    3. Entwicklung
    4. [Neuer Adapter] Xiaomi Luftfilter
      moeff last edited by
      @Ente im miio sieht es bei mir so aus
      @JensA https://github.com/JoJ123/ioBroker.mihome-airpurifier ist der alte Adapter, hier habe ich nur die Vorgängerversionen der Xiaomi Purifier zur Auswahl - der Adapter startet zwar, sagt aber Unknown Purifier Version
      der Adapter von dontobi - https://github.com/dontobi/ioBroker.mihome-airpurifier Startet leider bei mir nicht - sondern bleibt mit hängen:
      host.iobroker	2020-12-25 02:16:31.218	error	instance system.adapter.mihome-airpurifier.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/miio/lib/devices/air-purifier.js:11:18)
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:723:23)
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: SyntaxError: Unexpected token =
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: ^
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: fs1 = -1;
      host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: /opt/iobroker/node_modules/miio/lib/devices/capabilities/fan-speed.js:7
      dontobi J 2 Replies Last reply Reply Quote 0
      • dontobi
        dontobi @moeff last edited by
        @moeff in deiner Fehlermeldung steht auch woran es liegt, nämlich am Token. Ich pushe im Laufe der Woche eine neue Version, die lediglich die 2er Serie unterstützt. Dann ist wenigstens eine stabile Version online.
          JensA @moeff last edited by
          @moeff
          Aha, dann war ich also mit den git Links durcheinander gekommen. Der Adapter von dontobi - https://github.com/dontobi/ioBroker.mihome-airpurifier (0.2.1) startet bei mir ohne Probleme. Beim Abspeichern der Konfiguration bekomme ich folgende Meldung: "Einige Daten wurden nicht gespeichert. Verwerfen?" Er scheint sich aber die Daten doch zu merken, zumindest sind sie beim erneuten Aufrufen der Konfiguration vollständig:
          Ich bekomme aber den Kontakt zum 2H nicht hin. Das Log sieht folgendermaßen aus:
          Kann ich beim Auslesen des Token über den vacuum adapter was falsch gemacht haben? (mehrfach gecheckt, keine Leerzeichen am Ende etc.)
          Ist vielleicht meine H2 Firmware nicht kompatibel?
          dontobi 1 Reply Last reply Reply Quote 0
          • dontobi
            dontobi @JensA last edited by
            @JensA stell den Adapter bitte Mal auf debug und starte ihn neu. Anschließend poste hier Mal das Log, dann sollten wir mehr wissen.
              JensA @dontobi last edited by
              @dontobi
              Hier wie gewünscht:
              • dontobi
                @JensA an dem Token liegt es wahrscheinlich nicht. Ist die IP richtig?
                  @dontobi
                  Ja, die IP stimmt. Die Daten aus dem vacuum adapter sehen so aus:
                  • dasquiddi
                    dasquiddi last edited by
                    Konnte mein Problem mit dem Wechsel von Node-v10 auf v12 lösen. Habe damit erfolgreich die Verbindung zu meinem 2H herstellen können und erhalte korrekte Daten davon.
                    Meinen Token konnte ich nur mittels Tool von der HomeAssistant Seite über die Cloud auslesen. Link
                    Der Weg über "miio discover" ergab nur ??? beim Token.
                      Thomas Braun Most Active @dasquiddi last edited by
                      @dasquiddi
                      Ein upgrade auf die gerade empfohlene node-Version ist immer eine gute Idee. (Hätte fast von mir sein können... 🙂 )
                      Die xiaomi-Token kann man übrigens auch über den ioBroker-Adapter für die Staubsauger auslesen.
                      • dontobi
                        dontobi @Thomas Braun last edited by
                        Nachdem ich eben die Version 0.2.2 pushen wollte, ist irgend etwas schief gegangen. Auch ein Rebase von miio hat nichts gebracht. Daher habe ich mir gerade den ioBroker.miio Adapter angesehen. Dieser ist besser dokumentiert und ich werde diesen nun weiter verwenden und auch an der Entwicklung teilnehmen. Daher werde ich die Repos löschen.
                          crunchip Forum Testing Most Active @dontobi last edited by
                          @dontobi das klingt nach......es könnte demnächst auch mit dem H3 klappen😇
                          • dontobi
                            dontobi @crunchip last edited by
                            @crunchip ich werde es versuchen. Brauche da aber jemanden, der einen 3 oder 3h hat.
                            crunchip S 2 Replies Last reply Reply Quote 0
                              @dontobi hab ich, mio adapter läuft auch, hatte ich installiert, wegen den phillips zhirui downlights.
                              Datenpunkte sind vorhanden/angelegt jedoch keine Verbindung
                                SaiBot1981 @dontobi last edited by SaiBot1981
                                @dontobi sagte in [Neuer Adapter] Xiaomi Luftfilter:
                                Ich hab den adapter auch installiert. Genau wie bei Crunship sind bei mir die datenpunkte nicht gefüllt. die verbindung ist jedoch da. Ich hab den 3H.
                                  moeff @dontobi last edited by
                                  @dontobi said in [Neuer Adapter] Xiaomi Luftfilter:
                                  Der/das Token ist korrekt gesetzt. Der Fehler bleibt. Der/das Token wurde per vacuum adapter ausgelesen und sogar nochmal händisch gecheckt. Ebenfalls habe ich im miio mit dem Token keine Probleme den 2H zu verbinden.
                                  • dontobi
                                    @crunchip ich kann mir auch schon vorstellen woran das liegt. Bin gerade dabei den Adapter zu verstehen und zu erweitern. Melde mich, wenn ich was zum testen habe.
                                    • dontobi
                                      Ich habe meine eigene Version des ioBroker.miio Adapters seit ein paar Stunden im Einsatz. Wer den Mal testen möchte, kann sich gerne bei mir per PM melden.
                                      M crunchip 2 Replies Last reply Reply Quote 1
                                        moeff @dontobi last edited by moeff
                                        @dontobi
                                        https://github.com/dontobi/ioBroker.miio ?
                                        Was ist der Unterschied? Der 2H funktioniert mit dem originalen alten miio Adapter perfekt, hab damit ein paar Routinen und kann auch mit Alexa nun mehr als nur ein/aus wie mit dem Xiaomi Home Skill steuern
                                        • dontobi
                                          @moeff du kannst den alten noch verwenden. Jedoch werde ich in den alten keine Energie mehr stecken, denn ganz schlau wurde ich bis zum Schluss nicht.
                                            gibts auch was zu testen mit dem 3H
                                            188
                                            28172
