    4. Homebridge-Adapter: Funktionierende Plugins und Beispiele
      mrMuppet @becksyyy last edited by
      Ich habe im Einsatz:
      tedee-Smartlock: "homebridge-tedee"
      Version 3.0.1 in /opt/iobroker/node_modules/iobroker.ham, node: v12.18.4, js-controller: 3.1.6
      Mit Datenpunkten:
      ham.0.Haustür.Accessory-Information.Accessory-Flags
      ham.0.Haustür.Accessory-Information.App-Matching-Identifier
      ham.0.Haustür.Accessory-Information.Configured-Name
      ham.0.Haustür.Accessory-Information.Firmware-Revision
      ham.0.Haustür.Accessory-Information.Hardware-Revision
      ham.0.Haustür.Accessory-Information.Identify
      ham.0.Haustür.Accessory-Information.Manufacturer
      ham.0.Haustür.Accessory-Information.Model
      ham.0.Haustür.Accessory-Information.Name
      ham.0.Haustür.Accessory-Information.Product-Data
      ham.0.Haustür.Accessory-Information.Serial-Number
      ham.0.Haustür.Accessory-Information.Software-Revision
      ham.0.Haustür.Battery.Battery-Level
      ham.0.Haustür.Battery.Charging-State
      ham.0.Haustür.Battery.Name
      ham.0.Haustür.Battery.Status-Low-Battery
      ham.0.Haustür.Lock.Lock-Current-State
      ham.0.Haustür.Lock.Lock-Target-State
      ham.0.Haustür.Lock.Name
      Konfiguration:
        "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
        "accessories": [],
        "platforms": [
            "platform": "TedeePlatform",
            "emailAddress": "m****@gmail.com",
            "password": "*PASSWORT*",
            "devices": [
                "name": "Haustür",
                "unlatchFromUnlockedToUnlocked": false,
                "unlatchLock": false,
                "disableUnlock": false,
                "defaultLockName": "Lock",
                "defaultLatchName": "Latch"
            "updateInterval": 30
        mrMuppet @mrMuppet last edited by
        Nest Camera Adapter: "homebridge-nest-cam"
        Funktioniert mit "Nest Hello" (VideoTürklingel) und "Nest IQ Cam Outdoor"
        Mit Datenpunkten:
        ham.0.Backyard
        ham.0.Backyard.00000110.Active
        ham.0.Backyard.00000110.Selected-RTP-Stream-Configuration
        ham.0.Backyard.00000110.Setup-Endpoints
        ham.0.Backyard.00000110.Streaming-Status
        ham.0.Backyard.00000110.Supported-Audio-Stream-Configuration
        ham.0.Backyard.00000110.Supported-RTP-Configuration
        ham.0.Backyard.00000110.Supported-Video-Stream-Configuration
        ham.0.Backyard.00000112.Mute
        ham.0.Backyard.00000112.Volume
        ham.0.Backyard.Accessory-Information.Accessory-Flags
        ham.0.Backyard.Accessory-Information.App-Matching-Identifier
        ham.0.Backyard.Accessory-Information.Configured-Name
        ham.0.Backyard.Accessory-Information.Firmware-Revision
        ham.0.Backyard.Accessory-Information.Hardware-Revision
        ham.0.Backyard.Accessory-Information.Identify
        ham.0.Backyard.Accessory-Information.Manufacturer
        ham.0.Backyard.Accessory-Information.Model
        ham.0.Backyard.Accessory-Information.Name
        ham.0.Backyard.Accessory-Information.Product-Data
        ham.0.Backyard.Accessory-Information.Serial-Number
        ham.0.Backyard.Accessory-Information.Software-Revision
        ham.0.Backyard.Backyard-Audio.Name
        ham.0.Backyard.Backyard-Audio.On
        ham.0.Backyard.Backyard-Face---Adrian.Motion-Detected
        ham.0.Backyard.Backyard-Face---Adrian.Name
        ham.0.Backyard.Backyard-Face---Adrian.Status-Active
        ham.0.Backyard.Backyard-Face---Adrian.Status-Fault
        ham.0.Backyard.Backyard-Face---Adrian.Status-Low-Battery
        ham.0.Backyard.Backyard-Face---Adrian.Status-Tampered
        Die Datenpunkte gibt es zu jedem erkannten Gesicht und zu den folgenden "Events"
        ham.0.Backyard.Backyard-Motion
        ham.0.Backyard.Backyard-Package-Delivered
        ham.0.Backyard.Backyard-Package-Retrieved
        ham.0.Backyard.Backyard-Person
        ham.0.Backyard.Backyard-Sound
        ham.0.Backyard.Backyard-Streaming.Name
        ham.0.Backyard.Backyard-Streaming.On
        Bei der Klingel kommen dann noch einigen Datenpunkte zur Klingel dazu... die erspare ich euch jetzt mal. Insgesamt gibt es bei mir einige hundert Datenpunkte. Aber ich kann problemlos aus die Gesichtserkennung, Paketerkennung etc nutzen.
        Installation ist wegen des Nest/Google-Developer-Accounts etwas komplizierter, aber in der Anleitung zum Adapter ausreichend beschrieben.
          Pischleuder last edited by
          Govee led-stripe H6159 mit
          homebridge-govee mit node 12.20.0 / npm 6.14.8
            "accessories": [],
            "platforms": [
                "platform": "config",
                "name": "Config",
                "port": 8080,
                "auth": "none",
                "sudo": true
                "platform": "Govee",
                "name": "Govee",
                "apiKey": "your  api key",
                "device": "99:E5:A4:C1:38:29:DA:7B",
                "model": "H6159",
                "deviceName": "H6159",
                "controllable": true,
                "retrievable": true,
                "supportCmds": [
                  "turn",
                  "brightness",
                  "color",
                  "colorTem"
            Boardy @stoepselinho last edited by Boardy
            @stoepselinho sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
            @becksyyy
            hallo, was genau ist die app_id und wie bekommt man den access_token?
            ich würde gerne meine Klimaanlage von Samsung einbinden.
            Bist du hier schon weiter - hänge and er selben Stelle - die Anleitung im smartthing adapter scheint nicht mehr ganz zu passen....?
            @becksyyy , @gfrene Könnt ihr hier bitte noch mal helfen - bei euch hat es ja geklappt... geht das ganze auch ohne Smartthings Hub?
            • Bandit
              Bandit last edited by
              homebridge-haier-ac v0.2.1 Plugin --> Auch wenn der Thread "funktionierende Plugins" heißt, hier ein negatives Beispiel.
              Adapter funktioniert tadellos in Homebridge
              Versuch über HAM im ioBroker
              HAM im Wrapper Modus
              Adaptereinstellung:
                      "accessory": "HaierAC",
                      "ip": "192.168.11.50",
                      "mac": "04FA83B757D7",
                      "name": "Haier-AC-Schlafzimmer",
                      "treatAutoHeatAs": "fan"
              Im ioBroker werden alle Objekte angelegt, die Werte sind jedoch Standardwerte. Ein Auslesen der Haier-AC erfolgt nicht, auch kann die Haier-AC aus dem ioBroker nicht gesteuert werden.
              Keine für mich erkennbare Fehlermeldung im Log, Allerdings passiert bei updateState nichts. Hier dar Anfang vom Log, danach kommen noch etliche weitere Datenpunkte mit gleichem Ergebnis
              2020-12-27 17:32:28.322 - info: host.banditpi "system.adapter.ham.0" enabled
              2020-12-27 17:32:28.359 - info: host.banditpi instance system.adapter.ham.0 started with pid 17875
              2020-12-27 17:32:29.456 - info: ham.0 (17875) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.20.0, js-controller: 3.1.6
              2020-12-27 17:32:29.489 - info: ham.0 (17875) Install/Update the following Libraries: homebridge-haier-ac
              2020-12-27 17:32:29.490 - info: ham.0 (17875) Install/Update homebridge-haier-ac
              2020-12-27 17:32:29.492 - info: ham.0 (17875) npm install homebridge-haier-ac --production --loglevel error (System call)
              2020-12-27 17:32:43.153 - info: ham.0 (17875) + homebridge-haier-ac@0.2.1
              added 9 packages from 16 contributors and audited 9 packages in 11.597s
              2020-12-27 17:32:43.179 - info: ham.0 (17875) found 0 vulnerabilities
              2020-12-27 17:32:45.841 - info: ham.0 (17875) All Libraries installed/updated
              2020-12-27 17:32:56.368 - info: ham.0 (17875) updateDev Haier-AC-Schlafzimmer: name = Haier-AC-Schlafzimmer /type= 1
              2020-12-27 17:32:56.372 - info: ham.0 (17875) updateChannel Haier-AC-Schlafzimmer.Accessory-Information: name =
              2020-12-27 17:32:56.375 - info: ham.0 (17875) updateState Haier-AC-Schlafzimmer.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
              2020-12-27 17:32:56.377 - info: ham.0 (17875) updateState Haier-AC-Schlafzimmer.Accessory-Information.Manufacturer: value = Haier /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
              2020-12-27 17:32:56.378 - info: ham.0 (17875) updateState Haier-AC-Schlafzimmer.Accessory-Information.Model: value = AirCond /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
              2020-12-27 17:32:56.379 - info: ham.0 (17875) updateState Haier-AC-Schlafzimmer.Accessory-Information.Name: value = Haier-AC-Schlafzimmer /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                apollon77 @Bandit last edited by
                @Bandit FDann mal bitte Github issue beim ham adapter mit vollem debug log anlegen
                GregorS 1 Reply Last reply Reply Quote 0
                • GregorS
                  GregorS @apollon77 last edited by
                  @apollon77
                  ich habe mir das Plugin homebridge-apc-back-ups-hs500 installiert.
                  Meine Konfiguration ist leer. Wie komme ich an die richtige Konfiguration?
                  Bei anderen Plugins stand was bei der Beschreibung dabei.
                  Stehe hier gerade voll auf dem Schlauch.
                    apollon77 @GregorS last edited by
                    @GregorS sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
                    Ich denke du musst den Plugin Anbieter fragen das er auch ein klassisches Konfig Exaple zeigt. Hier scheint ein Schema zu sein was wohl das eine homebridge UI plugin nutzt ,... https://github.com/J1mbo/homebridge-APC-Back-UPS-HS500/blob/master/config.schema.json
                    • GregorS
                      @apollon77
                      Das ist blöd.
                      Komme an den J1mbo nicht dran. Er hat keine Kontaktdaten.
                        @GregorS öffne ein GitHub issue
                          Boardy @apollon77 last edited by Boardy
                          Erfolgsmeldung: Smartthings von Samsung funktioniert nun auch - ist aber ziemlich fummelig...
                          Beschreibung zu homebridge-smartthings v2.3.8 genau befolgen... mann muss im Samsung account eine App installieren - auf diese kann man dann zugreifen...
                          Problem war an die ID´s zu kommen da hier die Anleitung nicht mehr passt... aber es geht so:
                          , I figured it out. In the new app, I was able to go to HomeBridge v2 under SmartApps and click on "Render the platform data for Homebridge config.json". I was able to get that info there and save it in my config.json.
                          Config:
                            "description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration file containing devices you actually own.",
                            "accessories": [],
                            "platforms": [
                                "platform": "SmartThings-v2",
                                "name": "SmartThings-v2",
                                "app_url": "https://graph-eu01-euwest1.api.smartthings.com:443/api/smartapps/installations/",
                                "app_id": "bxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxanzupassen",
                                "access_token": "bxxxxxxxxxxxxxxxxxxxxxxxxanzupassen",
                                "direct_port": 8000,
                                "temperature_unit": "C",
                                "validateTokenId": false,
                                "logConfig": {
                                  "debug": false,
                                  "showChanges": true,
                                  "hideTimestamp": true,
                                  "hideNamePrefix": true,
                                  "file": {
                                    "enabled": true,
                                    "level": "good"
                            SkeeveKlah @Boardy last edited by
                            @Boardy Super!!
                            Warum auch immer, mit der angepassten Konfig von Dir hat es bei mir jetzt auch geklappt! Danke!
                              Boardy @SkeeveKlah last edited by
                              @SkeeveKlah Hi, ich will meien AC Daten auslesen - klappt das mit dem debug Mode bei Dir? AC geräte werden nicht unterstützt, aber in der App im Debug mode sehe ich alles was ich benötige... nur im IOBroker kommt nicht mehr an...
                                TheAriba last edited by
                                Hallo zusammen!
                                Wie ich tatsächlich ein homebridge plugin in ioBroker zum Laufen bekomme würde mir an der Stelle auch helfen. Irgendwie verstehe ich da nur Bahnhof 🙂 .
                                Fehlt hier noch etwas an den Einstellungen? Es knallt im Log ein wenig.
                                f6789800-8d22-42df-a0b8-78640dd60144-image.png fd5a655d-ec1e-4207-b2cb-2ced501fb391-image.png
                                host.raspberrypi	2021-01-13 23:38:00.586	info	Restart adapter system.adapter.ham.0 because enabled
                                host.raspberrypi	2021-01-13 23:38:00.585	info	instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
                                host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[3]: [1/13/2021, 22:38:00] Error loading platform requested in your config.json at position 1
                                host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: [1/13/2021, 22:38:00] ====================
                                host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: at Server.start (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:71:28)
                                host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: at PluginManager.initializeInstalledPlugins (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManager.js:61:22)
                                host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: at Map.forEach (<anonymous>)
                                host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManager.js:63:24
                                host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Plugin.load (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/plugin.js:124:31)
                                host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at require (internal/modules/cjs/helpers.js:74:18)
                                host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Module.require (internal/modules/cjs/loader.js:887:19)
                                host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Function.Module._load (/opt/iobroker/node_modules/mock-require/index.js:30:22)
                                host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                                host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                                host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/iobroker.ham/main.js
                                host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js
                                host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js
                                host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js
                                host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/api.js
                                host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManager.js
                                host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/plugin.js
                                host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: Require stack:
                                host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: [1/13/2021, 22:38:00] Error: Cannot find module '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-doorbird/dist/index.js'
                                host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: [1/13/2021, 22:38:00] ERROR LOADING PLUGIN homebridge-doorbird:
                                host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[1]: [1/13/2021, 22:38:00] ====================
                                host.raspberrypi	2021-01-13 23:38:00.581	error	Caught by controller[0]: [1/13/2021, 22:38:00] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                                ham.0	2021-01-13 23:38:00.059	info	(4089) Terminated (NO_ERROR): Without reason
                                ham.0	2021-01-13 23:38:00.058	info	(4089) terminating
                                ham.0	2021-01-13 23:38:00.050	info	(4089) cleaned everything up...
                                ham.0	2021-01-13 23:38:00.049	error	(4089) Error: The requested platform 'Doorbird' was not registered by any plugin. at PluginManager.getPluginForPlatform (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManag
                                ham.0	2021-01-13 23:38:00.045	error	(4089) unhandled promise rejection: The requested platform 'Doorbird' was not registered by any plugin.
                                ham.0	2021-01-13 23:38:00.045	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                ham.0	2021-01-13 23:38:00.041	debug	(4089) [1/13/2021, 22:38:00] Loading 1 platforms...
                                ham.0	2021-01-13 23:37:58.965	info	(4089) All Libraries installed/updated
                                ham.0	2021-01-13 23:37:58.964	error	(4089) Error: Library https://github.com/hjdhjd/homebridge-doorbird not installed after 3 attempts
                                ham.0	2021-01-13 23:37:58.925	info	(4089) found 0 vulnerabilities
                                ham.0	2021-01-13 23:37:58.846	info	(4089) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 14.395s
                                ham.0	2021-01-13 23:37:43.153	info	(4089) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
                                ham.0	2021-01-13 23:37:43.119	info	(4089) found 0 vulnerabilities
                                ham.0	2021-01-13 23:37:43.043	info	(4089) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 20.522s
                                ham.0	2021-01-13 23:37:21.253	info	(4089) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
                                ham.0	2021-01-13 23:37:21.213	info	(4089) found 0 vulnerabilities
                                ham.0	2021-01-13 23:37:21.121	info	(4089) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 13.538s
                                ham.0	2021-01-13 23:37:06.277	info	(4089) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
                                ham.0	2021-01-13 23:37:06.276	info	(4089) Install/Update https://github.com/hjdhjd/homebridge-doorbird
                                ham.0	2021-01-13 23:37:06.275	info	(4089) Install/Update the following Libraries: https://github.com/hjdhjd/homebridge-doorbird
                                ham.0	2021-01-13 23:37:06.246	info	(4089) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.20.1, js-controller: 3.1.6
                                host.raspberrypi	2021-01-13 23:37:05.107	info	instance system.adapter.ham.0 started with pid 4089
                                host.raspberrypi	2021-01-13 23:37:02.604	info	instance system.adapter.ham.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                ham.0	2021-01-13 23:37:02.072	info	(3781) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                ham.0	2021-01-13 23:37:02.071	info	(3781) terminating
                                ham.0	2021-01-13 23:37:02.070	info	(3781) cleaned everything up...
                                ham.0	2021-01-13 23:37:02.069	info	(3781) Got terminate signal TERMINATE_YOURSELF
                                host.raspberrypi	2021-01-13 23:37:02.066	info	stopInstance system.adapter.ham.0 send kill signal
                                host.raspberrypi	2021-01-13 23:37:02.065	info	stopInstance system.adapter.ham.0 (force=false, process=true)
                                ham.0	2021-01-13 23:37:02.042	info	(3781) All NPM Modules got reinstalled/updated ... restarting ...
                                ham.0	2021-01-13 23:37:02.041	error	(3781) Error: Library https://github.com/hjdhjd/homebridge-doorbird not installed after 3 attempts
                                ham.0	2021-01-13 23:37:02.001	info	(3781) found 0 vulnerabilities
                                ham.0	2021-01-13 23:37:01.912	info	(3781) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 14.307s
                                ham.0	2021-01-13 23:36:46.329	info	(3781) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
                                ham.0	2021-01-13 23:36:46.296	info	(3781) found 0 vulnerabilities
                                ham.0	2021-01-13 23:36:46.220	info	(3781) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 14.364s
                                ham.0	2021-01-13 22:36:30.521	info	(3781) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
                                ham.0	2021-01-13 22:36:30.484	info	(3781) found 0 vulnerabilities
                                ham.0	2021-01-13 22:36:30.402	info	updated 1 package and audited 39 packages in 14.212s
                                ham.0	2021-01-13 22:36:30.402	info	(3781) + homebridge-doorbird@1.0.1
                                ham.0	2021-01-13 22:36:14.865	info	(3781) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
                                ham.0	2021-01-13 22:36:14.864	info	(3781) Install/Update https://github.com/hjdhjd/homebridge-doorbird
                                ham.0	2021-01-13 22:36:14.863	info	(3781) Install/Update the following Libraries: https://github.com/hjdhjd/homebridge-doorbird
                                ham.0	2021-01-13 22:36:14.834	info	(3781) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.20.1, js-controller: 3.1.6
                                Ich bedanke mich vorab für eure Unterstützung!
                                  apollon77 @TheAriba last edited by
                                  @enoceaneltako said in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
                                  Naja teht doch alles in der Fehlermeung. DU musst in der Liste der Pakete auch die nötigen Plugin Pakete aufzählen das Sie installiert werden können.
                                    @boardy Tja... ich habe ne Waschmaschine im Adapter und die wird wohl nur als Schalter angezeigt, irgendwo hatte ich das auch mal gelesen, hatte etwas Hoffnung das mittlerweile ein bischen mehr geht, ist aber wohl nicht.
                                    ManN kann eben (noch) nicht alles haben 😳
                                      amiethaner last edited by
                                      Hey @apollon77
                                      Ich kenn mich mit der Programmiererei so leider ned aus, aber wollte mal vorsichtig anfragen
                                      obs für Fibaro HC2 mal ne erweiterung geben wird, oder ob das technisch überhaupt geht.
                                      Hier wären ja deutlich mehr values der einzelnen Devices vorhanden als über den Ham zum IOB kommen.
                                      Ansonsten aber echt n dicken Danke für den Adapter! Super arbeit!
                                        apollon77 @amiethaner last edited by
                                        @amiethaner Keine ahnug obs das mal geben wird 🙂 Gibts einen Adapter Request dazu?
                                          amiethaner @apollon77 last edited by
                                          @apollon77 sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
                                          Ich glaub ned, meinst es bringt was wenn ich einen aufmach
                                            A Former User @apollon77 last edited by
                                            @apollon77
                                            Hier ein Beispiel für die Govee-Ambiente H6104, hab 2 Stück, es werden beide automatisch gefunden, läuft so:
                                              "accessories": [],
                                              "platforms": [
                                                  "name": "Govee",
                                                  "apiKey": "api-key",
                                                  "model": "H6104",
                                                  "supportCmds": [
                                                    "turn",
                                                    "brightness",
                                                    "color",
                                                    "colorTem"
                                            gelberlemmy 1 Reply Last reply Reply Quote 1
                                            238
                                            55889
