    4. Beta Test js-controller 3.2.x auf GitHub
      Thomas Braun Most Active @SBorg last edited by
      @SBorg @apollon77
      Die 3.2.5 hängt bei mir auch:
      2021-01-10 15:04:31.231  - error: host.raspberrypi startInstance system.adapter.admin.0Invalid version of "js-controller". Installed "3.2.5-0", required ">=2.0.0
      2021-01-10 15:04:35.260  - error: host.raspberrypi startInstance system.adapter.alexa2.0Invalid version of "js-controller". Installed "3.2.5-0", required ">=2.0.0
      2021-01-10 15:04:39.227  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 11919
      2021-01-10 15:04:42.627  - info: backitup.0 (11919) starting. Version 1.8.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.15.4, js-controller: 3.2.5-0
      2021-01-10 15:04:42.699  - info: backitup.0 (11919) [iobroker] backup was activated at 02:42 every 1 day(s)
      2021-01-10 15:04:43.222  - error: host.raspberrypi startInstance system.adapter.javascript.0Invalid version of "js-controller". Installed "3.2.5-0", required ">=2.2.0
      2021-01-10 15:04:47.286  - error: host.raspberrypi startInstance system.adapter.mihome.0Invalid version of "js-controller". Installed "3.2.5-0", required ">=2.0.0
      2021-01-10 15:04:51.278  - info: host.raspberrypi instance system.adapter.nuki-extended.0 started with pid 11940
      2021-01-10 15:04:53.096  - info: nuki-extended.0 (11940) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v14.15.4, js-controller: 3.2.5-0
      2021-01-10 15:04:54.092  - info: nuki-extended.0 (11940) Polling Nuki Web API with a frequency of 10s.
      2021-01-10 15:04:54.093  - info: nuki-extended.0 (11940) Listening for Nuki events on port 51989.
      2021-01-10 15:04:55.223  - error: host.raspberrypi startInstance system.adapter.tado.0Invalid version of "js-controller". Installed "3.2.5-0", required ">=1.4.2
      2021-01-10 15:04:59.227  - error: host.raspberrypi startInstance system.adapter.tr-064.0Invalid version of "js-controller". Installed "3.2.5-0", required ">=2.0.0
      2021-01-10 15:05:03.217  - error: host.raspberrypi startInstance system.adapter.tradfri.0Invalid version of "js-controller". Installed "3.2.5-0", required ">=1.4.2
      2021-01-10 15:05:07.254  - error: host.raspberrypi startInstance system.adapter.web.0Invalid version of "js-controller". Installed "3.2.5-0", required ">=2.0.0
      2021-01-10 15:05:11.263  - error: host.raspberrypi startInstance system.adapter.info.0Invalid version of "js-controller". Installed "3.2.5-0", required ">=2.0.0
      2021-01-10 15:05:15.246  - error: host.raspberrypi startInstance system.adapter.whatsapp-cmb.0Invalid version of "js-controller". Installed "3.2.5-0", required ">=1.4.2
        apollon77 last edited by
        Jupp, sorry, Bitte nochmal neu installieren. fixed
        Thomas Braun SBorg 2 Replies Last reply Reply Quote 0
          apollon77 @SBorg last edited by
          @SBorg Den "iobroker status all" fehler checke ich nachher.
            Thomas Braun Most Active @apollon77 last edited by
            @apollon77 sagte in Beta Test js-controller 3.2.x auf GitHub:
            Stimmt, fixed, startet wieder.
            • SBorg
              SBorg Forum Testing Most Active @apollon77 last edited by
              Done + doppelt gefixt: läuft wieder und der VIS-Dateimanager lüppt auch wieder 👍 😁
                A Former User @apollon77 last edited by
                @apollon77 js-controller 3.2.5 ohne besondere Vorkommnisse. 🙂
                • Feuersturm
                  Feuersturm @apollon77 last edited by
                  @Feuersturm @sigi234 Eine neue Version ist auf GitHub, die das fixen sollte. Bitte prüfen.
                  Ich konnte auch ohne Probleme auf die v.3.2.5 aktualisieren. VIS Dateimanager geht auch wieder und bisher sind keine neuen Probleme aufgefallen.
                  • Wal
                    Wal Developer last edited by
                    Ich muss morgen mal nachschauen, in meinem Doorio-Adapter gibt es ein Error wenn diese Zeilen abgearbeitet werden:
                    clearTimeout(tout1);
                    tout1 = setTimeout(() => {
                        tout1 = null;
                        adapter.setForeignState(adapter.config.call_established, false, true);
                        adapter.setState('CALL_ESTABLISHED', false, true);
                    }, 1000);
                    Die ID von setForeignState ist leer, kommt als Fehler. (adapter.js vom js-controller)
                    Mal sehen ob ich es finde. 😉
                      e-i-k-e @Wal last edited by e-i-k-e
                      Das Update (redis/redis, von 3.1.6 ) lief bei allen Geräten sauber durch, bis jetzt nichts auffälliges.
                      Adapter und Info sind in dauerschleifen. Kann dies mit dem neuen js-controller zutun haben?
                      Edit: Folgender error konnte ich soeben dem log entnehmen.
                      • Feuersturm
                        Feuersturm last edited by Feuersturm
                        @apollon77 Folgende Warnungen hab ich gerade noch bei mir im Log mit der 3.2.5 gefunden. Der dwd Adapter v2.5.2 hat keine Warnungen geworfen.
                        host.beebox(iobrokerMaster)	2021-01-10 21:27:56.216	warn	instance system.adapter.dwd.0 terminated due to SIGABRT
                        host.beebox(iobrokerMaster)	2021-01-10 21:25:04.212	warn	instance system.adapter.dwd.0 already running with pid 3422
                        host.beebox(iobrokerMaster)	2021-01-10 21:07:58.554	warn	instance system.adapter.dwd.0 terminated due to SIGABRT
                        host.beebox(iobrokerMaster)	2021-01-10 21:05:04.194	warn	instance system.adapter.dwd.0 already running with pid 2864
                        Was steckt dahinter und ist es ein Thema für den Controller oder für den dwd Adapter
                          lonsimbt @apollon77 last edited by
                          @apollon77
                          Update auf Version 3.2.5 ist problemlos durchgelaufen. Schwierigkeiten scheint bei mir nur der pushsafer-Adapter zu machen, der nicht mehr startet. Hier der Auszug aus dem Log:
                          pushsafer.0	2021-01-10 22:12:32.695	warn	(26610) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          pushsafer.0	2021-01-10 22:12:32.694	info	(26610) terminating
                          pushsafer.0	2021-01-10 22:12:32.172	error	(26610) adapter.getMessage is not a function
                          pushsafer.0	2021-01-10 22:12:32.172	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8255:34
                          pushsafer.0	2021-01-10 22:12:32.172	error	at Adapter.emit (events.js:314:20)
                          pushsafer.0	2021-01-10 22:12:32.172	error	at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:27:5)
                          pushsafer.0	2021-01-10 22:12:32.172	error	at main (/opt/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:64:5)
                          pushsafer.0	2021-01-10 22:12:32.172	error	at processMessages (/opt/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:54:13)
                          pushsafer.0	2021-01-10 22:12:32.172	error	(26610) TypeError: adapter.getMessage is not a function
                          pushsafer.0	2021-01-10 22:12:32.170	error	(26610) unhandled promise rejection: adapter.getMessage is not a function
                          pushsafer.0	2021-01-10 22:12:32.169	error	(26610) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          pushsafer.0	2021-01-10 22:12:32.149	info	(26610) starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.pushsafer, node: v12.20.0, js-controller: 3.2.5
                          Gruß Marco
                            apollon77 @e-i-k-e last edited by
                            @e-i-k-e wird im nächsten update gefixt
                              apollon77 @Feuersturm last edited by
                              @Feuersturm weiss nicht. stoppe mal, schaue mal das wirklich kein prozess mehr läuft, sonst muss man mal tiefer schauen. Noch jemand anders mit DWD?
                              • Feuersturm
                                Mit "stoppe mal" meinst du ioBroker oder nur den DWD Adapter?
                                  apollon77 @lonsimbt last edited by
                                  @lonsimbt versuch mal bitte die GitHub version?
                                    @Feuersturm nur DWD
                                    • Feuersturm
                                      @Feuersturm nur DWD
                                      Wo erkenne ich, dass kein DWD Prozess mehr läuft?
                                        @Feuersturm An der kommandozeile "ps auxww |grep dwd"
                                        • Feuersturm
                                          @apollon77
                                          ps auxww |grep dwd liefert:
                                          proxmox@ioBrokerBETA:~$ ps auxww |grep dwd
                                          iobroker  5617  0.0 48.9 2719812 2054304 ?     Rl   22:50   4:58 io.dwd.0
                                          proxmox   5711  0.0  0.0  11460  1004 pts/0    S+   22:54   0:00 grep --color=auto dwd
                                          Kurz bevor ich die Instanz ausschalten wollte kam noch dieser Error um die Ecke:
                                          dwd.0	2021-01-10 22:50:10.377	error	(5617) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          dwd.0	2021-01-10 22:50:09.667	info	(5617) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          dwd.0	2021-01-10 22:50:06.771	info	(5617) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.18.3, js-controller: 3.2.5
                                            @Feuersturm und mehr log nicht? am besten stoppen wie gesagt undd ann falls noch ein prozess läuft den mal killen
                                            1.0k
                                            js-controller
                                            25
                                            287
                                            46397
