    4. Material Design Widgets: UniFi Netzwerk Status
    • tobasium
      tobasium @cdellasanta last edited by
      @cdellasanta ich bekomme leider einen Fehler wen ich dein script nutze:
      javascript.0	2021-01-01 19:00:30.452	error	(1936) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      javascript.0	2021-01-01 19:00:30.452	error	(1936) at runMicrotasks (<anonymous>)
      javascript.0	2021-01-01 19:00:30.452	error	(1936) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
      javascript.0	2021-01-01 19:00:30.451	error	(1936) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.0	2021-01-01 19:00:30.450	error	(1936) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
      javascript.0	2021-01-01 19:00:30.450	error	(1936) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1219:17
      javascript.0	2021-01-01 19:00:30.449	error	(1936) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1681:17
      javascript.0	2021-01-01 19:00:30.449	error	(1936) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1587:37)
      javascript.0	2021-01-01 19:00:30.448	error	(1936) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1364:28)
      javascript.0	2021-01-01 19:00:30.447	error	(1936) at Object.createScript (vm.js:261:10)
      javascript.0	2021-01-01 19:00:30.446	error	(1936) at new Script (vm.js:88:7)
      javascript.0	2021-01-01 19:00:30.444	error	(1936) SyntaxError: Unexpected token ':'
      javascript.0	2021-01-01 19:00:30.444	error	(1936) ^
      javascript.0	2021-01-01 19:00:30.443	error	(1936) function setup(): void {
      javascript.0	2021-01-01 19:00:30.442	error	at script.js.Smarthome_Tobi.System.Unifi-Status:119
      javascript.0	2021-01-01 19:00:30.442	error	(1936) script.js.Smarthome_Tobi.System.Unifi-Status compile failed:
      Siehst du woran es liegt? Vielen Dank Vorab.
      cdellasanta 1 Reply Last reply Reply Quote 0
      • cdellasanta
        cdellasanta Developer @tobasium last edited by
        @Nashra said in Material Design Widgets: UniFi Netzwerk Status:
        Erstmal ein frohes und gesundes neues Jahr @cdellasanta
        Danke gleichfalls 😉
        @tobasium said in Material Design Widgets: UniFi Netzwerk Status:
        Ich glaube ich sehe wo den Problem ist: script.js
        .. du musst es als TypeScript (neu)erstellen:
        tobasium 1 Reply Last reply Reply Quote 0
        • tobasium
          @cdellasanta Danke schonmal leider immer noch errors im log:
          javascript.0	2021-01-01 23:09:15.310	error	(1936) at Script.runInContext (vm.js:130:18)
          javascript.0	2021-01-01 23:09:15.310	error	(1936) at script.js.Smarthome_Tobi.System.Unifi-Netzwerk:107:1
          javascript.0	2021-01-01 23:09:15.310	error	(1936) at initializeState (script.js.Smarthome_Tobi.System.Unifi-Netzwerk:549:9)
          javascript.0	2021-01-01 23:09:15.309	error	(1936) at registerListener (script.js.Smarthome_Tobi.System.Unifi-Netzwerk:516:13)
          javascript.0	2021-01-01 23:09:15.309	error	(1936) at runAfterInitialization (script.js.Smarthome_Tobi.System.Unifi-Netzwerk:510:10)
          javascript.0	2021-01-01 23:09:15.308	error	(1936) TypeError: Cannot read property 'setTimeout' of undefined
          javascript.0	2021-01-01 23:09:15.308	error	(1936) ^
          javascript.0	2021-01-01 23:09:15.307	error	(1936) this.setTimeout(function () { return runAfterInitialization(callback); }, 100);
          javascript.0	2021-01-01 23:09:15.307	error	(1936) script.js.Smarthome_Tobi.System.Unifi-Netzwerk: script.js.Smarthome_Tobi.System.Unifi-Netzwerk:510
          • cdellasanta
            cdellasanta Developer @tobasium last edited by cdellasanta
            this.setTimeout(function ....
            Hmmm .. ändere alle this.setTimeout(..) einfach zu setTimeout(...) ...
            Ich habe den this prefixed (und es funktioniert bei mir) weil beim lesen der Beschreibung der Befehl fand ich es besser, und es gab damit keinen "Inspection Fehler" ..
            Edit: .. ich sehe jetzt dass es auch ohne this kein "Code Fehler" mehr gezeigt wird .. ich ändere den Code im oberen Abschnitt (und im PR).
            • tobasium
              @cdellasanta
              Also das sieht schon deutlich besser aus. Danke.
              Nächste Fehler tauchen jetzt auf sobald ich Sortierung ändere:
              javascript.0	2021-01-02 15:59:30.915	error	(1936) at processImmediate (internal/timers.js:461:21)
              javascript.0	2021-01-02 15:59:30.915	error	(1936) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
              javascript.0	2021-01-02 15:59:30.914	error	(1936) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:472:25)
              javascript.0	2021-01-02 15:59:30.914	error	(1936) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1070:38)
              javascript.0	2021-01-02 15:59:30.914	error	(1936) at Object.<anonymous> (script.js.Smarthome_Tobi.System.Unifi-Netzwerk:107:163)
              javascript.0	2021-01-02 15:59:30.913	error	(1936) at resetSortTimer (script.js.Smarthome_Tobi.System.Unifi-Netzwerk:313:14)
              javascript.0	2021-01-02 15:59:30.912	error	(1936) Error in callback: TypeError: Cannot read property 'clearTimeout' of undefined
              Aber zumindestens läuft es jetzt schonmal.
              Danke für deine ganze Arbeit.
              • cdellasanta
                clearTimeout
                😧 hätte ich sehen müssen ... ändere zusätzlich alle this.clearTimeout(...) zu clearTimeout(...) ...
                tobasium 1 Reply Last reply Reply Quote 1
                • tobasium
                  tobasium @cdellasanta last edited by tobasium
                  @cdellasanta said in Material Design Widgets: UniFi Netzwerk Status:
                  clearTimeout(...)
                  Perfekt. jetzt läuft es ohne error.
                  Was mich nur wundert warum gibt es die Fehler bei mir und bei dir gab es die nicht?
                  • cdellasanta
                    Es hat sicher zu tun mit unterschiedliche Versionen, ich habe bei mir aktuell:
                    • Admin-controller: 4.1.12
                    • JS-Controller version: 4.10.8
                    • Node version: v12.18.4
                    • Operating system: linux (Raspbian)
                    Du hast vermutlich andere Versionen, ich vermute die Node Version ist da verantwortlich .. aber eben .. ist jetzt kein Problem mehr 😉
                    • tobasium
                      @cdellasanta
                      Hier mal meine Infos:
                      Node.js: v12.20.0
                      NPM: 6.14.8
                      Operating system: buanet docker image synology
                      lobomau 1 Reply Last reply Reply Quote 0
                      • lobomau
                        lobomau @tobasium last edited by
                        @tobasium @cdellasanta ihr redet wahrscheinlich von der Admin Version und nicht js-controller,oder?
                        Ich habe js-controller 3.1.6 und bin da eigentlich aktuell,dachte ich.
                        • tobasium
                          tobasium @lobomau last edited by tobasium
                          @lobomau Wir reden schon vom Script Engine -> https://github.com/iobroker/ioBroker.javascript/blob/master/README.md
                          • lobomau
                            @tobasium ihr redet vom Javascript Adapter und nicht vom js-controller.
                            Der Vergleich des js-controller ist auch ganz hilfreich, findet man unter Hosts:
                            • tobasium
                              @lobomau oh ok 3.1.6 also ebenfalls aktuell unterwegs
                              • lobomau
                                @tobasium und ihr habt mit dem Javascript Adapter 4.10.x eine Beta Version. Das kann zu Problemen führen.
                                Bei mir läuft 4.8.x stable Version.
                                • efxz
                                  efxz @Nashra last edited by
                                  @Nashra
                                  Ich versuche schon den ganzen Tag meinen Geräten Bilder zuzuordnen, leider erfolglos. Wie und wo im script kommen die Zuweisungen "image":"bildname.png", link"ip?" hin?
                                  tobasium Nashra 2 Replies Last reply Reply Quote 0
                                  • tobasium
                                    tobasium @efxz last edited by
                                    @efxz das musst du im unifi controller eintragen:
                                    1.Du logst dich im unfi controler ein.
                                    2. Klickst auf Endgeräte.
                                    3. Wählst hier das Gerät für welches du ein Bild im IoBroker hinterlegt hast.
                                    4. Nach dem öffnen des Ger#tes hier auf das Zahnrad (Konfiguration.
                                    5. Unter Anmerkung die Info hinterlge:
                                    Format wie folgt:
                                        "image": "CCU2",
                                        "icon": "",
                                        "link": "http"
                                    efxz 1 Reply Last reply Reply Quote 0
                                    • Nashra
                                      Nashra Most Active Forum Testing @efxz last edited by Nashra
                                      @efxz sagte in Material Design Widgets: UniFi Netzwerk Status:
                                      @Nashra
                                      Hey, @tobasium hat es ja oben schon beschrieben. Wenn Du alles so machst werden die einzelnen Bilder angezeigt.
                                      • efxz
                                        efxz @tobasium last edited by
                                        @tobasium
                                        Vielen Dank
                                          joesilver8 @cdellasanta last edited by joesilver8
                                          @cdellasanta
                                          Vielen Dank für deine super Arbeit. Habe deine Skripts bei mir eingebaut und bekomme auch fast alles hin. Aber eben nur fast, vielleicht hast du ja noch eine Idee. Zunächst funktioenieren die Links in der NetworkView irgendwie nicht. Es wird zwar beim Mouseover als Link angezeigt, aber beim anklicken passiert nichts. Die Links ansich müssten aber passen, da diese in der Deviceview die richtige Seite aufrufen.
                                          Hier ist allerdings das nächste Problem: Die Seiten funktionieren zum Teil nicht richtig. So fehlt zum Beispiel bei Seiten an denen man sich anmelden muss das Login-Fenster, oder bei der Statusseite des Samsung-Druckers, der Inhalt des Hauptframes.
                                          Hast du da vielleicht ne Idee, wo der Haken sein könnte?. Bin da leider ziemlich ratlos.
                                          joesilver
                                          • cdellasanta
                                            cdellasanta Developer @joesilver8 last edited by
                                            @joesilver8
                                            🤠 jep, war auch anfangs für mich nicht einfach ... habs im Code versucht zu Beschrieben, aber ist vermutlich nicht genügend klar ..
                                            // Optional: display links into a separate view, instead of new navigation window (set false to disable this feature)
                                            const devicesView = {currentViewState: '0_userdata.0.vis.currentView', devicesViewKey: JSON.parse(getState('0_userdata.0.vis.widgetViews').val).indexOf('8_Devices')};
                                            Ich nehme an du benutzest auch die Haupsicht aus materialdesign, mit einen tplVis-materialdesign-TopAppBar-Navigation Widget und einen View8 container Widget (tplStatefulContainerView8).
                                            Um den "switch" von einen View auf einen andere, musst du einen Status einbinden:
                                            • TopAppBar-Navigation Widget: 524cb7f4-c1e9-42fd-a5de-926d73555e16-image.png
                                            • View8 Widget: 1a4d0412-8aca-49c6-a5d9-caeea28fb9b6-image.png
                                            wenn du das macht, dann im Code gibt es dieses abschnitt der bei jede aktualisierung der selectedUrl Status, ändert den 0_userdata.0.vis.currentView und somit geht in der "devices" View:
                                            if (devicesView) {
                                                initializeState(`${statePrefix}.linksJsonList`, '[]', {name: 'Device links listing: linksJsonList', type: 'string'});
                                                initializeState(`${statePrefix}.selectedUrl`, '', {name: 'Selected device link: selectedUrl', type: 'string'}, 'any', obj => {
                                                    // On selected device change, go to "Devices" view
                                                    log(`Switching to devices View that should now display URL: ${obj.state.val}`, 'debug');
                                                    setState(devicesView.currentViewState, devicesView.devicesViewKey);
                                            Übrigens die Device View habe ich für mich angepasst, und jetzt sieht so bei mir aus:
                                            Selber bin ich einen Schritt weiter gegangen, da die ganze "Menu zu Sicht" einbindung nicht meinen Geschmack trifft, ich habe es in einen Skript Konfigurierbar gemacht, anstatt jedes mal beide Widgets anpassen müssen:
                                            const views = [
                                                // Order is important; icon is full path to image or a materialdesign icon
                                                {view: '1_Shutters',      label: 'Roller shutters', icon: 'window-shutter'},
                                                {view: '3_0_Weather',     label: 'Weather',         icon: 'weather-partly-cloudy'}, // or weather-sunny? Could icon change depending on current weather?
                                                {view: '4_Radar',         label: 'Radar',           icon: 'radar'},
                                                {view: '5_Sun',           label: 'Sun position',    icon: 'weather-sunny'},
                                                {view: '8_Devices',       label: 'Devices',         icon: 'devices'},
                                                {view: '9_UnifiNetwork',  label: 'Network',         icon: 'server-network'},
                                                {view: '0_Sandbox',       label: 'Playground',      icon: 'test-tube'},
                                                {view: '3_Weather',       label: 'Weather (old)',   icon: 'test-tube'},
                                            Das Ganze kannst hier anschauen/kopieren, dort kannst auch meine letzten Entwicklungen finden,
                                            • Sonnenstand (dank sonnenverlauf.de) cce579d6-5303-48c0-b2da-170a17df7944-image.png
                                            Ich wollte dedizierte Themen hirer im Forum aufmachen darüber .. aber leider immer zu wenig Zeit ..
                                            Ich sollte eigentlich mein shelly.cloud ablösen für die Rolladensteuerung, aber hatte noch nicht Zeit 🙄
                                            Du hattest aber noch eine Frage:
                                            Das ist vermutlich ein Problem mit den Inhalt der in einen iframe geladen ist, diese folgen gewisse Sicherheitsregeln.
                                            Solltest den Fehler anschauen der im Entwicklermodus angezeigt wird.. vermutlich ist einen "HTTPS zu HTTP" oder einen "Cookie" Problem. Da kann ich wenig helfen (es kann unter umstände auch sehr kompliziert werden).
                                            N J 2 Replies Last reply Reply Quote 0
                                            iconlist material design widgets statusanzeige unifi vis
                                            31
                                            109
                                            17954
