    2. English
    3. ioBroker general
    4. Simple API Use SOLVED
    • UncleSam
      UncleSam Developer @ap2017 last edited by UncleSam
      @ap2017 What are you trying to do and what is your issue?
      The URL you are providing contains a lot of spaces (which is wrong).
      Also you say user.data.0 (which doesn't exist) and then try to use javascript.0. IDs must match exactly the IDs in ioBroker. Simply use the "copy" button next to the state ID to get the full ID in the correct format.
        ap2017 @UncleSam last edited by
        @UncleSam Thank you for quick response and good comments. My actual URL does not have extra spaces:
        http://iobrokerIP:8087/set/javascript.0.Pi-detection?Value=true
        I created PI-detection variable in javascript.0 folder and monitoring value of this variable in response to motion detection from MotionEye, but so far I am getting nothing. My MotionEye Web Hook URL is http://iobrokerIP:8087/set/javascript.0.Pi-detection?Value=true with HTTP method set as GET
        paul53 UncleSam 2 Replies Last reply Reply Quote 0
          paul53 @ap2017 last edited by paul53
          @ap2017
          Link is wrong (Value --> value).
          http://iobrokerip:8087/set/javascript.0.Pi-detection?value=true
          • UncleSam
            @ap2017 Thanks for the clarifications.
            What happens if you open the URL in your browser? Do you get a JSON response similar to the following or an error message?
            {"id":"javascript.0.Pi-detection","value":true}
            How do you know that you are "getting nothing"?
              @UncleSam In browser I am getting error message
              "error: datapoint "javascript.0.Pi-detection" not found"
              I monitor variable PI-detection as Boolean widget in VIS
              UncleSam 1 Reply Last reply Reply Quote 0
              • UncleSam
                @ap2017 Can you please share a screenshot of your object tree in ioBroker where we can see the mentioned state (and its parents)?
                  @UncleSam Here the screenshot. Do I need to have subfolder variables in my URL?
                    @ap2017
                    URL: http://iobrokerip:8087/set/javascript.0.variables.PI-detection?value=true
                    • UncleSam
                      @ap2017 So, did you copy the state ID the way I asked you to?
                      Because it seems to me that the name should be javascript.0.variables.PI-detection
                      A 2 Replies Last reply Reply Quote 0
                        ap2017 @UncleSam last edited by ap2017
                        @UncleSam Thank you, with subfolder "variables" added I am getting browser response
                        {"id":"javascript.0.variables.PI-detection","value":true,"val":true}
                        Now I need to figure out how MotionEye notification work, since I PI-detection does not change in response to motion
                          @UncleSam Everything works now. I did not realized that I have to reset the web hook variable after motion is detected.
                            tehMilcho @ap2017 last edited by
                            Hey there,
                            i got the same Error but little different problem. I have copyed the Object-Path with the little button.
                            so i build this URL:
                            http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint
                            The Url works fine in any browser but when i try to use it in my code i get:
                            "error: no value found for "0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1". Use /set/id?value=1 or /set/id?value=1&wait=1000"
                            I will use it in a Lua Script that runs on the "Fibaro Home center lite". When i rebuild the URL to "toggle" it works fine.. i have no clue whats the issue .. because it makes no sense for me.
                            Lua Code:
                            local value = fibaro.getValue(52, "value")
                            local url
                            -- Deside if value should be true or false
                            if (fibaro.getValue(52, "value") == true) then
                            url = 'http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=true&prettyPrint'
                            elseif (fibaro.getValue(52, "value") == false) then
                            url = 'SERVER/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint'
                            else
                            print ("No Match")
                            end
                            print(url)
                            local selfhttp = net.HTTPClient()
                            local headers = {
                                    ["Accept"] = "application/json",
                                    ["Content-Type"] = 'application/json',
                                    ["Cache-Control"] = "no-cache"
                            selfhttp:request(url, {
                              options={
                                method = 'GET',
                                headers = headers,
                                timeout = 5000
                             success = function(response)
                                        print(response.status)
                                        print(response.data)
                                end,
                                error = function(message)
                                        print("error:", message)
                                end
                            anyone knows something? i think i had the same issue by try to use something like this in Android App - Tasker, but then give out and used toggle.
                              MCU last edited by
                              @tehmilcho sagte in Simple API Use SOLVED:
                              Try to encode the URL
                              let encodedUrl = encodeURIComponent(url);
                                tehMilcho @MCU last edited by
                                @mcu said in Simple API Use SOLVED:
                                the Lua Script in Fibaro seems not happy about it:
                                [24.11.2023] [22:43:48] [ERROR] [SCENE29]: (load):15: syntax error near 'encodedUrl
                                  MCU @tehMilcho last edited by
                                  @tehmilcho In LUA seems to be
                                  local encodedUrl = url.escape(url)
                                    mhh seems like fibaro specail lua?
                                    [24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')
                                      @tehmilcho Do you use it so?
                                      url = url.escape(url)
                                        options={
                                          method = 'GET',
                                          headers = headers,
                                          timeout = 5000
                                        end,
                                        end
                                        @mcu yep this leads to "[24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')"
                                          Try this
                                          url = url:gsub("([^A-Za-z0-9_])", function(c) return string.format("%%%02X", string.byte(c)) end)
                                            then it seems to get stuck, no error but will not finsh and also the state in iobroker is not changed, when you Output the new string you will get:
                                            http%3A%2F%2F192%2E168%2E178%2E37%3A8087%2Fset%2F0_userdata%2E0%2EVirtualDevices%2Ehc3lite%2EFlurPIR%2D1%3Fvalue%3Dtrue%26prettyPrint
                                            1.3k
                                            api simple api
                                            4110
