:12:12.659	debug	(15283) configuration familymembers: [{"familymember":"","macaddress":"","ipaddress":"","useip":false,"comment":"","enabled":false}]
                                            fb-checkpresence.0	2020-12-29 12:12:12.659	debug	(15283) configuration dateformat: <dd.mm.yyyy HH:MM:ss>
                                            fb-checkpresence.0	2020-12-29 12:12:12.659	debug	(15283) configuration history: <sql.0>
                                            fb-checkpresence.0	2020-12-29 12:12:12.658	debug	(15283) configuration user: <tom>
                                            fb-checkpresence.0	2020-12-29 12:12:12.658	info	(15283) start fb-checkpresence: ip-address: "192.168.1.1" - interval devices: 1 Min. - interval members: 60 s
                                            fb-checkpresence.0	2020-12-29 12:12:12.638	info	(15283) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
                                            fb-checkpresence.0	2020-12-29 12:12:11.394	debug	(15283) statesDB connected
                                            fb-checkpresence.0	2020-12-29 12:12:11.393	debug	(15283) States connected to redis: 127.0.0.1:9000
                                            fb-checkpresence.0	2020-12-29 12:12:11.359	debug	(15283) States create System PubSub Client
                                            fb-checkpresence.0	2020-12-29 12:12:11.357	debug	(15283) States create User PubSub Client
                                            fb-checkpresence.0	2020-12-29 12:12:11.338	debug	(15283) Redis States: Use Redis connection: 127.0.0.1:9000
                                            fb-checkpresence.0	2020-12-29 12:12:11.336	debug	(15283) objectDB connected
                                            fb-checkpresence.0	2020-12-29 12:12:11.333	debug	(15283) Objects connected to redis: 127.0.0.1:9001
                                            fb-checkpresence.0	2020-12-29 12:12:11.272	debug	(15283) Objects client initialize lua scripts
                                            fb-checkpresence.0	2020-12-29 12:12:11.272	debug	(15283) Objects create User PubSub Client
                                            fb-checkpresence.0	2020-12-29 12:12:11.271	debug	(15283) Objects create System PubSub Client
                                            fb-checkpresence.0	2020-12-29 12:12:11.269	debug	(15283) Objects client ready ... initialize now
                                            fb-checkpresence.0	2020-12-29 12:12:11.218	debug	(15283) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                            fb-checkpresence.0	2020-12-29 12:12:08.797	info	(14129) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            fb-checkpresence.0	2020-12-29 12:12:08.796	info	(14129) terminating
                                            fb-checkpresence.0	2020-12-29 12:12:08.796	error	(14129) onUnload: TypeError: Cannot read property 'exitRequest' of null
                                            fb-checkpresence.0	2020-12-29 12:12:08.795	info	(14129) Got terminate signal TERMINATE_YOURSELF
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            255847
