    4. Ereignisliste erzeugen
    • sissiwup
      sissiwup last edited by
      hab es oben angepasst. Geht jetzt mit neuen TimeStamps
      • Bluefox
        Bluefox last edited by
        Vielleicht wird so was interessant.
        Alle events werden aus dem history/sql Adapter gelesen.
        `/* Read events from history adapter.
           Define the list of IDs, that must be shown.
           Additionally for every ID the display name and number of events can be defined.
        var historyInstance = 'sql.0'; // can be history adapter too
        // ofcourse all IDs must be enabled for history
        var states = {
            "javascript.0.graph.minutes"/*graph.minutes*/:      { name: 'Minutes', count: 15},
            "system.adapter.admin.0.memRss"/*admin.0.memRss*/ : { name: 'Memory'}
        var timeout = null; // de-bounce
        // create variable, where the list will be stored
        createState('eventList', '', function () {
            //first execute
            readAllEvents();
        function publishEvents(events) {
            // AS HTML
            /*var table = '';
            for (var e = 0; e < events.length; e++) {
                table += '';
            table += '
        | ' + formatDate(events[e].time, 'hh:mm:ss.sss') + ' | ' + states[events[e].id].name + ' | ' + events[e].val + ' |
            // as JSON
               events[e].time = formatDate(events[e].time, 'hh:mm:ss.sss');
               events[e].id   = states[events[e].id].name || events[e].id;
            setState('eventList', JSON.stringify(events), true);
        function readOneId(id, number, events, cb) {
            var end = new Date().getTime();
            sendTo(historyInstance, 'getHistory', {
                options: {
                    end:        end,
                    aggregate: 'none',
                    count:      number || 10
            }, function (result) {
                if (result.result) {
                    for (var i = 0; i < result.result.length; i++) {
                        events.push({id: id, time: result.result[i].ts, val: result.result[i].val});
                cb();
        // read events for all IDs
        function readAllEvents() {
            timeout = null;
            var ready = 0;
            var events = [];
            for (var id in states) {
                ready++;
                readOneId(id, 10, events, function () {
                    if (!--ready) {
                        events.sort(function (a, b) {
                            if (a.time < b.time) return 1;
                            if (a.time > b.time) return -1;
                            return 0;
                        publishEvents(events);
        // subscribe on all changes
            on(id, function () {
                if (timeout) return;
                // de-bounce creation
                timeout = setTimeout(readAllEvents, 500);
         ![48_2016-05-25_23_51_20-edit_vis.png](/assets/uploads/files/48_2016-05-25_23_51_20-edit_vis.png)
        Widget:
        >! ~~[spoiler]~~`~~[code]~~[{"tpl":"tplTableBody","data":{"visibility-cond":"==","visibility-val":1,"static_value":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-oid":"javascript.0.eventList","colCount":"3","colName1":"Time","colWidth1":"60px","colAttr1":"time","table_oid":"javascript.0.eventList","colName2":"Event","colWidth2":"80px","colAttr2":"id","colName3":"Value","colWidth3":"60px","colAttr3":"val","hide_header":false,"class":""},"style":{"left":"760px","top":"315px","width":"332px","height":"200px"},"widgetSet":"basic"}][/code]`[/spoiler][/i][/i]
          ChristianF last edited by
          Ich danke ebenfalls sehr für dieses Script, ist eine tolle Sache !
          Allerdings habe ich mit diesem Abschnitt so meine Probleme:
              var rooms ={"ST-05" : "OG Balkontür", "ST-02" : "OG Wohnzimmer BW", "ST-03" : "EG Treppenhaustür"
                , "ST-01" : "EG Wintergarten" , "ST-04" : "EG Eingangstür"
                , "BW-01" : "UG Garage" , "BW-02" : "EG Wintergarten" , "BW-03" : "OG Wohnzimmer"
                , "VS-01" : "EG Eingangstür" , "VS-02" : "UG Eingangstür" , "VS-03" : "UG Waschküche"
                , "VS-04" : "UG Garagentor" , "VS-05" : "EG Balkontür Atrium" , "VS-06" : "EG Relaxraum"
                , "VS-07" : "OG Balkontür" , "VS-08" : "OG Dachfenster" , "VS-09" : "EG Katzen R"
                , "VS-10" : "EG Katzen L" , "VS-11" : "EG Wintergarten" , "VS-12" : "EG Wohnzimmerfenster"
                , "VS-13" : "EG Küche L" , "VS-14" : "EG Küche R" , "VS-15" : "EG Abstellkammer"
                , "VS-16" : "EG Trepphaus" , "VS-17" : "OG Gästezimmer" , "VS-18" : "OG Ankleidezimmer"
          Wie muss ich das an meine Räume anpassen? Was muss dort genau stehen? Ich bin ein bisschen lost..
          Danke!
          Viele grüße
          Christian
            pix last edited by
            Wenn ich das richtig sehe, ist das eine etwas unglückliche Textformatierung, die dir Probleme macht.
            var rooms = {
                "ST-05": "OG Balkontür",
                "ST-02": "OG Wohnzimmer BW",
                "ST-03": "EG Treppenhaustür",
                "ST-01": "EG Wintergarten",
                "ST-04": "EG Eingangstür",
                "BW-01": "UG Garage",
                "BW-02": "EG Wintergarten",
                "BW-03": "OG Wohnzimmer",
                "VS-01": "EG Eingangstür",
                "VS-02": "UG Eingangstür",
                "VS-03": "UG Waschküche",
                "VS-04": "UG Garagentor",
                "VS-05": "EG Balkontür Atrium",
                "VS-06": "EG Relaxraum",
                "VS-07": "OG Balkontür",
                "VS-08": "OG Dachfenster",
                "VS-09": "EG Katzen R",
                "VS-10": "EG Katzen L",
                "VS-11": "EG Wintergarten",
                "VS-12": "EG Wohnzimmerfenster",
                "VS-13": "EG Küche L",
                "VS-14": "EG Küche R",
                "VS-15": "EG Abstellkammer",
                "VS-16": "EG Trepphaus",
                "VS-17": "OG Gästezimmer",
                "VS-18": "OG Ankleidezimmer"
            Wenn du dir nun die Ausgabe ansiehst: 261_bildschirmfoto_202015-09-06_20um_2020.46.22.png Es sind also nur Bezeichnungen.
            Das Skript lauscht auf deine Sensoren an anderer Stelle:
            var sensorsST = $('channel[state.id=*.STATE](functions=ST)').each(function(id) {
                var val = getObject(id).common.name;
                log("DeviceST=" + val);
            var sensorsVS = $('channel[state.id=*.STATE](functions=VS)').each(function(id) {
                log("DeviceVS=" + val);
            var sensorsBW = $('channel[state.id=*.MOTION](functions=BW)').each(function(id) {
                log("DeviceBW=" + val);
            var vAlarmanlage = $('state[id="hm-rega.0.3747"]').each(function(id) {
                log("Alarmanlage=" + val);
            Es lauscht in den Gewerken ST, BW, VS (vermute BW= Bewegungsmelder, VS= Verschluss, ST ???), ob die angegebenen Datenpunkte sich ändern. Dazu wird auf die REGA-Variable Alarmanlage gelauscht.
            Pix
              michihorn last edited by
              @ruhr70:
              @Fitti:
              Wofür hast Du es entwickelt, was machst Du damit dann? `
              Um "wichtige" Ereignisse des Tages in einer Liste darzustellen, die dann in Vis mit eingebunden ist.
              Ich lasse mir z.B. u.a. folgende Punkte anzeigen:
              • Anwesenheiten
              • Haustür geöffnet
              • Internetausfall / neue IP-Adresse
              • Anrufe in Abewesenheit
              • Änderungen von Logikschaltern (Logik ein/aus)
              • Änderung von diversen Variablen
              Die letzten 30 Ereignisse werden in einer Liste in VIS dargestellt. `
              Hallo
              wie realisierst Du denn Internetausfall?
              Michael
                kirbsi last edited by
                @sissiwup:
                um eine Ereignisliste:
                filename="Bildschirmfoto 2015-09-06 um 20.46.22.png" index="0">~~
                zu erzeugen, kann man folgendes Skript verwenden:
                `createState("vEreignisse","
                *   first
                function ereignis(text) {
                    log("ereignis "+text);
                    var ereignisStr = getState("vEreignisse").val;
                    var ereignisArr;
                    ereignisArr = ereignisStr.replace(/`
                `*   /, "").replace(/<\/li><\/ul>/, "").split("*   ");
                        ereignisArr = ereignisArr.reverse();
                        ereignisArr.push(text);
                        ereignisArr.reverse().splice(99); // Liste auf 20 Einträge beschränken
                        var str = ereignisArr.join("`
                        setState("vEreignisse", "
                    *   "+str+"
                    function timestamp(ts) {
                        var now=new Date(ts);
                        var day = now.getDate();
                        var month = now.getMonth() + 1;
                        var year = now.getFullYear();
                        var weekday = now.getDay();
                        var hours = now.getHours();
                        var minutes = now.getMinutes();
                        var seconds = now.getSeconds();
                        var day0  = ((day < 10) ? "0" : "");
                        var month0  = ((month < 10) ? "0" : "");
                        var hours0  = ((hours < 10) ? "0" : "");
                        var minutes0  = ((minutes < 10) ? "0" : "");
                        var seconds0  = ((seconds < 10) ? "0" : "");
                        var output = year + "-" + month0 + month + "-" + day0 + day + " " + hours0 + hours + ":" + minutes0 + minutes + ":" + seconds0 + seconds;
                        return output;
                    function room(obj) {
                        var devname=obj.deviceName;
                        var dp = getObject(obj.id,"rooms");
                        var raum=dp.enumNames;
                    //    var raum="---";
                        if (devname in rooms) {
                            return rooms[devname];
                        return raum;
                    sensorsST.on(function(obj) {
                      var aktion="AUTO";
                      if (obj.newState.val == 1) {
                        aktion="OFF";
                      var ts=timestamp(obj.newState.ts);
                        ereignis(ts + " " + obj.deviceName + " " + room(obj) + " " + aktion);
                    //    log("OBJ=" + JSON.stringify(obj,null,2));
                    sensorsVS.on(function(obj) {
                      var aktion="ZU";
                        aktion="AUF";
                    sensorsBW.on(function(obj) {
                        ereignis(ts + " " + obj.deviceName + " " + room(obj) + " " + "Bewegung");
                    vAlarmanlage.on(function(obj) {
                      var aktion="Haus alles gesichert";
                        aktion="im Haus/Lüften";
                      if (obj.newState.val == 2) {
                        aktion="OFF";
                        ereignis(ts + " Alarmstatus: " + aktion);
                    mit den Funktionen sensorsXX Frage ich alle Sensoren, die zu einer Gruppe gehören ab,
                    bei VS = Verschluß, BW = Bewegung und ST = Statusänderung/Schalter
                    mit vAlarmanlage Frage ich einen einzelnen Datenpunkt ab, hier eine Variable.
                    Im unteren Bereich des Skriptes muss zu jeder Funktion eine *.on Funktion dazu erstellt werden.
                    Diese kann je nach Geräteart die Ausgabe umformulieren.
                    UPDATE: Angepasst an neue Timestamps!
                Ich bekomme es nicht so schön dargestellt mit diesem skript. Welches widget nutzt ihr?
                • ruhr70
                  ruhr70 last edited by
                  @michihorn:
                  @ruhr70:
                  • Anwesenheiten
                  • Haustür geöffnet
                  Hallo
                  Michael `
                  Oh… sorry. Hab die Frage irgendwie übersehen.
                  Momentan nicht aktiv. Aber das war simpel gelöst.
                  Drei "größere" externe Adressen (1x per IP, 2x per URL) mit dem PING Adapter überwacht. Wenn alle drei dreimal hintereinander nicht erreichbar sind, wurde das als Internetausfall gewertet und in die Ereignisliste geschrieben. Zusätzlich habe ich regelmässig die öffentlcihe IP-Adresse abgefragt und bei Änderung diese auch in die Ereignisliste geschrieben (das war einmal täglich Nachts, nach der Zwangstrennung).
                  Internetausfall wurde zusätzlich im Haus per Sonos angesagt.
                  • ruhr70
                    @kirbsi:
                    Ich bekomme es nicht so schön dargestellt mit diesem skript. Welches widget nutzt ihr? `
                    Bei mir ist es ein "basic - html", da ich Infos tlw. farbig hervorhebe.
                      Wie bekommst du es denn mit Basic HTML dargestellt. Komme doch gar nicht auf meine Objekt ID?
                      • ruhr70
                        @kirbsi:
                        Wie bekommst du es denn mit Basic HTML dargestellt. Komme doch gar nicht auf meine Objekt ID? `
                        Ich baue die Ereignislisten als Text mit html-Formatierungen auf und verweise auf den den Datenpunkt mit geschfeiten Klammern {Datentenpunkt_ID}.
                          Vielen Dank. Hat super geklappt. Kannst du mir noch n Tip geben wie du das mit den Farben gemacht hast?
                          • ruhr70
                            @kirbsi:
                            Vielen Dank. Hat super geklappt. Kannst du mir noch n Tip geben wie du das mit den Farben gemacht hast? `
                            Im Text des Ereignis html-Formatierungen einbauen:
                            event('ioBroker - **Update für ' + obj.state.val + '** Adapter verfügbar.');
                            event() ist bei mir eine kurze globale Funktion, mit der ich aus jedem Skript ein Ereignis schreiben kann.
                            In den Ereignissen, in den ich was farbig oder fett darstellen lassen möchte, formatiere ich das mit .
                              Ja das kann ich leider nicht mehr nachvollziehen.
                              • ruhr70
                                @kirbsi:
                                Ja das kann ich leider nicht mehr nachvollziehen. `
                                Am Beispiel oben:
                                hallo
                                Das hallo würde nun rot ausgegeben.
                                • htrecksler
                                  htrecksler Forum Testing last edited by
                                  @ruhr70
                                  kannst Du mir verraten wie Du das mit dem 3 mal hintereinander gemacht hast?
                                  Wenn ich mit "on" subscribe reagiert er nur dann wenn der der Ping von TRUE auf FALSE ändert (und umgekehrt)
                                  Bleibt der Status gleich passiert nichts.
                                  var oldState = null;
                                  var newState = null;
                                  on("ping.0.IntelNuc.192_168_XXX_XX", function (obj) {
                                       newState = obj.state;
                                       oldState = obj.oldState;
                                       log('Test-' + 'NewState: '+ newState.val + '-' + 'OldState: ' + oldState.val);
                                  Der Logeintrag wird nur dann geschrieben wenn ich am Handy WLAN aus bzw einschalte.
                                  • ruhr70
                                    @htrecksler:
                                    emacht hast?
                                    Bleibt der Status gleich passiert nichts. `
                                    Schau mal bitte unter: https://github.com/ioBroker/ioBroker.ja … some-state
                                    Du musst den Parameter "change" anders einstellen.
                                    "ne" ist Default (keine Änderung des Datenpunkts.
                                    Dann baust Du einen Zähler, der, in meinem Beispiel, bei einmal "true" immer auf 0 gesetzt wird und der hochzählt, sobald alle der überwachten Pings auf "false"stehen. Die Grenze ist dann z.B. drei.
                                    • htrecksler
                                      OK, Danke … den Defaultwert für change hatte ich verdrängt.
                                      Ich probiere es nachher aus. Danke für schnelle Hilfe.
                                      EDIT: probiert...kaum macht man es richtig...funktioniert's. Danke nochmal
                                        PrinzEisenherz1 last edited by
                                        @ruhr70:
                                        @kirbsi:
                                        In den Ereignissen, in den ich was farbig oder fett darstellen lassen möchte, formatiere ich das mit . `
                                        Hi ruhr70!
                                        Könntest Du mir vielleicht das genauer erklären wie Du das mit der globalen Funktion umgesetzt hast?
                                        Ich habe da n paar Scripte wo ich gerne n Ereignis an die Ereignissliste übergeben möchte.
                                        Des weiteren hab ich nämlich das Problem wenn ich z.B ein Javascript-Objekt auslesen möchte
                                        var vBewegungGarten = $('state[id="javascript.0.Garten.Bewegung"]').each(function(id) {
                                            log("Garten=" + val);
                                        vBewegungGarten.on(function(obj) {
                                          if (obj.newState.val === 0) {
                                            var aktion="Bewegung erkannt";
                                            ereignis(ts + " Garten: " + aktion);
                                        Dann steigt irgendwie das Script bzw der Javascript-Adapter aus.
                                        Könntest Du mir da vielleicht weiterhelfen?
                                        Vielen Dank im voraus
                                        Gruß Johnny
                                        • ruhr70
                                          @PrinzEisenherz1:
                                          Ich habe da n paar Scripte wo ich gerne n Ereignis an die Ereignissliste übergeben möchte. `
                                          ne, ist zu peinlich das zu schreiben 😉
                                          Das globale Skript: :roll:
                                          function event(text) {
                                              setState("javascript.0.Ereignisliste.event",text);
                                          Und dann das Skript für die Ereignisse als normales Skript. Überwachung des Datenpunkts im Ereignislistenskript. Erstellung der Ereignisliste.
                                          Über einen zweiten Parameter könnte man jetzt noch einbauen, dass unterschiedliche Datenpunkte gefüllt werden, um unterschiedliche Ereignislisten global anzusteuern.
                                          Das wars dann schon.
                                          @PrinzEisenherz1:
                                          Könntest Du mir da vielleicht weiterhelfen? `
                                          Ich weiss nicht, ob ich Dir da helfen kann. Mit dem Selector habe ich recht wenig Erfahrung und die Infos sind jetzt etwas dürftig.
                                          Kannst Du im Log mehr sehen?
                                          Ansonsten was geht auskommentieren und nach und nach freigeben, um zu sehen, wann der Adapter aussteigt.
                                          sorry
                                            Danke für die Info!
                                            Und wie hast Du Dein Ereignisscript abgeändert das es die Ereignisse so sauber untereinander reiht?
                                            Mein Script sieht so aus
                                            `/* Programm Ereignissliste für VIS */
                                            	var logging = true;
                                            createState("javascript.0.Servicemeldungen.vEreignisse","
                                            *   first
                                            var sensorsST = $('channel[state.id=*.STATE](functions=Schaltsteckdosen)').each(function(id) {
                                            	if (logging) log("DeviceST=" + val);
                                            var sensorsVS = $('channel[state.id=*.STATE](functions=Verschluss)').each(function(id) {
                                            	if (logging) log("DeviceVS=" + val);
                                            var sensorsBW = $('channel[state.id=*.MOTION](functions=Bewegungsmelder)').each(function(id) {
                                            	if (logging) log("DeviceBW=" + val);
                                            var vAlarmanlage_aussen = $('state[id="hm-rega.0.8834"]').each(function(id) {
                                            	if (logging) log("Alarmanlage Aussenbereich= " + val);
                                            var vAlarmanlage_gesamt = $('state[id="hm-rega.0.8835"]').each(function(id) {
                                            	if (logging) log("Alarmanlage Gesamt= " + val);
                                            var vAnwesenheitBaerchen = $('state[id="hm-rega.0.17897"]').each(function(id) {
                                            	if (logging) log("Baerchen anwesend= " + val);
                                            var vAnwesenheitHase = $('state[id="hm-rega.0.17898"]').each(function(id) {
                                            	if (logging) log("Hase anwesend= " + val);
                                            	if (logging) log("ereignis "+text);
                                                var ereignisStr = getState("javascript.0.Servicemeldungen.vEreignisse").val;
                                                var ereignisArr;
                                                    setState("javascript.0.Servicemeldungen.vEreignisse", "
                                                *   "+str+"
                                                    var output = day0 + day + "." + month0 + month + ". " + hours0 + hours + ":" + minutes0 + minutes+ " ";
                                                    return output;
                                                  var aktion=" => AUS";
                                                    aktion=" => AN";
                                                  ereignis(ts + "  " + obj.deviceName + " " + aktion);
                                                	if (logging) log("OBJ=" + JSON.stringify(obj,null,2));
                                                  var aktion=" => VERSCHLOSSEN";
                                                    aktion=" => AUF";
                                                    aktion=" => KIPP";
                                                  ereignis(ts + "  " + room(obj) + " " + " => Bewegung");
                                                vAlarmanlage_aussen.on(function(obj) {
                                                  var aktion="Aussenbereich gesichert";
                                                    aktion="Aussenbereich deaktiviert";
                                                vAlarmanlage_gesamt.on(function(obj) {
                                                  var aktion="Komplettbereich gesichert";
                                                    aktion="Komplettbereich deaktiviert";
                                                vAnwesenheitBaerchen.on(function(obj) {
                                                  var aktion="Bärchen ist ausser Haus";
                                                    aktion="Bärchen ist anwesend";
                                                    ereignis(ts + "  Anwesenheit: " + aktion);
                                                vAnwesenheitHase.on(function(obj) {
                                                  var aktion="Hase ist ausser Haus";
                                                    aktion="Hase ist anwesend";
                                                und das Globale Script so
                                                    setState("javascript.0.Servicemeldungen.vEreignisse",text);
                                                Wenn ich jetzt Dein Beispiel nehme
                                                on({id: 'admin.0.info.updatesNumber', change: 'any'},
                                                function(obj) {
                                                event2('ioBroker - **Update für ' + obj.state.val + '** Adapter verfügbar.');
                                                Dann werden zum einen alle Ereignisse gelöscht und nur dieses angezeigt und dann fehlt auch noch die Uhrzeit!
                                                Wie hast du das gelöst?
                                                gruß
                                                Johnny
                                            89
                                            20145
