    5. [gelöst] Steckdose abschalten wenn keine Verbraucher an ist
    • kmxak
      Hier mal mein Blockly export.
       <variables>
         <variable id="l/t3I)WoH^OA[[RzT,Zk">stromverbrauch</variable>
         <variable id="OBTuwCF{~9]jQKUB%jMw">autoaus</variable>
         <variable id="_$yc8j}3;@cF@?Kv}Av0">einschaltdelay</variable>
         <variable id="CFa^/g$%jfEW6h7r#kux">powerlist</variable>
         <variable id="z%|k!S:.W:jdEhGRUBL,">zaehler</variable>
         <variable type="interval" id="Intervall">Intervall</variable>
         <variable id="Z;wS@*12Sx?^}auD?ts%">avg_value</variable>
         <variable id="Uk):4hQu(lb/RQd3kHn/">benachrichtigungblock</variable>
       </variables>
       <block type="on" id="fwKmbeifl~+Sta{(h9Mk" x="-687" y="-1037">
         <field name="OID">sonoff.0.Gosund_16A_2.POWER</field>
           <block type="controls_if" id="H+GLbdH01hwuSelsSY7r">
               <block type="logic_compare" id=",00d5khAOJW4D|_Qsd8X">
                 <field name="OP">EQ</field>
                   <block type="on_source" id="b.6}j{Q{=ygu#c5aJHBy">
                   <block type="logic_boolean" id="j.wm.WV[GwVx07V*)X$)">
               <block type="comment" id="+nB}byM7I!_Fac}b3[]X">
                 <field name="COMMENT">--</field>
                   <block type="variables_set" id="@9x:1DCyj/$0?f!6dtlO">
                     <field name="VAR" id="l/t3I)WoH^OA[[RzT,Zk">stromverbrauch</field>
                       <block type="get_value" id="hLd,qrb{)Cx@?T:SUSc8">
                         <field name="OID">sonoff.0.Gosund_16A_2.ENERGY_Total</field>
                       <block type="debug" id="+]AbpiYNZ/IbTuv0snwl">
                         <value name="TEXT">
                           <shadow type="text" id="0AMBTeqKOT!q((LbylWt">
                           <block type="text" id="|.=T4X7`XMOw/;@WtI`V">
                             <field name="TEXT">Strom wurde Eingeschaltet</field>
                           <block type="comment" id="+KmEq~P1kcxjsCOGNmKS">
                             <field name="COMMENT">Einschaltdelay da meine Verbraucher erst nach Zeit x mehr Strom verbrauchen</field>
                               <block type="variables_set" id="jNvYFooZgTEtjoTbV5},">
                                 <field name="VAR" id="_$yc8j}3;@cF@?Kv}Av0">einschaltdelay</field>
                                   <block type="math_number" id="W4wMH[K2Z]0a7,241s%M">
                                     <field name="NUM">1</field>
                                   <block type="variables_set" id="0aa?[W^Eiz/+s!b_cjv:">
                                     <field name="VAR" id="CFa^/g$%jfEW6h7r#kux">powerlist</field>
                                       <block type="lists_create_with" id="l{)ggJUIC^MB5~HnpkK">
                                         <value name="ADD0">
                                           <block type="lists_repeat" id="qTquchIQ2hsLO@+nwdb">
                                             <value name="NUM">
                                               <shadow type="math_number" id="OOxCj9]M~w6x,4GjIY1w">
                                                 <field name="NUM">5</field>
                                             <value name="ITEM">
                                               <block type="math_number" id="}J@R=hD{b4@:1|m;fr@1">
                                                 <field name="NUM">0</field>
                                       <block type="variables_set" id="_wJwOrDH[-@z)7#f.]~d">
                                         <field name="VAR" id="z%|k!S:.W:jdEhGRUBL,">zaehler</field>
                                           <block type="math_number" id="^1qClPKO)byi*^}yrl">
                                           <block type="timeouts_setinterval" id="R8G,T3uOIZ5^nKaY{6Z}">
                                             <field name="NAME">Intervall</field>
                                             <field name="INTERVAL">2</field>
                                               <block type="math_change" id="R2$5CM}}=x)ZZzq?tn0;">
                                                 <value name="DELTA">
                                                   <shadow type="math_number" id="$}oF{hMlPytxX5!htGz~">
                                                   <block type="math_number" id="|P`W95)vb5!Im:V:)s4q">
                                                   <block type="lists_setIndex" id="i[9ekb#FxDO[Q,XJUf%z">
                                                     <mutation at="true"></mutation>
                                                     <field name="MODE">SET</field>
                                                     <value name="LIST">
                                                       <block type="variables_get" id="r]E9:0GGU,7t#Tqmsr0A">
                                                     <value name="AT">
                                                       <block type="variables_get" id="OEy#cK{(ocW-W/P=0REj">
                                                     <value name="TO">
                                                       <block type="get_value" id="1}qZEO:SOFgy~d;!g;/K">
                                                         <field name="OID">sonoff.0.Gosund_16A_2.ENERGY_Power</field>
                                                       <block type="controls_if" id="x(3]2/PR=(yMJ}uG?Uh,">
                                                           <block type="logic_compare" id="HsSrLZlMD0fDvd}LBHRP">
                                                               <block type="variables_get" id="YPHVohUdGN/YmEVD{v">
                                                               <block type="math_number" id="OG6z9tzsrW|MVnF@N590">
                                                           <block type="variables_set" id="}26op)#ACFS@6GCrqdsM">
                                                               <block type="math_number" id=":U2HH_Tw43Z9dw[B(E0Z">
                                                           <block type="math_change" id=")DYK%F553DwziokE]-p*">
                                                               <shadow type="math_number" id="B8xv]2@}Pt8_lYV;Y6D">
                                                               <block type="variables_set" id="7j-hdnljTg~+n;hMm#j">
        <field name="VAR" id="Z;wS@*12Sx?^}auD?ts%">avg_value</field>
        <block type="math_on_list" id="b)d0^t{W1V#)z47Z1h(">
        <mutation op="AVERAGE"></mutation>
        <field name="OP">AVERAGE</field>
        <value name="LIST">
        <block type="variables_get" id="r-/qP?MC)4!OxRnYex/F">
        <block type="comment" id="3T=QeZ{8t7Pm;%oGD%yf">
        <field name="COMMENT">Einschaltdelay 4  = 8 Min</field>
        <block type="comment" id="RP^2i0QK0JMk}|gkBT5F">
        <field name="COMMENT">avg_value -&gt; bei unterschreitung Strom aus.</field>
        <block type="comment" id="03,%{=VG-SzzrB=a-S1Z">
        <field name="COMMENT">Wird aus den letzten 5 Werten berechnet.</field>
        <block type="controls_if" id="xBQ6a7WY}7jH~,VrbA5L">
        <block type="logic_operation" id="PWd:bWs@l|P`;Coy(wlv">
        <field name="OP">AND</field>
        <block type="logic_compare" id="G(%Xbg3S95.u*[rIEWL">
        <field name="OP">LTE</field>
        <block type="variables_get" id="#V]okvvd)vkX8N.s``P5">
        <block type="math_number" id=":N/u3Fuq]M^8B-F-vS">
        <field name="NUM">2</field>
        <block type="logic_compare" id="?t?Di.W3M]v#Dn{|gOb]">
        <field name="OP">GT</field>
        <block type="variables_get" id=")M9#nS5#P(pkx6*vu`A=">
        <block type="math_number" id="GC+):3mdb6PRyTG{7mgo">
        <field name="NUM">4</field>
        <block type="debug" id="B[SZKw1;y#gJ1OU;Tr;D">
        <value name="TEXT">
        <shadow type="text" id="U-wE%J;#NF)0X0=%+V?G">
        <block type="text" id="%#~W=JO5=%3Y@z~V,YQO">
        <field name="TEXT">Ruhestrom erkannt</field>
        <block type="control" id="anaQ0d?KPFj:sP,X1-K?">
        <field name="DELAY_MS">1</field>
        <block type="logic_boolean" id="2JCBeLdK8N]Ix}yV~*94">
        <block type="variables_set" id="fuqp%?y}c2tl.?zKA/?y">
        <field name="VAR" id="OBTuwCF{~9]jQKUB%jMw">autoaus</field>
        <block type="math_number" id="r6lLD6}msp5YE*piv=8d">
        <block type="variables_set" id="0vvwm;vyJ80jo9SAyL.?">
        <field name="VAR" id="Uk):4hQu(lb/RQd3kHn/">benachrichtigungblock</field>
        <block type="math_number" id="4,aSJIO@Gcwmr+Iu%+ga">
             <statement name="ELSE">
               <block type="controls_if" id="f7vnDPeD;{[$7]$ewa1.">
                   <block type="logic_compare" id="MExqe1V-nep`h,q~_1d|">
                       <block type="variables_get" id="UH[RHO~!Oo75_2Igg;?X">
                       <block type="math_number" id="Y%B!!2Uraf73%I;J)),B">
                   <block type="debug" id="L4bI7J*r.8b42*cArWUS">
                     <value name="TEXT">
                       <shadow type="text">
                       <block type="text" id="rlKQvkkK/Ty-RF;8|/vM">
                         <field name="TEXT">Strom wurde automatisch vom Script ausgeschaltet</field>
                       <block type="timeouts_clearinterval" id="p=l9/+/FOmceOb~o9A9$">
                           <block type="variables_set" id=")KfD@56l!FgHrd8B+]#~">
                               <block type="math_number" id="GuoEPQIi?X]qJyJ;L63L">
                               <block type="variables_set" id="o=-(myrQAgFcL=;tq_H{">
                                   <block type="math_number" id="!4wi9X[d:yB*i#*Zm~98">
                   <block type="debug" id=":[vy,.7Rjc{2LPBtU-]X">
                     <value name="TEXT">
                       <block type="text" id="[iG,EPME{uZ@|00V~jk4">
                         <field name="TEXT">Strom manuell ausgeschaltet</field>
                       <block type="timeouts_clearinterval" id="q**7MU6#|`H;5$v}q.b7">
                           <block type="variables_set" id="^zb1,F[bdIn*vD;5,wQc">
                               <block type="math_number" id="o*9w2u{+?HZE(6hM!Vjy">
      Falls Steckdose an wird alle 2 min gemessen wiviel Watt es zieht der durchschnitt der letzten 5 Messungen wird als Trigger genommen. Wird der Wert unterschritten geht es weiter. Ich unterscheide auch ob das Script oder der User ausschaltet. Ist für meine Waschmaschiene gedacht. Für den Export habe ich alle Telegram und Alexa sachen rausgelöscht.
      Das Script selber ist von mir nur umgeändert und der ersteller hatte es mal irgendwo hier im Forum zur verfügung gestellt mit der berechnung des verbrauches.
      • Dr. Bakterius
        Dr. Bakterius Most Active @paul53 last edited by Dr. Bakterius
        @paul53 Die 'SONST FALLS'-Abfrage kann man sich sparen. Außerdem ist da wieder 'größer als' statt 'kleiner als' eingesetzt. 😀
        Und ich würde direkt vor dem 'timeout' noch einen 'stop' einbauen. Sonst startet jede Wertänderung unter 8,1 Watt einen neuen Timer.
          e-s @Dr. Bakterius last edited by
          @Dr-Bakterius
          Eben nicht, musste mir das auch länger durch den Kopf gehen lassen. Aber die version von @paul53 ist schon super durchdacht.
          Erst fragt er ab ob mehr als 8 Watt, wenn ja dann stop timeout, da weiter aktiv.
          Aber nur wenn weniger als 8 Watt ist, dann wird das sonst falls abgefragt. Dabei die Frage ob es beim letzten mal mehr als 8 watt waren. Nur wenn das so ist, dann wird der timeout gestartet.
          Wenn dies nicht so wäre, dann würde der timeout mehrmals gestartet werden wenn sich der Verbrauch unterhalb von 8 w ändert.
          • Dr. Bakterius
            Dr. Bakterius Most Active @e-s last edited by
            @e-s Stimmt, das mit 'vorheriger Wert' ist mir nicht aufgefallen. Trotzdem kann man auf die zweite Abfrage verzichten und dann eben oben auch ein Stop einbauen. Funktioniert auch. Viele Wege führen ans Ziel... 😳
            paul53 E 2 Replies Last reply Reply Quote 0
              paul53 @Dr. Bakterius last edited by
              @Dr-Bakterius sagte:
              Das setzt voraus, dass die Leistung lange genug konstant bleibt, da sonst der Timer nie abläuft.
                @Dr-Bakterius
                Das sonst falls ist ja gerade das geniale daran, weil wenig Abfragen und keine dauerloops.
                  spaceball303 @paul53 last edited by
                  @paul53 Vielen Dank, so gehts!
                  Sebastian Kühn 1 Reply Last reply Reply Quote 0
                  • Sebastian Kühn
                    Sebastian Kühn @spaceball303 last edited by
                    Eure Idee finde ich richtig klasse. Ich bin neu und würde mir gern genau für diesen Zweck gern eine SP112 zulegen...
                    Kurz mal vornweg... wenn die Steckdose dann automatisch im Standby abschaltet, wie lässt sich dann die Waschmaschine wieder anschalten? Muss man die Steckdose dann irgendwie wieder frei geben?@spaceball303
                      klassisch Most Active @Sebastian Kühn last edited by
                      @Sebastian-Kühn sagte in [gelöst] Steckdose abschalten wenn keine Verbraucher an ist:
                      Schau mal, ob Du mit einer Shelly nicht besser fährst. Die geht out of the box ohne Modifikation mit dem ioBroker Shelly-Adapter. Hat CE und kostet auch nur um 20 EUR, z.B. Voelkner A182832 die große für 16A, die würde ich für Waschmaschine, Trockner etc nehmen. Verwende ich für die Mikrowelle und überall wo Platz ist. Die Kleine Shelly habe ich am Automower, Voelkner A182882. Voelkner Preise schwanken leider,
                      Waschmaschine, Mikrowelle, Pedelec habe ich noch aus alten Zeiten mit Homematc realisiert. Shelly ist aber günstiger.
                      Und es gibt genau für diesen Zweck der Geräteabschaltung mittlerweile eine Adapterentwicklung, dann mußt Du nichts programmieren, siehe dort https://forum.iobroker.net/topic/37915/test-adapter-device-reminder-v0-x?page=1 . Und wenn die Maschine dann fertig ist, bekommt man noch eine Nachricht per Messanger oder email.
                      Bei den tasmotisierten Chinadosen hast Du einiges zu tun und am Ende keine Zulassung und die volle Verantwortung. Das muß man sich nicht mehr antun und rechtfertigt den bezahlbaren Mehrpreis für die Shelly.
                      Sowohl meine Homematic-Dosen als auch die große Shelly haben einen Knopf zum Einschalten. Beim Beladen von Waschmaschine/Trockner muß man also dann zusätzlich diesen Taster drücken, damit die Maschine wieder Strom bekommt.
                      Deshalb mag ich auch die wirklich günstigen (10 EUR) Ikea Tradfri Steckdosen nicht, Die haben diesen Schalter weggegeizt - und damit die Nutzbarkeit deutlich eingeschränkt. Klar könnte man die Dose über den Rechner, ioBroker oder einen Remote Taster etc. einschalten, aber der Taster am Gerät ist die beste Lösung. Billig schnell, intuitiv.
                      • amg_666
                        amg_666 @klassisch last edited by
                        @klassisch ICh hab an meiner Waschmaschine auch ne Homematic Dose und ein Skript in Homematic, welches die Steckdose nach dem Waschen ausschaltet. Das ist aber von der Logik ganz simpel gelöst, einfach Prüfen ob Strom=0 ist und dann 15 Min später ausschalten. Mir ist klar dass das Fehlerbehaftet sein kann aber die Steuerung läuft so schon seit Jahren ohne Probleme (sprich ohne ein laufendes Waschprogramm zu beenden).
                          klassisch Most Active @amg_666 last edited by
                          @amg_666 so ähnlich laufen bei mir Waschmaschine und Trochner schon seit Jahren. Leicht andere Parameter, weil meine Maschine im "Wartezustand" noch etwas Ruhestrom zieht. Und die Wartezeit konnte ich etwas reduzieren, hängt aber vom Waschprogramm ab. Und so schnell muß das im Alltag auch nicht funktionieren.
                          Zusammen mit der Benachrichtigung eines der hilfreicheren Themen - und auch noch recht einfach. Mit den alten HM Dosen halt doppelt so teuer als mit den Shelly.
                            tbi last edited by
                            ich versuche das ganze leider gerade auch erfolglos, mit der schaltbaren Shelly Steckdose an meinem Fernseher.
                            Sobald er unter 30 Watt zieht soll er ausgehen. Der Wert eine Minute ist jetzt nur zum testen, damit ich das ergebnis schneller hab.
                            Leider schaltet er sich mit diesem blockly script nichtsdestotrotz nach einer Minute ab, auch bei 70 Watt dauerleistungsbezug.
                            kann mir jemand helfen oder einen Tipp geben? Danke im Voraus
                              paul53 @tbi last edited by
                              @tbi sagte: einen Tipp geben?
                              sonst falls vorheriger Wert > 30
                                tbi @paul53 last edited by
                                ahhh, danke - probier ich heut abend gleich aus
                                  fir3drag0n @paul53 last edited by fir3drag0n
                                  @paul53 ich habe dazu eine ergänzende Frage: und zwar will ich ebenso eine Steckdose gemäß einem Schwellwert schalten. Allerdings soll die Steckdose A zusätzlich nur geschaltet werden wenn x Watt unterschritten sind (wie hier) und eine zweite Steckdose B ebenfalls einen Schwellwert eine Weile unterschritten hat.
                                  Wie baue ich das ein, direkt in der ersten Abfrage?
                                    paul53 @fir3drag0n last edited by
                                    @fir3drag0n sagte: Steckdose A zusätzlich nur geschaltet werden wenn x Watt unterschritten sind (wie hier) und eine zweite Steckdose B ebenfalls einen Schwellwert eine Weile unterschritten hat.
                                    Wenn auf die Leistung von zwei Steckdosen getriggert wird, können "Wert" und "vorheriger Wert" nicht verwendet werden. So wird es funktionieren:
                                      Homoran Global Moderator Administrators @fir3drag0n last edited by Homoran
                                      @fir3drag0n sagte in [gelöst] Steckdose abschalten wenn keine Verbraucher an ist:
                                      das ist imho eine Andere Anforderung.
                                      Wobei ich noch nicht ganz die Reihenfolge der Bedingungen verstanden habe.
                                      Möglichkeit:
                                      Dose 1 schaltet ab wenn unter gewisser Leistung...
                                      DANN fällt auch Dose 2 unter gewisse Leistung...
                                      nur DANN soll Dose 1 ausschalten.
                                        fir3drag0n @Homoran last edited by
                                        @homoran ich meinte es so:
                                        wenn Dose A größer als Wert X (für eine bestimmte Zeit) ist, dann mache bei Dose B nichts
                                        wenn Dose A kleiner als Wert X ist, dann prüfe ob Dose B größer/kleiner ihren Wert Power hat und schalte dann, wenn erfüllt.
                                        Dose A soll also gar nicht schalten.
                                          paul53 @fir3drag0n last edited by paul53
                                          @fir3drag0n
                                          Ich habe es so interpretiert: Wenn beide Steckdosen ihren jeweiligen Grenzwert für eine Weile unterschreiten, soll eine Steckdose ausgeschaltet werden? Ist die Interpretation falsch?
                                            das sind zwei verschiedene Anforderungen! Nicht eindeutig zumindest.
                                            soll Dose B schalten sobald ihre Bedingung erfüllt ist (nachdem die Bedingung von Dose A erfüllt war)?
                                            oder immer an bleiben, wenn zum Zeitpunkt der Leistungsunterschreitung von Dose A die Bedingung für Dose B nicht erfüllt ist?
                                            29
                                            6768
