    5. [Gelöst] Rolladen mit Blockly Script steuern
      paul53 @paul53 last edited by
      @paul53 sagte:
      Du musst noch Astro-Trigger (SA und SU) einsetzen.
       <variables>
         <variable id="*@#O`4um.(3hbA:(zHv7">rollos</variable>
         <variable id="/!l]R_6qje~AC4QCtkJt">Tuer_geschlossen</variable>
         <variable id=")z%f,tXn?!GbC|5$y{mm">rollo</variable>
       </variables>
       <block type="procedures_defnoreturn" id=",yKUl=3lGi+KjS5=;_Y#" x="187" y="-137">
         <mutation>
           <arg name="rollos" varid="*@#O`4um.(3hbA:(zHv7"></arg>
         </mutation>
         <field name="NAME">Fenster</field>
         <statement name="STACK">
           <block type="control" id="(3@GeX5GEZz|lAd.m$4{">
             <field name="OID">hm-rpc.0.OEQ0892796.1.LEVEL</field>
             <field name="DELAY_MS">5</field>
               <block type="variables_get" id="UxT/HO0c!o{kB*(q!Ro4">
                 <field name="VAR" id="*@#O`4um.(3hbA:(zHv7">rollos</field>
               <block type="control" id="?e[?w5,ltw.N-`2SC?s4">
                 <field name="OID">hm-rpc.0.OEQ0984789.1.LEVEL</field>
                 <field name="DELAY_MS">10</field>
                   <block type="variables_get" id="bSWRp{e8.#7C|qx$3u$o">
       <block type="comment" id="-/:MDED2QW:auM;grBXD" x="63" y="-13">
         <field name="COMMENT">Terassentür</field>
           <block type="variables_set" id="D}sjfjpWsoRYQO]|WP!I">
             <field name="VAR" id="/!l]R_6qje~AC4QCtkJt">Tuer_geschlossen</field>
               <block type="logic_negate" id="A[dLLmlj+p6?TQGiZ~(4">
                 <value name="BOOL">
                   <block type="get_value" id="3HS,N8V{-|s6ijN]Rn{C">
                     <field name="OID">zigbee.0.00158d0002394252.opened</field>
               <block type="on_ext" id="Fie!sxd/K|0_HFnhBbYh">
                 <value name="OID0">
                   <shadow type="field_oid" id="/Iv)*899]Z6.,:_bpq1:">
                     <field name="oid">zigbee.0.00158d0002394252.opened</field>
                   <block type="variables_set" id="U7C~jo=R(O.Q]EHu_|uu">
                       <block type="logic_negate" id="qJ=6#~`c#a}$R55TP[h{">
                         <value name="BOOL">
                           <block type="on_source" id="VG[E-RtgZu*JIL|4|){-">
                       <block type="procedures_callnoreturn" id="a=6aT_B7e^4fjS*BrfSr">
                         <mutation name="Terasse"></mutation>
                   <block type="schedule" id="7qaQ}i:{``qvajje5=iB">
                     <field name="SCHEDULE">0 0 * * *</field>
                       <block type="procedures_callnoreturn" id=")|YAW$Q@6?I9^3N+*[K-">
                       <block type="astro" id="$4Hlxa1h2e%RB3300)SG">
                         <field name="TYPE">sunrise</field>
                         <field name="OFFSET">0</field>
                           <block type="procedures_callnoreturn" id="/)KMjI==#):Ad8M)xO(+">
                               <block type="procedures_callnoreturn" id="0xSwd=wq5)R)5{*X^w_W">
                                 <mutation name="Fenster">
                                   <arg name="rollos"></arg>
                                 </mutation>
                                 <value name="ARG0">
                                   <block type="math_number" id="G3=%sL8e$TU2X{LMl+R@">
                                     <field name="NUM">100</field>
                           <block type="astro" id="hr!AEW}qu`Jml+2ZvLk.">
                             <field name="TYPE">sunset</field>
                               <block type="controls_if" id="=?wrUl;5J?$mkZiA8yQ2">
                                   <block type="variables_get" id="W6mJ%^$5A3]AhtY_PHa=">
                                   <block type="control" id="SsQHo]fQo/QSLc%#-7X,">
                                     <field name="OID">hm-rpc.0.OEQ0890233.1.LEVEL</field>
                                       <block type="math_number" id="-J0OO$VB^v.,fu-gZ|W,">
                                         <field name="NUM">50</field>
                                   <block type="procedures_callnoreturn" id="?(e@N)=e]I](Ye)C)E3k">
                                     </mutation>
                                     <value name="ARG0">
                                       <block type="math_number" id="(o3sBX/eF)7k=$gUuUId">
                                         <field name="NUM">0</field>
       <block type="procedures_defnoreturn" id="wo(Y;N%mzX+yCkH]((4j" x="563" y="37">
         <field name="NAME">Terasse</field>
           <block type="controls_if" id="lye}(Uf^OOlR.q_wqODd">
               <block type="variables_get" id=")wt~2gD21p,,(r)3b/p/">
               <block type="controls_if" id="apbCYld@f*hNkG!K!9B/">
                 <mutation elseif="1" else="1"></mutation>
                   <block type="time_compare_ex" id="+T^/t5E@+miHRsP%5(0C">
                     <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                     <value name="START_TIME">
                       <shadow type="text" id="cmp`:7nDHp#SkiQS9~Vo">
                         <field name="TEXT">00:00</field>
                     <value name="END_TIME">
                       <shadow type="text" id="eYiS:sH(tR$9:zp:7.xk">
                         <field name="TEXT">18:00</field>
                       <block type="time_astro" id="9|X]D;PEAk}pKE[C^*1k">
                   <block type="variables_set" id="cw^sWVV`j/u9-*=%}%g9">
                     <field name="VAR" id=")z%f,tXn?!GbC|5$y{mm">rollo</field>
                       <block type="math_number" id="@mDqzU4[BZ_F/%V6TgT;">
                 <value name="IF1">
                   <block type="time_compare_ex" id="-#nKTwO-I/o;7y6`Q%j#">
                       <shadow type="text" id=".3t^vi/WEW7X?9qc.%_p">
                         <field name="TEXT">12:00</field>
                       <block type="time_astro" id="_tKh1:X/:U34[)!|f-}y">
                       <shadow type="text" id="Xs}+?ybgrq,t5Kzf+fi@">
                         <field name="TEXT">23:59</field>
                 <statement name="DO1">
                   <block type="variables_set" id="+%SZpEO4]z-[rKTPn%qJ">
                       <block type="math_number" id="vCitva3e^LqNap_e$,_J">
                 <statement name="ELSE">
                   <block type="variables_set" id="O)#e{L+{Xxn)0jxLaLJC">
                       <block type="math_number" id="tbRPn]EoyUx]6s8PVZKn">
               <block type="variables_set" id="!s`9SPBMy,E$T5UQ%ntN">
                   <block type="math_number" id="s0rvX,5[7O~77.CLaxjX">
               <block type="controls_if" id="UaT2d8c+20#@j(l-n*m6">
                   <block type="logic_compare" id="gl_8cIu(2q`4JSC(:^M=">
                     <field name="OP">NEQ</field>
                       <block type="variables_get" id="-QktzY|DANqS52y2rp[]">
                       <block type="get_value" id="w%P1z,02~]Z|gtJfw7Eq">
                   <block type="control" id="0yB4wra11;C:BMU+[}_^">
                       <block type="variables_get" id="m]umWgjv;77bN{ls?3Y~">
        acem @paul53 last edited by acem
        @paul53 Javascript-Instanz sieht so aus was trage ich hier ein?
          paul53 @acem last edited by
          @acem sagte:
          Nimm den Haken bei "Systemeinstellungen" raus und trage dann die Ortskoordinaten ein.
            @paul53 Ich habe den Haken rausgenommen und die koordinaten Breite, Länge eingetragen!
            Muß ich hier die Tageszeiteinstellungen auch anpassen?
              @acem sagte:
              Nein, die Einstellungen haben nur Einfluss auf den Datenpunkt "javascript.0.variables.isDayTime".
                @paul53 habe es soeben nochmals getestet, Dank deiner Hilfe Funktioniert es mit der Astrofunktion.
                Vielen Herzlichen Dank👍 🙂
                Acem
                  acem @acem last edited by acem
                  Seit der Umstellung auf die Astro-Funktion fährt der Terrassen-Rollo morgens nicht hoch!
                  Abend fahren Alle Rollos runter, morgens fahren nur 2 Rollos hoch ausser Terrassentür-Rollo.
                  Muß man hier noch etwas ändern?
                    @acem sagte:
                    Dann trage mal beim Vergleich einen Offset von -1 Minute zum Sonnenaufgang ein.
                      @paul53 welche ist das Vergleich? habe ich es an die richtige stelle eingetragen?
                        @acem sagte:
                        Ja.
                          Alles klar.
                          Vielen Dank
                          3643
