    4. JavaScript
    5. TV Programm Mini Anzeige - HTML Tabelle
    • Stephan Schleich
      Stephan Schleich @JayR last edited by
      @JayR Magst du das Script mit uns teilen? Jarvis ist ja ziemlich im kommen
      JayR 1 Reply Last reply Reply Quote 0
      • JayR
        JayR @Stephan Schleich last edited by JayR
        @Stephan-Schleich :
        Ganz unten im Script muss in den CONF_CUSTOM noch der Pfad eingefügt werden:
        "path" : "value"
         * Created: 04.12.2020
         * Created by: JayR / liv-in-sky
         * Description: Get tv program
         * Notes:
         * Source: https://forum.iobroker.net/topic/28447/tv-programm-mini-anzeige-html-tabelle
         * ToDo: nothing
         * Version: 1.1
         * Changes: 1.0 - Initial creation
         * 12.12.20 1.1 - Change trigger
         * Configuration
        const LOGGING = true;   //if(LOGGING)   log('');
        const VERBOSE = false;  //if(LOGGING && VERBOSE)    log('');
        var channels = ["Das Erste", "ZDF", "SWR", "Sat.1", "RTL", "RTL Zwei", "Sky Sport News", "ProSieben", "SPORT1", "VOX",  "kabel eins", "ZDFneo", "n-tv"];
        const CONF_CUSTOM = buildConfigObject();
        const STATES = createCustomStates();
        let returnVal;
         * Start/Init
         getTvProgram();
         * Functions
        function getTvProgram(){
            let url = getProgramUrl();
            getTV(url).then(function() {
                returnVal.forEach(function(channel) {
                    log(channel);
                    setState(CONF_CUSTOM.path + "tv." + channel[1].replace(" ","").replace(" ","").replace(".","") + ".time", channel[0]);
                    setState(CONF_CUSTOM.path + "tv." + channel[1].replace(" ","").replace(" ","").replace(".","") + ".program", channel[2].substr(0, channel[2].length-2));
                    setState(CONF_CUSTOM.path + "tv." + channel[1].replace(" ","").replace(" ","").replace(".","") + ".name", channel[1]);
         async function getTV(url) {
             return new Promise(async (resolve, reject) => {
                 await request(url, async function(error, response, result) {
                    resolvHtml(result);
                     if (result != "") {
                         resolve()
                     } else {
                         reject()
                 }).on("error", function(e) {
                     console.error(e);
        async function resolvHtml(gesuchtVal) {
            var re = /\s<a title=".+?" name="bid_/g;
            let found = "fff" + gesuchtVal.match(re);
            let helper = found.match(/\".+?" name="bid_/g);
            let helper2 = [];
            for (var i = 0; i < helper.length; i++) {
                let hhh = helper[i].replace(/,/g, " --");
                hhh = hhh.replace(/\'/g, " ");
                hhh = hhh.replace(/ (\d\d):(\d\d) /g, " $1\-\-\-$2");
                hhh = hhh.replace(/\:/g, ";");
                hhh = hhh.replace(/(\d\d)---(\d\d)/g, " $1:$2 ");
                hhh = hhh.replace(/www\..+\/tv-pro/g, "tv-pro");
                hhh = hhh.replace(/(\d\d\.\d\d\..+)\.(.+)\" data/g, "$1x_y_x$2 data"); //ersetzt punkt in sendernamen (sat.1)
                hhh = hhh.replace(/(^.+?)\.+(.+?\d\d\.\d\d\.)/g, "$1x_x_x$2"); //ersetzt punkte im datum
                hhh = hhh.replace(/\*/g, "_");
                hhh = hhh.replace(/ data.+programm(.+)/g, "bbb$1");
                helper2.push(hhh)
            var htmlArray = helper2.toString().split(",");
            var helpArray = [];
            var helpArray1 = [];
            var helpArray2 = [];
            for (var i = 0; i < htmlArray.length; i++) {
                var haken = htmlArray[i].replace(/,>/g, "");
                helpArray.push(haken);
             } // /,>/g , ""
             for (var i = 0; i < helpArray.length; i++) {
                var haken = helpArray[i].replace("xxx", "");
                helpArray1.push(haken);
             } // /,>/g , ""
             for (var i = 0; i < helpArray1.length; i++) {
                var haken = helpArray1[i].replace(/\"/g, "");
                helpArray2.push(haken);
                if (i < 0) log(helpArray2[i])
             } // /,>/g , ""
            let resultObj = [];
            for (var i = 0; i < helpArray2.length; i++) {
                let val4help = helpArray2[i].slice(((helpArray2[i].indexOf('bbb') + 1 + 3) - 1), helpArray2[i].length);
                val4help = val4help.replace(/ name=bid_/g, "");
                if (i < 0) log(val4help)
                let val3 = helpArray2[i].slice(0, (helpArray2[i].indexOf(':') + 1) - 5).trim();
                val3 = val3.replace(/x_x_x/g, ".");
                val3 = val3.replace(/x_y_x/g, ".") // val3=val3.slice(0, (val3.lastIndexOf('-') + 1) - 1);   // sendung
                let val2 = helpArray2[i].slice(((helpArray2[i].lastIndexOf('.') + 1 + 1) - 1), helpArray2[i].length).trim();
                val2 = val2.replace(/bbb.+/g, "");;
                if (i < 0) log(val2);
                val2 = val2.replace(/x_x_x/g, ".");
                val2 = val2.replace(/x_y_x/g, ".") // sender
                let val1 = helpArray2[i].slice((((helpArray2[i].lastIndexOf(':') + 1) - 2) - 1), helpArray2[i].indexOf(':') + 1 + 2).trim(); // uhrzeit
                resultObj.push([val1, val2, val3, val4help]);
            let myObjFilter = [];
            for (var b = 0; b < resultObj.length; b++) {
                if (channels.includes(resultObj[b][1].trim()) && resultObj[b][1].trim() != "") {
                    myObjFilter.push(resultObj[b]);
                } else {
            let myObjFilterHelp = [];
            let bevore;
            for (var b = 0; b < myObjFilter.length; b++) {
                if (myObjFilter[b][1] != bevore) {
                    myObjFilterHelp.push(myObjFilter[b]);
                    bevore = myObjFilter[b][1]
                } else {}
            returnVal = myObjFilterHelp;
        function getProgramUrl(){
            let programTime = parseInt(getState(CONF_CUSTOM.path + 'tv.programTime').val);
            let url;
            if(programTime == 1) url = 'https://www.hoerzu.de/tv-programm/jetzt/';
            else if (programTime == 2){
                let houre = new Date();
                let time;
                if(houre.getHours() == 23){
                    time = "00";
                    url = "https://www.hoerzu.de/tv-programm/morgen/";
                }else{
                    time = (houre.getHours() + 1).toString();
                    url = "https://www.hoerzu.de/tv-programm/heute/"
                if(houre.getMinutes() >= 0 && houre.getMinutes() < 30) time = time + ":30";
                else time = time = time + ":00";
                url = url + time + "/";
            else if (programTime == 3) url = 'https://www.hoerzu.de/tv-programm/heute/20:30/';
            else if (programTime == 4) url = 'https://www.hoerzu.de/tv-programm/heute/22:30/';
            return url;
         * Trigger
         on({
           id: CONF_CUSTOM.path + 'tv.programTime',
           change: 'any'
        }, function(obj) {
            getTvProgram();
        schedule('*/30 * * * *', function() {
            getTvProgram();
         * Create States
        function createCustomStates() {
            var customStates =
                    "name" : 'tv.programTime',
                    "path" : CONF_CUSTOM.path
            channels.forEach(function(channel) {
                customStates.push(
                    "name" : 'tv.' + channel.replace(" ","").replace(" ","").replace(".","") + ".time",
                customStates.push(
                    "name" : 'tv.' + channel.replace(" ","").replace(" ","").replace(".","") + ".program",
                customStates.push(
                    "name" : 'tv.' + channel.replace(" ","").replace(" ","").replace(".","") + ".name",
            createStates(customStates);
            return customStates;
         * Config
        function buildConfigObject(){
            var configObj = JSON.stringify(
                    "path" : "value",
            return JSON.parse(configObj);
         * End
        In Jarvis kann dann noch eine Aktion hinzugefügt werden um direkt auf den Sender umzuschalten.
        L A 2 Replies Last reply Reply Quote 1
          Lutzy79 @JayR last edited by
          @JayR sagte in TV Programm Mini Anzeige - HTML Tabelle:
          @Stephan-Schleich :
          "path" : "value"
           * Notes:
           * ToDo: nothing
           * Version: 1.1
           * Configuration
          let returnVal;
           * Start/Init
           getTvProgram();
           * Functions
                      log(channel);
                      resolvHtml(result);
                       if (result != "") {
                           resolve()
                       } else {
                           reject()
                       console.error(e);
              let helper2 = [];
                  helper2.push(hhh)
              var helpArray = [];
               } // /,>/g , ""
               } // /,>/g , ""
               } // /,>/g , ""
              let resultObj = [];
                  } else {
              let bevore;
                  } else {}
              let url;
                  let time;
                      time = "00";
                  }else{
              return url;
           * Trigger
           on({
             change: 'any'
          }, function(obj) {
              getTvProgram();
              getTvProgram();
           * Create States
              var customStates =
                  customStates.push(
                  customStates.push(
                  customStates.push(
           * Config
                      "path" : "value",
           * End
          Finde die Idee und die Umsetzung über Jarvis die Sender umzuschalten von dir echt klasse. Kannst du bitte kurz beschreiben, wie du das gemacht hast?
          Ich verstehe leider nicht genau, was ich in deinem Script als Pfad eingeben muss und an welcher Stelle genau. Vielleicht könntest du das genauer erklären, evtl mit Beispiel?
          Vielen Dank schon mal
          • JayR
            JayR @Lutzy79 last edited by
            @Lutzy79 : Ich habe das Ganze über den Harmonyadapter realisiert.
            Ich habe die TV Programme dargestellt und hab in dem Menü ein Button eingebaut mit dem ich umschalten kann.
            Im Hintergrund läuft ein Script was z.B. Sender1 in Nummer 0 + 0 + 0 + 1 übersetzt und das so in Harmony auswählt.
              Acidburn78 @JayR last edited by
              @JayR Hallo JayR wie muss ich den Pfad angeben? "0_userdata.0" z.B.? Und ich bekomme beim ausführen des Scripts immer den Fehler "ReferenceError: createStates is not defined"
              • JayR
                JayR @Acidburn78 last edited by JayR
                @Acidburn78 said in TV Programm Mini Anzeige - HTML Tabelle:
                 * Notes:
                 * ToDo: nothing
                 * Version: 1.1
                 * Configuration
                let returnVal;
                 * Start/Init
                 getTvProgram();
                 * Functions
                            log(channel);
                            resolvHtml(result);
                             if (result != "") {
                                 resolve()
                             } else {
                                 reject()
                             console.error(e);
                    let helper2 = [];
                        helper2.push(hhh)
                    var helpArray = [];
                     } // /,>/g , ""
                     } // /,>/g , ""
                     } // /,>/g , ""
                    let resultObj = [];
                        } else {
                    let bevore;
                        } else {}
                    let url;
                        let time;
                            time = "00";
                        }else{
                    return url;
                 * Trigger
                 on({
                   change: 'any'
                }, function(obj) {
                    getTvProgram();
                    getTvProgram();
                 * Create States
                    var customStates =
                        customStates.push(
                        customStates.push(
                        customStates.push(
                function createStates(states){
                    states.forEach(function(state) {
                        var objId = state.path + state.name;
                        if(!getObject(objId)) {
                            createState(objId);
                 * Config
                            "path" : "value",
                 * End
                @Acidburn78: Kannst du diese Version nochmal testen.
                Den Pfad wo die Werte angelegt werden sollen z.B. "0_userdata.0." oder "0_userdata.0.tv."
                Kannst du bitte mal testen und mit feedback geben.
                A L 2 Replies Last reply Reply Quote 0
                  Acidburn78 @JayR last edited by Acidburn78
                  @JayR said in TV Programm Mini Anzeige - HTML Tabelle:
                  0_userdata.0.tv.
                  wunderbar jetzt werden die States angelegt aber ich bekomme jetzt folgende Fehlermeldungen
                  javascript.0	2021-01-07 14:04:10.922	error	(3492) at Script.runInContext (vm.js:130:18)
                  javascript.0	2021-01-07 14:04:10.922	error	(3492) at script.js.Skript_1:225:3
                  javascript.0	2021-01-07 14:04:10.922	error	(3492) at script.js.Skript_1:26:2
                  javascript.0	2021-01-07 14:04:10.922	error	(3492) at getTvProgram (script.js.Skript_1:31:15)
                  javascript.0	2021-01-07 14:04:10.921	error	(3492) at getProgramUrl (script.js.Skript_1:128:77)
                  javascript.0	2021-01-07 14:04:10.921	error	(3492) script.js.Skript_1: TypeError: Cannot read property 'val' of undefined
                  javascript.0	2021-01-07 14:04:10.919	info	(3492) script.js.Skript_1: registered 0 subscriptions and 0 schedules
                  javascript.0	2021-01-07 14:04:10.919	error	(3492) script.js.Skript_1: Please disable that setting or use "getState" with a callback, e.g.: getState("0_userdata.0.tv.tv.programTime", (err, state) => { ... });
                  javascript.0	2021-01-07 14:04:10.918	error	(3492) script.js.Skript_1: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
                  javascript.0	2021-01-07 14:04:10.912	info	(3492) Start javascript script.js.Skript_1
                  Sorry die Meldung ist die die jetzt immer kommt
                    brauche ich für Javascript eventuell noch weitere Module?
                    • JayR
                      @Acidburn78: Setzt mal das Value 1 in den State: 0_userdata.0.tv.tv.programTime
                        @JayR Danke hatte es gerade herausgefunden 🙂 jetzt funktioniert es
                           * Notes:
                           * ToDo: nothing
                           * Version: 1.1
                           * Configuration
                          let returnVal;
                           * Start/Init
                           getTvProgram();
                           * Functions
                                      log(channel);
                                      resolvHtml(result);
                                       if (result != "") {
                                           resolve()
                                       } else {
                                           reject()
                                       console.error(e);
                              let helper2 = [];
                                  helper2.push(hhh)
                              var helpArray = [];
                               } // /,>/g , ""
                               } // /,>/g , ""
                               } // /,>/g , ""
                              let resultObj = [];
                                  } else {
                              let bevore;
                                  } else {}
                              let url;
                                  let time;
                                      time = "00";
                                  }else{
                              return url;
                           * Trigger
                           on({
                             change: 'any'
                          }, function(obj) {
                              getTvProgram();
                              getTvProgram();
                           * Create States
                              var customStates =
                                  customStates.push(
                                  customStates.push(
                                  customStates.push(
                                      createState(objId);
                           * Config
                                      "path" : "value",
                           * End
                          Kann mir jemand kurz erklären, wo (in welcher Zeile) ich den pfad in dem Script von JayR eintragen muss? Ich komme einfach nicht drauf 😞
                          Danke!
                          • JayR
                            @Lutzy79 : Ganz unten in den Configs
                              sorry, bin da echt ein Anfänger. Wenn ich in Zeile 431 statt "path" : "value", einfach 0_userdata.0.tv. eintrage, bekomme ich ein "compile error" im log
                                Lutzy79 @Lutzy79 last edited by
                                @Lutzy79 sagte in TV Programm Mini Anzeige - HTML Tabelle:
                                Danke, hab´s doch noch hinbekommen, hab anscheinend den Punkt am Ende vergessen
                                • JayR
                                  @Lutzy79 : Genau der Pfad muss mit . enden. Ist etwas versteckt habe in allen meiner Scripte die Struktur und beziehe normalerweise die Pfade aus einem Config JSON. Hab es etwas umgeschrieben, dass es auch für andere passt.
                                  • Latzi
                                    Latzi last edited by
                                    @liv-in-sky
                                    ich hab heute die Script-Engine auf den neuesten Stand gebracht (Version 4.10.9) und dabei folgende Meldung erhalten:
                                    2021-01-17 05:24:35.397 - error: javascript.0 (2098) WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                    Nach gründlicher Suche bin ich auf dein Script gestoßen, darin wird request-promise-native verwendet.
                                    Gibt es hier Grund zur Sorge oder kann ich die Meldung ignorieren?
                                    mikeal created this issue in request/request
                                    open Request’s Past, Present and Future #3142
                                      liv-in-sky @Latzi last edited by
                                      @latzi ist kein problem - wird einfach nicht mehr weiterentwickelt - daher deprecated - ist aber anwendbar
                                      es gibt ja jetzt eh einen neuen adapter, da ist es fraglich, ob diese scriptreihe weiterentwickelt wird oder geändert, wenn hoerzu mal was ändert
                                      Latzi 1 Reply Last reply Reply Quote 2
                                      • Latzi
                                        Latzi @liv-in-sky last edited by
                                        @liv-in-sky
                                        sehr gut 👏
                                        Es ist eins meiner Lieblingsscripte und möchte es äußerst ungern missen!
                                        Hoffentlich hat hoerzu anderes zu tun und belässt es so wie es ist 😄
                                        Vielen Dank nochmal für deine genialen Entwicklungen 👍 👏
                                        • Salzer Michael
                                          Salzer Michael last edited by
                                          @liv-in-sky
                                          Hello
                                          Altes Thema altes Script aber das beste was bisher für EPG gab.
                                          Leider seit seit ner Woche
                                          3:40:00.692 error javascript.0 (26951) script.js.common.EPG.EPG: TypeError: Cannot read property 'split' of null
                                          23:40:00.693 error javascript.0 (26951) at script.js.common.EPG.EPG:226:60
                                          Gibts da abhilfe oder Infos dazu ?
                                            liv-in-sky @Salzer Michael last edited by
                                            @salzer-michael
                                            Kannst du mir sagen welches Script genau
                                            Du kannst auch gerne dein Script hier posten
                                            javascript
                                            20
                                            327
                                            48914
