Beta Test js-controller 3.2.x auf GitHub
@lobomau passt.
@apollon77 hab mir den nächsten slave einen Pi1 vorgenommen. Diesmal zuerst den fix gestartet, aber fürhrt zum gleichen Fehler (?) wie beim Pi3. Ich mache dann gleich wieder den Schritt wie beim Pi3.
pi@raspberrypi:~ $ cd /opt/iobroker pi@raspberrypi:/opt/iobroker $ sudo iobroker stop pi@raspberrypi:/opt/iobroker $ sudo iobroker fix library: loaded Library version=2020-12-07 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2020-12-07 ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Reading package lists... Done Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== pi@raspberrypi:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller > iobroker.js-controller@3.2.4 preinstall /opt/iobroker/node_modules/iobroker.js -controller > node lib/preinstallCheck.js Could not check npm version: Error: Timeout Assuming that correct version is installed. > iobroker.js-controller@3.2.4 install /opt/iobroker/node_modules/iobroker.js-co ntroller > node iobroker.js setup first Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/io broker/node_modules/iobroker.js-controller/lib/setup/../../../../reinstall.js' Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt /iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker. bat' Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat' Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat' fs.js:114 throw err; ^ Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js- controller/lib/setup/../../tmp' at Object.mkdirSync (fs.js:757:3) at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/ setupSetup.js:835:16) at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/set up.js:272:23) at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-con troller/lib/setup.js:2643:5) at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iob roker.js:1:24) at Module._compile (internal/modules/cjs/loader.js:778:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10) at Module.load (internal/modules/cjs/loader.js:653:32) at tryModuleLoad (internal/modules/cjs/loader.js:593:12) at Function.Module._load (internal/modules/cjs/loader.js:585:3) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/ch okidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@ 2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"} ) npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! iobroker.js-controller@3.2.4 install: `node iobroker.js setup first` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.js-controller@3.2.4 install script. npm ERR! This is probably not a problem with npm. There is likely additional log ging output above. npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2021-01-10T08_43_13_360Z-debug.log pi@raspberrypi:/opt/iobroker $ -
@apollon77 ich habe alle Geräte auf 3.2.4 angehoben und alle Adapter sind grün.
ABER: es klappte immer nur mitsudo -H -u iobroker npm install ioBroker/ioBroker.js-controllerUnd der Fix brachte auch nichts.
@apollon77 Moin Ingo, den VIS-Dateimanager kann ich unter file-DB bestätigen. Er "bastelt" da pro Klick auf den /vis.0/ - Ordner jedes mal einen neuen Slash mit an
@lobomau
Man macht das auch ja nicht mitsudo npmoder
sudo iobrokerDamit haust du das ganze als root ins System! Das ist falsch.
@Thomas-Braun da hast du recht hab ich gar nicht gesehen gehabt ;-))
@SBorg konnte es lokal nachstellen. Schaue ich nachher an
@SBorg sagte in Beta Test js-controller 3.2.x auf GitHub:
Jupp, und der Ordner Projekt ist auch weg!
Eben mal den Controller aktualisiert, habe sonst nichts zu tun
Ohne Fehler durchgelaufen.
Installierte Adapter:
Proxmox System:
Ich hatte es zwar schon lt. Anzeige im ioB bemerkt, aber er braucht wohl offensichtlich weniger RAM
Ich weiß nur gerade nicht ob der aktuelle 3.1.6 auch satte 2GB beim starten braucht, könnte aber auch dem da gerade durchgeführtem Update auf die 3.2.4 geschuldet sein... -
@apollon77 sagte in Beta Test js-controller 3.2.x auf GitHub:
Mal andere Frage: Schaut mal ob jemand hier einejn Eintrag hat (unter "Objekte", Expertenmodus, "system.host.NAME.notifications" ... Falls das bei jemandem nicht leer ist bitte iobroker mal stoppen und in iobroker-data nach der notifications.json schauen und den Inhalt mal posten ... Danke
Bitteschön, beim Server, sollte Enigma, Mihome-Vacuum gewesen sein...
{"restartLoop":{"count":4}}mehr steht da leider nicht, hab auf den Datenpunkt mal die History angesetzt und lass mir das in der View anzeigen, bzw. einfach per Telegram schicken, wenn sich was ändert..
bei meinem Pi3 slave steht
{"restartLoop":{"count":1}}notifivation.json leer:
pi@raspberrypi:/opt $ cd iobroker pi@raspberrypi:/opt/iobroker $ cd iobroker-data pi@raspberrypi:/opt/iobroker/iobroker-data $ ls backup-objects iobroker.json objects.json states.json files notifications.json objects.json.bak states.json.bak pi@raspberrypi:/opt/iobroker/iobroker-data $ sudo nano notifications.json GNU nano 3.2 notifications.json {} -
notifications.json
{"system":{"restartLoop":{"system.adapter.mihome-vacuum.0":[{"message":"Restart loop detected","ts":1610197549296}],"system.adapter.zigbee.0":[{"message":"Restart loop detected","ts":1610196881536}]}}} -
@Feuersturm was sagt „iobroker setup custom“ bei der objects databank für einen Typ? File oder redis?
Ich nutze dann wohl file
proxmox@ioBrokerBETA:~$ iobroker setup custom Current configuration: - Objects database: - Type: file -
Bei mir machen RAM und CPU folgendes. Ursache kenne ich noch nicht.
@SBorg ,
nicht schlecht dein Speicherverbrauch. Bei mir sind es ca. 200MB weniger, von 1,4GB auf 1,14GB.
Instanzen siehe oben, Grafana läuft auch noch im gleichen Container. -
@lobomau hast du vorm checken Des file iobroker gestoppt ;-))
@apollon77 ja
@Feuersturm Danke. Dachte ich mir
@lobomau interessant. Glaube da solltest du mal auf Prozess Ebene schauen
