    • Z
      Zelkin @jomjol last edited by
      @jomjol
      Hier noch die Ausgabe nachdem Ich nochmals Erase und Flash mit dem Download Tool hab laufen lassen:
      [2020-12-30 20:40:43,388][CombinePanel_ESP32_spi][Panel_Combine.py][line:473][INFO]: switch do not chg bin : 0
      [2020-12-30 20:41:11,651][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:376][INFO]: test baudrate: 921600
      [2020-12-30 20:41:51,621][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:400][INFO]: ************
      [2020-12-30 20:41:51,622][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:401][INFO]: check_res: (True, [])
      [2020-12-30 20:41:51,622][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:402][INFO]: is running : False
      [2020-12-30 20:41:51,624][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:403][INFO]: ************
      [2020-12-30 20:41:51,624][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:494][INFO]: *********************
      [2020-12-30 20:41:51,624][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:495][INFO]: pic path: ./RESOURCE/IDLE_S.bmp
      [2020-12-30 20:41:51,625][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:496][INFO]: ***********************
      [2020-12-30 20:41:51,644][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:434][INFO]: TEST!!!!
      [2020-12-30 20:41:51,644][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:435][INFO]: SELF.COMSTR: COM5
      [2020-12-30 20:41:51,644][EspDownloadThread][download_panel_info.py][line:788][INFO]: test running: False
      CONNECT BAUD: 115200
      [2020-12-30 20:41:51,859][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:494][INFO]: *********************
      [2020-12-30 20:41:51,859][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:495][INFO]: pic path: ./RESOURCE/SYNC_S.bmp
      [2020-12-30 20:41:51,859][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:496][INFO]: ***********************
      .Uploading stub...
      Running stub...
      Stub running...
      Changing baud rate to 921600
      Changed.
      [2020-12-30 20:41:53,180][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:494][INFO]: *********************
      [2020-12-30 20:41:53,180][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:495][INFO]: pic path: ./RESOURCE/DOWNLOAD_S.bmp
      [2020-12-30 20:41:53,180][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:496][INFO]: ***********************
      [2020-12-30 20:41:53,654][ESP8266Loader_spi[1]][espDownloader.py][line:619][INFO]: status[before]: 0x400000
      [2020-12-30 20:42:02,815][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:494][INFO]: *********************
      [2020-12-30 20:42:04,908][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:495][INFO]: pic path: ./RESOURCE/FINISH_S.bmp
      [2020-12-30 20:42:04,910][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:496][INFO]: ***********************
      [2020-12-30 20:42:17,321][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:400][INFO]: ************
      [2020-12-30 20:42:17,322][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:401][INFO]: check_res: (True, [])
      [2020-12-30 20:42:17,322][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:402][INFO]: is running : False
      [2020-12-30 20:42:17,322][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:403][INFO]: ************
      [2020-12-30 20:42:17,322][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:494][INFO]: *********************
      [2020-12-30 20:42:17,322][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:495][INFO]: pic path: ./RESOURCE/IDLE_S.bmp
      [2020-12-30 20:42:17,322][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:496][INFO]: ***********************
      [2020-12-30 20:42:17,346][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:434][INFO]: TEST!!!!
      [2020-12-30 20:42:17,346][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:435][INFO]: SELF.COMSTR: COM5
      [2020-12-30 20:42:17,346][EspDownloadThread][download_panel_info.py][line:788][INFO]: test running: False
      [2020-12-30 20:42:17,563][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:494][INFO]: *********************
      [2020-12-30 20:42:17,563][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:495][INFO]: pic path: ./RESOURCE/SYNC_S.bmp
      [2020-12-30 20:42:17,565][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:496][INFO]: ***********************
      ....._____....._____.....____[2020-12-30 20:42:28,509][ESP8266Loader_spi[1]][espDownloader.py][line:1538][INFO]: Disabling the rom console...
      Efuse CONSOLE_DEBUG_DISABLE is already burned.
      Uploading stub...
      Running stub...
      Stub running...
      Changed.
      [2020-12-30 20:42:29,388][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:494][INFO]: *********************
      [2020-12-30 20:42:29,388][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:495][INFO]: pic path: ./RESOURCE/DOWNLOAD_S.bmp
      [2020-12-30 20:42:29,388][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:496][INFO]: ***********************
       is stub and send flash finish
      [2020-12-30 20:42:31,476][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:494][INFO]: *********************
      [2020-12-30 20:42:31,476][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:495][INFO]: pic path: ./RESOURCE/FINISH_S.bmp
      [2020-12-30 20:42:31,476][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:496][INFO]: ***********************
      Ich hoffe du wirst daraus Schlau
      • Z
        @jomjol
        OK
        Hab eben gemarkt das Ich ein IDI........ bin
        hatte im Download Tool vergessen die 3 Dateien anzuhaken ..... 🤦‍♂️
        nun bekomme Ich auch schon eine andere Asugabe ... aber leider dennoch ein fehler:
        C:\AI-on-the-edge-device-4.1.1\firmware\bootloader.bin
        C:\AI-on-the-edge-device-4.1.1\firmware\partitions.bin
        C:\AI-on-the-edge-device-4.1.1\firmware\firmware.bin
        test offset :  4096 0x1000
        case ok
        test offset :  32768 0x8000
        case ok
        test offset :  65536 0x10000
        case ok
        [2020-12-30 20:53:55,696][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:400][INFO]: ************
        [2020-12-30 20:53:55,697][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:401][INFO]: check_res: (True, [[u'C:\\AI-on-the-edge-device-4.1.1\\firmware\\bootloader.bin', 4096], [u'C:\\AI-on-the-edge-device-4.1.1\\firmware\\partitions.bin', 32768], [u'C:\\AI-on-the-edge-device-4.1.1\\firmware\\firmware.bin', 65536]])
        [2020-12-30 20:53:55,697][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:402][INFO]: is running : False
        [2020-12-30 20:53:55,697][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:403][INFO]: ************
        Traceback (most recent call last):
          File "download_panel_info.py", line 451, in OnButton_EraseButton
          File "download_panel_info.py", line 421, in start_func
          File "download_panel_info.py", line 703, in flash_config
        UnicodeDecodeError: 'gb2312' codec can't decode bytes in position 40-41: illegal multibyte sequence
        • Z
          @jomjol
          Man Man
          Danke für die Hilfe
          Nach dem Neustart des Download Tool hat sich nun auch der fehler verabschiedet ..........
          Neustart des ESP und ..... jup da drückt er aufn knopf und er geht
          Danke nochmal
          • MichMein
            MichMein @pfried last edited by
            @pfried sagte in Wasserzähler - Version 2 - all-in-device:
            @MichMein Wenn du zurück auf den letzten Master gehst, besteht dann weiterhin das Problem bei Dir?
            Habe ich nicht getestet da ich ungern auf die neuen Funktionen im Rolling verzichten wollte. Aber wie @jomjol geschrieben sollten die Fehler im Master ja nicht auftauchen.
            J pfried 2 Replies Last reply Reply Quote 0
              jomjol @Zelkin last edited by
              @Zelkin Gerne!
                jomjol @MichMein last edited by
                @MichMein sagte in Wasserzähler - Version 2 - all-in-device:
                Ich bin gerade im Internet noch auf eine andere Spur gestossen: die Übertragung des Bildes von der OV2640 insbesondere in den RAM könnte an die Grenzen des PSRAMs stoßen und damit zu unberechenbaren Fehlern führen. Habe eine Idee für eine Anpassung dazu gerade im Testlauf.
                Morgen bin ich schlauer.
                MichMein J 2 Replies Last reply Reply Quote 0
                • MichMein
                  MichMein @jomjol last edited by
                  @jomjol sagte in Wasserzähler - Version 2 - all-in-device:
                  Du bist heute auch schon schlauer wie so manch andere unter uns 🤣
                  Danke für Deine Mühen!
                  • pfried
                    pfried @MichMein last edited by
                    @MichMein Kannst Du mir bitte bei den IOBroker MQTT Einstellungen helfen?
                    Ist das so richtig?
                    MichMein 1 Reply Last reply Reply Quote 0
                      jomjol @jomjol last edited by
                      Hat geklappt - Ursache ist ein Limit in der Übertragung des internen Kameraspeichers in den ESP32 für die Weiterverarbeitung. Das hier das relativ langsame PSRAM verwendet wird, stößt man hier je nach Größe des jpg-codierten Bildes an die Limits.
                      Ich habe über Nacht den Takt der Kamera gedrosselt. Damit liefert sie die Daten langsamer und siehe da, es lief jetzt 120 Runden ohne Probleme durch.
                      Ich muss jetzt die ganzen Debugging Details wieder deaktivieren und den Code etwas aufräumen, dann lade ich noch dieses Jahr (😊 ) eine neue Rolling hoch.
                      Gebe euch hier dann kurz Bescheid.
                      pfried MichMein 2 Replies Last reply Reply Quote 1
                      • pfried
                        pfried @jomjol last edited by
                        @jomjol Super! Werde dann gleich testen!
                        • MichMein
                          @pfried Hallo, meine Einstellungen sehen auch so aus wie bei Dir.
                          • MichMein
                            @jomjol Das klingt ja nach nem super Jahresabschluss 🍾
                              @MichMein @pfried
                              Neue Version ist hochgeladen. Hatte gerade das Ereignis, dass die Oberfläche nicht reagiert hat, bin aber auch Remote mit schlechter Netzverbindung unterwegs. Wenn euch was auffällt, bitte gerne sofort melden.
                              Gruß und guten Rutsch!
                              jomjol
                              F MichMein 2 Replies Last reply Reply Quote 0
                                Feinfinger @jomjol last edited by
                                @jomjol
                                Ist installiert, ohne Fehler.
                                Bin mal gespannt, ob das häufige rebooten jetzt weg ist, ich hatte das übrigens auch mit der lezten master Version.
                                Hat mich aber nie gestört, da ja die Werte immer gepasst haben.
                                • MichMein
                                  @jomjol Ist installiert, allerdings habe ich bei einem meiner ESPs das Problem das er das Bild nicht mehr drehen möchte. Ich werde es mal neu parametrisieren, untersuchen und dan berichten.
                                  pfried 1 Reply Last reply Reply Quote 0
                                  • pfried
                                    @all: Guten Rutsch ins neue (hoffentlich bessere) Jahr 2021! 🍾
                                    • MichMein
                                      Hallo @jomjol,
                                      den einen ESP für den Gaszähler hat es scheinbar zerrissen, der möchte nicht mehr so richtig. Es sind aber bereits drei neue ESPs im Anflug und sollten nächste Woche hier sein. Ich habe es mit allen möglichen Firmware Versionen getestet und er startet immer wieder neu 😞 .
                                      2020-12-31_18-18-40: Reboot - now
                                      2020-12-31_18-19-12: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-19-12: =============================================================================================
                                      2020-12-31_18-19-12: =================================== Main Started ============================================
                                      2020-12-31_18-19-16: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-19-19: task_autodoFlow - next round - Round #1
                                      2020-12-31_18-19-47: logfileact_get_handler
                                      2020-12-31_18-20-39: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-20-39: =============================================================================================
                                      2020-12-31_18-20-39: =================================== Main Started ============================================
                                      2020-12-31_18-20-43: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-20-49: task_autodoFlow - next round - Round #1
                                      2020-12-31_18-21-25: logfileact_get_handler
                                      2020-12-31_18-22-07: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-22-07: =============================================================================================
                                      2020-12-31_18-22-07: =================================== Main Started ============================================
                                      2020-12-31_18-22-11: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-22-13: task_autodoFlow - next round - Round #1
                                      2020-12-31_18-23-32: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-23-32: =============================================================================================
                                      2020-12-31_18-23-32: =================================== Main Started ============================================
                                      2020-12-31_18-23-36: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-23-38: task_autodoFlow - next round - Round #1
                                      2020-12-31_18-24-55: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-24-55: =============================================================================================
                                      2020-12-31_18-24-55: =================================== Main Started ============================================
                                      2020-12-31_18-24-59: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-25-01: task_autodoFlow - next round - Round #1
                                      2020-12-31_18-26-20: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-26-20: =============================================================================================
                                      2020-12-31_18-26-20: =================================== Main Started ============================================
                                      2020-12-31_18-26-24: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-26-28: task_autodoFlow - next round - Round #1
                                      2020-12-31_18-27-47: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-27-47: =============================================================================================
                                      2020-12-31_18-27-47: =================================== Main Started ============================================
                                      2020-12-31_18-27-51: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-27-57: task_autodoFlow - next round - Round #1
                                      2020-12-31_18-29-17: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-29-17: =============================================================================================
                                      2020-12-31_18-29-17: =================================== Main Started ============================================
                                      2020-12-31_18-29-21: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-29-23: task_autodoFlow - next round - Round #1
                                      2020-12-31_18-30-42: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-30-42: =============================================================================================
                                      2020-12-31_18-30-42: =================================== Main Started ============================================
                                      2020-12-31_18-30-46: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-30-48: task_autodoFlow - next round - Round #1
                                      2020-12-31_18-32-07: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-32-07: =============================================================================================
                                      2020-12-31_18-32-07: =================================== Main Started ============================================
                                      2020-12-31_18-32-11: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-32-15: task_autodoFlow - next round - Round #1
                                      2020-12-31_18-33-34: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-33-34: =============================================================================================
                                      2020-12-31_18-33-34: =================================== Main Started ============================================
                                      2020-12-31_18-33-38: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                      2020-12-31_18-33-40: logfileact_get_handler
                                      Mal abwarten das neue Jahr so bringen wird.
                                      Ich kann mich den Worten von @pfried nur anschliessen und wünsche ebenfalls allen einen schönen Abend und einen guten Rutsch 🎆
                                      Bis nächtes Jahr 👋
                                      • pfried
                                        @MichMein Bei mir hat sich auch der Gaszähler aufgehängt. Schaue Dir mal die SD Karte an, die war bei mir zerstört. Habe diese gelöscht, neu formattiert und die Sicherung der SD Karte wieder aufgespielt. Den ESP Flash habe ich gelöscht und den Master neu aufgespielt. Siehe da, das System läuft wieder! Denke aber, es war die zerstörte SD Karte (hat auf einmal mehrere Partitionen drauf). LG Paul
                                        • MichMein
                                          @pfried Hi,
                                          ja ich habe vorhin meine SD auch nochmal formatiert und er läuft erstmal wieder, nur er sendet nicht die aktuellen Daten per MQTT. Mal schauen was @jomjol zu meinem Issue auf github so sagt.
                                          Aber danke für den Tip.
                                            @pfried Hi,
                                            Beim MQTT habe ich eigentlich nichts geändert - hast du mal deine alte und neue Config.ini verglichen?
                                            Der Fehler könnte von CheckDigitIncreaseConsistency kommen. Ich habe es jetzt in der neuen Default-Konfiguration deaktiviert. Falls es nicht daran liegt, bitte kurze RM, dann schaue ich es mir nochmal an.
                                            pfried MichMein 2 Replies Last reply Reply Quote 0
                                            237
                                            3409
                                            1928580
