      Tom Haase last edited by
      Rolladen per Object "closeSleep" runtergefahren.
      Fensterkontakt geöffnet
      2021-01-09 16:56:57.523 - debug: shuttercontrol.0 (1591) start buttonAction
      2021-01-09 16:56:57.528 - info: shuttercontrol.0 (1591) Set ID: Buero1 pct value: 100%
      2021-01-09 16:56:57.530 - debug: shuttercontrol.0 (1591) shutterDownButton Buero1 pct old height: 0% new height: 100%
      2021-01-09 16:56:57.547 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
      2021-01-09 16:56:57.548 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
      2021-01-09 16:56:57.642 - info: fhem.0 (1222) stateChange (out): fhem.0.Friedhelm.pct | 100 > set Friedhelm pct 100
      2021-01-09 16:56:57.647 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | state > fhem.0.Friedhelm.state drive-down
      2021-01-09 16:56:57.648 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | boolean > fhem.0.Friedhelm.state_boolean drive-down
      2021-01-09 16:56:57.649 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | value > fhem.0.Friedhelm.state_value drive-down
      2021-01-09 16:56:57.653 - info: fhem.0 (1222) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send down | state > fhem.0.SD_Keeloq_AC6000.state send down
      2021-01-09 16:57:24.118 - info: fhem.0 (1222) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
      2021-01-09 16:57:24.121 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | state > fhem.0.Friedhelm.state closed
      2021-01-09 16:57:24.123 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | boolean > fhem.0.Friedhelm.state_boolean false
      2021-01-09 16:57:24.124 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | value > fhem.0.Friedhelm.state_value 0
      2021-01-09 16:57:24.159 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
      2021-01-09 16:57:24.160 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
      2021-01-09 16:57:45.212 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
      2021-01-09 16:57:45.219 - debug: shuttercontrol.0 (1591) save trigger height: 100% for device: Buero1 pct
      2021-01-09 16:57:45.220 - debug: shuttercontrol.0 (1591) save trigger action: down for device: Buero1 pct
      2021-01-09 16:57:47.776 - info: fhem.0 (1222) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        und wenn ich den Fensterkontakt wieder schließe
        2021-01-09 17:00:00.008 - debug: shuttercontrol.0 (1591) calculate astrodata ...
        2021-01-09 17:00:00.009 - debug: shuttercontrol.0 (1591) Sun Azimut: NaN°
        2021-01-09 17:00:00.010 - debug: shuttercontrol.0 (1591) Sun Elevation: NaN°
        2021-01-09 17:00:00.082 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 4141
        2021-01-09 17:00:01.887 - info: dwd.0 (4141) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2021-01-09 17:00:01.899 - info: dwd.0 (4141) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.0, js-controller: 3.1.6
        2021-01-09 17:00:04.124 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 4156
        2021-01-09 17:00:05.536 - info: daswetter.0 (4156) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2021-01-09 17:00:05.553 - info: daswetter.0 (4156) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
        2021-01-09 17:00:08.146 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 4172
        2021-01-09 17:00:08.369 - info: dwd.0 (4141) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-01-09 17:00:08.889 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-01-09 17:00:10.413 - info: ical.0 (4172) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2021-01-09 17:00:10.473 - info: ical.0 (4172) starting. Version 1.8.5 in /opt/iobroker/node_modules/iobroker.ical, node: v12.20.0, js-controller: 3.1.6
        2021-01-09 17:00:11.504 - info: ical.0 (4172) processing URL: calendar1 https://calendar.google.com/calendar/ical/6gbrsp5mk0pf4a0dgamj7d56n4%40group.calendar.google.com/private-a5d30d07577f1b5f997d66da0421d549/basic.ics
        2021-01-09 17:00:16.263 - info: daswetter.0 (4156) got wrong data structure! trying to repair...
        2021-01-09 17:00:16.680 - info: ical.0 (4172) Terminated (NO_ERROR): Without reason
        2021-01-09 17:00:17.194 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2021-01-09 17:00:18.807 - info: daswetter.0 (4156) Terminated (NO_ERROR): Without reason
        2021-01-09 17:00:19.323 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2021-01-09 17:00:55.047 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: false
        2021-01-09 17:00:55.054 - debug: shuttercontrol.0 (1591) shutter trigger released Buero1 pct already in place: 100%
        2021-01-09 17:00:55.055 - debug: shuttercontrol.0 (1591) save back trigger action: down for device Buero1 pct
        • MichMein
          MichMein @simatec last edited by
          @simatec sagte in Test Adapter shuttercontrol v1.1.x:
          ... so wie in meiner Signatur beschrieben auf debug
          Wo genau soll die denn sein 🤔 ich sehe nix
            Homoran Global Moderator Administrators @MichMein last edited by
            @MichMein sagte in Test Adapter shuttercontrol v1.1.x:
            Wo genau soll die denn sein ich sehe nix
            dann musst du das aktivieren
              FoxRo @Tom Haase last edited by
              @Tom-Haase said in Test Adapter shuttercontrol v1.1.x:
              ... Rollladen wurde runtergefahren..
              ... Fenster wurde geöffnet ...
              ..an dieser Stelle müsste der Fahrauftrag kommen um auf 50% zu fahren...
              Im Code gibt es an dieser Stelle keine weitere Verzweigung oder Abhängigkeiten!
              Warum dann erst 2Sek später vom FHEM was zum "Alive" gemeldet wird weiss ich nicht, sieht aber danach aus, dass der FHEM Adapter an dieser Stelle neu gestartet wurde. (warum auch immer)
              Wenn das so ist, kann dieser den Fahrauftrag vom Shuttercontrol wohl nicht ausführen.
              Kannst Du mal in den Objekten vom Shuttercontrol / shutters schauen, was für Werte im autoState und im autoLevel für den Rollladen stehen, während Du das Fenster offen hast?
              Das gibt einen Hinweis, ob die Stelle von Shuttercontrol korrekt weiter durchlaufen wurde.
              Allenfalls gibt es noch mehr an Informationen her, wenn alle anderen Adapter, die nicht benötigt werden, stoppst und den FHEM Adapter gleich wie den Shuttercontrol auf Debug stellst.
                Tom Haase @FoxRo last edited by Tom Haase
                @FoxRo sagte in Test Adapter shuttercontrol v1.1.x:
                und so sieht es bei geschlossenem Rollo aus:
                  Tom Haase last edited by Tom Haase
                  Puuuh!
                  Rolladen per "closeSleep" manuell heruntergefahren, dann den Fensterkontakt geöffnet
                  2021-01-09 18:34:58.573 - debug: fhem.0 (8023) [setAlive] start setAlive 300 sec
                  2021-01-09 18:34:58.581 - info: fhem.0 (8023) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                  2021-01-09 18:34:58.583 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213698576,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698576}
                  2021-01-09 18:34:58.592 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "dummy fhem.0.alive on"
                  2021-01-09 18:34:58.594 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive true - start
                  2021-01-09 18:34:58.596 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive reset timer
                  2021-01-09 18:34:58.653 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM {"val":"","ack":true,"ts":1610213698647,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398597}
                  2021-01-09 18:34:58.656 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Info.alive true {"val":true,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213098621}
                  2021-01-09 18:34:58.659 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberIn 19 {"val":19,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
                  2021-01-09 18:34:58.663 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeIn 57 {"val":57,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
                  2021-01-09 18:34:58.666 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberOut 1 {"val":1,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
                  2021-01-09 18:34:58.670 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeOut 114 {"val":114,"ack":true,"ts":1610213698649,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698649}
                  2021-01-09 18:34:58.677 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213698673,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398609}
                  2021-01-09 18:34:58.680 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1610213698678,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698678}
                  2021-01-09 18:35:00.011 - debug: shuttercontrol.0 (1591) calculate astrodata ...
                  2021-01-09 18:35:00.012 - debug: shuttercontrol.0 (1591) Sun Azimut: NaN°
                  2021-01-09 18:35:00.013 - debug: shuttercontrol.0 (1591) Sun Elevation: NaN°
                  2021-01-09 18:39:23.313 - debug: shuttercontrol.0 (1591) start buttonAction
                  2021-01-09 18:39:23.316 - info: shuttercontrol.0 (1591) Set ID: Buero1 pct value: 100%
                  2021-01-09 18:39:23.318 - debug: shuttercontrol.0 (1591) shutterDownButton Buero1 pct old height: 0% new height: 100%
                  2021-01-09 18:39:23.324 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 100 {"val":100,"ack":false,"ts":1610213963319,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc":1610213963319}
                  2021-01-09 18:39:23.328 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
                  2021-01-09 18:39:23.329 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
                  2021-01-09 18:39:23.434 - info: fhem.0 (8023) stateChange (out): fhem.0.Friedhelm.pct | 100 > set Friedhelm pct 100
                  2021-01-09 18:39:23.436 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm command: pct-100"
                  2021-01-09 18:39:23.437 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm command: pct-100 | reading > fhem.0.Friedhelm.command pct-100
                  2021-01-09 18:39:23.438 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm desired_pct: 100"
                  2021-01-09 18:39:23.439 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm desired_pct: 100 | reading > fhem.0.Friedhelm.desired_pct 100
                  2021-01-09 18:39:23.440 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm last_drive: drive-down"
                  2021-01-09 18:39:23.440 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm last_drive: drive-down | reading > fhem.0.Friedhelm.last_drive drive-down
                  2021-01-09 18:39:23.441 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-down"
                  2021-01-09 18:39:23.442 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | state > fhem.0.Friedhelm.state drive-down
                  2021-01-09 18:39:23.443 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | boolean > fhem.0.Friedhelm.state_boolean drive-down
                  2021-01-09 18:39:23.444 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | value > fhem.0.Friedhelm.state_value drive-down
                  2021-01-09 18:39:23.445 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-type: modul"
                  2021-01-09 18:39:23.445 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm drive-type: modul | reading > fhem.0.Friedhelm.drive-type modul
                  2021-01-09 18:39:23.446 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: down"
                  2021-01-09 18:39:23.447 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: down | reading > fhem.0.SD_Keeloq_AC6000.button down
                  2021-01-09 18:39:23.448 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                  2021-01-09 18:39:23.449 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                  2021-01-09 18:39:23.449 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9226"
                  2021-01-09 18:39:23.450 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9226 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9226
                  2021-01-09 18:39:23.451 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send down"
                  2021-01-09 18:39:23.452 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send down | state > fhem.0.SD_Keeloq_AC6000.state send down
                  2021-01-09 18:39:23.453 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: down"
                  2021-01-09 18:39:23.453 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: down | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 down
                  2021-01-09 18:39:23.454 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                  2021-01-09 18:39:23.455 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                  2021-01-09 18:39:23.481 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.command pct-100 {"val":"pct-100","ack":true,"ts":1610213963474,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963474}
                  2021-01-09 18:39:23.482 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.desired_pct 100 {"val":"100","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
                  2021-01-09 18:39:23.486 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.last_drive drive-down {"val":"drive-down","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
                  2021-01-09 18:39:23.490 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state drive-down {"val":"drive-down","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
                  2021-01-09 18:39:23.491 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean drive-down {"val":"drive-down","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
                  2021-01-09 18:39:23.495 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value drive-down {"val":"drive-down","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
                  2021-01-09 18:39:23.496 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button down {"val":"down","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
                  2021-01-09 18:39:23.497 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9226 {"val":"9226","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
                  2021-01-09 18:39:23.501 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send down {"val":"send down","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
                  2021-01-09 18:39:23.502 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 down {"val":"down","ack":true,"ts":1610213963478,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963478}
                  2021-01-09 18:39:50.099 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm pct: 100"
                  2021-01-09 18:39:50.100 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm pct: 100 | reading > fhem.0.Friedhelm.pct 100
                  2021-01-09 18:39:50.101 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: stop"
                  2021-01-09 18:39:50.102 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: stop | reading > fhem.0.SD_Keeloq_AC6000.button stop
                  2021-01-09 18:39:50.103 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                  2021-01-09 18:39:50.104 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                  2021-01-09 18:39:50.104 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9227"
                  2021-01-09 18:39:50.105 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9227 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9227
                  2021-01-09 18:39:50.106 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send stop"
                  2021-01-09 18:39:50.106 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
                  2021-01-09 18:39:50.107 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop"
                  2021-01-09 18:39:50.108 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop
                  2021-01-09 18:39:50.109 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                  2021-01-09 18:39:50.109 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                  2021-01-09 18:39:50.110 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm closed"
                  2021-01-09 18:39:50.111 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | state > fhem.0.Friedhelm.state closed
                  2021-01-09 18:39:50.112 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | boolean > fhem.0.Friedhelm.state_boolean false
                  2021-01-09 18:39:50.113 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | value > fhem.0.Friedhelm.state_value 0
                  2021-01-09 18:39:50.140 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 100 {"val":"100","ack":true,"ts":1610213990132,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990132}
                  2021-01-09 18:39:50.141 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button stop {"val":"stop","ack":true,"ts":1610213990133,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990133}
                  2021-01-09 18:39:50.148 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
                  2021-01-09 18:39:50.147 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9227 {"val":"9227","ack":true,"ts":1610213990134,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990134}
                  2021-01-09 18:39:50.148 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
                  2021-01-09 18:39:50.151 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send stop {"val":"send stop","ack":true,"ts":1610213990134,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990134}
                  2021-01-09 18:39:50.155 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop {"val":"stop","ack":true,"ts":1610213990137,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990137}
                  2021-01-09 18:39:50.156 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state closed {"val":"closed","ack":true,"ts":1610213990138,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990138}
                  2021-01-09 18:39:50.156 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean false {"val":false,"ack":true,"ts":1610213990138,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990138}
                  2021-01-09 18:39:50.157 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value 0 {"val":0,"ack":true,"ts":1610213990139,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990139}
                  2021-01-09 18:39:54.744 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
                  2021-01-09 18:39:54.749 - debug: shuttercontrol.0 (1591) save trigger height: 100% for device: Buero1 pct
                  2021-01-09 18:39:54.750 - debug: shuttercontrol.0 (1591) save trigger action: down for device: Buero1 pct
                  2021-01-09 18:39:58.576 - debug: fhem.0 (8023) [setAlive] start setAlive 300 sec
                  2021-01-09 18:39:58.584 - info: fhem.0 (8023) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                  2021-01-09 18:39:58.585 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213998579,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998579}
                  2021-01-09 18:39:58.595 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "dummy fhem.0.alive on"
                  2021-01-09 18:39:58.596 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive true - start
                  2021-01-09 18:39:58.599 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive reset timer
                  2021-01-09 18:39:58.627 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM {"val":"","ack":true,"ts":1610213998620,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398597}
                  2021-01-09 18:39:58.630 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Info.alive true {"val":true,"ack":true,"ts":1610213998621,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213098621}
                  2021-01-09 18:39:58.641 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberIn 18 {"val":18,"ack":true,"ts":1610213998622,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998622}
                  2021-01-09 18:39:58.645 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeIn 47 {"val":47,"ack":true,"ts":1610213998623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998623}
                  2021-01-09 18:39:58.649 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberOut 1 {"val":1,"ack":true,"ts":1610213998623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
                  2021-01-09 18:39:58.650 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeOut 111 {"val":111,"ack":true,"ts":1610213998623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998623}
                  2021-01-09 18:39:58.655 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213998649,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398609}
                  2021-01-09 18:39:58.662 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1610213998658,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998658}
                  2021-01-09 18:40:00.008 - debug: shuttercontrol.0 (1591) calculate astrodata ...
                  2021-01-09 18:40:00.009 - debug: shuttercontrol.0 (1591) Sun Azimut: NaN°
                  2021-01-09 18:40:00.010 - debug: shuttercontrol.0 (1591) Sun Elevation: NaN°
                  • simatec
                    simatec Developer Most Active @Tom Haase last edited by
                    @Tom-Haase Kann es sein, dass fhem ein Problem mit den 50% hat?
                    Setze mal zum testen die Rollladenhöhe bei geöffneten Fenster auf 0%
                      Die Screenshots sind von den Zuständen, wenn der Rollladen oben resp. unten ist.
                      Mich würde wunder nehmen, wie die Zustände sind, nachdem du runter gefahren hast und dann während dem das Fenster offen ist.
                      der autoLevel müsste dann eigentlich auf den Wert vom Trigger (50%) und der autoState auf "Triggered" ändern.
                      Damit liese sich prüfen, ob der Shuttercontrol Code an dieser Stelle weiterläuft und zum setzen der Zustände kommt oder ob er an der Stelle komplett abbricht - warum auch immer.
                        Tom Haase @simatec last edited by Tom Haase
                        Bingo!
                        Mit dieser Einstellung (0%) fährt der Rollo beim Kontakt öffnen komplett hoch und beim Schließen des Kontakts wieder runter.
                        Zu FHEM: Ich steuere in FHEM die Rollos mittels ASC und ich kann das in 10er Schritten einstellen, was auch gut funktioniert.
                        Das Log von dieser Aktion:
                        2021-01-10 09:07:59.648 - debug: shuttercontrol.0 (10924) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
                        2021-01-10 09:07:59.670 - debug: shuttercontrol.0 (10924) save trigger height: 100% for device Buero1 pct
                        2021-01-10 09:07:59.671 - debug: shuttercontrol.0 (10924) save trigger action: down for device Buero1 pct
                        2021-01-10 09:07:59.672 - info: shuttercontrol.0 (10924) #1 Set ID: Buero1 pct value: 0%
                        2021-01-10 09:07:59.681 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 0 {"val":0,"ack":false,"ts":1610266079676,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc":1610266079676}
                        2021-01-10 09:07:59.687 - debug: shuttercontrol.0 (10924) Shutter state changed: Buero1 pct old value = 100 new value = 0
                        2021-01-10 09:07:59.688 - debug: shuttercontrol.0 (10924) Buero1 pct Old value = 100. New value = 0. automatic is active
                        2021-01-10 09:07:59.781 - info: fhem.0 (8023) stateChange (out): fhem.0.Friedhelm.pct | 0 > set Friedhelm pct 0
                        2021-01-10 09:07:59.781 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm command: pct-0"
                        2021-01-10 09:07:59.782 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm command: pct-0 | reading > fhem.0.Friedhelm.command pct-0
                        2021-01-10 09:07:59.783 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm desired_pct: 0"
                        2021-01-10 09:07:59.783 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm desired_pct: 0 | reading > fhem.0.Friedhelm.desired_pct 0
                        2021-01-10 09:07:59.784 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm last_drive: drive-up"
                        2021-01-10 09:07:59.784 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm last_drive: drive-up | reading > fhem.0.Friedhelm.last_drive drive-up
                        2021-01-10 09:07:59.784 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-up"
                        2021-01-10 09:07:59.785 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | state > fhem.0.Friedhelm.state drive-up
                        2021-01-10 09:07:59.785 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | boolean > fhem.0.Friedhelm.state_boolean drive-up
                        2021-01-10 09:07:59.786 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | value > fhem.0.Friedhelm.state_value drive-up
                        2021-01-10 09:07:59.786 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-type: modul"
                        2021-01-10 09:07:59.786 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm drive-type: modul | reading > fhem.0.Friedhelm.drive-type modul
                        2021-01-10 09:07:59.787 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: up"
                        2021-01-10 09:07:59.787 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: up | reading > fhem.0.SD_Keeloq_AC6000.button up
                        2021-01-10 09:07:59.788 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                        2021-01-10 09:07:59.788 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                        2021-01-10 09:07:59.788 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9282"
                        2021-01-10 09:07:59.789 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9282 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9282
                        2021-01-10 09:07:59.789 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send up"
                        2021-01-10 09:07:59.789 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send up | state > fhem.0.SD_Keeloq_AC6000.state send up
                        2021-01-10 09:07:59.790 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: up"
                        2021-01-10 09:07:59.790 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: up | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 up
                        2021-01-10 09:07:59.790 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                        2021-01-10 09:07:59.791 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                        2021-01-10 09:07:59.810 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.command pct-0 {"val":"pct-0","ack":true,"ts":1610266079806,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079806}
                        2021-01-10 09:07:59.812 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.desired_pct 0 {"val":"0","ack":true,"ts":1610266079806,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079806}
                        2021-01-10 09:07:59.814 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.last_drive drive-up {"val":"drive-up","ack":true,"ts":1610266079806,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079806}
                        2021-01-10 09:07:59.816 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state drive-up {"val":"drive-up","ack":true,"ts":1610266079807,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079807}
                        2021-01-10 09:07:59.817 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean drive-up {"val":"drive-up","ack":true,"ts":1610266079808,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079808}
                        2021-01-10 09:07:59.820 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value drive-up {"val":"drive-up","ack":true,"ts":1610266079808,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079808}
                        2021-01-10 09:07:59.822 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button up {"val":"up","ack":true,"ts":1610266079808,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079808}
                        2021-01-10 09:07:59.823 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9282 {"val":"9282","ack":true,"ts":1610266079809,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079809}
                        2021-01-10 09:07:59.824 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send up {"val":"send up","ack":true,"ts":1610266079809,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079809}
                        2021-01-10 09:07:59.828 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 up {"val":"up","ack":true,"ts":1610266079809,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079809}
                        2021-01-10 09:08:28.102 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm pct: 0"
                        2021-01-10 09:08:28.103 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm pct: 0 | reading > fhem.0.Friedhelm.pct 0
                        2021-01-10 09:08:28.103 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: stop"
                        2021-01-10 09:08:28.103 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: stop | reading > fhem.0.SD_Keeloq_AC6000.button stop
                        2021-01-10 09:08:28.103 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                        2021-01-10 09:08:28.104 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                        2021-01-10 09:08:28.104 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9283"
                        2021-01-10 09:08:28.104 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9283 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9283
                        2021-01-10 09:08:28.105 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send stop"
                        2021-01-10 09:08:28.105 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
                        2021-01-10 09:08:28.105 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop"
                        2021-01-10 09:08:28.106 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop
                        2021-01-10 09:08:28.106 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                        2021-01-10 09:08:28.106 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                        2021-01-10 09:08:28.106 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm open"
                        2021-01-10 09:08:28.107 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm open | state > fhem.0.Friedhelm.state open
                        2021-01-10 09:08:28.107 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm open | boolean > fhem.0.Friedhelm.state_boolean true
                        2021-01-10 09:08:28.107 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm open | value > fhem.0.Friedhelm.state_value 2
                        2021-01-10 09:08:28.121 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 0 {"val":"0","ack":true,"ts":1610266108115,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108115}
                        2021-01-10 09:08:28.124 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button stop {"val":"stop","ack":true,"ts":1610266108115,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108115}
                        2021-01-10 09:08:28.125 - debug: shuttercontrol.0 (10924) Shutter state changed: Buero1 pct old value = 100 new value = 0
                        2021-01-10 09:08:28.124 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9283 {"val":"9283","ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                        2021-01-10 09:08:28.126 - debug: shuttercontrol.0 (10924) Buero1 pct Old value = 100. New value = 0. automatic is active
                        2021-01-10 09:08:28.127 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send stop {"val":"send stop","ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                        2021-01-10 09:08:28.127 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop {"val":"stop","ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                        2021-01-10 09:08:28.129 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state open {"val":"open","ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                        2021-01-10 09:08:28.129 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean true {"val":true,"ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                        2021-01-10 09:08:28.129 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value 2 {"val":2,"ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                        2021-01-10 09:08:32.940 - debug: shuttercontrol.0 (10924) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: false
                        2021-01-10 09:08:32.946 - info: shuttercontrol.0 (10924) change to last height: 100% for device: Buero1 pct
                        2021-01-10 09:08:32.947 - debug: shuttercontrol.0 (10924) save back trigger action: down for device: Buero1 pct
                        2021-01-10 09:08:32.953 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 100 {"val":100,"ack":false,"ts":1610266112948,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc":1610266112948}
                        2021-01-10 09:08:32.958 - debug: shuttercontrol.0 (10924) Buero1 pct Old value = 100. New value = 100. automatic is active
                        2021-01-10 09:08:33.044 - info: fhem.0 (8023) stateChange (out): fhem.0.Friedhelm.pct | 100 > set Friedhelm pct 100
                        2021-01-10 09:08:33.045 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm command: pct-100"
                        2021-01-10 09:08:33.046 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm command: pct-100 | reading > fhem.0.Friedhelm.command pct-100
                        2021-01-10 09:08:33.046 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm desired_pct: 100"
                        2021-01-10 09:08:33.047 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm desired_pct: 100 | reading > fhem.0.Friedhelm.desired_pct 100
                        2021-01-10 09:08:33.047 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm last_drive: drive-down"
                        2021-01-10 09:08:33.048 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm last_drive: drive-down | reading > fhem.0.Friedhelm.last_drive drive-down
                        2021-01-10 09:08:33.048 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-down"
                        2021-01-10 09:08:33.049 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | state > fhem.0.Friedhelm.state drive-down
                        2021-01-10 09:08:33.049 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | boolean > fhem.0.Friedhelm.state_boolean drive-down
                        2021-01-10 09:08:33.050 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | value > fhem.0.Friedhelm.state_value drive-down
                        2021-01-10 09:08:33.050 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-type: modul"
                        2021-01-10 09:08:33.051 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm drive-type: modul | reading > fhem.0.Friedhelm.drive-type modul
                        2021-01-10 09:08:33.051 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: down"
                        2021-01-10 09:08:33.052 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: down | reading > fhem.0.SD_Keeloq_AC6000.button down
                        2021-01-10 09:08:33.052 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                        2021-01-10 09:08:33.053 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                        2021-01-10 09:08:33.053 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9284"
                        2021-01-10 09:08:33.054 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9284 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9284
                        2021-01-10 09:08:33.054 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send down"
                        2021-01-10 09:08:33.054 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send down | state > fhem.0.SD_Keeloq_AC6000.state send down
                        2021-01-10 09:08:33.055 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: down"
                        2021-01-10 09:08:33.055 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: down | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 down
                        2021-01-10 09:08:33.056 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                        2021-01-10 09:08:33.056 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                        2021-01-10 09:08:33.076 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.command pct-100 {"val":"pct-100","ack":true,"ts":1610266113071,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113071}
                        2021-01-10 09:08:33.080 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.desired_pct 100 {"val":"100","ack":true,"ts":1610266113072,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113072}
                        2021-01-10 09:08:33.082 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.last_drive drive-down {"val":"drive-down","ack":true,"ts":1610266113072,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113072}
                        2021-01-10 09:08:33.084 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state drive-down {"val":"drive-down","ack":true,"ts":1610266113072,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113072}
                        2021-01-10 09:08:33.087 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean drive-down {"val":"drive-down","ack":true,"ts":1610266113072,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113072}
                        2021-01-10 09:08:33.090 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value drive-down {"val":"drive-down","ack":true,"ts":1610266113073,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113073}
                        2021-01-10 09:08:33.091 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button down {"val":"down","ack":true,"ts":1610266113073,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113073}
                        2021-01-10 09:08:33.091 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9284 {"val":"9284","ack":true,"ts":1610266113074,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113074}
                        2021-01-10 09:08:33.093 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send down {"val":"send down","ack":true,"ts":1610266113074,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113074}
                        2021-01-10 09:08:33.094 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 down {"val":"down","ack":true,"ts":1610266113074,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113074}
                        2021-01-10 09:09:00.109 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm pct: 100"
                        2021-01-10 09:09:00.110 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm pct: 100 | reading > fhem.0.Friedhelm.pct 100
                        2021-01-10 09:09:00.111 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: stop"
                        2021-01-10 09:09:00.111 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: stop | reading > fhem.0.SD_Keeloq_AC6000.button stop
                        2021-01-10 09:09:00.112 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                        2021-01-10 09:09:00.112 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                        2021-01-10 09:09:00.113 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9285"
                        2021-01-10 09:09:00.114 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9285 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9285
                        2021-01-10 09:09:00.114 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send stop"
                        2021-01-10 09:09:00.115 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
                        2021-01-10 09:09:00.115 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop"
                        2021-01-10 09:09:00.116 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop
                        2021-01-10 09:09:00.116 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                        2021-01-10 09:09:00.117 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                        2021-01-10 09:09:00.118 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm closed"
                        2021-01-10 09:09:00.118 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | state > fhem.0.Friedhelm.state closed
                        2021-01-10 09:09:00.119 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | boolean > fhem.0.Friedhelm.state_boolean false
                        2021-01-10 09:09:00.120 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | value > fhem.0.Friedhelm.state_value 0
                        2021-01-10 09:09:00.152 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 100 {"val":"100","ack":true,"ts":1610266140144,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140144}
                        2021-01-10 09:09:00.156 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button stop {"val":"stop","ack":true,"ts":1610266140145,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140145}
                        2021-01-10 09:09:00.159 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9285 {"val":"9285","ack":true,"ts":1610266140146,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140146}
                        2021-01-10 09:09:00.161 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send stop {"val":"send stop","ack":true,"ts":1610266140146,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140146}
                        2021-01-10 09:09:00.164 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop {"val":"stop","ack":true,"ts":1610266140147,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140147}
                        2021-01-10 09:09:00.166 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state closed {"val":"closed","ack":true,"ts":1610266140147,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140147}
                        2021-01-10 09:09:00.168 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean false {"val":false,"ack":true,"ts":1610266140148,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140148}
                        2021-01-10 09:09:00.172 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value 0 {"val":0,"ack":true,"ts":1610266140148,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140148}
                        2021-01-10 09:09:00.176 - debug: shuttercontrol.0 (10924) Shutter state changed: Buero1 pct old value = 0 new value = 100
                        2021-01-10 09:09:00.177 - debug: shuttercontrol.0 (10924) Buero1 pct Old value = 0. New value = 100. automatic is active
                        Übrigens: Alle anderen Schritte 10-25.....% funzen nicht!
                        simatec F 2 Replies Last reply Reply Quote 0
                        • simatec
                          @Tom-Haase sagte in Test Adapter shuttercontrol v1.1.x:
                          Bingo!
                          OK also können wir ein Problem bei shuttercontrol ausschließen.
                          Was passiert, wenn du den state deines Rollladen manuell auf 50% setzt?
                          Falls er nicht fahren sollte, was ich vermute, dann nimm mal den Log und mache beim fhem Adapter ein Issue auf, bzw. suche/frage mal hier im Forum zwecks fhem Adapter nach.
                          Ich kenne den Adapter leider nicht.
                            Bingo!
                            Schön, dass du da einen Schritt weiter gekommen bist.
                            (hatte schon Bammel, ob ich da in der Vergangenheit was "verbockt" habe?) 🙄
                            Den FHEM und den FHEM Adapter kenne ich auch nicht. Weiss nur, dass der Adapter via Telnet Commands mit dem FHEM kommuniziert. Könntest evtl prüfen, ob Du via Telnet das Kommando mit 50% manuell direkt auslösen kannst. Damit könntest feststellen ob das Problem im FHEM oder im FHEM Adapter liegt.
                            Seltsam ist, dass IoBroker offensichtlich den Wert nicht schreiben kann dies aber ohne Fehlermeldung einfach übergeht. Könnte es sein, dass der Datentyp des Rollo Positionsobjekts vom FHEM Adapter nicht kompatibel ist? Bei mir ist die Rolloposition vom Typ "number". Du kannst dies im Objekt unter der Kartei RAW (nur Experten) einsehen.
                            Weiter kann ich dir leider auch nicht mehr helfen.
                            Viel Erfolg!
                            Roli
                              Ehrlich gesagt hört hier schon mein bischen Wissen auf.......leider.
                              Über object----autolevel...?
                              Hast du noch ne Krücke für mich?
                                Ja wie oben geschrieben, dass geht für mich jetzt zu sehr ans Eingemachte. Sehr schade. Ich lass das aber mal auf mich wirken. Vielleicht findet sich hier nochmal ein FHEM-Experte ein, der mir u.U. helfen könnte.
                                Ich würde ja am liebsten ganz auf FHEM verzichten, nutze sowieso nur noch das "Rollo"Modul in FHEM, weil es anscheinend die einzige Möglichkeit bietet, meine Jarolift Funkschalter anzusteuern. Vielleicht gibt es ja mal jemanden hier in der iobroker Welt, der das "Rollo Modul" auf iobroker überträgt. Es gibt ja doch einige die die Jaros nutzen. Wäre toll.
                                Zunächst aber mal ganz lieben Dank euch Beiden für die Mühe
                                lg
                                tom
                                  Ich möchte euch beiden doch noch mal auf die Nerven gehen bevor ich mich dann vielleicht doch von diesem schönen Adapter verabschieden muss.....leider
                                  Ich habe gerade nochmal meine ursprüngliche Einstellung genommen und probiert:
                                  Also
                                  Ok ich weiß es sollte 0 und 100 getauscht sein. Habe ich verstanden.
                                  Aber mit dieser Einstellung fährt der Rollo auf jede Stellung die ich einstelle per Fensterkontakt, ganz sauber. Alles probiert!
                                  Allerdings ist dann close und open bei den Objects vertauscht. Zum Schließen muss ich dann bspw. "openSleep" zum öffnen nehmen. Wenn ich das nun per Option tauschen könnte, würde doch sicherlich auch die Zeitsteuerung funktionieren, oder denke ich da total falsch?
                                  Und das heißt aber doch auch , dass die Kommandos zum "%fahren" der Rollos bei FHEM ankommen, oder?
                                  Tom
                                  simatec 2 Replies Last reply Reply Quote 0
                                  • simatec
                                    @Tom-Haase
                                    Deine Einstellungen sind noch immer falsch.
                                    • simatec
                                      @Tom-Haase
                                      Ich habe deine Konstellation mal simuliert und es funktioniert problemlos.
                                      Bitte halte dich an meinen Screenshot bzw. meine markierten Änderungen
                                        @simatec said in Test Adapter shuttercontrol v1.1.x:
                                        das hatte ich ja schon eingestellt und damit fährt das Ding ja auch odentlich rauf und runter. Aber eben der Fensterkontakt mag diese Einstellung nicht und möchte es anscheinend lieber anders rum.
                                        2021-01-12 07:42:14.678 - debug: shuttercontrol.0 (29264) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
                                        2021-01-12 07:42:14.682 - debug: shuttercontrol.0 (29264) save trigger height: 100% for device: Buero1 pct
                                        2021-01-12 07:42:14.683 - debug: shuttercontrol.0 (29264) save trigger action: down for device: Buero1 pct
                                        2021-01-12 07:42:18.533 - debug: shuttercontrol.0 (29264) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: false
                                        2021-01-12 07:42:18.540 - debug: shuttercontrol.0 (29264) shutter trigger released Buero1 pct already in place: 100%
                                        2021-01-12 07:42:18.541 - debug: shuttercontrol.0 (29264) save back trigger action: down for device Buero1 pct
                                        Hattest du den Fensterkontakt auch simuliert?
                                        • simatec
                                          @tom-haase
                                          Den Fensterkontakt hatte ich auch simuliert.
                                          Der Zigbee Kontakt opened ist ein ein state für die Meldung offen.
                                          offen = true
                                          geschlossen = false
                                          shuttercontrol benötigt in der Config den Wert des geschlossenen Zustandes.
                                          Also musst du "false" einstellen.
                                            Alles brav gemacht, das Biest macht nix.
                                            F simatec 2 Replies Last reply Reply Quote 0
                                            331
                                            7376
                                            10251307
