    4. Beta Test js-controller 3.2.x auf GitHub
      apollon77 @lobomau last edited by
      @lobomau iobroker fix bitte, dann nochmal versuchen. Danke
      lobomau 1 Reply Last reply Reply Quote 0
        apollon77 @Feuersturm last edited by
        @Feuersturm was sagt „iobroker setup custom“ bei der objects databank für einen Typ? File oder redis?
        • lobomau
          lobomau @apollon77 last edited by lobomau
          @apollon77 hab ich kein ioBroker mehr!?
          der zweite Befehl mit fix.sh hatte auch nicht geklappt.
          Nun läuft gerade durch:
          sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
          • lobomau
            lobomau @lobomau last edited by lobomau
            @apollon77 ich glaube es hat geklappt:
            pi@Pi3:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
            library: loaded
            Library version=2020-12-07
            ioBroker is not installed in /opt/iobroker! Cannot fix anything...
            pi@Pi3:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker/ioBroker.js-cont                                                        roller
            > iobroker.js-controller@3.2.4 preinstall /opt/iobroker/node_modules/iobroker.js                                                        -controller
            > node lib/preinstallCheck.js
            NPM version: 6.14.10
            > iobroker.js-controller@3.2.4 install /opt/iobroker/node_modules/iobroker.js-co                                                        ntroller
            > node iobroker.js setup first
            object 0_userdata.0.example_state created
            object _design/system updated
            ioBroker configuration updated
            > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
            > node scripts/postinstall
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/ch                                                        okidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                                                        2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                                                        )
            + iobroker.js-controller@3.2.4
            added 87 packages from 45 contributors, removed 3 packages and moved 1 package i                                                        n 178.757s
            11 packages are looking for funding
              run `npm fund` for details
            pi@Pi3:/opt/iobroker $ sudo npm fund
            iobroker.inst@2.0.3
            ├─┬ https://github.com/sponsors/isaacs
            │ └── glob@7.1.6
            ├─┬ https://github.com/sponsors/epoberezkin
            │ └── ajv@6.12.3
            ├─┬ https://github.com/sponsors/RubenVerborgh
            │ └── follow-redirects@1.13.0
            ├─┬ https://github.com/sponsors/ljharb
            │ └── is-nan@1.3.0, resolve@1.17.0, has-symbols@1.0.1
            ├─┬ https://opencollective.com/ioredis
            │ └── ioredis@4.19.4
            ├─┬ https://github.com/sponsors/jonschlinkert
            │ └── picomatch@2.2.2
            ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
            │ └── wrap-ansi@7.0.0
            ├─┬ https://github.com/chalk/ansi-styles?sponsor=1
            │ └── ansi-styles@4.3.0
            ├─┬ https://github.com/sponsors/feross
            │ └── safe-buffer@5.2.1, simple-concat@1.0.1
            ├─┬ https://www.patreon.com/feross
            ├─┬ https://feross.org/support
            └─┬ https://github.com/sponsors/sindresorhus
              └── mimic-response@2.1.0
            pi@Pi3:/opt/iobroker $ sudo iobroker start
              @lobomau passt.
              • lobomau
                @apollon77 hab mir den nächsten slave einen Pi1 vorgenommen. Diesmal zuerst den fix gestartet, aber fürhrt zum gleichen Fehler (?) wie beim Pi3. Ich mache dann gleich wieder den Schritt wie beim Pi3.
                pi@raspberrypi:~ $ cd /opt/iobroker
                pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
                pi@raspberrypi:/opt/iobroker $ sudo iobroker fix
                library: loaded
                    Welcome to the ioBroker installation fixer!
                    Script version: 2020-12-07
                    Installing prerequisites (1/3)
                Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                Reading package lists... Done
                Installed gcc-c++
                    Checking ioBroker user and directory permissions (2/3)
                Created /etc/sudoers.d/iobroker
                Fixing directory permissions...
                    Checking autostart (3/3)
                Enabling autostart...
                Autostart enabled!
                    Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                pi@raspberrypi:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
                Could not check npm version: Error: Timeout
                Assuming that correct version is installed.
                Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/io                             broker/node_modules/iobroker.js-controller/lib/setup/../../../../reinstall.js'
                Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.                             bat'
                Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
                fs.js:114
                    throw err;
                Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-                             controller/lib/setup/../../tmp'
                    at Object.mkdirSync (fs.js:757:3)
                    at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/                             setupSetup.js:835:16)
                    at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/set                             up.js:272:23)
                    at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-con                             troller/lib/setup.js:2643:5)
                    at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iob                             roker.js:1:24)
                    at Module._compile (internal/modules/cjs/loader.js:778:30)
                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                    at Module.load (internal/modules/cjs/loader.js:653:32)
                    at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                    at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! iobroker.js-controller@3.2.4 install: `node iobroker.js setup first`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the iobroker.js-controller@3.2.4 install script.
                npm ERR! This is probably not a problem with npm. There is likely additional log                             ging output above.
                npm ERR!     /root/.npm/_logs/2021-01-10T08_43_13_360Z-debug.log
                • lobomau
                  @apollon77 ich habe alle Geräte auf 3.2.4 angehoben und alle Adapter sind grün.
                  ABER: es klappte immer nur mit
                  Und der Fix brachte auch nichts.
                  • SBorg
                    @apollon77 Moin Ingo, den VIS-Dateimanager kann ich unter file-DB bestätigen. Er "bastelt" da pro Klick auf den /vis.0/ - Ordner jedes mal einen neuen Slash mit an 😉
                    apollon77 sigi234 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @lobomau last edited by Thomas Braun
                      @lobomau
                      Man macht das auch ja nicht mit
                      sudo npm
                      oder
                      sudo iobroker
                      Damit haust du das ganze als root ins System! Das ist falsch.
                        apollon77 @Thomas Braun last edited by
                        @Thomas-Braun da hast du recht hab ich gar nicht gesehen gehabt ;-))
                          apollon77 @SBorg last edited by
                          @SBorg konnte es lokal nachstellen. Schaue ich nachher an
                            sigi234 Forum Testing Most Active @SBorg last edited by
                            @SBorg sagte in Beta Test js-controller 3.2.x auf GitHub:
                            Jupp, und der Ordner Projekt ist auch weg!
                            • Wal
                              Wal Developer last edited by
                              Eben mal den Controller aktualisiert, habe sonst nichts zu tun 🙂
                              Ohne Fehler durchgelaufen.
                              Installierte Adapter:
                              Proxmox System:
                              • SBorg
                                Ich hatte es zwar schon lt. Anzeige im ioB bemerkt, aber er braucht wohl offensichtlich weniger RAM 🙂
                                Ich weiß nur gerade nicht ob der aktuelle 3.1.6 auch satte 2GB beim starten braucht, könnte aber auch dem da gerade durchgeführtem Update auf die 3.2.4 geschuldet sein...
                                  A Former User @apollon77 last edited by
                                  @apollon77 sagte in Beta Test js-controller 3.2.x auf GitHub:
                                  Mal andere Frage: Schaut mal ob jemand hier einejn Eintrag hat (unter "Objekte", Expertenmodus, "system.host.NAME.notifications" ... Falls das bei jemandem nicht leer ist bitte iobroker mal stoppen und in iobroker-data nach der notifications.json schauen und den Inhalt mal posten ... Danke 🙂
                                  Bitteschön, beim Server, sollte Enigma, Mihome-Vacuum gewesen sein...
                                  {"restartLoop":{"count":4}}
                                  mehr steht da leider nicht, hab auf den Datenpunkt mal die History angesetzt und lass mir das in der View anzeigen, bzw. einfach per Telegram schicken, wenn sich was ändert.. 🙂
                                  • lobomau
                                    bei meinem Pi3 slave steht
                                    {"restartLoop":{"count":1}}
                                    notifivation.json leer:
                                    pi@raspberrypi:/opt $ cd iobroker
                                    pi@raspberrypi:/opt/iobroker $ cd iobroker-data
                                    pi@raspberrypi:/opt/iobroker/iobroker-data $ ls
                                    backup-objects  iobroker.json       objects.json      states.json
                                    files           notifications.json  objects.json.bak  states.json.bak
                                    pi@raspberrypi:/opt/iobroker/iobroker-data $ sudo nano notifications.json
                                      GNU nano 3.2                   notifications.json
                                      Thomas Braun Most Active @apollon77 last edited by
                                      @apollon77
                                      notifications.json
                                      {"system":{"restartLoop":{"system.adapter.mihome-vacuum.0":[{"message":"Restart loop detected","ts":1610197549296}],"system.adapter.zigbee.0":[{"message":"Restart loop detected","ts":1610196881536}]}}}
                                      • Feuersturm
                                        Feuersturm @apollon77 last edited by
                                        Ich nutze dann wohl file 🙂
                                        proxmox@ioBrokerBETA:~$ iobroker setup custom
                                        Current configuration:
                                        - Objects database:
                                          - Type: file
                                        • lobomau
                                          Bei mir machen RAM und CPU folgendes. Ursache kenne ich noch nicht.
                                          • Wal
                                            Wal Developer @SBorg last edited by
                                            @SBorg ,
                                            nicht schlecht dein Speicherverbrauch. Bei mir sind es ca. 200MB weniger, von 1,4GB auf 1,14GB.
                                            Instanzen siehe oben, Grafana läuft auch noch im gleichen Container.
                                            js-controller
                                            25
                                            287
                                            46101
