    4. Test Adapter Z-Wave 2 (v1.8.x)
      Markus84 @AlCalzone last edited by
      Ich habe meine Z-Wave Stick an einen anderen USB Port hängen müssen. Seitdem bleibt der Adapter gelb. Den Port habe ich geändert. Bei allen anderen Ports erhalte ich im Log eine Fehlermeldung, ich hoffe daher es ist der richtige Port. Hier der Auszug aus dem Log:
      zwave2.0	2020-12-28 02:32:17.983	silly	(11242) States user redis pmessage zwave2.0.*/zwave2.0.info.healingNetwork:{"val":false,"ack":true,"ts":1609119137962,"q":0,"from":"system.adapter.zwave2.0","user":"system.user.admin","lc":15815246377
      zwave2.0	2020-12-28 02:32:17.982	silly	(11242) States user redis pmessage zwave2.0.*/zwave2.0.info.exclusion:{"val":false,"ack":true,"ts":1609119137962,"q":0,"from":"system.adapter.zwave2.0","user":"system.user.admin","lc":1581013646426}
      zwave2.0	2020-12-28 02:32:17.977	silly	(11242) States user redis pmessage zwave2.0.*/zwave2.0.info.inclusion:{"val":0,"ack":true,"ts":1609119137961,"q":0,"from":"system.adapter.zwave2.0","user":"system.user.admin","lc":1591774453893}
      zwave2.0	2020-12-28 02:32:17.974	silly	(11242) States user redis pmessage zwave2.0.*/zwave2.0.info.connection:{"val":false,"ack":true,"ts":1609119137961,"q":0,"from":"system.adapter.zwave2.0","user":"system.user.admin","lc":1609112855846}
      zwave2.0	2020-12-28 02:32:17.955	silly	(11242) States system redis pmessage system.adapter.zwave2.0.logLevel/system.adapter.zwave2.0.logLevel:{"val":"silly","ack":true,"ts":1609119137842,"q":0,"from":"system.adapter.zwave2.0","lc":16091191
      zwave2.0	2020-12-28 02:32:17.800	info	(11242) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.zwave2, node: v14.15.3, js-controller: 3.1.6
      host.raspberrypi	2020-12-28 02:32:14.375	info	instance system.adapter.zwave2.0 started with pid 11242
      host.raspberrypi	2020-12-28 02:32:11.773	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      zwave2.0	2020-12-28 02:32:11.193	info	(10999) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zwave2.0	2020-12-28 02:32:11.191	info	(10999) terminating
      zwave2.0	2020-12-28 02:32:11.190	info	(10999) Shutting down driver...
      zwave2.0	2020-12-28 02:32:11.186	info	(10999) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2020-12-28 02:32:11.177	info	stopInstance system.adapter.zwave2.0 send kill signal
      host.raspberrypi	2020-12-28 02:32:11.152	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)```
      Kann mir hier jemand helfen?
        moritzabcde @AlCalzone last edited by
        @AlCalzone said in Test Adapter Z-Wave 2 (v1.8.x):
        Ja, das Mesh wird nur durch netzbetriebene Geräte aufgebaut. Batteriebetrieben verbringen die meiste Zeit schlafend, sodass sie da nicht beitragen können.
        Vielen Dank für die Infos!
        Eine letzte Frage noch: Würde ein weiteres netzbetriebenes Gerät (bei korrekter Positionierung) die Reichweite erweitern, so dass der entfernte Thermostat zuverlässiger angesprochen werden kann?
        • AlCalzone
          AlCalzone Developer @moritzabcde last edited by
          @moritzabcde Wäre zumindest sehr wahrscheinlich
          @Markus84 ich sehe keinen Fehler 😕
            Ich habe jetzt noch einen Fehler im Log gefunden:
            host.raspberrypi	2020-12-28 14:15:34.923	warn	instance system.adapter.zwave2.0 terminated due to SIGABRT
            Kannst du hier vielleicht etwas draus ableiten?
            • AlCalzone
              AlCalzone Developer @Markus84 last edited by
              @Markus84 sagte in Test Adapter Z-Wave 2 (v1.8.x):
              SIGABRT sind kritische Fehler in low-level-Bibliotheken. Könnte vom System stammen oder aus der Serialport-Library, das kann ich leider nicht erkennen und auch nicht abfangen 😞
                @AlCalzone Okay, danke für die Antwort. Ich hab jetzt alles mögliche ausprobiert und bekomme jetzt diese Fehlermeldung nach einer Neuinstallation des Adapters:
                zwave2.0	2020-12-28 16:55:29.302	error	(30129) The Z-Wave driver could not be started: Error: Device or resource busy, cannot open /dev/ttyACM0
                Hast du hier zufällig eine Idee?
                • AlCalzone
                  @Markus84 Irgendwas blockiert deinen Port. Mal komplett neu starten?
                    @AlCalzone Das habe ich schon ausprobiert. Ich habe ihn auch schon an einen anderen Port gesteckt. Was mich wundert ist, dass die Ausgabe von
                    ls /dev/tty*
                    identisch ist - egal ob der Stick abgezogen ist oder in irgendeiner USB Buchse steckt...
                    Troya 1 Reply Last reply Reply Quote 0
                    • Troya
                      Troya @Markus84 last edited by
                      @Markus84
                      Hatte ja mal die Frage gestellt, ob beide zwave Adapter gleichzeitig aktiv sein können, was beantwortet wurde mit 'die kommen sich wohl in die Quere'
                      Kann das bei dir evtl das Problem sein? Vielleicht vergessen den alten zu pausieren 🤷‍♂️
                        Markus84 @Troya last edited by
                        @Troya Ich habe nur einen Z-Wave Adapter installiert.
                        AlCalzone 1 Reply Last reply Reply Quote 1
                        • AlCalzone
                          @Markus84 Proxmox oder irgendwas mit Virtualisierung?
                            @AlCalzone Nein, läuft auf einen RPI4. Ich habe nichts anderes gemacht als den Conbee Stick mit dem Z-Wave Stick getauscht...
                              Chris_78 @Markus84 last edited by Chris_78
                              @Markus84
                              Kann es sein, dass du noch die Conbee/Phoscon Software installiert hast? Diese kann den
                              Port auch blockieren. Falls du diese aktuell nicht benötigst am besten mal deinstallieren.
                              Oder zumindest prüfen, ob du in der Phoscon Software den Port wechseln kannst...
                              Würde am besten aber erst mal deinstallieren. Falls noch benötigt vorher noch die Einstellungen sichern/exportieren... 🙂
                              Nachtrag:
                              Falls du den Zigbee-Adapter benutzt evtl. auch hier mal die Porteinstellungen prüfen, ob dieser nicht den gleichen Port wie der
                              Z-Wave-Adapter nutzt.
                                Markus84 @Chris_78 last edited by
                                @Chris_78 said in Test Adapter Z-Wave 2 (v1.8.x):
                                Bei mir läuft alles über Zigbee, nur die Rauchmelder laufen über Z-Wave. Daher kann ich das leider nicht ausprobieren. Aber es ging ja sonst auch immer beides parallel ohne Probleme...
                                • AlCalzone
                                  @Markus84 Und du bist 100% sicher, dass es der richtige Pfad ist?
                                    Ich habe den Fehler gefunden. Ich benutze den Aeotec Stick. Er funktioniert an keinem der ioBroker Ports direkt. Auch wenn er an einem USB Verlängerunskabel angeschlossen ist funktioniert er nicht. Sobald ich ihn an einen separaten USB Hub stecke (ohne separate Stromversorgung) funktioniert es wieder.
                                    Sehr seltsam... Aber besten Dank für eure Unterstützung!
                                    • AlCalzone
                                      v1.8.3 ist auf dem Weg - Changelog oben 🙂
                                      • Andreas Wartmann
                                        Andreas Wartmann last edited by
                                        Hi, bei mir startet seit ein paar Tagen der Adapter (Windows, latest) dauernd neu:
                                        zwave2.0	2021-01-01 21:25:31.289	error	(4728) Failed to initialize the driver: dest already exists.
                                        zwave2.0	2021-01-01 21:25:29.501	info	(4728) starting. Version 1.8.3 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.zwave2, node: v10.17.0, js-controller: 3.1.6
                                        zwave2.0	2021-01-01 21:25:26.936	info	(2372) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        zwave2.0	2021-01-01 21:25:25.926	error	(2372) Restarting the adapter in a second...
                                        zwave2.0	2021-01-01 21:25:25.925	error	(2372) Failed to initialize the driver: dest already exists.
                                        zwave2.0	2021-01-01 21:25:24.142	info	(2372) starting. Version 1.8.3 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.zwave2, node: v10.17.0, js-controller: 3.1.6
                                        zwave2.0	2021-01-01 21:25:21.549	info	(11936) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        zwave2.0	2021-01-01 21:25:20.537	error	(11936) Restarting the adapter in a second...
                                        zwave2.0	2021-01-01 21:25:20.537	error	(11936) Failed to initialize the driver: dest already exists.
                                        zwave2.0	2021-01-01 21:25:18.721	info	(11936) starting. Version 1.8.3 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.zwave2, node: v10.17.0, js-controller: 3.1.6
                                        zwave2.0	2021-01-01 21:25:16.173	info	(2792) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        Ich hab sowohl versucht die Instanz als auch den Adapter zu löschen und neu zu installieren, hat leider nichts geholfen. Irgendwelche Tipps von Eurer Seite? Der alte z-wave Adapter läuft soweit (hab ich pausiert beim Erstellen des Logs oben).
                                        • AlCalzone
                                          AlCalzone Developer @Andreas Wartmann last edited by
                                          @Andreas-Wartmann sagte in Test Adapter Z-Wave 2 (v1.8.x):
                                          dest already exists
                                          Zeigst du mir bitte mal den Inhalt des Cache-Verzeichnisses?
                                          /opt/iobroker/iobroker-data/zwave2.0/cache
                                          Andreas Wartmann 1 Reply Last reply Reply Quote 0
                                          • Andreas Wartmann
                                            Andreas Wartmann @AlCalzone last edited by
                                            @AlCalzone
                                            Ist das das richtige Verzeichnis?
                                            test z-wave zwave
                                            32
                                            325
                                            47094
