    4. Test Adapter Nuki-extended v2.0.x
      A Former User last edited by
      ![alt text](Bildschirmfoto 2021-01-01 um 19.43.55.png image url)
      Warum werden mir nicht mehr Informationen angezeigt?
        @Paul-OL
        Log file vom Start des Adapters?
            @Paul-OL
            Bitte keine Screenshots sondern als Text (in CodeTags) hier rein.
              A Former User @Thomas Braun last edited by
              @Thomas-Braun
              Danke für deinen Einsatz. Wie es scheint, brauchte es einige Neustarts oder Minuten um sich zu aktualisieren. Es hat dann einfach nach einiger zeit die Ordner selber angezeigt.
                Aber die Instanz is gelb
                web.0	2021-01-01 20:05:05.480	info	(27951) ==>Connected system.user.admin from ::ffff:192.168.1.153
                javascript.0	2021-01-01 20:04:57.239	info	(19995) script.js.Klingel: registered 1 subscription and 0 schedules
                javascript.0	2021-01-01 20:04:57.227	info	(19995) Start javascript script.js.Klingel
                javascript.0	2021-01-01 20:04:57.212	info	(19995) Stop script script.js.Klingel
                javascript.0	2021-01-01 19:52:40.574	info	(19995) script.js.Klingel: registered 1 subscription and 0 schedules
                javascript.0	2021-01-01 19:52:40.568	info	(19995) Start javascript script.js.Klingel
                javascript.0	2021-01-01 19:52:39.232	info	(19995) Stop script script.js.Klingel
                web.0	2021-01-01 19:50:00.206	info	(27951) <==Disconnect system.user.admin from ::ffff:192.168.1.153 vis.0
                web.0	2021-01-01 19:49:58.738	info	(27951) ==>Connected system.user.admin from ::ffff:192.168.1.153
                nuki-extended.0	2021-01-01 19:49:41.796	info	(13898) Listening for Nuki events on port 51989.
                nuki-extended.0	2021-01-01 19:49:41.794	info	(13898) Polling Nuki Web API deactivated.
                nuki-extended.0	2021-01-01 19:49:39.987	info	(13898) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v12.20.0, js-controller: 3.1.6
                host.raspberrypi	2021-01-01 19:49:37.847	info	instance system.adapter.nuki-extended.0 started with pid 13898
                host.raspberrypi	2021-01-01 19:49:35.356	info	instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                nuki-extended.0	2021-01-01 19:49:34.837	info	(9463) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                nuki-extended.0	2021-01-01 19:49:34.835	info	(9463) terminating
                nuki-extended.0	2021-01-01 19:49:34.834	info	(9463) Adapter stopped und unloaded.
                nuki-extended.0	2021-01-01 19:49:34.830	info	(9463) Got terminate signal TERMINATE_YOURSELF
                host.raspberrypi	2021-01-01 19:49:34.824	info	stopInstance system.adapter.nuki-extended.0 send kill signal
                host.raspberrypi	2021-01-01 19:49:34.822	info	stopInstance system.adapter.nuki-extended.0 (force=false, process=true)
                javascript.0	2021-01-01 19:46:04.217	info	(19995) script.js.NachrichtWohnungsTuer: registered 1 subscription and 0 schedules
                javascript.0	2021-01-01 19:46:04.159	info	(19995) Start javascript script.js.NachrichtWohnungsTuer
                javascript.0	2021-01-01 19:46:01.214	info	(19995) Stop script script.js.NachrichtWohnungsTuer
                web.0	2021-01-01 19:43:06.471	info	(27951) <==Disconnect system.user.admin from ::ffff:192.168.1.153 vis.0
                web.0	2021-01-01 19:43:05.166	info	(27951) ==>Connected system.user.admin from ::ffff:192.168.1.153
                nuki-extended.0	2021-01-01 19:42:35.557	info	(9463) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v12.20.0, js-controller: 3.1.6
                host.raspberrypi	2021-01-01 19:42:33.649	info	instance system.adapter.nuki-extended.0 started with pid 9463
                host.raspberrypi	2021-01-01 19:42:31.173	info	instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                nuki-extended.0	2021-01-01 19:42:30.653	info	(8794) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                nuki-extended.0	2021-01-01 19:42:30.650	info	(8794) terminating
                nuki-extended.0	2021-01-01 19:42:30.644	info	(8794) Adapter stopped und unloaded.
                nuki-extended.0	2021-01-01 19:42:30.633	info	(8794) Got terminate signal TERMINATE_YOURSELF
                  @Paul-OL sagte in Test Adapter Nuki-extended v2.0.x:
                  Bei mir wir da gepollt.
                    A Former User @Thomas Braun last edited by A Former User
                    @Thomas-Braun Was bedeutet gepollt?
                    Was muss ich jetzt machen?
                    Auserdem , sehe ich, dass es den Zustand "ringState" gibt. Der ändert sich aber nicht zurück auf false.
                    Wie soll ich das Klingeln den abgreifen?
                    Ich will dass beim Klingeln die Lampe 3 mal leuchtet.
                      @Paul-OL Sprichst du auch beide APIs an?
                      nuki bride und nuki web?
                      Bei nuki web muss auch ein Intervall gesetzt werden, bei 0 wird nicht gepollt/abgerufen. Ich habe da 10 Sekunden drin.
                        @Thomas-Braun
                        Ja, ich habe beide API`s drin.
                        Nun habe ich die 10 sekunden eingetragen und es funktioniert besser. Ich werde es weiter beobachten.
                        Danke für deinen Einsatz. Ich weiß das zu schätzen.
                          mcbarney last edited by
                          Ich bin Newbie im Bereich NUKI und IOBROKER und habe da ein Problem.
                          ich würde gerne den die variable ringStateUpdate auslesen. Leider bekommen ich diese unter den opener State Variablen nicht angezeigt:
                          In dieser Ansicht bekomme ich angezeigt das es an der Tür geklingelt hat:
                          Firmwareversionen sind wie folgt:
                          Bridge: 2.8.0
                          Opener: 1.6.4
                          Adapterversion:
                          Nuki Extended: 2.3.0
                          Admin: 4.1.11
                          Ich hoffe ihr könnt mir eventuell mit den Daten schon weiterhelfen.
                          Wenn nicht sagt mir bitte welche Infos ihr noch von mir braucht.
                          Vielen Dank und Grüße
                          Dirk
                          • Dr. Bakterius
                            Dr. Bakterius Most Active @mcbarney last edited by
                            @mcbarney Bist du auch im richtigen Ordner? Ich habe zwar keinen Opener, aber mir sieht das sehr danach aus, dass du im Ordner vom Smartlock suchst. Wie sieht denn die Ordnerstruktur (inkl. Unterordner) unter nuki-extended.0 aus?
                            Thomas Braun M 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @Dr. Bakterius last edited by
                              @dr-bakterius
                              Ich glaube hier wäre eine Antwort günstiger:
                              https://forum.iobroker.net/topic/41357/nuki-ringstateupdate-nicht-verfügbar?_=1611504536016
                                mcbarney @Dr. Bakterius last edited by
                                @dr-bakterius hi vielen Dank schonmal für deine Rückmeldung. Lass uns hier weitermachen:
                                Habe dort nochmal einen Screenshot von der Strucktur hinterlegt.
                                Dirk
                                  gizmodlx @mcbarney last edited by
                                  Hi zusammen! Ich bin bei meinen bisherigen Recherchen leider zu keiner Antwort gekommen. Gibt es eine Möglichkeit, die Nuki-Ereignisse (Öffnung durch Person X, Schließung durch Person Y) abzufragen und sich dann entsprechend benachrichtigen zu lassen?
                                  Ich kenne die Benachrichtigungsoption in der NUKI-App. Mir geht es aber darum, diese Nachrichten auch im ioBroker entsprechend zu verarbeiten. Und dazu finde ich einfach nichts.
                                  • JackDaniel
                                    JackDaniel last edited by
                                    hmm ja müsste gehen, bei diesem adapter hast du ja unter jedem benutzer einen dp datelastActive was man als auslöser verwenden könnte, und mit dem dp lastAction vom schloss könnte man identifizieren was gemacht wurde
                                    G 2 Replies Last reply Reply Quote 0
                                      gizmodlx @JackDaniel last edited by
                                      @jackdaniel Prima! Danke für den Tipp. Das sieht in der Tat vielversprechend aus. Schaue ich mir mal an.
                                      In der Doku vom Adapter findet man auch Infos zu einem Knoten "notifications". Allerdings finde ich den partout nicht.
                                      • Dr. Bakterius
                                        Dr. Bakterius Most Active @gizmodlx last edited by
                                        @gizmodlx sagte in Test Adapter Nuki-extended v2.0.x:
                                        Hier?
                                          gizmodlx @Dr. Bakterius last edited by
                                          @dr-bakterius Ok, da hab ich mich unklar ausgedrückt 🙂
                                          Die "Notifications" hab ich auch im Baum "Info" gefunden, nicht jedoch die in der Doku erwähnten "notifications.notificationindex...."
                                            @jackdaniel said in Test Adapter Nuki-extended v2.0.x:
                                            Leider scheinen diese Infos nicht zeitnah aktualisiert zu werden - trotz Abrufintervall von 10 Sekunden habe ich teils nach Stunden hier noch kein Status-Update. Ich vermute das lässt sich so derzeit nicht sinnvoll nutzen.
                                            31.7k
                                            79.9k
                                            nuki nuki-extended adapter
                                            65
                                            599
                                            111047
