    3. Entwicklung
    4. ZigBee neue Version 1.4.0
      locito09 @Asgothian last edited by
      @Asgothian said in ZigBee neue Version 1.4.0:
      @locito09
      Welche Version hast du genau installiert ? Bitte poste die ersten 10 Zeilen im Log nach dem Start des Zigbee Adapters.
      A.
      zigbee.0	2021-01-05 15:18:34.882	info	(11524) Currently 49 devices are joined:
      zigbee.0	2021-01-05 15:18:34.870	info	(11524) --> transmitPower : high
      zigbee.0	2021-01-05 15:18:34.860	info	(11524) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
      zigbee.0	2021-01-05 15:18:32.887	info	(11524) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/12a53933175cb96f4695d08e4b436fac87b129f9
      zigbee.0	2021-01-05 15:18:32.712	info	(11524) Starting Zigbee npm ...
      zigbee.0	2021-01-05 15:18:32.583	info	(11524) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.19.0, js-controller: 3.1.6
      host.debianiobroker	2021-01-05 15:18:29.106	info	instance system.adapter.zigbee.0 started with pid 11524
      host.debianiobroker	2021-01-05 15:18:27.100	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.debianiobroker	2021-01-05 15:18:27.046	info	stopInstance system.adapter.zigbee.0 killing pid 767
      zigbee.0	2021-01-05 15:18:26.560	info	(767) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0	2021-01-05 15:18:26.558	info	(767) terminating
      zigbee.0	2021-01-05 15:18:26.059	info	(767) Zigbee: disabling joining new devices.
      zigbee.0	2021-01-05 15:18:26.055	info	(767) cleaned everything up...
      0 arteck committed to ioBroker/ioBroker.zigbee
      Update package.json
        Scavi last edited by
        Hat jemand Erfahrungen mit dem Lidl Lighstrip https://www.zigbee2mqtt.io/devices/HG06104A.html gemacht (1.4.2).
        Habe das Strip heute nochmal neu gekoppelt und habe z.b kein "effect" auswahl.
        Color Steuerung ist mit der Version nicht ganz so Optimal. Hex und RGS funktionieren nicht richtig (falsche Farben -> immer grünlich oder einfach nur blau egel bei welchem code)
        Named Color klappt ganz gut. (e.g. blue, red usw)
        TransitionTime wird anscheinend auch ignoriert.
        Hatte vorher 1.4.0 drauf dort waren die exposed werte noch andere. Auf das update auf 1.4.2 über iobroker musste ich jedoch manuell in den node_modules die zigbee_herdman_* verzeichnische löschen weil er es selbst nicht hinbekommen hat. Dann hat es auch geklappt.
        H T 2 Replies Last reply Reply Quote 0
          hukio @Scavi last edited by
          Der Blitzwolf Tuya TS0121_plug mißt die Leistungswerte kontinuierlich. Die Werte müssen aber abgefragt werden (werden nicht publiziert von alleine). In der älteren Zigbee Version (1.2) wurde die Abfrage etwa alle 20 s gemacht. Jetzt sind es 60 s, was nach link text der normale Wert ist. Weiß jemand, bzw., wer kann mir helfen, die Leistung ohne Warten abzufragen?
          In der Diskussion damals war @dimaiv involviert, der mehrere plugs hat.
          Danke!
            dimaiv @hukio last edited by dimaiv
            @hukio
            Hi, ja, das kann man machen.
            Entweder kann man Abfrageintervall editieren, Datei devices.js in herdsman-converters.
            Oder folgende Nachricht an die Dose senden und die antwortet sofort:
            "devId": "zigbee.0.842e14fffedb8ae5",
            "ep": "1",
            "cid": "haElectricalMeasurement",
            "cmd": "read",
            "cmdType": "foundation",
            "zclData": {
            "activePower": {}
            "cfg": null
            Bei devId natürlich eigenen Gerät wählen.
              hukio @dimaiv last edited by
              @dimaiv und wie mache ich dies? Als javascript?
              Danke für die Hilfe.h
                Holzlenkrad @the-crow last edited by
                @the-crow said in ZigBee neue Version 1.4.0:
                Auch von mir, vielen Dank für die tolle Arbeit.
                Ich habe noch eine Ergänzung zu folgendem Zwischenstecker:
                Node.js v14.15.1
                Zigbee adapter v1.4.0
                Der Zwischenstecker unterstüzt eigentlich das separte Schalten von Strom und USB. Als ich den über Deconz eingebunden hatte, funktionierte das auch. Jetzt kann ich nur mehr beide gleichzeitig ein/aus schalten und es wird in den Objekten auch nur ein switch angegeben.
                Bist du dir wirklich sicher, dass man die USB-Buchsen auch schalten kann, zusätzlich zur Steckdose? Als ich mir den Stecker gekauft habe, habe ich dazu jedenfalls nichts gefunden.
                Ich kann aber bei Bedarf auch gern mal rein gucken, ob da wirklich zwei Relais drin sind 😄
                  Holzlenkrad last edited by
                  Welchen praktischen Unterschied macht es eigentlich, ob man ein neues Device direkt am Coordinator oder an einem Router peert? Die haben ja aus irgendeinem Grund einen extra Button dafür.
                  Ich dachte Zigbee würde so funktionieren, dass sich die Geräte ohnehin das beste Netz "zurecht mashen"... ?
                  • Asgothian
                    Asgothian Developer @Holzlenkrad last edited by
                    @Holzlenkrad sagte in ZigBee neue Version 1.4.0:
                    Es macht genau keinen Unterschied. Egal welcher der Knöpfe gedrückt wird - es wird immer das gesamte Netz geöffnet. Es gibt dazu im Adapter nur eine Funktion.
                    Allerdings kann es auf Grund von Inkompatibilitäten dazu kommen das
                    • bestimmte router ein anlernen nicht zulassen, sprich das Geräte zum Koordinator gebracht werden müssen
                    • bestimmte Geräte nicht an einem Router angelernt werden können, un diese zum Koordinator gebracht werden müssen.
                    H Smart_Home 2 Replies Last reply Reply Quote 0
                    • Asgothian
                      Die Beschreibung der Endpunkte deutet darauf hin das beide getrennt schaltbar sind. An welcher stelle das nicht weiter gereicht wird muss geschaut werden.
                      A.
                        Holzlenkrad @Asgothian last edited by Holzlenkrad
                        @Asgothian
                        Ok, dann mal anders gefragt. Wann soll ich den Pairing-Knopf des Koordinatos drücken und wann den eines Routers, wenn es ohnehin keinen Unterschied macht?
                        Bezüglich des Steckdosenadapters ZK-EU-2U:
                        Wie kann ich dir helfen, dass der zweite Switch schaltbar gemacht wird?
                        So ist er aktuell bei mir eingerichtet:
                        Edit: Und ich sehe gerade, dass der Status gar nicht zum iobroker zurück gemeldet wird, wenn man den Stecker manuell an seinem Schalter schaltet. Das ist ja auch mal ungeil...
                        Liegt aber vermutlich an der Hardware?`
                        • Asgothian
                          @Holzlenkrad Beides liegt an der Einbindung im Herdsman. Das kann ich mir aber erst am Wochenende anschauen.
                          A.
                          • Smart_Home
                            Smart_Home @Asgothian last edited by
                            @Asgothian sagte in ZigBee neue Version 1.4.0:
                            Beim Durchsuchen des Forums bin ich auf deinen Post gestoßen. Ich habe aktuell einen Thread offen, in dem es darum geht, dass ich Aktoren/Lampen/Thermostate nicht in mein Zigbee-Netzwerk eingelernt bekomme, wenn ich vom Coordinator zu weit weg bin, sondern nur direkt am Coordinator selber. Vielleicht kannst du ja mal einen Blick drauf werfen:
                            https://forum.iobroker.net/topic/40369/nicht-gelöst-zigbee-geräte-werden-nicht-erkannt
                              @Asgothian
                              Danke!
                              Vielleicht hilft das dann auch weiter:
                              https://github.com/Koenkk/zigbee2mqtt/issues/4503
                              • Slowman
                                Slowman last edited by
                                Hat man die Möglichkeit Geräte zu deaktivieren (damit man keine Warn-Meldungen bekommt). Benutze manche Plugs nur 1-2x im Jahr, bisher melde ich diese immer ab und an. Oder habe ich diese Funktion noch nicht gefunden?
                                • Asgothian
                                  Asgothian Developer @Slowman last edited by
                                  @Slowman
                                  Du kannst die Geräte rauswerfen, und dann wenn du sie wieder benötigst neu pairen. Weitere Funktionen kennt das System bisher nicht.
                                  A.
                                  • JackDaniel
                                    JackDaniel @JackDaniel last edited by
                                    @JackDaniel sagte in ZigBee neue Version 1.4.0:
                                    Node JS Version - v12.20.0
                                    ioBroker.Zigbee Version -1.4.0
                                    HW des Koordinators - dieser hier
                                    das kommt beim löschversuch
                                    zigbee.0	2020-12-07 18:07:21.101	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:07:21.100	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be
                                    zigbee.0	2020-12-07 18:07:21.099	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55","
                                    zigbee.0	2020-12-07 18:07:21.098	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
                                    zigbee.0	2020-12-07 18:07:21.098	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE","
                                    zigbee.0	2020-12-07 18:07:21.022	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
                                    zigbee.0	2020-12-07 18:07:20.956	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
                                    zigbee.0	2020-12-07 18:07:20.955	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE","
                                    zigbee.0	2020-12-07 18:07:20.874	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
                                    zigbee.0	2020-12-07 18:07:20.653	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
                                    zigbee.0	2020-12-07 18:07:20.652	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextHo
                                    zigbee.0	2020-12-07 18:07:20.627	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:07:20.627	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
                                    zigbee.0	2020-12-07 18:07:20.591	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
                                    zigbee.0	2020-12-07 18:07:20.514	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:07:20.513	debug	(541206) getDevices result: [{"type":"device","common":{"name":"Rollo Kinderzimmer","type":"E1757","icon":"img/Ikea_fyrtur.png"},"native":{"id":"000d6ffffe2de624"},"from":"system.adapter.zigbee.0","us
                                    zigbee.0	2020-12-07 18:07:20.454	debug	(541206) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:07:20.453	debug	(541206) List of ports: [{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS10"},{"comName":"/dev/ttyS11"},{"comName":"/dev/
                                    zigbee.0	2020-12-07 18:07:20.429	debug	(541206) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:07:20.429	debug	(541206) getGroups result: {}
                                    zigbee.0	2020-12-07 18:07:20.402	debug	(541206) Routing table succeeded for 'Coordinator'
                                    zigbee.0	2020-12-07 18:07:20.402	debug	(541206) Routing for 'Coordinator': {"table":[{"destinationAddress":61554,"status":"ACTIVE","nextHop":13418},{"destinationAddress":45744,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,
                                    zigbee.0	2020-12-07 18:07:20.399	debug	(541206) LQI succeeded for 'Coordinator'
                                    zigbee.0	2020-12-07 18:07:20.365	debug	(541206) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:07:20.364	debug	(541206) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:07:20.332	debug	(541206) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.0","channel":"26","port":"/dev/ttyACM0","type":"zStack30x","revision":20200211,"version":"2.2.7.2"}
                                    chromecast.0	2020-12-07 18:07:17.218	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:07:17.170	info	(120990) TV_Wohnzimmer - not enabled
                                    zigbee.0	2020-12-07 18:07:15.430	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:07:15.430	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
                                    zigbee.0	2020-12-07 18:07:15.371	debug	(541206) sendTo "delBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:07:15.370	error	at async /opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:255:21
                                    zigbee.0	2020-12-07 18:07:15.370	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                    zigbee.0	2020-12-07 18:07:15.370	error	at Binding.doBindUnbind (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:102:111)
                                    zigbee.0	2020-12-07 18:07:15.370	error	at Binding.getBindEp (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:89:28)
                                    zigbee.0	2020-12-07 18:07:15.370	error	(541206) Failed to doBindUnbind TypeError: Cannot read property 'split' of undefined
                                    zigbee.0	2020-12-07 18:07:15.369	debug	(541206) source: {"type":"device","device":{"ID":5,"_type":"EndDevice","_ieeeAddr":"0x086bd7fffe5f8d3f","_networkAddress":2137,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":
                                    zigbee.0	2020-12-07 18:07:15.367	debug	(541206) found state: {"val":"{\"bind_source\":\"zigbee.0.086bd7fffe5f8d3f\",\"bind_source_ep\":\"1\",\"bind_target\":\"1\",\"unbind_from_coordinator\":false}","ack":true,"ts":1600584776907,"q":0,"fr
                                    zigbee.0	2020-12-07 18:07:15.365	debug	(541206) delBinding message: "bind_086bd7fffe5f8d3f_1_1_undefined"
                                    chromecast.0	2020-12-07 18:07:10.877	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:07:10.744	info	(120990) TV_Wohnzimmer - not enabled
                                    zigbee.0	2020-12-07 18:07:08.706	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:07:08.706	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940b
                                    zigbee.0	2020-12-07 18:07:08.706	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55",
                                    zigbee.0	2020-12-07 18:07:08.705	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
                                    zigbee.0	2020-12-07 18:07:08.705	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE",
                                    zigbee.0	2020-12-07 18:07:08.642	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
                                    zigbee.0	2020-12-07 18:07:08.578	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
                                    zigbee.0	2020-12-07 18:07:08.577	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE",
                                    zigbee.0	2020-12-07 18:07:08.494	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
                                    zigbee.0	2020-12-07 18:07:08.260	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:07:08.259	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
                                    zigbee.0	2020-12-07 18:07:08.224	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
                                    zigbee.0	2020-12-07 18:07:08.223	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextH
                                    zigbee.0	2020-12-07 18:07:08.162	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
                                    zigbee.0	2020-12-07 18:07:08.045	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    und das wenn ich die bindung ändern will
                                    zigbee.0	2020-12-07 18:09:02.654	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:09:02.653	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be
                                    zigbee.0	2020-12-07 18:09:02.652	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55","
                                    zigbee.0	2020-12-07 18:09:02.651	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
                                    zigbee.0	2020-12-07 18:09:02.650	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE","
                                    zigbee.0	2020-12-07 18:09:02.581	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
                                    zigbee.0	2020-12-07 18:09:02.517	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
                                    zigbee.0	2020-12-07 18:09:02.516	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE","
                                    zigbee.0	2020-12-07 18:09:02.437	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
                                    zigbee.0	2020-12-07 18:09:02.221	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
                                    zigbee.0	2020-12-07 18:09:02.220	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextHo
                                    zigbee.0	2020-12-07 18:09:02.179	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:09:02.179	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
                                    zigbee.0	2020-12-07 18:09:02.160	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
                                    zigbee.0	2020-12-07 18:09:02.051	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:09:02.050	debug	(541206) getDevices result: [{"type":"device","common":{"name":"Rollo Kinderzimmer","type":"E1757","icon":"img/Ikea_fyrtur.png"},"native":{"id":"000d6ffffe2de624"},"from":"system.adapter.zigbee.0","us
                                    zigbee.0	2020-12-07 18:09:02.027	debug	(541206) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:09:02.027	debug	(541206) List of ports: [{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS10"},{"comName":"/dev/ttyS11"},{"comName":"/dev/
                                    zigbee.0	2020-12-07 18:09:01.972	debug	(541206) Routing table succeeded for 'Coordinator'
                                    zigbee.0	2020-12-07 18:09:01.972	debug	(541206) Routing for 'Coordinator': {"table":[{"destinationAddress":61554,"status":"ACTIVE","nextHop":13418},{"destinationAddress":45744,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,
                                    zigbee.0	2020-12-07 18:09:01.969	debug	(541206) LQI succeeded for 'Coordinator'
                                    zigbee.0	2020-12-07 18:09:01.957	debug	(541206) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:09:01.956	debug	(541206) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:09:01.956	debug	(541206) getGroups result: {}
                                    zigbee.0	2020-12-07 18:09:01.955	debug	(541206) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:09:01.955	debug	(541206) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.0","channel":"26","port":"/dev/ttyACM0","type":"zStack30x","revision":20200211,"version":"2.2.7.2"}
                                    mystrom-wifi-switch.1	2020-12-07 18:09:01.480	info	(533412) result from http://192.168.1.64:{"power":15.14,"Ws":15.25,"relay":true,"temperature":21.31}
                                    mystrom-wifi-switch.0	2020-12-07 18:08:59.750	info	(533396) result from http://192.168.1.61:{"power":0,"Ws":1.75,"relay":true,"temperature":4.68}
                                    chromecast.0	2020-12-07 18:08:59.629	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:08:59.628	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:08:59.617	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:08:59.606	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:08:59.603	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:08:59.332	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:08:59.331	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:08:59.330	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:08:59.302	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:08:59.298	info	(120990) TV_Wohnzimmer - not enabled
                                    zigbee.0	2020-12-07 18:08:58.876	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:08:58.875	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
                                    zigbee.0	2020-12-07 18:08:58.826	debug	(541206) sendTo "editBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:08:58.825	error	at async /opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:255:21
                                    zigbee.0	2020-12-07 18:08:58.825	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                    zigbee.0	2020-12-07 18:08:58.825	error	at runMicrotasks (<anonymous>)
                                    zigbee.0	2020-12-07 18:08:58.825	error	at Binding.doBindUnbind (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:102:111)
                                    zigbee.0	2020-12-07 18:08:58.825	error	at Binding.getBindEp (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:89:28)
                                    zigbee.0	2020-12-07 18:08:58.825	error	(541206) Failed to doBindUnbind TypeError: Cannot read property 'split' of undefined
                                    zigbee.0	2020-12-07 18:08:58.823	debug	(541206) source: {"type":"device","device":{"ID":5,"_type":"EndDevice","_ieeeAddr":"0x086bd7fffe5f8d3f","_networkAddress":2137,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":
                                    zigbee.0	2020-12-07 18:08:58.821	debug	(541206) found state: {"val":"{\"bind_source\":\"zigbee.0.086bd7fffe5f8d3f\",\"bind_source_ep\":\"1\",\"bind_target\":\"1\",\"unbind_from_coordinator\":false}","ack":true,"ts":1600584776907,"q":0,"fr
                                    zigbee.0	2020-12-07 18:08:58.819	debug	(541206) delBinding message: "bind_086bd7fffe5f8d3f_1_1_undefined"
                                    zigbee.0	2020-12-07 18:08:58.818	debug	(541206) editBinding message: {"id":"bind_086bd7fffe5f8d3f_1_1_undefined","bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"zigbee.0.d0cf5efffeea0fc4","bind_target_ep":"1"
                                    chromecast.0	2020-12-07 18:08:51.236	info	(120990) TV_Wohnzimmer - not enabled
                                    chromecast.0	2020-12-07 18:08:51.006	info	(120990) TV_Wohnzimmer - not enabled
                                    unifi.0	2020-12-07 18:08:50.171	info	(530746) Update done
                                    zigbee.0	2020-12-07 18:08:48.437	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:08:48.436	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940b
                                    zigbee.0	2020-12-07 18:08:48.435	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55",
                                    zigbee.0	2020-12-07 18:08:48.434	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
                                    zigbee.0	2020-12-07 18:08:48.433	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE",
                                    zigbee.0	2020-12-07 18:08:48.370	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
                                    zigbee.0	2020-12-07 18:08:48.307	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
                                    zigbee.0	2020-12-07 18:08:48.306	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE",
                                    zigbee.0	2020-12-07 18:08:48.237	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
                                    zigbee.0	2020-12-07 18:08:48.052	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    zigbee.0	2020-12-07 18:08:48.051	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
                                    zigbee.0	2020-12-07 18:08:48.018	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
                                    zigbee.0	2020-12-07 18:08:48.017	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextH
                                    zigbee.0	2020-12-07 18:08:47.941	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
                                    zigbee.0	2020-12-07 18:08:47.833	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                                    @JackDaniel
                                    Ich wollte mir mal ein Bild von dem Fehler machen - irgendwie kommt da immer das raus:
                                    Im Ernst - ohne weitere Referenzen kann an mit der Fehlermeldung NICHTS getan werden.
                                    • Node JS Version
                                    • ioBroker.Zigbee Version
                                    • HW des Koordinators
                                    • Kachel des Koordinators im ioBroker.Zigbee (sofern iobroker.Zigbee Version1.4.0)
                                    • betroffene Geräte (Beschreibung, Kachel, welche DP's hast du versucht zu "binden"
                                    • ggf. auftretende debug Meldungen beim "bind"
                                    • ggf. auftretende debug Meldungen beim "unbind"
                                      (Ja, fuer die beiden letzten Punkte ist es notwendig den Adapter im Debug zu starten und das ganze noch einmal zu probieren)
                                    Ansonsten: Logs in code Tags, damit es so aussieht - dann kann man das nicht nur lesen sondern sogar auch verstehen:
                                    at Binding.getBindEp (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:89:28) at Binding.doBindUnbind (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:102:111)
                                    at runMicrotasks () at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                    A.
                                    @Asgothian
                                    gibt es eigentlich schon erkentnisse zu diesem thema?
                                    • Asgothian
                                      Asgothian Developer @JackDaniel last edited by
                                      @JackDaniel
                                      It should be fixed in 1.4.2
                                      A.
                                      JackDaniel 1 Reply Last reply Reply Quote 0
                                        Tim12 @Scavi last edited by
                                        @Scavi, bei den GU10 aus der Lidl-Reihe habe ich bislang auch noch kein sattes Gelb erreichen können - allerdings unabhängig von der Adapterversion. Die Lampe scheint bei Farben im Gelbbereich tendenziell zu viele Blauanteile zu haben. Hattest du mit älteren Versionen mehr Glück?
                                          daNick last edited by daNick
                                          Hallo
                                          Folgendes Gerät wird nicht erkannt:
                                          Datenpunkte werden nicht angelegt
                                          Es ist diese Lampe der Paul Neuhaus GmbH
                                          https://www.paul-neuhaus.de/shop/de/q-mia-led-wandleuchte-smart-home.html
                                          Lt. Karton: Artikel-Nr. Neuhaus 9185-13
                                          Lt. Website: Art.-Nr.: 100.491.61
                                          Adapter 1.4.2, GitHub Update 11.1.2021, 14:15
                                          Danke!
                                          daNick
                                          • Asgothian
                                            Asgothian Developer @daNick last edited by Asgothian
                                            @daNick
                                            Ist dieses Gerät bei zigbee2mqtt.io als supported gelistet ?
                                            Wenn nein - siehe "how to support new devices" - wenn das getan ist und der ioBroker auf den neuen zigbee-herdsman-converter umgestellt ist sollte die Lampe direkt im ioBroker gehen.
                                            A.
                                            alpha git neu zigbee
                                            62
                                            393
                                            68283
