    4. Test Adapter fb-checkpresence v1.1.x
    • afuerhoff
      afuerhoff Developer @Thomas Jansen last edited by
      @Thomas-Jansen
      Bitte unter Instanzen die Log Stufe auf debug setzen und hier das Log posten.
      Die andere Meldung sagt nur, dass die Firmware der Fritzbox das Feature nicht supported.
      Thomas Jansen 1 Reply Last reply Reply Quote 0
      • Thomas Jansen
        Thomas Jansen @afuerhoff last edited by
        @afuerhoff hi, hier das LOG:
        fb-checkpresence.0 2021-01-05 21:08:00.216 info (30355) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        fb-checkpresence.0 2021-01-05 21:08:00.211 info (30355) terminating
        fb-checkpresence.0 2021-01-05 21:08:00.210 info (30355) cleaned everything up ...
        fb-checkpresence.0 2021-01-05 21:08:00.208 info (30355) Got terminate signal TERMINATE_YOURSELF
        fb-checkpresence.0 2021-01-05 21:08:00.152 error (30355) createFbDeviceObjects -> can't read devices from fritzbox! Adapter stops
        fb-checkpresence.0 2021-01-05 21:08:00.151 error (30355) getDeviceList: {"message":"Request failed with status code 503","name":"Error","stack":"Error: Request failed with status code 503\n at createError (/opt/iobroker/node_modules/axios/lib/cor
        fb-checkpresence.0 2021-01-05 21:07:59.788 info (30355) createMemberObjects finished successfully
        fb-checkpresence.0 2021-01-05 21:07:59.787 debug (30355) enableHistory.2 Galaxy-Note10 true
        fb-checkpresence.0 2021-01-05 21:07:59.759 debug (30355) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0 2021-01-05 21:07:59.744 debug (30355) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0 2021-01-05 21:07:59.622 info (30355) createGlobalObjects finished successfully
        fb-checkpresence.0 2021-01-05 21:07:59.365 info (30355) service DeviceConfig1-Reboot is supported
        fb-checkpresence.0 2021-01-05 21:07:59.345 warn (30355) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
        fb-checkpresence.0 2021-01-05 21:07:59.344 warn (30355) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
        fb-checkpresence.0 2021-01-05 21:07:59.342 info (30355) service DeviceInfo1-GetInfo is supported
        fb-checkpresence.0 2021-01-05 21:07:59.325 info (30355) service WLANConfiguration3-GetInfo is supported
        fb-checkpresence.0 2021-01-05 21:07:59.310 info (30355) service WLANConfiguration3-SetEnable is supported
        fb-checkpresence.0 2021-01-05 21:07:59.296 info (30355) service WANPPPConnection1-GetInfo is supported
        fb-checkpresence.0 2021-01-05 21:07:59.281 info (30355) service DeviceInfo1-GetSecurityPort is supported
        fb-checkpresence.0 2021-01-05 21:07:59.267 info (30355) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
        fb-checkpresence.0 2021-01-05 21:07:59.255 info (30355) service Hosts1-GetSpecificHostEntry is supported
        fb-checkpresence.0 2021-01-05 21:07:59.242 info (30355) service Hosts1-X_AVM-DE_GetMeshListPath is supported
        fb-checkpresence.0 2021-01-05 21:07:59.228 info (30355) service Hosts1-X_AVM-DE_GetHostListPath is supported
        fb-checkpresence.0 2021-01-05 21:07:59.214 debug (30355) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
        fb-checkpresence.0 2021-01-05 21:07:59.193 debug (30355) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"233","Major":"161","Minor":"7","Patch":"13","Bui
        fb-checkpresence.0 2021-01-05 21:07:59.083 debug (30355) configuratuion mesh info: false
        fb-checkpresence.0 2021-01-05 21:07:59.083 debug (30355) configuration fb-devices true
        fb-checkpresence.0 2021-01-05 21:07:59.082 debug (30355) configuration familymembers: [{"familymember":"Galaxy-Note10","macaddress":"92:65:A8:12:99:34","ipaddress":"192.168.178.23","useip":false,"comment":"Galaxy-Note10","enabled":true}]
        fb-checkpresence.0 2021-01-05 21:07:59.082 debug (30355) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
        fb-checkpresence.0 2021-01-05 21:07:59.081 debug (30355) configuration history: <influxdb.0>
        fb-checkpresence.0 2021-01-05 21:07:59.080 debug (30355) configuration user: <burger20202.4>
        fb-checkpresence.0 2021-01-05 21:07:59.079 info (30355) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 1 Min. - interval members: 60 s
        fb-checkpresence.0 2021-01-05 21:07:59.044 info (30355) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.1, js-controller: 3.1.6
        afuerhoff 1 Reply Last reply Reply Quote 0
        • afuerhoff
          afuerhoff Developer @Thomas Jansen last edited by afuerhoff
          @Thomas-Jansen
          Hallo, es scheint keine Antwort von der Fritzbox zu kommen, wenn es um den User und das Passwort geht. Bitte mal den Punkt aus dem Usernamen entfernen. Und dann erneut versuchen.
          Bitte auch Passwort einmal neu eingeben, falls das nicht geholfen hat. Und zu guter Letzt könnte noch ein Neustart der Fritzbox helfen.
            Flo1988 @Flo1988 last edited by
            @Flo1988 sagte in Test Adapter fb-checkpresence v1.1.x:
            @afuerhoff
            Sry.
            node wurde auf 12.20.0 geupdated.
            Läuft trotzdem nicht.
            WLAN wurde während dem log bei "Florian" deaktiviert aber passiert nix.
            fb-checkpresence.0	2020-12-29 20:11:21.928	debug	(4210) loopDevices ends after 2,157899582 s
            fb-checkpresence.0	2020-12-29 20:11:21.924	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
            fb-checkpresence.0	2020-12-29 20:11:21.778	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
            fb-checkpresence.0	2020-12-29 20:11:21.662	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
            fb-checkpresence.0	2020-12-29 20:10:19.702	debug	(4210) loopDevices ends after 1,441445027 s
            fb-checkpresence.0	2020-12-29 20:10:19.700	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
            fb-checkpresence.0	2020-12-29 20:10:19.615	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
            fb-checkpresence.0	2020-12-29 20:10:19.546	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
            fb-checkpresence.0	2020-12-29 20:10:13.252	info	(4210) createFbDeviceObjects finished successfully
            fb-checkpresence.0	2020-12-29 20:10:04.787	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
            fb-checkpresence.0	2020-12-29 20:10:03.789	info	(4210) createMemberObjects finished successfully
            fb-checkpresence.0	2020-12-29 20:10:03.788	debug	(4210) enableHistory.2 Silke true
            fb-checkpresence.0	2020-12-29 20:10:03.762	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
            fb-checkpresence.0	2020-12-29 20:10:03.752	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
            fb-checkpresence.0	2020-12-29 20:10:03.625	debug	(4210) enableHistory.2 Florian true
            fb-checkpresence.0	2020-12-29 20:10:03.597	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
            fb-checkpresence.0	2020-12-29 20:10:03.584	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
            fb-checkpresence.0	2020-12-29 20:10:03.454	info	(4210) createGlobalObjects finished successfully
            fb-checkpresence.0	2020-12-29 20:10:03.085	info	(4210) service DeviceConfig1-Reboot is supported
            fb-checkpresence.0	2020-12-29 20:10:03.064	info	(4210) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
            fb-checkpresence.0	2020-12-29 20:10:02.952	info	(4210) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
            fb-checkpresence.0	2020-12-29 20:10:02.938	info	(4210) service DeviceInfo1-GetInfo is supported
            fb-checkpresence.0	2020-12-29 20:10:02.919	info	(4210) service WLANConfiguration3-GetInfo is supported
            fb-checkpresence.0	2020-12-29 20:10:02.903	info	(4210) service WLANConfiguration3-SetEnable is supported
            fb-checkpresence.0	2020-12-29 20:10:02.886	info	(4210) service WANPPPConnection1-GetInfo is supported
            fb-checkpresence.0	2020-12-29 20:10:02.869	info	(4210) service DeviceInfo1-GetSecurityPort is supported
            fb-checkpresence.0	2020-12-29 20:10:02.853	info	(4210) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
            fb-checkpresence.0	2020-12-29 20:10:02.834	info	(4210) service Hosts1-GetSpecificHostEntry is supported
            fb-checkpresence.0	2020-12-29 20:10:02.820	info	(4210) service Hosts1-X_AVM-DE_GetMeshListPath is supported
            fb-checkpresence.0	2020-12-29 20:10:02.802	info	(4210) service Hosts1-X_AVM-DE_GetHostListPath is supported
            fb-checkpresence.0	2020-12-29 20:10:02.787	debug	(4210) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
            fb-checkpresence.0	2020-12-29 20:10:02.756	debug	(4210) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"226","Major":"154","Minor":"7","Patch":"21","Buil
            fb-checkpresence.0	2020-12-29 20:10:02.498	debug	(4210) configuratuion mesh info: false
            fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration fb-devices true
            fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration familymembers: [{"familymember":"Florian","macaddress":"A0:FB:C5:21:AC:7B","ipaddress":"192.168.155.86","useip":false,"comment":"iPhone12pro","enabled":true},{"familymember":"Silk
            fb-checkpresence.0	2020-12-29 20:10:02.496	debug	(4210) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
            fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration history: <influxdb.0>
            fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration user: <ioBroker_tr064>
            fb-checkpresence.0	2020-12-29 20:10:02.493	info	(4210) start fb-checkpresence: ip-address: "192.168.155.1" - interval devices: 1 Min. - interval members: 10 s
            fb-checkpresence.0	2020-12-29 20:10:02.451	info	(4210) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
            fb-checkpresence.0	2020-12-29 20:09:56.390	info	(4147) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            fb-checkpresence.0	2020-12-29 20:09:56.388	info	(4147) terminating
            fb-checkpresence.0	2020-12-29 20:09:56.386	info	(4147) cleaned everything up ...
            fb-checkpresence.0	2020-12-29 20:09:56.384	info	(4147) Got terminate signal TERMINATE_YOURSELF
            Gibt es hier schon eine Idee, warum die Geräte nicht richtig erkannt werden?
            In der FritzBox werden sie korrekt als aktiv und inaktiv angezeigt.
            Bis Version 1.0.4 hat auch alles prima funktioniert.
            Der Fehler hat sich mit der Änderung auf 1.1.0 eingeschlichen.
            • Pedder007
              Pedder007 @Pedder007 last edited by
              An der Stelle nochmal kurz ein Feedback nach nun gut einer Woche Laufzeit nach dem Update.
              Keinerlei veraltete oder verwechselte Einträge mehr, Adapter läuft super stabil und sogar die Familie ist nun in der Lage zu sehen wo sie ggf. gerade am WLAN "hängen" und ggf. via VIS einzelne (Fritz) NW-Devices neu zu booten, sofern diese überhaupt noch erreichbar sind - sonst hilft natürlich nur Stecker ziehen 😉
              Danke nochmal, dass erleichtert einem wirklich das Leben und reduziert meine persönlichen Tickets zum Thema "Papa das WLAN geht wieder nicht...." 😆 drastisch! 👍 👍 👍
                A Former User @afuerhoff last edited by
                @afuerhoff hab noch was entdeckt, was Du vielleicht gerne nachrüsten kannst... 🙂
                Einen DONATE 💰 Button in der Adapterkonfig, damits auch jeder sieht..
                afuerhoff 1 Reply Last reply Reply Quote 1
                • Dominik F.
                  Dominik F. @afuerhoff last edited by
                  @afuerhoff
                  Nabend,
                  ich nutze deinen Adapter in der Version 1.10 und der funktioniert auch sehr zuverlässig.
                  Nun habe ich festgestellt, dass der Heatingcontrol Adapter ständig neu getriggert wird.
                  Ich nutze dort einen Datenpunkt von deinem Adapter. Das Problem scheint zu sein, dass dein Adapter den Datenpunkt für Presence minütlich neu setzt auch wenn dieser sich nicht ändert.
                  Gibt es eine Möglichkeit, oder ist es vielleicht schon in der neuen Version enthalten, dass die Datenpunkte nur bei Änderung neu gesetzt werden?
                  • afuerhoff
                    afuerhoff Developer @Flo1988 last edited by
                    Es sieht so aus, als ob die Routine für die Familienmitglieder gar nicht durchlaufen wird.
                    Da müsste eigentlich eine Meldung im Log kommen.
                    Kannst Du mal das Interval auf 11s setzen. Ich denke ich hab den Fehler gefunden.
                    • afuerhoff
                      afuerhoff Developer @Guest last edited by
                      @ilovegym sagte in Test Adapter fb-checkpresence v1.1.x:
                      🙂 Muss mich mal informieren wie hier die Abgabenlage so ist. Da möchte doch bestimmt das Finanzamt beteiligt werden.
                      • afuerhoff
                        afuerhoff Developer @Dominik F. last edited by
                        @Dominik-F sagte in Test Adapter fb-checkpresence v1.1.x:
                        Bis jetzt ist das noch nicht vorgesehen. Für die presence Datenpunkte könnte ich das aber erstmal so einbauen. Die 1.1.1 ist ja noch nicht kpl. fertig.
                        Dominik F. 2 Replies Last reply Reply Quote 1
                          @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
                          Wenn man dir Spendet, weniger.. 🙂 Ansonsten gibt da nur genaue Auskunft dein Steuerberater, kommt drauf an, was du alles so machst und Einkünfte hast.. 🙂
                          • Dominik F.
                            @afuerhoff
                            Das wäre klasse, vielen lieben dank
                              Flo1988 @afuerhoff last edited by
                              Funktioniert!
                              Habe den Intervall auf 11 Sekunden gestellt und die Geräte werden wieder zuverlässig erkannt.
                              Ich lasse es erstmal so, wenn es eine neue Version zum Testen gibt, bitte schreiben, dann kann ich schauen ob es auch bei mir mit 10 Sekunden wieder geht.
                              Verwunderlich, dass ich der einzige bin, bei dem der Fehler auftritt... 😕
                              • Dominik F.
                                @afuerhoff
                                Ich hätte noch einen Wunsch für deinen Adapter.
                                Einen Datenpunkt, wo gezählt wird wie viele gerade Anwesend sind.
                                • afuerhoff
                                  @Dominik-F
                                  Kein Problem
                                  • Fenriswolf
                                    Fenriswolf last edited by
                                    Ich habe immernoch sehr regelmäßig das Problem, das die Verbindung verloren geht.
                                    2021-01-11 17:04:17.805 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                                    2021-01-11 17:06:00.798 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                                    2021-01-11 17:06:00.799 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                                    2021-01-11 17:07:44.017 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                                    2021-01-11 17:07:44.018 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                                    2021-01-11 17:09:26.365 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                                    2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                                    2021-01-11 17:11:09.171 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                                    2021-01-11 17:11:09.172 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                                    Was mich aber bei genauerer Betrachtung viel mehr verwirrt, ist der Punkt
                                    2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: ...... "urn:dslforum-org:service:Hosts:1\"},.........
                                    Was hat das DSL-Forum damit zu tun ??
                                    bis denne
                                    afuerhoff 2 Replies Last reply Reply Quote 0
                                    • afuerhoff
                                      afuerhoff Developer @Fenriswolf last edited by
                                      @Fenriswolf sagte in Test Adapter fb-checkpresence v1.1.x:
                                      dslforum-org
                                      Du kannst ja mal diese Url bei Dir eingeben: http://fritz.box:49000/tr64desc.xml
                                      Dann sollte als erstes diese Zeile kommen: <root xmlns="urn:dslforum-org:device-1-0">
                                      Das hat mit dem TR-064 Standard zu tun.
                                      Fenriswolf 1 Reply Last reply Reply Quote 0
                                      • Fenriswolf
                                        Fenriswolf @afuerhoff last edited by
                                        dslforum-org
                                        OK 😉 danke für die schnelle Antwort
                                        • afuerhoff
                                          @Fenriswolf
                                          Bzgl. Fehlermeldungen habe ich bei mir jetzt kaum noch welche. Evtl. hilft der neuste Adapterstand. Ist aber noch nicht auf Github hochgeladen.
                                          • Fenriswolf
                                            @Fenriswolf
                                            Habe bei mir jetzt mal die Intervallzeit bei den Haupteinstellungen hochgesetzt. Nachdem ich gesehen habe, das es nur für die Device-Suche ist und nicht für die Mitgliedererkennung.
                                            Hatte da wohl noch ein Problem in meinen eigenen Hirnwindungen.
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            256173
