    4. [Vorlage] Vis für Adapter HeatingControl
    • Rene_HM
      Rene_HM Developer @Conquest last edited by
      @Conquest steht noch auf der to do list...
      • moppel2810
        moppel2810 @Rene_HM last edited by
        @Rene_HM ja geht alles. dann mach mal lieber den 2.0 fertig👍 😉
        • Dominik F.
          Dominik F. @Rene_HM last edited by
          @Rene_HM
          Das geht einfach auf Set_Temperature und viel steckt da nicht hinter.
          Hier das Widget:
          [{"tpl":"tplIconInc","data":{"oid":"hm-rpc.0.MEQ0236893.2.SET_TEMPERATURE","visibility-cond":"==","visibility-val":1,"repeat_delay":"800","repeat_interval":"800","src":"/vis.0/Handy/images/ic_add_white_48dp.png","step":"+0.5","minmax":"24","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Inspiration/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Inspiration/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Inspiration/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"text":"","visibility-groups-action":"hide","name":"Wohnzimmer HK2","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"class":"mdui-button-raised mdui-green-bg","imageHeight":"100"},"style":{"left":"calc(90% - 23px)","top":"84px","background":"transparent","width":"46px","height":"46px","z-index":5,"border-style":"none","font-weight":"bold","font-size":"large"},"widgetSet":"jqui"}]
          • Rene_HM
            Rene_HM Developer @moppel2810 last edited by Rene_HM
            @moppel2810 Ich sehe das Problem mit der exception nun auch in der 2.0, kann aber die exception vermeiden, wenn ich "Verwendung der Stellantriebe, wenn kein Thermostat vorhanden ist" unter Aktoreinstellungen im admin auf "nichts" stelle. Ist das bei dir auch so?
            siehe issue
            moppel2810 1 Reply Last reply Reply Quote 0
            • moppel2810
              @Rene_HM
              Und jetzt bitte nochmal auf deutsch😂 🙈
              Ich hab nicht wirklich viel Ahnung😕
              • Rene_HM
                @moppel2810 Du hast oben den Fehler
                exception in HandleActors [Error: The id is empty! Please provide a valid id.]
                reportet.
                Ich war der Meinung, das Thema mit der 2.0 vom Adapter gelöst zu haben, nun sehe ich das gleiche Problem auch in der 2.0. Deshalb meine Frage, ob du diese Einstellung gesetzt hast:
                und ob der Fehler weg ist, wenn du diese Einstellung auf "nichts" änderst...
                • moppel2810
                  @Rene_HM nein Aktoren verwenden habe ich deaktiviert
                    Borio85 last edited by
                    Kann mir einer bitte erklären, wie ich das Haussymbol unten rechts wegbekomme? Finde es irgendwie nicht.
                    Auf dem iPad verdecktes es mir eins der Dreiecke zum auf- und zuklappen
                      @Dominik-F said in Test Adapter HeatingControl v2.0.x:
                      @Chaot
                      Zu deiner Frage ganz oben bezüglich Anleitung, hier ein Auszug aus der Anleitung von Pittini:
                      Es gibt, durch Klick auf die Symbole ganz rechts und links in der Titelleiste, ausklappbare Sidemenüs. Im rechten hab ich Dir Links zu den Projekten und Anleitungen von Vis, MaterialDesign und HeatingControl hinterlegt. Das linke Menü ist an sich unbenutzt, kann aber von Dir verwendet werden falls Du die Seite erweitern möchtest.
                      Hab ich selbst gerade erst gesehen als ich mir die Anleitung nochmal durchgelesen hab xD Das sind die Verweise die dir gefehlt haben zu z.B. dem MD CSS von Uhula.
                      Zu den Farbeinstellungen auch aus der Anleitung:
                      Die Farbeinstellungen sollten egal welche Version du genutzt hast trotzdem funktionieren.
                      Nutzt du einzelne Views aus der Vis in deinem eigenen Projekt oder nutzt du gerade ausschließlich Pittinis Vis? Wenn du die Views in deinem Projekt nutzt, dann wird dir vermutlich was fehlen. In Pittinis Vis sollte das alles funktionieren.
                      Wir können für Pittinis Vis aber mal folgendes probieren:
                      Im der View "abar" befinden sich 3 Widgets. Im dritten sind die Farbeinstellungen gespeichert.
                      Ersetze mal dieses Widget durch folgendes:
                      Dort sind meine Farbeinstellungen schon gespeichert, es sollte sich also theoretisch farblich etwas tun.
                      [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"\"primary_color\":\"#000000\",\n\"abar_color\":\"#121212\",\n\"tnav_color\":\"#000000\",\n\"bnav_color\":\"#000000\",\n\"lnav_color\":\"#000000\",\n\"rnav_color\":\"#000000\",\n\"secondary_color\":\"amber\",\n\"content_color\":\"#121212\",\n\"lnav_fixed_width\":\"{0_userdata.0.mdui.vis.lnav_fixed_width}\",\n\"lnav_fixed_open\":\"true\"\n\"color1\":\"\",\n\"color1_dark\":\"\",\n\"color2\":\"\",\n\"color2_dark\":\"\",\n\"color3\":\"\",\n\"color3_dark\":\"\"\n\n","class":"mdui-label xdui-config","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"104px","top":"536px","width":"542px","height":""},"widgetSet":"basic"}]
                      Um den Thread hier mit der Vis nicht zu überlasten, würde ich vorschlagen, dass du einen Thread aufmachst und wir dort schauen, dass deine Vis funktioniert.
                      @Dominik-F Ich häng mich mal dran, wenn ich die mdui-color Farben ändere passiert nichts, es bleibt alles so wie es ist. Die Standardfarben kann ich aber bearbeiten und sehe sofort jede Änderung. Dein Widget habe ich auch eingefügt und alles ist beim alten geblieben. Hast du evtl. eine Idee woran es liegen kann?
                      Dominik F. 2 Replies Last reply Reply Quote 0
                      • Dominik F.
                        Dominik F. @Borio85 last edited by
                        @Borio85
                        Ich gehe jetzt erstmal auf die neue Version 3.10 ein von Pittini
                        Das ist eine sehr spezielle Sache die schon n bissel weiter in die Materie geht. Brauchst du eigentlich nicht, ist eher ein Nice to have finde ich.
                        Ich glaube ich verstehe jetzt auch was @Chaot meinte.
                        Du kannst Widgets Farben geben, z.B. Grün --> mdui-green.
                        In Pittinis View findet das z.B. in der cardHzngProfilParam statt.
                        Wenn du jetzt dort das "green" durch "color1" ersetzt, kannst du die gewünschte Farbe in den Einstellungen mdui-colo1 in der Runtime Einstellen.
                        Je nachdem ob du das Darktheme oder Lighttheme nutzt kannst du dann die entsprechende Farbe des Widgets verändern.
                        Chaot B 3 Replies Last reply Reply Quote 0
                        • Dominik F.
                          @Borio85
                          Ob Dark oder Light Theme entscheidet sich durch die von dir gewählte Hintergrundfarbe bei z.B. Primary Color oder Contend Color. Das bedeutet, wählst du einen dunklen HIntergrund, wird die Schriftfarbe automatisch weiß/hell, wählst du einen hellen Hintergrund, wird die Schriftfarbe automatisch schwarz/dunkel.
                          Zusätzlich dazu, kannst du dann wie oben beschrieben die Schrift oder Widgetfarbe durch setzen von mdui-color1 ändern im jeweiligen Theme.
                          • Chaot
                            Chaot @Dominik F. last edited by
                            @Dominik-F Ich habe dein Widget jetzt mal übernommen und an dritter Stelle eingefügt. Hat sich aber nichts geändert.
                            Seltsamerweise sehe ich ja alles im Editor im Dark-Mode. Aber sobald ich in die VIS schalte ist alles im Light-Mode und ich finde nicht wo das hängt.
                              Borio85 @Dominik F. last edited by
                              @Dominik-F Ahh verstehe, also müsste ich dann überall wo mdui-green steht es durch den Platzhalter color1 usw. austauschen und erst dann könnte ich in in der Runtime die Farben für color1 usw. im laufende Betrieb ändern. Hast recht, ist nice to have, ich habe mich nur gewundert wieso da nichts passiert und bei Primary, Secondary und Content Color es sofort geändert wird. Hab schon gedacht ich hätte etwas falsch konfiguriert.
                              Vielen Dank fürs aufklären.
                              • Chaot
                                @Dominik-F
                                Ich habe mir die CSS jetzt nochmal durchgelesen und bin auf die Zeile 35 gestoßen:
                                /* (3) Umschalten vis-Edit light/dark Theme */
                                Das bezieht sich nur auf den Editor oder sehe ich das falsch?
                                Dominik F. 1 Reply Last reply Reply Quote 0
                                • Dominik F.
                                  Dominik F. @Chaot last edited by Dominik F.
                                  @Chaot sagte in [Vorlage] Vis für Adapter HeatingControl:
                                  @Dominik-F
                                  Ja genau. Ich hatte dich glaube ich erst falsch verstanden.
                                  Mach mir mal bitte n Screenshot damit ich weiß wie das bei dir aussieht.
                                  Zusätzlich mach mir mal n Screenshot von der View abar
                                  • Chaot
                                    • Dominik F.
                                      @Chaot
                                      Und wenn du Links oben aufs Menü gehst, dann auf Einstellungen und dann bei Standard Farben einstellst, ändert sich keine Farbe?
                                      Ich hab hier z.B. folgendes eingestellt:
                                      Da müsste sich eigentlich was ändern bei dir. Wenn du dort was einstellst, z.B. bei Primary Color, dann sollte sich da eigentlich die obere Navigation farblich ändern.
                                      Wenn nicht, verstehe ich es ehrlich gesagt nicht.
                                      Man muss eigentlich nur die Zip Datei als Projekt importieren, diese HeatingControl nennen und dann ist da eigentlich alles vorhanden damit es funktioniert
                                      Chaot 2 Replies Last reply Reply Quote 0
                                      • Chaot
                                        Chaot @Dominik F. last edited by Chaot
                                        @Dominik-F Ja, die Navigationsleiste ändert sich. Aber ich finde nicht wie ich den Hintergrund ändern kann.
                                        Edit: Gefunden - Danke
                                        Dominik F. uwe12489 2 Replies Last reply Reply Quote 0
                                        • Chaot
                                          @Dominik-F Komisch -
                                          Wenn ich die VIS passend einstelle und dann den VIS Editor öffne sind die Einstellungen wieder weg.
                                          • Dominik F.
                                            Was hast du eingestellt damit es funktioniert?
                                            Ich weiß gerade nicht genau was du meinst.
                                            template vis
                                            52
                                            443
                                            89630
