    4. JavaScript
    5. [gelöst]Datenpunkt aus Json in CCU2 Variable schreiben?
      chemieka last edited by chemieka
      Ich habe eine Tabelle und möchte das Erste Datum und Uhrzeit in eine CCU2 Variable schreiben.
      Ich hab zwar schon mit Blocky gearbeitet aber hier bleibe ich hängen.
      Der Inhalt der Tabelle (liegt als Objekt vor) schaut dabei so aus:
      [{"Datum":"7.1","Start":"16:17","Saugzeit":"11 min","Fläche":"12.37 m²","Error":0,"Ende":true},{"Datum":"7.1","Start":"16:14","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"7.1","Start":"15:49","Saugzeit":"12 min","Fläche":"7.63 m²","Error":0,"Ende":true},{"Datum":"6.1","Start":"07:00","Saugzeit":"8 min","Fläche":"14.64 m²","Error":0,"Ende":false},{"Datum":"4.1","Start":"07:00","Saugzeit":"44 min","Fläche":"46.37 m²","Error":0,"Ende":true},{"Datum":"1.1","Start":"07:00","Saugzeit":"46 min","Fläche":"51.15 m²","Error":0,"Ende":true},{"Datum":"30.12","Start":"12:14","Saugzeit":"57 min","Fläche":"54.34 m²","Error":0,"Ende":true},{"Datum":"28.12","Start":"11:21","Saugzeit":"52 min","Fläche":"55.09 m²","Error":0,"Ende":true},{"Datum":"28.12","Start":"11:04","Saugzeit":"16 min","Fläche":"3.99 m²","Error":0,"Ende":false},{"Datum":"26.12","Start":"07:00","Saugzeit":"9 min","Fläche":"13.21 m²","Error":8,"Ende":false},{"Datum":"24.12","Start":"07:00","Saugzeit":"25 min","Fläche":"27.49 m²","Error":0,"Ende":true},{"Datum":"23.12","Start":"16:58","Saugzeit":"38 min","Fläche":"35.17 m²","Error":0,"Ende":true},{"Datum":"23.12","Start":"11:24","Saugzeit":"54 min","Fläche":"57.24 m²","Error":0,"Ende":true},{"Datum":"21.12","Start":"07:00","Saugzeit":"49 min","Fläche":"53.05 m²","Error":0,"Ende":true},{"Datum":"19.12","Start":"07:00","Saugzeit":"44 min","Fläche":"46.46 m²","Error":0,"Ende":true},{"Datum":"17.12","Start":"07:00","Saugzeit":"59 min","Fläche":"52.08 m²","Error":0,"Ende":true},{"Datum":"14.12","Start":"07:00","Saugzeit":"45 min","Fläche":"49.58 m²","Error":0,"Ende":true},{"Datum":"12.12","Start":"11:58","Saugzeit":"43 min","Fläche":"25.72 m²","Error":0,"Ende":true},{"Datum":"12.12","Start":"11:53","Saugzeit":"3 min","Fläche":"1.91 m²","Error":0,"Ende":true},{"Datum":"12.12","Start":"11:29","Saugzeit":"24 min","Fläche":"13.2 m²","Error":0,"Ende":false}]
      Vielen Dank für die Unterstützung.
        paul53 @chemieka last edited by paul53
        @chemieka sagte:
        let obj = JSON.parse(json)[0];
        setState(idSV, obj.Datum + '. ' + obj.Start);
          chemieka @paul53 last edited by
          Das schaut so einfach aus aber wo muss ich rein schreiben aus welchen Adapter und Objekt er die Daten nehmen soll und wo sie wieder hin sollen?
          Wie gesagt ich bekomme maximal Blocky etwas selber hin. Bei einem richtigen Script müsstest du weiter ausholen bitte.
            @chemieka sagte:
            Du hast nicht geschrieben: Wo. In einem Datenpunkt ?
              die Tabelle liegt im Adapter mihome-vacuum.0.history.allTableJSON
              und soll in eine Variable hm-rega.0.7466
                @chemieka
                Neues Script erstellen (Javascript-Instanz):
                const idJson = 'mihome-vacuum.0.history.allTableJSON';
                const idSV   = 'hm-rega.0.7466';
                function json2sv(json) {
                json2sv(getState(idJson).val); // Script start
                on(idJson, function(dp) { // Wertänderung
                   json2sv(dp.state.val);
                  @paul53 sagte in Datenpunkt aus Json Tabelle in CCU2 Variable schreiben?:
                  const idJson = 'mihome-vacuum.0.history.allTableJSON'; const idSV = 'hm-rega.0.7466'; function json2sv(json) { let obj = JSON.parse(json)[0]; setState(idSV, obj.Datum + '. ' + obj.Start); } json2sv(getState(idJson).val); // Script start on(idJson, function(dp) { // Wertänderung json2sv(dp.state.val); });
                  OK das habe ich. Wie könnte ich es starten lassen? Tägliche Timer?
                    @chemieka sagte:
                    Nein, das Script aktivieren und schon geht es los: Einmal bei Start und dann wird bei jeder Änderung des JSON-Inhalts getriggert.
                      Das ist ja Klasse die Daten sind in der Variable.
                      Also ehrlich mir ist das ein Rätzel, ihr seit Künstler.
                      Vielen Dank.😁
