    4. JavaScript
    5. HTML Tabelle Linux-Control Adapter
    • dirk1962
      dirk1962 @Scrounger last edited by Negalein
      @Scrounger, ich hoffe Du kannst mit dem log-file was anfangen. Wenn Du es anders brauchst bitte melden.
      2021-01-08 15:25:00.016 - info: host.ioBrokerNUC instance system.adapter.dwd.0 started with pid 20067
      2021-01-08 15:25:01.844 - info: dwd.0 (20067) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.1, js-controller: 3.1.6
      2021-01-08 15:25:07.319 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 (force=false, process=true)
      2021-01-08 15:25:07.319 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 send kill signal
      2021-01-08 15:25:07.321 - info: linux-control.0 (19946) Got terminate signal TERMINATE_YOURSELF
      2021-01-08 15:25:07.322 - info: linux-control.0 (19946) cleaned everything up...
      2021-01-08 15:25:07.322 - info: linux-control.0 (19946) terminating
      2021-01-08 15:25:07.323 - debug: linux-control.0 (19946) Plugin sentry destroyed
      2021-01-08 15:25:07.323 - info: linux-control.0 (19946) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-01-08 15:25:07.844 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-01-08 15:25:10.351 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 started with pid 20092
      2021-01-08 15:25:10.670 - debug: linux-control.0 (20092) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-01-08 15:25:10.692 - debug: linux-control.0 (20092) Objects client ready ... initialize now
      2021-01-08 15:25:10.694 - debug: linux-control.0 (20092) Objects create System PubSub Client
      2021-01-08 15:25:10.694 - debug: linux-control.0 (20092) Objects create User PubSub Client
      2021-01-08 15:25:10.699 - debug: linux-control.0 (20092) Objects client initialize lua scripts
      2021-01-08 15:25:10.708 - debug: linux-control.0 (20092) Objects connected to redis: 127.0.0.1:9001
      2021-01-08 15:25:10.710 - debug: linux-control.0 (20092) objectDB connected
      2021-01-08 15:25:10.711 - debug: linux-control.0 (20092) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-01-08 15:25:10.715 - debug: linux-control.0 (20092) States create User PubSub Client
      2021-01-08 15:25:10.716 - debug: linux-control.0 (20092) States create System PubSub Client
      2021-01-08 15:25:10.726 - debug: linux-control.0 (20092) States connected to redis: 127.0.0.1:9000
      2021-01-08 15:25:10.726 - debug: linux-control.0 (20092) statesDB connected
      2021-01-08 15:25:11.470 - debug: linux-control.0 (20092) Plugin sentry Initialize Plugin (enabled=true)
      2021-01-08 15:25:11.519 - info: linux-control.0 (20092) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.1, js-controller: 3.1.6
      2021-01-08 15:25:11.549 - info: linux-control.0 (20092) getting data from Proxmox (192.168.1.102:22, Adapter start)
      2021-01-08 15:25:11.634 - debug: linux-control.0 (20092) [distributionInfo] Proxmox (192.168.1.102:22): send command: 'cat /etc/os-release'
      2021-01-08 15:25:11.734 - debug: linux-control.0 (20092) [distributionInfo] Proxmox (192.168.1.102:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
      NAME="Debian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      2021-01-08 15:25:11.740 - debug: linux-control.0 (20092) [distributionInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
      2021-01-08 15:25:11.749 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get update'
      2021-01-08 15:25:12.164 - info: dwd.0 (20067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-01-08 15:25:12.669 - info: host.ioBrokerNUC instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-01-08 15:25:13.826 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: Hit:1 http://security.debian.org buster/updates InRelease
      Hit:2 http://security.debian.org/debian-security buster/updates InRelease
      Hit:3 http://ftp.de.debian.org/debian buster InRelease
      Hit:4 http://ftp.de.debian.org/debian buster-updates InRelease
      Hit:5 http://download.proxmox.com/debian/pve buster InRelease
      Reading package lists...
      2021-01-08 15:25:13.827 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s[([\w,\-,\d,\.,~,:,\+]+)]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
      2021-01-08 15:25:14.122 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout:
      2021-01-08 15:25:14.122 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.newPackages: 0
      2021-01-08 15:25:14.168 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.upgradable: false
      2021-01-08 15:25:14.214 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
      ' -W | sort -nr | head -1'
      2021-01-08 15:25:14.228 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: 1609669960
      2021-01-08 15:25:14.229 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.lastUpdate: 1609669960000 -> 03.01.2021 11:32
      2021-01-08 15:25:14.273 - debug: linux-control.0 (20092) [servicesInfo] Proxmox (192.168.1.102:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2021-01-08 15:25:14.283 - debug: linux-control.0 (20092) [servicesInfo] Proxmox (192.168.1.102:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
      apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
      apt-daily.service,loaded,inactive,dead, Daily apt download activities
      auditd.service,not-found,inactive,dead, auditd.service
      auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
      blk-availability.service,loaded,active,exited, Availability of block devices
      ceph.service,not-found,inactive,dead, ceph.service
      connman.service,not-found,inactive,dead, connman.service
      console-getty.service,loaded,inactive,dead, Console Getty
      console-screen.service,not-found,inactive,dead, console-screen.service
      console-setup.service,loaded,active,exited, Set console font and keymap
      corosync.service,loaded,inactive,dead, Corosync Cluster Engine
      cron.service,loaded,active,running, Regular background program processing daemon
      dbus.service,loaded,active,running, D-Bus System Message Bus
      display-manager.service,not-found,inactive,dead, display-manager.service
      dm-event.service,loaded,active,running, Device-mapper event daemon
      dracut-mount.service,not-found,inactive,dead, dracut-mount.service
      emergency.service,loaded,inactive,dead, Emergency Shell
      exim4.service,not-found,inactive,dead, exim4.service
      fcoe.service,not-found,inactive,dead, fcoe.service
      getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
      getty@tty1.service,loaded,active,running, Getty on tty1
      glusterd.service,not-found,inactive,dead, glusterd.service
      gssproxy.service,not-found,inactive,dead, gssproxy.service
      ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
      iscsi-shutdown.service,not-found,inactive,dead, iscsi-shutdown.service
      iscsid.service,loaded,active,running, iSCSI initiator daemon (iscsid)
      kbd.service,not-found,inactive,dead, kbd.service
      keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
      kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
      ksmtuned.service,loaded,active,running, Kernel Samepage Merging (KSM) Tuning Daemon
      lm-sensors.service,loaded,active,exited, Initialize hardware monitoring sensors
      logrotate.service,loaded,inactive,dead, Rotate log files
      lvm2-activation.service,not-found,inactive,dead, lvm2-activation.service
      lvm2-lvmpolld.service,loaded,inactive,dead, LVM2 poll daemon
      lvm2-monitor.service,loaded,active,exited, Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
      lvm2-pvscan@259:3.service,loaded,active,exited, LVM event activation on device 259:3
      lxc-monitord.service,loaded,active,running, LXC Container Monitoring Daemon
      lxc-net.service,loaded,active,exited, LXC network bridge setup
      lxc.service,loaded,active,exited, LXC Container Initialization and Autoboot Code
      lxcfs.service,loaded,active,running, FUSE filesystem for LXC
      man-db.service,loaded,inactive,dead, Daily man-db regeneration
      networking.service,loaded,active,exited, Raise network interfaces
      NetworkManager.service,not-found,inactive,dead, NetworkManager.service
      nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
      nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
      nfs-kernel-server.service,not-found,inactive,dead, nfs-kernel-server.service
      nfs-server.service,not-found,inactive,dead, nfs-server.service
      nfs-utils.service,loaded,inactive,dead, NFS server and client services
      open-iscsi.service,loaded,active,exited, Login to default iSCSI targets
      plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
      plymouth-start.service,not-found,inactive,dead, plymouth-start.service
      postfix.service,loaded,active,exited, Postfix Mail Transport Agent
      postfix@-.service,loaded,active,running, Postfix Mail Transport Agent (instance -)
      pve-cluster.service,loaded,active,running, The Proxmox VE cluster filesystem
      pve-daily-update.service,loaded,inactive,dead, Daily PVE download activities
      pve-firewall.service,loaded,active,running, Proxmox VE firewall
      pve-guests.service,loaded,active,exited, PVE guests
      pve-ha-crm.service,loaded,active,running, PVE Cluster HA Resource Manager Daemon
      pve-ha-lrm.service,loaded,active,running, PVE Local HA Resource Manager Daemon
      pve-lxc-syscalld.service,loaded,active,running, Proxmox VE LXC Syscall Daemon
      pvebanner.service,loaded,active,exited, Proxmox VE Login Banner
      pvedaemon.service,loaded,active,running, PVE API Daemon
      pvefw-logger.service,loaded,active,running, Proxmox VE firewall logger
      pvenetcommit.service,loaded,active,exited, Commit Proxmox VE network changes
      pveproxy.service,loaded,active,running, PVE API Proxy Server
      pvesr.service,loaded,inactive,dead, Proxmox VE replication runner
      pvestatd.service,loaded,active,running, PVE Status Daemon
      qmeventd.service,loaded,active,running, PVE Qemu Event Daemon
      rbdmap.service,loaded,active,exited, Map RBD devices
      rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
      rescue.service,loaded,inactive,dead, Rescue Shell
      rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
      rpc-statd-notify.service,loaded,inactive,dead, Notify NFS peers of a restart
      rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
      rpcbind.service,loaded,active,running, RPC bind portmap service
      rrdcached.service,loaded,active,running, LSB: start or stop rrdcached
      rsync.service,loaded,inactive,dead, fast remote file copy program daemon
      rsyslog.service,loaded,active,running, System Logging Service
      sendmail.service,not-found,inactive,dead, sendmail.service
      smartmontools.service,loaded,active,running, Self Monitoring and Reporting Technology (SMART) Daemon
      smb.service,not-found,inactive,dead, smb.service
      spiceproxy.service,loaded,active,running, PVE SPICE Proxy Server
      ssh.service,loaded,active,running, OpenBSD Secure Shell server
      systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
      systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
      systemd-backlight@backlight:acpi_video0.service,loaded,active,exited, Load/Save Screen Backlight Brightness of backlight:acpi_video0
      systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
      systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
      systemd-fsck@dev-disk-by\x2duuid-D782\x2dA871.service,loaded,active,exited, File System Check on /dev/disk/by-uuid/D782-A871
      systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
      systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
      systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
      systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
      systemd-journald.service,loaded,active,running, Journal Service
      systemd-logind.service,loaded,active,running, Login Service
      systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
      systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
      systemd-networkd.service,loaded,inactive,dead, Network Service
      systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
      systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
      systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
      systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
      systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
      systemd-sysusers.service,loaded,active,exited, Create System Users
      systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
      systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
      systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
      systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
      systemd-udev-settle.service,loaded,active,exited, udev Wait for Complete Device Initialization
      systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
      systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
      systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
      systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
      systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
      systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
      systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
      user-runtime-dir@0.service,loaded,active,exited, User Runtime Directory /run/user/0
      user@0.service,loaded,active,running, User Manager for UID 0
      watchdog-mux.service,loaded,active,running, Proxmox VE watchdog multiplexer
      zfs-import-cache.service,loaded,active,exited, Import ZFS pools by cache file
      zfs-mount.service,loaded,active,exited, Mount ZFS filesystems
      zfs-share.service,loaded,active,exited, ZFS file system shares
      zfs-volume-wait.service,loaded,active,exited, Wait for ZFS Volume (zvol) links in /dev
      zfs-zed.service,loaded,active,running, ZFS Event Daemon (zed)
      2021-01-08 15:25:14.285 - debug: linux-control.0 (20092) [servicesInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"blk-availability.service","load":"loaded","active":"active","running":"exited","description":"Availability of block devices"},{"id":"ceph.service","load":"not-found","active":"inactive","running":"dead","description":"ceph.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-getty.service","load":"loaded","active":"inactive","running":"dead","description":"Console Getty"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"corosync.service","load":"loaded","active":"inactive","running":"dead","description":"Corosync Cluster Engine"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dm-event.service","load":"loaded","active":"active","running":"running","description":"Device-mapper event daemon"},{"id":"dracut-mount.service","load":"not-found","active":"inactive","running":"dead","description":"dracut-mount.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"not-found","active":"inactive","running":"dead","description":"exim4.service"},{"id":"fcoe.service","load":"not-found","active":"inactive","running":"dead","description":"fcoe.service"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"glusterd.service","load":"not-found","active":"inactive","running":"dead","description":"glusterd.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"iscsi-shutdown.service","load":"not-found","active":"inactive","running":"dead","description":"iscsi-shutdown.service"},{"id":"iscsid.service","load":"loaded","active":"active","running":"running","description":"iSCSI initiator daemon (iscsid)"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"ksmtuned.service","load":"loaded","active":"active","running":"running","description":"Kernel Samepage Merging (KSM) Tuning Daemon"},{"id":"lm-sensors.service","load":"loaded","active":"active","running":"exited","description":"Initialize hardware monitoring sensors"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"lvm2-activation.service","load":"not-found","active":"inactive","running":"dead","description":"lvm2-activation.service"},{"id":"lvm2-lvmpolld.service","load":"loaded","active":"inactive","running":"dead","description":"LVM2 poll daemon"},{"id":"lvm2-monitor.service","load":"loaded","active":"active","running":"exited","description":"Monitoring of LVM2 mirrors","field6":"snapshots etc. using dmeventd or progress polling"},{"id":"lvm2-pvscan@259:3.service","load":"loaded","active":"active","running":"exited","description":"LVM event activation on device 259:3"},{"id":"lxc-monitord.service","load":"loaded","active":"active","running":"running","description":"LXC Container Monitoring Daemon"},{"id":"lxc-net.service","load":"loaded","active":"active","running":"exited","description":"LXC network bridge setup"},{"id":"lxc.service","load":"loaded","active":"active","running":"exited","description":"LXC Container Initialization and Autoboot Code"},{"id":"lxcfs.service","load":"loaded","active":"active","running":"running","description":"FUSE filesystem for LXC"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-kernel-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-kernel-server.service"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"open-iscsi.service","load":"loaded","active":"active","running":"exited","description":"Login to default iSCSI targets"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postfix.service","load":"loaded","active":"active","running":"exited","description":"Postfix Mail Transport Agent"},{"id":"postfix@-.service","load":"loaded","active":"active","running":"running","description":"Postfix Mail Transport Agent (instance -)"},{"id":"pve-cluster.service","load":"loaded","active":"active","running":"running","description":"The Proxmox VE cluster filesystem"},{"id":"pve-daily-update.service","load":"loaded","active":"inactive","running":"dead","description":"Daily PVE download activities"},{"id":"pve-firewall.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall"},{"id":"pve-guests.service","load":"loaded","active":"active","running":"exited","description":"PVE guests"},{"id":"pve-ha-crm.service","load":"loaded","active":"active","running":"running","description":"PVE Cluster HA Resource Manager Daemon"},{"id":"pve-ha-lrm.service","load":"loaded","active":"active","running":"running","description":"PVE Local HA Resource Manager Daemon"},{"id":"pve-lxc-syscalld.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE LXC Syscall Daemon"},{"id":"pvebanner.service","load":"loaded","active":"active","running":"exited","description":"Proxmox VE Login Banner"},{"id":"pvedaemon.service","load":"loaded","active":"active","running":"running","description":"PVE API Daemon"},{"id":"pvefw-logger.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall logger"},{"id":"pvenetcommit.service","load":"loaded","active":"active","running":"exited","description":"Commit Proxmox VE network changes"},{"id":"pveproxy.service","load":"loaded","active":"active","running":"running","description":"PVE API Proxy Server"},{"id":"pvesr.service","load":"loaded","active":"inactive","running":"dead","description":"Proxmox VE replication runner"},{"id":"pvestatd.service","load":"loaded","active":"active","running":"running","description":"PVE Status Daemon"},{"id":"qmeventd.service","load":"loaded","active":"active","running":"running","description":"PVE Qemu Event Daemon"},{"id":"rbdmap.service","load":"loaded","active":"active","running":"exited","description":"Map RBD devices"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-statd-notify.service","load":"loaded","active":"inactive","running":"dead","description":"Notify NFS peers of a restart"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rrdcached.service","load":"loaded","active":"active","running":"running","description":"LSB: start or stop rrdcached"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"sendmail.service","load":"not-found","active":"inactive","running":"dead","description":"sendmail.service"},{"id":"smartmontools.service","load":"loaded","active":"active","running":"running","description":"Self Monitoring and Reporting Technology (SMART) Daemon"},{"id":"smb.service","load":"not-found","active":"inactive","running":"dead","description":"smb.service"},{"id":"spiceproxy.service","load":"loaded","active":"active","running":"running","description":"PVE SPICE Proxy Server"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-backlight@backlight:acpi_video0.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Screen Backlight Brightness of backlight:acpi_video0"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2duuid-D782\\x2dA871.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-uuid/D782-A871"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-settle.service","load":"loaded","active":"active","running":"exited","description":"udev Wait for Complete Device Initialization"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@0.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/0"},{"id":"user@0.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 0"},{"id":"watchdog-mux.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE watchdog multiplexer"},{"id":"zfs-import-cache.service","load":"loaded","active":"active","running":"exited","description":"Import ZFS pools by cache file"},{"id":"zfs-mount.service","load":"loaded","active":"active","running":"exited","description":"Mount ZFS filesystems"},{"id":"zfs-share.service","load":"loaded","active":"active","running":"exited","description":"ZFS file system shares"},{"id":"zfs-volume-wait.service","load":"loaded","active":"active","running":"exited","description":"Wait for ZFS Volume (zvol) links in /dev"},{"id":"zfs-zed.service","load":"loaded","active":"active","running":"running","description":"ZFS Event Daemon (zed)"}]
      2021-01-08 15:25:14.500 - debug: linux-control.0 (20092) [needrestart] Proxmox (192.168.1.102:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:25:14.507 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/log/ | awk '{ print $1 /1024 }''
      2021-01-08 15:25:14.516 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 28.6914
      2021-01-08 15:25:14.518 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.size: 28.69 MB
      2021-01-08 15:25:14.559 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/log/ -name "*" | wc -l'
      2021-01-08 15:25:14.567 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1382
      2021-01-08 15:25:14.569 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.files: 1382 Dateien
      2021-01-08 15:25:14.611 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/log/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
      2021-01-08 15:25:15.627 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610115911
      2021-01-08 15:25:15.629 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.lastChange: 1610115911000 -> 08.01.2021 15:25
      2021-01-08 15:25:15.671 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/ | awk '{ print $1 /1024 }''
      2021-01-08 15:25:15.701 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1899.28
      2021-01-08 15:25:15.702 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.size: 1899.28 MB
      2021-01-08 15:25:15.748 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/ -name "*" | wc -l'
      2021-01-08 15:25:15.773 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 5349
      2021-01-08 15:25:15.777 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.files: 5349 Dateien
      2021-01-08 15:25:15.821 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
      2021-01-08 15:25:19.713 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610115919
      2021-01-08 15:25:19.715 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.lastChange: 1610115919000 -> 08.01.2021 15:25
      2021-01-08 15:25:19.760 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2021-01-08 15:25:19.767 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): response stdout: 14
      2021-01-08 15:25:19.771 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
      2021-01-08 15:25:19.777 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): response stdout: 31986;7014;24434
      2021-01-08 15:25:19.820 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
      2021-01-08 15:25:19.827 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): response stdout: 8191;0;8191
      2021-01-08 15:25:19.829 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
      2021-01-08 15:25:19.844 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): response stdout: 39.6;/usr/bin/kvm
      2021-01-08 15:25:19.889 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): send command: 'sensors | grep Package -m 1 | awk '{print $4}' | awk '{print substr($1, length($0)-6,2)}''
      2021-01-08 15:25:19.898 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): response stdout: 58
      2021-01-08 15:25:19.901 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): send command: 'sensors | grep 'Core 0:' | awk '{print $3}' | cut -c2-3'
      2021-01-08 15:25:19.909 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): response stdout: 57
      2021-01-08 15:25:19.911 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): send command: 'sensors | grep 'Core 1:' | awk '{print $3}' | cut -c2-3'
      2021-01-08 15:25:19.919 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): response stdout: 57
      2021-01-08 15:25:19.922 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): send command: 'sensors | grep 'Core 2:' | awk '{print $3}' | cut -c2-3'
      2021-01-08 15:25:19.930 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): response stdout: 58
      2021-01-08 15:25:19.933 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): send command: 'sensors | grep 'Core 3:' | awk '{print $3}' | cut -c2-3'
      2021-01-08 15:25:19.940 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): response stdout: 60
      2021-01-08 15:25:19.943 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): send command: 'qm status 100 | awk '{print substr($0, length($0)-6,7)}''
      2021-01-08 15:25:20.493 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): response stdout: running
      2021-01-08 15:25:20.496 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): send command: 'qm status 110 | awk '{print substr($0, length($0)-6,7)}''
      2021-01-08 15:25:21.050 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): response stdout: running
      2021-01-08 15:25:21.069 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): send command: 'qm status 120 | awk '{print substr($0, length($0)-6,7)}''
      2021-01-08 15:25:21.594 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): response stdout: running
      2021-01-08 15:25:21.601 - info: linux-control.0 (20092) successful received data from Proxmox (192.168.1.102:22)
      2021-01-08 15:25:21.620 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.refresh' subscribed
      2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpdate' subscribed
      2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpgrade' subscribed
      2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.restart' subscribed
      2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.start' subscribed
      2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.stop' subscribed
      2021-01-08 15:25:21.622 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.restart' subscribed
      2021-01-08 15:25:21.622 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.shutdown' subscribed
      2021-01-08 15:25:21.622 - info: linux-control.0 (20092) getting data from ioBroker (192.168.1.170:22, Adapter start)
      2021-01-08 15:25:21.632 - debug: linux-control.0 (20092) [getConnection] Host 'ioBroker' (192.168.1.170:22): using sudo for authentification
      2021-01-08 15:25:21.693 - debug: linux-control.0 (20092) [distributionInfo] ioBroker (192.168.1.170:22): send command: 'cat /etc/os-release'
      2021-01-08 15:25:21.795 - debug: linux-control.0 (20092) [distributionInfo] ioBroker (192.168.1.170:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
      VERSION_ID="10"
      ID=debian
      2021-01-08 15:25:21.797 - debug: linux-control.0 (20092) [distributionInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
      2021-01-08 15:25:21.805 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'sudo -S apt-get update'
      2021-01-08 15:25:21.822 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
      [sudo] Passwort für dirk:
      Leider darf der Benutzer dirk »/usr/bin/apt-get update« als root auf ioBrokerNUC nicht ausführen.
      2021-01-08 15:25:21.822 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s[([\w,\-,\d,\.,~,:,\+]+)]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
      2021-01-08 15:25:22.174 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
      2021-01-08 15:25:22.174 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.newPackages: 0
      2021-01-08 15:25:22.178 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.upgradable: false
      2021-01-08 15:25:22.226 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
      2021-01-08 15:25:22.239 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout: 1609923124
      2021-01-08 15:25:22.239 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.lastUpdate: 1609923124000 -> 06.01.2021 09:52
      2021-01-08 15:25:22.285 - debug: linux-control.0 (20092) [servicesInfo] ioBroker (192.168.1.170:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2021-01-08 15:25:22.293 - debug: linux-control.0 (20092) [servicesInfo] ioBroker (192.168.1.170:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
      ifup@ens18.service,loaded,active,exited, ifup for ens18
      influxdb.service,not-found,inactive,dead, influxdb.service
      iobroker.service,loaded,active,running, ioBroker Server
      mariadb-server.service,not-found,inactive,dead, mariadb-server.service
      mysql-server.service,not-found,inactive,dead, mysql-server.service
      redis.service,not-found,inactive,dead, redis.service
      user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
      user@1000.service,loaded,active,running, User Manager for UID 1000
      2021-01-08 15:25:22.296 - debug: linux-control.0 (20092) [servicesInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
      2021-01-08 15:25:22.432 - debug: linux-control.0 (20092) [needrestart] ioBroker (192.168.1.170:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:25:22.439 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2021-01-08 15:25:22.445 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): response stdout: 27
      2021-01-08 15:25:22.456 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
      2021-01-08 15:25:22.462 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): response stdout: 7978;2289;4997
      2021-01-08 15:25:22.508 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
      2021-01-08 15:25:22.515 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): response stdout: 8189;0;8189
      2021-01-08 15:25:22.517 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
      2021-01-08 15:25:22.529 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): response stdout: 9.0;io.linux-control.0
      2021-01-08 15:25:22.532 - debug: linux-control.0 (20092) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-stop, description: : create button
      2021-01-08 15:25:22.534 - debug: linux-control.0 (20092) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-start, description: : create button
      2021-01-08 15:25:22.535 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): send command: 'du -c /opt/iobroker | tail -1 | awk '{printf $1MB}''
      2021-01-08 15:25:22.851 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): response stdout: 1833800
      2021-01-08 15:25:22.856 - info: linux-control.0 (20092) successful received data from ioBroker (192.168.1.170:22)
      2021-01-08 15:25:22.869 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.refresh' subscribed
      2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpdate' subscribed
      2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpgrade' subscribed
      2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.restart' subscribed
      2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-stop' subscribed
      2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-start' subscribed
      2021-01-08 15:25:22.871 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.start' subscribed
      2021-01-08 15:25:22.871 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.stop' subscribed
      2021-01-08 15:25:22.871 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.restart' subscribed
      2021-01-08 15:25:22.872 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.start' subscribed
      2021-01-08 15:25:22.872 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.stop' subscribed
      2021-01-08 15:25:22.872 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.restart' subscribed
      2021-01-08 15:25:22.873 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.shutdown' subscribed
      2021-01-08 15:25:22.873 - info: linux-control.0 (20092) getting data from Raspberrymatic (192.168.1.171:22, Adapter start)
      2021-01-08 15:25:22.930 - debug: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): send command: 'cat /etc/os-release'
      2021-01-08 15:25:22.975 - debug: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): response stdout: NAME=Buildroot
      VERSION=2.15.5-20151101-2805-g412dbfc5
      ID=buildroot
      VERSION_ID=2020.11
      PRETTY_NAME="Buildroot 2020.11"
      2021-01-08 15:25:22.977 - debug: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): csvToJson result: [{"prop":"NAME","val":"Buildroot"},{"prop":"VERSION","val":"2.15.5-20151101-2805-g412dbfc5"},{"prop":"ID","val":"buildroot"},{"prop":"VERSION_ID","val":"2020.11"},{"prop":"PRETTY_NAME","val":"Buildroot 2020.11"}]
      2021-01-08 15:25:23.023 - warn: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): property 'VERSION_CODENAME' not exist in result!
      2021-01-08 15:25:23.026 - debug: linux-control.0 (20092) [cmdAptUpdate] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:25:23.028 - debug: linux-control.0 (20092) [servicesInfo] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:25:23.033 - debug: linux-control.0 (20092) [needrestart] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:25:23.039 - debug: linux-control.0 (20092) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2021-01-08 15:25:23.045 - debug: linux-control.0 (20092) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): response stdout: 61
      2021-01-08 15:25:23.049 - info: linux-control.0 (20092) successful received data from Raspberrymatic (192.168.1.171:22)
      2021-01-08 15:25:23.062 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.refresh' subscribed
      2021-01-08 15:25:23.062 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpgrade' subscribed
      2021-01-08 15:25:23.062 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpdate' subscribed
      2021-01-08 15:25:23.063 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.restart' subscribed
      2021-01-08 15:25:23.063 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.shutdown' subscribed
      2021-01-08 15:25:23.063 - info: linux-control.0 (20092) getting data from Motioneye (192.168.1.174:22, Adapter start)
      2021-01-08 15:25:23.072 - debug: linux-control.0 (20092) [getConnection] Host 'Motioneye' (192.168.1.174:22): using sudo for authentification
      2021-01-08 15:25:23.153 - debug: linux-control.0 (20092) [distributionInfo] Motioneye (192.168.1.174:22): send command: 'cat /etc/os-release'
      2021-01-08 15:25:23.187 - debug: linux-control.0 (20092) [distributionInfo] Motioneye (192.168.1.174:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
      VERSION_ID="10"
      ID=debian
      2021-01-08 15:25:23.188 - debug: linux-control.0 (20092) [distributionInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
      2021-01-08 15:25:23.238 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'sudo -S apt-get update'
      2021-01-08 15:25:23.255 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
      dirk ist nicht in der sudoers-Datei. Dieser Vorfall wird gemeldet.
      2021-01-08 15:25:23.255 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s[([\w,\-,\d,\.,~,:,\+]+)]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
      2021-01-08 15:25:23.590 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
      2021-01-08 15:25:23.591 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.newPackages: 0
      2021-01-08 15:25:23.594 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.upgradable: false
      2021-01-08 15:25:23.598 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
      2021-01-08 15:25:23.613 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout: 1585325736
      2021-01-08 15:25:23.613 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.lastUpdate: 1585325736000 -> 27.03.2020 17:15
      2021-01-08 15:25:23.656 - debug: linux-control.0 (20092) [servicesInfo] Motioneye (192.168.1.174:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2021-01-08 15:25:23.666 - debug: linux-control.0 (20092) [servicesInfo] Motioneye (192.168.1.174:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
      motion.service,loaded,active,exited, LSB: Start Motion detection
      motioneye.service,loaded,active,running, motionEye Server
      2021-01-08 15:25:23.667 - debug: linux-control.0 (20092) [servicesInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"motion.service","load":"loaded","active":"active","running":"exited","description":"LSB: Start Motion detection"},{"id":"motioneye.service","load":"loaded","active":"active","running":"running","description":"motionEye Server"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
      2021-01-08 15:25:23.792 - debug: linux-control.0 (20092) [needrestart] Motioneye (192.168.1.174:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:25:23.798 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2021-01-08 15:25:23.805 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): response stdout: 28
      2021-01-08 15:25:23.808 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
      2021-01-08 15:25:23.813 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): response stdout: 3946;222;3533
      2021-01-08 15:25:23.815 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
      2021-01-08 15:25:23.824 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): response stdout: 34.1;/usr/bin/motion
      2021-01-08 15:25:23.835 - info: linux-control.0 (20092) successful received data from Motioneye (192.168.1.174:22)
      2021-01-08 15:25:23.852 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.refresh' subscribed
      2021-01-08 15:25:23.852 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpdate' subscribed
      2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpgrade' subscribed
      2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.restart' subscribed
      2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.start' subscribed
      2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.stop' subscribed
      2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.restart' subscribed
      2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.shutdown' subscribed
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
        liv-in-sky @dirk1962 last edited by
        @dirk1962 benutze bitte immer code tag um solche meldungen im forum zu posten
        du kannst den spoiler tag nutzen und im spoiler tag auch noch das code tag reinkopieren
        hier posten
        code tag = </>
        dirk1962 2 Replies Last reply Reply Quote 0
        • dirk1962
          dirk1962 @liv-in-sky last edited by
          @liv-in-sky Sorry!
          2021-01-08 15:25:00.016 - info: host.ioBrokerNUC instance system.adapter.dwd.0 started with pid 20067
          2021-01-08 15:25:01.844 - info: dwd.0 (20067) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.1, js-controller: 3.1.6
          2021-01-08 15:25:07.319 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 (force=false, process=true)
          2021-01-08 15:25:07.319 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 send kill signal
          2021-01-08 15:25:07.321 - info: linux-control.0 (19946) Got terminate signal TERMINATE_YOURSELF
          2021-01-08 15:25:07.322 - info: linux-control.0 (19946) cleaned everything up...
          2021-01-08 15:25:07.322 - info: linux-control.0 (19946) terminating
          2021-01-08 15:25:07.323 - debug: linux-control.0 (19946) Plugin sentry destroyed
          2021-01-08 15:25:07.323 - info: linux-control.0 (19946) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2021-01-08 15:25:07.844 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2021-01-08 15:25:10.351 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 started with pid 20092
          2021-01-08 15:25:10.670 - debug: linux-control.0 (20092) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2021-01-08 15:25:10.692 - debug: linux-control.0 (20092) Objects client ready ... initialize now
          2021-01-08 15:25:10.694 - debug: linux-control.0 (20092) Objects create System PubSub Client
          2021-01-08 15:25:10.694 - debug: linux-control.0 (20092) Objects create User PubSub Client
          2021-01-08 15:25:10.699 - debug: linux-control.0 (20092) Objects client initialize lua scripts
          2021-01-08 15:25:10.708 - debug: linux-control.0 (20092) Objects connected to redis: 127.0.0.1:9001
          2021-01-08 15:25:10.710 - debug: linux-control.0 (20092) objectDB connected
          2021-01-08 15:25:10.711 - debug: linux-control.0 (20092) Redis States: Use Redis connection: 127.0.0.1:9000
          2021-01-08 15:25:10.715 - debug: linux-control.0 (20092) States create User PubSub Client
          2021-01-08 15:25:10.716 - debug: linux-control.0 (20092) States create System PubSub Client
          2021-01-08 15:25:10.726 - debug: linux-control.0 (20092) States connected to redis: 127.0.0.1:9000
          2021-01-08 15:25:10.726 - debug: linux-control.0 (20092) statesDB connected
          2021-01-08 15:25:11.470 - debug: linux-control.0 (20092) Plugin sentry Initialize Plugin (enabled=true)
          2021-01-08 15:25:11.519 - info: linux-control.0 (20092) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.1, js-controller: 3.1.6
          2021-01-08 15:25:11.549 - info: linux-control.0 (20092) getting data from Proxmox (192.168.1.102:22, Adapter start)
          2021-01-08 15:25:11.634 - debug: linux-control.0 (20092) [distributionInfo] Proxmox (192.168.1.102:22): send command: 'cat /etc/os-release'
          2021-01-08 15:25:11.734 - debug: linux-control.0 (20092) [distributionInfo] Proxmox (192.168.1.102:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
          NAME="Debian GNU/Linux"
          VERSION_ID="10"
          VERSION="10 (buster)"
          VERSION_CODENAME=buster
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          2021-01-08 15:25:11.740 - debug: linux-control.0 (20092) [distributionInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
          2021-01-08 15:25:11.749 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get update'
          2021-01-08 15:25:12.164 - info: dwd.0 (20067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2021-01-08 15:25:12.669 - info: host.ioBrokerNUC instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2021-01-08 15:25:13.826 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: Hit:1 http://security.debian.org buster/updates InRelease
          Hit:2 http://security.debian.org/debian-security buster/updates InRelease
          Hit:3 http://ftp.de.debian.org/debian buster InRelease
          Hit:4 http://ftp.de.debian.org/debian buster-updates InRelease
          Hit:5 http://download.proxmox.com/debian/pve buster InRelease
          Reading package lists...
          2021-01-08 15:25:13.827 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s[([\w,\-,\d,\.,~,:,\+]+)]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
          2021-01-08 15:25:14.122 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout:
          2021-01-08 15:25:14.122 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.newPackages: 0
          2021-01-08 15:25:14.168 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.upgradable: false
          2021-01-08 15:25:14.214 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
          ' -W | sort -nr | head -1'
          2021-01-08 15:25:14.228 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: 1609669960
          2021-01-08 15:25:14.229 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.lastUpdate: 1609669960000 -> 03.01.2021 11:32
          2021-01-08 15:25:14.273 - debug: linux-control.0 (20092) [servicesInfo] Proxmox (192.168.1.102:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
          2021-01-08 15:25:14.283 - debug: linux-control.0 (20092) [servicesInfo] Proxmox (192.168.1.102:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
          apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
          apt-daily.service,loaded,inactive,dead, Daily apt download activities
          auditd.service,not-found,inactive,dead, auditd.service
          auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
          blk-availability.service,loaded,active,exited, Availability of block devices
          ceph.service,not-found,inactive,dead, ceph.service
          connman.service,not-found,inactive,dead, connman.service
          console-getty.service,loaded,inactive,dead, Console Getty
          console-screen.service,not-found,inactive,dead, console-screen.service
          console-setup.service,loaded,active,exited, Set console font and keymap
          corosync.service,loaded,inactive,dead, Corosync Cluster Engine
          cron.service,loaded,active,running, Regular background program processing daemon
          dbus.service,loaded,active,running, D-Bus System Message Bus
          display-manager.service,not-found,inactive,dead, display-manager.service
          dm-event.service,loaded,active,running, Device-mapper event daemon
          dracut-mount.service,not-found,inactive,dead, dracut-mount.service
          emergency.service,loaded,inactive,dead, Emergency Shell
          exim4.service,not-found,inactive,dead, exim4.service
          fcoe.service,not-found,inactive,dead, fcoe.service
          getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
          getty@tty1.service,loaded,active,running, Getty on tty1
          glusterd.service,not-found,inactive,dead, glusterd.service
          gssproxy.service,not-found,inactive,dead, gssproxy.service
          ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
          iscsi-shutdown.service,not-found,inactive,dead, iscsi-shutdown.service
          iscsid.service,loaded,active,running, iSCSI initiator daemon (iscsid)
          kbd.service,not-found,inactive,dead, kbd.service
          keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
          kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
          ksmtuned.service,loaded,active,running, Kernel Samepage Merging (KSM) Tuning Daemon
          lm-sensors.service,loaded,active,exited, Initialize hardware monitoring sensors
          logrotate.service,loaded,inactive,dead, Rotate log files
          lvm2-activation.service,not-found,inactive,dead, lvm2-activation.service
          lvm2-lvmpolld.service,loaded,inactive,dead, LVM2 poll daemon
          lvm2-monitor.service,loaded,active,exited, Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
          lvm2-pvscan@259:3.service,loaded,active,exited, LVM event activation on device 259:3
          lxc-monitord.service,loaded,active,running, LXC Container Monitoring Daemon
          lxc-net.service,loaded,active,exited, LXC network bridge setup
          lxc.service,loaded,active,exited, LXC Container Initialization and Autoboot Code
          lxcfs.service,loaded,active,running, FUSE filesystem for LXC
          man-db.service,loaded,inactive,dead, Daily man-db regeneration
          networking.service,loaded,active,exited, Raise network interfaces
          NetworkManager.service,not-found,inactive,dead, NetworkManager.service
          nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
          nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
          nfs-kernel-server.service,not-found,inactive,dead, nfs-kernel-server.service
          nfs-server.service,not-found,inactive,dead, nfs-server.service
          nfs-utils.service,loaded,inactive,dead, NFS server and client services
          open-iscsi.service,loaded,active,exited, Login to default iSCSI targets
          plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
          plymouth-start.service,not-found,inactive,dead, plymouth-start.service
          postfix.service,loaded,active,exited, Postfix Mail Transport Agent
          postfix@-.service,loaded,active,running, Postfix Mail Transport Agent (instance -)
          pve-cluster.service,loaded,active,running, The Proxmox VE cluster filesystem
          pve-daily-update.service,loaded,inactive,dead, Daily PVE download activities
          pve-firewall.service,loaded,active,running, Proxmox VE firewall
          pve-guests.service,loaded,active,exited, PVE guests
          pve-ha-crm.service,loaded,active,running, PVE Cluster HA Resource Manager Daemon
          pve-ha-lrm.service,loaded,active,running, PVE Local HA Resource Manager Daemon
          pve-lxc-syscalld.service,loaded,active,running, Proxmox VE LXC Syscall Daemon
          pvebanner.service,loaded,active,exited, Proxmox VE Login Banner
          pvedaemon.service,loaded,active,running, PVE API Daemon
          pvefw-logger.service,loaded,active,running, Proxmox VE firewall logger
          pvenetcommit.service,loaded,active,exited, Commit Proxmox VE network changes
          pveproxy.service,loaded,active,running, PVE API Proxy Server
          pvesr.service,loaded,inactive,dead, Proxmox VE replication runner
          pvestatd.service,loaded,active,running, PVE Status Daemon
          qmeventd.service,loaded,active,running, PVE Qemu Event Daemon
          rbdmap.service,loaded,active,exited, Map RBD devices
          rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
          rescue.service,loaded,inactive,dead, Rescue Shell
          rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
          rpc-statd-notify.service,loaded,inactive,dead, Notify NFS peers of a restart
          rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
          rpcbind.service,loaded,active,running, RPC bind portmap service
          rrdcached.service,loaded,active,running, LSB: start or stop rrdcached
          rsync.service,loaded,inactive,dead, fast remote file copy program daemon
          rsyslog.service,loaded,active,running, System Logging Service
          sendmail.service,not-found,inactive,dead, sendmail.service
          smartmontools.service,loaded,active,running, Self Monitoring and Reporting Technology (SMART) Daemon
          smb.service,not-found,inactive,dead, smb.service
          spiceproxy.service,loaded,active,running, PVE SPICE Proxy Server
          ssh.service,loaded,active,running, OpenBSD Secure Shell server
          systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
          systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
          systemd-backlight@backlight:acpi_video0.service,loaded,active,exited, Load/Save Screen Backlight Brightness of backlight:acpi_video0
          systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
          systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
          systemd-fsck@dev-disk-by\x2duuid-D782\x2dA871.service,loaded,active,exited, File System Check on /dev/disk/by-uuid/D782-A871
          systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
          systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
          systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
          systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
          systemd-journald.service,loaded,active,running, Journal Service
          systemd-logind.service,loaded,active,running, Login Service
          systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
          systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
          systemd-networkd.service,loaded,inactive,dead, Network Service
          systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
          systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
          systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
          systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
          systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
          systemd-sysusers.service,loaded,active,exited, Create System Users
          systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
          systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
          systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
          systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
          systemd-udev-settle.service,loaded,active,exited, udev Wait for Complete Device Initialization
          systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
          systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
          systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
          systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
          systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
          systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
          systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
          user-runtime-dir@0.service,loaded,active,exited, User Runtime Directory /run/user/0
          user@0.service,loaded,active,running, User Manager for UID 0
          watchdog-mux.service,loaded,active,running, Proxmox VE watchdog multiplexer
          zfs-import-cache.service,loaded,active,exited, Import ZFS pools by cache file
          zfs-mount.service,loaded,active,exited, Mount ZFS filesystems
          zfs-share.service,loaded,active,exited, ZFS file system shares
          zfs-volume-wait.service,loaded,active,exited, Wait for ZFS Volume (zvol) links in /dev
          zfs-zed.service,loaded,active,running, ZFS Event Daemon (zed)
          2021-01-08 15:25:14.285 - debug: linux-control.0 (20092) [servicesInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"blk-availability.service","load":"loaded","active":"active","running":"exited","description":"Availability of block devices"},{"id":"ceph.service","load":"not-found","active":"inactive","running":"dead","description":"ceph.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-getty.service","load":"loaded","active":"inactive","running":"dead","description":"Console Getty"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"corosync.service","load":"loaded","active":"inactive","running":"dead","description":"Corosync Cluster Engine"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dm-event.service","load":"loaded","active":"active","running":"running","description":"Device-mapper event daemon"},{"id":"dracut-mount.service","load":"not-found","active":"inactive","running":"dead","description":"dracut-mount.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"not-found","active":"inactive","running":"dead","description":"exim4.service"},{"id":"fcoe.service","load":"not-found","active":"inactive","running":"dead","description":"fcoe.service"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"glusterd.service","load":"not-found","active":"inactive","running":"dead","description":"glusterd.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"iscsi-shutdown.service","load":"not-found","active":"inactive","running":"dead","description":"iscsi-shutdown.service"},{"id":"iscsid.service","load":"loaded","active":"active","running":"running","description":"iSCSI initiator daemon (iscsid)"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"ksmtuned.service","load":"loaded","active":"active","running":"running","description":"Kernel Samepage Merging (KSM) Tuning Daemon"},{"id":"lm-sensors.service","load":"loaded","active":"active","running":"exited","description":"Initialize hardware monitoring sensors"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"lvm2-activation.service","load":"not-found","active":"inactive","running":"dead","description":"lvm2-activation.service"},{"id":"lvm2-lvmpolld.service","load":"loaded","active":"inactive","running":"dead","description":"LVM2 poll daemon"},{"id":"lvm2-monitor.service","load":"loaded","active":"active","running":"exited","description":"Monitoring of LVM2 mirrors","field6":"snapshots etc. using dmeventd or progress polling"},{"id":"lvm2-pvscan@259:3.service","load":"loaded","active":"active","running":"exited","description":"LVM event activation on device 259:3"},{"id":"lxc-monitord.service","load":"loaded","active":"active","running":"running","description":"LXC Container Monitoring Daemon"},{"id":"lxc-net.service","load":"loaded","active":"active","running":"exited","description":"LXC network bridge setup"},{"id":"lxc.service","load":"loaded","active":"active","running":"exited","description":"LXC Container Initialization and Autoboot Code"},{"id":"lxcfs.service","load":"loaded","active":"active","running":"running","description":"FUSE filesystem for LXC"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-kernel-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-kernel-server.service"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"open-iscsi.service","load":"loaded","active":"active","running":"exited","description":"Login to default iSCSI targets"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postfix.service","load":"loaded","active":"active","running":"exited","description":"Postfix Mail Transport Agent"},{"id":"postfix@-.service","load":"loaded","active":"active","running":"running","description":"Postfix Mail Transport Agent (instance -)"},{"id":"pve-cluster.service","load":"loaded","active":"active","running":"running","description":"The Proxmox VE cluster filesystem"},{"id":"pve-daily-update.service","load":"loaded","active":"inactive","running":"dead","description":"Daily PVE download activities"},{"id":"pve-firewall.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall"},{"id":"pve-guests.service","load":"loaded","active":"active","running":"exited","description":"PVE guests"},{"id":"pve-ha-crm.service","load":"loaded","active":"active","running":"running","description":"PVE Cluster HA Resource Manager Daemon"},{"id":"pve-ha-lrm.service","load":"loaded","active":"active","running":"running","description":"PVE Local HA Resource Manager Daemon"},{"id":"pve-lxc-syscalld.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE LXC Syscall Daemon"},{"id":"pvebanner.service","load":"loaded","active":"active","running":"exited","description":"Proxmox VE Login Banner"},{"id":"pvedaemon.service","load":"loaded","active":"active","running":"running","description":"PVE API Daemon"},{"id":"pvefw-logger.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall logger"},{"id":"pvenetcommit.service","load":"loaded","active":"active","running":"exited","description":"Commit Proxmox VE network changes"},{"id":"pveproxy.service","load":"loaded","active":"active","running":"running","description":"PVE API Proxy Server"},{"id":"pvesr.service","load":"loaded","active":"inactive","running":"dead","description":"Proxmox VE replication runner"},{"id":"pvestatd.service","load":"loaded","active":"active","running":"running","description":"PVE Status Daemon"},{"id":"qmeventd.service","load":"loaded","active":"active","running":"running","description":"PVE Qemu Event Daemon"},{"id":"rbdmap.service","load":"loaded","active":"active","running":"exited","description":"Map RBD devices"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-statd-notify.service","load":"loaded","active":"inactive","running":"dead","description":"Notify NFS peers of a restart"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rrdcached.service","load":"loaded","active":"active","running":"running","description":"LSB: start or stop rrdcached"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"sendmail.service","load":"not-found","active":"inactive","running":"dead","description":"sendmail.service"},{"id":"smartmontools.service","load":"loaded","active":"active","running":"running","description":"Self Monitoring and Reporting Technology (SMART) Daemon"},{"id":"smb.service","load":"not-found","active":"inactive","running":"dead","description":"smb.service"},{"id":"spiceproxy.service","load":"loaded","active":"active","running":"running","description":"PVE SPICE Proxy Server"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-backlight@backlight:acpi_video0.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Screen Backlight Brightness of backlight:acpi_video0"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2duuid-D782\\x2dA871.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-uuid/D782-A871"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-settle.service","load":"loaded","active":"active","running":"exited","description":"udev Wait for Complete Device Initialization"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@0.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/0"},{"id":"user@0.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 0"},{"id":"watchdog-mux.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE watchdog multiplexer"},{"id":"zfs-import-cache.service","load":"loaded","active":"active","running":"exited","description":"Import ZFS pools by cache file"},{"id":"zfs-mount.service","load":"loaded","active":"active","running":"exited","description":"Mount ZFS filesystems"},{"id":"zfs-share.service","load":"loaded","active":"active","running":"exited","description":"ZFS file system shares"},{"id":"zfs-volume-wait.service","load":"loaded","active":"active","running":"exited","description":"Wait for ZFS Volume (zvol) links in /dev"},{"id":"zfs-zed.service","load":"loaded","active":"active","running":"running","description":"ZFS Event Daemon (zed)"}]
          2021-01-08 15:25:14.500 - debug: linux-control.0 (20092) [needrestart] Proxmox (192.168.1.102:22): no datapoints selected -> removing existing datapoints
          2021-01-08 15:25:14.507 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/log/ | awk '{ print $1 /1024 }''
          2021-01-08 15:25:14.516 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 28.6914
          2021-01-08 15:25:14.518 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.size: 28.69 MB
          2021-01-08 15:25:14.559 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/log/ -name "*" | wc -l'
          2021-01-08 15:25:14.567 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1382
          2021-01-08 15:25:14.569 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.files: 1382 Dateien
          2021-01-08 15:25:14.611 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/log/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
          2021-01-08 15:25:15.627 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610115911
          2021-01-08 15:25:15.629 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.lastChange: 1610115911000 -> 08.01.2021 15:25
          2021-01-08 15:25:15.671 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/ | awk '{ print $1 /1024 }''
          2021-01-08 15:25:15.701 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1899.28
          2021-01-08 15:25:15.702 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.size: 1899.28 MB
          2021-01-08 15:25:15.748 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/ -name "*" | wc -l'
          2021-01-08 15:25:15.773 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 5349
          2021-01-08 15:25:15.777 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.files: 5349 Dateien
          2021-01-08 15:25:15.821 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
          2021-01-08 15:25:19.713 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610115919
          2021-01-08 15:25:19.715 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.lastChange: 1610115919000 -> 08.01.2021 15:25
          2021-01-08 15:25:19.760 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
          2021-01-08 15:25:19.767 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): response stdout: 14
          2021-01-08 15:25:19.771 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
          2021-01-08 15:25:19.777 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): response stdout: 31986;7014;24434
          2021-01-08 15:25:19.820 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
          2021-01-08 15:25:19.827 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): response stdout: 8191;0;8191
          2021-01-08 15:25:19.829 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
          2021-01-08 15:25:19.844 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): response stdout: 39.6;/usr/bin/kvm
          2021-01-08 15:25:19.889 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): send command: 'sensors | grep Package -m 1 | awk '{print $4}' | awk '{print substr($1, length($0)-6,2)}''
          2021-01-08 15:25:19.898 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): response stdout: 58
          2021-01-08 15:25:19.901 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): send command: 'sensors | grep 'Core 0:' | awk '{print $3}' | cut -c2-3'
          2021-01-08 15:25:19.909 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): response stdout: 57
          2021-01-08 15:25:19.911 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): send command: 'sensors | grep 'Core 1:' | awk '{print $3}' | cut -c2-3'
          2021-01-08 15:25:19.919 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): response stdout: 57
          2021-01-08 15:25:19.922 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): send command: 'sensors | grep 'Core 2:' | awk '{print $3}' | cut -c2-3'
          2021-01-08 15:25:19.930 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): response stdout: 58
          2021-01-08 15:25:19.933 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): send command: 'sensors | grep 'Core 3:' | awk '{print $3}' | cut -c2-3'
          2021-01-08 15:25:19.940 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): response stdout: 60
          2021-01-08 15:25:19.943 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): send command: 'qm status 100 | awk '{print substr($0, length($0)-6,7)}''
          2021-01-08 15:25:20.493 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): response stdout: running
          2021-01-08 15:25:20.496 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): send command: 'qm status 110 | awk '{print substr($0, length($0)-6,7)}''
          2021-01-08 15:25:21.050 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): response stdout: running
          2021-01-08 15:25:21.069 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): send command: 'qm status 120 | awk '{print substr($0, length($0)-6,7)}''
          2021-01-08 15:25:21.594 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): response stdout: running
          2021-01-08 15:25:21.601 - info: linux-control.0 (20092) successful received data from Proxmox (192.168.1.102:22)
          2021-01-08 15:25:21.620 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.refresh' subscribed
          2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpdate' subscribed
          2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpgrade' subscribed
          2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.restart' subscribed
          2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.start' subscribed
          2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.stop' subscribed
          2021-01-08 15:25:21.622 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.restart' subscribed
          2021-01-08 15:25:21.622 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.shutdown' subscribed
          2021-01-08 15:25:21.622 - info: linux-control.0 (20092) getting data from ioBroker (192.168.1.170:22, Adapter start)
          2021-01-08 15:25:21.632 - debug: linux-control.0 (20092) [getConnection] Host 'ioBroker' (192.168.1.170:22): using sudo for authentification
          2021-01-08 15:25:21.693 - debug: linux-control.0 (20092) [distributionInfo] ioBroker (192.168.1.170:22): send command: 'cat /etc/os-release'
          2021-01-08 15:25:21.795 - debug: linux-control.0 (20092) [distributionInfo] ioBroker (192.168.1.170:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
          VERSION_ID="10"
          ID=debian
          2021-01-08 15:25:21.797 - debug: linux-control.0 (20092) [distributionInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
          2021-01-08 15:25:21.805 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'sudo -S apt-get update'
          2021-01-08 15:25:21.822 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
          [sudo] Passwort für dirk:
          Leider darf der Benutzer dirk »/usr/bin/apt-get update« als root auf ioBrokerNUC nicht ausführen.
          2021-01-08 15:25:21.822 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s[([\w,\-,\d,\.,~,:,\+]+)]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
          2021-01-08 15:25:22.174 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
          2021-01-08 15:25:22.174 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.newPackages: 0
          2021-01-08 15:25:22.178 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.upgradable: false
          2021-01-08 15:25:22.226 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
          2021-01-08 15:25:22.239 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout: 1609923124
          2021-01-08 15:25:22.239 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.lastUpdate: 1609923124000 -> 06.01.2021 09:52
          2021-01-08 15:25:22.285 - debug: linux-control.0 (20092) [servicesInfo] ioBroker (192.168.1.170:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
          2021-01-08 15:25:22.293 - debug: linux-control.0 (20092) [servicesInfo] ioBroker (192.168.1.170:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
          ifup@ens18.service,loaded,active,exited, ifup for ens18
          influxdb.service,not-found,inactive,dead, influxdb.service
          iobroker.service,loaded,active,running, ioBroker Server
          mariadb-server.service,not-found,inactive,dead, mariadb-server.service
          mysql-server.service,not-found,inactive,dead, mysql-server.service
          redis.service,not-found,inactive,dead, redis.service
          user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
          user@1000.service,loaded,active,running, User Manager for UID 1000
          2021-01-08 15:25:22.296 - debug: linux-control.0 (20092) [servicesInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
          2021-01-08 15:25:22.432 - debug: linux-control.0 (20092) [needrestart] ioBroker (192.168.1.170:22): no datapoints selected -> removing existing datapoints
          2021-01-08 15:25:22.439 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
          2021-01-08 15:25:22.445 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): response stdout: 27
          2021-01-08 15:25:22.456 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
          2021-01-08 15:25:22.462 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): response stdout: 7978;2289;4997
          2021-01-08 15:25:22.508 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
          2021-01-08 15:25:22.515 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): response stdout: 8189;0;8189
          2021-01-08 15:25:22.517 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
          2021-01-08 15:25:22.529 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): response stdout: 9.0;io.linux-control.0
          2021-01-08 15:25:22.532 - debug: linux-control.0 (20092) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-stop, description: : create button
          2021-01-08 15:25:22.534 - debug: linux-control.0 (20092) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-start, description: : create button
          2021-01-08 15:25:22.535 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): send command: 'du -c /opt/iobroker | tail -1 | awk '{printf $1MB}''
          2021-01-08 15:25:22.851 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): response stdout: 1833800
          2021-01-08 15:25:22.856 - info: linux-control.0 (20092) successful received data from ioBroker (192.168.1.170:22)
          2021-01-08 15:25:22.869 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.refresh' subscribed
          2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpdate' subscribed
          2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpgrade' subscribed
          2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.restart' subscribed
          2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-stop' subscribed
          2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-start' subscribed
          2021-01-08 15:25:22.871 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.start' subscribed
          2021-01-08 15:25:22.871 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.stop' subscribed
          2021-01-08 15:25:22.871 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.restart' subscribed
          2021-01-08 15:25:22.872 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.start' subscribed
          2021-01-08 15:25:22.872 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.stop' subscribed
          2021-01-08 15:25:22.872 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.restart' subscribed
          2021-01-08 15:25:22.873 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.shutdown' subscribed
          2021-01-08 15:25:22.873 - info: linux-control.0 (20092) getting data from Raspberrymatic (192.168.1.171:22, Adapter start)
          2021-01-08 15:25:22.930 - debug: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): send command: 'cat /etc/os-release'
          2021-01-08 15:25:22.975 - debug: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): response stdout: NAME=Buildroot
          VERSION=2.15.5-20151101-2805-g412dbfc5
          ID=buildroot
          VERSION_ID=2020.11
          PRETTY_NAME="Buildroot 2020.11"
          2021-01-08 15:25:22.977 - debug: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): csvToJson result: [{"prop":"NAME","val":"Buildroot"},{"prop":"VERSION","val":"2.15.5-20151101-2805-g412dbfc5"},{"prop":"ID","val":"buildroot"},{"prop":"VERSION_ID","val":"2020.11"},{"prop":"PRETTY_NAME","val":"Buildroot 2020.11"}]
          2021-01-08 15:25:23.023 - warn: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): property 'VERSION_CODENAME' not exist in result!
          2021-01-08 15:25:23.026 - debug: linux-control.0 (20092) [cmdAptUpdate] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
          2021-01-08 15:25:23.028 - debug: linux-control.0 (20092) [servicesInfo] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
          2021-01-08 15:25:23.033 - debug: linux-control.0 (20092) [needrestart] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
          2021-01-08 15:25:23.039 - debug: linux-control.0 (20092) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
          2021-01-08 15:25:23.045 - debug: linux-control.0 (20092) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): response stdout: 61
          2021-01-08 15:25:23.049 - info: linux-control.0 (20092) successful received data from Raspberrymatic (192.168.1.171:22)
          2021-01-08 15:25:23.062 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.refresh' subscribed
          2021-01-08 15:25:23.062 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpgrade' subscribed
          2021-01-08 15:25:23.062 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpdate' subscribed
          2021-01-08 15:25:23.063 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.restart' subscribed
          2021-01-08 15:25:23.063 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.shutdown' subscribed
          2021-01-08 15:25:23.063 - info: linux-control.0 (20092) getting data from Motioneye (192.168.1.174:22, Adapter start)
          2021-01-08 15:25:23.072 - debug: linux-control.0 (20092) [getConnection] Host 'Motioneye' (192.168.1.174:22): using sudo for authentification
          2021-01-08 15:25:23.153 - debug: linux-control.0 (20092) [distributionInfo] Motioneye (192.168.1.174:22): send command: 'cat /etc/os-release'
          2021-01-08 15:25:23.187 - debug: linux-control.0 (20092) [distributionInfo] Motioneye (192.168.1.174:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
          VERSION_ID="10"
          ID=debian
          2021-01-08 15:25:23.188 - debug: linux-control.0 (20092) [distributionInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
          2021-01-08 15:25:23.238 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'sudo -S apt-get update'
          2021-01-08 15:25:23.255 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
          dirk ist nicht in der sudoers-Datei. Dieser Vorfall wird gemeldet.
          2021-01-08 15:25:23.255 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s[([\w,\-,\d,\.,~,:,\+]+)]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
          2021-01-08 15:25:23.590 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
          2021-01-08 15:25:23.591 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.newPackages: 0
          2021-01-08 15:25:23.594 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.upgradable: false
          2021-01-08 15:25:23.598 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
          2021-01-08 15:25:23.613 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout: 1585325736
          2021-01-08 15:25:23.613 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.lastUpdate: 1585325736000 -> 27.03.2020 17:15
          2021-01-08 15:25:23.656 - debug: linux-control.0 (20092) [servicesInfo] Motioneye (192.168.1.174:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
          2021-01-08 15:25:23.666 - debug: linux-control.0 (20092) [servicesInfo] Motioneye (192.168.1.174:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
          motion.service,loaded,active,exited, LSB: Start Motion detection
          motioneye.service,loaded,active,running, motionEye Server
          2021-01-08 15:25:23.667 - debug: linux-control.0 (20092) [servicesInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"motion.service","load":"loaded","active":"active","running":"exited","description":"LSB: Start Motion detection"},{"id":"motioneye.service","load":"loaded","active":"active","running":"running","description":"motionEye Server"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
          2021-01-08 15:25:23.792 - debug: linux-control.0 (20092) [needrestart] Motioneye (192.168.1.174:22): no datapoints selected -> removing existing datapoints
          2021-01-08 15:25:23.798 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
          2021-01-08 15:25:23.805 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): response stdout: 28
          2021-01-08 15:25:23.808 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
          2021-01-08 15:25:23.813 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): response stdout: 3946;222;3533
          2021-01-08 15:25:23.815 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
          2021-01-08 15:25:23.824 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): response stdout: 34.1;/usr/bin/motion
          2021-01-08 15:25:23.835 - info: linux-control.0 (20092) successful received data from Motioneye (192.168.1.174:22)
          2021-01-08 15:25:23.852 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.refresh' subscribed
          2021-01-08 15:25:23.852 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpdate' subscribed
          2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpgrade' subscribed
          2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.restart' subscribed
          2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.start' subscribed
          2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.stop' subscribed
          2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.restart' subscribed
          2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.shutdown' subscribed
          • dirk1962
            dirk1962 @liv-in-sky last edited by
            @liv-in-sky @Scrounger Ich hatte den Ordner Befehl für Motioneye wieder rausgenommen. In diesem log ist er wieder mit drin.
            2021-01-08 15:49:06.639 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 (force=false, process=true)
            2021-01-08 15:49:06.642 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 send kill signal
            2021-01-08 15:49:06.644 - info: linux-control.0 (21211) Got terminate signal TERMINATE_YOURSELF
            2021-01-08 15:49:06.645 - info: linux-control.0 (21211) cleaned everything up...
            2021-01-08 15:49:06.645 - info: linux-control.0 (21211) terminating
            2021-01-08 15:49:06.645 - debug: linux-control.0 (21211) Plugin sentry destroyed
            2021-01-08 15:49:06.645 - info: linux-control.0 (21211) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-01-08 15:49:07.168 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-01-08 15:49:09.673 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 started with pid 21312
            2021-01-08 15:49:10.004 - debug: linux-control.0 (21312) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2021-01-08 15:49:10.030 - debug: linux-control.0 (21312) Objects client ready ... initialize now
            2021-01-08 15:49:10.031 - debug: linux-control.0 (21312) Objects create System PubSub Client
            2021-01-08 15:49:10.032 - debug: linux-control.0 (21312) Objects create User PubSub Client
            2021-01-08 15:49:10.032 - debug: linux-control.0 (21312) Objects client initialize lua scripts
            2021-01-08 15:49:10.041 - debug: linux-control.0 (21312) Objects connected to redis: 127.0.0.1:9001
            2021-01-08 15:49:10.043 - debug: linux-control.0 (21312) objectDB connected
            2021-01-08 15:49:10.044 - debug: linux-control.0 (21312) Redis States: Use Redis connection: 127.0.0.1:9000
            2021-01-08 15:49:10.049 - debug: linux-control.0 (21312) States create User PubSub Client
            2021-01-08 15:49:10.050 - debug: linux-control.0 (21312) States create System PubSub Client
            2021-01-08 15:49:10.057 - debug: linux-control.0 (21312) States connected to redis: 127.0.0.1:9000
            2021-01-08 15:49:10.058 - debug: linux-control.0 (21312) statesDB connected
            2021-01-08 15:49:11.034 - debug: linux-control.0 (21312) Plugin sentry Initialize Plugin (enabled=true)
            2021-01-08 15:49:11.082 - info: linux-control.0 (21312) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.1, js-controller: 3.1.6
            2021-01-08 15:49:11.114 - info: linux-control.0 (21312) getting data from Proxmox (192.168.1.102:22, Adapter start)
            2021-01-08 15:49:11.199 - debug: linux-control.0 (21312) [distributionInfo] Proxmox (192.168.1.102:22): send command: 'cat /etc/os-release'
            2021-01-08 15:49:11.290 - debug: linux-control.0 (21312) [distributionInfo] Proxmox (192.168.1.102:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
            NAME="Debian GNU/Linux"
            VERSION_ID="10"
            VERSION="10 (buster)"
            VERSION_CODENAME=buster
            ID=debian
            HOME_URL="https://www.debian.org/"
            SUPPORT_URL="https://www.debian.org/support"
            BUG_REPORT_URL="https://bugs.debian.org/"
            2021-01-08 15:49:11.296 - debug: linux-control.0 (21312) [distributionInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
            2021-01-08 15:49:11.307 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get update'
            2021-01-08 15:49:13.285 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: Hit:1 http://security.debian.org buster/updates InRelease
            Hit:2 http://security.debian.org/debian-security buster/updates InRelease
            Hit:3 http://download.proxmox.com/debian/pve buster InRelease
            Hit:4 http://ftp.de.debian.org/debian buster InRelease
            Hit:5 http://ftp.de.debian.org/debian buster-updates InRelease
            Reading package lists...
            2021-01-08 15:49:13.285 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s[([\w,\-,\d,\.,~,:,\+]+)]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
            2021-01-08 15:49:13.577 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout:
            2021-01-08 15:49:13.577 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.newPackages: 0
            2021-01-08 15:49:13.580 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.upgradable: false
            2021-01-08 15:49:13.626 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
            ' -W | sort -nr | head -1'
            2021-01-08 15:49:13.640 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: 1609669960
            2021-01-08 15:49:13.640 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.lastUpdate: 1609669960000 -> 03.01.2021 11:32
            2021-01-08 15:49:13.685 - debug: linux-control.0 (21312) [servicesInfo] Proxmox (192.168.1.102:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
            2021-01-08 15:49:13.695 - debug: linux-control.0 (21312) [servicesInfo] Proxmox (192.168.1.102:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
            apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
            apt-daily.service,loaded,inactive,dead, Daily apt download activities
            auditd.service,not-found,inactive,dead, auditd.service
            auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
            blk-availability.service,loaded,active,exited, Availability of block devices
            ceph.service,not-found,inactive,dead, ceph.service
            connman.service,not-found,inactive,dead, connman.service
            console-getty.service,loaded,inactive,dead, Console Getty
            console-screen.service,not-found,inactive,dead, console-screen.service
            console-setup.service,loaded,active,exited, Set console font and keymap
            corosync.service,loaded,inactive,dead, Corosync Cluster Engine
            cron.service,loaded,active,running, Regular background program processing daemon
            dbus.service,loaded,active,running, D-Bus System Message Bus
            display-manager.service,not-found,inactive,dead, display-manager.service
            dm-event.service,loaded,active,running, Device-mapper event daemon
            dracut-mount.service,not-found,inactive,dead, dracut-mount.service
            emergency.service,loaded,inactive,dead, Emergency Shell
            exim4.service,not-found,inactive,dead, exim4.service
            fcoe.service,not-found,inactive,dead, fcoe.service
            getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
            getty@tty1.service,loaded,active,running, Getty on tty1
            glusterd.service,not-found,inactive,dead, glusterd.service
            gssproxy.service,not-found,inactive,dead, gssproxy.service
            ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
            iscsi-shutdown.service,not-found,inactive,dead, iscsi-shutdown.service
            iscsid.service,loaded,active,running, iSCSI initiator daemon (iscsid)
            kbd.service,not-found,inactive,dead, kbd.service
            keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
            kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
            ksmtuned.service,loaded,active,running, Kernel Samepage Merging (KSM) Tuning Daemon
            lm-sensors.service,loaded,active,exited, Initialize hardware monitoring sensors
            logrotate.service,loaded,inactive,dead, Rotate log files
            lvm2-activation.service,not-found,inactive,dead, lvm2-activation.service
            lvm2-lvmpolld.service,loaded,inactive,dead, LVM2 poll daemon
            lvm2-monitor.service,loaded,active,exited, Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
            lvm2-pvscan@259:3.service,loaded,active,exited, LVM event activation on device 259:3
            lxc-monitord.service,loaded,active,running, LXC Container Monitoring Daemon
            lxc-net.service,loaded,active,exited, LXC network bridge setup
            lxc.service,loaded,active,exited, LXC Container Initialization and Autoboot Code
            lxcfs.service,loaded,active,running, FUSE filesystem for LXC
            man-db.service,loaded,inactive,dead, Daily man-db regeneration
            networking.service,loaded,active,exited, Raise network interfaces
            NetworkManager.service,not-found,inactive,dead, NetworkManager.service
            nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
            nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
            nfs-kernel-server.service,not-found,inactive,dead, nfs-kernel-server.service
            nfs-server.service,not-found,inactive,dead, nfs-server.service
            nfs-utils.service,loaded,inactive,dead, NFS server and client services
            open-iscsi.service,loaded,active,exited, Login to default iSCSI targets
            plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
            plymouth-start.service,not-found,inactive,dead, plymouth-start.service
            postfix.service,loaded,active,exited, Postfix Mail Transport Agent
            postfix@-.service,loaded,active,running, Postfix Mail Transport Agent (instance -)
            pve-cluster.service,loaded,active,running, The Proxmox VE cluster filesystem
            pve-daily-update.service,loaded,inactive,dead, Daily PVE download activities
            pve-firewall.service,loaded,active,running, Proxmox VE firewall
            pve-guests.service,loaded,active,exited, PVE guests
            pve-ha-crm.service,loaded,active,running, PVE Cluster HA Resource Manager Daemon
            pve-ha-lrm.service,loaded,active,running, PVE Local HA Resource Manager Daemon
            pve-lxc-syscalld.service,loaded,active,running, Proxmox VE LXC Syscall Daemon
            pvebanner.service,loaded,active,exited, Proxmox VE Login Banner
            pvedaemon.service,loaded,active,running, PVE API Daemon
            pvefw-logger.service,loaded,active,running, Proxmox VE firewall logger
            pvenetcommit.service,loaded,active,exited, Commit Proxmox VE network changes
            pveproxy.service,loaded,active,running, PVE API Proxy Server
            pvesr.service,loaded,inactive,dead, Proxmox VE replication runner
            pvestatd.service,loaded,active,running, PVE Status Daemon
            qmeventd.service,loaded,active,running, PVE Qemu Event Daemon
            rbdmap.service,loaded,active,exited, Map RBD devices
            rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
            rescue.service,loaded,inactive,dead, Rescue Shell
            rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
            rpc-statd-notify.service,loaded,inactive,dead, Notify NFS peers of a restart
            rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
            rpcbind.service,loaded,active,running, RPC bind portmap service
            rrdcached.service,loaded,active,running, LSB: start or stop rrdcached
            rsync.service,loaded,inactive,dead, fast remote file copy program daemon
            rsyslog.service,loaded,active,running, System Logging Service
            sendmail.service,not-found,inactive,dead, sendmail.service
            smartmontools.service,loaded,active,running, Self Monitoring and Reporting Technology (SMART) Daemon
            smb.service,not-found,inactive,dead, smb.service
            spiceproxy.service,loaded,active,running, PVE SPICE Proxy Server
            ssh.service,loaded,active,running, OpenBSD Secure Shell server
            systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
            systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
            systemd-backlight@backlight:acpi_video0.service,loaded,active,exited, Load/Save Screen Backlight Brightness of backlight:acpi_video0
            systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
            systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
            systemd-fsck@dev-disk-by\x2duuid-D782\x2dA871.service,loaded,active,exited, File System Check on /dev/disk/by-uuid/D782-A871
            systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
            systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
            systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
            systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
            systemd-journald.service,loaded,active,running, Journal Service
            systemd-logind.service,loaded,active,running, Login Service
            systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
            systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
            systemd-networkd.service,loaded,inactive,dead, Network Service
            systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
            systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
            systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
            systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
            systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
            systemd-sysusers.service,loaded,active,exited, Create System Users
            systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
            systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
            systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
            systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
            systemd-udev-settle.service,loaded,active,exited, udev Wait for Complete Device Initialization
            systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
            systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
            systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
            systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
            systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
            systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
            systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
            user-runtime-dir@0.service,loaded,active,exited, User Runtime Directory /run/user/0
            user@0.service,loaded,active,running, User Manager for UID 0
            watchdog-mux.service,loaded,active,running, Proxmox VE watchdog multiplexer
            zfs-import-cache.service,loaded,active,exited, Import ZFS pools by cache file
            zfs-mount.service,loaded,active,exited, Mount ZFS filesystems
            zfs-share.service,loaded,active,exited, ZFS file system shares
            zfs-volume-wait.service,loaded,active,exited, Wait for ZFS Volume (zvol) links in /dev
            zfs-zed.service,loaded,active,running, ZFS Event Daemon (zed)
            2021-01-08 15:49:13.698 - debug: linux-control.0 (21312) [servicesInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"blk-availability.service","load":"loaded","active":"active","running":"exited","description":"Availability of block devices"},{"id":"ceph.service","load":"not-found","active":"inactive","running":"dead","description":"ceph.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-getty.service","load":"loaded","active":"inactive","running":"dead","description":"Console Getty"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"corosync.service","load":"loaded","active":"inactive","running":"dead","description":"Corosync Cluster Engine"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dm-event.service","load":"loaded","active":"active","running":"running","description":"Device-mapper event daemon"},{"id":"dracut-mount.service","load":"not-found","active":"inactive","running":"dead","description":"dracut-mount.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"not-found","active":"inactive","running":"dead","description":"exim4.service"},{"id":"fcoe.service","load":"not-found","active":"inactive","running":"dead","description":"fcoe.service"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"glusterd.service","load":"not-found","active":"inactive","running":"dead","description":"glusterd.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"iscsi-shutdown.service","load":"not-found","active":"inactive","running":"dead","description":"iscsi-shutdown.service"},{"id":"iscsid.service","load":"loaded","active":"active","running":"running","description":"iSCSI initiator daemon (iscsid)"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"ksmtuned.service","load":"loaded","active":"active","running":"running","description":"Kernel Samepage Merging (KSM) Tuning Daemon"},{"id":"lm-sensors.service","load":"loaded","active":"active","running":"exited","description":"Initialize hardware monitoring sensors"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"lvm2-activation.service","load":"not-found","active":"inactive","running":"dead","description":"lvm2-activation.service"},{"id":"lvm2-lvmpolld.service","load":"loaded","active":"inactive","running":"dead","description":"LVM2 poll daemon"},{"id":"lvm2-monitor.service","load":"loaded","active":"active","running":"exited","description":"Monitoring of LVM2 mirrors","field6":"snapshots etc. using dmeventd or progress polling"},{"id":"lvm2-pvscan@259:3.service","load":"loaded","active":"active","running":"exited","description":"LVM event activation on device 259:3"},{"id":"lxc-monitord.service","load":"loaded","active":"active","running":"running","description":"LXC Container Monitoring Daemon"},{"id":"lxc-net.service","load":"loaded","active":"active","running":"exited","description":"LXC network bridge setup"},{"id":"lxc.service","load":"loaded","active":"active","running":"exited","description":"LXC Container Initialization and Autoboot Code"},{"id":"lxcfs.service","load":"loaded","active":"active","running":"running","description":"FUSE filesystem for LXC"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-kernel-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-kernel-server.service"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"open-iscsi.service","load":"loaded","active":"active","running":"exited","description":"Login to default iSCSI targets"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postfix.service","load":"loaded","active":"active","running":"exited","description":"Postfix Mail Transport Agent"},{"id":"postfix@-.service","load":"loaded","active":"active","running":"running","description":"Postfix Mail Transport Agent (instance -)"},{"id":"pve-cluster.service","load":"loaded","active":"active","running":"running","description":"The Proxmox VE cluster filesystem"},{"id":"pve-daily-update.service","load":"loaded","active":"inactive","running":"dead","description":"Daily PVE download activities"},{"id":"pve-firewall.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall"},{"id":"pve-guests.service","load":"loaded","active":"active","running":"exited","description":"PVE guests"},{"id":"pve-ha-crm.service","load":"loaded","active":"active","running":"running","description":"PVE Cluster HA Resource Manager Daemon"},{"id":"pve-ha-lrm.service","load":"loaded","active":"active","running":"running","description":"PVE Local HA Resource Manager Daemon"},{"id":"pve-lxc-syscalld.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE LXC Syscall Daemon"},{"id":"pvebanner.service","load":"loaded","active":"active","running":"exited","description":"Proxmox VE Login Banner"},{"id":"pvedaemon.service","load":"loaded","active":"active","running":"running","description":"PVE API Daemon"},{"id":"pvefw-logger.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall logger"},{"id":"pvenetcommit.service","load":"loaded","active":"active","running":"exited","description":"Commit Proxmox VE network changes"},{"id":"pveproxy.service","load":"loaded","active":"active","running":"running","description":"PVE API Proxy Server"},{"id":"pvesr.service","load":"loaded","active":"inactive","running":"dead","description":"Proxmox VE replication runner"},{"id":"pvestatd.service","load":"loaded","active":"active","running":"running","description":"PVE Status Daemon"},{"id":"qmeventd.service","load":"loaded","active":"active","running":"running","description":"PVE Qemu Event Daemon"},{"id":"rbdmap.service","load":"loaded","active":"active","running":"exited","description":"Map RBD devices"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-statd-notify.service","load":"loaded","active":"inactive","running":"dead","description":"Notify NFS peers of a restart"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rrdcached.service","load":"loaded","active":"active","running":"running","description":"LSB: start or stop rrdcached"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"sendmail.service","load":"not-found","active":"inactive","running":"dead","description":"sendmail.service"},{"id":"smartmontools.service","load":"loaded","active":"active","running":"running","description":"Self Monitoring and Reporting Technology (SMART) Daemon"},{"id":"smb.service","load":"not-found","active":"inactive","running":"dead","description":"smb.service"},{"id":"spiceproxy.service","load":"loaded","active":"active","running":"running","description":"PVE SPICE Proxy Server"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-backlight@backlight:acpi_video0.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Screen Backlight Brightness of backlight:acpi_video0"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2duuid-D782\\x2dA871.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-uuid/D782-A871"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-settle.service","load":"loaded","active":"active","running":"exited","description":"udev Wait for Complete Device Initialization"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@0.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/0"},{"id":"user@0.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 0"},{"id":"watchdog-mux.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE watchdog multiplexer"},{"id":"zfs-import-cache.service","load":"loaded","active":"active","running":"exited","description":"Import ZFS pools by cache file"},{"id":"zfs-mount.service","load":"loaded","active":"active","running":"exited","description":"Mount ZFS filesystems"},{"id":"zfs-share.service","load":"loaded","active":"active","running":"exited","description":"ZFS file system shares"},{"id":"zfs-volume-wait.service","load":"loaded","active":"active","running":"exited","description":"Wait for ZFS Volume (zvol) links in /dev"},{"id":"zfs-zed.service","load":"loaded","active":"active","running":"running","description":"ZFS Event Daemon (zed)"}]
            2021-01-08 15:49:13.911 - debug: linux-control.0 (21312) [needrestart] Proxmox (192.168.1.102:22): no datapoints selected -> removing existing datapoints
            2021-01-08 15:49:13.918 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/log/ | awk '{ print $1 /1024 }''
            2021-01-08 15:49:13.927 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 28.8086
            2021-01-08 15:49:13.928 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.size: 28.81 MB
            2021-01-08 15:49:13.971 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/log/ -name "*" | wc -l'
            2021-01-08 15:49:13.980 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1382
            2021-01-08 15:49:13.981 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.files: 1382 Dateien
            2021-01-08 15:49:14.023 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/log/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
            2021-01-08 15:49:15.018 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610117351
            2021-01-08 15:49:15.020 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.lastChange: 1610117351000 -> 08.01.2021 15:49
            2021-01-08 15:49:15.064 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/ | awk '{ print $1 /1024 }''
            2021-01-08 15:49:15.095 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1899.54
            2021-01-08 15:49:15.096 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.size: 1899.54 MB
            2021-01-08 15:49:15.140 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/ -name "*" | wc -l'
            2021-01-08 15:49:15.159 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 5349
            2021-01-08 15:49:15.161 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.files: 5349 Dateien
            2021-01-08 15:49:15.205 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
            2021-01-08 15:49:19.082 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610117359
            2021-01-08 15:49:19.083 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.lastChange: 1610117359000 -> 08.01.2021 15:49
            2021-01-08 15:49:19.128 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
            2021-01-08 15:49:19.137 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): response stdout: 14
            2021-01-08 15:49:19.139 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
            2021-01-08 15:49:19.145 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): response stdout: 31986;7015;24428
            2021-01-08 15:49:19.188 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
            2021-01-08 15:49:19.195 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): response stdout: 8191;0;8191
            2021-01-08 15:49:19.240 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
            2021-01-08 15:49:19.255 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): response stdout: 39.4;/usr/bin/kvm
            2021-01-08 15:49:19.300 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): send command: 'sensors | grep Package -m 1 | awk '{print $4}' | awk '{print substr($1, length($0)-6,2)}''
            2021-01-08 15:49:19.307 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): response stdout: 60
            2021-01-08 15:49:19.352 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): send command: 'sensors | grep 'Core 0:' | awk '{print $3}' | cut -c2-3'
            2021-01-08 15:49:19.359 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): response stdout: 60
            2021-01-08 15:49:19.404 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): send command: 'sensors | grep 'Core 1:' | awk '{print $3}' | cut -c2-3'
            2021-01-08 15:49:19.411 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): response stdout: 58
            2021-01-08 15:49:19.459 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): send command: 'sensors | grep 'Core 2:' | awk '{print $3}' | cut -c2-3'
            2021-01-08 15:49:19.468 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): response stdout: 58
            2021-01-08 15:49:19.470 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): send command: 'sensors | grep 'Core 3:' | awk '{print $3}' | cut -c2-3'
            2021-01-08 15:49:19.478 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): response stdout: 59
            2021-01-08 15:49:19.481 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): send command: 'qm status 100 | awk '{print substr($0, length($0)-6,7)}''
            2021-01-08 15:49:20.042 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): response stdout: running
            2021-01-08 15:49:20.056 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): send command: 'qm status 110 | awk '{print substr($0, length($0)-6,7)}''
            2021-01-08 15:49:20.646 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): response stdout: running
            2021-01-08 15:49:20.649 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): send command: 'qm status 120 | awk '{print substr($0, length($0)-6,7)}''
            2021-01-08 15:49:21.202 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): response stdout: running
            2021-01-08 15:49:21.210 - info: linux-control.0 (21312) successful received data from Proxmox (192.168.1.102:22)
            2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.refresh' subscribed
            2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpdate' subscribed
            2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpgrade' subscribed
            2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.restart' subscribed
            2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.start' subscribed
            2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.stop' subscribed
            2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.restart' subscribed
            2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.shutdown' subscribed
            2021-01-08 15:49:21.233 - info: linux-control.0 (21312) getting data from ioBroker (192.168.1.170:22, Adapter start)
            2021-01-08 15:49:21.244 - debug: linux-control.0 (21312) [getConnection] Host 'ioBroker' (192.168.1.170:22): using sudo for authentification
            2021-01-08 15:49:21.341 - debug: linux-control.0 (21312) [distributionInfo] ioBroker (192.168.1.170:22): send command: 'cat /etc/os-release'
            2021-01-08 15:49:21.374 - debug: linux-control.0 (21312) [distributionInfo] ioBroker (192.168.1.170:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
            VERSION_ID="10"
            ID=debian
            2021-01-08 15:49:21.376 - debug: linux-control.0 (21312) [distributionInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
            2021-01-08 15:49:21.434 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'sudo -S apt-get update'
            2021-01-08 15:49:21.452 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
            [sudo] Passwort für dirk:
            Leider darf der Benutzer dirk »/usr/bin/apt-get update« als root auf ioBrokerNUC nicht ausführen.
            2021-01-08 15:49:21.452 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s[([\w,\-,\d,\.,~,:,\+]+)]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
            2021-01-08 15:49:21.805 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
            2021-01-08 15:49:21.806 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.newPackages: 0
            2021-01-08 15:49:21.809 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.upgradable: false
            2021-01-08 15:49:21.814 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
            2021-01-08 15:49:21.828 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout: 1609923124
            2021-01-08 15:49:21.829 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.lastUpdate: 1609923124000 -> 06.01.2021 09:52
            2021-01-08 15:49:21.873 - debug: linux-control.0 (21312) [servicesInfo] ioBroker (192.168.1.170:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
            2021-01-08 15:49:21.881 - debug: linux-control.0 (21312) [servicesInfo] ioBroker (192.168.1.170:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
            ifup@ens18.service,loaded,active,exited, ifup for ens18
            influxdb.service,not-found,inactive,dead, influxdb.service
            iobroker.service,loaded,active,running, ioBroker Server
            mariadb-server.service,not-found,inactive,dead, mariadb-server.service
            mysql-server.service,not-found,inactive,dead, mysql-server.service
            redis.service,not-found,inactive,dead, redis.service
            user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
            user@1000.service,loaded,active,running, User Manager for UID 1000
            2021-01-08 15:49:21.884 - debug: linux-control.0 (21312) [servicesInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
            2021-01-08 15:49:22.037 - debug: linux-control.0 (21312) [needrestart] ioBroker (192.168.1.170:22): no datapoints selected -> removing existing datapoints
            2021-01-08 15:49:22.043 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
            2021-01-08 15:49:22.048 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): response stdout: 27
            2021-01-08 15:49:22.051 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
            2021-01-08 15:49:22.056 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): response stdout: 7978;2251;5034
            2021-01-08 15:49:22.058 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
            2021-01-08 15:49:22.064 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): response stdout: 8189;0;8189
            2021-01-08 15:49:22.066 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
            2021-01-08 15:49:22.080 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): response stdout: 8.4;io.linux-control.0
            2021-01-08 15:49:22.082 - debug: linux-control.0 (21312) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-stop, description: : create button
            2021-01-08 15:49:22.083 - debug: linux-control.0 (21312) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-start, description: : create button
            2021-01-08 15:49:22.084 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): send command: 'du -c /opt/iobroker | tail -1 | awk '{printf $1MB}''
            2021-01-08 15:49:22.397 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): response stdout: 1833808
            2021-01-08 15:49:22.402 - info: linux-control.0 (21312) successful received data from ioBroker (192.168.1.170:22)
            2021-01-08 15:49:22.417 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.refresh' subscribed
            2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpdate' subscribed
            2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpgrade' subscribed
            2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.restart' subscribed
            2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-stop' subscribed
            2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-start' subscribed
            2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.start' subscribed
            2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.stop' subscribed
            2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.restart' subscribed
            2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.start' subscribed
            2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.stop' subscribed
            2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.restart' subscribed
            2021-01-08 15:49:22.420 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.shutdown' subscribed
            2021-01-08 15:49:22.420 - info: linux-control.0 (21312) getting data from Raspberrymatic (192.168.1.171:22, Adapter start)
            2021-01-08 15:49:22.517 - debug: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): send command: 'cat /etc/os-release'
            2021-01-08 15:49:22.523 - debug: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): response stdout: NAME=Buildroot
            VERSION=2.15.5-20151101-2805-g412dbfc5
            ID=buildroot
            VERSION_ID=2020.11
            PRETTY_NAME="Buildroot 2020.11"
            2021-01-08 15:49:22.525 - debug: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): csvToJson result: [{"prop":"NAME","val":"Buildroot"},{"prop":"VERSION","val":"2.15.5-20151101-2805-g412dbfc5"},{"prop":"ID","val":"buildroot"},{"prop":"VERSION_ID","val":"2020.11"},{"prop":"PRETTY_NAME","val":"Buildroot 2020.11"}]
            2021-01-08 15:49:22.571 - warn: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): property 'VERSION_CODENAME' not exist in result!
            2021-01-08 15:49:22.617 - debug: linux-control.0 (21312) [cmdAptUpdate] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
            2021-01-08 15:49:22.619 - debug: linux-control.0 (21312) [servicesInfo] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
            2021-01-08 15:49:22.624 - debug: linux-control.0 (21312) [needrestart] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
            2021-01-08 15:49:22.630 - debug: linux-control.0 (21312) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
            2021-01-08 15:49:22.635 - debug: linux-control.0 (21312) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): response stdout: 61
            2021-01-08 15:49:22.683 - info: linux-control.0 (21312) successful received data from Raspberrymatic (192.168.1.171:22)
            2021-01-08 15:49:22.701 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.refresh' subscribed
            2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpgrade' subscribed
            2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpdate' subscribed
            2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.restart' subscribed
            2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.shutdown' subscribed
            2021-01-08 15:49:22.702 - info: linux-control.0 (21312) getting data from Motioneye (192.168.1.174:22, Adapter start)
            2021-01-08 15:49:22.713 - debug: linux-control.0 (21312) [getConnection] Host 'Motioneye' (192.168.1.174:22): using sudo for authentification
            2021-01-08 15:49:22.795 - debug: linux-control.0 (21312) [distributionInfo] Motioneye (192.168.1.174:22): send command: 'cat /etc/os-release'
            2021-01-08 15:49:22.826 - debug: linux-control.0 (21312) [distributionInfo] Motioneye (192.168.1.174:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
            VERSION_ID="10"
            ID=debian
            2021-01-08 15:49:22.829 - debug: linux-control.0 (21312) [distributionInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
            2021-01-08 15:49:22.837 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'sudo -S apt-get update'
            2021-01-08 15:49:22.858 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
            dirk ist nicht in der sudoers-Datei. Dieser Vorfall wird gemeldet.
            2021-01-08 15:49:22.858 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s[([\w,\-,\d,\.,~,:,\+]+)]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
            2021-01-08 15:49:23.192 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
            2021-01-08 15:49:23.192 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.newPackages: 0
            2021-01-08 15:49:23.195 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.upgradable: false
            2021-01-08 15:49:23.201 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
            2021-01-08 15:49:23.216 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout: 1585325736
            2021-01-08 15:49:23.217 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.lastUpdate: 1585325736000 -> 27.03.2020 17:15
            2021-01-08 15:49:23.260 - debug: linux-control.0 (21312) [servicesInfo] Motioneye (192.168.1.174:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
            2021-01-08 15:49:23.269 - debug: linux-control.0 (21312) [servicesInfo] Motioneye (192.168.1.174:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
            motion.service,loaded,active,exited, LSB: Start Motion detection
            motioneye.service,loaded,active,running, motionEye Server
            2021-01-08 15:49:23.270 - debug: linux-control.0 (21312) [servicesInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"motion.service","load":"loaded","active":"active","running":"exited","description":"LSB: Start Motion detection"},{"id":"motioneye.service","load":"loaded","active":"active","running":"running","description":"motionEye Server"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
            2021-01-08 15:49:23.398 - debug: linux-control.0 (21312) [needrestart] Motioneye (192.168.1.174:22): no datapoints selected -> removing existing datapoints
            2021-01-08 15:49:23.403 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): send command: 'sudo -S du -sk /var/lib/motioneye | awk '{ print $1 /1024 }''
            2021-01-08 15:49:23.424 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): response stdout:
            2021-01-08 15:49:23.425 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): Motioneye.folders.motioneye.size: NaN MB
            2021-01-08 15:49:23.427 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): send command: 'sudo -S find /var/lib/motioneye -name "*" | wc -l'
            2021-01-08 15:49:23.443 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): response stdout:
            0
            2021-01-08 15:49:23.444 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): Motioneye.folders.motioneye.files: NaN Dateien
            2021-01-08 15:49:23.487 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): send command: 'tmp=$(sudo -S find /var/lib/motioneye -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
            2021-01-08 15:49:23.508 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): response stdout:
            date: Diese Option benötigt ein Argument -- »r«
            „date --help“ liefert weitere Informationen.
            2021-01-08 15:49:23.509 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): Motioneye.folders.motioneye.lastChange: NaN ->
            2021-01-08 15:49:23.551 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
            2021-01-08 15:49:23.559 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): response stdout: 28
            2021-01-08 15:49:23.561 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
            2021-01-08 15:49:23.570 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): response stdout: 3946;222;3532
            2021-01-08 15:49:23.582 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
            2021-01-08 15:49:23.596 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): response stdout: 33.9;/usr/bin/motion
            2021-01-08 15:49:23.606 - info: linux-control.0 (21312) successful received data from Motioneye (192.168.1.174:22)
            2021-01-08 15:49:23.619 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.refresh' subscribed
            2021-01-08 15:49:23.619 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpdate' subscribed
            2021-01-08 15:49:23.619 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpgrade' subscribed
            2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.restart' subscribed
            2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.start' subscribed
            2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.stop' subscribed
            2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.restart' subscribed
            2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.shutdown' subscribed
            • Scrounger
              Scrounger Developer @dirk1962 last edited by
              @dirk1962 sagte in HTML Tabelle Linux-Control Adapter:
              @liv-in-sky @Scrounger Ich hatte den Ordner Befehl für Motioneye wieder rausgenommen. In diesem log ist er wieder mit drin.
              Coole Fehlermeldung, du wurdest gemeldet 😁
              User hat nicht ausreichend rechte.
                liv-in-sky @Scrounger last edited by
                @Scrounger
                die bestrafung ist auf bewährung - da er sich ja selbst angezeigt hat 🙂
                • Scrounger
                  Scrounger Developer @liv-in-sky last edited by
                  @liv-in-sky
                  Abwarten, was da erst steht wenn er sich nach 20h einloggt 😁
                  Blöd das das als response und nicht als Fehler kommt, muss ich mir was überlegen, wie man das abfangen bzw. im log als error ausgeben kann.
                  dirk1962 2 Replies Last reply Reply Quote 1
                  • dirk1962
                    dirk1962 @Scrounger last edited by
                    @Scrounger @liv-in-sky Gerade war die Polizei da und wollte mich verhaften. Ich hab alles abgestritten und sie zu Euch geschickt, weil von Euch der Adapter und das Script ist. 😀 😀
                      liv-in-sky @dirk1962 last edited by
                      dirk1962 1 Reply Last reply Reply Quote 1
                      • dirk1962
                        @Scrounger Mit dem Update von Linux Control wurden die nicht ausreichenden Rechte als error angezeigt. Seitdem ich die Rechte gesetzt habe, werden auch die Inhalte der Ordner korrekt angezeigt. Vielen Dank für Deine Hilfe.
                        • dirk1962
                          dirk1962 @liv-in-sky last edited by
                          @liv-in-sky, ich habe für meine drei VM's unter Proxmox Datenpunkte für start/stop angelegt. Diese sind in den Objekten sichtbar und schaltbar. In der html-Tabelle von VIS sind sie ebenfalls schaltbar. In der materialdesign Icon List allerdings nicht. Habe ich irgendwas übersehen oder mache ich etwas falsch?
                            @dirk1962 leider check ich nicht, was du meinst - alle 6 schalter sind im untersten bild md-widget zu sehen - was genau fehlt dir ?
                            dirk1962 1 Reply Last reply Reply Quote 0
                            • dirk1962
                              @liv-in-sky mir fehlt nichts, die Schalter sind "tot". Wenn ich auf Motioneye-stop drücke passiert nichts.
                                @dirk1962
                                sorry - schaltbar mit sichtbar verwechselt 😞
                                das kommt bei mir manchmal auch vor - da verliert die vis die verbindung vom socket (vermute ich) - da hilft ein browser refresh
                                egal ob in der tabelle oder im widget - es wird immer das selbe interne script ausgeführt
                                • dirk1962
                                  @liv-in-sky sagte in HTML Tabelle Linux-Control Adapter:
                                  @dirk1962
                                  Das ist mir auch klar. Nur wenn auf 4 verschiedenen Geräten das Schalten per html-Tabelle funktioniert und das Schalten per MD Widget nicht, dann ist der refresh des Browsers für mich nicht nachvollziehbar. 😕
                                    liv-in-sky @dirk1962 last edited by liv-in-sky
                                    @dirk1962 hast du mal in chrome die entwickler-console geöffnet, vielleicht sieht man da was, wenn du den button drückst
                                    • dirk1962
                                      @liv-in-sky das kommt beim Drücken auf Motioneye-stop
                                        @dirk1962
                                        script in html tabelle wird ausgeführt - anscheinend ist parameter übergabe im script nicht korrekt
                                          @dirk1962
                                          hast du lust auf anydesk session - im moment sehe ich bei mir hier kein problem
                                          • dirk1962
                                            @liv-in-sky, auf dem PC geht es mittlerweile. Frag mich aber bitte nicht, was ich gemacht habe. Auf dem Tablet und Handy muss ich noch prüfen. Da weiß ich auch noch nicht, wie ich da die Entwickler-console geöffnet bekomme.
                                            Du hast sicherlich Recht, dass das Problem bei mir liegt 😞 😞 .
                                            javascript template
                                            27446
