    4. Test Adapter enigma2 v1.2.x
      Termina @Matten Matten last edited by
      @Matten-Matten
      Danke für Dein Script - habe ich mal ausprobiert und natürlich gestartet. Mein Datenpunkt (Zeichenkette) lautet: 0_userdata.0.Picon_Channel_Enigma
      Das wird leider trotzdem reingeschrieben: 1_0_19_6C_C_85_C00000_0_0_0__Sky Sport News H
      So habe ich das Script nun angepasst (Instanz 2.1)
      on({id: "enigma2.1.enigma2.CHANNEL_SERVICEREFERENCE_NAME", change: "ne"}, function (obj) {
        var value = obj.state.val;
        if ((obj.state ? obj.state.val : "") == (obj.state ? obj.state.val : "").indexOf('__')) {
          setState("0_userdata.0.Picon_Channel_Enigma", ((obj.state ? obj.state.val : "").slice(0, (obj.state ? obj.state.val : "").indexOf('__'))));
        } else {
          setState("0_userdata.0.Picon_Channel_Enigma", (obj.state ? obj.state.val : ""));
      Matten Matten 1 Reply Last reply Reply Quote 0
      • Matten Matten
        Matten Matten @Termina last edited by
        @Termina
        Hast du Mal auf einen anderen Sender gewechselt?
          @Matten-Matten
          Na klar... 🙂
          • dslraser
            dslraser Forum Testing Most Active @Termina last edited by dslraser
            @Termina
            probier mal
             <variables>
               <variable id="[%zw0^6j%s%)OcG|xSrt">Text</variable>
             </variables>
             <block type="variables_set" id="18vxkhIO{?Au?c`!oA!s" x="-12" y="-87">
               <field name="VAR" id="[%zw0^6j%s%)OcG|xSrt">Text</field>
                 <block type="get_value" id="z(!5A%YW+t7VPbq8b})l">
                   <field name="OID">enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME</field>
                 <block type="on_ext" id="dutQE){rM/,+u.F@44PM">
                   <value name="OID0">
                     <shadow type="field_oid" id="c5=6E$;?iA{M5ROUVvxV">
                       <field name="oid">enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME</field>
                     <block type="variables_set" id="-N{/qq)c_1p,81/;Rz:b">
                         <block type="get_value" id="M:-NIy~.,9w.Kn{(=$?k">
                         <block type="controls_if" id="U~Xx]Yh0p0I-rp_a{(eP">
                             <block type="logic_compare" id="+;D-U2ZL[$v[MU9?xd|@">
                               <field name="OP">EQ</field>
                                 <block type="get_value" id="AEvb6Pm+g;6Ggz^GC7qn">
                                 <block type="text_indexOf" id="|Cib00HrRWst$y/~bl3h">
                                   <field name="END">FIRST</field>
                                     <block type="variables_get" id="YHk%DZ.63+YB7$9ie-}-">
                                   <value name="FIND">
                                     <shadow type="text" id="Us7Z~U75%J:4ggN2NNfy">
                                       <field name="TEXT">__</field>
                             <block type="update" id="Qe!Y*(q#z8K__/-Q#G|z">
                               <field name="OID">0_userdata.0.Picon_Channel_Enigma</field>
                                 <block type="text_getSubstring" id="l,$Itw@S6]O,-F[r/}g;" inline="false">
                                   <mutation at1="false" at2="true"></mutation>
                                   <field name="WHERE1">FIRST</field>
                                   <field name="WHERE2">FROM_START</field>
                                   <value name="STRING">
                                     <block type="variables_get" id="QEB9#,[!UlIWpwq}rK]M">
                                   <value name="AT2">
                                     <block type="text_indexOf" id="}xOCy;vp?;f3e:`#gIB!">
                                       <field name="END">LAST</field>
                                         <block type="variables_get" id="A$GNrLFSAVLY^0e,uGrt">
                                       <value name="FIND">
                                         <shadow type="text" id="zAtu5Q[0||}.Y~]X=)9D">
                           <statement name="ELSE">
                             <block type="update" id="Ct}+rK+yNBzZT?+[ol1h">
                                 <block type="get_value" id="gK(-Vnw$BATo_pkoR[7_">
            var Text2;
            Text2 = getState("enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val;
            on({id: 'enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME', change: "any"}, async function (obj) {
             if (getState("enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val == Text2.indexOf('__') + 1) {
               setState("0_userdata.0.Picon_Channel_Enigma"/*Picon_Channel_Enigma*/, (Text2.slice(0, Text2.lastIndexOf('__') + 1)), true);
             } else {
               setState("0_userdata.0.Picon_Channel_Enigma"/*Picon_Channel_Enigma*/, getState("enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val, true);
            EDIT: wenn das geht, dann reicht auch der Trigger wurde geändert
            Glasfaser T 2 Replies Last reply Reply Quote 2
            • Glasfaser
              Glasfaser @dslraser last edited by Glasfaser
              @dslraser
              Du bist ein Künstler ... da kommt etwas anderes herraus :
              Ist mir leider zu hoch mit dem Wegnehmen ... aber der Weg wird schon richtig sein
              EDIT:
              Funktioniert ... hatte ein Deamon im Datenpunkt .. habe zu viel im Datenpunkt gespielt 🙂
                eMd last edited by
                Ich habe mir dafür auch mal ein blockly gepostet um die senderpicons in die VIS zu laden, finde ich auch komisch, bei mir wird immer der Sender hinten rangehangrn...
                MfG
                eMd
                PS: Nutze Open.atv
                  Termina @dslraser last edited by
                  @dslraser
                  Wahnsinn, ich kann das alles nachvollziehen und selbstverständlich habe ich sowohl meinen Datenpunkt, als auch die Enigma-Datenpunkten noch einmal überprüft, aber er schreibt immer noch in meinen Datenpunkt einfach dass, was im Enigma-Datenpunkt auch steht. Also er schneidet leider nichts ab... 😞
                  Glasfaser 2 Replies Last reply Reply Quote 0
                  • Glasfaser
                    Glasfaser @Termina last edited by Glasfaser
                    @Termina sagte in Test Adapter enigma2 v1.2.x:
                    ich habe es zu Fuß getestet .... mit deiner Beispiel Angabe ....
                    und das Script/Blockly funktioniert von @dslraser
                    • Glasfaser
                      @Termina
                      Nimm mal das 1:1 in ein JS .
                      var Text2;
                      Text2 = getState("enigma2.1.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val;
                      on({id: 'enigma2.1.enigma2.CHANNEL_SERVICEREFERENCE_NAME', change: "any"}, async function (obj) {
                       if (getState("enigma2.1.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val == Text2.indexOf('__') + 1) {
                       } else {
                         setState("0_userdata.0.Picon_Channel_Enigma"/*Picon_Channel_Enigma*/, getState("enigma2.1.enigma2.CHANNEL_SERVICEREFERENCE_NAME").val, true);
                        el_malto last edited by el_malto
                        Bei mir werden die Namen der Picons auch richtig im Adapter angezeigt.
                        Mal eine bisschen andere Frage, ich nutze die Picons nicht in der VIS.
                        Habt ihr eure Picons lokal gespeichert? Weil ihr die so einbindet:
                        /vis.0/picon/{enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME}.png
                        Warum holt ihr die nicht direkt vom Receiver mit dem
                        enigma2.0.enigma2.CHANNEL_PICON
                        Datenpunkt?
                        So müsst ihr ja immer alle Picons auf dem Receiver und lokal aktuell halten.
                        Oder klappt das evtl. zwecks Passwortabfrage nicht?
                        • Matten Matten
                          Matten Matten @el_malto last edited by Matten Matten
                          @el_malto
                          Nicht jeder nutzt/hat das Open webif. Das Standard Interface oder das Dream Webinterface unterstützten das nicht.
                          Wenn du in der config nicht openwebinterface
                          auswählst taucht auch der Datenpunk nicht auf unter Objekte.
                            el_malto @Matten Matten last edited by
                            @Matten-Matten ah ok alles klar, hatte es bisher nur mit dem OpenWebIF getest, da dass standardmäßig bei OpenATV dabei ist.
                              Es ist zum Mäusemelken!
                              So, habe nun extra an dem großen Rad gedreht, damit ich das Ganze über den Datenpunkt enigma2.1.enigma2.CHANNEL_PICON ziehen kann und was passiert... Der Datenpunkt verweist auf:
                              http://192.168.178.28:80/picon/1_0_19_EF76_3F9_1_C00000_0_0_0__Kabel 1 H.png
                              Währenddessen RTL 2 z.B. so aussieht - also richtig ist:
                              http://192.168.178.28:80/picon/1_0_19_EF15_421_1_C00000_0_0_0.png
                              Ich bin echt mit dem Latein am Ende!
                              Herzlichen Dank an @Glasfaser, @dslraser und die anderen, aber selbst die Blockly´s und Javascripte zeigen bei mir keine Wirkung! Er schreibt in meinen Datenpunkt (Zeichenkette -> liegt es daran?) einfach immer 1zu1 das rein, was im Enigma-Datenpunkt steht. Habe aus meiner Sicht alles mögliche schon gemacht inkl. Iobroker neustart, Enigma Box Openwebif usw...
                                Termina @Termina last edited by
                                Sooo, nun habe ich durch Zufall doch wohl den Übeltäter gefunden!
                                Ich habe mir einige Sender per DreamboxEdit umbenannt. Also aus z.B. kabel eins HD -> Kabel 1 HD gemacht.
                                Das gefällt dem Adapter nicht und er schreibt in den Datenpunkt jeweils den neuen Namen nach einem __
                                Ich habe den editierten Sender aus meinem Bouqet gelöscht und den originalen dann wieder hinzugefügt. Ein Neustart der Box und schon ist im Adapter auch alles fein! 🙂
                                Das ist aber natürlich dann doch wieder irgendwie blöd, da es ja Gründe hatte, warum ich bestimmte Sender umbenannt habe. Meint ihr, da kann es eine Lösung geben?
                                • Glasfaser
                                  Wo du Bouqet schreibts .
                                  Ich vermute er schreibt es dann in die Datei .....
                                  schau mal in die Datei und lösche dann den Zusatz !?
                                  • Glasfaser
                                    @Termina
                                    Habe es mal selber geändert von rbb Berlin HD auf RBB Berlin HD
                                    Bingo ....
                                    Wird dann angezeigt im Datenpunkt.
                                    1_0_19_286F_425_1_C00000_0_0_0__RBB Berlin H
                                    und so in der Datei
                                    Dann weißt du ja jetzt , wo du es am einfachsten ändern kannst .
                                      Termina @Glasfaser last edited by
                                      @Glasfaser
                                      Super! Doch leider habe ich wieder ein aber... 😞 Sry! 😇
                                      Denn wenn ich das nun anpasse wie hier z.B.
                                      #SERVICE 1:0:19:EF75:3F9:1:C00000:0:0:0:
                                      #DESCRIPTION Pro 7 HD
                                      Dann funktioniert es leider nicht. Es klappt leider erst, wenn ich auch die Zeile DESCRIPTION lösche. Dann jedoch habe ich auch den Original-TV Sendernamen und nicht mehr meinen editierten... 😞
                                      • Glasfaser
                                        @Termina
                                        Mann ... Mann ... bist du schwierig 😉
                                        Also beim Zappen achte ich nicht auf Groß/Kleinschreibung ob vorne Pro 7 steht oder hinten .... das wäre mir zu umständlich erstmal die Wörter zu lesen 😁
                                        Dann hast du schonmal ein Anhaltspunkt ..... vielleicht findest du etwas anderes ..
                                        .... aber warum das Script/Blockly von @dslraser nicht bei dir funktioniert , ist mir ein Rätzel
                                        T 1 Reply Last reply Reply Quote 2
                                          @Glasfaser
                                          Hast ja recht! Zumindest ist jetzt nach den ganzen Tagen des Suchens endlich der Grund gefunden! Da muss ich jetzt einfach schauen, ob ich eher auf den favorisierten Sendernamen oder auf das Picon verzichten kann! Wobei der Sendername für mich nur in der Senderliste interessant ist, aber das ist eine andere Geschichte... 🙂
                                          Ganz herzlichen Dank an alle, die sich da mit so reingekniet haben! 👍
                                          • Glasfaser
                                            Eigentlich nicht ...
                                            Das Picon ist doch in sehr kurzer Zeit auf den neuen Namen geändert ...
                                            ist halt doppelt aber wehn Störts und du bist zufrieden .
                                            adapter enigma2
                                            71
                                            640
                                            141648
