    4. Beta Test js-controller 3.2.x auf GitHub
    • Issi
      Issi Developer last edited by Issi
      Hi, ich habe da glaube was gefunden wen man ein state erstellt mit einem def Wert wird er Orange dargestellt und die Quality zeigt [0x20] an hab es mit einem frisch installierten adapter und direkt in den ioBroker Objekten unter 0_userdata probiert beides dasselbe im log steht nichts drin
      ist das jetzt ein feature oder ein bug 😕
      • Feuersturm
        Feuersturm last edited by Feuersturm
        Ich habe gerade mal meinen ioBroker Container geclont und den js-controller 3.2.4 installiert.
        Beim update kamen folgende Meldungen:
        proxmox@ioBrokerBETA:/opt/iobroker$ npm install ioBroker/ioBroker.js-controller
        [sudo] password for proxmox:
        > iobroker.js-controller@3.2.4 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.6
        > iobroker.js-controller@3.2.4 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        object 0_userdata.0.example_state created
        object _design/system updated
        The following notifications happened during sync:
        - Ignoring Directory "iogo.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "tr-064-community.admin" because officially not created as meta object. Please remove directory!
        Renamed repository "default to "stable"
        Renamed repository "latest to "beta"
        > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
        > node scripts/postinstall
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        + iobroker.js-controller@3.2.4
        added 44 packages from 16 contributors, removed 53 packages, updated 40 packages and moved 1 package in 102.359s
        35 packages are looking for funding
          run `npm fund` for details
        proxmox@ioBrokerBETA:/opt/iobroker$ nodejs -v
        v12.18.3
        proxmox@ioBrokerBETA:/opt/iobroker$ node -v
        v12.18.3
        proxmox@ioBrokerBETA:/opt/iobroker$ npm -v
        6.14.6
        Bei socketio v 3.1.2 ( @apollon77 ) kommt folgende Warnung
        Edit Issue https://github.com/ioBroker/ioBroker.socketio/issues/40
        socketio.0	2021-01-09 22:33:47.854	warn	(3964) State "socketio.0.connected" has no existing object, this might lead to an error in future versions
        Ich habe den Pong Fehlter auch mit der 1.14.27
        HomeMatic RPC - 1.14.27 ( @foxriver76 )
        hm-rpc.0	2021-01-09 22:34:48.960	warn	(3530) State "hm-rpc.0.CENTRAL.0.PONG" has no existing object, this might lead to an error in future versions
        Ebenfalls kommen beim HmIPW-DRAP vom Adapter hm-rpc folgende Warnungen:
        Edit: Issue: https://github.com/ioBroker/ioBroker.hm-rpc/issues/298
        hm-rpc.0	2021-01-09 22:35:09.066	warn	(3530) State "hm-rpc.0.00179A4989A6AB.2.CURRENT" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.059	warn	(3530) State "hm-rpc.0.00179A4989A6AB.2.CURRENT_STATUS" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.055	warn	(3530) State "hm-rpc.0.00179A4989A6AB.2.VOLTAGE" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.054	warn	(3530) State "hm-rpc.0.00179A4989A6AB.2.VOLTAGE_STATUS" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.053	warn	(3530) State "hm-rpc.0.00179A4989A6AB.1.CURRENT" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.052	warn	(3530) State "hm-rpc.0.00179A4989A6AB.1.CURRENT_STATUS" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.051	warn	(3530) State "hm-rpc.0.00179A4989A6AB.1.VOLTAGE" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.050	warn	(3530) State "hm-rpc.0.00179A4989A6AB.1.VOLTAGE_STATUS" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.049	warn	(3530) State "hm-rpc.0.00179A4989A6AB.0.ERROR_CODE" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.048	warn	(3530) State "hm-rpc.0.00179A4989A6AB.0.ACTUAL_TEMPERATURE" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.046	warn	(3530) State "hm-rpc.0.00179A4989A6AB.0.ERROR_BUS_CONFIG_MISMATCH" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.045	warn	(3530) State "hm-rpc.0.00179A4989A6AB.0.ERROR_SHORT_CIRCUIT_DATA_LINE_BUS_1" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.044	warn	(3530) State "hm-rpc.0.00179A4989A6AB.0.ERROR_SHORT_CIRCUIT_DATA_LINE_BUS_2" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.043	warn	(3530) State "hm-rpc.0.00179A4989A6AB.0.ERROR_OVERHEAT" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.042	warn	(3530) State "hm-rpc.0.00179A4989A6AB.0.ERROR_POWER_SHORT_CIRCUIT_BUS_1" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.040	warn	(3530) State "hm-rpc.0.00179A4989A6AB.0.ERROR_POWER_SHORT_CIRCUIT_BUS_2" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.037	warn	(3530) State "hm-rpc.0.00179A4989A6AB.0.VOLTAGE" has no existing object, this might lead to an error in future versions
        hm-rpc.0	2021-01-09 22:35:09.036	warn	(3530) State "hm-rpc.0.00179A4989A6AB.0.ERROR_UNDERVOLTAGE" has no existing object, this might lead to an error in future versions
        Feuer-sturm created this issue in ioBroker/ioBroker.socketio
        closed Warnung "has no existing object," beim Beta-Test von js-controller 3.2.x #40
        Feuer-sturm created this issue in ioBroker/ioBroker.hm-rpc
        closed Warnung "has no existing object," für HMIPw-DRAP beim Beta-Test von js-controller 3.2.x #298
          apollon77 @Issi last edited by
          @Issi "feature" ... steht auch im changelog. Damit soll dargestellt werden da der wert nicht vom Gerät kam und auch nicht vom User oder einem Adapter gesetzt wurde.
            apollon77 @Feuersturm last edited by
            @Feuersturm Die Meldungen sind alle ok. Falls Du die adapter wo oben die "Ignoring Directory" meldungen kamen dann bitte einmal "iobroker upload ..." machen bzw ausnahmsweise manuell im iobroker-data/files einfach löschen ... oder ignorieren - tut nicht weh 🙂
            Rest bitte die Meldungen bei den adaptern melden
            • Feuersturm
              Feuersturm @MalleRalle last edited by
              @MalleRalle sagte in Beta Test js-controller 3.2.x auf GitHub:
              Update auf hm-rpc@1.14.27 behebt den PONG Fehler
              Hast du den Adapter normal über ioBroker installiert oder hast du die Version 1.14.29 über die Git-Katze installiert. Laut Changelog ist der Fix in der 1.14.29 enthalten, im latest / Beta wird mir aber nur die 1.14.27 angeboten.
                apollon77 last edited by
                Mal andere Frage: Schaut mal ob jemand hier einejn Eintrag hat (unter "Objekte", Expertenmodus, "system.host.NAME.notifications" ... Falls das bei jemandem nicht leer ist bitte iobroker mal stoppen und in iobroker-data nach der notifications.json schauen und den Inhalt mal posten ... Danke 🙂
                SBorg ? lobomau Thomas Braun 4 Replies Last reply Reply Quote 0
                • SBorg
                  SBorg Forum Testing Most Active @apollon77 last edited by
                  @apollon77 Bidda sche:
                  {"system":{"restartLoop":{"system.adapter.backitup.0":[{"message":"Restart loop detected","ts":1610188753329}],"system.adapter.enigma2.0":[{"message":"Restart loop detected","ts":1610189429633}]}}}
                    apollon77 @SBorg last edited by
                    @SBorg Cool :-)) Danke ... Das system tut mal generell ... Du hattest also zwei Fälle das Adapter zu schnell gecrasht sind 🙂 Später mal wird das im Admin angezeigt
                    • Feuersturm
                      Feuersturm @apollon77 last edited by Feuersturm
                      @apollon77 Hat das Update auch Einfluss auf den VIS Dateimanager?
                      js-controller 3.2.4:
                      Wenn ich jetzt eine Ebene höher gehe dann verschwindet der Ordnername und ich komme in vis.0/main auch nicht mehr rein. Ebenfalls fehlen sämtliche anderen Inhalte im vis.0 Ordner.
                      Gleiches gilt, wenn ich auf der obersten Wurzelebene bin und dann in die einzelnen Ordner navigiere.
                      So sieht der vis.0 Ordner im meinem Produktivsystem (js-controller 3.1.6) aus:
                      sigi234 apollon77 4 Replies Last reply Reply Quote 0
                        sigi234 Forum Testing Most Active @Feuersturm last edited by sigi234
                        @Feuersturm
                        Das kann ich bestätigen!
                        Siehe:
                        https://discord.com/channels/743167951875604501/743227673379209389/797497699368697888
                          @Feuersturm wenn du den doppelten slash weg machst ist der Inhalt dann wieder da?
                          Aber ja das kann durchaus sein. Checke ich.
                            @Feuersturm noch frage: dB ist file oder redis?
                            • Feuersturm
                              @apollon77 sagte in Beta Test js-controller 3.2.x auf GitHub:
                              Ich verstehe die Frage leider nicht. Worauf bezieht sich deine Frage?
                              lobomau apollon77 2 Replies Last reply Reply Quote 0
                              • lobomau
                                lobomau @Feuersturm last edited by
                                @apollon77 ich habe mal auf einem slave ausprobiert einem Pi3 mit node 12.20.1 und npm 6.14.10.
                                Scheint nicht geklappt zu haben:
                                pi@Pi3:~ $ cd /opt/iobroker
                                pi@Pi3:/opt/iobroker $ sudo iobroker stop
                                pi@Pi3:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
                                > iobroker.js-controller@3.2.4 preinstall /opt/iobroker/node_modules/iobroker.js                                           -controller
                                NPM version: 6.14.10
                                > iobroker.js-controller@3.2.4 install /opt/iobroker/node_modules/iobroker.js-co                                           ntroller
                                Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/io                                           broker/node_modules/iobroker.js-controller/lib/setup/../../../../reinstall.js'
                                Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                                           /iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.                                           bat'
                                Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                                           /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                                Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                                           /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
                                internal/fs/utils.js:269
                                    throw err;
                                Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-                                           controller/lib/setup/../../tmp'
                                    at Object.mkdirSync (fs.js:921:3)
                                    at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/                                           setupSetup.js:835:16)
                                    at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/set                                           up.js:272:23)
                                    at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-con                                           troller/lib/setup.js:2643:5)
                                    at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iob                                           roker.js:1:24)
                                    at Module._compile (internal/modules/cjs/loader.js:999:30)
                                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                                    at Module.load (internal/modules/cjs/loader.js:863:32)
                                    at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                                    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js                                           :60:12) {
                                  errno: -13,
                                  syscall: 'mkdir',
                                  code: 'EACCES',
                                  path: '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/ch                                           okidar/node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                                           2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                                           )
                                npm ERR! code ELIFECYCLE
                                npm ERR! errno 1
                                npm ERR! iobroker.js-controller@3.2.4 install: `node iobroker.js setup first`
                                npm ERR! Exit status 1
                                npm ERR!
                                npm ERR! Failed at the iobroker.js-controller@3.2.4 install script.
                                npm ERR! This is probably not a problem with npm. There is likely additional log                                           ging output above.
                                npm ERR!     /root/.npm/_logs/2021-01-10T08_01_16_275Z-debug.log
                                  apollon77 @lobomau last edited by
                                  @lobomau iobroker fix bitte, dann nochmal versuchen. Danke
                                  lobomau 1 Reply Last reply Reply Quote 0
                                    @Feuersturm was sagt „iobroker setup custom“ bei der objects databank für einen Typ? File oder redis?
                                    • lobomau
                                      lobomau @apollon77 last edited by lobomau
                                      @apollon77 hab ich kein ioBroker mehr!?
                                      der zweite Befehl mit fix.sh hatte auch nicht geklappt.
                                      Nun läuft gerade durch:
                                      sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
                                      • lobomau
                                        lobomau @lobomau last edited by lobomau
                                        @apollon77 ich glaube es hat geklappt:
                                        pi@Pi3:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
                                        library: loaded
                                        Library version=2020-12-07
                                        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                                        pi@Pi3:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker/ioBroker.js-cont                                                        roller
                                        ioBroker configuration updated
                                        added 87 packages from 45 contributors, removed 3 packages and moved 1 package i                                                        n 178.757s
                                        11 packages are looking for funding
                                        pi@Pi3:/opt/iobroker $ sudo npm fund
                                        iobroker.inst@2.0.3
                                        ├─┬ https://github.com/sponsors/isaacs
                                        │ └── glob@7.1.6
                                        ├─┬ https://github.com/sponsors/epoberezkin
                                        │ └── ajv@6.12.3
                                        ├─┬ https://github.com/sponsors/RubenVerborgh
                                        │ └── follow-redirects@1.13.0
                                        ├─┬ https://github.com/sponsors/ljharb
                                        │ └── is-nan@1.3.0, resolve@1.17.0, has-symbols@1.0.1
                                        ├─┬ https://opencollective.com/ioredis
                                        │ └── ioredis@4.19.4
                                        ├─┬ https://github.com/sponsors/jonschlinkert
                                        │ └── picomatch@2.2.2
                                        ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                                        │ └── wrap-ansi@7.0.0
                                        ├─┬ https://github.com/chalk/ansi-styles?sponsor=1
                                        │ └── ansi-styles@4.3.0
                                        ├─┬ https://github.com/sponsors/feross
                                        │ └── safe-buffer@5.2.1, simple-concat@1.0.1
                                        ├─┬ https://www.patreon.com/feross
                                        ├─┬ https://feross.org/support
                                        └─┬ https://github.com/sponsors/sindresorhus
                                          └── mimic-response@2.1.0
                                        pi@Pi3:/opt/iobroker $ sudo iobroker start
                                          @lobomau passt.
                                          • lobomau
                                            @apollon77 hab mir den nächsten slave einen Pi1 vorgenommen. Diesmal zuerst den fix gestartet, aber fürhrt zum gleichen Fehler (?) wie beim Pi3. Ich mache dann gleich wieder den Schritt wie beim Pi3.
                                            pi@raspberrypi:~ $ cd /opt/iobroker
                                            pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
                                            pi@raspberrypi:/opt/iobroker $ sudo iobroker fix
                                            library: loaded
                                                Welcome to the ioBroker installation fixer!
                                                Script version: 2020-12-07
                                                Installing prerequisites (1/3)
                                            Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                            Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                            Reading package lists... Done
                                            Installed gcc-c++
                                                Checking ioBroker user and directory permissions (2/3)
                                            Created /etc/sudoers.d/iobroker
                                            Fixing directory permissions...
                                                Checking autostart (3/3)
                                            Enabling autostart...
                                            Autostart enabled!
                                                Your installation was fixed successfully
                                                Run iobroker start to start ioBroker again!
                                            pi@raspberrypi:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
                                            Could not check npm version: Error: Timeout
                                            Assuming that correct version is installed.
                                            fs.js:114
                                                throw err;
                                                at Object.mkdirSync (fs.js:757:3)
                                                at Module._compile (internal/modules/cjs/loader.js:778:30)
                                                at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                                at Module.load (internal/modules/cjs/loader.js:653:32)
                                                at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                                at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                            npm ERR! errno 1
                                            npm ERR!
                                            npm ERR!     /root/.npm/_logs/2021-01-10T08_43_13_360Z-debug.log
                                            js-controller
                                            25
                                            287
                                            46088
