    4. Test Adapter Linux Control v1.x.x
    • Scrounger
      Scrounger Developer @Stephan Schleich last edited by
      @Stephan-Schleich
      Puhh ok bin auch kein Linux experte.
      • timeout im adapter hoch geschraubt?
      • hat dein user ausreichende berechtigungen?
      • ssh login methode auf den clients prüfen (PasswordAuthentication yes)
      Stephan Schleich 1 Reply Last reply Reply Quote 0
      • Stephan Schleich
        Stephan Schleich @Scrounger last edited by
        @Scrounger Timeout hab ich auch schon angepasst und der Rest passt alles 😞
        • Scrounger
          Scrounger Developer @Stephan Schleich last edited by Scrounger
          @Stephan-Schleich
          Ok ich bau was ein, damit man besser sieht was der ping zurück gibt.
          Edit: ok ist eingebaut, teste die aktuelle version von github. Adapter auf debug und dann log ausgabe posten (keine Screenshot, gesamte logs!)
          • Stephan Schleich
            Stephan Schleich @Scrounger last edited by Stephan Schleich
            @Scrounger
            linux-control.0	2020-12-30 06:49:18.603	debug	(2333) getting data from ioBrokerPi (192.168.178.200:22) -> not enabled!
            linux-control.0	2020-12-30 06:49:18.603	debug	(2333) [refreshHost] Pi-hole (192.168.178.205:22): button 'linux-control.0.Pi-hole.refresh' subscribed
            linux-control.0	2020-12-30 06:49:18.549	debug	(2333) [getConnection] Host 'Pi-hole' (192.168.178.205:22) ping result: {"host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev
            linux-control.0	2020-12-30 06:49:18.549	info	(2333) [getConnection] Host 'Pi-hole' (192.168.178.205:22) seems not to be online
            linux-control.0	2020-12-30 06:49:18.544	info	(2333) getting data from Pi-hole (192.168.178.205:22, Adapter start)
            linux-control.0	2020-12-30 06:49:18.544	debug	(2333) [refreshHost] ioBroker (192.168.178.200:22): button 'linux-control.0.ioBroker.refresh' subscribed
            linux-control.0	2020-12-30 06:49:18.532	debug	(2333) [getConnection] Host 'ioBroker' (192.168.178.200:22) ping result: {"host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stdde
            linux-control.0	2020-12-30 06:49:18.531	info	(2333) [getConnection] Host 'ioBroker' (192.168.178.200:22) seems not to be online
            linux-control.0	2020-12-30 06:49:18.507	info	(2333) getting data from ioBroker (192.168.178.200:22, Adapter start)
            linux-control.0	2020-12-30 06:49:18.506	debug	(2333) [refreshHost] Proxmox (192.168.178.199:22): button 'linux-control.0.Proxmox.refresh' subscribed
            linux-control.0	2020-12-30 06:49:18.444	debug	(2333) [getConnection] Host 'Proxmox' (192.168.178.199:22) ping result: {"host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev
            linux-control.0	2020-12-30 06:49:18.443	info	(2333) [getConnection] Host 'Proxmox' (192.168.178.199:22) seems not to be online
            linux-control.0	2020-12-30 06:49:18.431	info	(2333) getting data from Proxmox (192.168.178.199:22, Adapter start)
            linux-control.0	2020-12-30 06:49:18.414	info	(2333) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.0, js-controller: 3.1.6
            linux-control.0	2020-12-30 06:49:18.367	info	(2333) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            linux-control.0	2020-12-30 06:49:18.365	debug	(2333) Plugin sentry Initialize Plugin (enabled=true)
            linux-control.0	2020-12-30 06:49:18.069	debug	(2333) statesDB connected
            linux-control.0	2020-12-30 06:49:18.069	debug	(2333) States connected to redis: 127.0.0.1:9000
            linux-control.0	2020-12-30 06:49:18.063	debug	(2333) States create System PubSub Client
            linux-control.0	2020-12-30 06:49:18.062	debug	(2333) States create User PubSub Client
            linux-control.0	2020-12-30 06:49:18.058	debug	(2333) Redis States: Use Redis connection: 127.0.0.1:9000
            linux-control.0	2020-12-30 06:49:18.058	debug	(2333) objectDB connected
            linux-control.0	2020-12-30 06:49:18.055	debug	(2333) Objects connected to redis: 127.0.0.1:9001
            linux-control.0	2020-12-30 06:49:18.047	debug	(2333) Objects client initialize lua scripts
            linux-control.0	2020-12-30 06:49:18.046	debug	(2333) Objects create User PubSub Client
            linux-control.0	2020-12-30 06:49:18.046	debug	(2333) Objects create System PubSub Client
            linux-control.0	2020-12-30 06:49:18.045	debug	(2333) Objects client ready ... initialize now
            linux-control.0	2020-12-30 06:49:18.027	debug	(2333) Redis Objects: Use Redis connection: 127.0.0.1:9001
            linux-control.0	2020-12-30 06:49:14.710	info	(31817) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            linux-control.0	2020-12-30 06:49:14.710	info	(31817) terminating
            linux-control.0	2020-12-30 06:49:14.710	info	(31817) cleaned everything up...
            linux-control.0	2020-12-30 06:49:14.709	info	(31817) Got terminate signal TERMINATE_YOURSELF
            • Scrounger
              @Stephan-Schleich
              Leider nicht das vollständige log, das brauch ich aber...
              Funktioniert bei Dir der ping adapter?
              • Stephan Schleich
                @Scrounger Ich hatte nicht mehr zum kopieren, war 1:1 ausm Log nachm Restart
                Den Ping Adapter hab ich gerade mal installiert, und dieser kann auch nicht pingen O_o
                Nach "sudo apt-get install iputils-ping --reinstall" an allen LXC Debian Buster Containern + Reboot funktioniert es nun.
                Scrounger 2 Replies Last reply Reply Quote 1
                • Scrounger
                  @Stephan-Schleich sagte in Test Adapter Linux Control v1.x.x:
                  Nö das ist der log ausm admin, deshlab abgeschnitten. Ich brauch das log aus iobroker/log/xy.log.
                  • Stephan Schleich
                    @Scrounger alles klar, merk ich mir für die Zukunft. Aber nun gehts ja 🙂
                    • Scrounger
                      Aber nun gehts ja 🙂
                      Perfekt, habs gleich mal mit in die Doku aufgenommen.
                      Stephan Schleich 1 Reply Last reply Reply Quote 1
                      • Stephan Schleich
                        @Scrounger Bei mir war aber scheinbar zwingend ein reboot erforderlich, vllt sollte man das noch mit ergänzen?
                        • Segway
                          Segway @Scrounger last edited by
                          @Scrounger
                          So, ich habe mal die Export / Import genutzt, da ich den Adapter auf ein anderes System umziehe !
                          Dabei sind mir 2 Sachen aufgefallen:
                          1. Wenn ich den json importiert habe, dann gibt die Oberfläche mir NICHT den Button speichern und schliessen frei ! Somit wird die geladene Konfiguration gar nicht abgespeichert. (Workaround: einfach unter Meine Befehle einen DP anlegen dann kommt der Button)
                          2. Anscheinend werden Username / Passwörter nicht richtig übernommen. Er kann sich mit den Clients nicht verbinden. Gebe ich manuell nochmal Username / Passwort ein, dann kann er sich connecten. Scheint aber auch nicht bei Allen zu sein ?
                          • Scrounger
                            Scrounger Developer @Segway last edited by
                            @Segway sagte in Test Adapter Linux Control v1.x.x:
                            Kann ich bestätigen, bitte erstell dazu ein issue
                            1. Anscheinend werden Username / Passwörter nicht richtig übernommen. Er kann sich mit den Clients nicht verbinden. Gebe ich manuell nochmal Username / Passwort ein, dann kann er sich connecten. Scheint aber auch nicht bei Allen zu sein ?
                            Passwörter werden nicht übernommen, da diese nicht im klartext abgespeichert werden sollten - Sicherheit!
                            Wenn das System gewechselt wird, ist auch der iob Schlüssel anders und deshalb werden die PWs nicht korrekt entschlüsselt.
                            • U
                              UncleB last edited by
                              Mahlzeit zusammen, genialer Adapter 🙂
                              Ich versetze meinen Rechner im die Bereitschaft "suspend"
                              Das funktioniert mit einem eigenen Befehl auch sehr gut "sudo -S pm-suspend"
                              Nun würde ich den Rechner über einen einfachen Taster gerne "wecken" finde hierzu keinen Befehl..
                              Vermutlich funktioniert das nur über WOL? Oder horcht der Rechner im Bereitschaftsmodus auf iwelche Befehle?
                                liv-in-sky @UncleB last edited by
                                @UncleB sollte nur über wol gehen oder geräte schalter
                                • dirk1962
                                  dirk1962 last edited by
                                  Hallo @Scrounger, ich habe unter Proxmox einmal ioBroker in einer VM und einmal im Container installiert.
                                  In der VM zeigt linux-control an, dass Proxmox online ist.
                                  2021-01-27 13:01:53.783 - info: host.ioBroker stopInstance system.adapter.linux-control.0 (force=false, process=true)
                                  2021-01-27 13:01:53.787 - info: linux-control.0 (10410) Got terminate signal TERMINATE_YOURSELF
                                  2021-01-27 13:01:53.787 - info: linux-control.0 (10410) cleaned everything up...
                                  2021-01-27 13:01:53.788 - info: linux-control.0 (10410) terminating
                                  2021-01-27 13:01:53.788 - debug: linux-control.0 (10410) Plugin sentry destroyed
                                  2021-01-27 13:01:53.788 - info: linux-control.0 (10410) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-01-27 13:01:53.827 - info: host.ioBroker stopInstance system.adapter.linux-control.0 send kill signal
                                  2021-01-27 13:01:54.312 - info: host.ioBroker instance system.adapter.linux-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-01-27 13:01:56.851 - info: host.ioBroker instance system.adapter.linux-control.0 started with pid 10426
                                  2021-01-27 13:01:57.208 - debug: linux-control.0 (10426) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2021-01-27 13:01:57.219 - debug: linux-control.0 (10426) Objects client ready ... initialize now
                                  2021-01-27 13:01:57.220 - debug: linux-control.0 (10426) Objects create System PubSub Client
                                  2021-01-27 13:01:57.221 - debug: linux-control.0 (10426) Objects create User PubSub Client
                                  2021-01-27 13:01:57.221 - debug: linux-control.0 (10426) Objects client initialize lua scripts
                                  2021-01-27 13:01:57.225 - debug: linux-control.0 (10426) Objects connected to redis: 127.0.0.1:9001
                                  2021-01-27 13:01:57.229 - debug: linux-control.0 (10426) objectDB connected
                                  2021-01-27 13:01:57.230 - debug: linux-control.0 (10426) Redis States: Use Redis connection: 127.0.0.1:9000
                                  2021-01-27 13:01:57.237 - debug: linux-control.0 (10426) States create System PubSub Client
                                  2021-01-27 13:01:57.238 - debug: linux-control.0 (10426) States create User PubSub Client
                                  2021-01-27 13:01:57.240 - debug: linux-control.0 (10426) States connected to redis: 127.0.0.1:9000
                                  2021-01-27 13:01:57.241 - debug: linux-control.0 (10426) statesDB connected
                                  2021-01-27 13:01:57.300 - debug: linux-control.0 (10426) Plugin sentry Initialize Plugin (enabled=true)
                                  2021-01-27 13:01:57.370 - info: linux-control.0 (10426) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.1, js-controller: 3.2.11
                                  2021-01-27 13:01:57.397 - info: linux-control.0 (10426) getting data from Proxmox (192.168.1.102:22, Adapter start)
                                  2021-01-27 13:01:57.464 - debug: linux-control.0 (10426) [distributionInfo] Proxmox (192.168.1.102:22): send command: 'cat /etc/os-release'
                                  2021-01-27 13:01:57.571 - debug: linux-control.0 (10426) [distributionInfo] Proxmox (192.168.1.102:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
                                  NAME="Debian GNU/Linux"
                                  VERSION_ID="10"
                                  VERSION="10 (buster)"
                                  VERSION_CODENAME=buster
                                  ID=debian
                                  HOME_URL="https://www.debian.org/"
                                  SUPPORT_URL="https://www.debian.org/support"
                                  BUG_REPORT_URL="https://bugs.debian.org/"
                                  2021-01-27 13:01:57.580 - debug: linux-control.0 (10426) [distributionInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
                                  2021-01-27 13:01:57.588 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get update'
                                  2021-01-27 13:01:58.831 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: Hit:1 http://security.debian.org buster/updates InRelease
                                  Hit:2 http://ftp.de.debian.org/debian buster InRelease
                                  Hit:3 http://security.debian.org/debian-security buster/updates InRelease
                                  Hit:4 http://ftp.de.debian.org/debian buster-updates InRelease
                                  Hit:5 http://download.proxmox.com/debian/pve buster InRelease
                                  Reading package lists...
                                  2021-01-27 13:01:58.832 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s[([\w,\-,\d,\.,~,:,\+]+)]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
                                  2021-01-27 13:01:59.145 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout:
                                  2021-01-27 13:01:59.145 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.newPackages: 0
                                  2021-01-27 13:01:59.148 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.upgradable: false
                                  2021-01-27 13:01:59.152 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
                                  ' -W | sort -nr | head -1'
                                  2021-01-27 13:01:59.165 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: 1611500573
                                  2021-01-27 13:01:59.166 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.lastUpdate: 1611500573000 -> 24.01.2021 16:02
                                  2021-01-27 13:01:59.213 - debug: linux-control.0 (10426) [servicesInfo] Proxmox (192.168.1.102:22): no datapoints selected -> removing existing datapoints
                                  2021-01-27 13:01:59.218 - debug: linux-control.0 (10426) [needrestart] Proxmox (192.168.1.102:22): no datapoints selected -> removing existing datapoints
                                  2021-01-27 13:01:59.222 - info: linux-control.0 (10426) successful received data from Proxmox (192.168.1.102:22)
                                  2021-01-27 13:01:59.228 - debug: linux-control.0 (10426) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.refresh' subscribed
                                  2021-01-27 13:01:59.229 - debug: linux-control.0 (10426) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpdate' subscribed
                                  2021-01-27 13:01:59.229 - debug: linux-control.0 (10426) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpgrade' subscribed
                                  Im Container zeigt linux-control an, dass Proxmox offline ist.
                                  2021-01-27 12:07:20.066 - info: host.ioBroker stopInstance system.adapter.linux-control.0 (force=false, process=true)
                                  2021-01-27 12:07:20.070 - info: host.ioBroker stopInstance system.adapter.linux-control.0 send kill signal
                                  2021-01-27 12:07:20.070 - info: linux-control.0 (22741) Got terminate signal TERMINATE_YOURSELF
                                  2021-01-27 12:07:20.070 - info: linux-control.0 (22741) cleaned everything up...
                                  2021-01-27 12:07:20.071 - info: linux-control.0 (22741) terminating
                                  2021-01-27 12:07:20.071 - debug: linux-control.0 (22741) Plugin sentry destroyed
                                  2021-01-27 12:07:20.071 - info: linux-control.0 (22741) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-01-27 12:07:20.638 - info: host.ioBroker instance system.adapter.linux-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-01-27 12:07:23.148 - info: host.ioBroker instance system.adapter.linux-control.0 started with pid 22795
                                  2021-01-27 12:07:23.494 - debug: linux-control.0 (22795) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2021-01-27 12:07:23.507 - debug: linux-control.0 (22795) Objects client ready ... initialize now
                                  2021-01-27 12:07:23.508 - debug: linux-control.0 (22795) Objects create System PubSub Client
                                  2021-01-27 12:07:23.509 - debug: linux-control.0 (22795) Objects create User PubSub Client
                                  2021-01-27 12:07:23.509 - debug: linux-control.0 (22795) Objects client initialize lua scripts
                                  2021-01-27 12:07:23.524 - debug: linux-control.0 (22795) Objects connected to redis: 127.0.0.1:9001
                                  2021-01-27 12:07:23.528 - debug: linux-control.0 (22795) objectDB connected
                                  2021-01-27 12:07:23.529 - debug: linux-control.0 (22795) Redis States: Use Redis connection: 127.0.0.1:9000
                                  2021-01-27 12:07:23.536 - debug: linux-control.0 (22795) States create System PubSub Client
                                  2021-01-27 12:07:23.537 - debug: linux-control.0 (22795) States create User PubSub Client
                                  2021-01-27 12:07:23.546 - debug: linux-control.0 (22795) States connected to redis: 127.0.0.1:9000
                                  2021-01-27 12:07:23.546 - debug: linux-control.0 (22795) statesDB connected
                                  2021-01-27 12:07:23.714 - debug: linux-control.0 (22795) Plugin sentry Initialize Plugin (enabled=true)
                                  2021-01-27 12:07:23.784 - info: linux-control.0 (22795) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.1, js-controller: 3.2.11
                                  2021-01-27 12:07:23.806 - info: linux-control.0 (22795) getting data from Proxmox (192.168.1.102:22, Adapter start)
                                  2021-01-27 12:07:23.814 - info: linux-control.0 (22795) [getConnection] Host 'Proxmox' (192.168.1.102:22) seems not to be online
                                  2021-01-27 12:07:23.815 - debug: linux-control.0 (22795) [getConnection] Host 'Proxmox' (192.168.1.102:22) ping result: {"host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev":"unknown","packetLoss":"unknown"}
                                  2021-01-27 12:07:23.872 - debug: linux-control.0 (22795) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.refresh' subscribed
                                  VM und Container sind mit Debian 10.7.0-amd64.
                                  Du hast doch iobroker auch im Container und bei Dir funktioniert es wie ich am Material Design Widget von Dir gesehen habe. Hast Du eine Idee, warum es bei mir nicht funktioniert?
                                  • Scrounger
                                    Scrounger Developer @dirk1962 last edited by Scrounger
                                    @dirk1962
                                    Ja ber mein lxc läuft auf ubunut 20 basis.
                                    Schätze es dieses Problem, da er den nicht anpingen kann, gleiches wird auch beim ping adapter wahscheinlich der Fall sein:
                                    https://github.com/Scrounger/ioBroker.linux-control#known-issues
                                    Schau mal weiter oben hier, da gabs das thema schon.
                                    dirk1962 1 Reply Last reply Reply Quote 1
                                    • dirk1962
                                      dirk1962 @Scrounger last edited by
                                      @scrounger Danke für die schnelle Rückmeldung. Dann mach ich den Container mit Ubuntu.
                                      • Scrounger
                                        @dirk1962 installiert doch einfach iputils-ping. Dann sollte es gehen
                                        dirk1962 1 Reply Last reply Reply Quote 0
                                        • dirk1962
                                          @scrounger das ist schon installiert. Muss ich dann noch was machen?
                                          • Scrounger
                                            @dirk1962
                                            Da ich das problem nicht kenne, kann ich nicht viel dazu sagen, aber hier gabs genau das gleiche thema:
                                            https://forum.iobroker.net/topic/35870/test-adapter-linux-control-v1-x-x/253?_=1611757704506
                                            adapter control hardware linux steuern
                                            70
                                            675
                                            163900
