    4. Test Adapter fb-checkpresence v1.1.x
    • TG70
      TG70 Forum Testing @afuerhoff last edited by
      @afuerhoff Autofill hatte ich tatsächlich an ... habe es jetzt mal ausgeschaltet.
      Sieht so aus als würde er jetzt speichern. Danke dir
      An meinem Datums/Uhrzeitformat gefällt ihm irgendwie immer noch was nicht:
      Zuerst geht der Adapter auf gelb, danach auf rot, siehe Log:
      fb-checkpresence.0	2020-12-29 12:14:23.369	info	(15283) createGlobalObjects finished successfully
      fb-checkpresence.0	2020-12-29 12:14:23.273	info	(15283) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      fb-checkpresence.0	2020-12-29 12:14:23.272	info	(15283) terminating
      fb-checkpresence.0	2020-12-29 12:14:23.271	info	(15283) cleaned everything up ...
      fb-checkpresence.0	2020-12-29 12:14:23.271	info	(15283) Got terminate signal TERMINATE_YOURSELF
      fb-checkpresence.0	2020-12-29 12:14:23.137	warn	(15283) chkService: "can not get services!"
      fb-checkpresence.0	2020-12-29 12:14:23.136	warn	(15283) chkService: "can not get services!"
      fb-checkpresence.0	2020-12-29 12:14:23.135	warn	(15283) chkService: "can not get services!"
      fb-checkpresence.0	2020-12-29 12:14:23.134	warn	(15283) chkService: "can not get services!"
      fb-checkpresence.0	2020-12-29 12:14:23.133	warn	(15283) chkService: "can not get services!"
      fb-checkpresence.0	2020-12-29 12:14:23.132	warn	(15283) chkService: "can not get services!"
      fb-checkpresence.0	2020-12-29 12:14:23.130	error	(15283) Can not get services! Adapter stops
      fb-checkpresence.0	2020-12-29 12:14:23.129	error	(15283) getServices: {"message":"connect ETIMEDOUT 192.168.1.1:49000","name":"Error","stack":"Error: connect ETIMEDOUT 192.168.1.1:49000\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:114
      fb-checkpresence.0	2020-12-29 12:12:16.496	debug	(15283) system.adapter.admin.0: logging true
      fb-checkpresence.0	2020-12-29 12:12:15.475	debug	(15283) system.adapter.admin.0: logging false
      fb-checkpresence.0	2020-12-29 12:12:12.660	debug	(15283) configuratuion mesh info: true
      fb-checkpresence.0	2020-12-29 12:12:12.659	debug	(15283) configuration fb-devices true
      fb-checkpresence.0	2020-12-29 12:12:12.659	debug	(15283) configuration familymembers: [{"familymember":"","macaddress":"","ipaddress":"","useip":false,"comment":"","enabled":false}]
      fb-checkpresence.0	2020-12-29 12:12:12.659	debug	(15283) configuration dateformat: <dd.mm.yyyy HH:MM:ss>
      fb-checkpresence.0	2020-12-29 12:12:12.659	debug	(15283) configuration history: <sql.0>
      fb-checkpresence.0	2020-12-29 12:12:12.658	debug	(15283) configuration user: <tom>
      fb-checkpresence.0	2020-12-29 12:12:12.658	info	(15283) start fb-checkpresence: ip-address: "192.168.1.1" - interval devices: 1 Min. - interval members: 60 s
      fb-checkpresence.0	2020-12-29 12:12:12.638	info	(15283) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
      fb-checkpresence.0	2020-12-29 12:12:11.394	debug	(15283) statesDB connected
      fb-checkpresence.0	2020-12-29 12:12:11.393	debug	(15283) States connected to redis: 127.0.0.1:9000
      fb-checkpresence.0	2020-12-29 12:12:11.359	debug	(15283) States create System PubSub Client
      fb-checkpresence.0	2020-12-29 12:12:11.357	debug	(15283) States create User PubSub Client
      fb-checkpresence.0	2020-12-29 12:12:11.338	debug	(15283) Redis States: Use Redis connection: 127.0.0.1:9000
      fb-checkpresence.0	2020-12-29 12:12:11.336	debug	(15283) objectDB connected
      fb-checkpresence.0	2020-12-29 12:12:11.333	debug	(15283) Objects connected to redis: 127.0.0.1:9001
      fb-checkpresence.0	2020-12-29 12:12:11.272	debug	(15283) Objects client initialize lua scripts
      fb-checkpresence.0	2020-12-29 12:12:11.272	debug	(15283) Objects create User PubSub Client
      fb-checkpresence.0	2020-12-29 12:12:11.271	debug	(15283) Objects create System PubSub Client
      fb-checkpresence.0	2020-12-29 12:12:11.269	debug	(15283) Objects client ready ... initialize now
      fb-checkpresence.0	2020-12-29 12:12:11.218	debug	(15283) Redis Objects: Use Redis connection: 127.0.0.1:9001
      fb-checkpresence.0	2020-12-29 12:12:08.797	info	(14129) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      fb-checkpresence.0	2020-12-29 12:12:08.796	info	(14129) terminating
      fb-checkpresence.0	2020-12-29 12:12:08.796	error	(14129) onUnload: TypeError: Cannot read property 'exitRequest' of null
      fb-checkpresence.0	2020-12-29 12:12:08.795	info	(14129) Got terminate signal TERMINATE_YOURSELF
      afuerhoff 1 Reply Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @TG70 last edited by
        @TG70
        Wenn du speichern konntest ist das Dateformat ok. Der rote Balken verändert sich nur, wenn du das Feld wechselst.
        Hast Du wirklich die richtige IP-Adresse eingestellt. Der Adapter kann ja schon die grundlegendsten Dinge nicht von der Fritzbox abfragen.
        Wenn du die URL http://192.168.1.1:49000/tr64desc.xml im Browser eingibst, kommt dann ein Ergebnis zurück?
          Flo1988 @afuerhoff last edited by
          @afuerhoff "Private WLAN-Adresse" (so heißt die neue Funktion in iOS 14 zum Verbergen der MAC-adresse) ist für alle Geräte in dem Heimnetzwerk abgeschaltet.
          Das hatte ich auch schon im Verdacht, daran kann es aber nicht liegen.
          Ich werde mal deine neue Version probieren und berichten.
          Vielleicht hat sich das Problem mit 1.11 schon erledigt.
          • afuerhoff
            afuerhoff Developer @Flo1988 last edited by
            @Flo1988
            Ansonsten bitte auf Logstufe debug das Log posten.
            ? F 3 Replies Last reply Reply Quote 0
              A Former User @afuerhoff last edited by
              @afuerhoff Version 1.1.1 läuft hier ohne Auffäligkeiten.
              Node 14.15.3, NPM 6.14.10, js-controller 3.1.8, Fritzbox 7590 mit 7.24-beta, iobroker im Debian-10 LXC.
                A Former User @afuerhoff last edited by A Former User
                @afuerhoff
                so, nachdem der Adapter sich seine Daten geholt hat, ist mir folgendes aufgefallen, bei den Devices Active, Inactiv, und devices:
                Im Pfad fb-devices:
                active - 314
                count - 323
                inactive - 15 ???
                Dann im Hauptpfad:
                activeDevices - 314
                devices - 329
                Also active und ActiveDevices scheint gleich, plus die 15 inactive ergibt 329 - das sind devices.
                Was ist count ??
                Kannst du da mit den Datenpunkten aufräumen, wenn sie doch gleich sind, oder wo ist der Unterschied?
                In der Fritzbox sieht das so aus:
                  @afuerhoff
                  Leider bringt 1.11 keine Besserung.
                  Werde wieder zurück zu 1.04 gehen.
                  Hier der Log von 1.11:
                  • Instanz wurde neugestartet
                  • Beide "Member" Ordner sind wie bei 1.10 auf false, Objekt "presence" ist aber true und beide haben einen Eintrag bei "speed"
                  • iPhone "Florian" und "Silke" waren beide im WLAN und anschließend wurde das WLAN bei "Florian" am iPhone deaktiviert
                  • Auch nach ca. 10min hat sich nichts getan. Mit 1.10 ist normalerweise der speed verschwunden, bei 1.11 passiert nix mehr.
                  fb-checkpresence.0	2020-12-29 18:26:56.926	info	(30826) createFbDeviceObjects finished successfully
                  fb-checkpresence.0	2020-12-29 18:26:47.221	info	(30826) createMemberObjects finished successfully
                  fb-checkpresence.0	2020-12-29 18:26:46.826	info	(30826) createGlobalObjects finished successfully
                  fb-checkpresence.0	2020-12-29 18:26:46.487	info	(30826) service DeviceConfig1-Reboot is supported
                  fb-checkpresence.0	2020-12-29 18:26:46.475	info	(30826) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                  fb-checkpresence.0	2020-12-29 18:26:46.462	info	(30826) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                  fb-checkpresence.0	2020-12-29 18:26:46.449	info	(30826) service DeviceInfo1-GetInfo is supported
                  fb-checkpresence.0	2020-12-29 18:26:46.434	info	(30826) service WLANConfiguration3-GetInfo is supported
                  fb-checkpresence.0	2020-12-29 18:26:46.418	info	(30826) service WLANConfiguration3-SetEnable is supported
                  fb-checkpresence.0	2020-12-29 18:26:46.401	info	(30826) service WANPPPConnection1-GetInfo is supported
                  fb-checkpresence.0	2020-12-29 18:26:46.385	info	(30826) service DeviceInfo1-GetSecurityPort is supported
                  fb-checkpresence.0	2020-12-29 18:26:46.372	info	(30826) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                  fb-checkpresence.0	2020-12-29 18:26:46.340	info	(30826) service Hosts1-GetSpecificHostEntry is supported
                  fb-checkpresence.0	2020-12-29 18:26:46.325	info	(30826) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                  fb-checkpresence.0	2020-12-29 18:26:46.308	info	(30826) service Hosts1-X_AVM-DE_GetHostListPath is supported
                  fb-checkpresence.0	2020-12-29 18:26:45.766	info	(30826) start fb-checkpresence: ip-address: "192.168.155.1" - interval devices: 1 Min. - interval members: 10 s
                  fb-checkpresence.0	2020-12-29 18:26:45.717	info	(30826) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.18.0, js-controller: 3.1.6
                  fb-checkpresence.0	2020-12-29 18:26:38.662	info	(30744) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  fb-checkpresence.0	2020-12-29 18:26:38.659	info	(30744) terminating
                  fb-checkpresence.0	2020-12-29 18:26:38.656	info	(30744) cleaned everything up ...
                  fb-checkpresence.0	2020-12-29 18:26:38.649	info	(30744) Got terminate signal TERMINATE_YOURSELF
                  afuerhoff Thomas Braun 2 Replies Last reply Reply Quote 0
                  • afuerhoff
                    @Flo1988
                    Bitte die Instanz auf Logstufe debug stellen und dann den Log posten.
                      Thomas Braun Most Active @Flo1988 last edited by
                      @Flo1988 sagte in Test Adapter fb-checkpresence v1.1.x:
                      node: v10.18.0
                      Vielleicht auch mal auf die empfohlene node-Version wechseln.
                        @afuerhoff
                        Sry.
                        node wurde auf 12.20.0 geupdated.
                        Läuft trotzdem nicht.
                        WLAN wurde während dem log bei "Florian" deaktiviert aber passiert nix.
                        fb-checkpresence.0	2020-12-29 20:11:21.928	debug	(4210) loopDevices ends after 2,157899582 s
                        fb-checkpresence.0	2020-12-29 20:11:21.924	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
                        fb-checkpresence.0	2020-12-29 20:11:21.778	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
                        fb-checkpresence.0	2020-12-29 20:11:21.662	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
                        fb-checkpresence.0	2020-12-29 20:10:19.702	debug	(4210) loopDevices ends after 1,441445027 s
                        fb-checkpresence.0	2020-12-29 20:10:19.700	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
                        fb-checkpresence.0	2020-12-29 20:10:19.615	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
                        fb-checkpresence.0	2020-12-29 20:10:19.546	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
                        fb-checkpresence.0	2020-12-29 20:10:13.252	info	(4210) createFbDeviceObjects finished successfully
                        fb-checkpresence.0	2020-12-29 20:10:04.787	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
                        fb-checkpresence.0	2020-12-29 20:10:03.789	info	(4210) createMemberObjects finished successfully
                        fb-checkpresence.0	2020-12-29 20:10:03.788	debug	(4210) enableHistory.2 Silke true
                        fb-checkpresence.0	2020-12-29 20:10:03.762	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                        fb-checkpresence.0	2020-12-29 20:10:03.752	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                        fb-checkpresence.0	2020-12-29 20:10:03.625	debug	(4210) enableHistory.2 Florian true
                        fb-checkpresence.0	2020-12-29 20:10:03.597	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                        fb-checkpresence.0	2020-12-29 20:10:03.584	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                        fb-checkpresence.0	2020-12-29 20:10:03.454	info	(4210) createGlobalObjects finished successfully
                        fb-checkpresence.0	2020-12-29 20:10:03.085	info	(4210) service DeviceConfig1-Reboot is supported
                        fb-checkpresence.0	2020-12-29 20:10:03.064	info	(4210) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                        fb-checkpresence.0	2020-12-29 20:10:02.952	info	(4210) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                        fb-checkpresence.0	2020-12-29 20:10:02.938	info	(4210) service DeviceInfo1-GetInfo is supported
                        fb-checkpresence.0	2020-12-29 20:10:02.919	info	(4210) service WLANConfiguration3-GetInfo is supported
                        fb-checkpresence.0	2020-12-29 20:10:02.903	info	(4210) service WLANConfiguration3-SetEnable is supported
                        fb-checkpresence.0	2020-12-29 20:10:02.886	info	(4210) service WANPPPConnection1-GetInfo is supported
                        fb-checkpresence.0	2020-12-29 20:10:02.869	info	(4210) service DeviceInfo1-GetSecurityPort is supported
                        fb-checkpresence.0	2020-12-29 20:10:02.853	info	(4210) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                        fb-checkpresence.0	2020-12-29 20:10:02.834	info	(4210) service Hosts1-GetSpecificHostEntry is supported
                        fb-checkpresence.0	2020-12-29 20:10:02.820	info	(4210) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                        fb-checkpresence.0	2020-12-29 20:10:02.802	info	(4210) service Hosts1-X_AVM-DE_GetHostListPath is supported
                        fb-checkpresence.0	2020-12-29 20:10:02.787	debug	(4210) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
                        fb-checkpresence.0	2020-12-29 20:10:02.756	debug	(4210) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"226","Major":"154","Minor":"7","Patch":"21","Buil
                        fb-checkpresence.0	2020-12-29 20:10:02.498	debug	(4210) configuratuion mesh info: false
                        fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration fb-devices true
                        fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration familymembers: [{"familymember":"Florian","macaddress":"A0:FB:C5:21:AC:7B","ipaddress":"192.168.155.86","useip":false,"comment":"iPhone12pro","enabled":true},{"familymember":"Silk
                        fb-checkpresence.0	2020-12-29 20:10:02.496	debug	(4210) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
                        fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration history: <influxdb.0>
                        fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration user: <ioBroker_tr064>
                        fb-checkpresence.0	2020-12-29 20:10:02.493	info	(4210) start fb-checkpresence: ip-address: "192.168.155.1" - interval devices: 1 Min. - interval members: 10 s
                        fb-checkpresence.0	2020-12-29 20:10:02.451	info	(4210) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
                        fb-checkpresence.0	2020-12-29 20:09:56.390	info	(4147) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        fb-checkpresence.0	2020-12-29 20:09:56.388	info	(4147) terminating
                        fb-checkpresence.0	2020-12-29 20:09:56.386	info	(4147) cleaned everything up ...
                        fb-checkpresence.0	2020-12-29 20:09:56.384	info	(4147) Got terminate signal TERMINATE_YOURSELF
                        • afuerhoff
                          afuerhoff Developer @Guest last edited by
                          @ilovegym sagte in Test Adapter fb-checkpresence v1.1.x:
                          Im Pfad fb-devices:
                          active - 314
                          count - 323
                          inactive - 15 ???
                          Dann im Hauptpfad:
                          activeDevices - 314
                          devices - 329
                          Ich habe die Datenpunkte irgendwann mal in den fb-devices Ordner verschoben . Im Hauptpfad habe ich sie aus Kompatibilitätsgründen gelassen. Der Unterschied ist durch einen kleinen Bug mit hineingekommen. Count sollte eigentlich identisch mit devices sein.
                          Stephan Schleich ? 2 Replies Last reply Reply Quote 0
                          • Stephan Schleich
                            Stephan Schleich @afuerhoff last edited by
                            @afuerhoff Könntest du die WLAN QR Codes noch mit einbinden?
                              @afuerhoff Hi,
                              sind das Werte, die du von der FB bekommst, oder rechnest du da was um/aus ?
                              • afuerhoff
                                @ilovegym
                                Nach dem Bugfix sind das dann die Werte aus der Fritzbox.
                                Allerdings stimmen diese dann nicht mit der Anzahl der angelegten Fb-devices überein. Da es hier durch doppelte Namen dann weniger Devices sind.
                                  @afuerhoff ja klar, ein Device hat bei mir z.bsp. bis zu 4 NICs, was 4 MAC und 4 IPs sind.. aber nur einen Hostnamen.. 🙂
                                  Sonst läuft alles super, weiter so, ich freu mich aufs nächste Update!
                                  • afuerhoff
                                    @ilovegym
                                    Der nächste Stand kann dann auch über den Namen die Anwesenheit abfragen. Hierzu muss er dann aber identisch sein zum Namen in der Fritzbox. Das müsste allen helfen, die die Verschleierung der Mac nicht deaktivieren können oder wollen.
                                    Beispiel Devices in der Fritzbox:
                                    Device 1: xxx-iPhone
                                    Mac:yy:xx: ...
                                    Aktiv: true
                                    Device 2: xxx-iPhone
                                    Mac:zz:xx: ...
                                    Aktiv: false
                                    Es wird dann geschaut, ob einer der Einträge in der Fritzbox aktiv ist und das wird dann als Anwesenheit zurückgegeben. Sind alle inaktiv das ist auch die Rückgabe inaktiv.
                                    Hierbei muss aber vom Anwender sichergestellt sein, das es Mac's vom gleichen Gerät sind. Ansonsten hat man nach obiger Logik die Anwesenheit von verschiedenen Geräten verodert.
                                      @afuerhoff Ah, sehr gut, dann kann ich unter gleichem Namen auch meine Smartwatch eintragen und ich bin dann erst abwesend, wenn Smartphone und! Smartwatch offline sind... zur Zeit mache ich das mit verschiedenen Namen und einem Script.. ( das Script fragt zusätzlich noch die Location vom Life360-Adapter ab).
                                        @afuerhoff Hab noch ein wichtiges Feature für deinen Adapter:
                                        ein DONATE Button für ne kleine Spende per Paypal.. 🙂
                                        Kommt zur Zeit sehr gut bei den Usern an 🙂
                                        • afuerhoff
                                          🙂 mal schauen
                                            @afuerhoff in den 90ern hab ich mit Shareware Hunderttausende gemacht.. also komm.. 🙂
                                            ( gut, damals gabs noch kein Internet, nur Z-Netz und Fido, die Software wurde auf Disketten in den Zeitschriften ausgeliefert.. :-))
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            249833
