    4. Zwave 0.4
    Zwave 0.4
    • Lenny.CB
      Lenny.CB Most Active last edited by
      bin gespannt…
      zur Zeit läuft bei mir der Umweg über die "FHEM-ioBroker-Brücke".
      Direkt würde mir besser gefallen. 😄
      • Bluefox
        Bluefox last edited by
        https://www.youtube.com/watch?v=c7JmFaKFLP0
        Also es läuft bei mir… Aber stick + openzwave sind ziemlich buggy. Suche noch die workarounds, aber man kann schon ausprobieren.
        • Bluefox
          Ich brauche allerdings Hilfe bei der Übersetzung:
                          "removeFailedNode":     {"en": "Remove failed",         "de": "Remove failed",      "ru": "Удалить не удалось"},
                  "requestNodeNeighborUpdate":  {"en": "Neighbor update", "de": "Neighbor update",    "ru": "Обновление соединений"},
                  "assignReturnRoute":    {"en": "Assign return route",   "de": "Assign return route", "ru": "Назначить обратный маршрут"},
                  "deleteAllReturnRoutes": {"en": "Delete all routes",    "de": "Delete all routes",  "ru": "Удалить все маршруты"},
                  "requestNetworkUpdate": {"en": "Network update",        "de": "Network update",     "ru": "Сетевое обновление"},
                  "replicationSend":      {"en": "Replication",           "de": "Replication",        "ru": "Копирование"},
                  "setName":              {"en": "Set name",              "de": "Set name",           "ru": "Задать имя"},
                  "setLocation":          {"en": "Set location",          "de": "Set location",       "ru": "Задать локацию"},
                  "createButton":         {"en": "Create button",         "de": "Create button",      "ru": "Создать кнопку"},
                  "deleteButton":         {"en": "Delete button",         "de": "Delete button",      "ru": "Удалить кнопку"},
          var ctrlState = [
                  /*0: */ {'en': 'No command in progress',    'de': 'No command in progress',     'ru': 'Нет команды в процессе'},
                  /*1: */ {'en': 'The command is starting',   'de': 'The command is starting',    'ru': 'Команда запускается'},
                  /*2: */ {'en': 'The command was cancelled', 'de': 'The command was cancelled',  'ru': 'Команда была отменена'},
                  /*3: */ {'en': 'Command invocation had error(s) and was aborted',
                      'de': 'Command invocation had error(s) and was aborted',
                      'ru': 'Команда вызова содержит ошибку и была прервана'
                  /*4: */ {'en': 'Controller is waiting for a user action',
                      'de': 'Controller is waiting for a user action',
                      'ru': 'Контроллер ожидает действий пользователя'
                  /*5: */ {'en': 'Controller command is on a sleep queue wait for device',
                      'de': 'Controller command is on a sleep queue wait for device',
                      'ru': 'Команда контроллера находится в очереди'
                  /*6: */ {'en': 'The controller is communicating with the other device to carry out the command',
                      'de': 'The controller is communicating with the other device to carry out the command',
                      'ru': 'Контроллер обменивается данными с другим устройством, чтобы выполнить команду'
                  /*7: */ {'en': 'The command has completed successfully',
                      'de': 'The command has completed successfully',
                      'ru': 'Команда успешно завершена'
                  /*8: */ {'en': 'The command has failed',    'de': 'The command has failed', 'ru': 'The command has failed'},
                  /*9: */ {'en': 'The controller thinks the node is OK',
                      'de': 'The controller thinks the node is OK',
                      'ru': 'Контроллер считает, что узел в норме'
                  /*10:*/ {'en': 'The controller thinks the node has failed',
                      'de': 'The controller thinks the node has failed',
                      'ru': 'Контроллер считает, что узел упал'
                  {}, // 11
                  {}, // 12
                  {}, // 13
                  {}, // 14
                  {   'en': 'Continue to remove devices',
                      'de': 'Lösche die Geräte weiter',
                      'ru': 'Удаление можно продолжить'}
                  , // 15
                  {   'en': 'Continue to add devices',
                      'de': 'Füge die Geräte weiter hinzu',
                      'ru': 'Добавление можно продолжить'}
          var ctrlError = [
                  /*0:*/  {'en': 'No error',         'de': 'No error',         'ru': 'Без ошибок'},
                  /*1*/   {'en': 'ButtonNotFound',   'de': 'ButtonNotFound',   'ru': 'Кнопка не найдена'},
                  /*2:*/  {'en': 'NodeNotFound',     'de': 'NodeNotFound',     'ru': 'Узел не найден'},
                  /*3:*/  {'en': 'NotBridge',        'de': 'NotBridge',        'ru': 'Нет моста'},
                  /*4:*/  {'en': 'NotSUC',           'de': 'NotSUC',           'ru': 'Нет SUC'},
                  /*5:*/  {'en': 'NotSecondary',     'de': 'NotSecondary',     'ru': 'Нет второстепенного узла'},
                  /*6:*/  {'en': 'NotPrimary',       'de': 'NotPrimary',       'ru': 'Нет главного узла'},
                  /*7:*/  {'en': 'IsPrimary',        'de': 'IsPrimary',        'ru': 'Главный'},
                  /*8:*/  {'en': 'NotFound',         'de': 'NotFound',         'ru': 'Не найден'},
                  /*9:*/  {'en': 'Busy',             'de': 'Busy',             'ru': 'Занят'},
                  /*10:*/ {'en': 'Failed',           'de': 'Failed',           'ru': 'Неудачный'},
                  /*11:*/ {'en': 'Disabled',         'de': 'Disabled',         'ru': 'Отключен'},
                  /*12:*/ {'en': 'Overflow',         'de': 'Overflow',         'ru': 'Переполнение'}
          var commands = {
                  'removeFailedNode':  {
                      'en': 'Remove a specific failed node from the controller\'s memory.',
                      'de': 'Remove a specific failed node from the controller\'s memory.',
                      'ru': 'Удалить конкретный сбойный узел из памяти контроллера.'
                  'hasNodeFailed': {
                      'en': 'Check whether a node is in the controller\'s failed nodes list.',
                      'de': 'Check whether a node is in the controller\'s failed nodes list.',
                      'ru': 'Проверьте правильность узлов в контролере, вышел из строя список узлов.'
                  'requestNodeNeighborUpdate': {
                      'en': 'Get a node to rebuild its neighbour list.',
                      'de': 'Get a node to rebuild its neighbour list.',
                      'ru': 'Опросить узлы, чтобы восстановить свой список.'
                  'assignReturnRoute': {
                      'en': 'Assign a network return routes to a device.',
                      'de': 'Assign a network return routes to a device.',
                      'ru': 'Назначьте сеть маршрутов к устройству.'
                  'deleteAllReturnRoutes': {
                      'en': 'Delete all return routes from a device.',
                      'de': 'Delete all return routes from a device.',
                      'ru': 'Удалить все маршруты к устройству.'
                  'sendNodeInformation': {
                      'en': 'Send a NIF (node information frame).',
                      'de': 'Send a NIF (node information frame).',
                      'ru': 'Отправить NIF (кадр информации изла).'
                  'requestNetworkUpdate': {
                      'en': 'Request network information from the SUC/SIS.',
                      'de': 'Request network information from the SUC/SIS.',
                      'ru': 'Запрос информации от сети SUC/SIS.'
                  'replicationSend': {
                      'en': 'Send information from primary to secondary.',
                      'de': 'Send information from primary to secondary.',
                      'ru': 'Отправить информацию от главного второстепенному.'
                  'createButton': {
                      'en': 'Create an id that tracks handheld button presses.',
                      'de': 'Create an id that tracks handheld button presses.',
                      'ru': 'Создать идентификатор отслеживания ручного нажатия кнопки.'
                  'deleteButton': {
                      'en': 'Delete id that tracks handheld button presses.',
                      'de': 'Delete id that tracks handheld button presses.',
                      'ru': 'Удалить идентификатор отслеживания ручного нажатия кнопки.'
                  'replaceFailedNode': {
                      'en': 'Replace a non-responding node with another. The node must be in the controller\'s list of failed nodes for this command to succeed.',
                      'de': 'Replace a non-responding node with another. The node must be in the controller\'s list of failed nodes for this command to succeed.',
                      'ru': 'Заменить зависший узел на другой. Узел должен находиться в списке ошибочных узлов контроллера.'
                  'setName': {
                      'en': 'Set node name.',
                      'de': 'Set node name.',
                      'ru': 'Назначить имя узла.'
                  'setLocation': {
                      'en': 'Set node location.',
                      'de': 'Set node location.',
                      'ru': 'Задать локацию узла.'
                  'healNetworkNode': {
                      'en': 'Attempt to heal the network if nodes become unresponsive.',
                      'de': 'Attempt to heal the network if nodes become unresponsive.',
                      'ru': 'Попытка исправить сеть узлов не отвечающих на запросы.'
                  'refreshNodeInfo': {
                      'en': 'Refresh node information.',
                      'de': 'Refresh node information.',
                      'ru': 'Обновить информацию состояния узлов.'
          • Alex1808
            Alex1808 last edited by
            @Bluefox:
            Ich brauche allerdings Hilfe bei der Übersetzung: `
            +Russisch
            "requestNodeNeighborUpdate": {"en": "Neighbor update", "de": "Neighbor update", "ru": "Ближнее обновление"},
            2.
            var ctrlState = [
                             'ru': 'Команда вызова содержит ошибку (и) и была прервана'
                             'ru': 'Команда контроллера находится в ожидание очереди отрабатывания устройством'
                             'ru': 'Контроллер считает что узел в норме'
                             'ru': 'Контроллер считает узел не отрабатывается'
                    {}, // 11
                    {}, // 12
                    {}, // 13
                    {}, // 14
                    , // 15
            var ctrlError = [
            /0:/ {'en': 'No error', 'de': 'No error', 'ru': 'Без ошибок'},
            /1/ {'en': 'ButtonNotFound', 'de': 'ButtonNotFound', 'ru': 'КнопкаНеНайдена'},
            /2:/ {'en': 'NodeNotFound', 'de': 'NodeNotFound', 'ru': 'УзелНеНайден'},
            /3:/ {'en': 'NotBridge', 'de': 'NotBridge', 'ru': 'НетМоста'},
            /4:/ {'en': 'NotSUC', 'de': 'NotSUC', 'ru': 'НетSUC'},
            /5:/ {'en': 'NotSecondary', 'de': 'NotSecondary', 'ru': 'НетВторостепенного'},
            /6:/ {'en': 'NotPrimary', 'de': 'NotPrimary', 'ru': 'НетГлавного'},
            /7:/ {'en': 'IsPrimary', 'de': 'IsPrimary', 'ru': 'Главный'},
            /8:/ {'en': 'NotFound', 'de': 'NotFound', 'ru': 'Ненайден'},
            /9:/ {'en': 'Busy', 'de': 'Busy', 'ru': 'Занят'},
            /10:/ {'en': 'Failed', 'de': 'Failed', 'ru': 'Неудачный'},
            /11:/ {'en': 'Disabled', 'de': 'Disabled', 'ru': 'Отключен'},
            /12:/ {'en': 'Overflow', 'de': 'Overflow', 'ru': 'Заливка'}
            4.
            var commands = {
                        'ru': 'Удалить конкретный сбойный узел из памяти контроллера\ов.'
                    'hasNodeFailed': {
                        'ru': 'Проверьте правильность узлов в контролере\ах, вышел из строя список узлов.'
                    'createButton': {
                    'deleteButton': {
                        'ru': 'Заменить зависший узел на другой. Узел должен находиться в списке ошибочных узлов контроллера\ов чтобы успешно отработать.'
                    'setName': {
                    'setLocation': {
            • ruhr70
              ruhr70 last edited by
              @Bluefox:
              sorry… hab heute den Super-GAU..
              Nur ärgerlich:
              • Raspberry Pi 3 mit
              -- BLE Skript (im Forum "gesichert")
              -- ZWAVE Stick
              -- Script für einen USB-CO2 Sensor (TFA Dorstmann)
              Ist abgeraucht (die SD). Sicherungen liegen auf der Diskstation, s.u.
              Und nun das "Kleine" andere Problemchen:
              • Diskstation mit über 11 TB netto-Daten fährt nach Reboot nicht mehr sauber hoch
              • unter anderem liegen da auch die Skript-Sicherungen
              Wenn ich damit weiter bin, gerne 😉
              • Bluefox
                @Alex1808:
                @Bluefox:
                +Russisch `
                Спасибо. 🙂
                • Dutchman
                  Ich wag mich mal dran, koennten einige fehlschlaege drin stehen da meine deutsche grammatiek mich nach 18 Jahren im ausland doch ein bischen im stich laesst.
                  Teil 1:
                  "removeFailedNode": {"en": "Remove failed", "de": "Löschen fehlgeschlagen", "ru": "Удалить не удалось"},
                  "requestNodeNeighborUpdate": {"en": "Neighbor update", "de": "Nachbar-Update", "ru": "Ближнее обновление"},
                  "assignReturnRoute": {"en": "Assign return route", "de": "Rückgabeweg zuweisen", "ru": "Назначить обратный маршрут"},
                  "deleteAllReturnRoutes": {"en": "Delete all routes", "de": "Löschen aller Routierungen", "ru": "Удалить все маршруты"},
                  "requestNetworkUpdate": {"en": "Network update", "de": "Netzwerkaktualisierung", "ru": "Сетевое обновление"},
                  "replicationSend": {"en": "Replication", "de": "Replikation", "ru": "Копирование"},
                  "setName": {"en": "Set name", "de": "Namen festlegen", "ru": "Задать имя"},
                  "setLocation": {"en": "Set location", "de": "Ort festlegen", "ru": "Задать локацию"},
                  "createButton": {"en": "Create button", "de": "Erstellen", "ru": "Создать кнопку"},
                  "deleteButton": {"en": "Delete button", "de": "Löschen", "ru": "Удалить кнопку"},
                  Teil 2:
                  var ctrlState = [
                          /*0: */ {'en': 'No command in progress',    'de': 'Kein Befehl in Bearbeitung',     'ru': 'Нет команды в процессе'},
                          /*1: */ {'en': 'The command is starting',   'de': 'Der Befehl wird gestartet',    'ru': 'Команда запускается'},
                          /*2: */ {'en': 'The command was cancelled', 'de': 'Der Befehl wurde abgebrochen',  'ru': 'Команда была отменена'},
                                   'de': 'Befehl hatte Fehler und wurde abgebrochen',
                                   'de': 'Controller wartet auf eine Benutzeraktion',
                                   'de': 'Controller-Befehl befindet sich in der Warteschlange und wartet auf Gerät',
                                   'de': 'Der Controller kommuniziert mit dem anderen Gerät um den Befehl auszuführen',
                                   'de': 'Der Befehl wurde erfolgreich abgeschlossen',
                                   'de': 'Der Controller denkt das der Knoten OK ist',
                                   'de': 'Der Controller denkt das der Knoten ausgefallen ist',
                          {}, // 11
                          {}, // 12
                          {}, // 13
                          {}, // 14
                          , // 15
                  Teil 3:
                  var ctrlError = [
                  /0:/ {'en': 'No error', 'de': 'Kein Fehler', 'ru': 'Без ошибок'},
                  /1/ {'en': 'ButtonNotFound', 'de': 'Tasternichtgefunden', 'ru': 'КнопкаНеНайдена'},
                  /2:/ {'en': 'NodeNotFound', 'de': 'Knotennichtgefunden', 'ru': 'УзелНеНайден'},
                  /3:/ {'en': 'NotBridge', 'de': 'KeineBrücke', 'ru': 'НетМоста'},
                  /4:/ {'en': 'NotSUC', 'de': 'KeinSUC', 'ru': 'НетSUC'},
                  /5:/ {'en': 'NotSecondary', 'de': 'NichtSekundär', 'ru': 'НетВторостепенного'},
                  /6:/ {'en': 'NotPrimary', 'de': 'NichtPrimär', 'ru': 'НетГлавного'},
                  /7:/ {'en': 'IsPrimary', 'de': 'IstPrimärr', 'ru': 'Главный'},
                  /8:/ {'en': 'NotFound', 'de': 'Nichtgefunden', 'ru': 'Ненайден'},
                  /9:/ {'en': 'Busy', 'de': 'Beschäftigt', 'ru': 'Занят'},
                  /10:/ {'en': 'Failed', 'de': 'Gescheitert', 'ru': 'Неудачный'},
                  /11:/ {'en': 'Disabled', 'de': 'Behindert', 'ru': 'Отключен'},
                  /12:/ {'en': 'Overflow', 'de': 'Überlauf', 'ru': 'Заливка'}
                  Teil 4:
                  var commands = {
                              'de': 'Entfernen Sie einen bestimmten ausgefallenen Knoten aus dem Speicher des Controllers.',
                          'hasNodeFailed': {
                              'de': 'Prüfen Sie ob sich ein Knoten in der Controller-Fehlerliste befindet.',
                              'de': 'Holen Sie sich einen Knoten um die Nachbarliste neu zu erstellen.',
                              'de': 'Weisen Sie einen Netwerk Rückgabeweg zum Gerät zu.',
                              'de': 'Löschen Sie alle Rückgabewege von einem Gerät.',
                              'de': 'Senden eines NIF (Knoteninformationsrahmen)).',
                              'de': 'Anfordern von Netzwerkinformationen aus dem SUC / SIS.',
                              'de': 'Senden der Informationen von primär nach sekundär.',
                          'createButton': {
                              'de': 'Erstellen einer ID die Handheld-Taste drücken verfolgt.',
                          'deleteButton': {
                              'de': 'Löschen einer ID die Handheld-Taste drücken verfolgt.',
                              'de': 'Ersetzen Sie einen nicht antwortenden Knoten durch einen anderen. Der Knoten muss sich in der Controller-Liste der ausgefallenen Knoten befinden, damit dieser Befehl erfolgreich ausgeführt werden kann.',
                          'setName': {
                              'de': 'Knotennamen festlegen.',
                          'setLocation': {
                              'de': 'Knotenpunkt festlegen.',
                              'de': 'Versuche das Netzwerk zu heilen wenn ein knoten nicht mehr reagiert.',
                              'de': 'Aktualisieren von Knoteninformationen.',
                  so fertig, hoffe es macht einigermassen Sinn 😉
                  • Bluefox
                    Muss sagen, dass die Übersetzungsanfragen werden viiiiiieeel flotter erledigt, als vor einem Jahr.
                    Danke 😄
                      paul53 last edited by
                      Einige Verbesserugsvorschläge:
                      Teil 1:
                              "createButton":         {"en": "Create button",         "de": "Taste erstellen",      "ru": "Создать кнопку"},
                              "deleteButton":         {"en": "Delete button",         "de": "Taste löschen",        "ru": "Удалить кнопку"},
                      Teil 2:
                                  'de': 'weitere Geräte löschen',
                              , // 15
                                  'de': 'weitere Geräte hinzufügen',
                      Teil 3:
                              /*11:*/ {'en': 'Disabled',         'de': 'Gesperrt',         'ru': 'Отключен'},
                      Teil 4 (eventuell):
                              'setLocation': {
                                  'de': 'Ort des Knotens festlegen.',
                      • AlCalzone
                        @paul53:
                        Würde nicht "Taste" sagen, sondern "Knopf".
                        @paul53:
                        Teil 3:
                        Hier wäre "deaktiviert" vermutlich passender. "gesperrt" wäre "locked".
                        • Dutchman
                          @AlCalzone:
                          @paul53:
                          @paul53:
                          Teil 3:
                          Hier wäre "deaktiviert" vermutlich passender. "gesperrt" wäre "locked". `
                          Ich stimme auch zu deaktiviert anstaat gesperrt.
                          Danke fuer eure verbaesserungen !
                          • Lenny.CB
                            @Bluefox:
                            Also es läuft bei mir… Aber stick + openzwave sind ziemlich buggy. Suche noch die workarounds, aber man kann schon ausprobieren. `
                            ich konnte es nicht abwarten und musste es probieren… 😄
                            ich komme beim "USB Device Name:" nicht weiter. Hier ist das Feld immer leer. Eintragen (ttyACM0) kann ich auch nichts.
                            • Dutchman
                              @Lenny.CB:
                              @Bluefox:
                              zwave.jpg `
                              Eest adapter activieren ? Beim rflink ist die auswahl auch nur mit activierten adapter moeglich
                              • Lenny.CB
                                war aktiv…
                                also bei aktivertem Adapter kann ich nichts eintragen, es wird auch nichts angeboten
                                bei inaktiven Adapter kann ich das Device eintragen, was aber nach dem Speichern keine Auswirkungen hat.
                                Adapter bleibt "rot"
                                • Bluefox
                                  Es müssen aber irgendwelche Logs da sein?
                                  • Lenny.CB
                                    host.iobroker	2016-11-06 20:45:48.606	info	Restart adapter system.adapter.zwave.0 because enabled
                                    host.iobroker	2016-11-06 20:45:48.603	error	instance system.adapter.zwave.0 terminated with code 1 ()
                                    host.iobroker	2016-11-06 20:45:47.732	info	instance system.adapter.zwave.0 started with pid 6259
                                    host.iobroker	2016-11-06 20:45:47.696	info	object change system.adapter.zwave.0
                                    unter zwave.0 ist nichts da…
                                    • Dutchman
                                      @Lenny.CB:
                                      unter zwave.0 ist nichts da… `
                                      Mach mal bitte den adapter auf debug
                                      Leider geht bei mir die installation von git bereits schief damit kan ich nicht mitschaun 😕
                                      ! @HomeControl:/opt/iobroker$ sudo iobroker url "https://github.com/ioBroker/ioBroker.zwave/tarball/master" zwave --debug install https://github.com/ioBroker/ioBroker.zwave/tarball/master npm install https://github.com/ioBroker/ioBroker.zwave/tarball/master --production --prefix "/opt/iobroker" (System call) ! > iobroker.zwave@0.4.0 preinstall /opt/iobroker/node_modules/iobroker.zwave node preinstall.js ! ---> sudo apt-get install libudev-dev -y stdout: Reading package lists... Building dependency tree... Reading state information... libudev-dev is already the newest version (229-4ubuntu12). The following packages were automatically installed and are no longer required: linux-headers-4.4.0-21 linux-headers-4.4.0-21-generic linux-headers-4.4.0-38 linux-headers-4.4.0-38-generic linux-image-4.4.0-21-generic linux-image-4.4.0-38-generic linux-image-extra-4.4.0-21-generic linux-image-extra-4.4.0-38-generic Use 'sudo apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded. ! stderr: stdout: stderr: % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 125 0 125 0 0 194 0 --:--:-- --:--:-- --:--:-- 194 100 1602k 100 1602k 0 0 721k 0 0:00:02 0:00:02 --:--:-- 2228k ! ---> unzip master.zip && rm master.zip stdout: Archive: master.zip 41883f921f28b1c0e094d733d5838634885b2ba4 creating: open-zwave-master/ creating: open-zwave-master/.github/ inflating: open-zwave-master/.github/CONTRIBUTING.md inflating: open-zwave-master/.github/ISSUE_TEMPLATE.md inflating: open-zwave-master/.gitignore inflating: open-zwave-master/ChangeLog inflating: open-zwave-master/INSTALL inflating: open-zwave-master/Makefile inflating: open-zwave-master/README.md creating: open-zwave-master/config/ creating: open-zwave-master/config/2gig/ inflating: open-zwave-master/config/2gig/ct100.xml inflating: open-zwave-master/config/2gig/ct101.xml inflating: open-zwave-master/config/2gig/ct30.xml inflating: open-zwave-master/config/2gig/ct50e.xml creating: open-zwave-master/config/BeNext/ inflating: open-zwave-master/config/BeNext/1poleswitch.xml inflating: open-zwave-master/config/BeNext/2poleswitch.xml inflating: open-zwave-master/config/BeNext/AlarmSound.xml inflating: open-zwave-master/config/BeNext/BuiltinDimmer.xml inflating: open-zwave-master/config/BeNext/DoorSensor.xml inflating: open-zwave-master/config/BeNext/EnergySwitch.xml inflating: open-zwave-master/config/BeNext/HeatingControl.xml inflating: open-zwave-master/config/BeNext/Molite.xml inflating: open-zwave-master/config/BeNext/PanicButton.xml inflating: open-zwave-master/config/BeNext/PanicWatch.xml inflating: open-zwave-master/config/BeNext/PluginDimmer.xml inflating: open-zwave-master/config/BeNext/SceneController.xml inflating: open-zwave-master/config/BeNext/TagReader.xml creating: open-zwave-master/config/act/ inflating: open-zwave-master/config/act/lfm20.xml inflating: open-zwave-master/config/act/zdm230.xml inflating: open-zwave-master/config/act/zdw103.xml inflating: open-zwave-master/config/act/zdw232.xml inflating: open-zwave-master/config/act/zir010.xml inflating: open-zwave-master/config/act/zrp110.xml inflating: open-zwave-master/config/act/zrw103.xml creating: open-zwave-master/config/aeotec/ inflating: open-zwave-master/config/aeotec/dsa03202.xml inflating: open-zwave-master/config/aeotec/dsa22.xml inflating: open-zwave-master/config/aeotec/dsa38.xml inflating: open-zwave-master/config/aeotec/dsb04100.xml inflating: open-zwave-master/config/aeotec/dsb05.xml inflating: open-zwave-master/config/aeotec/dsb09104.xml inflating: open-zwave-master/config/aeotec/dsb28.xml inflating: open-zwave-master/config/aeotec/dsb29.xml inflating: open-zwave-master/config/aeotec/dsb45.xml inflating: open-zwave-master/config/aeotec/dsb54.xml inflating: open-zwave-master/config/aeotec/dsc06106.xml inflating: open-zwave-master/config/aeotec/dsc08101.xml inflating: open-zwave-master/config/aeotec/dsc10.xml inflating: open-zwave-master/config/aeotec/dsc11.xml inflating: open-zwave-master/config/aeotec/dsc12104.xml inflating: open-zwave-master/config/aeotec/dsc13104.xml inflating: open-zwave-master/config/aeotec/dsc14104.xml inflating: open-zwave-master/config/aeotec/dsc18103.xml inflating: open-zwave-master/config/aeotec/dsc19103.xml inflating: open-zwave-master/config/aeotec/dsc24.xml inflating: open-zwave-master/config/aeotec/dsc26103.xml inflating: open-zwave-master/config/aeotec/dsc27103.xml inflating: open-zwave-master/config/aeotec/dsc35103.xml inflating: open-zwave-master/config/aeotec/dsd37.xml inflating: open-zwave-master/config/aeotec/zw056.xml inflating: open-zwave-master/config/aeotec/zw062.xml inflating: open-zwave-master/config/aeotec/zw074.xml inflating: open-zwave-master/config/aeotec/zw075.xml inflating: open-zwave-master/config/aeotec/zw078.xml inflating: open-zwave-master/config/aeotec/zw080.xml inflating: open-zwave-master/config/aeotec/zw088.xml inflating: open-zwave-master/config/aeotec/zw089.xml inflating: open-zwave-master/config/aeotec/zw090.xml inflating: open-zwave-master/config/aeotec/zw095.xml inflating: open-zwave-master/config/aeotec/zw096.xml inflating: open-zwave-master/config/aeotec/zw097.xml inflating: open-zwave-master/config/aeotec/zw098.xml inflating: open-zwave-master/config/aeotec/zw099.xml inflating: open-zwave-master/config/aeotec/zw100.xml inflating: open-zwave-master/config/aeotec/zw112.xml inflating: open-zwave-master/config/aeotec/zw117.xml inflating: open-zwave-master/config/aeotec/zw120.xml inflating: open-zwave-master/config/aeotec/zw121.xml inflating: open-zwave-master/config/aeotec/zw130.xml creating: open-zwave-master/config/assa_abloy/ inflating: open-zwave-master/config/assa_abloy/KeyfreeConnected.xml inflating: open-zwave-master/config/assa_abloy/RealLivingCapTouch.xml creating: open-zwave-master/config/cooper/ inflating: open-zwave-master/config/cooper/RF9505-T.xml inflating: open-zwave-master/config/cooper/RF9540-N.xml creating: open-zwave-master/config/danfoss/ inflating: open-zwave-master/config/danfoss/living.xml inflating: open-zwave-master/config/danfoss/rsroom.xml inflating: open-zwave-master/config/danfoss/z.xml inflating: open-zwave-master/config/device_classes.xml inflating: open-zwave-master/config/device_classes.xsd inflating: open-zwave-master/config/device_configuration.xsd creating: open-zwave-master/config/devolo/ inflating: open-zwave-master/config/devolo/mt02648.xml inflating: open-zwave-master/config/devolo/mt2646.xml inflating: open-zwave-master/config/devolo/mt2647.xml creating: open-zwave-master/config/dlink/ inflating: open-zwave-master/config/dlink/dch-z110.xml inflating: open-zwave-master/config/dlink/dch-z120.xml inflating: open-zwave-master/config/dlink/dch-z510.xml creating: open-zwave-master/config/domitech/ inflating: open-zwave-master/config/domitech/zb22uk.xml inflating: open-zwave-master/config/domitech/ze27eu.xml creating: open-zwave-master/config/dragontech/ inflating: open-zwave-master/config/dragontech/wd-100.xml creating: open-zwave-master/config/duwi/ inflating: open-zwave-master/config/duwi/05458.xml inflating: open-zwave-master/config/duwi/ZWES1000.xml inflating: open-zwave-master/config/duwi/ZWESJ300.xml inflating: open-zwave-master/config/duwi/zwfb.xml creating: open-zwave-master/config/electronicsolutions/ inflating: open-zwave-master/config/electronicsolutions/dbmz.xml creating: open-zwave-master/config/enerwave/ inflating: open-zwave-master/config/enerwave/zw15s.xml inflating: open-zwave-master/config/enerwave/zw20r.xml inflating: open-zwave-master/config/enerwave/zw20rm.xml inflating: open-zwave-master/config/enerwave/zw500d.xml inflating: open-zwave-master/config/enerwave/zwn-bpc.xml inflating: open-zwave-master/config/enerwave/zwn-sc7.xml creating: open-zwave-master/config/eurotronic/ inflating: open-zwave-master/config/eurotronic/eur_cometz.xml inflating: open-zwave-master/config/eurotronic/eur_stellaz.xml creating: open-zwave-master/config/everspring/ inflating: open-zwave-master/config/everspring/ad146.xml inflating: open-zwave-master/config/everspring/ad147.xml inflating: open-zwave-master/config/everspring/an145.xml inflating: open-zwave-master/config/everspring/an158.xml inflating: open-zwave-master/config/everspring/an179.xml inflating: open-zwave-master/config/everspring/an180.xml inflating: open-zwave-master/config/everspring/an181.xml inflating: open-zwave-master/config/everspring/hac01.xml inflating: open-zwave-master/config/everspring/hsp02.xml inflating: open-zwave-master/config/everspring/se812.xml inflating: open-zwave-master/config/everspring/sf812.xml inflating: open-zwave-master/config/everspring/sm103.xml inflating: open-zwave-master/config/everspring/sp103.xml inflating: open-zwave-master/config/everspring/sp814.xml inflating: open-zwave-master/config/everspring/st812.xml inflating: open-zwave-master/config/everspring/st814.xml inflating: open-zwave-master/config/everspring/st815.xml inflating: open-zwave-master/config/everspring/tse03.xml creating: open-zwave-master/config/everspringct/ inflating: open-zwave-master/config/everspringct/hsm02.xml creating: open-zwave-master/config/evolve/ inflating: open-zwave-master/config/evolve/lrm-as.xml inflating: open-zwave-master/config/evolve/lsm-15.xml inflating: open-zwave-master/config/evolve/ltm-5.xml creating: open-zwave-master/config/fakro/ inflating: open-zwave-master/config/fakro/zws12.xml inflating: open-zwave-master/config/fakro/zws230.xml creating: open-zwave-master/config/fibaro/ inflating: open-zwave-master/config/fibaro/fgbs001.xml inflating: open-zwave-master/config/fibaro/fgd211.xml inflating: open-zwave-master/config/fibaro/fgd212.xml inflating: open-zwave-master/config/fibaro/fgfs101.xml inflating: open-zwave-master/config/fibaro/fgfs101zw5.xml inflating: open-zwave-master/config/fibaro/fggc001.xml inflating: open-zwave-master/config/fibaro/fgk001.xml inflating: open-zwave-master/config/fibaro/fgk10x.xml inflating: open-zwave-master/config/fibaro/fgms.xml inflating: open-zwave-master/config/fibaro/fgpb101.xml inflating: open-zwave-master/config/fibaro/fgr221.xml inflating: open-zwave-master/config/fibaro/fgr222.xml inflating: open-zwave-master/config/fibaro/fgrgbwm441.xml inflating: open-zwave-master/config/fibaro/fgrm222.xml inflating: open-zwave-master/config/fibaro/fgs211.xml inflating: open-zwave-master/config/fibaro/fgs212.xml inflating: open-zwave-master/config/fibaro/fgs213.xml inflating: open-zwave-master/config/fibaro/fgs221.xml inflating: open-zwave-master/config/fibaro/fgs222.xml inflating: open-zwave-master/config/fibaro/fgs223.xml inflating: open-zwave-master/config/fibaro/fgsd002.xml inflating: open-zwave-master/config/fibaro/fgss101.xml inflating: open-zwave-master/config/fibaro/fgwpe.xml creating: open-zwave-master/config/firstalert/ inflating: open-zwave-master/config/firstalert/zcombo.xml creating: open-zwave-master/config/fortrezz/ inflating: open-zwave-master/config/fortrezz/mimolite.xml inflating: open-zwave-master/config/fortrezz/ssa2.xml inflating: open-zwave-master/config/fortrezz/ssa3.xml inflating: open-zwave-master/config/fortrezz/wv01.xml inflating: open-zwave-master/config/fortrezz/wwa02.xml creating: open-zwave-master/config/frostdale/ inflating: open-zwave-master/config/frostdale/fdn2nxx.xml creating: open-zwave-master/config/ge/ inflating: open-zwave-master/config/ge/12724-dimmer.xml inflating: open-zwave-master/config/ge/dimmer.xml inflating: open-zwave-master/config/ge/dimmer_module.xml inflating: open-zwave-master/config/ge/hinge-pin.xml inflating: open-zwave-master/config/ge/receptacle.xml inflating: open-zwave-master/config/ge/relay.xml creating: open-zwave-master/config/gr/ inflating: open-zwave-master/config/gr/gr105.xml inflating: open-zwave-master/config/gr/gr105n.xml creating: open-zwave-master/config/greenwave/ inflating: open-zwave-master/config/greenwave/powernode1.xml inflating: open-zwave-master/config/greenwave/powernode6.xml creating: open-zwave-master/config/homeseer/ inflating: open-zwave-master/config/homeseer/ezmotionplus.xml inflating: open-zwave-master/config/homeseer/hsm100.xml inflating: open-zwave-master/config/homeseer/hsm200.xml inflating: open-zwave-master/config/homeseer/ztroller.xml creating: open-zwave-master/config/honeywell/ inflating: open-zwave-master/config/honeywell/th8320zw1000.xml creating: open-zwave-master/config/horstmann/ inflating: open-zwave-master/config/horstmann/asrzw.xml inflating: open-zwave-master/config/horstmann/hrt4zw.xml inflating: open-zwave-master/config/horstmann/scsc17.xml inflating: open-zwave-master/config/horstmann/ses302.xml inflating: open-zwave-master/config/horstmann/ses303.xml inflating: open-zwave-master/config/horstmann/sir321.xml inflating: open-zwave-master/config/horstmann/srt323.xml creating: open-zwave-master/config/idlock/ inflating: open-zwave-master/config/idlock/idlock101.xml creating: open-zwave-master/config/intermatic/ inflating: open-zwave-master/config/intermatic/ca8900.xml creating: open-zwave-master/config/iris/ inflating: open-zwave-master/config/iris/rangeextender.xml creating: open-zwave-master/config/kwikset/ inflating: open-zwave-master/config/kwikset/smartcode.xml creating: open-zwave-master/config/leviton/ inflating: open-zwave-master/config/leviton/rzi10.xml inflating: open-zwave-master/config/leviton/vrcpg.xml inflating: open-zwave-master/config/leviton/vrf01.xml inflating: open-zwave-master/config/leviton/vri06.xml inflating: open-zwave-master/config/leviton/vri10.xml creating: open-zwave-master/config/linear/ inflating: open-zwave-master/config/linear/LB60Z-1.xml inflating: open-zwave-master/config/linear/PD300Z-2.xml inflating: open-zwave-master/config/linear/WA00Z-1.xml inflating: open-zwave-master/config/linear/WD500Z-1.xml inflating: open-zwave-master/config/manufacturer_specific.xml inflating: open-zwave-master/config/manufacturer_specific.xsd creating: open-zwave-master/config/mcohome/ inflating: open-zwave-master/config/mcohome/mhp210.xml inflating: open-zwave-master/config/mcohome/mhs311.xml inflating: open-zwave-master/config/mcohome/mhs312.xml inflating: open-zwave-master/config/mcohome/mhs314.xml inflating: open-zwave-master/config/mcohome/mhs411.xml inflating: open-zwave-master/config/mcohome/mhs412.xml inflating: open-zwave-master/config/mcohome/mhs513.xml creating: open-zwave-master/config/merten/ inflating: open-zwave-master/config/merten/507801.xml inflating: open-zwave-master/config/merten/50x5xx.xml creating: open-zwave-master/config/nexia/ inflating: open-zwave-master/config/nexia/db100z.xml creating: open-zwave-master/config/nodon/ inflating: open-zwave-master/config/nodon/asp3100SmartPlug.xml inflating: open-zwave-master/config/nodon/crc3100OctanRemote.xml inflating: open-zwave-master/config/nodon/crc360xSofremote.xml inflating: open-zwave-master/config/nodon/cws3101wallswitch.xml inflating: open-zwave-master/config/nodon/msp31xxMicroSmartPlug.xml creating: open-zwave-master/config/northq/ inflating: open-zwave-master/config/northq/nq9021.xml inflating: open-zwave-master/config/northq/nq9121.xml inflating: open-zwave-master/config/northq/nq92021.xml inflating: open-zwave-master/config/options.xml inflating: open-zwave-master/config/options.xsd creating: open-zwave-master/config/philio/ inflating: open-zwave-master/config/philio/pan03.xml inflating: open-zwave-master/config/philio/pan04.xml inflating: open-zwave-master/config/philio/pan08.xml inflating: open-zwave-master/config/philio/phpab01.xml inflating: open-zwave-master/config/philio/phpat02.xml inflating: open-zwave-master/config/philio/phpsg01.xml inflating: open-zwave-master/config/philio/pse02.xml inflating: open-zwave-master/config/philio/psm02.xml inflating: open-zwave-master/config/philio/psr04.xml inflating: open-zwave-master/config/philio/pst02-1c.xml inflating: open-zwave-master/config/philio/pst02-b.xml inflating: open-zwave-master/config/philio/pst02.xml creating: open-zwave-master/config/polycontrol/ inflating: open-zwave-master/config/polycontrol/doorlock.xml inflating: open-zwave-master/config/polycontrol/keypad.xml inflating: open-zwave-master/config/polycontrol/polylock.xml creating: open-zwave-master/config/popp/ inflating: open-zwave-master/config/popp/009105.xml inflating: open-zwave-master/config/popp/009303.xml inflating: open-zwave-master/config/popp/123580.xml inflating: open-zwave-master/config/popp/123601.xml inflating: open-zwave-master/config/popp/123658.xml inflating: open-zwave-master/config/popp/smoke-detector.xml inflating: open-zwave-master/config/popp/solar-siren.xml inflating: open-zwave-master/config/popp/zweather.xml creating: open-zwave-master/config/qees/ inflating: open-zwave-master/config/qees/reto-dimmer-plus.xml inflating: open-zwave-master/config/qees/reto-plugin-switch.xml creating: open-zwave-master/config/qubino/ inflating: open-zwave-master/config/qubino/ZMNHAA2.xml inflating: open-zwave-master/config/qubino/ZMNHADx.xml inflating: open-zwave-master/config/qubino/ZMNHBA2.xml inflating: open-zwave-master/config/qubino/ZMNHBDx.xml inflating: open-zwave-master/config/qubino/ZMNHCA2.xml inflating: open-zwave-master/config/qubino/ZMNHCDx.xml inflating: open-zwave-master/config/qubino/ZMNHDA2.xml inflating: open-zwave-master/config/qubino/ZMNHDDx.xml inflating: open-zwave-master/config/qubino/ZMNHIA2.xml inflating: open-zwave-master/config/qubino/ZMNHIDxS1.xml inflating: open-zwave-master/config/qubino/ZMNHIDxS2.xml inflating: open-zwave-master/config/qubino/ZMNHJA2.xml inflating: open-zwave-master/config/qubino/ZMNHJD1.xml inflating: open-zwave-master/config/qubino/ZMNHKDx.xml inflating: open-zwave-master/config/qubino/ZMNHLAx.xml inflating: open-zwave-master/config/qubino/ZMNHLDx.xml inflating: open-zwave-master/config/qubino/ZMNHNDx.xml inflating: open-zwave-master/config/qubino/ZMNHODx.xml inflating: open-zwave-master/config/qubino/ZMNHSDx.xml inflating: open-zwave-master/config/qubino/ZMNHTDx.xml inflating: open-zwave-master/config/qubino/ZMNHUD1.xml inflating: open-zwave-master/config/qubino/ZMNHVDx.xml inflating: open-zwave-master/config/qubino/ZMNHZDx.xml creating: open-zwave-master/config/rcs/ inflating: open-zwave-master/config/rcs/em52-zw.xml inflating: open-zwave-master/config/rcs/pm12-zw.xml inflating: open-zwave-master/config/rcs/therm0005.xml inflating: open-zwave-master/config/rcs/therm0007.xml inflating: open-zwave-master/config/rcs/therm0009.xml creating: open-zwave-master/config/remotec/ inflating: open-zwave-master/config/remotec/zfm-80.xml inflating: open-zwave-master/config/remotec/zrc-90.xml inflating: open-zwave-master/config/remotec/zts-110.xml inflating: open-zwave-master/config/remotec/zurc.xml inflating: open-zwave-master/config/remotec/zxt-120.xml creating: open-zwave-master/config/schlage/ inflating: open-zwave-master/config/schlage/BE469NXCEN.xml creating: open-zwave-master/config/schlagelink/ inflating: open-zwave-master/config/schlagelink/itemp.xml inflating: open-zwave-master/config/schlagelink/minikeypad.xml creating: open-zwave-master/config/sensative/ inflating: open-zwave-master/config/sensative/strips.xml creating: open-zwave-master/config/shenzen_neo/ inflating: open-zwave-master/config/shenzen_neo/nas-ds01z.xml inflating: open-zwave-master/config/shenzen_neo/nas-pd01z.xml inflating: open-zwave-master/config/shenzen_neo/nas-wr01z.xml inflating: open-zwave-master/config/shenzen_neo/nas-ws02z.xml creating: open-zwave-master/config/stelpro/ inflating: open-zwave-master/config/stelpro/stzw402.xml creating: open-zwave-master/config/swiid/ inflating: open-zwave-master/config/swiid/swiidinter.xml inflating: open-zwave-master/config/swiid/swiidplug.xml creating: open-zwave-master/config/telldus/ inflating: open-zwave-master/config/telldus/tzdw100.xml creating: open-zwave-master/config/thermofloor/ inflating: open-zwave-master/config/thermofloor/heatit021.xml creating: open-zwave-master/config/trane/ inflating: open-zwave-master/config/trane/TZEMT400AB32MAA.xml inflating: open-zwave-master/config/trane/TZEMT400BB32MAA.xml creating: open-zwave-master/config/vision/ inflating: open-zwave-master/config/vision/zd2102.xml inflating: open-zwave-master/config/vision/zd2201.xml inflating: open-zwave-master/config/vision/zg8101.xml inflating: open-zwave-master/config/vision/zm1601eu.xml inflating: open-zwave-master/config/vision/zm1601eu5.xml inflating: open-zwave-master/config/vision/zm1602eu.xml inflating: open-zwave-master/config/vision/zm1602eu5.xml inflating: open-zwave-master/config/vision/zp3102.xml inflating: open-zwave-master/config/vision/zp3111.xml inflating: open-zwave-master/config/vision/zs5101eu.xml creating: open-zwave-master/config/vitrum/ inflating: open-zwave-master/config/vitrum/vitrumBS.xml creating: open-zwave-master/config/waynedalton/ inflating: open-zwave-master/config/waynedalton/WDTC-20.xml creating: open-zwave-master/config/wenzhou/ inflating: open-zwave-master/config/wenzhou/sm103.xml inflating: open-zwave-master/config/wenzhou/tsp01.xml inflating: open-zwave-master/config/wenzhou/tz55.xml inflating: open-zwave-master/config/wenzhou/tz56.xml inflating: open-zwave-master/config/wenzhou/tz65d.xml inflating: open-zwave-master/config/wenzhou/tz66d.xml inflating: open-zwave-master/config/wenzhou/tz67.xml inflating: open-zwave-master/config/wenzhou/tz68.xml inflating: open-zwave-master/config/wenzhou/tz88.xml creating: open-zwave-master/config/widom/ inflating: open-zwave-master/config/widom/UBS104.xml inflating: open-zwave-master/config/widom/UME304C_S.xml inflating: open-zwave-master/config/widom/WDS.xml creating: open-zwave-master/config/zipato/ inflating: open-zwave-master/config/zipato/MiniKeypad.xml inflating: open-zwave-master/config/zipato/RGBBulb.xml creating: open-zwave-master/config/zooz/ inflating: open-zwave-master/config/zooz/zen07.xml inflating: open-zwave-master/config/zooz/zse08.xml inflating: open-zwave-master/config/zooz/zse09.xml creating: open-zwave-master/config/zwave.me/ inflating: open-zwave-master/config/zwave.me/ZME_05431.xml inflating: open-zwave-master/config/zwave.me/ZME_06433.xml inflating: open-zwave-master/config/zwave.me/ZME_06436.xml inflating: open-zwave-master/config/zwave.me/ZME_064381.xml inflating: open-zwave-master/config/zwave.me/ZME_064435.xml inflating: open-zwave-master/config/zwave.me/ZME_KFOB-S.xml inflating: open-zwave-master/config/zwave.me/ZME_RC2.xml inflating: open-zwave-master/config/zwave.me/ZME_WALLC-S.xml inflating: open-zwave-master/config/zwave.me/ZME_WCD2.xml inflating: open-zwave-master/config/zwave.me/ZUno.xml inflating: open-zwave-master/config/zwave.me/iTemp.xml inflating: open-zwave-master/config/zwave.me/kfob.xml inflating: open-zwave-master/config/zwave.me/popp_kfob-c.xml inflating: open-zwave-master/config/zwave.me/zweather.xml inflating: open-zwave-master/config/zwcfg.xsd inflating: open-zwave-master/config/zwscene.xsd creating: open-zwave-master/cpp/ creating: open-zwave-master/cpp/build/ inflating: open-zwave-master/cpp/build/Makefile inflating: open-zwave-master/cpp/build/OZW_RunTests.sh inflating: open-zwave-master/cpp/build/libopenzwave.pc.in inflating: open-zwave-master/cpp/build/ozw_config.in inflating: open-zwave-master/cpp/build/sh2ju.sh inflating: open-zwave-master/cpp/build/support.mk inflating: open-zwave-master/cpp/build/testconfig.pl inflating: open-zwave-master/cpp/build/testconfigsuppressions.cfg creating: open-zwave-master/cpp/build/winRT/ creating: open-zwave-master/cpp/build/winRT/vs2015/ inflating: open-zwave-master/cpp/build/winRT/vs2015/OpenZWave.sln inflating: open-zwave-master/cpp/build/winRT/vs2015/OpenZWave.vcxproj inflating: open-zwave-master/cpp/build/winRT/vs2015/OpenZWave.vcxproj.filters creating: open-zwave-master/cpp/build/windows/ inflating: open-zwave-master/cpp/build/windows/GIT-VS-VERSION-GEN.bat creating: open-zwave-master/cpp/build/windows/installer/ inflating: open-zwave-master/cpp/build/windows/installer/buildall.bat inflating: open-zwave-master/cpp/build/windows/installer/openzwave.nsi creating: open-zwave-master/cpp/build/windows/mingw32/ inflating: open-zwave-master/cpp/build/windows/mingw32/Makefile creating: open-zwave-master/cpp/build/windows/vs2008/ inflating: open-zwave-master/cpp/build/windows/vs2008/OpenZWave.sln inflating: open-zwave-master/cpp/build/windows/vs2008/OpenZWave.vcproj creating: open-zwave-master/cpp/build/windows/vs2010/ inflating: open-zwave-master/cpp/build/windows/vs2010/OpenZWave.sln inflating: open-zwave-master/cpp/build/windows/vs2010/OpenZWave.vcxproj inflating: open-zwave-master/cpp/build/windows/vs2010/OpenZWave.vcxproj.filters inflating: open-zwave-master/cpp/build/windows/winversion.tmpl creating: open-zwave-master/cpp/examples/ creating: open-zwave-master/cpp/examples/MinOZW/ inflating: open-zwave-master/cpp/examples/MinOZW/Main.cpp inflating: open-zwave-master/cpp/examples/MinOZW/Makefile inflating: open-zwave-master/cpp/examples/MinOZW/MinOZW.in creating: open-zwave-master/cpp/examples/windows/ creating: open-zwave-master/cpp/examples/windows/MinOZW/ inflating: open-zwave-master/cpp/examples/windows/MinOZW/Main.cpp creating: open-zwave-master/cpp/examples/windows/MinOZW/vs2008/ inflating: open-zwave-master/cpp/examples/windows/MinOZW/vs2008/MinOZW.sln inflating: open-zwave-master/cpp/examples/windows/MinOZW/vs2008/MinOZW.vcproj creating: open-zwave-master/cpp/examples/windows/MinOZW/vs2010/ inflating: open-zwave-master/cpp/examples/windows/MinOZW/vs2010/MinOZW.sln inflating: open-zwave-master/cpp/examples/windows/MinOZW/vs2010/MinOZW.vcxproj inflating: open-zwave-master/cpp/examples/windows/MinOZW/vs2010/MinOZW.vcxproj.filters creating: open-zwave-master/cpp/hidapi/ inflating: open-zwave-master/cpp/hidapi/AUTHORS.txt inflating: open-zwave-master/cpp/hidapi/HACKING.txt inflating: open-zwave-master/cpp/hidapi/LICENSE-bsd.txt inflating: open-zwave-master/cpp/hidapi/LICENSE-gpl3.txt inflating: open-zwave-master/cpp/hidapi/LICENSE-orig.txt inflating: open-zwave-master/cpp/hidapi/LICENSE.txt inflating: open-zwave-master/cpp/hidapi/Makefile.am inflating: open-zwave-master/cpp/hidapi/README.txt inflating: open-zwave-master/cpp/hidapi/bootstrap inflating: open-zwave-master/cpp/hidapi/configure.ac creating: open-zwave-master/cpp/hidapi/doxygen/ inflating: open-zwave-master/cpp/hidapi/doxygen/Doxyfile creating: open-zwave-master/cpp/hidapi/hidapi/ inflating: open-zwave-master/cpp/hidapi/hidapi/hidapi.h creating: open-zwave-master/cpp/hidapi/libusb/ inflating: open-zwave-master/cpp/hidapi/libusb/Makefile-manual inflating: open-zwave-master/cpp/hidapi/libusb/Makefile.am inflating: open-zwave-master/cpp/hidapi/libusb/Makefile.freebsd inflating: open-zwave-master/cpp/hidapi/libusb/Makefile.linux inflating: open-zwave-master/cpp/hidapi/libusb/hid.c creating: open-zwave-master/cpp/hidapi/linux/ inflating: open-zwave-master/cpp/hidapi/linux/.gitignore inflating: open-zwave-master/cpp/hidapi/linux/Makefile-manual inflating: open-zwave-master/cpp/hidapi/linux/Makefile.am inflating: open-zwave-master/cpp/hidapi/linux/README.txt inflating: open-zwave-master/cpp/hidapi/linux/hid.c creating: open-zwave-master/cpp/hidapi/m4/ inflating: open-zwave-master/cpp/hidapi/m4/ax_pthread.m4 inflating: open-zwave-master/cpp/hidapi/m4/pkg.m4 creating: open-zwave-master/cpp/hidapi/mac/ inflating: open-zwave-master/cpp/hidapi/mac/.gitignore inflating: open-zwave-master/cpp/hidapi/mac/Makefile-manual inflating: open-zwave-master/cpp/hidapi/mac/Makefile.am inflating: open-zwave-master/cpp/hidapi/mac/hid.c creating: open-zwave-master/cpp/hidapi/pc/ inflating: open-zwave-master/cpp/hidapi/pc/hidapi-hidraw.pc.in inflating: open-zwave-master/cpp/hidapi/pc/hidapi-libusb.pc.in inflating: open-zwave-master/cpp/hidapi/pc/hidapi.pc.in creating: open-zwave-master/cpp/hidapi/udev/ inflating: open-zwave-master/cpp/hidapi/udev/99-hid.rules creating: open-zwave-master/cpp/hidapi/windows/ inflating: open-zwave-master/cpp/hidapi/windows/.gitignore inflating: open-zwave-master/cpp/hidapi/windows/Makefile-manual inflating: open-zwave-master/cpp/hidapi/windows/Makefile.am inflating: open-zwave-master/cpp/hidapi/windows/Makefile.mingw creating: open-zwave-master/cpp/hidapi/windows/ddk_build/ extracting: open-zwave-master/cpp/hidapi/windows/ddk_build/.gitignore inflating: open-zwave-master/cpp/hidapi/windows/ddk_build/hidapi.def inflating: open-zwave-master/cpp/hidapi/windows/ddk_build/makefile inflating: open-zwave-master/cpp/hidapi/windows/ddk_build/sources inflating: open-zwave-master/cpp/hidapi/windows/hid.cpp inflating: open-zwave-master/cpp/hidapi/windows/hidapi.sln inflating: open-zwave-master/cpp/hidapi/windows/hidapi.vcproj inflating: open-zwave-master/cpp/hidapi/windows/hidtest.vcproj creating: open-zwave-master/cpp/src/ inflating: open-zwave-master/cpp/src/Bitfield.h inflating: open-zwave-master/cpp/src/Defs.h inflating: open-zwave-master/cpp/src/DoxygenMain.h inflating: open-zwave-master/cpp/src/Driver.cpp inflating: open-zwave-master/cpp/src/Driver.h inflating: open-zwave-master/cpp/src/Group.cpp inflating: open-zwave-master/cpp/src/Group.h inflating: open-zwave-master/cpp/src/Manager.cpp inflating: open-zwave-master/cpp/src/Manager.h inflating: open-zwave-master/cpp/src/Msg.cpp inflating: open-zwave-master/cpp/src/Msg.h inflating: open-zwave-master/cpp/src/Node.cpp inflating: open-zwave-master/cpp/src/Node.h inflating: open-zwave-master/cpp/src/Notification.cpp inflating: open-zwave-master/cpp/src/Notification.h inflating: open-zwave-master/cpp/src/OZWException.h inflating: open-zwave-master/cpp/src/Options.cpp inflating: open-zwave-master/cpp/src/Options.h inflating: open-zwave-master/cpp/src/Scene.cpp inflating: open-zwave-master/cpp/src/Scene.h inflating: open-zwave-master/cpp/src/Utils.cpp inflating: open-zwave-master/cpp/src/Utils.h inflating: open-zwave-master/cpp/src/ZWSecurity.cpp inflating: open-zwave-master/cpp/src/ZWSecurity.h creating: open-zwave-master/cpp/src/aes/ inflating: open-zwave-master/cpp/src/aes/aes.h inflating: open-zwave-master/cpp/src/aes/aes.txt inflating: open-zwave-master/cpp/src/aes/aes_modes.c inflating: open-zwave-master/cpp/src/aes/aescpp.h inflating: open-zwave-master/cpp/src/aes/aescrypt.c inflating: open-zwave-master/cpp/src/aes/aeskey.c inflating: open-zwave-master/cpp/src/aes/aesopt.h inflating: open-zwave-master/cpp/src/aes/aestab.c inflating: open-zwave-master/cpp/src/aes/aestab.h inflating: open-zwave-master/cpp/src/aes/brg_endian.h inflating: open-zwave-master/cpp/src/aes/brg_types.h creating: open-zwave-master/cpp/src/command_classes/ inflating: open-zwave-master/cpp/src/command_classes/Alarm.cpp inflating: open-zwave-master/cpp/src/command_classes/Alarm.h inflating: open-zwave-master/cpp/src/command_classes/ApplicationStatus.cpp inflating: open-zwave-master/cpp/src/command_classes/ApplicationStatus.h inflating: open-zwave-master/cpp/src/command_classes/Association.cpp inflating: open-zwave-master/cpp/src/command_classes/Association.h inflating: open-zwave-master/cpp/src/command_classes/AssociationCommandConfiguration.cpp inflating: open-zwave-master/cpp/src/command_classes/AssociationCommandConfiguration.h inflating: open-zwave-master/cpp/src/command_classes/Basic.cpp inflating: open-zwave-master/cpp/src/command_classes/Basic.h inflating: open-zwave-master/cpp/src/command_classes/BasicWindowCovering.cpp inflating: open-zwave-master/cpp/src/command_classes/BasicWindowCovering.h inflating: open-zwave-master/cpp/src/command_classes/Battery.cpp inflating: open-zwave-master/cpp/src/command_classes/Battery.h inflating: open-zwave-master/cpp/src/command_classes/CRC16Encap.cpp inflating: open-zwave-master/cpp/src/command_classes/CRC16Encap.h inflating: open-zwave-master/cpp/src/command_classes/CentralScene.cpp inflating: open-zwave-master/cpp/src/command_classes/CentralScene.h inflating: open-zwave-master/cpp/src/command_classes/ClimateControlSchedule.cpp inflating: open-zwave-master/cpp/src/command_classes/ClimateControlSchedule.h inflating: open-zwave-master/cpp/src/command_classes/Clock.cpp inflating: open-zwave-master/cpp/src/command_classes/Clock.h inflating: open-zwave-master/cpp/src/command_classes/Color.cpp inflating: open-zwave-master/cpp/src/command_classes/Color.h inflating: open-zwave-master/cpp/src/command_classes/CommandClass.cpp inflating: open-zwave-master/cpp/src/command_classes/CommandClass.h inflating: open-zwave-master/cpp/src/command_classes/CommandClasses.cpp inflating: open-zwave-master/cpp/src/command_classes/CommandClasses.h inflating: open-zwave-master/cpp/src/command_classes/Configuration.cpp inflating: open-zwave-master/cpp/src/command_classes/Configuration.h inflating: open-zwave-master/cpp/src/command_classes/ControllerReplication.cpp inflating: open-zwave-master/cpp/src/command_classes/ControllerReplication.h inflating: open-zwave-master/cpp/src/command_classes/DeviceResetLocally.cpp inflating: open-zwave-master/cpp/src/command_classes/DeviceResetLocally.h inflating: open-zwave-master/cpp/src/command_classes/DoorLock.cpp inflating: open-zwave-master/cpp/src/command_classes/DoorLock.h inflating: open-zwave-master/cpp/src/command_classes/DoorLockLogging.cpp inflating: open-zwave-master/cpp/src/command_classes/DoorLockLogging.h inflating: open-zwave-master/cpp/src/command_classes/EnergyProduction.cpp inflating: open-zwave-master/cpp/src/command_classes/EnergyProduction.h inflating: open-zwave-master/cpp/src/command_classes/Hail.cpp inflating: open-zwave-master/cpp/src/command_classes/Hail.h inflating: open-zwave-master/cpp/src/command_classes/Indicator.cpp inflating: open-zwave-master/cpp/src/command_classes/Indicator.h inflating: open-zwave-master/cpp/src/command_classes/Language.cpp inflating: open-zwave-master/cpp/src/command_classes/Language.h inflating: open-zwave-master/cpp/src/command_classes/Lock.cpp inflating: open-zwave-master/cpp/src/command_classes/Lock.h inflating: open-zwave-master/cpp/src/command_classes/ManufacturerSpecific.cpp inflating: open-zwave-master/cpp/src/command_classes/ManufacturerSpecific.h inflating: open-zwave-master/cpp/src/command_classes/Meter.cpp inflating: open-zwave-master/cpp/src/command_classes/Meter.h inflating: open-zwave-master/cpp/src/command_classes/MeterPulse.cpp inflating: open-zwave-master/cpp/src/command_classes/MeterPulse.h inflating: open-zwave-master/cpp/src/command_classes/MultiCmd.cpp inflating: open-zwave-master/cpp/src/command_classes/MultiCmd.h inflating: open-zwave-master/cpp/src/command_classes/MultiInstance.cpp inflating: open-zwave-master/cpp/src/command_classes/MultiInstance.h inflating: open-zwave-master/cpp/src/command_classes/MultiInstanceAssociation.cpp inflating: open-zwave-master/cpp/src/command_classes/MultiInstanceAssociation.h inflating: open-zwave-master/cpp/src/command_classes/NoOperation.cpp inflating: open-zwave-master/cpp/src/command_classes/NoOperation.h inflating: open-zwave-master/cpp/src/command_classes/NodeNaming.cpp inflating: open-zwave-master/cpp/src/command_classes/NodeNaming.h inflating: open-zwave-master/cpp/src/command_classes/Powerlevel.cpp inflating: open-zwave-master/cpp/src/command_classes/Powerlevel.h inflating: open-zwave-master/cpp/src/command_classes/Proprietary.cpp inflating: open-zwave-master/cpp/src/command_classes/Proprietary.h inflating: open-zwave-master/cpp/src/command_classes/Protection.cpp inflating: open-zwave-master/cpp/src/command_classes/Protection.h inflating: open-zwave-master/cpp/src/command_classes/SceneActivation.cpp inflating: open-zwave-master/cpp/src/command_classes/SceneActivation.h inflating: open-zwave-master/cpp/src/command_classes/Security.cpp inflating: open-zwave-master/cpp/src/command_classes/Security.h inflating: open-zwave-master/cpp/src/command_classes/SensorAlarm.cpp inflating: open-zwave-master/cpp/src/command_classes/SensorAlarm.h inflating: open-zwave-master/cpp/src/command_classes/SensorBinary.cpp inflating: open-zwave-master/cpp/src/command_classes/SensorBinary.h inflating: open-zwave-master/cpp/src/command_classes/SensorMultilevel.cpp inflating: open-zwave-master/cpp/src/command_classes/SensorMultilevel.h inflating: open-zwave-master/cpp/src/command_classes/SwitchAll.cpp inflating: open-zwave-master/cpp/src/command_classes/SwitchAll.h inflating: open-zwave-master/cpp/src/command_classes/SwitchBinary.cpp inflating: open-zwave-master/cpp/src/command_classes/SwitchBinary.h inflating: open-zwave-master/cpp/src/command_classes/SwitchMultilevel.cpp inflating: open-zwave-master/cpp/src/command_classes/SwitchMultilevel.h inflating: open-zwave-master/cpp/src/command_classes/SwitchToggleBinary.cpp inflating: open-zwave-master/cpp/src/command_classes/SwitchToggleBinary.h inflating: open-zwave-master/cpp/src/command_classes/SwitchToggleMultilevel.cpp inflating: open-zwave-master/cpp/src/command_classes/SwitchToggleMultilevel.h inflating: open-zwave-master/cpp/src/command_classes/ThermostatFanMode.cpp inflating: open-zwave-master/cpp/src/command_classes/ThermostatFanMode.h inflating: open-zwave-master/cpp/src/command_classes/ThermostatFanState.cpp inflating: open-zwave-master/cpp/src/command_classes/ThermostatFanState.h inflating: open-zwave-master/cpp/src/command_classes/ThermostatMode.cpp inflating: open-zwave-master/cpp/src/command_classes/ThermostatMode.h inflating: open-zwave-master/cpp/src/command_classes/ThermostatOperatingState.cpp inflating: open-zwave-master/cpp/src/command_classes/ThermostatOperatingState.h inflating: open-zwave-master/cpp/src/command_classes/ThermostatSetpoint.cpp inflating: open-zwave-master/cpp/src/command_classes/ThermostatSetpoint.h inflating: open-zwave-master/cpp/src/command_classes/TimeParameters.cpp inflating: open-zwave-master/cpp/src/command_classes/TimeParameters.h inflating: open-zwave-master/cpp/src/command_classes/UserCode.cpp inflating: open-zwave-master/cpp/src/command_classes/UserCode.h inflating: open-zwave-master/cpp/src/command_classes/Version.cpp inflating: open-zwave-master/cpp/src/command_classes/Version.h inflating: open-zwave-master/cpp/src/command_classes/WakeUp.cpp inflating: open-zwave-master/cpp/src/command_classes/WakeUp.h inflating: open-zwave-master/cpp/src/command_classes/ZWavePlusInfo.cpp inflating: open-zwave-master/cpp/src/command_classes/ZWavePlusInfo.h creating: open-zwave-master/cpp/src/platform/ inflating: open-zwave-master/cpp/src/platform/Controller.cpp inflating: open-zwave-master/cpp/src/platform/Controller.h inflating: open-zwave-master/cpp/src/platform/Event.cpp inflating: open-zwave-master/cpp/src/platform/Event.h inflating: open-zwave-master/cpp/src/platform/FileOps.cpp inflating: open-zwave-master/cpp/src/platform/FileOps.h inflating: open-zwave-master/cpp/src/platform/HidController.cpp inflating: open-zwave-master/cpp/src/platform/HidController.h inflating: open-zwave-master/cpp/src/platform/Log.cpp inflating: open-zwave-master/cpp/src/platform/Log.h inflating: open-zwave-master/cpp/src/platform/Mutex.cpp inflating: open-zwave-master/cpp/src/platform/Mutex.h inflating: open-zwave-master/cpp/src/platform/Ref.h inflating: open-zwave-master/cpp/src/platform/SerialController.cpp inflating: open-zwave-master/cpp/src/platform/SerialController.h inflating: open-zwave-master/cpp/src/platform/Stream.cpp inflating: open-zwave-master/cpp/src/platform/Stream.h inflating: open-zwave-master/cpp/src/platform/Thread.cpp inflating: open-zwave-master/cpp/src/platform/Thread.h inflating: open-zwave-master/cpp/src/platform/TimeStamp.cpp inflating: open-zwave-master/cpp/src/platform/TimeStamp.h inflating: open-zwave-master/cpp/src/platform/Wait.cpp inflating: open-zwave-master/cpp/src/platform/Wait.h creating: open-zwave-master/cpp/src/platform/unix/ inflating: open-zwave-master/cpp/src/platform/unix/EventImpl.cpp inflating: open-zwave-master/cpp/src/platform/unix/EventImpl.h inflating: open-zwave-master/cpp/src/platform/unix/FileOpsImpl.cpp inflating: open-zwave-master/cpp/src/platform/unix/FileOpsImpl.h inflating: open-zwave-master/cpp/src/platform/unix/LogImpl.cpp inflating: open-zwave-master/cpp/src/platform/unix/LogImpl.h inflating: open-zwave-master/cpp/src/platform/unix/MutexImpl.cpp inflating: open-zwave-master/cpp/src/platform/unix/MutexImpl.h inflating: open-zwave-master/cpp/src/platform/unix/SerialControllerImpl.cpp inflating: open-zwave-master/cpp/src/platform/unix/SerialControllerImpl.h inflating: open-zwave-master/cpp/src/platform/unix/ThreadImpl.cpp inflating: open-zwave-master/cpp/src/platform/unix/ThreadImpl.h inflating: open-zwave-master/cpp/src/platform/unix/TimeStampImpl.cpp inflating: open-zwave-master/cpp/src/platform/unix/TimeStampImpl.h inflating: open-zwave-master/cpp/src/platform/unix/WaitImpl.cpp inflating: open-zwave-master/cpp/src/platform/unix/WaitImpl.h creating: open-zwave-master/cpp/src/platform/winRT/ inflating: open-zwave-master/cpp/src/platform/winRT/EventImpl.cpp inflating: open-zwave-master/cpp/src/platform/winRT/EventImpl.h inflating: open-zwave-master/cpp/src/platform/winRT/FileOpsImpl.cpp inflating: open-zwave-master/cpp/src/platform/winRT/FileOpsImpl.h inflating: open-zwave-master/cpp/src/platform/winRT/HidControllerWinRT.cpp inflating: open-zwave-master/cpp/src/platform/winRT/HidControllerWinRT.h inflating: open-zwave-master/cpp/src/platform/winRT/LogImpl.cpp inflating: open-zwave-master/cpp/src/platform/winRT/LogImpl.h inflating: open-zwave-master/cpp/src/platform/winRT/MutexImpl.cpp inflating: open-zwave-master/cpp/src/platform/winRT/MutexImpl.h inflating: open-zwave-master/cpp/src/platform/winRT/SerialControllerImpl.cpp inflating: open-zwave-master/cpp/src/platform/winRT/SerialControllerImpl.h inflating: open-zwave-master/cpp/src/platform/winRT/ThreadImpl.cpp inflating: open-zwave-master/cpp/src/platform/winRT/ThreadImpl.h inflating: open-zwave-master/cpp/src/platform/winRT/TimeStampImpl.cpp inflating: open-zwave-master/cpp/src/platform/winRT/TimeStampImpl.h inflating: open-zwave-master/cpp/src/platform/winRT/WaitImpl.cpp inflating: open-zwave-master/cpp/src/platform/winRT/WaitImpl.h creating: open-zwave-master/cpp/src/platform/windows/ inflating: open-zwave-master/cpp/src/platform/windows/EventImpl.cpp inflating: open-zwave-master/cpp/src/platform/windows/EventImpl.h inflating: open-zwave-master/cpp/src/platform/windows/FileOpsImpl.cpp inflating: open-zwave-master/cpp/src/platform/windows/FileOpsImpl.h inflating: open-zwave-master/cpp/src/platform/windows/LogImpl.cpp inflating: open-zwave-master/cpp/src/platform/windows/LogImpl.h inflating: open-zwave-master/cpp/src/platform/windows/MutexImpl.cpp inflating: open-zwave-master/cpp/src/platform/windows/MutexImpl.h inflating: open-zwave-master/cpp/src/platform/windows/SerialControllerImpl.cpp inflating: open-zwave-master/cpp/src/platform/windows/SerialControllerImpl.h inflating: open-zwave-master/cpp/src/platform/windows/ThreadImpl.cpp inflating: open-zwave-master/cpp/src/platform/windows/ThreadImpl.h inflating: open-zwave-master/cpp/src/platform/windows/TimeStampImpl.cpp inflating: open-zwave-master/cpp/src/platform/windows/TimeStampImpl.h inflating: open-zwave-master/cpp/src/platform/windows/WaitImpl.cpp inflating: open-zwave-master/cpp/src/platform/windows/WaitImpl.h creating: open-zwave-master/cpp/src/value_classes/ inflating: open-zwave-master/cpp/src/value_classes/Value.cpp inflating: open-zwave-master/cpp/src/value_classes/Value.h inflating: open-zwave-master/cpp/src/value_classes/ValueBool.cpp inflating: open-zwave-master/cpp/src/value_classes/ValueBool.h inflating: open-zwave-master/cpp/src/value_classes/ValueButton.cpp inflating: open-zwave-master/cpp/src/value_classes/ValueButton.h inflating: open-zwave-master/cpp/src/value_classes/ValueByte.cpp inflating: open-zwave-master/cpp/src/value_classes/ValueByte.h inflating: open-zwave-master/cpp/src/value_classes/ValueDecimal.cpp inflating: open-zwave-master/cpp/src/value_classes/ValueDecimal.h inflating: open-zwave-master/cpp/src/value_classes/ValueID.h inflating: open-zwave-master/cpp/src/value_classes/ValueInt.cpp inflating: open-zwave-master/cpp/src/value_classes/ValueInt.h inflating: open-zwave-master/cpp/src/value_classes/ValueList.cpp inflating: open-zwave-master/cpp/src/value_classes/ValueList.h inflating: open-zwave-master/cpp/src/value_classes/ValueRaw.cpp inflating: open-zwave-master/cpp/src/value_classes/ValueRaw.h inflating: open-zwave-master/cpp/src/value_classes/ValueSchedule.cpp inflating: open-zwave-master/cpp/src/value_classes/ValueSchedule.h inflating: open-zwave-master/cpp/src/value_classes/ValueShort.cpp inflating: open-zwave-master/cpp/src/value_classes/ValueShort.h inflating: open-zwave-master/cpp/src/value_classes/ValueStore.cpp inflating: open-zwave-master/cpp/src/value_classes/ValueStore.h inflating: open-zwave-master/cpp/src/value_classes/ValueString.cpp inflating: open-zwave-master/cpp/src/value_classes/ValueString.h creating: open-zwave-master/cpp/tinyxml/ inflating: open-zwave-master/cpp/tinyxml/Makefile inflating: open-zwave-master/cpp/tinyxml/tinystr.cpp inflating: open-zwave-master/cpp/tinyxml/tinystr.h inflating: open-zwave-master/cpp/tinyxml/tinyxml.cpp inflating: open-zwave-master/cpp/tinyxml/tinyxml.h inflating: open-zwave-master/cpp/tinyxml/tinyxmlerror.cpp inflating: open-zwave-master/cpp/tinyxml/tinyxmlparser.cpp creating: open-zwave-master/debian/ inflating: open-zwave-master/debian/MinOZW.1 inflating: open-zwave-master/debian/TODO inflating: open-zwave-master/debian/changelog extracting: open-zwave-master/debian/compat inflating: open-zwave-master/debian/control inflating: open-zwave-master/debian/copyright inflating: open-zwave-master/debian/libopenzwave-doc.doc-base inflating: open-zwave-master/debian/libopenzwave1.3-dev.install inflating: open-zwave-master/debian/libopenzwave1.3.install inflating: open-zwave-master/debian/libopenzwave1.3.lintian-overrides extracting: open-zwave-master/debian/openzwave.install extracting: open-zwave-master/debian/openzwave.manpages inflating: open-zwave-master/debian/rules creating: open-zwave-master/debian/source/ extracting: open-zwave-master/debian/source/format inflating: open-zwave-master/dist.mk inflating: open-zwave-master/distfiles.mk creating: open-zwave-master/docs/ inflating: open-zwave-master/docs/Doxyfile.in inflating: open-zwave-master/docs/default.htm creating: open-zwave-master/docs/general/ inflating: open-zwave-master/docs/general/DoxygenStepByStep.html inflating: open-zwave-master/docs/general/GettingHelp.html inflating: open-zwave-master/docs/general/Index.htm inflating: open-zwave-master/docs/general/MakingDocumentation.html inflating: open-zwave-master/docs/general/Notifications.html creating: open-zwave-master/docs/images+css/ inflating: open-zwave-master/docs/images+css/Doxywizard1.JPG inflating: open-zwave-master/docs/images+css/Doxywizard2.JPG inflating: open-zwave-master/docs/images+css/Doxywizard3.JPG inflating: open-zwave-master/docs/images+css/Doxywizard4.JPG inflating: open-zwave-master/docs/images+css/Doxywizard5.JPG inflating: open-zwave-master/docs/images+css/OpenZWave.css inflating: open-zwave-master/docs/images+css/image003.gif inflating: open-zwave-master/docs/images+css/zwalliance_250x100.jpg creating: open-zwave-master/dotnet/ creating: open-zwave-master/dotnet/build/ creating: open-zwave-master/dotnet/build/vs2008/ inflating: open-zwave-master/dotnet/build/vs2008/OpenZWaveDotNet.sln inflating: open-zwave-master/dotnet/build/vs2008/OpenZWaveDotNet.vcproj creating: open-zwave-master/dotnet/build/vs2010/ inflating: open-zwave-master/dotnet/build/vs2010/OpenZWaveDotNet.sln inflating: open-zwave-master/dotnet/build/vs2010/OpenZWaveDotNet.vcxproj inflating: open-zwave-master/dotnet/build/vs2010/OpenZWaveDotNet.vcxproj.filters creating: open-zwave-master/dotnet/examples/ creating: open-zwave-master/dotnet/examples/OZWForm/ inflating: open-zwave-master/dotnet/examples/OZWForm/CopyFilesVS2008.cmd inflating: open-zwave-master/dotnet/examples/OZWForm/CopyFilesVS2010.cmd inflating: open-zwave-master/dotnet/examples/OZWForm/README.TXT creating: open-zwave-master/dotnet/examples/OZWForm/build/ creating: open-zwave-master/dotnet/examples/OZWForm/build/vs2008/ inflating: open-zwave-master/dotnet/examples/OZWForm/build/vs2008/OZWForm.csproj inflating: open-zwave-master/dotnet/examples/OZWForm/build/vs2008/OZWForm.sln creating: open-zwave-master/dotnet/examples/OZWForm/build/vs2010/ inflating: open-zwave-master/dotnet/examples/OZWForm/build/vs2010/OZWForm.csproj inflating: open-zwave-master/dotnet/examples/OZWForm/build/vs2010/OZWForm.sln creating: open-zwave-master/dotnet/examples/OZWForm/src/ inflating: open-zwave-master/dotnet/examples/OZWForm/src/ConfigurationWakeUpDlg.Designer.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ConfigurationWakeUpDlg.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ConfigurationWakeUpDlg.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/ControllerCommandDlg.Designer.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ControllerCommandDlg.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ControllerCommandDlg.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/MainForm.Designer.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/MainForm.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/MainForm.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/Node.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/NodeForm.Designer.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/NodeForm.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/NodeForm.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/Program.cs creating: open-zwave-master/dotnet/examples/OZWForm/src/Properties/ inflating: open-zwave-master/dotnet/examples/OZWForm/src/Properties/AssemblyInfo.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/Properties/Resources.Designer.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/Properties/Resources.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/Properties/Settings.Designer.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/Properties/Settings.settings inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanel.Designer.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanel.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanel.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelBool.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelBool.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelButton.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelButton.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelByte.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelByte.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelDecimal.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelDecimal.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelInt.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelInt.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelList.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelList.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelShort.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelShort.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelString.cs inflating: open-zwave-master/dotnet/examples/OZWForm/src/ValuePanelString.resx inflating: open-zwave-master/dotnet/examples/OZWForm/src/app.config creating: open-zwave-master/dotnet/src/ inflating: open-zwave-master/dotnet/src/AssemblyInfo.cpp inflating: open-zwave-master/dotnet/src/ZWManager.cpp inflating: open-zwave-master/dotnet/src/ZWManager.h inflating: open-zwave-master/dotnet/src/ZWNotification.h inflating: open-zwave-master/dotnet/src/ZWOptions.cpp inflating: open-zwave-master/dotnet/src/ZWOptions.h inflating: open-zwave-master/dotnet/src/ZWValueID.h inflating: open-zwave-master/dotnet/src/app.ico inflating: open-zwave-master/dotnet/src/app.rc inflating: open-zwave-master/dotnet/src/resource.h creating: open-zwave-master/license/ inflating: open-zwave-master/license/Apache-License-2.0.txt inflating: open-zwave-master/license/gpl.txt inflating: open-zwave-master/license/lgpl.txt inflating: open-zwave-master/license/license.txt inflating: open-zwave-master/makedist inflating: open-zwave-master/openzwave.dsc inflating: open-zwave-master/openzwave.spec ! stderr: ---> cd open-zwave-master && make stdout: CPPFLAGS= make -C /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/build/ - make[1]: Entering directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/build' Building OpenZWave Version 1.4.-1 Building tinystr.o Building tinyxmlerror.o Building tinyxml.o Building tinyxmlparser.o Building hid.o Building aeskey.o Building aescrypt.o Building aestab.o Building aes_modes.o Building Security.o Building Proprietary.o Building Configuration.o Building ThermostatFanMode.o Building Language.o Building CommandClass.o Building ZWavePlusInfo.o Building Indicator.o Building MultiInstance.o Building MeterPulse.o Building SensorBinary.o Building SwitchBinary.o Building ClimateControlSchedule.o Building Clock.o Building SwitchAll.o Building SwitchToggleBinary.o Building ThermostatMode.o Building SensorMultilevel.o Building TimeParameters.o Building UserCode.o Building CentralScene.o Building ManufacturerSpecific.o Building ThermostatFanState.o Building Association.o Building DoorLock.o Building ApplicationStatus.o Building SwitchMultilevel.o Building NodeNaming.o Building DoorLockLogging.o Building SensorAlarm.o Building ThermostatOperatingState.o Building WakeUp.o Building BasicWindowCovering.o Building Lock.o Building MultiInstanceAssociation.o Building Color.o Building Hail.o Building MultiCmd.o Building SceneActivation.o Building Powerlevel.o Building Meter.o Building AssociationCommandConfiguration.o Building Battery.o Building CRC16Encap.o Building Version.o Building Alarm.o Building CommandClasses.o Building ThermostatSetpoint.o Building NoOperation.o Building EnergyProduction.o Building Basic.o Building DeviceResetLocally.o Building ControllerReplication.o Building Protection.o Building SwitchToggleMultilevel.o Building Value.o Building ValueList.o Building ValueButton.o Building ValueInt.o Building ValueStore.o Building ValueDecimal.o Building ValueRaw.o Building ValueString.o Building ValueByte.o Building ValueBool.o Building ValueSchedule.o Building ValueShort.o Building Controller.o Building Wait.o Building Thread.o Building Stream.o Building Log.o Building HidController.o Building Mutex.o Building SerialController.o Building Event.o Building FileOps.o Building TimeStamp.o Building FileOpsImpl.o Building TimeStampImpl.o Building WaitImpl.o Building ThreadImpl.o Building LogImpl.o Building MutexImpl.o Building SerialControllerImpl.o Building EventImpl.o Building Options.o Building Scene.o Building Utils.o Building Driver.o Building ZWSecurity.o Building Group.o Building Node.o Building Manager.o Building Msg.o Building Notification.o Creating vers.cpp Building vers.o Linking Static Library Linking Shared Library Making ozw_config file make[1]: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/build' CPPFLAGS= make -C /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/examples/MinOZW/ - make[1]: Entering directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/examples/MinOZW' Building Main.o Linking /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/.lib/MinOZW g++ -o /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/.lib/MinOZW /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/.lib/Main.o /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/libopenzwave.so -pthread Creating Temporary Shell Launch Script make[1]: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/examples/MinOZW' ! stderr: ---> cd open-zwave-master && sudo make install stdout: make -C /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/build/ - install make[1]: Entering directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/build' Making libopenzwave pkg-config file Installing Shared Library Installing Headers Installing Config Database Installing Documentation Installing Pkg-config Files make[1]: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/build' make -C /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/examples/MinOZW/ - install make[1]: Entering directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/examples/MinOZW' Installing into Prefix: /usr/local make[1]: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/examples/MinOZW' ! stderr: Makefile:197: Documentation not being built ! > openzwave-shared@1.2.0 preinstall /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared node lib/install-ozw.js ! > openzwave-shared@1.2.0 install /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared node-gyp rebuild ! /bin/sh: 1: pkg-config: not found gyp: Call to 'PKG_CONFIG_PATH= pkg-config --variable=libdir libopenzwave' returned exit status 127 while in binding.gyp. while trying to load binding.gyp gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1 gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:305:16) gyp ERR! stack at emitTwo (events.js:87:13) gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12) gyp ERR! System Linux 4.4.0-45-generic gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared gyp ERR! node -v v4.6.1 gyp ERR! node-gyp -v v3.4.0 gyp ERR! not ok ! > serialport@4.0.5 install /opt/iobroker/node_modules/iobroker.zwave/node_modules/serialport node-pre-gyp install --fallback-to-build ! [serialport] Success: "/opt/iobroker/node_modules/iobroker.zwave/node_modules/serialport/build/Release/serialport.node" is installed via remote npm ERR! Linux 4.4.0-45-generic npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.zwave/tarball/master" "--production" "--prefix" "/opt/iobroker" npm ERR! node v4.6.1 npm ERR! npm v2.15.9 npm ERR! code ELIFECYCLE ! npm ERR! openzwave-shared@1.2.0 install: `node-gyp rebuild` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the openzwave-shared@1.2.0 install script 'node-gyp rebuild'. npm ERR! This is most likely a problem with the openzwave-shared package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node-gyp rebuild npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs openzwave-shared npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm ERR! npm owner ls openzwave-shared npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request: npm ERR! /opt/iobroker/npm-debug.log host.HomeControl Cannot install https://github.com/ioBroker/ioBroker.zwave/tarball/master: 1 !
                                      • Lenny.CB
                                        Lenny.CB Most Active last edited by
                                        @Dutchman:
                                        Mach mal bitte den adapter auf debug `
                                        host.iobroker	2016-11-06 21:23:57.631	info	Restart adapter system.adapter.zwave.0 because enabled
                                        host.iobroker	2016-11-06 21:23:57.630	error	instance system.adapter.zwave.0 terminated with code 1 ()
                                        host.iobroker	2016-11-06 21:23:56.512	info	instance system.adapter.zwave.0 started with pid 7662
                                        host.iobroker	2016-11-06 21:23:52.300	info	Restart adapter system.adapter.zwave.0 because enabled
                                        host.iobroker	2016-11-06 21:23:52.299	error	instance system.adapter.zwave.0 terminated with code 1 ()
                                        host.iobroker	2016-11-06 21:23:51.339	info	instance system.adapter.zwave.0 started with pid 7656
                                        host.iobroker	2016-11-06 21:23:44.326	info	Restart adapter system.adapter.zwave.0 because enabled
                                        host.iobroker	2016-11-06 21:23:44.325	error	instance system.adapter.zwave.0 terminated with code 1 ()
                                        host.iobroker	2016-11-06 21:23:43.189	info	instance system.adapter.zwave.0 started with pid 7649
                                        mehr ist auch bei debug nicht.
                                        • Bluefox
                                          Bluefox last edited by
                                          @Dutchman:
                                          @Lenny.CB:
                                          host.iobroker	2016-11-06 20:45:48.606	info	Restart adapter system.adapter.zwave.0 because enabled
                                          host.iobroker	2016-11-06 20:45:48.603	error	instance system.adapter.zwave.0 terminated with code 1 ()
                                          host.iobroker	2016-11-06 20:45:47.732	info	instance system.adapter.zwave.0 started with pid 6259
                                          host.iobroker	2016-11-06 20:45:47.696	info	object change system.adapter.zwave.0
                                          unter zwave.0 ist nichts da… `
                                          Leider geht bei mir die installation von git bereits schief damit kan ich nicht mitschaun 😕 `
                                          Hast du das hier ausgeführt?
                                          ` > On some systems the additional package is required:
                                          apt-get install pkg-config
                                          npm install iobroker.zwave does following Steps for you:
                                          Download and install latest openzwave from github
                                          # cd /opt
                                          # curl -L -O https://github.com/OpenZWave/open-zwave … master.zip
                                          # unzip master.zip
                                          # cd open-zwave-master
                                          # make
                                          # sudo make install `
                                          https://github.com/ioBroker/ioBroker.zwave#installation
                                          • Lenny.CB
                                            das hatte ich noch von einer frühreren Version drauf.
                                            Ich lösche das nochmal und mache mal neu.
                                            31.7k
                                            79.8k
                                            142
                                            21341
