    4. BackItUp für InfluxDB
    • simatec
      simatec Developer Most Active @Segway last edited by
      @Segway
      Danke die kommt in den nächsten Wochen ins stable.
      Pro Instanz von Backitup kann aktuell eine Datenbank von Influx gesichert werden
      FreunderNacht 1 Reply Last reply Reply Quote 1
      • FreunderNacht
        FreunderNacht @simatec last edited by
        @simatec
        Ok, Influx jetzt auch auf dem System des Io Brokers installiert (ohne Datenbanken).
        Die bind-adresse der Influx auf dem IO Broker System ist die IP Adresse des Grafana/Influx-Systems und die bind-adresse auf dem Grafana/Influx-System ist die IP-Adresse des IO Broker Systems.
        Mein Log sieht wie folgt aus:
        Gestartet...
        [DEBUG] [mount] - mount successfully completed
        [DEBUG] [mount] - done
        [DEBUG] [iobroker] - host.io-broker 4949 states saved
        [DEBUG] [iobroker] - host.io-broker 5695 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_01_04-13_04_44_Home_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [DEBUG] [influxDB] - Start infulxDB Backup ...
        [DEBUG] [influxDB] - Created InfuxDB Backup dir
        [DEBUG] [influxDB] - exec: influxd backup -portable -database io-broker -host 192.168.2.97:8088 /opt/iobroker/backups/influxDB_2021_01_04-13_04_49_Home_backupiobroker
        [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
        [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
        [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database io-broker -host 192.168.2.97:8088 /opt/iobroker/backups/influxDB_2021_01_04-13_04_49_Home_backupiobroker
        2021/01/04 13:04:49 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (0)...
        2021/01/04 13:04:51 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (1)...
        2021/01/04 13:04:53 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (2)...
        2021/01/04 13:04:55 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (3)...
        2021/01/04 13:04:57 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (4)...
        2021/01/04 13:04:59 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (5)...
        2021/01/04 13:05:01 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 3.01s and retrying (6)...
        2021/01/04 13:05:04 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 11.441s and retrying (7)...
        2021/01/04 13:05:16 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 43.477s and retrying (8)...
        2021/01/04 13:05:59 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2m45.216s and retrying (9)...
        backup: dial tcp 192.168.2.97:8088: connect: connection refused
        [DEBUG] [cifs] - done
        [DEBUG] [clean] - done
        [DEBUG] [telegram] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [DEBUG] [umount] - mount activ... umount in 60 Seconds!!
        [DEBUG] [umount] - umount successfully completed
        [DEBUG] [umount] - done
        [EXIT] 0
        Das Backup funktioniert allerdings nicht.
        Hier steht als Port die :8088 ist dies korrekt?
        Müsste dort nicht die :8086 stehen?
        Freund der Nacht
        • simatec
          simatec Developer Most Active @FreunderNacht last edited by
          @FreunderNacht
          Für die Sicherung ist Port 8088 der Standardport.
          Was hast du in deine config eingtragen?
          Hast du influx nach der Änderung der Config neu gestartet?
          Im Adapter Menü ist ein Link zu der Config.
          Falls die IP des Influx-Systems nicht geht, trage mal folgendes ein.
          0.0.0.0:8088
          Und anschließend Influx neustarten
          • FreunderNacht
            FreunderNacht @simatec last edited by FreunderNacht
            @simatec
            Bei mir läuft der IO-Broker auf Server 1 (192.168.2.98) und die Influx auf Server 2 (192.168.2.97).
            Ich habe jetzt auch auf dem Server 1 (192.168.2.98) die Influx DB installiert wie du in deinem Post oben gesagt hast.
            Bei der Installation der Influx auf dem Server 1 und Server 2 bin ich nach folgender Anleitung vorgegangen:
            https://www.verdrahtet.info/2020/02/14/installation-von-influxdb-grafana-inkl-verbindung-zu-iobroker/
            Auf dem Server 2 habe ich allerdings keine Datenbank angelegt, den Rest habe ich so gemacht wie in der Anleitung.
            Hier der Auszug aus der influxdb.conf vom Server 1 (192.168.2.98):
            ### Welcome to the InfluxDB configuration file.
            # The values in this file override the default values used by the system if
            # a config option is not specified. The commented out lines are the configuration
            # field and the default value used. Uncommenting a line and changing the value
            # will change the value used at runtime when the process is restarted.
            # Once every 24 hours InfluxDB will report usage data to usage.influxdata.com
            # The data includes a random ID, os, arch, version, the number of series and other
            # usage data. No data from user databases is ever transmitted.
            # Change this option to true to disable reporting.
            # reporting-disabled = false
            # Bind address to use for the RPC service for backup and restore.
            bind-address = "192.168.2.97:8088"
            ### [meta]
            ### Controls the parameters for the Raft consensus group that stores metadata
            ### about the InfluxDB cluster.
            [meta]
              # Where the metadata/raft database is stored
              dir = "/var/lib/influxdb/meta"
              # Automatically create a default retention policy when creating a database.
              # retention-autocreate = true
              # If log messages are printed for the meta service
              # logging-enabled = true
            ### [data]
            ### Controls where the actual shard data for InfluxDB lives and how it is
            ### flushed from the WAL. "dir" may need to be changed to a suitable place
            ### for your system, but the WAL settings are an advanced configuration. The
            ### defaults should work for most systems.
            [data]
              # The directory where the TSM storage engine stores TSM files.
              dir = "/var/lib/influxdb/data"
              # The directory where the TSM storage engine stores WAL files.
              wal-dir = "/var/lib/influxdb/wal"
              # The amount of time that a write will wait before fsyncing.  A duration
              # greater than 0 can be used to batch up multiple fsync calls.  This is useful for slower
              # disks or when WAL write contention is seen.  A value of 0s fsyncs every write to the WAL.
              # Values in the range of 0-100ms are recommended for non-SSD disks.
              # wal-fsync-delay = "0s"
              # The type of shard index to use for new shards.  The default is an in-memory index that is
              # recreated at startup.  A value of "tsi1" will use a disk based index that supports higher
              # cardinality datasets.
            Hier der Auszug aus der influxdb.conf vom Server 2 (192.168.2.97):
            bind-address = "192.168.2.98:8088"
            ### [meta]
            [meta]
            ### [data]
            [data]
            Und hier die Adaptereinstellung für die Influx DB im BachitUp-Adapter:
            Ich habe jetzt meinen kompletten Proxmox-Server mal neu gestartet.
            Nach dem Neustart konnte sich der Influx-Adapter des IO Brokers nicht mehr mit der Datenbank verbinden.
            Ich musste die bind-adresse auf Server 2 wieder auskommentieren, danach kam eine Verbindung zwischen dem Influx-Adapter und der Datenbank wieder Zustande.
            Kann es etwas mit den Einstellungen die ich bei der Einrichtung der InfluxDB's gemacht habe zu tun haben (siehe Link oben)?
            Freund der Nacht
            • simatec
              @FreunderNacht
              Mach mal nur auf dem Server, auf dem die Datenbank läuft ein bind auf 0.0.0.0.
              Der Rest wird nicht benötigt.
              • FreunderNacht
                @simatec
                Können die anderen Einstellungen (siehe Link von Verdrahtet) so bleiben, oder soll ich die wieder zurück auf Standard setzen?
                • simatec
                  simatec Developer Most Active @FreunderNacht last edited by simatec
                  @FreunderNacht
                  Wenn du nach der Anleitung von verdrahtet gehst, hast du sicher einen Denkfehler bei der bind-address.
                  Suche mal in der Config nach rpc oder 8088.
                  Dort musst du die Bind ändern.
                  0.0.0.0:8088
                  Hier die Doku von influx dazu
                  https://docs.influxdata.com/influxdb/v1.8/administration/config#bind-address-127-0-0-1-8088
                  • FreunderNacht
                    @simatec
                    Hab's geändert:
                    bind-address = "0.0.0.0:8088"
                    ### [meta]
                    [meta]
                    ### [data]
                    Jetzt scheint es funktioniert zu haben:
                    Gestartet...
                    [DEBUG] [iobroker] - host.io-broker 4923 states saved
                    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_01_04-21_31_08_Home_backupiobroker.tar.gz
                    [DEBUG] [influxDB] - exec: influxd backup -portable -database io-broker -host 192.168.2.97:8088 /opt/iobroker/backups/influxDB_2021_01_04-21_31_14_Home_backupiobroker
                    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_01_04-21_31_14_Home_backupiobroker.tar.gz
                    [DEBUG] [influxDB] - done
                    [EXIT] 0
                    Die Bind-Adresse auf der InfluxDB die ich (nur für das Backup) auf dem Server des IO Brokers installiert habe, habe ich wieder auskommentiert.
                    @simatec
                    Vielen Dank für deine Hilfe, das hat mir sehr geholfen.
                    Freund der Nacht
                    • smile
                      smile last edited by
                      Ich habe mich gerade riesig gefreut als ich gesehen hab dass influxDB Backup mit integriert ist. Großes Dankeschön dafür!
                      Als ich bei mir das Backup machen wollte, konnte ich jedoch den Reiter influxDB nicht sehen.
                      influxDB läuft bei mir auf dem gleichen System (Windows 10) zusammen mit dem iobroker.
                      FreunderNacht 1 Reply Last reply Reply Quote 0
                      • FreunderNacht
                        FreunderNacht @smile last edited by
                        @smile
                        hast du die neuste Version des Adapters auf deinem System?
                        Bei mir ist es die Version 1.8.3.
                        Läuft allerdings unter Linux, könnte sein, das es da unterschiede gibt.
                        Freund der Nacht
                        smile 1 Reply Last reply Reply Quote 0
                        • smile
                          smile @FreunderNacht last edited by
                          @FreunderNacht Oh, interessant, bei mir ist Version 1.7 drauf und die 1.8 steht mir auch nicht zur Installation zur Verfügung. Kann es daran liegen dass node und nom nicht auf dem neusten Stand sind? 10.17.0 und npm 6.11.3 Sowie Admin auf 3.7.8
                          Ja könnte aber natürlich auch an dem Linux Unterschied liegen.
                          • Glasfaser
                            Glasfaser @smile last edited by
                            @smile sagte in BackItUp für InfluxDB:
                            Nö ... am Verwahrungsort im ioBroker.
                            • FreunderNacht
                              FreunderNacht @Glasfaser last edited by
                              @Glasfaser
                              Stimmt, ich hatte vergessen, das ich die Version aus "latest" installiert hatte.
                              Ich glaube aber oben in einem Post von @simatec gelesen zu haben, dass die Version 1.8.3 bald in den "stabel" kommt.
                              • FreunderNacht
                                @simatec sagte in BackItUp für InfluxDB:
                                @Segway
                                Jepp, da stehts.
                                  DF612 last edited by
                                  bei mir will der Restore der InfluxDB nicht klappen.
                                  Influx ist in der Version 1.8.3 installiert und funktioniert auch.
                                  Backitup läuft in Version 1.8.5
                                  Wiederhergestellt werden soll eine ca. 140MB große Datenbank, welche auf einem NAS über FTP abgerufen wird. Die Datei wird auch im Wiederherstellen Menü gefunden und kann ausgewählt werden.
                                  Sobald ich die Datei anklicke werde ich darauf hingewiesen, dass der IBroker neustarten wird und die kleine Uhr neben dem Datensatz verschwindet.
                                  Ab diesem Punkt gibt es kein weiteres Feedback.
                                  Nach ein paar Minuten lässt sich über die Konsole überprüfen, dass in InfluxDB die Datenbank und die Measurements angelegt wurden, allerdings sind in den Measurements keine Datenpunkte.
                                  Im Log sehe ich ebenfalls nichts.
                                  Hat jemand eine Idee wo hier das Problem liegen könnte?
                                  • simatec
                                    simatec Developer Most Active @DF612 last edited by
                                    @df612
                                    Versuche es bitte lokal zu restoren.
                                      passuff @simatec last edited by passuff
                                      @simatec
                                      Folgende Konfig:
                                      Server 1: iobroker
                                      Server 2. influxdb mit datenbank (läuft seit Jahren)
                                      Ich habe nun auf Server 1 influxdb nachinstalliert. Ich verstehe es zwar nicht, habe es aber dennoch einfach mal getan. Ich habe weder eine db noch einen Benutzer angelegt. Zusätzlich habe ich nun auf Server 2 ein bind auf 0.0.0.0:8088 eingerichtet. Vermutlich ergibt das alles keinen Sinn und der Grund warum das backup nicht funktioniert ist offensichtlich - ich verstehe hier leider nur Bahnhof:
                                      influxDB: Error: Command failed: influxd backup -portable -database iobroker -host 192.168.1.10:8088 "/opt/iobroker/backups/influxDB_2021_02_01-11_02_37_backupiobroker"
                                      2021/02/01 11:02:37 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (0)...
                                      2021/02/01 11:02:39 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (1)...
                                      2021/02/01 11:02:41 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (2)...
                                      2021/02/01 11:02:43 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (3)...
                                      2021/02/01 11:02:45 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (4)...
                                      2021/02/01 11:02:47 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (5)...
                                      2021/02/01 11:02:49 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 3.01s and retrying (6)...
                                      2021/02/01 11:02:52 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 11.441s and retrying (7)...
                                      2021/02/01 11:03:04 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 43.477s and retrying (8)...
                                      2021/02/01 11:03:47 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2m45.216s and retrying (9)...
                                      backup: dial tcp 192.168.1.10:8088: connect: connection refused
                                      Meine adapter settings zeigen auf die aktive db auf Server2.
                                      simatec 2 Replies Last reply Reply Quote 0
                                      • simatec
                                        simatec Developer Most Active @passuff last edited by
                                        @passuff sagte in BackItUp für InfluxDB:
                                        Hast du Influx auf Server 2 mit "bind auf 0.0.0.0:8088" geändert?
                                        Wurde im Anschluss an die Änderungen Influx auf Server 2 neugestartet?
                                          beides korrekt.
                                          • simatec
                                            @passuff
                                            Zeige mal bitte deine Config der Influx und deine IP-Adressen der Server
                                            1.0k
                                            81.1k
                                            backitup influxdb
                                            32
                                            273
                                            51517
