    4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
      babl @Dutchman last edited by
      @Dutchman na dann. 👍
      • Dutchman
        Dutchman Developer Most Active Administrators @babl last edited by
        @babl sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
        siehe hier auch die Verlinkungen zum issue im JS-controller
        https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/issues/191
        DutchmanNL created this issue in iobroker-community-adapters/ioBroker.sourceanalytix
        closed SourceState is set to default value at daily value reset #191
          jack99n @Dutchman last edited by
          Welchen DP von einer Gosund mit Tasmota drauf sollte man bei SA hinterlegen. Energie Power, Energie Today oder Energie Total?
          Bekomme bei Energie Total immer den Error
          sourceanalytix.0	2021-01-05 00:00:00.040	error	(3482) [[resetStartValues] for sonoff.0.Kühlschrank_usw.ENERGY_Power] error: Cannot read property 'calcValues' of null, stack: TypeError: Cannot read property 'calcValues' of null
          sourceanalytix.0	2021-01-05 00:00:00.040	error	at CronJob.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:547:54)
          sourceanalytix.0	2021-01-05 00:00:00.040	error	(3482) [reset values error for sonoff.0.Kühlschrank_usw.ENERGY_Power: Cannot read property 'calcValues' of null, stack: TypeError: Cannot read property 'calcValues' of null
          sourceanalytix.0	2021-01-05 00:00:00.035	error	at CronJob.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:547:54)
          sourceanalytix.0	2021-01-05 00:00:00.035	error	(3482) [[resetStartValues] for sonoff.0.Waschmaschine .ENERGY_Power] error: Cannot read property 'calcValues' of null, stack: TypeError: Cannot
          crunchip Dutchman 2 Replies Last reply Reply Quote 0
            crunchip Forum Testing Most Active @jack99n last edited by crunchip
            @jack99n sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
            Energie Total
            und bei unit kwh wählen
            • Dutchman
              Dutchman Developer Most Active Administrators @jack99n last edited by
              das sieht nach ner alte version aus ?
                kaschperle83 last edited by
                Frage zur Einstellung. Mein Stromzähler liefert den aktuelle Verbrauch und den Zählerstand.Was von beiden verwende ich für SourceAnalytics?
                • Dutchman
                  Dutchman Developer Most Active Administrators @kaschperle83 last edited by
                  @kaschperle83 sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                  aktuellen stand, verbrauch ist unnötige Berechnung von watt nach watt pro stunde das macht dein zaehler ja bereits 🙂
                    kaschperle83 @Dutchman last edited by
                    @Dutchman was muss ich denn bei dem Daten Punkt genau elEinstellen für den Zähler Wert.
                    Bei addiert sourceanalytik permanten den Zählerstand.
                      crunchip Forum Testing Most Active @kaschperle83 last edited by
                      ja
                      deine Unit, je nachdem was du alles haben möchtest, haken bei Kosten, Verbrauch und Zählerwerte setzen.
                      Bei Zählerstand Tagesbeginn, trägst du z.b deinen jetzigen Stand ein ( wenn du deine Stände für Woche/Monat/Quartal/Jahresbeginn ) kennst, kannst du die ebenfalls hinterlegen und das wars auch schon
                      • Dutchman
                        definiere addiert permanent ?
                          kaschperle83 @crunchip last edited by
                          @crunchip sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                          ja
                          Ich habe als Stand gestern 1.500 kWh ca gestartet und heute sagt mir sourceanalytik schon was von über 66.000 kWh.
                          Das ist doch falsch.
                          • Dutchman
                            komt was im log ? ich vermute auch hier den Dev: 0 bug ....
                              @Dutchman also ich bekomme jede Sekunde den Wert vom Zähler übermittelt und Sourca analytik scheint jeden einzelnen Wert also jede Sekunde zu addieren. Eigentlich muss doch nur der Wert morgens von dem abends abgezogen werden.
                                @Dutchman ob was im log steht muss ich später mal schauen. Ich habe auch gesehen ich habe schon die 4.8 alpha 2.kann es daran liegen.?
                                  kaschperle83 @kaschperle83 last edited by
                                  @kaschperle83 also im log steht nichts. Aber ich glaube jetzt läuft es. Ich hatte den Haken bei Verbrauch vergessen.
                                  • Dutchman
                                    ok, das klinkt merkwürdig ...
                                    ich arbeite gerade an einem workarround fuer DEV: 0 bug, sieht vielversprechend aus !
                                      @Dutchman Ich habe 0.4.8-alpha.2 drauf.
                                      • Dutchman
                                        0.4.8-Beta is unterwegs und kommt definitiv diese Woche ! Finally, danke für eure Geduld
                                        Und ja... dev0 auch als workarround gefixt will aber noch bissl testen vor Release
                                        1 Reply Last reply Reply Quote 5
                                        • Dutchman
                                          mal bitte probieren 😊
                                          W M XBiT 3 Replies Last reply Reply Quote 1
                                            Willi-Wunder @Dutchman last edited by Willi-Wunder
                                            @Dutchman
                                            Vielen Dank für das Update 🙂 Habe es gerade installiert bzw. neu eingerichtet. Hatte mit der vorherigen Version auch meine Probleme, hatte dann ja wie bereits oben geschrieben das Skript
                                            // https://github.com/hdering/homematic_stromverbrauch_protokollieren // Version: 1.3.3 am laufen. War das dein altes Skript?
                                            Er zeigt mir bereits Kosten und einen Verbrauch an, obwohl die Wärmepumpe momentan im standby mit 85 Watt ist. Werde es später nochmal prüfen. Muss ich beim Einrichten noch etwas beachten?
                                            Vielen Dank.
                                            adapter sourceanalytix testen update
                                            103
                                            1082
                                            316364
