    4. Test Adapter fb-checkpresence v1.1.x
      Flo1988 @Flo1988 last edited by
      @Flo1988 sagte in Test Adapter fb-checkpresence v1.1.x:
      @afuerhoff
      Sry.
      node wurde auf 12.20.0 geupdated.
      Läuft trotzdem nicht.
      WLAN wurde während dem log bei "Florian" deaktiviert aber passiert nix.
      fb-checkpresence.0	2020-12-29 20:11:21.928	debug	(4210) loopDevices ends after 2,157899582 s
      fb-checkpresence.0	2020-12-29 20:11:21.924	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
      fb-checkpresence.0	2020-12-29 20:11:21.778	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
      fb-checkpresence.0	2020-12-29 20:11:21.662	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
      fb-checkpresence.0	2020-12-29 20:10:19.702	debug	(4210) loopDevices ends after 1,441445027 s
      fb-checkpresence.0	2020-12-29 20:10:19.700	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
      fb-checkpresence.0	2020-12-29 20:10:19.615	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
      fb-checkpresence.0	2020-12-29 20:10:19.546	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
      fb-checkpresence.0	2020-12-29 20:10:13.252	info	(4210) createFbDeviceObjects finished successfully
      fb-checkpresence.0	2020-12-29 20:10:04.787	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
      fb-checkpresence.0	2020-12-29 20:10:03.789	info	(4210) createMemberObjects finished successfully
      fb-checkpresence.0	2020-12-29 20:10:03.788	debug	(4210) enableHistory.2 Silke true
      fb-checkpresence.0	2020-12-29 20:10:03.762	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-12-29 20:10:03.752	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-12-29 20:10:03.625	debug	(4210) enableHistory.2 Florian true
      fb-checkpresence.0	2020-12-29 20:10:03.597	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-12-29 20:10:03.584	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2020-12-29 20:10:03.454	info	(4210) createGlobalObjects finished successfully
      fb-checkpresence.0	2020-12-29 20:10:03.085	info	(4210) service DeviceConfig1-Reboot is supported
      fb-checkpresence.0	2020-12-29 20:10:03.064	info	(4210) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
      fb-checkpresence.0	2020-12-29 20:10:02.952	info	(4210) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
      fb-checkpresence.0	2020-12-29 20:10:02.938	info	(4210) service DeviceInfo1-GetInfo is supported
      fb-checkpresence.0	2020-12-29 20:10:02.919	info	(4210) service WLANConfiguration3-GetInfo is supported
      fb-checkpresence.0	2020-12-29 20:10:02.903	info	(4210) service WLANConfiguration3-SetEnable is supported
      fb-checkpresence.0	2020-12-29 20:10:02.886	info	(4210) service WANPPPConnection1-GetInfo is supported
      fb-checkpresence.0	2020-12-29 20:10:02.869	info	(4210) service DeviceInfo1-GetSecurityPort is supported
      fb-checkpresence.0	2020-12-29 20:10:02.853	info	(4210) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
      fb-checkpresence.0	2020-12-29 20:10:02.834	info	(4210) service Hosts1-GetSpecificHostEntry is supported
      fb-checkpresence.0	2020-12-29 20:10:02.820	info	(4210) service Hosts1-X_AVM-DE_GetMeshListPath is supported
      fb-checkpresence.0	2020-12-29 20:10:02.802	info	(4210) service Hosts1-X_AVM-DE_GetHostListPath is supported
      fb-checkpresence.0	2020-12-29 20:10:02.787	debug	(4210) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
      fb-checkpresence.0	2020-12-29 20:10:02.756	debug	(4210) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"226","Major":"154","Minor":"7","Patch":"21","Buil
      fb-checkpresence.0	2020-12-29 20:10:02.498	debug	(4210) configuratuion mesh info: false
      fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration fb-devices true
      fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration familymembers: [{"familymember":"Florian","macaddress":"A0:FB:C5:21:AC:7B","ipaddress":"192.168.155.86","useip":false,"comment":"iPhone12pro","enabled":true},{"familymember":"Silk
      fb-checkpresence.0	2020-12-29 20:10:02.496	debug	(4210) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
      fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration history: <influxdb.0>
      fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration user: <ioBroker_tr064>
      fb-checkpresence.0	2020-12-29 20:10:02.493	info	(4210) start fb-checkpresence: ip-address: "192.168.155.1" - interval devices: 1 Min. - interval members: 10 s
      fb-checkpresence.0	2020-12-29 20:10:02.451	info	(4210) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
      fb-checkpresence.0	2020-12-29 20:09:56.390	info	(4147) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      fb-checkpresence.0	2020-12-29 20:09:56.388	info	(4147) terminating
      fb-checkpresence.0	2020-12-29 20:09:56.386	info	(4147) cleaned everything up ...
      fb-checkpresence.0	2020-12-29 20:09:56.384	info	(4147) Got terminate signal TERMINATE_YOURSELF
      Gibt es hier schon eine Idee, warum die Geräte nicht richtig erkannt werden?
      In der FritzBox werden sie korrekt als aktiv und inaktiv angezeigt.
      Bis Version 1.0.4 hat auch alles prima funktioniert.
      Der Fehler hat sich mit der Änderung auf 1.1.0 eingeschlichen.
      afuerhoff 1 Reply Last reply Reply Quote 0
      • Pedder007
        Pedder007 @Pedder007 last edited by
        An der Stelle nochmal kurz ein Feedback nach nun gut einer Woche Laufzeit nach dem Update.
        Keinerlei veraltete oder verwechselte Einträge mehr, Adapter läuft super stabil und sogar die Familie ist nun in der Lage zu sehen wo sie ggf. gerade am WLAN "hängen" und ggf. via VIS einzelne (Fritz) NW-Devices neu zu booten, sofern diese überhaupt noch erreichbar sind - sonst hilft natürlich nur Stecker ziehen 😉
        Danke nochmal, dass erleichtert einem wirklich das Leben und reduziert meine persönlichen Tickets zum Thema "Papa das WLAN geht wieder nicht...." 😆 drastisch! 👍 👍 👍
          A Former User @afuerhoff last edited by
          @afuerhoff hab noch was entdeckt, was Du vielleicht gerne nachrüsten kannst... 🙂
          Einen DONATE 💰 Button in der Adapterkonfig, damits auch jeder sieht..
          afuerhoff 1 Reply Last reply Reply Quote 1
          • Dominik F.
            Dominik F. @afuerhoff last edited by
            @afuerhoff
            Nabend,
            ich nutze deinen Adapter in der Version 1.10 und der funktioniert auch sehr zuverlässig.
            Nun habe ich festgestellt, dass der Heatingcontrol Adapter ständig neu getriggert wird.
            Ich nutze dort einen Datenpunkt von deinem Adapter. Das Problem scheint zu sein, dass dein Adapter den Datenpunkt für Presence minütlich neu setzt auch wenn dieser sich nicht ändert.
            Gibt es eine Möglichkeit, oder ist es vielleicht schon in der neuen Version enthalten, dass die Datenpunkte nur bei Änderung neu gesetzt werden?
            • afuerhoff
              afuerhoff Developer @Flo1988 last edited by
              Es sieht so aus, als ob die Routine für die Familienmitglieder gar nicht durchlaufen wird.
              Da müsste eigentlich eine Meldung im Log kommen.
              Kannst Du mal das Interval auf 11s setzen. Ich denke ich hab den Fehler gefunden.
              • afuerhoff
                afuerhoff Developer @Guest last edited by
                @ilovegym sagte in Test Adapter fb-checkpresence v1.1.x:
                🙂 Muss mich mal informieren wie hier die Abgabenlage so ist. Da möchte doch bestimmt das Finanzamt beteiligt werden.
                • afuerhoff
                  afuerhoff Developer @Dominik F. last edited by
                  @Dominik-F sagte in Test Adapter fb-checkpresence v1.1.x:
                  Bis jetzt ist das noch nicht vorgesehen. Für die presence Datenpunkte könnte ich das aber erstmal so einbauen. Die 1.1.1 ist ja noch nicht kpl. fertig.
                  Dominik F. 2 Replies Last reply Reply Quote 1
                    @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
                    Wenn man dir Spendet, weniger.. 🙂 Ansonsten gibt da nur genaue Auskunft dein Steuerberater, kommt drauf an, was du alles so machst und Einkünfte hast.. 🙂
                    • Dominik F.
                      @afuerhoff
                      Das wäre klasse, vielen lieben dank
                        Flo1988 @afuerhoff last edited by
                        Funktioniert!
                        Habe den Intervall auf 11 Sekunden gestellt und die Geräte werden wieder zuverlässig erkannt.
                        Ich lasse es erstmal so, wenn es eine neue Version zum Testen gibt, bitte schreiben, dann kann ich schauen ob es auch bei mir mit 10 Sekunden wieder geht.
                        Verwunderlich, dass ich der einzige bin, bei dem der Fehler auftritt... 😕
                        • Dominik F.
                          @afuerhoff
                          Ich hätte noch einen Wunsch für deinen Adapter.
                          Einen Datenpunkt, wo gezählt wird wie viele gerade Anwesend sind.
                          • afuerhoff
                            @Dominik-F
                            Kein Problem
                            • Fenriswolf
                              Fenriswolf last edited by
                              Ich habe immernoch sehr regelmäßig das Problem, das die Verbindung verloren geht.
                              2021-01-11 17:04:17.805 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                              2021-01-11 17:06:00.798 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                              2021-01-11 17:06:00.799 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                              2021-01-11 17:07:44.017 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                              2021-01-11 17:07:44.018 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                              2021-01-11 17:09:26.365 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                              2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                              2021-01-11 17:11:09.171 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                              2021-01-11 17:11:09.172 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                              Was mich aber bei genauerer Betrachtung viel mehr verwirrt, ist der Punkt
                              2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: ...... "urn:dslforum-org:service:Hosts:1\"},.........
                              Was hat das DSL-Forum damit zu tun ??
                              bis denne
                              afuerhoff 2 Replies Last reply Reply Quote 0
                              • afuerhoff
                                afuerhoff Developer @Fenriswolf last edited by
                                @Fenriswolf sagte in Test Adapter fb-checkpresence v1.1.x:
                                dslforum-org
                                Du kannst ja mal diese Url bei Dir eingeben: http://fritz.box:49000/tr64desc.xml
                                Dann sollte als erstes diese Zeile kommen: <root xmlns="urn:dslforum-org:device-1-0">
                                Das hat mit dem TR-064 Standard zu tun.
                                Fenriswolf 1 Reply Last reply Reply Quote 0
                                • Fenriswolf
                                  Fenriswolf @afuerhoff last edited by
                                  dslforum-org
                                  OK 😉 danke für die schnelle Antwort
                                  • afuerhoff
                                    @Fenriswolf
                                    Bzgl. Fehlermeldungen habe ich bei mir jetzt kaum noch welche. Evtl. hilft der neuste Adapterstand. Ist aber noch nicht auf Github hochgeladen.
                                    • Fenriswolf
                                      @Fenriswolf
                                      Habe bei mir jetzt mal die Intervallzeit bei den Haupteinstellungen hochgesetzt. Nachdem ich gesehen habe, das es nur für die Device-Suche ist und nicht für die Mitgliedererkennung.
                                      Hatte da wohl noch ein Problem in meinen eigenen Hirnwindungen.
                                      • afuerhoff
                                        Die Meshdaten werden nur wenn angehakt geladen und im gleichen Intervall aktulisiert wie die
                                        Fb-Devicedaten.
                                        • TG70
                                          TG70 Forum Testing @afuerhoff last edited by
                                          @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
                                          @TG70
                                          Du brauchst die Fritzbox Version 7.20 damit es schneller geht.
                                          Also ich bin jetzt auf der Fritz! 7.23 ... Allerdings merke ich nichts davon, dass die Erkennung schneller geht.
                                          Den Zustand "Offline" wird mir erst nach ca. 10 Minuten angezeigt? Wie lange dauert es bei euch mit der Erkennung der Zustände "Online" und "Offline"
                                          • afuerhoff
                                            afuerhoff Developer @TG70 last edited by afuerhoff
                                            @TG70
                                            Wie ist denn die Intervalleinstellung für Familienmitglieder?
                                            EDIT: Bei mir dauert es mit der Version 7.21 (Intervall 10s) max. 20-30 s.
                                            TG70 1 Reply Last reply Reply Quote 0
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            256233
