    4. Beta Test js-controller 3.2.x auf GitHub
      Jan1 last edited by
      Der Enigma2 Adapter läuft mit der Version nicht mehr:
      2021-01-09 13:18:47.837 - info: host.Beelink "system.adapter.enigma2.0" disabled
      2021-01-09 13:19:03.296 - info: host.Beelink "system.adapter.enigma2.0" enabled
      2021-01-09 13:19:03.363 - info: host.Beelink instance system.adapter.enigma2.0 started with pid 1556694
      2021-01-09 13:19:05.000 - info: enigma2.0 (1556694) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.enigma2, node: v14.15.4, js-controller: 3.2.3
      2021-01-09 13:19:05.031 - info: enigma2.0 (1556694) starting Polling every 5000 ms
      2021-01-09 13:19:05.075 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-01-09 13:19:05.076 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
      2021-01-09 13:19:05.079 - error: enigma2.0 (1556694) Error: Not exists
      at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2270:17)
      at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3010:38)
      at processImmediate (internal/timers.js:463:21)
      2021-01-09 13:19:05.079 - error: enigma2.0 (1556694) Not exists
      2021-01-09 13:19:05.093 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-01-09 13:19:05.093 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
      2021-01-09 13:19:05.094 - error: enigma2.0 (1556694) Error: Not exists
      2021-01-09 13:19:05.094 - error: enigma2.0 (1556694) Not exists
      2021-01-09 13:19:05.104 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
      2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) Error: Not exists
      2021-01-09 13:19:05.105 - error: enigma2.0 (1556694) Not exists
      2021-01-09 13:19:05.106 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-01-09 13:19:05.107 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
      2021-01-09 13:19:05.107 - error: enigma2.0 (1556694) Error: Not exists
      2021-01-09 13:19:05.108 - error: enigma2.0 (1556694) Not exists
      2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) unhandled promise rejection: Not exists
      2021-01-09 13:19:05.109 - error: enigma2.0 (1556694) Error: Not exists
      2021-01-09 13:19:05.110 - error: enigma2.0 (1556694) Not exists
      2021-01-09 13:19:05.619 - info: enigma2.0 (1556694) terminating
      2021-01-09 13:19:05.621 - warn: enigma2.0 (1556694) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-01-09 13:19:06.260 - error: host.Beelink instance system.adapter.enigma2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-01-09 13:19:06.262 - info: host.Beelink Restart adapter system.adapter.enigma2.0 because enabled
        A Former User @Jan1 last edited by
        @Jan1 richtig, genauso wenig wie der mihome-vacuum, Issues hab ich schon angelegt.
          Jan1 @Guest last edited by
          @ilovegym
          Ist das die selbe Ursache und muss das im Adapter gefixt werden, oder im JS-Controller?
          Ich habs zur Sicherheit auch gleich noch im Adapter Thread gepostet.
          • SBorg
            SBorg Forum Testing Most Active @SBorg last edited by
            @SBorg sagte in Beta Test js-controller 3.2.x auf GitHub:
            Youtube + Enigma steigen per Exception kpl. aus, sind ohne Update so nicht mehr nutzbar.
            +weitere kommen durch den JS-Controller, müssen aber im jeweiligen Adapter gefixt werden 😉
              A Former User @apollon77 last edited by
              @apollon77
              smartmeter Adapter gibt ne Warnung:
              smartmeter.0 2021-01-09 13:35:48.320 warn (2581) State "smartmeter.0.1-0:1_8_0__255.rawvalue" has no existing object, this might lead to an error in future versions
              Ansonsten ist es jetzt mit 3.2.3 sehr ruhig... 🙂
              • Rob_in
                Rob_in @apollon77 last edited by
                Problem with chromecast adapter. Debug output:
                2021-01-09 13:36:54.062  - error: chromecast.0 (32660) Not exists
                  ioredis:redis write command[10.1.1.30:9000 (chromecast.0 (32660))]: 0 -> publish('messagebox.system.host.pg.mh,{"command":"addNotification","message":{"scope":"system","category":null,"message":"Not exists","instance":"chromecast.0"},"from":"system.adapter.chromecast.0","callback": ... <REDACTED full-length="351">') +12ms
                2021-01-09 13:36:54.065  - error: chromecast.0 (32660) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2021-01-09 13:36:54.067  - error: chromecast.0 (32660) unhandled promise rejection: Not exists
                2021-01-09 13:36:54.069  - error: chromecast.0 (32660) Error: Not exists
                    at Immediate.adapterObjects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3010:38)
                    at runCallback (timers.js:706:11)
                    at tryOnImmediate (timers.js:676:5)
                    at processImmediate (timers.js:658:5)
                2021-01-09 13:36:54.070  - error: chromecast.0 (32660) Not exists
                  ioredis:redis write command[10.1.1.30:9000 (chromecast.0 (32660))]: 0 -> publish('messagebox.system.host.pg.mh,{"command":"addNotification","message":{"scope":"system","category":null,"message":"Not exists","instance":"chromecast.0"},"from":"system.adapter.chromecast.0","callback": ... <REDACTED full-length="351">') +8ms
                2021-01-09 13:36:54.073  - error: chromecast.0 (32660) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2021-01-09 13:36:54.075  - error: chromecast.0 (32660) unhandled promise rejection: Not exists
                2021-01-09 13:36:54.077  - error: chromecast.0 (32660) Error: Not exists
                2021-01-09 13:36:54.078  - error: chromecast.0 (32660) Not exists
                  @apollon77
                  ich weiß nicht, ob dies hier mit der controller-Version zusammenhängt.
                  Ich hatte auf der Testinstallation den sony-bravia Adapter installiert und wollte ihn wieder löschen:
                  $ ./iobroker del sony-bravia
                  Delete adapter "sony-bravia"
                  host.ioBroker-rock64 Counted 1 meta of sony-bravia
                  host.ioBroker-rock64 Counted 1 adapter for sony-bravia
                  host.ioBroker-rock64 Counted 2 states (system.adapter.sony-bravia.*) from states
                  ERROR: Cannot delete sony-bravia.admin files folder: ReplyError: Error ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/iobroker-data/files/sony-bravia.admin'
                  host.ioBroker-rock64 object sony-bravia.admin deleted
                  host.ioBroker-rock64 Deleting 2 object(s).
                  host.ioBroker-rock64 Deleting 2 state(s).
                  npm uninstall iobroker.sony-bravia --loglevel error --prefix "/opt/iobroker" (System call)
                  Habe das monierte Verzeichnis geleert, da war noch _data.json drin, danach klappte es immer noch nicht.
                  Erneut installiert und wieder das oben gezeigte
                  EDIT:
                  Muss an der Version liegen!
                  bei hm-rpc das gleiche beim Löschen des Adapters:
                  $ ./iobroker del hm-rpc
                  Delete adapter "hm-rpc"
                  host.ioBroker-rock64 Counted 1 instances of hm-rpc
                  host.ioBroker-rock64 Counted 3 meta of hm-rpc
                  host.ioBroker-rock64 Counted 1 adapter for hm-rpc
                  host.ioBroker-rock64 Counted 116 devices of hm-rpc
                  host.ioBroker-rock64 Counted 516 channels of hm-rpc
                  host.ioBroker-rock64 Counted 2445 states of hm-rpc
                  host.ioBroker-rock64 Counted 15 states of system.adapter.hm-rpc
                  host.ioBroker-rock64 Counted 2438 states (io.hm-rpc.*) from states
                  host.ioBroker-rock64 Counted 15 states (system.adapter.hm-rpc.*) from states
                  host.ioBroker-rock64 Counted 1 objects of hm-rpc
                  ERROR: Cannot delete hm-rpc.admin files folder: ReplyError: Error ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/iobroker-data/files/hm-rpc.admin'
                  host.ioBroker-rock64 object hm-rpc.admin deleted
                  host.ioBroker-rock64 Deleting 3098 object(s). Be patient...
                  host.ioBroker-rock64: Only 3000 objects left to be deleted.
                  host.ioBroker-rock64: Only 2800 objects left to be deleted.
                  host.ioBroker-rock64: Only 2600 objects left to be deleted.
                  host.ioBroker-rock64: Only 2400 objects left to be deleted.
                  host.ioBroker-rock64: Only 2200 objects left to be deleted.
                  EDIT2:
                  jetzt sind sie auf einmal beide weg 😱
                    apollon77 @Jan1 last edited by
                    @Jan1 Wir werden den Fall hier im controller fixen. am Ende versuchen die Adapter ein Objekt zu löschen was es nicht gibt ... wir werden den Fehler als "aktion erfolgreich" behandeln, Fix kommt nachher
                      apollon77 @Guest last edited by
                      @ilovegym Butte auch Issue anlegen
                        apollon77 @Rob_in last edited by
                        @Rob_in siehe Post eben ... Fix kommt nachher noch
                        Rob_in 1 Reply Last reply Reply Quote 0
                        • Rob_in
                          @apollon77 Indeed, the chromecast issue is correct by this commit: https://github.com/ioBroker/ioBroker.js-controller/pull/1167/commits/8e43c640e5f6d06966becda582a7ffba6ed169bc
                          foxriver76 created this issue in ioBroker/ioBroker.js-controller
                          closed do not return an error if object does not exist on delForeignObject/d… #1167
                            apollon77 @Homoran last edited by
                            @Homoran schaue ich mir an
                              @apollon77 sagte in Beta Test js-controller 3.2.x auf GitHub:
                              https://github.com/Apollon77/ioBroker.smartmeter/issues/179
                              Ilovegym66 created this issue in Apollon77/ioBroker.smartmeter
                              closed js-cotntroller 3.2.3 warnings #179
                                @Rob_in Exakt, war gherade einkaufen und dann ne USV tauschen und jetzt sortiere ich alles und bereite update vor 🙂
                                Noch eeeeeetwas Geduld
                                  So, liebe Freunde der gepflegten Controler Tests 🙂
                                  Github ist nun mit der 3.2.4 ausgestattet die alles bisher berichtete behandelt.
                                  • die "Not exists" Fehler in einigen Adaptern wenn diese nicht existente Objekte gelöscht haben sollten weg sein
                                  • Lets encrypt wurde nochmal ein bissl getuned (hat das schonmal jemand gecheckt? ;-))
                                  • der Adapter löschen File Fehler von @Homoran sollte auch weg sein
                                  Have fun
                                  Ingo
                                  ? Homoran UncleSam peterbaumert 4 Replies Last reply Reply Quote 0
                                    @apollon77 Super, vielen vielen Dank fürs schnelle fixen, das Teil läuft hier jetzt produktiv und darf sich mal austoben.. 🙂
                                    Enigma, Mihome-Vacuum, etc.. keine Fehler mehr.
                                      Homoran Global Moderator Administrators @apollon77 last edited by
                                      Jepp!
                                      host.ioBroker-rock64 file hm-rpc.admin deleted
                                      host.ioBroker-rock64 Deleting 4 object(s).
                                      npm uninstall iobroker.hm-rpc --loglevel error --prefix "/opt/iobroker" (System call)
                                      process exited with code 0
                                      Danke!
                                        Jan1 last edited by
                                        Eine Warnung habe ich noch:
                                        alexa2.0	2021-01-09 18:37:33.810	warn	(2002421) State "alexa2.0.Echo-Devices.G070L80672670J9K.Player.muted" has no existing object, this might lead to an error in future versions
                                        alexa2.0	2021-01-09 18:37:33.808	warn	(2002421) State "alexa2.0.Echo-Devices.G070L80672670J9K.Player.volume" has no existing object, this might lead to an error in future versions
                                        apollon77 Homoran 2 Replies Last reply Reply Quote 0
                                          @Jan1 —> Adapter issue anlegen (bzw das gibts schon)
                                            Homoran Global Moderator Administrators @Jan1 last edited by
                                            @Jan1 sagte in Beta Test js-controller 3.2.x auf GitHub:
                                            so was hab ich reichlich:
                                            hm-rpc.0	2021-01-09 18:48:51.753	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:35","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:51.695	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:34","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:51.630	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:33","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:51.537	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:32","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:51.467	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:31","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:51.407	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:30","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:51.340	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:29","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:51.277	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:28","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:51.218	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:27","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:51.159	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:26","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:51.101	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:25","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:51.042	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:24","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:50.982	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:23","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:50.894	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:22","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:50.824	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:21","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:50.764	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:20","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:50.704	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:19","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:50.644	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:18","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:50.586	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:17","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:50.528	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:16","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:50.469	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:15","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:50.411	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:14","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:50.300	warn	(10641) State "hm-rpc.0.LTK0124195.2.FREQUENCY" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:50.298	warn	(10641) State "hm-rpc.0.LTK0124195.2.VOLTAGE" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:50.296	warn	(10641) State "hm-rpc.0.LTK0124195.2.CURRENT" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:50.287	warn	(10641) State "hm-rpc.0.LTK0124195.2.POWER" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:50.286	warn	(10641) State "hm-rpc.0.LTK0124195.2.ENERGY_COUNTER" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:50.284	warn	(10641) State "hm-rpc.0.LTK0124195.2.BOOT" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:50.234	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:13","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.813	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:12","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.747	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:11","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.689	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:10","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.630	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:9","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.571	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:8","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.512	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:7","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.453	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:6","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.393	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:5","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.333	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:4","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.263	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:3","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.203	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:2","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.140	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:1","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:49.072	warn	(10641) State "hm-rpc.0.NEQ0633493.1.STATE" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:49.070	warn	(10641) State "hm-rpc.0.NEQ0633493.1.LOWBAT" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:49.032	warn	(10641) State "hm-rpc.0.NEQ0633493.1.ERROR" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:48.133	info	(10641) xmlrpc -> getParamsetDescription ["BidCoS-RF:0","VALUES"]
                                            hm-rpc.0	2021-01-09 18:48:44.849	warn	(10641) State "hm-rpc.0.BidCoS-RF.50.PRESS_LONG" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:44.508	warn	(10641) State "hm-rpc.0.JEQ0140901.1.BRIGHTNESS" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:44.482	warn	(10641) State "hm-rpc.0.JEQ0140901.1.SUNSHINEDURATION" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:44.481	warn	(10641) State "hm-rpc.0.JEQ0140901.1.WIND_DIRECTION_RANGE" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:44.479	warn	(10641) State "hm-rpc.0.JEQ0140901.1.WIND_DIRECTION" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:44.478	warn	(10641) State "hm-rpc.0.JEQ0140901.1.WIND_SPEED" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:44.476	warn	(10641) State "hm-rpc.0.JEQ0140901.1.RAIN_COUNTER" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:44.475	warn	(10641) State "hm-rpc.0.JEQ0140901.1.RAINING" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:44.473	warn	(10641) State "hm-rpc.0.JEQ0140901.1.HUMIDITY" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:44.466	warn	(10641) State "hm-rpc.0.JEQ0140901.1.TEMPERATURE" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.685	warn	(10641) State "hm-rpc.0.LTK0129844.2.SET_TEMPERATURE" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.666	warn	(10641) State "hm-rpc.0.LTK0129844.2.ACTUAL_HUMIDITY" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.664	warn	(10641) State "hm-rpc.0.LTK0129844.2.ACTUAL_TEMPERATURE" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.646	warn	(10641) State "hm-rpc.0.NEQ0532734.5.LOWBAT" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.645	warn	(10641) State "hm-rpc.0.NEQ0532734.4.LOWBAT" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.643	warn	(10641) State "hm-rpc.0.NEQ0532734.3.LOWBAT" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.642	warn	(10641) State "hm-rpc.0.NEQ0532734.2.LOWBAT" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.640	warn	(10641) State "hm-rpc.0.NEQ0532734.1.LOWBAT" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.639	warn	(10641) State "hm-rpc.0.NEQ0532734.0.LOWBAT" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.637	warn	(10641) State "hm-rpc.0.NEQ0532734.4.TEMPERATURE" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.635	warn	(10641) State "hm-rpc.0.NEQ0532734.3.TEMPERATURE" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.633	warn	(10641) State "hm-rpc.0.NEQ0532734.2.TEMPERATURE" has no existing object, this might lead to an error in future versions
                                            hm-rpc.0	2021-01-09 18:48:43.621	warn	(10641) State "hm-rpc.0.NEQ0532734.1.TEMPERATURE" has no existing object, this might lead to an error in future versions
                                            Issue bei hm-rpc?
                                            1.0k
                                            js-controller
                                            25
                                            287
                                            46098
