    4. vis-inventwo v.2.x.x
      Reese1 @jkvarel last edited by Reese1
      @jkvarel
      ist nicht leer, so ist es eingestellt bei mir, mit der alten version geht es einwandfrei, netflix.png
      [{"tpl":"i-vis-universal","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iUniversalWidgetType":"Switch","iValueType":"value","iStateResponseTime":"0","iStateResetValueTime":"0","iNavWait":"100","iButtonCol":"#333333","iButtonActive":"#455618","iOpacityBack":"1","iCornerRadiusUL":"12","iCornerRadiusUR":"0","iCornerRadiusLR":"12","iCornerRadiusLL":"0","iContentFlexDirection":"vertical","iContentVertAlign":"iSpace-between","iContentOrder":"orderImgText","iOpacityCtn":"1","iTextColor":"#ffffff","iTextSize":"16","iTextAlign":"iStart","iTextSpaceTop":"0","iTextSpaceBottom":"0","iTextSpaceLeft":"0","iTextSpaceRight":"0","iIconSize":"70","iImgAlign":"iCenter","iImgSpaceTop":"5","iImgSpaceBottom":"0","iImgSpaceLeft":"0","iImgSpaceRight":"0","iImgRotation":"0","iImgBlinkFalse":"0","iImgBlinkTrue":"0","iImgColorFalse":"","iImgColorTrue":"","iImgColorFalseFilter":"","iImgColorTrueFilter":"","iShadowXOffset":"2","iShadowYOffset":"2","iShadowBlur":"2","iShadowSpread":"","iShadowColor":"#111111","iShadowColorActive":"#111111","iShadowInnerXOffset":"0","iShadowInnerYOffset":"0","iShadowInnerBlur":"0","iShadowInnerSpread":"0","iShadowInnerColor":"#111111","iShadowInnerColorActive":"#111111","iBorderSize":"0","iBorderStyle":"none","iBorderColor":"#ffffff","iBorderColorActive":"#ffffff","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"harmony.0.Harmony_Hub.activities.Netflix","iValueFalse":"0","iValueTrue":"2","iTextFalse":"Netflix Ausgeschaltet","iTextTrue":"Netflix Eingeschaltet","iImageFalse":"/vis.0/main/img/Lampensymbole/Lampe Aus.png","iImageTrue":"/vis.0/main/img/Lampensymbole/Lampe AN.png","iValueComparison":"equal","iButtonColHover":""},"style":{"left":"505px","top":"67px","width":"155px","height":"130px"},"widgetSet":"vis-inventwo"}]
      jkvarel 1 Reply Last reply Reply Quote 0
      • jkvarel
        jkvarel Developer @efxz last edited by
        @efxz so wie ich das sehe passiert das nur, wenn man auf dass Widget klickt. Ändert ein anderes Widget den Dp, dann funktioniert es. Ich werde schauen woran das liegt
        efxz 1 Reply Last reply Reply Quote 0
        • jkvarel
          jkvarel Developer @Reese1 last edited by
          @Reese1 also ändert sich bei dir der Hintergrund nicht? Iconfarbe ändert sich ja nicht, da du da ja nichts eingetragen hast
            @jkvarel
            doch, so schauts aus wenn eingeschaltet ist: netflix 2.png
            wenn ausgeschaltet ist schaut es so aus: netflix 3.png
            • jkvarel
              @Reese1 und was funktioniert nach dem Update nicht mehr? Die Hintergrundfarbe?
                @jkvarel
                genau, bei den neueren versionen ab 2.5.11 schaltet es zwar die aktion aber dass widget bleibt grau wie wenn ausgeschaltet wäre wie auf den bild oben,
                • efxz
                  efxz @jkvarel last edited by
                  @jkvarel
                  an der Gruppierung kann's nicht liegen?
                  skvarel jkvarel 2 Replies Last reply Reply Quote 0
                  • skvarel
                    skvarel Developer @efxz last edited by
                    @efxz .. Gruppierungen können Fehler verursachen. Da haben wir auch keinen Einfluss drauf. Das liegt dann am VIS Adapter.
                    • jkvarel
                      @Reese1 kannst du mal gucken, ob in der Browserkonsole Fehler sind?
                      • jkvarel
                        @efxz Ich denke ich hab den Fehler jetzt behoben. Ich konnte das Problem bei mir reproduzieren uns jetzt funktioniert es wie es soll. Bitte teste das mit dem nächstem Update und gib mir bescheid.
                        R efxz 3 Replies Last reply Reply Quote 0
                          @jkvarel
                          danke für deine hilfe, ich habe heute den adapter mal gelöscht und neu installiert, im moment läuft es auch mit der aktuellen version 2.7.2, ich werde es beobachten und falls es wieder nicht läuft bescheid geben,
                          • efxz
                            @jkvarel
                            2.7.3 funktioniert leider auch nicht.
                            • efxz
                              @jkvarel
                              2.7.4 funktioniert nun
                              • jkvarel
                                @efxz Sehr gut
                                  GreatEMU @jkvarel last edited by
                                  @jkvarel sagte in vis-inventwo v.2.x.x:
                                  @pd_mueller @Almixx
                                  Ist in der Version 2.6.0 (latest) möglich. Bei den Universal- und Multi-Widgets kann ein Vergleichsoperator ausgewählt werden
                                  Hallo
                                  Ich benutze die Version 2.7.4. Dort habe ich in dem Multi-Widget aber keinen Vergleichsoperator.
                                  Ich weiss aber auch nicht, ob ich für mein Vorhaben überhaupt den richtigen Ansatz verfolge.
                                  Abhängig von einem Wert (Wertebereich) möchte ich unterschiedliche Images anzeigen. Einfacher gesagt: je nach Wert der Akkuladung meines Tablets möchte ich ein entsprechendes Image anzeigen .
                                  • jkvarel
                                    jkvarel Developer @GreatEMU last edited by
                                    @greatemu
                                    Die Vergleichsoperatoren sollten eigentlich bei den einzelnen Zuständen sein. Oben gibt es keinen, da du dort nur die Werte zum schalten einträgst.58fe98ab-872c-4b10-9f92-cca9fbb5b691-image.png
                                    Wertebereiche kannst du ganz gut abdecken. Das Widget geht die Status von oben nach unten durch. Sobald eins wahr ist werden die restlichen ignoriert
                                      @jkvarel
                                      Danke für die Rückmeldung.
                                      Das schaut bei mir definitiv anders aus...
                                      • jkvarel
                                        @greatemu Klick mal bitte auf den Pfeil um dir alle Felder anzeigen zu lassen0e668209-be0b-4a53-b408-f6e6b0894318-image.png
                                          @jkvarel Danke! Das wars...
                                            Sven_hh @jkvarel last edited by
                                            @jkvarel
                                            Super, hab deine Antwort eben erst entdeckt und arbeite mit den beiden Widgets schon fleissig.
                                            Die Widgets sind echt super. Weiter so 👍
                                            Vg aus dem Kalten Norden.
                                            31.7k
                                            79.9k
                                            css inventwo test widget
                                            63
                                            443
                                            80955
